NXP RW610 - Memory Support
1,552件の閲覧回数
JohnnyC
Hello- We are looking for documentation for memory support on the RW610.
1,543件の閲覧回数
Christine_Li
Hi, @JohnnyC
I am sorry that we are not allowed to share the confidential documents directly.
Can you please describe your requirements/questions in detail?If you want to know the basic memory info of RW610, please see below:
The RW610 supports 1.2 MB SRAM with separate bus master access for higher throughput and individual power control for low-power operation.
The 256 kB on-chip ROM contains the secure bootloader and the following application programming interfaces(API):
In-application programming (IAP) and in-system programming (ISP)
Supports secure booting from UART/I2C/SPI/USB
OTP API to program the OTP memory
Random Number Generator (RNG) API
Christine.
