FRDM-RW612 - Getting USB device error
pratikpanchal44
I am using FRDM-RW612 for my project. I have connected barcode scanner module on USB device to my FRDM board. Barcode scanner has USB HID support.
Now, I am getting an error continuously as per below, once I scan any barcode.
runwaitState 10,deviceState 1, usb status 0USB_HostKeyboardProcessBuffer means data recvd
Currently, I am using the SDK version SDK_25.06.00_FRDM-RW612.
Please advise.
pratikpanchal44
Hello Team,
Thanks for the solution.
Currently, the system is working fine, and we found a problem on the device side.
RomanVR
Hello @pratikpanchal44.
Thanks for letting us know that the issue has been solved.
Best Regards!
pratikpanchal44
Hello @Ricardo_Zamora
We have used the keyboard-mouse USB HID example in our device.
RomanVR
Hello @pratikpanchal44, hope you are doing well.
Could you please confirm which modifications (if any) were done to the project? Is your device being detected by the host (FRDM-RW612)?
Additionally, please notice that this example only supports three types of devices:
  • Single mouse or single keyboard devices.
  • Composite device containing one mouse and one keyboard.
  • HUBs connected with one mouse and one keyboard.
Any further development to add more supported devices will have to be done on the customer side, however if any further support is needed, feel free to reach us.
Best Regards!
Ricardo_Zamora
Hello @pratikpanchal44 , hope you are doing well.
Could you please specify which USB HID example are you using and the modifications done to it?
Also please confirm if the example runs properly as is.
Ricardo
%3CLINGO-SUB%20id%3D%22lingo-sub-2195125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-RW612%20-%20Getting%20USB%20device%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20using%20FRDM-RW612%20for%20my%20project.%20I%20have%20connected%20barcode%20scanner%20module%20on%20USB%20device%20to%20my%20FRDM%20board.%20Barcode%20scanner%20has%20USB%20HID%20support.%26nbsp%3B%3C%2FP%3E%3CP%3ENow%2C%20I%20am%20getting%20an%20error%20continuously%20as%20per%20below%2C%20once%20I%20scan%20any%20barcode.%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CDIV%3ErunwaitState%2010%2CdeviceState%201%2C%20usb%20status%200USB_HostKeyboardProcessBuffer%20means%20data%20recvd%3C%2FDIV%3E%3CDIV%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FDIV%3E%3CP%3ECurrently%2C%20I%20am%20using%20the%20SDK%20version%20%3CU%3E%3CSTRONG%3ESDK_25.06.00_FRDM-RW612%3C%2FSTRONG%3E%3C%2FU%3E.%3C%2FP%3E%3CP%3EPlease%20advise.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2200241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-RW612%20-%20Getting%20USB%20device%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256293%22%20target%3D%22_blank%22%3E%40pratikpanchal44%3C%2FA%3E.%3C%2FP%3E%0A%3CP%3EThanks%20for%20letting%20us%20know%20that%20the%20issue%20has%20been%20solved.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2200034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-RW612%20-%20Getting%20USB%20device%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Team%2C%3C%2FP%3E%3CP%3EThanks%20for%20the%20solution.%26nbsp%3B%3C%2FP%3E%3CP%3ECurrently%2C%20the%20system%20is%20working%20fine%2C%20and%20we%20found%20a%20problem%20on%20the%20device%20side.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2196111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-RW612%20-%20Getting%20USB%20device%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256293%22%20target%3D%22_blank%22%3E%40pratikpanchal44%3C%2FA%3E%2C%26nbsp%3Bhope%20you%20are%20doing%20well.%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20confirm%20which%20modifications%20(if%20any)%20were%20done%20to%20the%20project%3F%20Is%20your%20device%20being%20detected%20by%20the%20host%20(FRDM-RW612)%3F%3C%2FP%3E%0A%3CP%3EAdditionally%2C%20please%20notice%20that%20this%20example%20only%20supports%20three%20types%20of%20devices%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3ESingle%20mouse%20or%20single%20keyboard%20devices.%3C%2FLI%3E%0A%3CLI%3EComposite%20device%20containing%20one%20mouse%20and%20one%20keyboard.%3C%2FLI%3E%0A%3CLI%3EHUBs%20connected%20with%20one%20mouse%20and%20one%20keyboard.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EAny%20further%20development%20to%20add%20more%20supported%20devices%20will%20have%20to%20be%20done%20on%20the%20customer%20side%2C%20however%20if%20any%20further%20support%20is%20needed%2C%20feel%20free%20to%20reach%20us.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195479%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-RW612%20-%20Getting%20USB%20device%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195479%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F184557%22%20target%3D%22_blank%22%3E%40Ricardo_Zamora%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EWe%20have%20used%20the%20keyboard-mouse%20USB%20HID%20example%20in%20our%20device.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195302%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-RW612%20-%20Getting%20USB%20device%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195302%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256293%22%20target%3D%22_blank%22%3E%40pratikpanchal44%3C%2FA%3E%26nbsp%3B%2C%20hope%20you%20are%20doing%20well.%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20specify%20which%20USB%20HID%20example%20are%20you%20using%20and%20the%20modifications%20done%20to%20it%3F%3C%2FP%3E%0A%3CP%3EAlso%20please%20confirm%20if%20the%20example%20runs%20properly%20as%20is.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards%2C%3C%2FP%3E%0A%3CP%3ERicardo%3C%2FP%3E%3C%2FLINGO-BODY%3E
