88W8997 Bluetooth cannot been tuned on when switch Android 13 BT toggle on
4,278件の閲覧回数
yao_feng
Issue: Bluetooth does not get powered on
Description: when we click bluetooth on (Android 13), it does not stick to ON and it returns to off. Please find herewith complete ad log during bluetooth on till it becomes off automatically.
Platform: MTK8195V
OS version/kernel: Android 13
module: AW-CM276NF (88W8997)
WiFi/BT driver/FW version: PCIE8997--16.92.21.p84.4-MM5X16368.p2-GPL-(FP92)
Blue stack version: NXP BT Vendor HAL Ver: 009.016 (VendorHAL_v009.011.016 (nxp.com))
Logs:
04-14 07:20:12.260 622 622 I bt-vnd-nxp: bt_vnd_init --- BT Vendor HAL Ver: 009.016 ---
04-14 07:20:12.260 622 622 D bt-vnd-nxp: vnd_load_conf(L695): Attempt to load conf from /vendor/etc/bluetooth/bt_vendor.conf
04-14 07:20:12.260 622 622 I bt-vnd-nxp: bt_vnd_init(L1490): Max supported Log Level: 5
04-14 07:20:12.260 622 622 I bt-vnd-nxp: bt_vnd_init(L1491): Selected Log Level:5
04-14 07:20:12.260 622 622 I bt-vnd-nxp: BT_VHAL Log Level:5
04-14 07:20:12.260 622 622 D bt-vnd-nxp: bt_vnd_init(L1502): BD address received from stack 2F:0B:A1:AA:BF:04
04-14 07:20:12.260 622 622 D bt-vnd-nxp: bt_vnd_op(L1513): opcode = 0
04-14 07:20:12.260 622 622 D bt-vnd-nxp: bt_vnd_op(L1528): power on --------------------------------------
04-14 07:20:12.260 622 622 D bt-vnd-nxp: bt_vnd_op(L1513): opcode = 3
04-14 07:20:12.260 622 622 D bt-vnd-nxp: bt_vnd_op(L1561): open serial port --------------------------------------
04-14 07:20:12.260 622 622 D bt-vnd-nxp: bt_vnd_op(L1580): baudrate_bt 3000000
04-14 07:20:12.260 622 622 D bt-vnd-nxp: bt_vnd_op(L1581): baudrate_fw_init 115200
04-14 07:20:12.260 622 622 D bt-vnd-nxp: get_prop_int32(L828): get_prop_int32: bluetooth.nxp.fw_downloaded = -1
04-14 07:20:12.261 622 622 D bt-vnd-nxp: uart_set_speed(L968): Baudrate set to 115200
04-14 07:20:12.261 622 622 I bt-vnd-nxp: bt_vnd_op(L1646): open uart port successfully, fd=7, mchar_port=/dev/ttyUSB0
04-14 07:20:12.261 622 622 D bt-vnd-nxp: get_prop_int32(L828): get_prop_int32: bluetooth.nxp.fw_downloaded = -1
04-14 07:20:12.261 622 622 D bt-vnd-nxp: bt_vnd_op(L1693): Error: No such file or directory (2)
04-14 07:20:12.261 622 622 D bt-vnd-nxp: config_uart(L1191): start send bt hci reset
04-14 07:20:12.261 622 622 D bt-vnd-nxp: config_uart(L1194): Write HCI Reset command
04-14 07:20:12.261 622 622 D bt-vnd-nxp: read_hci_event(L756): start read hci event 0x4
04-14 07:20:12.261 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.261 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.271 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.271 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.281 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.281 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.292 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.292 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.302 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.302 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.312 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.312 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.322 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.322 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.332 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.332 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.342 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.342 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.352 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.353 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.363 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.363 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.373 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.373 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.383 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.383 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.393 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.393 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.403 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.403 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.414 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.414 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.424 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.424 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.434 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.434 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.444 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.444 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.454 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.454 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.465 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.465 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.475 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.475 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.485 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.486 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.496 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.496 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.506 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.506 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.516 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.516 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.526 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.526 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.536 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.537 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.547 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.547 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.557 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.557 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.567 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.567 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.577 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.577 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.587 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.588 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.598 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.598 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.608 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.608 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.618 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.618 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.628 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.628 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.639 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.639 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.649 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.649 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.659 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.659 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.669 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.669 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.680 622 622 D bt-vnd-nxp: read_hci_event(L776): start read hci event code and len
04-14 07:20:12.680 622 622 D bt-vnd-nxp: read_hci_event(L788): start read hci event para
04-14 07:20:12.680 622 622 D bt-vnd-nxp: read_hci_event(L806): over read count = 7
04-14 07:20:12.680 622 622 D bt-vnd-nxp: config_uart(L1207): over send bt hci reset
04-14 07:20:12.680 622 622 D bt-vnd-nxp: config_uart(L1210): start set fw baud rate according to baudrate_bt
04-14 07:20:12.680 622 622 D bt-vnd-nxp: config_uart(L1213): set fw baudrate as 3000000
04-14 07:20:12.680 622 622 D bt-vnd-nxp: config_uart(L1228): start read hci event
04-14 07:20:12.680 622 622 D bt-vnd-nxp: read_hci_event(L756): start read hci event 0x4
04-14 07:20:12.680 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.680 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.690 622 622 D bt-vnd-nxp: read_hci_event(L760): read hci event 0x04 failed, retry
04-14 07:20:12.690 622 622 D bt-vnd-nxp: read_hci_event(L761): Error Try again (11)
04-14 07:20:12.700 622 622 D bt-vnd-nxp: read_hci_event(L776): start read hci event code and len
04-14 07:20:12.700 622 622 D bt-vnd-nxp: read_hci_event(L788): start read hci event para
04-14 07:20:12.700 622 622 D bt-vnd-nxp: read_hci_event(L806): over read count = 7
04-14 07:20:12.700 622 622 D bt-vnd-nxp: config_uart(L1236): over send bt chip baudrate
04-14 07:20:12.761 622 622 D bt-vnd-nxp: config_uart(L1239): start set host baud rate as baudrate_bt
04-14 07:20:12.761 622 622 D bt-vnd-nxp: uart_set_speed(L968): Baudrate set to 3000000
04-14 07:20:12.782 622 622 D bt-vnd-nxp: bt_vnd_op(L1737): open serial port over --------------------------------------
04-14 07:20:12.783 622 622 D bt-vnd-nxp: bt_vnd_op(L1513): opcode = 1
Please help to check anything wrong and have your opinion and suggestion.
Thanks.
4,272件の閲覧回数
yao_feng
