WiFi chip detection problem
13,777件の閲覧回数
bgaurav1718
Hello all,
I have a custom board based on iMX8MP with U-Blox Maya-W266 wifi module integrated. (Schematic diagram snippets attached).
bgaurav1718_0-1729657870368.pngbgaurav1718_0-1729657870368.pngbgaurav1718_2-1729657982861.pngbgaurav1718_2-1729657982861.png
SD2_X pins from U-Blox are connected to GPIO2 port of iMX8MP as shown below:
After booting the board, I followed instructions from "Getting Started with NXP-based Wireless Modules on i.MX 8M Quad EVK Running Linux OS" to bring up the wifi module:
However, I do not see any related messages in dmesg command output. I verified the configurations of wifi_mod_para.conf to be correct. Also, the firmware binary file is present inside nxp directory.
I have no idea on what to check for in further steps. I am not sure whether modifications in device tree are needed since the hardware designs are basically identical to the im8mp-evk design.
Any guidance would be of great help. Thank you!!
13,020件の閲覧回数
shaun_wu
Hello
I listed SDIO interface check items here. Please compare with your design.
16 返答(返信)
13,695件の閲覧回数
shaun_wu
Hello @bgaurav1718
1. I think mmc2 is not sdio interface you used. It is used for boot. You device didn't detected Wi-Fi card. There is a simply way to double check, our sd interface support hot swap. You could pullout when board running, see if mmc2 shows sd card removed.
2. I cant find any sd node from your device tree, could you double check on your side? You could go to our github to check 8mp example devise treelinux-imx/arch/arm64/boot/dts/freescale/imx8mp-evk.dts at lf-6.6.y · nxp-imx/linux-imx · GitHub. A sdio node should like following:
&usdhc3 {
assigned-clocks = <&clk IMX8MP_CLK_USDHC3>;
assigned-clock-rates = <400000000>;
pinctrl-names = "default", "state_100mhz", "state_200mhz";
pinctrl-0 = <&pinctrl_usdhc3>;
pinctrl-1 = <&pinctrl_usdhc3_100mhz>;
pinctrl-2 = <&pinctrl_usdhc3_200mhz>;
bus-width = <8>;
non-removable;
status = "okay";
Best Regards
Shaun
13,667件の閲覧回数
bgaurav1718
I installed a new image and looked through its device tree.
usdhc1 is mapped to mmc@30b40000,
usdhc2 is mapped to mmc@30b50000,
usdhc3 is mapped to mmc@30b60000.
bgaurav1718_1-1729754242320.pngbgaurav1718_1-1729754242320.pngbgaurav1718_2-1729754254245.pngbgaurav1718_2-1729754254245.png
I think this is what the device tree configuration is supposed to be. Still I get the same message
[ 2.107370] mmc2: new HS400 Enhanced strobe MMC card at address 0001
NOTE: I was reading an this article related to the issue. There, it mentions following:
Regarding the schematic, I have attached an image in original question. The pins from UBlox are connected to SD2_xxxx pins of the processor.  These pins belong to USDHC2.
13,662件の閲覧回数
bgaurav1718
usdhc2 is at address 30b50000. It is aliased as mmc1. So, mmc1 is probably where the WiFi module is connected. But there is only one message in kernel log related to mmc1:
[ 3.312631] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
13,656件の閲覧回数
shaun_wu
Hello @bgaurav1718
Please try add this node to your dts.
&usdhc2 {
assigned-clocks = <&clk IMX8MP_CLK_USDHC2>;
bus-width = <8>;
non-removable;
status = "okay";
Best Regards
Shaun
13,512件の閲覧回数
bgaurav1718
Hi @shaun_wu
I tested the signals in SDIO line. The clock seems fine. But the command is not correct. It needed to be 0 but it is something else. So, I guess the settings in device tree I am using is still wrong.
13,021件の閲覧回数
shaun_wu
Hello
13,635件の閲覧回数
bgaurav1718
I have added the details. Since I am using dts file decompiled from dtb file, the symbols you mentioned are converted into corresponding hex values.
I tried to compile this dts into dtb by commenting out the lines that were not shown in your device tree. The compiler showed some errors, so I had to include those lines.
Hex values in pinctrl-X belong to following:
Even with this entry in device tree, the problem still exits.
Since there is only one parameter in the device tree you suggested, I tried removing the second parameter. I still get the same result.
13,684件の閲覧回数
bgaurav1718
We are using a custom board with UBlox WiFi module soldered onto the board. So, I don't think hot swapping is feasible here. Do you have any other ways I could possibly try?
13,681件の閲覧回数
shaun_wu
Hello @bgaurav1718
You could check shematic.
Best Regards
Shaun
13,711件の閲覧回数
Amelia777
After struggling with a frustrating WiFi chip detection problem, I decided to take a break and called Ukraine Cleaners for house cleaning in Edmonds. They did an amazing job, leaving my home spotless and stress-free. Definitely lifted my spirits!
13,720件の閲覧回数
bgaurav1718
I don't think WiFi module is connected to other sd interfaces.
Device tree is attached below:
13,747件の閲覧回数
bgaurav1718
UPDATE: I found following messages in kernel log.
[ 2.024245] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[ 2.103390] mmc2: new HS400 Enhanced strobe MMC card at address 0001
However, it is supposed to be detected as:
mmc1: new ultra high speed DDR50 SDIO card at address 0001
13,741件の閲覧回数
shaun_wu
Hello @bgaurav1718
Could you check with following cmd:
dmesg       #check driver and firmware loading
ifconfig -a #check if maln0 uap0 interface enabled
Best Regards
Shaun
13,737件の閲覧回数
bgaurav1718
The module is detected as SD card. I have added snippet from kernel log above.
Also, no mlan0 and uap0 interfaces are available.
13,732件の閲覧回数
shaun_wu
Hello @bgaurav1718
I didn't see the log you shared, could you reshare?
I see the card was detected, it was detected as sdio card, not sd card. Thats what we expected. No problem.
Best Regards
Shaun
13,725件の閲覧回数
shaun_wu
--> Sorry I misunderstand your post, you are right this is not we expected. Could you share dts you used? And could you double confirm which sd interface you are using?
Best Regards
Shaun
%3CLINGO-SUB%20id%3D%22lingo-sub-1979772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81U-Blox%20Maya-W266%20wifi%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%81%9FiMX8MP%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(%E3%82%B9%E3%82%B1%E3%83%9E%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%20%E3%83%80%E3%82%A4%E3%82%A2%E3%82%B0%E3%83%A9%E3%83%A0%20%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%E3%81%8C%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bgaurav1718_0-1729657870368.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bgaurav1718_0-1729657870368.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306288iF747BF3FDE3BFB3A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bgaurav1718_0-1729657870368.png%22%20alt%3D%22bgaurav1718_0-1729657870368.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebgaurav1718_0-1729657870368.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bgaurav1718_2-1729657982861.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bgaurav1718_2-1729657982861.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306290iA1A7CD1E5267D0E9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bgaurav1718_2-1729657982861.png%22%20alt%3D%22bgaurav1718_2-1729657982861.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebgaurav1718_2-1729657982861.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EU-Blox%E3%81%AESD2_X%E3%83%94%E3%83%B3%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%ABiMX8MP%E3%81%AEGPIO2%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bgaurav1718_1-1729657902978.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bgaurav1718_1-1729657902978.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306289i3EA5A5AABB8F216C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bgaurav1718_1-1729657902978.png%22%20alt%3D%22bgaurav1718_1-1729657902978.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebgaurav1718_1-1729657902978.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%80%8C%3CSPAN%3EGetting%20Started%20with%20NXP-based%20Wireless%20Modules%20on%20i.MX%208M%20Quad%20EVK%20Running%20Linux%20OS%3C%2FSPAN%3E%E3%80%8D%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81wifi%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bgaurav1718_3-1729658308034.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bgaurav1718_3-1729658308034.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306293iC59C68E396B19564%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bgaurav1718_3-1729658308034.png%22%20alt%3D%22bgaurav1718_3-1729658308034.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebgaurav1718_3-1729658308034.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81dmesg%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82wifi_mod_para.conf%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AFnxp%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%95%E3%82%89%E3%81%AA%E3%82%8B%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E4%BD%95%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%8B%E8%A6%8B%E5%BD%93%E3%81%8C%E3%81%A4%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A8%AD%E8%A8%88%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%ABim8mp-evk%E8%A8%AD%E8%A8%88%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%82%93%E3%81%AA%E6%8C%87%E5%B0%8E%E3%81%A7%E3%82%82%E5%A4%A7%E3%81%84%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2006657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2006657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AFSDIO%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E9%A0%85%E7%9B%AE%E3%82%92%E3%83%AA%E3%82%B9%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1984550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1984550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186613%22%20target%3D%22_blank%22%3E%40shaun_wu%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3ESDIO%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E4%BF%A1%E5%8F%B7%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%99%82%E8%A8%88%E3%81%AF%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%AA%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%820%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E5%88%A5%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%81%8C%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%81%BE%E3%81%A0%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202024-10-30%20110524.png%22%20style%3D%22width%3A%20990px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202024-10-30%20110524.png%22%20style%3D%22width%3A%20990px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F307660i6CD240D1D8B211A1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202024-10-30%20110524.png%22%20alt%3D%22Screenshot%202024-10-30%20110524.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%202024-10-30%20110524.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1981572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1981572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A9%B3%E7%B4%B0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82dtb%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8B%E3%82%89%E9%80%86%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9Fdts%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%E3%81%AF%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8Bhex%E5%80%A4%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bgaurav1718_3-1729817765866.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bgaurav1718_3-1729817765866.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306871iD662E67B5DC3117B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bgaurav1718_3-1729817765866.png%22%20alt%3D%22bgaurav1718_3-1729817765866.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebgaurav1718_3-1729817765866.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AEdts%E3%82%92dtb%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E8%A1%8C%E3%82%92%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E7%A4%BA%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E8%A1%8C%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Epinctrl-X%20%E3%81%AE%2016%20%E9%80%B2%E6%95%B0%E5%80%A4%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%82%E3%81%AE%E3%81%AB%E5%B1%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bgaurav1718_2-1729817216030.png%22%20style%3D%22width%3A%20194px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bgaurav1718_2-1729817216030.png%22%20style%3D%22width%3A%20194px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306870i19C4D432430DD69D%2Fimage-dimensions%2F194x278%3Fv%3Dv2%22%20width%3D%22194%22%20height%3D%22278%22%20role%3D%22button%22%20title%3D%22bgaurav1718_2-1729817216030.png%22%20alt%3D%22bgaurav1718_2-1729817216030.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebgaurav1718_2-1729817216030.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AB%E3%81%93%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%8C%E3%81%82%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%BE%E3%81%A0%E8%A7%A3%E6%B6%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8F%90%E6%A1%88%E3%81%97%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AB%E3%81%AF%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C1%E3%81%A4%E3%81%97%E3%81%8B%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%812%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0%E5%90%8C%E3%81%98%E7%B5%90%E6%9E%9C%E3%82%92%E5%BE%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1981011%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1981011%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F218700%22%20target%3D%22_blank%22%3E%40bgaurav1718%3C%2FA%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92DTS%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26amp%3Busdhc2%20%7B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_USDHC2%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%88%20%3D%20%26lt%3B400000000%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Epinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%2C%20%22state_100mhz%22%2C%20%22state_200mhz%22%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%94%E3%83%B3ctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc3%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%94%E3%83%B3ctrl-1%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc3_100mhz%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%94%E3%83%B3ctrl-2%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc3_200mhz%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%90%E3%82%B9%E5%B9%85%20%3D%20%26lt%3B8%26gt%3B%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%97%E4%B8%8D%E5%8F%AF%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Estatus%20%3D%20%22%E5%A4%A7%E4%B8%88%E5%A4%AB%22%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUSDHC%202%20%E3%81%AF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%2030b50000%20%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%20mmc1%20%E3%81%A8%E3%81%97%E3%81%A6%E3%82%A8%E3%82%A4%E3%83%AA%E3%82%A2%E3%82%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81mmc1%E3%81%AF%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8FWiFi%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E6%89%80%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%20mmc1%20%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%201%20%E3%81%A4%E3%81%A0%E3%81%91%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%203.312631%5D%20mmc1%3A%2030b50000.mmc%20%5B30b50000.mmc%5D%20%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EUSDHC1%20%E3%81%AF%20mmc%4030b40000%20%E3%81%AB%E3%83%9E%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20%3CA%20href%3D%22mailto%3Ammc%4030b40000%2C%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E3%80%82%3C%2FA%3E%3C%2FP%3E%3CP%3EUSDHC%202%20%E3%81%AF%20%3CA%20href%3D%22mailto%3Ammc%4030b40000%2C%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E3%20mmc%4030b50000%20%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FA%3E%3C%2FP%3E%3CP%3EUSDHC%203%20%E3%81%AF%20mmc%4030b60000%20%E3%81%AB%E3%83%9E%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bgaurav1718_0-1729754219672.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bgaurav1718_0-1729754219672.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306687i67020ECFD3181961%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bgaurav1718_0-1729754219672.png%22%20alt%3D%22bgaurav1718_0-1729754219672.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebgaurav1718_0-1729754219672.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bgaurav1718_1-1729754242320.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bgaurav1718_1-1729754242320.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306688i2FA893957E339F8B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bgaurav1718_1-1729754242320.png%22%20alt%3D%22bgaurav1718_1-1729754242320.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebgaurav1718_1-1729754242320.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bgaurav1718_2-1729754254245.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bgaurav1718_2-1729754254245.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306689iBB51AD92AB3E9862%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bgaurav1718_2-1729754254245.png%22%20alt%3D%22bgaurav1718_2-1729754254245.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebgaurav1718_2-1729754254245.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%83%B3%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CDIV%3E%3CBLOCKQUOTE%3E%3CDIV%3E%3CSPAN%3E%5B%202.107370%5D%20mmc2%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200001%20%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20HS400%20%E6%8B%A1%E5%BC%B5%E3%82%B9%E3%83%88%E3%83%AD%E3%83%9C%20MMC%20%E3%82%AB%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FBLOCKQUOTE%3E%3C%2FDIV%3E%3CP%3E%E6%B3%A8%3A%E7%A7%81%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.silabs.com%2Fs%2Farticle%2Flinux-sdio-detection%3Flanguage%3Den_US%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%3C%2FA%3E%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%26nbsp%3B%E3%81%9D%E3%81%93%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%BF%B0%E3%81%B9%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bgaurav1718_4-1729755591690.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bgaurav1718_4-1729755591690.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306698iC5288EE41668A7FC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bgaurav1718_4-1729755591690.png%22%20alt%3D%22bgaurav1718_4-1729755591690.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebgaurav1718_4-1729755591690.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%A6%82%E7%95%A5%E5%9B%B3%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E5%85%83%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E7%94%BB%E5%83%8F%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82UBlox%20%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%20SD2_xxxx%20%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AFUSDHC2%E3%81%AB%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bgaurav1718_3-1729755294669.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bgaurav1718_3-1729755294669.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306694i10D31F4539978506%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bgaurav1718_3-1729755294669.png%22%20alt%3D%22bgaurav1718_3-1729755294669.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebgaurav1718_3-1729755294669.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F218700%22%20target%3D%22_blank%22%3E%40bgaurav1718%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%B7%E3%82%A7%E3%83%9E%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUBlox%20WiFi%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%8F%E3%83%B3%E3%83%80%E4%BB%98%E3%81%91%E3%81%97%E3%81%9F%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A7%E3%81%99%E3%81%8B%E3%82%89%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%83%9B%E3%83%83%E3%83%88%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%81%AF%E5%AE%9F%E7%8F%BE%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%96%E3%81%AB%E8%A9%A6%E3%81%99%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F218700%22%20target%3D%22_blank%22%3E%40bgaurav1718%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E1.mmc2%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fsdio%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%96%E3%83%BC%E3%83%88%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8CWi-Fi%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E7%B0%A1%E5%8D%98%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81SD%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AF%3CSPAN%3E%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E5%BC%95%E3%81%8D%E5%87%BA%E3%81%97%E3%81%A6%E3%80%81mmc2%E3%81%8CSD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2.%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%8B%E3%82%89sd%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%81%B4%E3%81%A7%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AEgithub%E3%81%AB%E8%A1%8C%E3%81%A3%E3%81%A6%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.6.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk.dts%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Elf-6.6.y%20%C2%B7%20nxp-imx%2Flinux-imx%C2%B7GitHub%3C%2FA%3E%20%E3%81%A7%E3%81%99%E3%80%82sdio%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%26amp%3Busdhc3%20%7B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_USDHC3%26gt%3B%3B%3CBR%20%2F%3E%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%83%AC%E3%83%BC%E3%83%88%20%3D%20%26lt%3B400000000%26gt%3B%3B%3CBR%20%2F%3Epinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%2C%20%22state_100mhz%22%2C%20%22state_200mhz%22%3B%3CBR%20%2F%3E%E3%83%94%E3%83%B3ctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc3%26gt%3B%3B%3CBR%20%2F%3E%E3%83%94%E3%83%B3ctrl-1%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc3_100mhz%26gt%3B%3B%3CBR%20%2F%3E%E3%83%94%E3%83%B3ctrl-2%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc3_200mhz%26gt%3B%3B%3CBR%20%2F%3E%E3%83%90%E3%82%B9%E5%B9%85%20%3D%20%26lt%3B8%26gt%3B%3B%3CBR%20%2F%3E%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%97%E4%B8%8D%E5%8F%AF%3B%3CBR%20%2F%3Estatus%20%3D%20%22%E5%A4%A7%E4%B8%88%E5%A4%AB%22%3B%3CBR%20%2F%3E%7D%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%A4%E3%83%A9%E3%82%A4%E3%83%A9%E3%81%99%E3%82%8BWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E8%8B%A6%E3%81%97%E3%82%93%E3%81%A0%E5%BE%8C%E3%80%81%E7%A7%81%E3%81%AF%E4%BC%91%E6%86%A9%E3%82%92%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B1%BA%E3%82%81%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fukrainecleaners.com%2Fedmonds%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E3%82%A8%E3%83%89%E3%83%A2%E3%83%B3%E3%82%BA%E3%81%AE%3CSPAN%3E%E3%83%8F%E3%82%A6%E3%82%B9%3C%2FSPAN%3E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FA%3E%E3%81%AE%E3%81%9F%E3%82%81%E3%81%ABUkraine%20Cleaners%E3%81%AB%E9%9B%BB%E8%A9%B1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%BD%BC%E3%82%89%E3%81%AF%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E4%BB%95%E4%BA%8B%E3%82%92%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%80%81%E7%A7%81%E3%81%AE%E5%AE%B6%E3%82%92%E3%81%8D%E3%82%8C%E3%81%84%E3%81%A7%E3%82%B9%E3%83%88%E3%83%AC%E3%82%B9%E3%81%AE%E3%81%AA%E3%81%84%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E9%96%93%E9%81%95%E3%81%84%E3%81%AA%E3%81%8F%E7%A7%81%E3%81%AE%E7%B2%BE%E7%A5%9E%E3%82%92%E9%AB%98%E6%8F%9A%E3%81%95%E3%81%9B%E3%81%BE%E3%81%97%E3%81%9F!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bgaurav1718_0-1729671959157.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bgaurav1718_0-1729671959157.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306372iAEB111CD07B63C8A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bgaurav1718_0-1729671959157.png%22%20alt%3D%22bgaurav1718_0-1729671959157.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebgaurav1718_0-1729671959157.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EWiFi%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E4%BB%96%E3%81%AESD%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AB%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CSPAN%3E%5B%202.024245%5D%20mmc2%3A%2030b60000.mmc%20%5B30b60000.mmc%5D%20%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCADMA%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%5B%202.103390%5D%20mmc2%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200001%20%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20HS400%20%E6%8B%A1%E5%BC%B5%E3%82%B9%E3%83%88%E3%83%AD%E3%83%9C%20MMC%20%E3%82%AB%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E--%26gt%3B%20%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E8%AA%A4%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fdts%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%BE%E3%81%9F%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BSD%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F218700%22%20target%3D%22_blank%22%3E%40bgaurav1718%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%85%B1%E6%9C%89%E3%81%97%E3%81%9F%E3%83%AD%E3%82%B0%E3%81%8C%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%89%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%86%8D%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AF%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8Fsdio%E3%82%AB%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AFSD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%AD%E3%82%B0%E3%81%8B%E3%82%89%E3%82%B9%E3%83%8B%E3%83%9A%E3%83%83%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81mlan0%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%A8%20uap0%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F218700%22%20target%3D%22_blank%22%3E%40bgaurav1718%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AC%A1%E3%81%AEcmd%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3Edmesg%20%23check%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A8%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3C%2FP%3E%0A%3CP%3Eifconfig%20-a%20%23check%20maln0%20UAP0%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AA%E5%A0%B4%E5%90%88%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AWiFi%E3%83%81%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%E6%9B%B4%E6%96%B0%EF%BC%9A%20%3C%2FSTRONG%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%AD%E3%82%B0%E3%81%A7%E6%AC%A1%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CDIV%3E%3CBLOCKQUOTE%3E%3CDIV%3E%3CSPAN%3E%5B%202.024245%5D%20mmc2%3A%2030b60000.mmc%20%5B30b60000.mmc%5D%20%E3%81%AE%20SDHCI%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCADMA%E3%81%AE%E4%BD%BF%E7%94%A8%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%202.103390%5D%20mmc2%3A%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200001%20%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%20HS400%20%E6%8B%A1%E5%BC%B5%E3%82%B9%E3%83%88%E3%83%AD%E3%83%9C%20MMC%20%E3%82%AB%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FBLOCKQUOTE%3E%3C%2FDIV%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Emmc1%3A%20%E6%96%B0%E3%81%97%E3%81%84%E8%B6%85%E9%AB%98%E9%80%9F%20DDR50%20SDIO%20%E3%82%AB%E3%83%BC%E3%83%89%20(%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200001)%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E
