SDMA Loading issue: i.MX8MP
301件の閲覧回数
Sanjiv_Mns
Platform
  • i.MX8M Plus EVK, kernel 6.12.49-lts-next-g42fbadd4b2e9-dirty
  • WiFi/BT module: AW-XM729, driver btnxpuart
  • Same hardware/kernel, two Yocto images: imx-image-core (BT works) vs imx-image-multimedia (BT fails)
Issue
  • On the multimedia image, imx-sdma@30bd0000 takes ~60s to report firmware ready: [ 3.11] imx-sdma 30bd0000.dma-controller: sdma or sdma firmware not ready!
    [ 60.40] imx-sdma 30bd0000.dma-controller: firmware found.
  • btnxpuart probes the BT UART at ~3–7s — before SDMA is ready — so the UART can't get DMA channels, and BT's HCI_Reset times out:
    imx-uart 30860000.serial: We cannot prepare for the RX/TX slave dma!
    Bluetooth: hci0: Opcode 0x0c03 failed: -110
  • On the working core image, SDMA is ready by ~3.7s, before BT probes — no issue.
Please Help here!
タグ(3)
3 返答(返信)
229件の閲覧回数
weidong_sun
Dear @Sanjiv_Mns ,
I built imx-image-multimedia based on L6.12.49.2.2.0 yocto source, run it on i.mx8mp-evk.
weidong_sun_0-1787287166486.pngweidong_sun_0-1787287166486.pngweidong_sun_1-1787287192914.pngweidong_sun_1-1787287192914.pngweidong_sun_2-1787287252963.pngweidong_sun_2-1787287252963.png
The IW623 module I am using is AW-XM729-PUR, which is M.2 module with PCIE interface.
If you are using SDIO interface for WIFI, the dtb file should be imx8mp-evk-usdhc1-m2.dtb
then run:
# modprobe btnxpuart
#hciconfig -a
hci0 interface will be listed.
[Note]
Default driver in imx-image-multimedia supports IW623, It uses AW693 firmware.
Thanks!
Weidong
231件の閲覧回数
weidong_sun
Dear @Sanjiv_Mns ,
Any update ?
Could you tell me SDIO or PCIE interface you are using?
Thanks!
weidong
256件の閲覧回数
weidong_sun
Dear @Sanjiv_Mns ,
Thanks for your feedback.
I will setup environment to test imx-image-multimeadia + IW623.
I need some time to prepare it, please wait for my test result.
By the way, AW-XM729 has 2 kinds of types, AW-XM729-PUR or AW-XM729-SUR?
Thanks!
Weidong
%3CLINGO-SUB%20id%3D%22lingo-sub-2405787%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESDMA%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AE%E5%95%8F%E9%A1%8C%3A%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405787%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3Ei.MX8M%20Plus%20EVK%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%206.12.49-lts-next-g42fbadd4b2e9-dirty%3C%2FLI%3E%3CLI%3EWiFi%2FBT%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3AAW-XM729%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90btnxpuart%3C%2FLI%3E%3CLI%3E%E5%90%8C%E3%81%98%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%2F%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7%E3%80%81Yocto%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C2%E3%81%A4%3Aimx-image-core(BT%E3%81%AF%E5%8B%95%E4%BD%9C)vs%20imx-image-multimedia(BT%E3%81%8C%E5%A4%B1%E6%95%97)%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%E5%95%8F%E9%A1%8C%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%AF%E3%80%81%20%3CSTRONG%3Eimx-sdma%4030bd0000%3C%2FSTRONG%3E%20%E3%81%8C%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E7%B4%8460%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%3A%20%3CSTRONG%3E%5B%203.11%5D%20imx-sdma%2030bd0000.dma-controller%3A%20sdma%E3%81%BE%E3%81%9F%E3%81%AFSDMA%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E6%BA%96%E5%82%99%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93!%20%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%2060.40%20%5D%20IMX-SDMA%2030bd0000.dma-controller%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E7%99%BA%E8%A6%8B%E3%80%82%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3EBTNXPUART%E3%81%AF%E3%80%81SDMA%E3%81%8C%E6%BA%96%E5%82%99%E3%81%95%E3%82%8C%E3%82%8B%E5%89%8D%E3%81%AE~3%E3%80%9C7%E7%A7%92%E3%81%A7BT%20UART%E3%82%92%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81UART%E3%81%AFDMA%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81BT%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88HCI_Reset%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CSTRONG%3Eimx-uart%2030860000.serial%3A%20RX%2FTX%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96DMA%E3%81%AB%E5%82%99%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93!%20%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EBluetooth%3A%20hci0%3A%20Opcode%200x0c03%20failed%20%3A%20-110%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%E5%8B%95%E4%BD%9C%E4%B8%AD%E3%81%AE%E3%82%B3%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%AF%E3%80%81BT%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E5%89%8D%E3%81%AB%E7%B4%843.7%E7%A7%92%E3%81%A7SDMA%E3%81%AE%E6%BA%96%E5%82%99%E3%81%8C%E6%95%B4%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SDMA%20Loading%20issue%3A%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262813%22%20target%3D%22_blank%22%3E%40Sanjiv_Mns%3C%2FA%3E%E6%A7%98%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%94%E6%84%8F%E8%A6%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Eimx-image-multimedia%20%2B%20IW623%20%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%BA%96%E5%82%99%E3%81%AB%E5%B0%91%E3%81%97%E6%99%82%E9%96%93%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81AW-XM729%E3%81%AB%E3%81%AFAW-XM729-PUR%E3%81%A8AW-XM729-SUR%E3%81%AE2%E7%A8%AE%E9%A1%9E%E3%81%8C%E3%81%82%E3%82%8B%E3%82%93%E3%81%A7%E3%81%99%E3%82%88%E3%81%AD%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%B6%AD%E6%9D%B1%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2407170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SDMA%20Loading%20issue%3A%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2407170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262813%22%20target%3D%22_blank%22%3E%40Sanjiv_Mns%3C%2FA%3E%E6%A7%98%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%95%E3%81%8B%E9%80%B2%E5%B1%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8BSDIO%E3%81%BE%E3%81%9F%E3%81%AFPCIE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%AD%8F%E6%9D%B1%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2407190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SDMA%20Loading%20issue%3A%20i.MX8MP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2407190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262813%22%20target%3D%22_blank%22%3E%40Sanjiv_Mns%3C%2FA%3E%E6%A7%98%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A7%81%E3%81%AFL6.12.49.2.2.0%E3%81%AEYocto%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%ABimx-image-multimedia%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%80%81i.mx8mp-evk%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22weidong_sun_0-1787287166486.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22weidong_sun_0-1787287166486.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395074i8B62199C7D1FBC86%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22weidong_sun_0-1787287166486.png%22%20alt%3D%22weidong_sun_0-1787287166486.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eweidong_sun_0-1787287166486.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eweidong_sun_0-1787287166486.png%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22weidong_sun_1-1787287192914.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22weidong_sun_1-1787287192914.png%22%20style%3D%22width%3A%20355px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395075i98AEB5FBD697A8DE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22weidong_sun_1-1787287192914.png%22%20alt%3D%22weidong_sun_1-1787287192914.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eweidong_sun_1-1787287192914.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eweidong_sun_1-1787287192914.png%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22weidong_sun_2-1787287252963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22weidong_sun_2-1787287252963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395076iDB415A7237C4D2C7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22weidong_sun_2-1787287252963.png%22%20alt%3D%22weidong_sun_2-1787287252963.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eweidong_sun_2-1787287252963.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eweidong_sun_2-1787287252963.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8BIW623%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AFAW-XM729-PUR%E3%81%A7%E3%80%81PCIE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E6%8C%81%E3%81%A4M.2%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%82%E3%81%97WiFi%E3%81%ABSDIO%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AA%E3%82%89%E3%80%81dtb%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AFimx8mp-evk-usdhc1-m2.dtb%E3%81%A7%E3%81%82%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%23%20modprobe%20btnxpuart%3C%2FP%3E%0A%3CP%3E%23hciconfig%20-a%3C%2FP%3E%0A%3CP%3EHCI0%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%8C%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%5B%E6%B3%A8%5D%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3Eimx-image-multimedia%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AFIW623%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81AW693%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%B6%AD%E6%9D%B1%3C%2FP%3E%3C%2FLINGO-BODY%3E
