RW612 and Openthread function txpower
1,528件の閲覧回数
joanou
Using the u-Blox IRIS-W106-10B (RW612) with MCUXpresso/Zephyr 4.2.0.  Most features work fine with openthread.  The device can get on mesh and ping, etc.  But some features are missing in software.  Using otPlatRadioSetTransmitPower() causes a reset, for example.
Side note: The API should be support a signed int because, for example, -1 dBm is a valid setting.
I noticed there is an example with vendor set tx power, which does not work after I port it in.  I think it should be hooked into the otPlatRadioSetTransmitPower() function.
#define SPINEL_PROP_VENDOR_NXP_GET_SET_TXPOWERLIMIT_CMD (SPINEL_PROP_VENDOR__BEGIN + 0x10B)
Also, perhaps related, getting the eui64 does not work.  I reworked the function to return the lower 8 bytes of the hwinfo address:
hwinfo_get_device_id.  I suspect that this is probably not correct.
Setting the Tx power from the C app is crucial for our application.
3 返答(返信)
1,489件の閲覧回数
RomanVR
Hello @joanou, hope you are doing well.
Are you doing your testings in a custom application or is it in any existing example? If it is an existing example what changes have you done?
Additionally, could you please test the openthread "shell" example? The example provides an input command to change the transmission power.
Please let me know whether this works for you or if you see a different behavior.
Best Regards!
1,447件の閲覧回数
joanou
I am using the nxp_ot_cli sample with some of my customizations. Here is main() below.  I also added vendor hook for the SPINEL_PROP_VENDOR_NXP_GET_SET_TXPOWERLIMIT_CMD callback from spinel.
I added this for modules/openthread/platform/radio_spinel.cpp
+otError otPlatRadioGetVendorMaxTransmitPower(otInstance *aInstance, uint8_t *aPower)
+ otError error;
+ OT_UNUSED_VARIABLE(aInstance);
+ if (psRadioSpinel == NULL)
+ otLogWarnPlat("psRadioSpinel for max tx get is null");
+ return OT_ERROR_GENERIC;
+ VerifyOrExit(aPower != NULL, error = OT_ERROR_INVALID_ARGS);
+ error = psRadioSpinel->GetVendorMaxTransmitPower(*aPower);
+exit:
+ return error;
+otError otPlatRadioSetVendorMaxTransmitPower(otInstance *aInstance, uint8_t aPower)
+ otLogWarnPlat("psRadioSpinel for set max Tx power is null");
+ return psRadioSpinel->SetVendorMaxTransmitPower(aPower);
The openthread module was modified to support hte vendor hook.
modified: include/openthread/platform/radio.h
modified: src/lib/spinel/CMakeLists.txt
modified: src/lib/spinel/radio_spinel.cpp
modified: src/lib/spinel/radio_spinel.hpp
modified: src/lib/spinel/spinel.h
modified: src/lib/spinel/spinel_driver.cpp
This was added to spinel.h.
SPINEL_PROP_VENDOR_NXP_GET_SET_TXPOWERLIMIT_CMD = (SPINEL_PROP_VENDOR__BEGIN + 0x10B),
int main(void)
   LOG_INF("nxp_ot_cli entry");
   k_sleep(K_MSEC(500));
   ot_context = openthread_get_default_context();
   __ASSERT(ot_context != NULL, "Fatal: OpenThread context not available!");
   ot_instance = openthread_get_default_instance();
   __ASSERT(ot_instance != NULL, "Fatal: OpenThread instance not available!");
   LOG_INF("Setting openthread leader weight");
   otThreadSetLocalLeaderWeight(ot_instance, 2);
   LOG_INF("Done setting leaderweight");
   LOG_INF("Setting openthread radio max transmit power to 12/2 dBm ...");
   otError err1 = otPlatRadioSetVendorMaxTransmitPower(ot_instance, 12);
   LOG_INF("Set openthread radio max transmit power: %s (err=%d)", otThreadErrorToString(err1), err1);
   uint8_t aPower = 0;
   LOG_INF("Getting openthread radio transmit power ...");
   otError err2 = otPlatRadioGetVendorMaxTransmitPower(ot_instance, &aPower);
   if ((aPower % 2 == 0))
      LOG_INF("Getting openthread radio transmit power is %u or %u.0 dBm, %s (err=%d)", aPower, aPower/2, otThreadErrorToString(err2), err2);
   else
      LOG_INF("Getting openthread radio transmit power is %u or %u.5 dBm, %s (err=%d)", aPower, aPower/2, otThreadErrorToString(err2), err2);
   //LOG_INF("Loop now");
   while (1)
      k_sleep(K_MSEC(1000));
   return 0;
タグ(1)
1,414件の閲覧回数
RomanVR
Hello @joanou.
I can infer that you are porting an OpenThead example to Zephyr, although please correct me if I'm wrong. As I mentioned before, I suggest that you take as reference and/or test the OpenThread Shell example from the Zephyr repository to check for additional porting details related to the transmit power control, which is included in this example.
Please let me know if the example works for you.
Best Regards!
%3CLINGO-SUB%20id%3D%22lingo-sub-2149374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERW612%E3%81%A8Openthread%E9%96%A2%E6%95%B0txpower%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eu-Blox%20%3CSPAN%3EIRIS-W106-10B%20(RW612)%20%E3%82%92%20MCUXpresso%2FZephyr%204.2.0%20%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82OpenThread%20%E3%81%A7%E3%81%AF%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E3%83%A1%E3%83%83%E3%82%B7%E3%83%A5%E6%8E%A5%E7%B6%9A%E3%82%84ping%20%E3%81%AA%E3%81%A9%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%81%AF%E4%B8%80%E9%83%A8%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81otPlatRadioSetTransmitPower()%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%A3%9C%E8%B6%B3%3A%20%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%20-1%20dBm%20%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81API%20%E3%81%AF%E7%AC%A6%E5%8F%B7%E4%BB%98%E3%81%8D%E6%95%B4%E6%95%B0%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%E3%81%8C%E9%80%81%E4%BF%A1%E9%9B%BB%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E4%BE%8B%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E7%A7%BB%E6%A4%8D%E3%81%97%E3%81%A6%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82otPlatRadioSetTransmitPower%20%3CSPAN%3E()%20%E9%96%A2%E6%95%B0%E3%81%AB%E3%83%95%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%23SPINEL_PROP_VENDOR_NXP_GET_SET_TXPOWERLIMIT_CMD%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3ESPINEL_PROP_VENDOR__BEGIN%3C%2FSPAN%3E%20%3CSPAN%3E%2B%200x10B)%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81eui64%20%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E9%96%A2%E6%95%B0%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3Ehwinfo_get_device_id%20%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E3%80%81hwinfo%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E4%B8%8B%E4%BD%8D%208%20%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E8%BF%94%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%81%93%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20C%20%E3%82%A2%E3%83%97%E3%83%AA%E3%81%8B%E3%82%89%20Tx%20%E9%9B%BB%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2153828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW612%20and%20Openthread%20function%20txpower%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248805%22%20target%3D%22_blank%22%3E%40joanou%3C%2FA%3E%20%E3%80%82%3C%2FP%3E%0A%3CP%3EOpenThead%20%E3%81%AE%E4%BE%8B%E3%82%92%20Zephyr%20%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%8E%A8%E6%B8%AC%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%82%89%E8%A8%82%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%89%8D%E3%81%AB%E8%BF%B0%E3%81%B9%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%80%81%E4%BF%A1%E9%9B%BB%E5%8A%9B%E5%88%B6%E5%BE%A1%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%BF%BD%E5%8A%A0%E3%81%AE%E7%A7%BB%E6%A4%8D%E8%A9%B3%E7%B4%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81Zephyr%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AE%20OpenThread%20Shell%20%E3%81%AE%E4%BE%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%8A%E3%82%88%E3%81%B3%2F%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%8C%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A4%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2153263%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW612%20and%20Openthread%20function%20txpower%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153263%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%82%92%E5%8A%A0%E3%81%88%E3%81%9F%20nxp_ot_cli%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%20main()%20%E3%81%A7%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%3CSPAN%3E%E3%82%B9%E3%83%94%E3%83%8D%E3%83%AB%E3%81%8B%E3%82%89%E3%81%AE%20SPINEL_PROP_VENDOR_NXP_GET_SET_TXPOWERLIMIT_CMD%20%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E7%94%A8%E3%81%AE%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%20%E3%83%95%E3%83%83%E3%82%AF%E3%82%82%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Emodules%2Fopenthread%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2Fradio_spinel.cpp%E3%81%AB%E3%81%93%E3%82%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%2BotError%20otPlatRadioGetVendorMaxTransmitPower(otInstance%20*aInstance%2C%20uint8_t%20*aPower)%3CBR%20%2F%3E%20%2B%7B%3CBR%20%2F%3E%20%2B%20otError%20%E3%82%A8%E3%83%A9%E3%83%BC%3B%3CBR%20%2F%3E%20%2B%3CBR%20%2F%3E%20%2B%20OT_UNUSED_VARIABLE(%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9)%3B%3CBR%20%2F%3E%20%2B%3CBR%20%2F%3E%20%2B%20if%20(psRadioSpinel%20%3D%3D%20NULL)%3CBR%20%2F%3E%20%2B%20%7B%3CBR%20%2F%3E%20%2B%20otLogWarnPlat(%22%E6%9C%80%E5%A4%A7tx%E5%8F%96%E5%BE%97%E3%81%AEpsRadioSpinel%E3%81%8Cnull%E3%81%A7%E3%81%99%22)%3B%3CBR%20%2F%3E%20%2B%20OT_ERROR_GENERIC%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%2B%20%7D%3CBR%20%2F%3E%20%2B%3CBR%20%2F%3E%20%2B%20VerifyOrExit(aPower%20!%3D%20NULL%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%20%3D%20OT_ERROR_INVALID_ARGS)%3B%3CBR%20%2F%3E%20%2B%20%E3%82%A8%E3%83%A9%E3%83%BC%20%3D%20psRadioSpinel-%26gt%3BGetVendorMaxTransmitPower(*aPower)%3B%3CBR%20%2F%3E%20%2B%3CBR%20%2F%3E%20%2B%E7%B5%82%E4%BA%86%3A%3CBR%20%2F%3E%20%2B%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%2B%7D%3CBR%20%2F%3E%20%2B%3CBR%20%2F%3E%20%2BotError%20otPlatRadioSetVendorMaxTransmitPower(otInstance%20*aInstance%2C%20uint8_t%20aPower)%3CBR%20%2F%3E%20%2B%7B%3CBR%20%2F%3E%20%2B%20if%20(psRadioSpinel%20%3D%3D%20NULL)%3CBR%20%2F%3E%20%2B%20%7B%3CBR%20%2F%3E%20%2B%20otLogWarnPlat(%22%E6%9C%80%E5%A4%A7%E9%80%81%E4%BF%A1%E9%9B%BB%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEpsRadioSpinel%E3%81%8Cnull%E3%81%A7%E3%81%99%22)%3B%3CBR%20%2F%3E%20%2B%20OT_ERROR_GENERIC%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%2B%20%7D%3CBR%20%2F%3E%20%2B%3CBR%20%2F%3E%20%2B%20OT_UNUSED_VARIABLE(%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9)%3B%3CBR%20%2F%3E%20%2B%20psRadioSpinel-%26gt%3BSetVendorMaxTransmitPower(aPower)%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%2B%7D%3CBR%20%2F%3E%20%2B%3CBR%20%2F%3E%3CBR%20%2F%3E%20openthread%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%20%E3%83%95%E3%83%83%E3%82%AF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E5%A4%89%E6%9B%B4%3A%20include%2Fopenthread%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2Fradio.h%3CBR%20%2F%3E%E5%A4%89%E6%9B%B4%3A%20src%2Flib%2Fspinel%2FCMakeLists.txt%3CBR%20%2F%3E%E5%A4%89%E6%9B%B4%3A%20src%2Flib%2Fspinel%2Fradio_spinel.cpp%3CBR%20%2F%3E%E5%A4%89%E6%9B%B4%3A%20src%2Flib%2Fspinel%2Fradio_spinel.hpp%3CBR%20%2F%3E%E5%A4%89%E6%9B%B4%3A%20src%2Flib%2Fspinel%2Fspinel.h%3CBR%20%2F%3E%E5%A4%89%E6%9B%B4%3A%20src%2Flib%2Fspinel%2Fspinel_driver.cpp%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%20spinel.h%20%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20SPINEL_PROP_VENDOR_NXP_GET_SET_TXPOWERLIMIT_CMD%20%3D%20(SPINEL_PROP_VENDOR__BEGIN%20%2B%200x10B)%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Eint%3C%2FSPAN%3E%20%3CSPAN%3Emain%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ELOG_INF%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22nxp_ot_cli%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Ek_sleep%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EK_MSEC%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E500%3C%2FSPAN%3E%20%3CSPAN%3E))%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Eot_context%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Eopenthread_get_default_context%3C%2FSPAN%3E%20%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E__ASSERT%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Eot_context%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3ENULL%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E%22%E8%87%B4%E5%91%BD%E7%9A%84%3A%20OpenThread%20%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%8C%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93!%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Eot_instance%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Eopenthread_get_default_instance%3C%2FSPAN%3E%20%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E__ASSERT%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Eot_instance%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3ENULL%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E%22%E8%87%B4%E5%91%BD%E7%9A%84%3A%20OpenThread%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93!%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ELOG_INF%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E9%87%8D%E3%81%BF%E3%82%92%E8%A8%AD%E5%AE%9A%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EotThreadSetLocalLeaderWeight%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Eot_instance%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ELOG_INF%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%82%A6%E3%82%A7%E3%82%A4%E3%83%88%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Ek_sleep%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EK_MSEC%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E500%3C%2FSPAN%3E%20%3CSPAN%3E))%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ELOG_INF%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22OpenThread%20%E7%84%A1%E7%B7%9A%E3%81%AE%E6%9C%80%E5%A4%A7%E9%80%81%E4%BF%A1%E9%9B%BB%E5%8A%9B%E3%82%92%2012%2F2%20dBm%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EotError%3C%2FSPAN%3E%20%3CSPAN%3Eerr1%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EotPlatRadioSetVendorMaxTransmitPower%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Eot_instance%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E12%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ELOG_INF%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E7%84%A1%E7%B7%9A%E3%81%AE%E6%9C%80%E5%A4%A7%E9%80%81%E4%BF%A1%E9%9B%BB%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%3A%3C%2FSPAN%3E%20%3CSPAN%3E%25s%3C%2FSPAN%3E%20%3CSPAN%3E(err%3D%3C%2FSPAN%3E%20%3CSPAN%3E%25d%3C%2FSPAN%3E%20%3CSPAN%3E)%22%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3EotThreadErrorToString%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Eerr1%3C%2FSPAN%3E%20%3CSPAN%3E)%2C%3C%2FSPAN%3E%20%3CSPAN%3Eerr1%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Ek_sleep%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EK_MSEC%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E500%3C%2FSPAN%3E%20%3CSPAN%3E))%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3EaPower%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ELOG_INF%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22OpenThread%20%E7%84%A1%E7%B7%9A%E9%80%81%E4%BF%A1%E9%9B%BB%E5%8A%9B%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EotError%3C%2FSPAN%3E%20%3CSPAN%3Eerr2%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EotPlatRadioGetVendorMaxTransmitPower%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Eot_instance%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3EaPower%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%82%82%E3%81%97%3C%2FSPAN%3E%3CSPAN%3E((%3C%2FSPAN%3E%20%3CSPAN%3EaPower%3C%2FSPAN%3E%20%3CSPAN%3E%25%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E))%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ELOG_INF%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E7%84%A1%E7%B7%9A%E9%80%81%E4%BF%A1%E9%9B%BB%E5%8A%9B%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E%25u%3C%2FSPAN%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E%25u%3C%2FSPAN%3E%20%3CSPAN%3E.0%20dBm%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%25s%3C%2FSPAN%3E%20%3CSPAN%3E(err%3D%3C%2FSPAN%3E%20%3CSPAN%3E%25d%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%81%A7%E3%81%99%22%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EaPower%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EaPower%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EotThreadErrorToString%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Eerr2%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3Eerr2%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ELOG_INF%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E7%84%A1%E7%B7%9A%E9%80%81%E4%BF%A1%E9%9B%BB%E5%8A%9B%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E%25u%3C%2FSPAN%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E%25u%3C%2FSPAN%3E%20%3CSPAN%3E.5%20dBm%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%25s%3C%2FSPAN%3E%20%3CSPAN%3E(err%3D%3C%2FSPAN%3E%20%3CSPAN%3E%25d%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%81%A7%E3%81%99%22%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EaPower%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EaPower%3C%2FSPAN%3E%20%3CSPAN%3E%2F%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3EotThreadErrorToString%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Eerr2%3C%2FSPAN%3E%20%3CSPAN%3E)%20%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3Eerr2%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%2F%2FLOG_INF(%22%E4%BB%8A%E3%81%99%E3%81%90%E3%83%AB%E3%83%BC%E3%83%97%22)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%80%E6%96%B9%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ELOG_INF%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22%E4%BB%8A%E3%81%99%E3%81%90%E3%83%AB%E3%83%BC%E3%83%97%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Ek_sleep%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EK_MSEC%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E1000%3C%2FSPAN%3E%20%3CSPAN%3E))%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW612%20and%20Openthread%20function%20txpower%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248805%22%20target%3D%22_blank%22%3E%40joanou%3C%2FA%3E%20%E3%80%81%E3%81%8A%E5%85%83%E6%B0%97%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E6%97%A2%E5%AD%98%E3%81%AE%E4%BE%8B%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E6%97%A2%E5%AD%98%E3%81%AE%E4%BE%8B%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81OpenThread%20%E3%81%AE%E3%80%8C%E3%82%B7%E3%82%A7%E3%83%AB%E3%80%8D%E3%81%AE%E4%BE%8B%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E9%80%81%E4%BF%A1%E9%9B%BB%E5%8A%9B%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%85%A5%E5%8A%9B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E5%8B%95%E4%BD%9C%E3%81%8C%E8%A6%8B%E3%82%89%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
