88W8997 easyMesh
88W8997 easyMesh
3,276 次查看
frank-TC
hi I'm frank. I am testing on Linux OS using SPB228 (purchased from hd wireless) module based on Marvell 88W8997. I tried to implement WIFI MESH, but the driver for easyMesh was not provided, so I was looking for other products. Then I found DVK-ST60-2230C Evaluation kit made based on 88W8997 states that it supports easy mesh. Can I get the Linux os driver for the kit? where? Also, is it possible to apply that driver to spb228?
3 回复数
3,252 次查看
stephanie_m
Could you please help us contacting the module manufacturer for some more information about the available resources for the module ?
The device indeed supports Mesh, still, you will need to check with the module manufacturer to validate the available drivers and enablement available for the specific module
Estephania
3,239 次查看
frank-TC
Thank you,
The URL where the product was purchased is https://www.hd-wireless.com/
I purchased the SPB228 Evaluation board(HDA228-USB-SDIO) module here, and brief information about the product is http://docker.hd-wireless.com/Support/SPB228
If you don't log in, you can only see very limited information.
Pls, ask you to confirm about supporting Mesh..
3,226 次查看
stephanie_m
Hello ,
Yes, I understand, that is the reason why I mentioned the chip supports that but you will need to verify with the manufacturer of your module about the enablement of those capabilities within their drivers.
Estephania
