IW611: Unable to setup Linux driver
1,117 次查看
mlytvyn
I'm trying to bring-up IW611 with Linux kernel 4.19. I'm using mwifiex branch if-6.12.49_2.20.
Configuration file contains following:
SDIW612 = {
cal_data_cfg=none
hw_name=IW611
fw_name=nxp/sduart_nw61x_v1.bin
drv_mode=0x1
auto_ds=2
pm_keep_power=1
cntry_txpwr=0
slew_rate=0
Chip is recognized by MMC bus driver, nwifiex driver is loaded. But when I try to bring mlan0 interface up, I get an write error. Can someone tell me what is missconfigured or get wrong?
Here is my dmesg output:
[ 8.423408] wlan: Loading MWLAN driver
[ 8.427639] No module param cfg file specified
[ 8.632441] wlan: Register to Bus Driver...
[ 8.666463] vendor=0x0471 device=0x0205 class=0 function=1
[ 8.711324] Attach moal handle ops, card interface type: 0x109
[ 8.764392] SDIW612: init module param from usr cfg
[ 8.769688] card_type: SDIW612, config block: 0
[ 8.774488] cal_data_cfg=none
[ 8.777622] hw_name=IW611
[ 8.780414] fw_name=nxp/sduart_nw61x_v1.bin
[ 8.784838] drv_mode = 1
[ 8.787512] auto_ds = 2
[ 8.790109] pm_keep_power on
[ 8.793152] cntry_txpwr = 0
[ 8.796102] slew_rate = 0
[ 8.798916] SDIO: sdio_blk_size=256 max_blk_count=65535 max_segs=64 max_seg_size=65536
[ 8.807287] rx_work=0 cpu_num=1
[ 8.810624] Enable moal_recv_amsdu_packet
[ 9.101160] Attach mlan adapter operations.card_type is 0x109.
[ 9.118472] wlan: Enable TX SG mode
[ 9.122181] wlan: mpa_tx.buf_size=65280
[ 9.126231] wlan: Enable RX SG mode
[ 9.129954] wlan: mpa_rx.buf_size=65280
[ 9.261877] Request firmware: nxp/sduart_nw61x_v1.bin
[ 10.067400] Wlan: FW download over, firmwarelen=913892 downloaded 837692
[ 10.467947] WLAN FW is active
[ 10.471106] on_time is 10463342042
[ 10.494983] VDLL image: len=76200
[ 10.498741] fw_cap_info=0x487cff03, dev_cap_mask=0xffffffff
[ 10.504665] uuid: e139b70377da5b6fbc71c709b955b9a7
[ 10.509761] max_p2p_conn = 8, max_sta_conn = 16
[ 10.529596] IOCTL failed: 1b0efb8f id=0x200000, sub_id=0x200046 action=1, status_code=0x3 [FW_CMDRESP]
[ 10.544554] Register NXP 802.11 Adapter mlan0
[ 10.549385] wlan: version = SDIW612---18.99.2.p19.10-MM6X18540.p33-GPL-(FP92)
[ 10.567328] Set REG 0x90002328: 0x10d57 slew_rate=0
[ 10.576793] usbcore: registered new interface driver usbxxx
[ 10.584854] wlan: Register to Bus Driver Done
[ 10.589480] wlan: Driver loaded successfully
Here I try to bring mlan0 up
[ 76.346952] cmd53 write error=-110
[ 76.353352] host_to_card, write iomem (1) failed: -1
[ 76.359014] write CFG reg failed
[ 76.362560] cmd53 write error=-110
[ 76.366184] host_to_card, write iomem (2) failed: -1
[ 76.371495] write CFG reg failed
[ 76.374999] cmd53 write error=-110
[ 76.402254] host_to_card, write iomem (3) failed: -1
[ 76.407537] write CFG reg failed
[ 76.410971] Error: host_to_card failed: 0xFFFFFFFF
[ 76.416043] DNLD_CMD: Host to Card Failed
[ 76.420306] IOCTL failed: ef7a4e76 id=0x90000, sub_id=0x90001 action=1, status_code=0x80000006 [CMD_DNLD_FAIL]
[ 76.430903] ------------Dump info-----------
[ 76.435415] Command to card failure
[ 76.439111] pending command id: 0x10 ioctl_buf= (null)
[ 76.444634] pending command id: 0x28 ioctl_buf=a69aa9f8
[ 76.450155] No pending scan command
[ 76.453847] CurCmd Empty
[ 76.456521] mlan_processing =1
[ 76.459753] main_lock_flag =0
[ 76.462885] main_process_cnt =75
[ 76.466292] delay_task_flag =0
[ 76.469523] mlan_rx_processing =0
[ 76.473022] rx_pkts_queued=0
[ 76.476061] more_task_flag = 0
[ 76.479292] num_cmd_timeout = 0
[ 76.482607] last_cmd_index = 2
[ 76.485830] last_cmd_id =
[ 76.485834] 0x27c
[ 76.488698] 0x27c
[ 76.490818] 0x243
[ 76.492938] 0xe4
[ 76.495058] 0x5b
[ 76.497086] 0x242
[ 76.499123] 0x4d
[ 76.501243] 0xd1
[ 76.503271] 0x10
[ 76.505299] 0x28
[ 76.510935] last_cmd_act =
[ 76.510937] 0x0
[ 76.513885] 0x1
[ 76.515821] 0x0
[ 76.517757] 0xff
[ 76.519704] 0x1
[ 76.521732] 0x1
[ 76.523668] 0x1
[ 76.525604] 0x0
[ 76.527540] 0x1
[ 76.529486] 0x213
[ 76.535109] last_cmd_resp_index = 2
[ 76.538799] last_cmd_resp_id =
[ 76.538802] 0x827c
[ 76.542117] 0x827c
[ 76.544329] 0x8243
[ 76.546540] 0x805b
[ 76.548761] 0x805b
[ 76.550973] 0x8242
[ 76.553185] 0x804d
[ 76.555396] 0x80d1
[ 76.557608] 0x8010
[ 76.559828] 0x8028
[ 76.565819] last_event_index = 1
[ 76.569233] last_event =
[ 76.569236] 0x0
[ 76.571999] 0x81
[ 76.573936] 0x0
[ 76.575963] 0x0
[ 76.577907] 0x0
[ 76.579844] 0x0
[ 76.581780] 0x0
[ 76.583716] 0x0
[ 76.585652] 0x0
[ 76.587587] 0x0
[ 76.593035] num_data_h2c_failure = 0
[ 76.596809] num_cmd_h2c_failure = 1
[ 76.600500] num_data_c2h_failure = 0
[ 76.604275] num_cmdevt_c2h_failure = 0
[ 76.608241] num_int_read_failure = 0
[ 76.612015] last_int_status = 64
[ 76.615422] num_alloc_buffer_failure = 0
[ 76.619572] num_pkt_dropped = 0
[ 76.622888] num_no_cmd_node = 0
[ 76.626202] num_event_deauth = 0
[ 76.629617] num_event_disassoc = 0
[ 76.633208] num_event_link_lost = 0
[ 76.636890] num_cmd_deauth = 0
[ 76.640121] num_cmd_assoc_success = 0
[ 76.643987] num_cmd_assoc_failure = 0
[ 76.647860] num_cons_assoc_failure = 0
[ 76.651818] cmd_resp_received=0
[ 76.655133] event_received=0
[ 76.658180] max_tx_buf_size=4096
[ 76.661587] tx_buf_size=3072
[ 76.664626] curr_tx_buf_size=3072
[ 76.668134] data_sent=0 cmd_sent=0
[ 76.671725] ps_mode=1 ps_state=0
[ 76.675133] wakeup_dev_req=0 wakeup_tries=0 wakeup_timeout=0
[ 76.681121] hs_configured=0 hs_activated=0
[ 76.685448] pps_uapsd_mode=0 sleep_pd=0
[ 76.689506] tx_lock_flag = 0
[ 76.692545] scan_processing = 0
[ 76.695859] scan_state = 0x0
[ 76.698907] bypass_pkt_count=0
[ 76.702132] mp_rd_bitmap=0x0 curr_rd_port=0x0
[ 76.706734] mp_wr_bitmap=0xffffffff curr_wr_port=0x0
[ 76.711987] mp_data_port_mask = 0xffffffff
[ 76.716314] last_recv_rd_bitmap=0x0 mp_invalid_update=0
[ 76.721843] last_recv_wr_bitmap=0xffffffff last_mp_index=0
[ 76.727641] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 76.734364] 0x00
[ 76.734367] 0x00
[ 76.736395] 0x00
[ 76.738432] 0x00
[ 76.740460] 0x00
[ 76.742488] 0x00
[ 76.744516] 0x00
[ 76.746543] 0x00
[ 76.748580] 0x00
[ 76.750609] 0x00
[ 76.752637] 0x00
[ 76.754665] 0x00
[ 76.756692] 0x00
[ 76.758729] 0x00
[ 76.760757] 0x00
[ 76.762785] 0x00
[ 76.768417] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 76.775131] 0x00
[ 76.775133] 0x00
[ 76.777162] 0x00
[ 76.779199] 0x00
[ 76.781227] 0x00
[ 76.783255] 0x00
[ 76.785283] 0x00
[ 76.787311] 0x00
[ 76.789348] 0x00
[ 76.791376] 0x00
[ 76.793404] 0x00
[ 76.795437] 0x00
[ 76.797465] 0x00
[ 76.799502] 0x00
[ 76.801531] 0x00
[ 76.803559] 0x00
[ 76.809192] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 76.815906] 0x00
[ 76.815908] 0x00
[ 76.817944] 0x00
[ 76.819973] 0x00
[ 76.822001] 0x00
[ 76.824029] 0x00
[ 76.826057] 0x00
[ 76.828093] 0x00
[ 76.830121] 0x00
[ 76.832149] 0x00
[ 76.834177] 0x00
[ 76.836205] 0x00
[ 76.838241] 0x00
[ 76.840269] 0x00
[ 76.842297] 0x00
[ 76.844325] 0x00
[ 76.849957] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 76.856671] 0x00
[ 76.856673] 0x00
[ 76.858711] 0x00
[ 76.860739] 0x00
[ 76.862774] 0x00
[ 76.864803] 0x00
[ 76.866831] 0x00
[ 76.868868] 0x00
[ 76.870897] 0x00
[ 76.872925] 0x00
[ 76.874953] 0x00
[ 76.876981] 0x00
[ 76.879018] 0x00
[ 76.881046] 0x00
[ 76.883074] 0x00
[ 76.885102] 0x00
[ 76.890734] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 76.897448] 0x00
[ 76.897451] 0x00
[ 76.899488] 0x00
[ 76.901516] 0x00
[ 76.903544] 0x00
[ 76.905572] 0x00
[ 76.907599] 0x00
[ 76.909636] 0x00
[ 76.911665] 0x00
[ 76.913693] 0x00
[ 76.915721] 0x00
[ 76.917749] 0x00
[ 76.919785] 0x00
[ 76.921813] 0x00
[ 76.923841] 0x00
[ 76.925869] 0x00
[ 76.931501] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 76.938223] 0x00
[ 76.938226] 0x00
[ 76.940254] 0x00
[ 76.942282] 0x00
[ 76.944310] 0x00
[ 76.946337] 0x00
[ 76.948374] 0x00
[ 76.950402] 0x00
[ 76.952430] 0x00
[ 76.954457] 0x00
[ 76.956485] 0x00
[ 76.958521] 0x00
[ 76.960550] 0x00
[ 76.962578] 0x00
[ 76.964605] 0x00
[ 76.966633] 0x00
[ 76.972265] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 76.978987] 0x00
[ 76.978990] 0x00
[ 76.981018] 0x00
[ 76.983046] 0x00
[ 76.985074] 0x00
[ 76.987102] 0x00
[ 76.989138] 0x00
[ 76.991167] 0x00
[ 76.993195] 0x00
[ 76.995222] 0x00
[ 76.997250] 0x00
[ 76.999286] 0x00
[ 77.001315] 0x00
[ 77.003343] 0x00
[ 77.005371] 0x00
[ 77.007399] 0x00
[ 77.013031] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 77.019753] 0x00
[ 77.019756] 0x00
[ 77.021784] 0x00
[ 77.023812] 0x00
[ 77.025840] 0x00
[ 77.027876] 0x00
[ 77.029905] 0x00
[ 77.031940] 0x00
[ 77.033969] 0x00
[ 77.035997] 0x00
[ 77.038033] 0x00
[ 77.040062] 0x00
[ 77.042090] 0x00
[ 77.044118] 0x00
[ 77.046145] 0x00
[ 77.048182] 0x00
[ 77.053806] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 77.060529] 0x00
[ 77.060531] 0x00
[ 77.062560] 0x00
[ 77.064587] 0x00
[ 77.066615] 0x00
[ 77.068652] 0x00
[ 77.070681] 0x00
[ 77.072708] 0x00
[ 77.074736] 0x00
[ 77.076764] 0x00
[ 77.078801] 0x00
[ 77.080829] 0x00
[ 77.082857] 0x00
[ 77.084884] 0x00
[ 77.086912] 0x00
[ 77.088949] 0x00
[ 77.094572] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 77.101295] 0x00
[ 77.101297] 0x00
[ 77.103326] 0x00
[ 77.105354] 0x00
[ 77.107381] 0x00
[ 77.109418] 0x00
[ 77.111446] 0x00
[ 77.113474] 0x00
[ 77.115502] 0x00
[ 77.117529] 0x00
[ 77.119566] 0x00
[ 77.121595] 0x00
[ 77.123623] 0x00
[ 77.125650] 0x00
[ 77.127678] 0x00
[ 77.129715] 0x00
[ 77.135341] bss_index = 0, tx_pkts_queued = 0 tx_pause
[ 77.140796] Host:chillair-r1234yf-00050 Timestamp:9c6953b9
[ 77.146691] Driver version = SDIW612---18.99.2.p19.10-MM6X18540.p33-GPL-(FP92)
[ 77.154431] main_state = 3
[ 77.157287] ioctl_pending = 1
[ 77.160428] tx_pending = 0
[ 77.163285] wmm_tx_pending[0] = 0
[ 77.166783] wmm_tx_pending[1] = 0
[ 77.170291] wmm_tx_pending[2] = 0
[ 77.173790] wmm_tx_pending[3] = 0
[ 77.177288] rx_pending = 0
[ 77.180152] lock_count = 44
[ 77.183100] malloc_count = 49
[ 77.186231] mbufalloc_count = 0
[ 77.189554] hs_skip_count = 0
[ 77.192685] hs_force_count = 0
[ 77.195909] Media state = "Disconnected"
[ 77.200059] carrier off
[ 77.202641] tx queue 0: stopped
[ 77.205956] tx queue 1: stopped
[ 77.209279] tx queue 2: stopped
[ 77.212595] tx queue 3: stopped
[ 77.215911] mlan0: num_tx_timeout = 0
[ 77.219799] -------- Dump info End---------
[ 77.237865] IPv6: ADDRCONF(NETDEV_UP): mlan0: link is not ready
[ 77.270404] SDIO Func0 (0x0-0x9): ERR
[ 77.274349] SDIO Func1 (0x10-0x17): ERR
[ 77.278454] SDIO Func1: (0x8) ERR
[ 77.282147] SDIO Func1 (0xe8-0xff): ERR
[ 77.387444] SDIO Func1 (0xe8-0xff): ERR
[ 77.391567] set pending clean
[ 77.471612] SDIO Write ERR
[ 77.474573] SDIO Write ERR
[ 77.477436] ==== DEBUG MODE OUTPUT START: 77.469673 ====
[ 77.483111] SDIO Write ERR
[ 77.485995] SDIO Write ERR
[ 77.488871] ==== DEBUG MODE END ====
[ 77.492866] IOCTL failed: a69aa9f8 id=0x20000, sub_id=0x20007 action=1, status_code=0x80000007 [CMD_CANCEL]
标记 (2)
6 回复数
1,010 次查看
mlytvyn
I use Silex SX-SDMAX surface mount version (https://www.silextechnology.com/connectivity-solutions/embedded-wireless/sx-sdmax). As I understood voltages on VIO and VIO_SD define signal levels.
1,092 次查看
shaun_wu
Hello @mlytvyn
Which host you are using?
The driver loading and firmware download no problem.
sdio communication reports error.
Best Regards
Shaun
1,086 次查看
mlytvyn
The MMC bus configured as following:
&mmc3 {
	status = "okay";
	dmas = <&edma_xbar 30 0 1>,
		   <&edma_xbar 31 0 2>;
	dma-names = "tx", "rx";
	pinctrl-names = "default", "sleep";
	pinctrl-0 = <&mmc3_pins_default>;
	pinctrl-1 = <&mmc3_pins_sleep>;
	vmmc-supply = <&dcdc4>;
	bus-width = <4>;
	cap-sdio-irq;
	ti,non-removable;
	max-frequency = <25000000>;   /* slow down to 25MHz for bring-up */
The MMC bus controller was managed to detect Wi-Fi chip, kernel loaded correct driver, driver flashed chip with FW blob provided and got FW version from chip. As for me it does not looks like SDIO configuration problem, but looks like driver (or FW) related problem.
 The first error happened here
What driver is trying to do at this stage?
Mykhailo
1,083 次查看
shaun_wu
Hello @mlytvyn
Could you try 50MHz frequency?
Best Regards
Shaun
1,079 次查看
mlytvyn
it doesn't change too much
Here I bring mlan0 up, and then get
I have the same error IOCTL failed: 61e24fe7 id=0x200000, sub_id=0x200046 action=1, status_code=0x3 [FW_CMDRESP]
1,021 次查看
shaun_wu
Hello @mlytvyn
Could you share which iw612 module you are using? Or you are using iw612evk? I notice your sd interface is 3.3V, have you matched sdio power level?
Best Regards
Shaun
%3CLINGO-SUB%20id%3D%22lingo-sub-2378392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIW611%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AE%BE%E7%BD%AE%20Linux%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E7%94%A8%20Linux%20%E5%86%85%E6%A0%B8%204.19%20%E5%90%AF%E5%8A%A8%20IW611%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20mwifiex%20%E5%88%86%E6%94%AF%20if-6.12.49_2.20%E3%80%82%3C%2FP%3E%3CP%3E%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E5%8C%85%E5%90%AB%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CDIV%3ESDIW612%20%3D%20%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecal_data_cfg%3Dnone%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ehw_name%3DIW611%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Efw_name%3Dnxp%2Fsduart_nw61x_v1.bin%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edrv_mode%3D0x1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eauto_ds%3D2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epm_keep_power%3D1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecntry_txpwr%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eslew_rate%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CP%3E%E8%8A%AF%E7%89%87%E8%A2%AB%20MMC%20%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%AF%86%E5%88%AB%EF%BC%8Cnwifiex%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%8A%A0%E8%BD%BD%E3%80%82%E4%BD%86%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%90%AF%E5%8A%A8%20mlan0%20%E6%8E%A5%E5%8F%A3%E6%97%B6%EF%BC%8C%E5%8D%B4%E5%87%BA%E7%8E%B0%E4%BA%86%E5%86%99%E5%85%A5%E9%94%99%E8%AF%AF%E3%80%82%E8%B0%81%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E6%98%AF%E4%BB%80%E4%B9%88%E5%9C%B0%E6%96%B9%E9%85%8D%E7%BD%AE%E9%94%99%E8%AF%AF%E6%88%96%E5%87%BA%E9%94%99%E4%BA%86%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E6%88%91%E7%9A%84%20dmesg%20%E8%BE%93%E5%87%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%5B8.423408%5D%20wlan%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20MWLAN%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3CBR%20%2F%3E%20%5B8.427639%5D%20%E6%9C%AA%E6%8C%87%E5%AE%9A%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%20cfg%20%E6%96%87%E4%BB%B6%20%5B8.632441%5D%20wlan%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%88%B0%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%20%3CBR%20%2F%3E%3CBR%20%2F%3E%5B8.666463%5D%20vendor%3D0x0471%20device%3D0x0205%20class%3D0%20function%3D1%20%5B8.711324%5D%20Attach%20moal%20handle%20ops%EF%BC%8C%E5%8D%A1%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%EF%BC%9A0x109%20%5B8.764392%5D%20SDIW612%EF%BC%9A%E6%9D%A5%E8%87%AA%E7%94%A8%E6%88%B7%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%20%3CBR%20%2F%3E%20%5B8.769688%5D%20cal_data_cfggs%EF%BC%9ASDIW612%EF%BC%8C%E9%85%8D%E7%BD%AE%E5%9D%97%EF%BC%9A0%20%5B8.774488%5D%20cal_data_cfggg%20%3D%E6%97%A0%20%5B8.777622%5D%20hw_name%3Diw611%20%3CBR%20%2F%3E%20%5B8.780414%5D%20fw_name%3Dnexp%2Fsduart_nw61x_v1.bin%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%5B%208.784838%5D%20drv_mode%20%3D%201%3CBR%20%2F%3E%5B%208.787512%5D%20auto_ds%20%3D%202%3CBR%20%2F%3E%5B%208.790109%5D%20pm_keep_power%20on%3CBR%20%2F%3E%5B%208.793152%5D%20cntry_txpwr%20%3D%200%3CBR%20%2F%3E%5B%208.796102%5D%20slew_rate%20%3D%200%3CBR%20%2F%3E%5B%208.798916%5D%20SDIO%3A%20sdio_blk_size%3D256%20max_blk_count%3D65535%20max_segs%3D64%20max_seg_size%3D65536%3CBR%20%2F%3E%5B%208.807287%5D%20rx_work%3D0%20cpu_num%3D1%3CBR%20%2F%3E%5B%208.810624%5D%20Enable%20moal_recv_amsdu_packet%3CBR%20%2F%3E%5B%209.101160%5D%20Attach%20mlan%20adapter%20operations.card_type%20is%200x109.%3CBR%20%2F%3E%5B%209.118472%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20TX%20SG%20%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%209.122181%5D%20wlan%3A%20mpa_tx.buf_size%3D65280%3CBR%20%2F%3E%5B%209.126231%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20RX%20SG%20%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%209.129954%5D%20wlan%3A%20mpa_rx.buf_size%3D65280%3CBR%20%2F%3E%5B%209.261877%5D%20%E8%AF%B7%E6%B1%82%E5%9B%BA%E4%BB%B6%EF%BC%9Anxp%2Fsduart_nw61x_v1.bin%3CBR%20%2F%3E%5B%2010.067400%5D%20Wlan%EF%BC%9AFW%20%E4%B8%8B%E8%BD%BD%E7%BB%93%E6%9D%9F%EF%BC%8Cfirmwarelen%3D913892%20%E5%B7%B2%E4%B8%8B%E8%BD%BD%20837692%3CBR%20%2F%3E%5B%2010.467947%5D%20WLAN%20FW%20%E5%A4%84%E4%BA%8E%E6%B4%BB%E5%8A%A8%E7%8A%B6%E6%80%81%3CBR%20%2F%3E%5B%2010.471106%5D%20on_time%20is%2010463342042%3CBR%20%2F%3E%5B%2010.494983%5D%20VDLL%20%E6%98%A0%E5%83%8F%EF%BC%9Alen%3D76200%3CBR%20%2F%3E%5B%2010.498741%5D%20fw_cap_info%3D0x487cff03%2C%20dev_cap_mask%3D0xffffffff%3CBR%20%2F%3E%5B%2010.504665%5D%20uuid%3A%20e139b70377da5b6fbc71c709b955b9a7%3CBR%20%2F%3E%5B%2010.509761%5D%20max_p2p_conn%20%3D%208%2C%20max_sta_conn%20%3D%2016%3CBR%20%2F%3E%5B%2010.529596%5D%20IOCTL%20failed%3A%201b0efb8f%20id%3D0x200000%2C%20sub_id%3D0x200046%20action%3D1%2C%20status_code%3D0x3%20%5BFW_CMDRESP%5D%3CBR%20%2F%3E%5B%2010.544554%5D%20Register%20NXP%20802.11%20Adapter%20mlan0%3CBR%20%2F%3E%5B%2010.549385%5D%20wlan%3A%20version%20%3D%20SDIW612---18.99.2.p19.10-MM6X18540.p33-GPL-(FP92)%3CBR%20%2F%3E%5B10.567328%5D%20%E8%AE%BE%E7%BD%AE%20REG%200x90002328%EF%BC%9A0x10d57%20slew_rate%3D0%20%5B10.576793%5D%20usbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E4%BA%86%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usbxxx%20%5B10.584854%5D%20wlan%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%88%B0%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%AE%8C%E6%88%90%20%3CBR%20%2F%3E%20%5B10.589480%5D%20wlan%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%88%90%E5%8A%9F%E5%8A%A0%E8%BD%BD%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%BF%99%E9%87%8C%E6%88%91%E5%B0%9D%E8%AF%95%E5%90%AF%E5%8A%A8%20mlan0%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B%2076.346952%5D%20cmd53%20write%20error%3D-110%3CBR%20%2F%3E%5B%2076.353352%5D%20host_too_card%2C%20write%20iomem%20(1)%20failed%3A%20-1%3CBR%20%2F%3E%5B%2076.359014%5D%20write%20CFG%20reg%20failed%3CBR%20%2F%3E%5B%2076.362560%5D%20cmd53%20write%20error%3D-110%3CBR%20%2F%3E%5B%2076.366184%5D%20host_too_card%2C%20write%20iomem%20(2)%20%E5%A4%B1%E8%B4%A5%EF%BC%9A-1%3CBR%20%2F%3E%5B%2076.371495%5D%20write%20CFG%20reg%20%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%5B%2076.374999%5D%20cmd53%20write%20error%3D-110%3CBR%20%2F%3E%5B%2076.402254%5D%20host_too_card%2C%20write%20iomem%20(3)%20%E5%A4%B1%E8%B4%A5%EF%BC%9A-1%3CBR%20%2F%3E%5B%2076.407537%5D%20write%20CFG%20reg%20%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%5B%2076.410971%5D%20Error%3A%20host_to_card%20failed%3A%200xFFFFFFFF%3CBR%20%2F%3E%5B%2076.416043%5D%20DNLD_CMD%3A%20Host%20to%20Card%20Failed%3CBR%20%2F%3E%5B%2076.420306%5D%20IOCTL%20failed%3A%20ef7a4e76%20id%3D0x90000%2C%20sub_id%3D0x90001%20action%3D1%2C%20status_code%3D0x80000006%20%5BCMD_DNLD_FAIL%5D%3CBR%20%2F%3E%5B%2076.430903%5D%20------------Dump%20info-----------%3CBR%20%2F%3E%5B%2076.435415%5D%20Command%20to%20card%20failure%3CBR%20%2F%3E%5B%2076.439111%5D%20pending%20command%20id%3A%200x10%20ioctl_buf%3D%20(null)%3CBR%20%2F%3E%5B%2076.444634%5D%20pending%20command%20id%3A%200x28%20ioctl_buf%3Da69aa9f8%3CBR%20%2F%3E%5B%2076.450155%5D%E6%B2%A1%E6%9C%89%E5%BE%85%E6%89%A7%E8%A1%8C%E7%9A%84%E6%89%AB%E6%8F%8F%E5%91%BD%E4%BB%A4%3CBR%20%2F%3E%5B%2076.453847%5D%20CurCmd%20%E7%A9%BA%3CBR%20%2F%3E%5B%2076.456521%5D%20mlan_processing%20%3D1%3CBR%20%2F%3E%5B%2076.459753%5D%20main_lock_flag%20%3D0%3CBR%20%2F%3E%5B%2076.462885%5D%20main_process_cnt%20%3D75%3CBR%20%2F%3E%5B%2076.466292%5D%20delay_task_flag%20%3D0%3CBR%20%2F%3E%5B%2076.469523%5D%20mlan_rx_processing%20%3D0%3CBR%20%2F%3E%5B%2076.473022%5D%20rx_pkts_queued%3D0%3CBR%20%2F%3E%5B%2076.476061%5D%20more_task_flag%20%3D%200%3CBR%20%2F%3E%5B%2076.479292%5D%20num_cmd_timeout%20%3D%200%3CBR%20%2F%3E%5B%2076.482607%5D%20last_cmd_index%20%3D%202%3CBR%20%2F%3E%5B%2076.485830%5D%20last_cmd_id%20%3D%3CBR%20%2F%3E%5B%2076.485834%5D%200x27c%3CBR%20%2F%3E%5B%2076.488698%5D%200x27c%3CBR%20%2F%3E%5B%2076.490818%5D%200x243%3CBR%20%2F%3E%5B%2076.492938%5D%200xe4%3CBR%20%2F%3E%5B%2076.495058%5D%200x5b%3CBR%20%2F%3E%5B%2076.497086%5D%200x242%3CBR%20%2F%3E%5B%2076.499123%5D%200x4d%3CBR%20%2F%3E%5B%2076.501243%5D%200xd1%3CBR%20%2F%3E%5B%2076.503271%5D%200x10%3CBR%20%2F%3E%5B%2076.505299%5D%200x28%3C%2FP%3E%3CP%3E%5B%2076.510935%5D%20last_cmd_act%20%3D%3CBR%20%2F%3E%5B%2076.510937%5D%200x0%3CBR%20%2F%3E%5B%2076.513885%5D%200x1%3CBR%20%2F%3E%5B%2076.515821%5D%200x0%3CBR%20%2F%3E%5B%2076.517757%5D%200xff%3CBR%20%2F%3E%5B%2076.519704%5D%200x1%3CBR%20%2F%3E%5B%2076.521732%5D%200x1%3CBR%20%2F%3E%5B%2076.523668%5D%200x1%3CBR%20%2F%3E%5B%2076.525604%5D%200x0%3CBR%20%2F%3E%5B%2076.527540%5D%200x1%3CBR%20%2F%3E%5B%2076.529486%5D%200x213%3C%2FP%3E%3CP%3E%5B%2076.535109%5D%20last_cmd_resp_index%20%3D%202%3CBR%20%2F%3E%5B%2076.538799%5D%20last_cmd_resp_id%20%3D%3CBR%20%2F%3E%5B%2076.538802%5D%200x827c%3CBR%20%2F%3E%5B%2076.542117%5D%200x827c%3CBR%20%2F%3E%5B%2076.544329%5D%200x8243%3CBR%20%2F%3E%5B%2076.546540%5D%200x805b%3CBR%20%2F%3E%5B%2076.548761%5D%200x805b%3CBR%20%2F%3E%5B%2076.550973%5D%200x8242%3CBR%20%2F%3E%5B%2076.553185%5D%200x804d%3CBR%20%2F%3E%5B%2076.555396%5D%200x80d1%3CBR%20%2F%3E%5B%2076.557608%5D%200x8010%3CBR%20%2F%3E%5B%2076.559828%5D%200x8028%3C%2FP%3E%3CP%3E%5B%2076.565819%5D%20last_event_index%20%3D%201%3CBR%20%2F%3E%5B%2076.569233%5D%20last_event%20%3D%3CBR%20%2F%3E%5B%2076.569236%5D%200x0%3CBR%20%2F%3E%5B%2076.571999%5D%200x81%3CBR%20%2F%3E%5B%2076.573936%5D%200x0%3CBR%20%2F%3E%5B%2076.575963%5D%200x0%3CBR%20%2F%3E%5B%2076.577907%5D%200x0%3CBR%20%2F%3E%5B%2076.579844%5D%200x0%3CBR%20%2F%3E%5B%2076.581780%5D%200x0%3CBR%20%2F%3E%5B%2076.583716%5D%200x0%3CBR%20%2F%3E%5B%2076.585652%5D%200x0%3CBR%20%2F%3E%5B%2076.587587%5D%200x0%3C%2FP%3E%3CP%3E%5B%2076.593035%5D%20num_data_h2c_failure%20%3D%200%3CBR%20%2F%3E%5B%2076.596809%5D%20num_cmd_h2c_failure%20%3D%201%3CBR%20%2F%3E%5B%2076.600500%5D%20num_data_c2h_failure%20%3D%200%3CBR%20%2F%3E%5B%2076.604275%5D%20num_cmdevt_c2h_failure%20%3D%200%3CBR%20%2F%3E%5B%2076.608241%5D%20num_int_read_failure%20%3D%200%3CBR%20%2F%3E%5B%2076.612015%5D%20last_int_status%20%3D%2064%3CBR%20%2F%3E%5B%2076.615422%5D%20num_alloc_buffer_failure%20%3D%200%3CBR%20%2F%3E%5B%2076.619572%5D%20num_pkt_dropped%20%3D%200%3CBR%20%2F%3E%5B%2076.622888%5D%20num_noo_cmd_node%20%3D%200%3CBR%20%2F%3E%5B%2076.626202%5D%20num_event_deauth%20%3D%200%3CBR%20%2F%3E%5B%2076.629617%5D%20num_event_disassoc%20%3D%200%3CBR%20%2F%3E%5B%2076.633208%5D%20num_event_link_lost%20%3D%200%3CBR%20%2F%3E%5B%2076.636890%5D%20num_cmd_deauth%20%3D%200%3CBR%20%2F%3E%5B%2076.640121%5D%20num_cmd_assoc_success%20%3D%200%3CBR%20%2F%3E%5B%2076.643987%5D%20num_cmd_assoc_failure%20%3D%200%3CBR%20%2F%3E%5B%2076.647860%5D%20num_cons_assoc_failure%20%3D%200%3CBR%20%2F%3E%5B%2076.651818%5D%20cmd_resp_received%3D0%3CBR%20%2F%3E%5B%2076.655133%5D%20event_received%3D0%3CBR%20%2F%3E%5B%2076.658180%5D%20max_tx_buf_size%3D4096%3CBR%20%2F%3E%5B%2076.661587%5D%20tx_buf_size%3D3072%3CBR%20%2F%3E%5B%2076.664626%5D%20curr_tx_buf_size%3D3072%3CBR%20%2F%3E%5B%2076.668134%5D%20data_sent%3D0%20cmd_sent%3D0%3CBR%20%2F%3E%5B%2076.671725%5D%20ps_mode%3D1%20ps_state%3D0%3CBR%20%2F%3E%5B%2076.675133%5D%20wakeup_dev_req%3D0%20wakeup_tries%3D0%20wakeup_timeout%3D0%3CBR%20%2F%3E%5B%2076.681121%5D%20hs_configured%3D0%20hs_activated%3D0%3CBR%20%2F%3E%5B%2076.685448%5D%20pps_uapsd_mode%3D0%20sleep_pd%3D0%3CBR%20%2F%3E%5B%2076.689506%5D%20tx_lock_flag%20%3D%200%3CBR%20%2F%3E%5B%2076.692545%5D%20scan_processing%20%3D%200%3CBR%20%2F%3E%5B%2076.695859%5D%20scan_state%20%3D%200x0%3CBR%20%2F%3E%5B%2076.698907%5D%20bypass_pkt_count%3D0%3CBR%20%2F%3E%5B%2076.702132%5D%20mp_rd_bitmap%3D0x0%20curr_rd_port%3D0x0%3CBR%20%2F%3E%5B%2076.706734%5D%20mp_wr_bitmap%3D0xffffff%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%2076.711987%5D%20mp_data_port_mask%20%3D%200xffffff%3CBR%20%2F%3E%5B%2076.716314%5D%20last_recv_rd_bitmap%3D0x0%20mp_invalid_update%3D0%3CBR%20%2F%3E%5B%2076.721843%5D%20last_recv_wr_bitmap%3D0xffffffff%20last_mp_index%3D0%3CBR%20%2F%3E%5B%2076.727641%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%2076.734364%5D%200x00%3CBR%20%2F%3E%5B%2076.734367%5D%200x00%3CBR%20%2F%3E%5B%2076.736395%5D%200x00%3CBR%20%2F%3E%5B%2076.738432%5D%200x00%3CBR%20%2F%3E%5B%2076.740460%5D%200x00%3CBR%20%2F%3E%5B%2076.742488%5D%200x00%3CBR%20%2F%3E%5B%2076.744516%5D%200x00%3CBR%20%2F%3E%5B%2076.746543%5D%200x00%3CBR%20%2F%3E%5B%2076.748580%5D%200x00%3CBR%20%2F%3E%5B%2076.750609%5D%200x00%3CBR%20%2F%3E%5B%2076.752637%5D%200x00%3CBR%20%2F%3E%5B%2076.754665%5D%200x00%3CBR%20%2F%3E%5B%2076.756692%5D%200x00%3CBR%20%2F%3E%5B%2076.758729%5D%200x00%3CBR%20%2F%3E%5B%2076.760757%5D%200x00%3CBR%20%2F%3E%5B%2076.762785%5D%200x00%3C%2FP%3E%3CP%3E%5B%2076.768417%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%2076.775131%5D%200x00%3CBR%20%2F%3E%5B%2076.775133%5D%200x00%3CBR%20%2F%3E%5B%2076.777162%5D%200x00%3CBR%20%2F%3E%5B%2076.779199%5D%200x00%3CBR%20%2F%3E%5B%2076.781227%5D%200x00%3CBR%20%2F%3E%5B%2076.783255%5D%200x00%3CBR%20%2F%3E%5B%2076.785283%5D%200x00%3CBR%20%2F%3E%5B%2076.787311%5D%200x00%3CBR%20%2F%3E%5B%2076.789348%5D%200x00%3CBR%20%2F%3E%5B%2076.791376%5D%200x00%3CBR%20%2F%3E%5B%2076.793404%5D%200x00%3CBR%20%2F%3E%5B%2076.795437%5D%200x00%3CBR%20%2F%3E%5B%2076.797465%5D%200x00%3CBR%20%2F%3E%5B%2076.799502%5D%200x00%3CBR%20%2F%3E%5B%2076.801531%5D%200x00%3CBR%20%2F%3E%5B%2076.803559%5D%200x00%3C%2FP%3E%3CP%3E%5B%2076.809192%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%2076.815906%5D%200x00%3CBR%20%2F%3E%5B%2076.815908%5D%200x00%3CBR%20%2F%3E%5B%2076.817944%5D%200x00%3CBR%20%2F%3E%5B%2076.819973%5D%200x00%3CBR%20%2F%3E%5B%2076.822001%5D%200x00%3CBR%20%2F%3E%5B%2076.824029%5D%200x00%3CBR%20%2F%3E%5B%2076.826057%5D%200x00%3CBR%20%2F%3E%5B%2076.828093%5D%200x00%3CBR%20%2F%3E%5B%2076.830121%5D%200x00%3CBR%20%2F%3E%5B%2076.832149%5D%200x00%3CBR%20%2F%3E%5B%2076.834177%5D%200x00%3CBR%20%2F%3E%5B%2076.836205%5D%200x00%3CBR%20%2F%3E%5B%2076.838241%5D%200x00%3CBR%20%2F%3E%5B%2076.840269%5D%200x00%3CBR%20%2F%3E%5B%2076.842297%5D%200x00%3CBR%20%2F%3E%5B%2076.844325%5D%200x00%3C%2FP%3E%3CP%3E%5B%2076.849957%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%2076.856671%5D%200x00%3CBR%20%2F%3E%5B%2076.856673%5D%200x00%3CBR%20%2F%3E%5B%2076.858711%5D%200x00%3CBR%20%2F%3E%5B%2076.860739%5D%200x00%3CBR%20%2F%3E%5B%2076.862774%5D%200x00%3CBR%20%2F%3E%5B%2076.864803%5D%200x00%3CBR%20%2F%3E%5B%2076.866831%5D%200x00%3CBR%20%2F%3E%5B%2076.868868%5D%200x00%3CBR%20%2F%3E%5B%2076.870897%5D%200x00%3CBR%20%2F%3E%5B%2076.872925%5D%200x00%3CBR%20%2F%3E%5B%2076.874953%5D%200x00%3CBR%20%2F%3E%5B%2076.876981%5D%200x00%3CBR%20%2F%3E%5B%2076.879018%5D%200x00%3CBR%20%2F%3E%5B%2076.881046%5D%200x00%3CBR%20%2F%3E%5B%2076.883074%5D%200x00%3CBR%20%2F%3E%5B%2076.885102%5D%200x00%3C%2FP%3E%3CP%3E%5B%2076.890734%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%2076.897448%5D%200x00%3CBR%20%2F%3E%5B%2076.897451%5D%200x00%3CBR%20%2F%3E%5B%2076.899488%5D%200x00%3CBR%20%2F%3E%5B%2076.901516%5D%200x00%3CBR%20%2F%3E%5B%2076.903544%5D%200x00%3CBR%20%2F%3E%5B%2076.905572%5D%200x00%3CBR%20%2F%3E%5B%2076.907599%5D%200x00%3CBR%20%2F%3E%5B%2076.909636%5D%200x00%3CBR%20%2F%3E%5B%2076.911665%5D%200x00%3CBR%20%2F%3E%5B%2076.913693%5D%200x00%3CBR%20%2F%3E%5B%2076.915721%5D%200x00%3CBR%20%2F%3E%5B%2076.917749%5D%200x00%3CBR%20%2F%3E%5B%2076.919785%5D%200x00%3CBR%20%2F%3E%5B%2076.921813%5D%200x00%3CBR%20%2F%3E%5B%2076.923841%5D%200x00%3CBR%20%2F%3E%5B%2076.925869%5D%200x00%3C%2FP%3E%3CP%3E%5B%2076.931501%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%2076.938223%5D%200x00%3CBR%20%2F%3E%5B%2076.938226%5D%200x00%3CBR%20%2F%3E%5B%2076.940254%5D%200x00%3CBR%20%2F%3E%5B%2076.942282%5D%200x00%3CBR%20%2F%3E%5B%2076.944310%5D%200x00%3CBR%20%2F%3E%5B%2076.946337%5D%200x00%3CBR%20%2F%3E%5B%2076.948374%5D%200x00%3CBR%20%2F%3E%5B%2076.950402%5D%200x00%3CBR%20%2F%3E%5B%2076.952430%5D%200x00%3CBR%20%2F%3E%5B%2076.954457%5D%200x00%3CBR%20%2F%3E%5B%2076.956485%5D%200x00%3CBR%20%2F%3E%5B%2076.958521%5D%200x00%3CBR%20%2F%3E%5B%2076.960550%5D%200x00%3CBR%20%2F%3E%5B%2076.962578%5D%200x00%3CBR%20%2F%3E%5B%2076.964605%5D%200x00%3CBR%20%2F%3E%5B%2076.966633%5D%200x00%3C%2FP%3E%3CP%3E%5B%2076.972265%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%2076.978987%5D%200x00%3CBR%20%2F%3E%5B%2076.978990%5D%200x00%3CBR%20%2F%3E%5B%2076.981018%5D%200x00%3CBR%20%2F%3E%5B%2076.983046%5D%200x00%3CBR%20%2F%3E%5B%2076.985074%5D%200x00%3CBR%20%2F%3E%5B%2076.987102%5D%200x00%3CBR%20%2F%3E%5B%2076.989138%5D%200x00%3CBR%20%2F%3E%5B%2076.991167%5D%200x00%3CBR%20%2F%3E%5B%2076.993195%5D%200x00%3CBR%20%2F%3E%5B%2076.995222%5D%200x00%3CBR%20%2F%3E%5B%2076.997250%5D%200x00%3CBR%20%2F%3E%5B%2076.999286%5D%200x00%3CBR%20%2F%3E%5B%2077.001315%5D%200x00%3CBR%20%2F%3E%5B%2077.003343%5D%200x00%3CBR%20%2F%3E%5B%2077.005371%5D%200x00%3CBR%20%2F%3E%5B%2077.007399%5D%200x00%3C%2FP%3E%3CP%3E%5B%2077.013031%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%2077.019753%5D%200x00%3CBR%20%2F%3E%5B%2077.019756%5D%200x00%3CBR%20%2F%3E%5B%2077.021784%5D%200x00%3CBR%20%2F%3E%5B%2077.023812%5D%200x00%3CBR%20%2F%3E%5B%2077.025840%5D%200x00%3CBR%20%2F%3E%5B%2077.027876%5D%200x00%3CBR%20%2F%3E%5B%2077.029905%5D%200x00%3CBR%20%2F%3E%5B%2077.031940%5D%200x00%3CBR%20%2F%3E%5B%2077.033969%5D%200x00%3CBR%20%2F%3E%5B%2077.035997%5D%200x00%3CBR%20%2F%3E%5B%2077.038033%5D%200x00%3CBR%20%2F%3E%5B%2077.040062%5D%200x00%3CBR%20%2F%3E%5B%2077.042090%5D%200x00%3CBR%20%2F%3E%5B%2077.044118%5D%200x00%3CBR%20%2F%3E%5B%2077.046145%5D%200x00%3CBR%20%2F%3E%5B%2077.048182%5D%200x00%3C%2FP%3E%3CP%3E%5B%2077.053806%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%2077.060529%5D%200x00%3CBR%20%2F%3E%5B%2077.060531%5D%200x00%3CBR%20%2F%3E%5B%2077.062560%5D%200x00%3CBR%20%2F%3E%5B%2077.064587%5D%200x00%3CBR%20%2F%3E%5B%2077.066615%5D%200x00%3CBR%20%2F%3E%5B%2077.068652%5D%200x00%3CBR%20%2F%3E%5B%2077.0x00%3CBR%20%2F%3E%5B%2077.072708%5D%200x00%3CBR%20%2F%3E%5B%2077.074736%5D%200x00%3CBR%20%2F%3E%5B%2077.076764%5D%200x00%3CBR%20%2F%3E%5B%2077.078801%5D%200x00%3CBR%20%2F%3E%5B%2077.080829%5D%200x00%3CBR%20%2F%3E%5B%2077.082857%5D%200x00%3CBR%20%2F%3E%5B%2077.084884%5D%200x00%3CBR%20%2F%3E%5B%2077.086912%5D%200x00%3CBR%20%2F%3E%5B%2077.088949%5D%200x00%3C%2FP%3E%3CP%3E%5B%2077.094572%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%2077.101295%5D%200x00%3CBR%20%2F%3E%5B%2077.101297%5D%200x00%3CBR%20%2F%3E%5B%2077.103326%5D%200x00%3CBR%20%2F%3E%5B%2077.105354%5D%200x00%3CBR%20%2F%3E%5B%2077.107381%5D%200x00%3CBR%20%2F%3E%5B%2077.109418%5D%200x00%3CBR%20%2F%3E%5B%2077.111446%5D%200x00%3CBR%20%2F%3E%5B%2077.113474%5D%200x00%3CBR%20%2F%3E%5B%2077.115502%5D%200x00%3CBR%20%2F%3E%5B%2077.117529%5D%200x00%3CBR%20%2F%3E%5B%2077.119566%5D%200x00%3CBR%20%2F%3E%5B%2077.121595%5D%200x00%3CBR%20%2F%3E%5B%2077.123623%5D%200x00%3CBR%20%2F%3E%5B%2077.125650%5D%200x00%3CBR%20%2F%3E%5B%2077.127678%5D%200x00%3CBR%20%2F%3E%5B%2077.129715%5D%200x00%3C%2FP%3E%3CP%3E%5B%2077.135341%5D%20bss_index%20%3D%200%2C%20tx_pkts_queued%20%3D%200%20tx_pause%3CBR%20%2F%3E%5B%2077.140796%5D%20Host%3Achillair-r1234yf-00050%20Timestamp%3A9c6953b9%3CBR%20%2F%3E%5B%2077.146691%5D%20Driver%20version%20%3D%20SDIW612---18.99.2.p19.10-MM6X18540.p33-GPL-(FP92)%3CBR%20%2F%3E%5B%2077.154431%5D%20main_state%20%3D%203%3CBR%20%2F%3E%5B%2077.157287%5D%20ioctl_pending%20%3D%201%3CBR%20%2F%3E%5B%2077.160428%5D%20tx_pending%20%3D%200%3CBR%20%2F%3E%5B%2077.163285%5D%20wmm_tx_pending%5B0%5D%20%3D%200%3CBR%20%2F%3E%5B%2077.166783%5D%20wmm_tx_pending%5B1%5D%20%3D%200%3CBR%20%2F%3E%5B%2077.170291%5D%20wmm_tx_pending%5B2%5D%20%3D%200%3CBR%20%2F%3E%5B%2077.173790%5D%20wmm_tx_pending%5B3%5D%20%3D%200%3CBR%20%2F%3E%5B%2077.177288%5D%20rx_pending%20%3D%200%3CBR%20%2F%3E%5B%2077.180152%5D%20lock_count%20%3D%2044%3CBR%20%2F%3E%5B%2077.183100%5D%20malloc_count%20%3D%2049%3CBR%20%2F%3E%5B%2077.186231%5D%20mbufalloc_count%20%3D%200%3CBR%20%2F%3E%5B%2077.189554%5D%20hs_skip_count%20%3D%200%3CBR%20%2F%3E%5B%2077.192685%5D%20hs_force_count%20%3D%200%3CBR%20%2F%3E%5B%2077.195909%5D%20Media%20state%20%3D%22Disconnected%22%3CBR%20%2F%3E%20%5B%2077.200059%5D%20carrier%20off%3CBR%20%2F%3E%5B%2077.202641%5D%20tx%20queue%200%3A%20stopped%3CBR%20%2F%3E%5B%2077.205956%5D%20tx%20queue%201%3A%20stopped%3CBR%20%2F%3E%5B%2077.209279%5D%20tx%20queue%202%3A%20stopped%3CBR%20%2F%3E%5B%2077.212595%5D%20tx%20%E9%98%9F%E5%88%97%203%3A%20stopped%3CBR%20%2F%3E%5B%2077.215911%5D%20mlan0%3A%20num_tx_timeout%20%3D%200%3CBR%20%2F%3E%5B%2077.219799%5D%20--------%20Dump%20info%20End---------%3CBR%20%2F%3E%5B%2077.237865%5D%20IPv6%3A%20ADDRCONF(NETDEV_UP)%3A%20mlan0%3A%20link%20is%20not%20ready%3CBR%20%2F%3E%5B%2077.270404%5D%20SDIO%20Func0%20(0x0-0x9)%EF%BC%9AERR%3CBR%20%2F%3E%5B%2077.274349%5D%20SDIO%20Func1%20(0x10-0x17)%EF%BC%9AERR%3CBR%20%2F%3E%5B%2077.278454%5D%20SDIO%20Func1%3A%20(0x8)%20ERR%3CBR%20%2F%3E%5B%2077.282147%5D%20SDIO%20Func1%20(0xe8-0xff)%EF%BC%9AERR%3CBR%20%2F%3E%5B%2077.387444%5D%20SDIO%20Func1%20(0xe8-0xff)%EF%BC%9AERR%3CBR%20%2F%3E%5B%2077.391567%5D%20set%20pending%20clean%3CBR%20%2F%3E%5B%2077.471612%5D%20SDIO%20Write%20ERR%3CBR%20%2F%3E%5B%2077.474573%5D%20SDIO%20Write%20ERR%3CBR%20%2F%3E%5B%2077.477436%5D%20%3D%3D%3D%3D%20DEBUG%20MODE%20OUTPUT%20START%3A%2077.469673%20%3D%3D%3D%3D%3CBR%20%2F%3E%5B%2077.483111%5D%20SDIO%20Write%20ERR%3CBR%20%2F%3E%5B%2077.485995%5D%20SDIO%20Write%20ERR%3CBR%20%2F%3E%5B%2077.488871%5D%20%3D%3D%3D%3D%20DEBUG%20MODE%20END%20%3D%3D%3D%3D%3CBR%20%2F%3E%5B%2077.492866%5D%20IOCTL%20%E5%A4%B1%E8%B4%A5%EF%BC%9A%20a69aa9f8%20id%3D0x20000%2C%20sub_id%3D0x20007%20action%3D1%2C%20status_code%3D0x80000007%20%5BCMD_CANCEL%5D%20(CMD_CANCEL)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IW611%3A%20Unable%20to%20setup%20Linux%20driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378752%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263577%22%20target%3D%22_blank%22%3E%40mlytvyn%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E8%AF%95%E8%AF%95%2050MHz%20%E7%9A%84%E9%A2%91%E7%8E%87%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%82%96%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IW611%3A%20Unable%20to%20setup%20Linux%20driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%9C%89%20TI%20Sitara%20AM4376%E3%80%82%20%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20966px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20966px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20966px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20966px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20966px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388354iEBAA369BF18B26E1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimage.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388355i5B7F28E3BD836856%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimage.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EMMC%20%E6%80%BB%E7%BA%BF%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Bmmc3%20%7B%0A%09status%20%3D%20%22okay%22%3B%09%0A%09dmas%20%3D%20%26lt%3B%26amp%3Bedma_xbar%2030%200%201%26gt%3B%2C%0A%09%09%20%20%20%26lt%3B%26amp%3Bedma_xbar%2031%200%202%26gt%3B%3B%0A%09dma-names%20%3D%20%22tx%22%2C%20%22rx%22%3B%0A%09pinctrl-names%20%3D%20%22default%22%2C%20%22sleep%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bmmc3_pins_default%26gt%3B%3B%0A%09pinctrl-1%20%3D%20%26lt%3B%26amp%3Bmmc3_pins_sleep%26gt%3B%3B%0A%09vmmc-supply%20%3D%20%26lt%3B%26amp%3Bdcdc4%26gt%3B%3B%0A%09bus-width%20%3D%20%26lt%3B4%26gt%3B%3B%0A%09cap-sdio-irq%3B%0A%09ti%2Cnon-removable%3B%0A%09max-frequency%20%3D%20%26lt%3B25000000%26gt%3B%3B%20%20%20%2F*%20slow%20down%20to%2025MHz%20for%20bring-up%20*%2F%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3EMMC%20%E6%80%BB%E7%BA%BF%E6%8E%A7%E5%88%B6%E5%99%A8%E8%AE%BE%E6%B3%95%E6%A3%80%E6%B5%8B%E5%88%B0%20Wi-Fi%20%E8%8A%AF%E7%89%87%EF%BC%8C%E5%86%85%E6%A0%B8%E5%8A%A0%E8%BD%BD%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BD%BF%E7%94%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E5%9B%BA%E4%BB%B6%20blob%20%E9%97%AA%E5%AD%98%E4%BA%86%E8%8A%AF%E7%89%87%EF%BC%8C%E5%B9%B6%E4%BB%8E%E8%8A%AF%E7%89%87%E4%B8%AD%E8%8E%B7%E5%BE%97%E4%BA%86%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%E3%80%82%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%EF%BC%8C%E8%BF%99%E4%B8%8D%E5%83%8F%E6%98%AF%20SDIO%20%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%EF%BC%8C%E8%80%8C%E5%83%8F%E6%98%AF%E4%B8%8E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E6%88%96%20FW%EF%BC%89%E6%9C%89%E5%85%B3%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E7%AC%AC%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%E5%8F%91%E7%94%9F%E5%9C%A8%E8%BF%99%E9%87%8C%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B%2010.529596%5D%20IOCTL%20%E5%A4%B1%E8%B4%A5%EF%BC%9A%201b0efb8f%20id%3D0x200000%2C%20sub_id%3D0x200046%20action%3D1%2C%20status_code%3D0x3%20%5BFW_CMDRESP%5D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%8F%B8%E6%9C%BA%E5%9C%A8%E8%BF%99%E4%B8%AA%E9%98%B6%E6%AE%B5%E8%A6%81%E5%81%9A%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%B1%B3%E5%93%88%E4%BC%8A%E6%B4%9B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IW611%3A%20Unable%20to%20setup%20Linux%20driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263577%22%20target%3D%22_blank%22%3E%40mlytvyn%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E5%8F%B0%E4%B8%BB%E6%9C%BA%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A0%E8%BD%BD%E5%92%8C%E5%9B%BA%E4%BB%B6%E4%B8%8B%E8%BD%BD%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%0A%3CP%3Esdio%20%E9%80%9A%E4%BF%A1%E6%8A%A5%E5%91%8A%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%82%96%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IW611%3A%20Unable%20to%20setup%20Linux%20driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%8F%98%E5%8C%96%E4%B8%8D%E5%A4%A7%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mlytvyn_0-1780995812806.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mlytvyn_0-1780995812806.png%22%20style%3D%22width%3A%20952px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mlytvyn_0-1780995812806.png%22%20style%3D%22width%3A%20952px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mlytvyn_0-1780995812806.png%22%20style%3D%22width%3A%20952px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388404iAFA5BE87B45F6D79%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22mlytvyn_0-1780995812806.png%22%20alt%3D%22mlytvyn_0-1780995812806.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emlytvyn_0-1780995812806.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%BF%99%E9%87%8C%EF%BC%8C%E6%88%91%E5%90%AF%E5%8A%A8%E4%BA%86%20mlan0%EF%BC%8C%E7%84%B6%E5%90%8E%E5%BE%97%E5%88%B0%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mlytvyn_2-1780995954838.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mlytvyn_2-1780995954838.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mlytvyn_2-1780995954838.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mlytvyn_2-1780995954838.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388407i3E59E1BA24CB8649%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22mlytvyn_2-1780995954838.png%22%20alt%3D%22mlytvyn_2-1780995954838.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emlytvyn_2-1780995954838.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mlytvyn_1-1780995851394.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mlytvyn_1-1780995851394.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mlytvyn_1-1780995851394.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mlytvyn_1-1780995851394.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388405iB94442459F729C0E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22mlytvyn_1-1780995851394.png%22%20alt%3D%22mlytvyn_1-1780995851394.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emlytvyn_1-1780995851394.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%20IOCTL%20failed%3A%2061e24fe7%20id%3D0x200000%2C%20sub_id%3D0x200046%20action%3D1%2C%20status_code%3D0x3%20%5BFW_CMDRESP%5D%20%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IW611%3A%20Unable%20to%20setup%20Linux%20driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263577%22%20target%3D%22_blank%22%3E%40mlytvyn%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%AC%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E7%A7%8D%20iw612%20%E6%A8%A1%E5%9D%97%EF%BC%9F%E8%BF%98%E6%98%AF%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20iw612evk%EF%BC%9F%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%E4%BD%A0%E7%9A%84%20sd%20%E6%8E%A5%E5%8F%A3%E6%98%AF%203.3V%EF%BC%8C%E4%BD%A0%E5%8C%B9%E9%85%8D%E4%BA%86%20sdio%20%E5%8A%9F%E7%8E%87%E7%BA%A7%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%82%96%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2380322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IW611%3A%20Unable%20to%20setup%20Linux%20driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20Silex%20SX-SDMAX%20%E8%A1%A8%E9%9D%A2%E8%B4%B4%E8%A3%85%E7%89%88%EF%BC%88%3CA%20href%3D%22https%3A%2F%2Fwww.silextechnology.com%2Fconnectivity-solutions%2Fembedded-wireless%2Fsx-sdmax)%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.silextechnology.com%2Fconnectivity-solutions%2Fembedded-wireless%2Fsx-sdmax%EF%BC%89%3C%2FA%3E%E3%80%82%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8CVIO%20%E5%92%8C%20VIO_SD%20%E4%B8%8A%E7%9A%84%E7%94%B5%E5%8E%8B%E5%86%B3%E5%AE%9A%E4%BA%86%E4%BF%A1%E5%8F%B7%E7%94%B5%E5%B9%B3%E3%80%82%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
