RW610 SWD Programming Issue During Board Bring-Up
Arunembien
Hi Team,
We have designed a custom board using RW610.
The board has now been fabricated, and bring-up activity is currently in progress. We are using an external MCU-Link debugger for programming and debugging.
While programming the RW610 device, we are encountering the below SWD configuration error:
0 SWD devices detected. Connect a device and try again.
Please find the attached schematics for reference.
Current strap pin configuration:
CON[3:0] = 1111 Boot from QSPI
CON[11] = 0 SWD mode enabled
Additional details:
  • VREF = 3.3V
  • Pull-up on SWCLK is DNP
Additionally, we observed the same behavior while trying to flash the RW612 EVK board using an external MCU-Link debugger.
Kindly provide your inputs or suggestions on this issue and let us know if any additional configuration or recovery steps are required.
Thanks and Regards,
Arun Kumar V
Arunembien
Hi Team,
I am attaching error log for your reference.  Kindly refer and support on this.
Arun
Christine_Li
Hi, @Arunembien
Can you please have a try with below recommendations?
  1. add/populate the SWCLK and SWDIO 10 kΩ pull-ups
  2. try the board with J-Link firmware on MCU-Link or a native J-Link
By the way, you mentioned, you also tried with our EVK, still have issue.
Do you mean our FRDM-RW612? Or our RW612-RD board?
Christine.
Christine_Li
Hi, @Arunembien
Have you tried with my recommendations?
Does it work for you?
If still need our support, please let me know your updates, Thanks!
Christine.
Christine_Li
Hi, @Arunembien
Christine.
Christine_Li
Hi, @Arunembien
Thanks for providing us logs and reporting to us.
I will check and reply to you ASAP.
Christine.
