RW610 WiFi Direct Implementation
Designer11
I'm looking to use the RW610 chipset for an upcoming project and was wondering whether its hardware can support Wi-Fi Direct. In addition, does anyone know where i can obtain application note or any documentation that explains the implementation and operation of Wi-Fi Direct for the RW610 chipset module.
Thank you so much in advance.
RomanVR
Hello @Designer11, hope you are doing well and sorry for the late reply.
The Wi-Fi example "wpa_supplicant" within SDK version 25.09, is compatible with Wi-Fi Direct/P2P feature, however to enable the feature it is required to define the macro: CONFIG_WPA_SUPP_P2P inside the "wifi_config.h"  file.
For more information about WFD interface please refer to UM11442 on section 3.8.1.5.
Please let me know if this information is helpful.
Best Regards!
RomanVR
Hello @Designer11, hope you are doing well.
I will check this internally and I will inform you once I get a response from the internal team.
Thank you for your patience.
Best Regards!
%3CLINGO-SUB%20id%3D%22lingo-sub-2186844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERW610%20WiFi%20Direct%20Implementation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2186844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EI'm%20looking%20to%20use%20the%20RW610%20chipset%20for%20an%20upcoming%20project%20and%20was%20wondering%20whether%20its%20hardware%20can%20support%20Wi-Fi%20Direct.%20In%20addition%2C%20does%20anyone%20know%20where%20i%20can%20obtain%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eapplication%20note%20or%20any%20documentation%20that%20explains%20the%20implementation%20and%20operation%20of%20Wi-Fi%20Direct%20for%20the%20RW610%20chipset%20module.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThank%20you%20so%20much%20in%20advance.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW610%20WiFi%20Direct%20Implementation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F32234%22%20target%3D%22_blank%22%3E%40Designer11%3C%2FA%3E%2C%26nbsp%3Bhope%20you%20are%20doing%20well%20and%20sorry%20for%20the%20late%20reply.%3C%2FP%3E%0A%3CP%3EThe%20Wi-Fi%20example%20%22wpa_supplicant%22%20within%20SDK%20version%2025.09%2C%20is%20compatible%20with%20Wi-Fi%20Direct%2FP2P%20feature%2C%20however%20to%20enable%20the%20feature%20it%20is%20required%20to%20define%20the%20macro%3A%20CONFIG_WPA_SUPP_P2P%20inside%20the%20%22wifi_config.h%22%26nbsp%3B%20file.%3C%2FP%3E%0A%3CP%3EFor%20more%20information%20about%20WFD%20interface%20please%20refer%20to%20%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fmcuxsdk%2Flatest%2Fhtml%2F_static%2Fwireless%2FUM11442-NXP-Wi-Fi-and-Bluetooth-Demo-Applications-for-i.MX-RT-platforms-User-Guide.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EUM11442%3C%2FA%3E%20on%20section%203.8.1.5.%3C%2FP%3E%0A%3CP%3EPlease%20let%20me%20know%20if%20this%20information%20is%20helpful.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2188463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW610%20WiFi%20Direct%20Implementation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2188463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F32234%22%20target%3D%22_blank%22%3E%40Designer11%3C%2FA%3E%2C%20hope%20you%20are%20doing%20well.%3C%2FP%3E%0A%3CP%3EI%20will%20check%20this%20internally%20and%20I%20will%20inform%20you%20once%20I%20get%20a%20response%20from%20the%20internal%20team.%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20patience.%3C%2FP%3E%3C%2FLINGO-BODY%3E
