IW612 Datasheet and documentation
7,220 次查看
NimeshRana
Contributor V
Hello NxP Wireless Team,
We are designing one IOT based product in which we are planning to support Wi-Fi6 technology. For that we came to know that NXP's IW612 supports Wi-Fi6.
Can you please help to share the datasheet of IW612 WLAN chipset? It will be good if NXP can share any application note for the same.
Nimesh Rana
标签 (2)
6 回复数
7,131 次查看
bruce_havemeier
CEL is finalizing a module based on this chip set.  If you would like to discuss the technical features, please reach out.
https://www.cel.com/product/cmp961x/
Regards-Bruce Havemeier
California Eastern Laboratories
7,142 次查看
stephanie_m
Sorry for the inconvenience this might cause you, but as this product has not been released we do not have any information available to share with you, nonetheless, could you please contact one distributors available in the Distributor Network|NXP or one of the NXP sales representative to help you with the request?
7,212 次查看
ocourson
Dear @NimeshRana
This Wireless Community forum is public, so we cannot disclose any restricted information here, like product datasheet.
I will initiate internal process to provide you such documents.
Olivier
7,048 次查看
ocourson
Dear @NimeshRana
Could you get the required information from distributor or module maker, or shall we continue internal process to get the docs ?
Please note that several module makers are finalizing their NXP IW612 based modules (CEL, Murata, U-blox, Azurewave, etc).
Olivier
7,039 次查看
NimeshRana
Contributor V
Hello Oliver,
Thanks for the update. We will connect with module makers for module. It will be good if you can share the chipset details for which we can check chip base discrete solution instead of using direct module. It will look like chipper solution.
Nimesh Rana
7,030 次查看
ocourson
Dear @NimeshRana
Generic information is available on NXP website:
https://www.nxp.com/products/wireless/wi-fi-plus-bluetooth/2-4-5-ghz-dual-band-1x1-wi-fi-6-802-11ax-...
Olivier
