I used I.MX95 + IW61x to do RF test what the method is following MFG and UM11490 document in WIfi and BT.
1. Using MFG method worked on Wifi but the BT didn't work.
2. Using UM11490 method didn't work both on Wifi and BT.
The command like below,
So My question
1. How can I test BT's RF test?
2. Why I can't use UM11490's method to do wifi RF test?
My MFG tool version is MFG-NW61X-MF-LABTOOL-Native-BRG-WIN-X86-2.0.0.32-18.80.3.p23.6
Thanks.
