AN 1189 Incorporate Occupancy sensor into Dimmable Switch
1,241 次查看
preveenp
Can you please guide me incorportating occupancy sensor functionality into dimmable switch.
I have designed a custom board based on dimmable light. I want to add a occupancy sensor into the dimmable switch so that it would have two end points.
I basically want to incorporate the Occupancy sensor subporject into dimmable switch sub porject in AN1189.
The PIR Sensor is on DIO16.
Preveen
0 回复数
