RW610 WiFi Direct Implementation
1,256 次查看
Designer11
I'm looking to use the RW610 chipset for an upcoming project and was wondering whether its hardware can support Wi-Fi Direct. In addition, does anyone know where i can obtain application note or any documentation that explains the implementation and operation of Wi-Fi Direct for the RW610 chipset module.
Thank you so much in advance.
标记 (3)
1,143 次查看
RomanVR
Hello @Designer11, hope you are doing well and sorry for the late reply.
The Wi-Fi example "wpa_supplicant" within SDK version 25.09, is compatible with Wi-Fi Direct/P2P feature, however to enable the feature it is required to define the macro: CONFIG_WPA_SUPP_P2P inside the "wifi_config.h"  file.
For more information about WFD interface please refer to UM11442 on section 3.8.1.5.
Please let me know if this information is helpful.
Best Regards!
1,208 次查看
RomanVR
Hello @Designer11, hope you are doing well.
I will check this internally and I will inform you once I get a response from the internal team.
Thank you for your patience.
Best Regards!
%3CLINGO-SUB%20id%3D%22lingo-sub-2186844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERW610%20WiFi%20Direct%20%E5%AE%9E%E7%8E%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2186844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E6%83%B3%E5%9C%A8%E5%8D%B3%E5%B0%86%E5%88%B0%E6%9D%A5%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%E4%BD%BF%E7%94%A8%20RW610%20%E8%8A%AF%E7%89%87%E7%BB%84%EF%BC%8C%E6%83%B3%E7%9F%A5%E9%81%93%E5%AE%83%E7%9A%84%E7%A1%AC%E4%BB%B6%E8%83%BD%E5%90%A6%E6%94%AF%E6%8C%81%20Wi-Fi%20Direct%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%BE%97%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%E6%88%96%E4%BB%BB%E4%BD%95%E8%A7%A3%E9%87%8A%20RW610%20%E8%8A%AF%E7%89%87%E7%BB%84%E6%A8%A1%E5%9D%97%E7%9A%84%20Wi-Fi%20Direct%20%E5%AE%9E%E7%8E%B0%E5%92%8C%E6%93%8D%E4%BD%9C%E7%9A%84%E6%96%87%E6%A1%A3%E5%90%97%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW610%20WiFi%20Direct%20Implementation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F32234%22%20target%3D%22_blank%22%3E%40%E8%AE%BE%E8%AE%A1%E5%B8%8811%3C%2FA%3E%EF%BC%8C%E5%B8%8C%E6%9C%9B%E4%BD%A0%E4%B8%80%E5%88%87%E9%83%BD%E5%A5%BD%EF%BC%8C%E5%BE%88%E6%8A%B1%E6%AD%89%E8%BF%99%E4%B9%88%E6%99%9A%E6%89%8D%E7%BB%99%E4%BD%A0%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3ESDK%2025.09%20%E7%89%88%E4%B8%AD%E7%9A%84%20Wi-Fi%20%E7%A4%BA%E4%BE%8B%22wpa_supplicant%22%20%E4%B8%8E%20Wi-Fi%20Direct%2FP2P%20%E5%8A%9F%E8%83%BD%E5%85%BC%E5%AE%B9%EF%BC%8C%E4%BD%86%E8%A6%81%E5%90%AF%E7%94%A8%E8%AF%A5%E5%8A%9F%E8%83%BD%EF%BC%8C%E9%9C%80%E8%A6%81%E5%AE%9A%E4%B9%89%E5%AE%8F%EF%BC%9A%E5%9C%A8%22wifi_config.h%22%20%E4%B8%AD%E5%AE%9A%E4%B9%89%E5%AE%8F%20CONFIG_WPA_SUPP_P2P%20%E9%94%89%E5%88%80%3C%2FP%3E%0A%3CP%3E%E6%9C%89%E5%85%B3%20WFD%20%E6%8E%A5%E5%8F%A3%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fmcuxsdk%2Flatest%2Fhtml%2F_static%2Fwireless%2FUM11442-NXP-Wi-Fi-and-Bluetooth-Demo-Applications-for-i.MX-RT-platforms-User-Guide.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EUM11442%3C%2FA%3E%E7%AC%AC%203.8.1.5%20%E8%8A%82%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E5%AF%B9%E6%82%A8%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2188463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW610%20WiFi%20Direct%20Implementation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2188463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F32234%22%20target%3D%22_blank%22%3E%40%E8%AE%BE%E8%AE%A1%E5%B8%8811%3C%2FA%3E%EF%BC%8C%E5%B8%8C%E6%9C%9B%E4%BD%A0%E4%B8%80%E5%88%87%E9%83%BD%E5%A5%BD%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B0%86%E5%9C%A8%E5%86%85%E9%83%A8%E6%A0%B8%E5%AE%9E%E6%AD%A4%E4%BA%8B%EF%BC%8C%E4%B8%80%E6%97%A6%E5%BE%97%E5%88%B0%E5%86%85%E9%83%A8%E5%9B%A2%E9%98%9F%E7%9A%84%E7%AD%94%E5%A4%8D%EF%BC%8C%E6%88%91%E5%B0%86%E7%AB%8B%E5%8D%B3%E9%80%9A%E7%9F%A5%E6%82%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%80%90%E5%BF%83%E7%AD%89%E5%BE%85%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
