OL2385 Sigfox plus FSK
1,155件の閲覧回数
erichnast
I know that the OL2385 can run the SigFOX stack, so now problem with this.  However, is it possible that in my application, I could bypass the SIGFOX stack and use the OL2385 as a normal FSK radio, running my propriety protocol.  Reason I need this is for a fallbcak should the SIGFOX network go down...  I don't want to have a separate radio chip as my fall back option, so would like to do both on the same OL2385.
957件の閲覧回数
mario_castaneda
Hi Erick,
You can use the OL2385, the datasheet mentioned that supports this FSK radio.
For more details please contact your local sales. as you know this product is in pre production status
Mario
