How to I do RF test
How to I do RF test
LarryLee
I used I.MX95 + IW61x to do RF test what the method is following  MFG and UM11490 document in WIfi and BT.
1. Using MFG method worked on Wifi but the BT didn't work.
2. Using UM11490 method didn't work both on Wifi and BT.
The command like below,
So My question
1. How can I test BT's RF test?
2. Why I can't use UM11490's method to do wifi RF test?
My MFG tool version is MFG-NW61X-MF-LABTOOL-Native-BRG-WIN-X86-2.0.0.32-18.80.3.p23.6
Thanks.
shaun_wu
Hello @LarryLee
Don't use mfg sdk for rf-test-mode. You should use general firmware to test.
Best Regards
Shaun
LarryLee
Hi @shaun_wu ,
Thanks for your reply.
Could you give me a sample workflow to trigger for doing BT RF test?
shaun_wu
Hello @LarryLee
UM11490 gives bt rf test steps on Chapter 4.10. You may refer to this part. If you have any problem about the doc, let us know.
Best Regards
Shaun
