KW41Z Thread
KW41Z Thread
4,178件の閲覧回数
sensenthuran
Can the  Home Kit sensors connect to KW41Z based border router network? , if so, how we should configure the KW41Z router to commission?
example sensors
Eve Door & Window - Apple HomeKit
https://www.amazon.ca/Eve-Door-Window-Automatically-Notifications/dp/B08BDM47S2?ref_=ast_sto_dp&th=1...
Wemo Smart Plug with Thread
https://www.amazon.com/HomeKit-Enabled-Automation-Compatible-Controller/dp/B09T4S3QKC/ref=sr_1_3?cri...
ラベル(2)
3 返答(返信)
3,936件の閲覧回数
patrick_pan
Hi, Sen
Theoretically the KW41 Thread BR is not HomeKit device, so it will not accept Homekit Accessory to join its network since the commissioning and pairing stages of Homekit Accessory requires either HW or SW MFI certified messages like credential / provisioning data be exchanged between Homekit Controller and Accessory. The KW41 Thread BR most probably will not provide these mandatory Homekit required information so Homekit Accessory wouldn't join it successfully.
B.R
Patrick
3,927件の閲覧回数
sensenthuran
Thanks @patrick_pan
We already tested KW41Z Thread Border gateway with Eval board sensors.
Would your recommend any commercial Thread sensors that can connect to NXP KW41Z Thread Border Gateway?
4,020件の閲覧回数
estephania_mart
Please help us checking this page with the current support of HOMEKIT , there you can also find some details on how to seek for more details as well.
