AW611 WiFi chip Wi-Fi scan timeout
1,539 次查看
eric25
I am debugging the driver and encountered the following issue: after successfully loading the Wi-Fi driver, no Wi-Fi hotspots can be found during a Wi-Fi hotspot scan (phones can detect the hotspot, the hotspot is very close to the Wi-Fi module, and the module has an antenna installed). Checking dmesg seems to indicate a timeout. Please see the attachment for the detailed log. Could you help analyze the cause? Thank you.
My operation steps are as follows:
1. Platform: sama5d3, Linux version: 4.4.19
2. Load the driver using the following commands, and dmesg shows successful loading.
insmod mlan.ko
insmod moal.ko drv_mode=7 ps_mode=2 auto_ds=2 host_mlme=1 cal_data_cfg=none fw_name=nxp/sd_w61x_v1.bin.se sta_name=wlan wfd_name=p2p cfg80211_wext=0xf drvdbg=0x80037
3. Use the wlan0 device and scan for Wi-Fi hotspots
ifconfig wlan0 up
wpa_supplicant -B -Dnl80211 -iwlan0 -c /etc/wpa.conf
wpa_cli -i wlan0 -g/var/run/wpa_supplicant/wlan0 ap_scan 1
wpa_cli -i wlan0 scan
wpa_cli -i wlan0 scan_result
4. When executing the wpa_cli -i wlan0 scan command, dmesg displays the following information, and no hotspots are found (the phone can detect multiple hotspots).
Jan 1 06:20:45 (none) user.alert kernel: [ 750.575641] wlan: wlan0 START SCAN
Jan 1 06:21:05 (none) user.warn kernel: [ 770.653428] Ext scan enh timeout
Jan 1 06:21:05 (none) user.warn kernel: [ 770.653465] ------------Dump info-----------
Jan 1 06:21:05 (none) user.warn kernel: [ 770.653478] EXT_SCAN_STATUS event Timeout
Jan 1 06:21:05 (none) user.warn kernel: [ 770.653490] CurCmd Empty
破坏者
[ 5.416061] UBIFS (ubi0:8): reserved for root: 4952683 bytes (4836 KiB)
[ 5.416088] UBIFS (ubi0:8): media format: w4/r0 (latest is w4/r0), UUID 9C8DF7E6-05DA-4D41-A3C5-0029C4D16B41, small LPT model
[ 5.557978] UBIFS (ubi0:8): un-mount UBI device 0
[ 5.558049] UBIFS (ubi0:8): background thread "ubifs_bgt0_8" stops
[ 82.542976] wlan: Loading MWLAN driver
[ 82.550306] wlan: Register to Bus Driver...
[ 82.613986] vendor=0x0471 device=0x0205 class=0 function=1
[ 82.614205] Attach moal handle ops, card interface type: 0x109
[ 82.614248] No module param cfg file specified
[ 82.614273] combo fw:nxp/sduart_nw61x.bin.se wlan fw:nxp/sd_w61x.bin.se
[ 82.614317] SDIO: sdio_blk_size=256 max_blk_count=512 max_segs=64 max_seg_size=4096
[ 82.614333] rx_work=0 cpu_num=1
[ 82.614354] Enable moal_recv_amsdu_packet
[ 82.614448] Attach mlan adapter operations.card_type is 0x109.
[ 82.615544] wlan: Enable TX SG mode
[ 82.615573] wlan: mpa_tx.buf_size=4096
[ 82.615583] wlan: Enable RX SG mode
[ 82.615594] wlan: mpa_rx.buf_size=4096
[ 82.622224] Request firmware: nxp/sd_w61x_v1.bin.se
[ 82.748653] Wakeup device...
[ 82.952631] Wlan: FW download over, firmwarelen=681308 downloaded 565508
[ 83.349412] WLAN FW is active
[ 83.349451] on_time is 83330185801
[ 83.349895] QUEUE_CMD: FUNC_INIT [0xa9] is queued
[ 83.349930] QUEUE_CMD: GET_HW_SPEC [0x3] is queued
[ 83.349974] DNLD_CMD (83.330689): FUNC_INIT [0xa9], act 0x263, len 16, seqno 0x1 timeout 5000
[ 83.372560] CMD_RESP (83.353254): FUNC_INIT [0x80a9], result 0, len 16, seqno 0x1
[ 83.372622] DNLD_CMD (83.353337): GET_HW_SPEC [0x3], act 0x0, len 71, seqno 0x2 timeout 5000
[ 83.372964] 83.353669 : Event: VDLL_IND [0x81]
[ 83.373008] VDLL_IND (OFFSET): offset=0x1c458
[ 83.373947] VDLL image: len=115800
[ 83.374253] CMD_RESP (83.354955): GET_HW_SPEC [0x8003], result 0, len 205, seqno 0x2
[ 83.374281] fw_cap_info=0x487cff03, dev_cap_mask=0xffffffff
[ 83.374299] GET_HW_SPEC: country_code=0x0
[ 83.374310] num_ant=1, antinfo=0x0
[ 83.374324] GET_HW_SPEC: hw_mpdu_density=4 dev_mcs_support=0x11
[ 83.374335] Enable Beamforming
[ 83.374350] GET_HW_SPEC: mgmt IE count=13
[ 83.374365] FW: SDIO rx aggr disabled 0x487cff03
[ 83.374381] pmadapter->ecsa_enable=1
[ 83.374415] QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 83.374429] pmadapter->getlog_enable=1
[ 83.374451] chanrpt api ver=14.1
[ 83.374464] fw_cap_info=0x487cff03 fw_cap_ext=0x2182b5
[ 83.374479] uuid: c10d697cf87d596cab35c831392df315
[ 83.374491] fw hotfix ver=11
[ 83.374502] fw ver=15.1
[ 83.374512] uap fw ver=2.0
[ 83.374523] max_p2p_conn = 8, max_sta_conn = 16
[ 83.374541] wlan_set_regiontable: 2.4G 0x10
[ 83.374561] wlan_set_regiontable: 5G 0x10
[ 83.374599] Get Hw Spec done, fw_cap=0x487cff03
[ 83.374630] org_drv_mode=0x7 drv_mode=0x7
[ 83.375214] Enable Beamforming
[ 83.375274] QUEUE_CMD: 802_11_FW_WAKE_METHOD [0x74] is queued
[ 83.375301] set tx_buf = 4096
[ 83.375321] QUEUE_CMD: RECONFIGURE_TX_BUFF [0xd9] is queued
[ 83.375347] PS Command: action = 0x6, bitmap = 0x1
[ 83.375365] QUEUE_CMD: 802_11_PS_MODE_ENH [0xe4] is queued
[ 83.375395] QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 83.375424] QUEUE_CMD: 802_11_RF_ANTENNA [0x20] is queued
[ 83.375453] QUEUE_CMD: CHAN_REGION_CFG [0x242] is queued
[ 83.375484] QUEUE_CMD: TX_RATE_CFG [0xd6] is queued
[ 83.375511] QUEUE_CMD: 802_11_RF_TX_POWER [0x1e] is queued
[ 83.375539] QUEUE_CMD: AMSDU_AGGR_CTRL [0xdf] is queued
[ 83.375566] QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 83.375609] DNLD_CMD (83.356326): 802_11_SNMP_MIB [0x16], act 0x1, len 15, seqno 0x3 timeout 5000
[ 83.376003] CMD_RESP (83.356703): 802_11_SNMP_MIB [0x8016], result 0, len 15, seqno 0x3
[ 83.376057] DNLD_CMD (83.356773): 802_11_FW_WAKE_METHOD [0x74], act 0x0, len 12, seqno 0x4 timeout 5000
[ 83.376391] CMD_RESP (83.357094): 802_11_FW_WAKE_METHOD [0x8074], result 0, len 18, seqno 0x4
[ 83.376416] FW wakeup method=1, gpio=0
[ 83.376454] DNLD_CMD (83.357172): RECONFIGURE_TX_BUFF [0xd9], act 0x1, len 16, seqno 0x5 timeout 5000
[ 83.377529] CMD_RESP (83.358231): RECONFIGURE_TX_BUFF [0x80d9], result 0, len 16, seqno 0x5
[ 83.377559] end port 32, data port mask ffffffff
[ 83.377575] max_tx_buf_size=4096, tx_buf_size=3328
[ 83.377612] DNLD_CMD (83.358329): 802_11_PS_MODE_ENH [0xe4], act 0x6, len 20, seqno 0x6 timeout 5000
[ 83.377947] CMD_RESP (83.358650): 802_11_PS_MODE_ENH [0x80e4], result 0, len 20, seqno 0x6
[ 83.377995] DNLD_CMD (83.358713): 802_11_SNMP_MIB [0x16], act 0x1, len 18, seqno 0x7 timeout 5000
[ 83.378324] CMD_RESP (83.359029): 802_11_SNMP_MIB [0x8016], result 0, len 18, seqno 0x7
[ 83.378374] DNLD_CMD (83.359090): 802_11_RF_ANTENNA [0x20], act 0xc, len 16, seqno 0x8 timeout 5000
[ 83.378707] CMD_RESP (83.359411): 802_11_RF_ANTENNA [0x8020], result 0, len 16, seqno 0x8
[ 83.378757] DNLD_CMD (83.359472): CHAN_REGION_CFG [0x242], act 0x0, len 11, seqno 0x9 timeout 5000
[ 83.380238] CMD_RESP (83.360924): CHAN_REGION_CFG [0x8242], result 0, len 1297, seqno 0x9
[ 83.380344] DNLD_CMD (83.361055): TX_RATE_CFG [0xd6], act 0x0, len 76, seqno 0xa timeout 5000
[ 83.381077] CMD_RESP (83.361775): TX_RATE_CFG [0x80d6], result 0, len 832, seqno 0xa
[ 83.381136] DNLD_CMD (83.361851): 802_11_RF_TX_POWER [0x1e], act 0x0, len 14, seqno 0xb timeout 5000
[ 83.381490] CMD_RESP (83.362193): 802_11_RF_TX_POWER [0x801e], result 0, len 14, seqno 0xb
[ 83.381539] DNLD_CMD (83.362255): AMSDU_AGGR_CTRL [0xdf], act 0x1, len 14, seqno 0xc timeout 5000
[ 83.381859] CMD_RESP (83.362563): AMSDU_AGGR_CTRL [0x80df], result 0, len 14, seqno 0xc
[ 83.381908] DNLD_CMD (83.362624): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0xd timeout 5000
[ 83.382235] CMD_RESP (83.362940): MAC_CONTROL [0x8028], result 0, len 12, seqno 0xd
[ 83.382289] QUEUE_CMD: APCMD_SYS_CONFIGURE [0xb0] is queued
[ 83.382328] DNLD_CMD (83.363045): APCMD_SYS_CONFIGURE [0xb0], act 0x0, len 20, seqno 0x100e timeout 5000
[ 83.383416] CMD_RESP (83.364108): APCMD_SYS_CONFIGURE [0x80b0], result 0, len 20, seqno 0x100e
[ 83.383478] QUEUE_CMD: TX_RATE_CFG [0xd6] is queued
[ 83.383510] QUEUE_CMD: 802_11_RF_TX_POWER [0x1e] is queued
[ 83.383539] QUEUE_CMD: AMSDU_AGGR_CTRL [0xdf] is queued
[ 83.383567] QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 83.383593] QUEUE_CMD: 802_11_MAC_ADDRESS [0x4d] is queued
[ 83.383630] DNLD_CMD (83.364347): TX_RATE_CFG [0xd6], act 0x0, len 76, seqno 0x200f timeout 5000
[ 83.387943] CMD_RESP (83.368633): TX_RATE_CFG [0x80d6], result 0, len 832, seqno 0x200f
[ 83.388009] DNLD_CMD (83.368722): 802_11_RF_TX_POWER [0x1e], act 0x0, len 14, seqno 0x2010 timeout 5000
[ 83.388382] CMD_RESP (83.369085): 802_11_RF_TX_POWER [0x801e], result 0, len 14, seqno 0x2010
[ 83.388433] DNLD_CMD (83.369149): AMSDU_AGGR_CTRL [0xdf], act 0x1, len 14, seqno 0x2011 timeout 5000
[ 83.388775] CMD_RESP (83.369478): AMSDU_AGGR_CTRL [0x80df], result 0, len 14, seqno 0x2011
[ 83.388825] DNLD_CMD (83.369541): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0x2012 timeout 5000
[ 83.389139] CMD_RESP (83.369844): MAC_CONTROL [0x8028], result 0, len 12, seqno 0x2012
[ 83.389187] DNLD_CMD (83.369904): 802_11_MAC_ADDRESS [0x4d], act 0x0, len 16, seqno 0x2013 timeout 5000
[ 83.389639] CMD_RESP (83.370340): 802_11_MAC_ADDRESS [0x804d], result 0, len 16, seqno 0x2013
[ 83.389700] QUEUE_CMD: WMM_PARAM_CONFIG [0x23a] is queued
[ 83.389749] DNLD_CMD (83.370464): WMM_PARAM_CONFIG [0x23a], act 0x2, len 26, seqno 0x14 timeout 5000
[ 83.390091] CMD_RESP (83.370793): WMM_PARAM_CONFIG [0x823a], result 0, len 26, seqno 0x14
[ 83.392977] Set wiphy max_ap_assoc_sta=8
[ 83.393072] max_rate=390M
[ 83.393089] max_rate=390M
[ 83.393108] vht_cap=0x33d07030 rx_mcs_map=0xfffe rx_max=0x186 tx_mcs_map=0xfffe tx_max=0x186
[ 83.393129] max_rate=390M
[ 83.393139] max_rate=390M
[ 83.393155] vht_cap=0x33d07030 rx_mcs_map=0xfffe rx_max=0x186 tx_mcs_map=0xfffe tx_max=0x186
[ 83.393191] wlan%d: QUEUE_CMD: 802_11_RF_ANTENNA [0x20] is queued
[ 83.407537] wlan%d: DNLD_CMD (83.388260): 802_11_RF_ANTENNA [0x20], act 0xc, len 16, seqno 0x15 timeout 5000
[ 83.408034] wlan%d: CMD_RESP (83.388756): 802_11_RF_ANTENNA [0x8020], result 0, len 16, seqno 0x15
[ 83.408202] wlan%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 83.408278] wlan%d: DNLD_CMD (83.389008): 802_11_SNMP_MIB [0x16], act 0x0, len 142, seqno 0x16 timeout 5000
[ 83.408707] wlan%d: CMD_RESP (83.389430): 802_11_SNMP_MIB [0x8016], result 0, len 142, seqno 0x16
[ 83.408860] wlan%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 83.408930] wlan%d: DNLD_CMD (83.389661): 802_11_SNMP_MIB [0x16], act 0x0, len 142, seqno 0x17 timeout 5000
[ 83.409425] wlan%d: CMD_RESP (83.390146): 802_11_SNMP_MIB [0x8016], result 0, len 142, seqno 0x17
[ 83.409582] wlan%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 83.409653] wlan%d: DNLD_CMD (83.390383): 802_11_SNMP_MIB [0x16], act 0x0, len 142, seqno 0x18 timeout 5000
[ 83.410075] wlan%d: CMD_RESP (83.390798): 802_11_SNMP_MIB [0x8016], result 0, len 142, seqno 0x18
[ 83.410606] cfg80211 regulatory domain callback 00 initiator=0 dfs_region=0
[ 83.410668] Regulatory domain BY_CORE
[ 83.410738] wlan%d: QUEUE_CMD: 802_11_RF_ANTENNA [0x20] is queued
[ 83.410973] wlan%d: DNLD_CMD (83.391699): 802_11_RF_ANTENNA [0x20], act 0xc, len 16, seqno 0x19 timeout 5000
[ 83.411461] wlan%d: CMD_RESP (83.392183): 802_11_RF_ANTENNA [0x8020], result 0, len 16, seqno 0x19
[ 83.411802] PS Command: action = 0x0, bitmap = 0x0
[ 83.411833] wlan%d: QUEUE_CMD: 802_11_PS_MODE_ENH [0xe4] is queued
[ 83.411914] wlan%d: DNLD_CMD (83.392643): 802_11_PS_MODE_ENH [0xe4], act 0x0, len 12, seqno 0x1a timeout 5000
[ 83.412367] wlan%d: CMD_RESP (83.393090): 802_11_PS_MODE_ENH [0x80e4], result 0, len 68, seqno 0x1a
[ 83.412416] ps_bitmap=0x0
[ 83.412535] CFG80211: Country=00, band=0, no_of_sub_band=1
[ 83.412577] wlan%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 83.412633] 11D:Country=WW band=0 sub-band=1 dfs_region=0
[ 83.412650] 11D: first chan=1 no_of_chan=14, max_tx_pwr=20
[ 83.412665] wlan%d: QUEUE_CMD: 802_11D_DOMAIN_INFO [0x5b] is queued
[ 83.412694] wlan_set_regiontable: 2.4G 0x0
[ 83.412718] wlan_set_regiontable: 5G 0x0
[ 83.412794] wlan%d: DNLD_CMD (83.393523): 802_11_SNMP_MIB [0x16], act 0x1, len 16, seqno 0x1b timeout 5000
[ 83.413234] wlan%d: CMD_RESP (83.393957): 802_11_SNMP_MIB [0x8016], result 0, len 16, seqno 0x1b
[ 83.413292] wlan%d: DNLD_CMD (83.394022): 802_11D_DOMAIN_INFO [0x5b], act 0x1, len 32, seqno 0x1c timeout 5000
[ 83.413739] wlan%d: 83.394463 : Event: VDLL_IND [0x81]
[ 83.413802] VDLL_IND: type=0 ID=23 offset = 0xe808 len = 600
[ 83.413827] wlan%d: DNLD_VDLL : block_len=600
[ 83.431747] wlan%d: 83.412467 : Event: VDLL_IND [0x81]
[ 83.431826] VDLL_IND: type=0 ID=23 offset = 0xea60 len = 600
[ 83.431855] wlan%d: DNLD_VDLL : block_len=600
[ 83.432517] wlan%d: 83.413237 : Event: VDLL_IND [0x81]
[ 83.432590] VDLL_IND: type=0 ID=23 offset = 0xecb8 len = 600
[ 83.432617] wlan%d: DNLD_VDLL : block_len=600
[ 83.433205] wlan%d: 83.413926 : Event: VDLL_IND [0x81]
[ 83.433276] VDLL_IND: type=0 ID=23 offset = 0xef10 len = 600
[ 83.433301] wlan%d: DNLD_VDLL : block_len=600
[ 83.434255] wlan%d: 83.414977 : Event: VDLL_IND [0x81]
[ 83.434325] VDLL_IND: type=0 ID=23 offset = 0xf168 len = 600
[ 83.434348] wlan%d: DNLD_VDLL : block_len=600
[ 83.434915] wlan%d: 83.415636 : Event: VDLL_IND [0x81]
[ 83.434987] VDLL_IND: type=0 ID=23 offset = 0xf3c0 len = 600
[ 83.435010] wlan%d: DNLD_VDLL : block_len=600
[ 83.435581] wlan%d: 83.416302 : Event: VDLL_IND [0x81]
[ 83.435652] VDLL_IND: type=0 ID=23 offset = 0xf618 len = 600
[ 83.435675] wlan%d: DNLD_VDLL : block_len=600
[ 83.436242] wlan%d: 83.416962 : Event: VDLL_IND [0x81]
[ 83.436313] VDLL_IND: type=0 ID=23 offset = 0xf870 len = 600
[ 83.436338] wlan%d: DNLD_VDLL : block_len=600
[ 83.436923] wlan%d: 83.417645 : Event: VDLL_IND [0x81]
[ 83.436995] VDLL_IND: type=0 ID=23 offset = 0xfac8 len = 600
[ 83.437019] wlan%d: DNLD_VDLL : block_len=600
[ 83.451150] wlan%d: 83.431867 : Event: VDLL_IND [0x81]
[ 83.451232] VDLL_IND: type=0 ID=18 offset = 0xc4e0 len = 600
[ 83.451260] wlan%d: DNLD_VDLL : block_len=600
[ 83.469048] wlan%d: 83.449766 : Event: VDLL_IND [0x81]
[ 83.469131] VDLL_IND: type=0 ID=18 offset = 0xc738 len = 600
[ 83.469158] wlan%d: DNLD_VDLL : block_len=600
[ 83.469811] wlan%d: 83.450531 : Event: VDLL_IND [0x81]
[ 83.469883] VDLL_IND: type=0 ID=18 offset = 0xc990 len = 600
[ 83.469909] wlan%d: DNLD_VDLL : block_len=600
[ 83.470486] wlan%d: 83.451207 : Event: VDLL_IND [0x81]
[ 83.470558] VDLL_IND: type=0 ID=18 offset = 0xcbe8 len = 600
[ 83.470584] wlan%d: DNLD_VDLL : block_len=600
[ 83.471148] wlan%d: 83.451869 : Event: VDLL_IND [0x81]
[ 83.471220] VDLL_IND: type=0 ID=18 offset = 0xce40 len = 600
[ 83.471247] wlan%d: DNLD_VDLL : block_len=600
[ 83.471960] wlan%d: CMD_RESP (83.452682): 802_11D_DOMAIN_INFO [0x805b], result 0, len 32, seqno 0x1c
[ 83.472106] CFG80211: Country=00, band=1, no_of_sub_band=25
[ 83.472166] 11D:Country=WW band=1 sub-band=25 dfs_region=0
[ 83.472182] 11D: first chan=36 no_of_chan=1, max_tx_pwr=20
[ 83.472194] 11D: first chan=40 no_of_chan=1, max_tx_pwr=20
[ 83.472205] 11D: first chan=44 no_of_chan=1, max_tx_pwr=20
[ 83.472216] 11D: first chan=48 no_of_chan=1, max_tx_pwr=20
[ 83.472227] 11D: first chan=52 no_of_chan=1, max_tx_pwr=20
[ 83.472239] 11D: first chan=56 no_of_chan=1, max_tx_pwr=20
[ 83.472249] 11D: first chan=60 no_of_chan=1, max_tx_pwr=20
[ 83.472261] 11D: first chan=64 no_of_chan=1, max_tx_pwr=20
[ 83.472272] 11D: first chan=100 no_of_chan=1, max_tx_pwr=20
[ 83.472284] 11D: first chan=104 no_of_chan=1, max_tx_pwr=20
[ 83.472295] 11D: first chan=108 no_of_chan=1, max_tx_pwr=20
[ 83.472307] 11D: first chan=112 no_of_chan=1, max_tx_pwr=20
[ 83.472318] 11D: first chan=116 no_of_chan=1, max_tx_pwr=20
[ 83.472330] 11D: first chan=120 no_of_chan=1, max_tx_pwr=20
[ 83.472341] 11D: first chan=124 no_of_chan=1, max_tx_pwr=20
[ 83.472353] 11D: first chan=128 no_of_chan=1, max_tx_pwr=20
[ 83.472365] 11D: first chan=132 no_of_chan=1, max_tx_pwr=20
[ 83.472376] 11D: first chan=136 no_of_chan=1, max_tx_pwr=20
[ 83.472388] 11D: first chan=140 no_of_chan=1, max_tx_pwr=20
[ 83.472399] 11D: first chan=144 no_of_chan=1, max_tx_pwr=20
[ 83.472411] 11D: first chan=149 no_of_chan=1, max_tx_pwr=20
[ 83.472422] 11D: first chan=153 no_of_chan=1, max_tx_pwr=20
[ 83.472434] 11D: first chan=157 no_of_chan=1, max_tx_pwr=20
[ 83.472446] 11D: first chan=161 no_of_chan=1, max_tx_pwr=20
[ 83.472457] 11D: first chan=165 no_of_chan=1, max_tx_pwr=20
[ 83.472475] wlan%d: QUEUE_CMD: 802_11D_DOMAIN_INFO [0x5b] is queued
[ 83.472507] wlan_set_regiontable: 2.4G 0x0
[ 83.472526] wlan_set_regiontable: 5G 0x0
[ 83.472603] wlan%d: DNLD_CMD (83.453331): 802_11D_DOMAIN_INFO [0x5b], act 0x1, len 104, seqno 0x1d timeout 5000
[ 83.494139] wlan%d: CMD_RESP (83.474857): 802_11D_DOMAIN_INFO [0x805b], result 0, len 104, seqno 0x1d
[ 83.494780] Set wlan%d interface addr: 30:XX:XX:XX:8c:11
[ 83.494841] wlan%d: QUEUE_CMD: 802_11_MAC_ADDRESS [0x4d] is queued
[ 83.494928] wlan%d: DNLD_CMD (83.475657): 802_11_MAC_ADDRESS [0x4d], act 0x1, len 16, seqno 0x1e timeout 5000
[ 83.495415] wlan%d: CMD_RESP (83.476138): 802_11_MAC_ADDRESS [0x804d], result 0, len 16, seqno 0x1e
[ 83.497089] Register NXP 802.11 Adapter wlan0
[ 83.497471] uap%d: QUEUE_CMD: 11AX_CFG [0x266] is queued
[ 83.497582] wlan0 set multicast_list
[ 83.497622] wlan0: QUEUE_CMD: MAC_MULTICAST_ADR [0x10] is queued
[ 83.497654] wlan0: QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 83.509486] uap%d: DNLD_CMD (83.490204): 11AX_CFG [0x266], act 0x1, len 39, seqno 0x101f timeout 5000
[ 83.510032] wlan0: 83.490754 : Event: VDLL_IND [0x81]
[ 83.510109] VDLL_IND: type=0 ID=24 offset = 0xfd20 len = 600
[ 83.510135] wlan0: DNLD_VDLL : block_len=600
[ 83.528293] wlan0: 83.509009 : Event: VDLL_IND [0x81]
[ 83.528377] VDLL_IND: type=0 ID=24 offset = 0xff78 len = 600
[ 83.528405] wlan0: DNLD_VDLL : block_len=600
[ 83.529075] wlan0: 83.509795 : Event: VDLL_IND [0x81]
[ 83.529151] VDLL_IND: type=0 ID=24 offset = 0x101d0 len = 600
[ 83.529176] wlan0: DNLD_VDLL : block_len=600
[ 83.529781] wlan0: 83.510504 : Event: VDLL_IND [0x81]
[ 83.529849] VDLL_IND: type=0 ID=24 offset = 0x10428 len = 600
[ 83.529871] wlan0: DNLD_VDLL : block_len=600
[ 83.530444] wlan0: 83.511164 : Event: VDLL_IND [0x81]
[ 83.530517] VDLL_IND: type=0 ID=24 offset = 0x10680 len = 600
[ 83.530541] wlan0: DNLD_VDLL : block_len=600
[ 83.531107] wlan0: 83.511826 : Event: VDLL_IND [0x81]
[ 83.531178] VDLL_IND: type=0 ID=24 offset = 0x108d8 len = 600
[ 83.531202] wlan0: DNLD_VDLL : block_len=600
[ 83.531884] uap%d: CMD_RESP (83.512604): 11AX_CFG [0x8266], result 0, len 39, seqno 0x101f
[ 83.531948] user_2g_hecap_len=28
[ 83.531997] wlan0: DNLD_CMD (83.512726): MAC_MULTICAST_ADR [0x10], act 0x1, len 204, seqno 0x20 timeout 5000
[ 83.532430] wlan0: CMD_RESP (83.513154): MAC_MULTICAST_ADR [0x8010], result 0, len 204, seqno 0x20
[ 83.532484] wlan0: DNLD_CMD (83.513216): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0x21 timeout 5000
[ 83.532797] wlan0: CMD_RESP (83.513521): MAC_CONTROL [0x8028], result 0, len 12, seqno 0x21
[ 83.532964] uap%d: QUEUE_CMD: 11AX_CFG [0x266] is queued
[ 83.533051] uap%d: DNLD_CMD (83.513779): 11AX_CFG [0x266], act 0x1, len 39, seqno 0x1022 timeout 5000
[ 83.533496] uap%d: CMD_RESP (83.514218): 11AX_CFG [0x8266], result 0, len 39, seqno 0x1022
[ 83.533548] user_hecap_len=28
[ 83.539872] Set uap%d interface addr: 32:XX:XX:XX:8d:11
[ 83.539937] uap%d: QUEUE_CMD: APCMD_SYS_CONFIGURE [0xb0] is queued
[ 83.540028] uap%d: DNLD_CMD (83.520757): APCMD_SYS_CONFIGURE [0xb0], act 0x1, len 20, seqno 0x1023 timeout 5000
[ 83.540517] uap%d: CMD_RESP (83.521240): APCMD_SYS_CONFIGURE [0x80b0], result 0, len 20, seqno 0x1023
[ 83.542165] Register NXP 802.11 Adapter uap0
[ 83.542494] PS Command: action = 0x0, bitmap = 0x0
[ 83.542521] p2p%d: QUEUE_CMD: 802_11_PS_MODE_ENH [0xe4] is queued
[ 83.542607] uap0 set multicast_list
[ 83.543135] p2p%d: DNLD_CMD (83.523858): 802_11_PS_MODE_ENH [0xe4], act 0x0, len 12, seqno 0x2024 timeout 5000
[ 83.543643] p2p%d: CMD_RESP (83.524364): 802_11_PS_MODE_ENH [0x80e4], result 0, len 68, seqno 0x2024
[ 83.543693] ps_bitmap=0x0
[ 83.543799] CFG80211: Country=00, band=0, no_of_sub_band=1
[ 83.543841] p2p%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 83.543895] 11D:Country=WW band=0 sub-band=1 dfs_region=0
[ 83.543910] 11D: first chan=1 no_of_chan=14, max_tx_pwr=20
[ 83.543925] p2p%d: QUEUE_CMD: 802_11D_DOMAIN_INFO [0x5b] is queued
[ 83.543954] wlan_set_regiontable: 2.4G 0x0
[ 83.543973] wlan_set_regiontable: 5G 0x0
[ 83.544059] p2p%d: DNLD_CMD (83.524786): 802_11_SNMP_MIB [0x16], act 0x1, len 16, seqno 0x2025 timeout 5000
[ 83.544517] p2p%d: CMD_RESP (83.525239): 802_11_SNMP_MIB [0x8016], result 0, len 16, seqno 0x2025
[ 83.544580] p2p%d: DNLD_CMD (83.525310): 802_11D_DOMAIN_INFO [0x5b], act 0x1, len 32, seqno 0x2026 timeout 5000
[ 83.566231] p2p%d: CMD_RESP (83.546947): 802_11D_DOMAIN_INFO [0x805b], result 0, len 32, seqno 0x2026
[ 83.566411] CFG80211: Country=00, band=1, no_of_sub_band=25
[ 83.566474] 11D:Country=WW band=1 sub-band=25 dfs_region=0
[ 83.566489] 11D: first chan=36 no_of_chan=1, max_tx_pwr=20
[ 83.566501] 11D: first chan=40 no_of_chan=1, max_tx_pwr=20
[ 83.566513] 11D: first chan=44 no_of_chan=1, max_tx_pwr=20
[ 83.566524] 11D: first chan=48 no_of_chan=1, max_tx_pwr=20
[ 83.566535] 11D: first chan=52 no_of_chan=1, max_tx_pwr=20
[ 83.566546] 11D: first chan=56 no_of_chan=1, max_tx_pwr=20
[ 83.566557] 11D: first chan=60 no_of_chan=1, max_tx_pwr=20
[ 83.566569] 11D: first chan=64 no_of_chan=1, max_tx_pwr=20
[ 83.566580] 11D: first chan=100 no_of_chan=1, max_tx_pwr=20
[ 83.566592] 11D: first chan=104 no_of_chan=1, max_tx_pwr=20
[ 83.566604] 11D: first chan=108 no_of_chan=1, max_tx_pwr=20
[ 83.566615] 11D: first chan=112 no_of_chan=1, max_tx_pwr=20
[ 83.566627] 11D: first chan=116 no_of_chan=1, max_tx_pwr=20
[ 83.566638] 11D: first chan=120 no_of_chan=1, max_tx_pwr=20
[ 83.566650] 11D: first chan=124 no_of_chan=1, max_tx_pwr=20
[ 83.566661] 11D: first chan=128 no_of_chan=1, max_tx_pwr=20
[ 83.566673] 11D: first chan=132 no_of_chan=1, max_tx_pwr=20
[ 83.566685] 11D: first chan=136 no_of_chan=1, max_tx_pwr=20
[ 83.566696] 11D: first chan=140 no_of_chan=1, max_tx_pwr=20
[ 83.566708] 11D: first chan=144 no_of_chan=1, max_tx_pwr=20
[ 83.566720] 11D: first chan=149 no_of_chan=1, max_tx_pwr=20
[ 83.566731] 11D: first chan=153 no_of_chan=1, max_tx_pwr=20
[ 83.566743] 11D: first chan=157 no_of_chan=1, max_tx_pwr=20
[ 83.566755] 11D: first chan=161 no_of_chan=1, max_tx_pwr=20
[ 83.566767] 11D: first chan=165 no_of_chan=1, max_tx_pwr=20
[ 83.566784] p2p%d: QUEUE_CMD: 802_11D_DOMAIN_INFO [0x5b] is queued
[ 83.566815] wlan_set_regiontable: 2.4G 0x0
[ 83.566835] wlan_set_regiontable: 5G 0x0
[ 83.566911] p2p%d: DNLD_CMD (83.547640): 802_11D_DOMAIN_INFO [0x5b], act 0x1, len 104, seqno 0x2027 timeout 5000
[ 83.588510] p2p%d: CMD_RESP (83.569226): 802_11D_DOMAIN_INFO [0x805b], result 0, len 104, seqno 0x2027
[ 83.598432] Set WFD device addr: 32:XX:XX:XX:8c:11
[ 83.598498] p2p%d: QUEUE_CMD: 802_11_MAC_ADDRESS [0x4d] is queued
[ 83.598592] p2p%d: DNLD_CMD (83.579322): 802_11_MAC_ADDRESS [0x4d], act 0x1, len 16, seqno 0x2028 timeout 5000
[ 83.599075] p2p%d: CMD_RESP (83.579798): 802_11_MAC_ADDRESS [0x804d], result 0, len 16, seqno 0x2028
[ 83.600896] Register NXP 802.11 Adapter p2p0
[ 83.601044] wlan: version = SDIW612---18.99.3.p26.11-MM6X18540.p17-(FP92)
[ 83.601125] wlan0: QUEUE_CMD: REG_ACCESS [0x27c] is queued
[ 83.601706] p2p0 set multicast_list
[ 83.601758] p2p0: QUEUE_CMD: MAC_MULTICAST_ADR [0x10] is queued
[ 83.601798] p2p0: QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 83.601862] wlan0: DNLD_CMD (83.582592): REG_ACCESS [0x27c], act 0x0, len 20, seqno 0x29 timeout 5000
[ 83.602352] wlan0: CMD_RESP (83.583074): REG_ACCESS [0x827c], result 0, len 20, seqno 0x29
[ 83.602435] p2p0: DNLD_CMD (83.583164): MAC_MULTICAST_ADR [0x10], act 0x1, len 204, seqno 0x202a timeout 5000
[ 83.602875] p2p0: CMD_RESP (83.583599): MAC_MULTICAST_ADR [0x8010], result 0, len 204, seqno 0x202a
[ 83.602933] p2p0: DNLD_CMD (83.583663): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0x202b timeout 5000
[ 83.603253] p2p0: CMD_RESP (83.583977): MAC_CONTROL [0x8028], result 0, len 12, seqno 0x202b
[ 83.649540] Set REG 0x90002328: 0x13d57 slew_rate=3
[ 83.649608] wlan0: QUEUE_CMD: REG_ACCESS [0x27c] is queued
[ 83.649704] wlan0: DNLD_CMD (83.630433): REG_ACCESS [0x27c], act 0x1, len 20, seqno 0x2c timeout 5000
[ 83.650198] wlan0: CMD_RESP (83.630922): REG_ACCESS [0x827c], result 0, len 20, seqno 0x2c
[ 83.650381] wlan0: QUEUE_CMD: INDEPENDENT_RESET_CFG [0x243] is queued
[ 83.650456] wlan0: DNLD_CMD (83.631187): INDEPENDENT_RESET_CFG [0x243], act 0x0, len 12, seqno 0x2d timeout 5000
[ 83.650885] wlan0: CMD_RESP (83.631608): INDEPENDENT_RESET_CFG [0x8243], result 0, len 12, seqno 0x2d
[ 83.651544] wlan: Register to Bus Driver Done
[ 83.651568] wlan: Driver loaded successfully
[ 91.250327] wlan0: QUEUE_CMD: TXPWR_CFG [0xd1] is queued
[ 91.250455] wlan0: DNLD_CMD (91.231183): TXPWR_CFG [0xd1], act 0x0, len 16, seqno 0x2e timeout 5000
[ 91.250979] wlan0: CMD_RESP (91.231700): TXPWR_CFG [0x80d1], result 0, len 140, seqno 0x2e
[ 91.251505] wlan0: QUEUE_CMD: TXPWR_CFG [0xd1] is queued
[ 91.251610] wlan0: DNLD_CMD (91.232338): TXPWR_CFG [0xd1], act 0x0, len 16, seqno 0x2f timeout 5000
[ 91.252073] wlan0: CMD_RESP (91.232795): TXPWR_CFG [0x80d1], result 0, len 140, seqno 0x2f
[ 91.256518] wlan0: QUEUE_CMD: 802_11_RF_ANTENNA [0x20] is queued
[ 91.256644] wlan0: DNLD_CMD (91.237371): 802_11_RF_ANTENNA [0x20], act 0xc, len 16, seqno 0x30 timeout 5000
[ 91.257138] wlan0: CMD_RESP (91.237860): 802_11_RF_ANTENNA [0x8020], result 0, len 16, seqno 0x30
[ 91.262751] wlan0: QUEUE_CMD: TXPWR_CFG [0xd1] is queued
[ 91.262879] wlan0: DNLD_CMD (91.243606): TXPWR_CFG [0xd1], act 0x0, len 16, seqno 0x31 timeout 5000
[ 91.263360] wlan0: CMD_RESP (91.244082): TXPWR_CFG [0x80d1], result 0, len 140, seqno 0x31
[ 91.263875] wlan0: QUEUE_CMD: TXPWR_CFG [0xd1] is queued
[ 91.263981] wlan0: DNLD_CMD (91.244710): TXPWR_CFG [0xd1], act 0x0, len 16, seqno 0x32 timeout 5000
[ 91.264440] wlan0: CMD_RESP (91.245161): TXPWR_CFG [0x80d1], result 0, len 140, seqno 0x32
[ 91.273598] wlan0: QUEUE_CMD: RX_MGMT_IND [0x10c] is queued
[ 91.273755] wlan0: DNLD_CMD (91.254481): RX_MGMT_IND [0x10c], act 0x1, len 14, seqno 0x33 timeout 5000
[ 91.274249] wlan0: CMD_RESP (91.254971): RX_MGMT_IND [0x810c], result 0, len 14, seqno 0x33
[ 91.285501] wlan0: QUEUE_CMD: TXPWR_CFG [0xd1] is queued
[ 91.285628] wlan0: DNLD_CMD (91.266356): TXPWR_CFG [0xd1], act 0x0, len 16, seqno 0x34 timeout 5000
[ 91.286112] wlan0: CMD_RESP (91.266833): TXPWR_CFG [0x80d1], result 0, len 140, seqno 0x34
[ 91.286736] wlan0 set multicast_list
[ 91.286794] wlan0: QUEUE_CMD: MAC_MULTICAST_ADR [0x10] is queued
[ 91.286835] wlan0: QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 91.286916] wlan0: DNLD_CMD (91.267643): MAC_MULTICAST_ADR [0x10], act 0x1, len 204, seqno 0x35 timeout 5000
[ 91.287407] wlan0: CMD_RESP (91.268128): MAC_MULTICAST_ADR [0x8010], result 0, len 204, seqno 0x35
[ 91.287469] wlan0: DNLD_CMD (91.268199): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0x36 timeout 5000
[ 91.287894] wlan0: CMD_RESP (91.268617): MAC_CONTROL [0x8028], result 0, len 12, seqno 0x36
[ 91.297629] wlan0: QUEUE_CMD: 802_11_RF_ANTENNA [0x20] is queued
[ 91.297755] wlan0: DNLD_CMD (91.278484): 802_11_RF_ANTENNA [0x20], act 0xc, len 16, seqno 0x37 timeout 5000
[ 91.298244] wlan0: CMD_RESP (91.278966): 802_11_RF_ANTENNA [0x8020], result 0, len 16, seqno 0x37
[ 112.909482] wlan0: QUEUE_CMD: MGMT_IE_LIST [0xf2] is queued
[ 112.909610] wlan0: DNLD_CMD (112.890335): MGMT_IE_LIST [0xf2], act 0x1, len 127, seqno 0x38 timeout 5000
[ 112.910138] wlan0: CMD_RESP (112.890857): MGMT_IE_LIST [0x80f2], result 0, len 127, seqno 0x38
[ 112.910277] probereq ie length = 107
[ 112.910302] beacon=ffff assocresp=ffff proberesp=ffff probereq=0
[ 112.910324] wlan:random_mac 00:XX:XX:XX:00:00
[ 112.910848] max_rate=390M
[ 112.910869] max_rate=390M
[ 112.910887] Set: HE rx mcs set 0x0000fffe tx mcs set 0x0000fffe
[ 112.910946] max_rate=390M
[ 112.910957] max_rate=390M
[ 112.910972] Set: HE rx mcs set 0x0000fffe tx mcs set 0x0000fffe
[ 112.911000] wlan0: QUEUE_CMD: 802_11_SCAN_EXT [0x107] is queued
[ 112.911052] wlan: wlan0 START SCAN
[ 112.911216] wlan0: DNLD_CMD (112.891939): 802_11_SCAN_EXT [0x107], act 0x1, len 266, seqno 0x39 timeout 20000
[ 112.921346] wlan0: CMD_RESP (112.902062): 802_11_SCAN_EXT [0x8107], result 0, len 12, seqno 0x39
[ 132.979298] Ext scan enh timeout
[ 132.979336] ------------Dump info-----------
[ 132.979347] EXT_SCAN_STATUS event Timeout
[ 132.979360] CurCmd Empty
[ 132.979372] mlan_processing =0
[ 132.979382] main_lock_flag =0
[ 132.979392] main_process_cnt =125
[ 132.979401] delay_task_flag =0
[ 132.979410] mlan_rx_processing =0
[ 132.979419] rx_pkts_queued=0
[ 132.979428] more_task_flag = 0
[ 132.979437] num_cmd_timeout = 0
[ 132.979446] last_cmd_index = 7
[ 132.979455] last_cmd_id = 0xd1 0x10c 0xd1 0x10 0x28 0x20 0xf2 0x107 0x20 0xd1
[ 132.979499] last_cmd_act = 0x0 0x1 0x0 0x1 0x213 0xc 0x1 0x1 0xc 0x0
[ 132.979535] last_cmd_resp_index = 7
[ 132.979544] last_cmd_resp_id = 0x80d1 0x810c 0x80d1 0x8010 0x8028 0x8020 0x80f2 0x8107 0x8020 0x80d1
[ 132.979583] last_event_index = 1
[ 132.979592] last_event = 0x81 0x81 0x81 0x81 0x81 0x81 0x81 0x81 0x81 0x81
[ 132.979630] num_data_h2c_failure = 0
[ 132.979642] num_cmd_h2c_failure = 0
[ 132.979653] num_data_c2h_failure = 0
[ 132.979663] num_cmdevt_c2h_failure = 0
[ 132.979673] num_int_read_failure = 0
[ 132.979683] last_int_status = 64
[ 132.979692] num_alloc_buffer_failure = 0
[ 132.979701] num_pkt_dropped = 0
[ 132.979710] num_no_cmd_node = 0
[ 132.979719] num_event_deauth = 0
[ 132.979728] num_event_disassoc = 0
[ 132.979737] num_event_link_lost = 0
[ 132.979746] num_cmd_deauth = 0
[ 132.979756] num_cmd_assoc_success = 0
[ 132.979766] num_cmd_assoc_failure = 0
[ 132.979776] num_cons_assoc_failure = 0
[ 132.979785] cmd_resp_received=0
[ 132.979794] event_received=0
[ 132.979804] max_tx_buf_size=4096
[ 132.979813] tx_buf_size=3328
[ 132.979822] curr_tx_buf_size=3328
[ 132.979832] data_sent=0 cmd_sent=0
[ 132.979843] ps_mode=0 ps_state=0
[ 132.979855] wakeup_dev_req=0 wakeup_tries=0 wakeup_timeout=0
[ 132.979866] hs_configured=0 hs_activated=0
[ 132.979877] pps_uapsd_mode=0 sleep_pd=0
[ 132.979886] tx_lock_flag = 0
[ 132.979896] scan_processing = 1
[ 132.979906] scan_state = 0x5
[ 132.979915] bypass_pkt_count=0
[ 132.979927] mp_rd_bitmap=0x0 curr_rd_port=0x0
[ 132.979939] mp_wr_bitmap=0xffffffff curr_wr_port=0x0
[ 132.979949] mp_data_port_mask = 0xffffffff
[ 132.979960] last_recv_rd_bitmap=0x0 mp_invalid_update=0
[ 132.979972] last_recv_wr_bitmap=0xffffffff last_mp_index=0
[ 132.979986] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 132.979995] 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[ 132.980048] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 132.980058] 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[ 132.980111] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 132.980120] 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[ 132.980172] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 132.980182] 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[ 132.980234] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 132.980244] 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[ 132.980297] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 132.980306] 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[ 132.980359] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 132.980368] 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[ 132.980420] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 132.980430] 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[ 132.980482] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 132.980491] 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[ 132.980542] mp_wr_bitmap: 0x0 mp_wr_ports=0x0 len=0 curr_wr_port=0x0
[ 132.980552] 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[ 132.980604] bss_index = 0, tx_pkts_queued = 0 tx_pause
[ 132.980619] bss_index = 1, tx_pkts_queued = 0 tx_pause
[ 132.980631] bss_index = 2, tx_pkts_queued = 0 tx_pause
[ 132.980647] bss_index = 3, tx_pkts_queued = 0 tx_pause
[ 132.980663] event id:0x80000012
[ 132.980702] Host:br03 Timestamp:c0623ac4
[ 132.980730] Driver version = SDIW612---18.99.3.p26.11-MM6X18540.p17-(FP92)
[ 132.980743] main_state = 4
[ 132.980753] ioctl_pending = 1
[ 132.980762] tx_pending = 0
[ 132.980772] wmm_tx_pending[0] = 0
[ 132.980781] wmm_tx_pending[1] = 0
[ 132.980790] wmm_tx_pending[2] = 0
[ 132.980800] wmm_tx_pending[3] = 0
[ 132.980810] rx_pending = 0
[ 132.980819] lock_count = 111
[ 132.980828] malloc_count = 52
[ 132.980837] mbufalloc_count = 0
[ 132.980846] hs_skip_count = 0
[ 132.980856] hs_force_count = 0
[ 132.980868] Media state = "Disconnected"
[ 132.980881] carrier off
[ 132.980894] tx queue 0: stopped
[ 132.980907] tx queue 1: stopped
[ 132.980920] tx queue 2: stopped
[ 132.980933] tx queue 3: stopped
[ 132.980946] wlan0: num_tx_timeout = 0
[ 132.980960] uap0: num_tx_timeout = 0
[ 132.980973] p2p0: num_tx_timeout = 0
[ 132.981005] -------- Dump info End---------
[ 132.981063] Wakeup device...
[ 132.981682] SDIO Func0 (0x0-0x9): 43 03 02 02 03 02 08 02 03 00
[ 132.982016] SDIO Func1 (0x10-0x17): 00 00 00 00 ff ff ff ff
[ 132.982575] SDIO Func1: (0x8) c3 (0x58) 00 (0x5c) 48 (0x5d) 00 (0x60) 87 (0x61) 0c (0x62) 00 (0x64) 10 (0x65) 00 (0x66) 00 (0x68) 00 (0x69) 00 (0x6a) 00
[ 132.983518] SDIO Func1 (0xe8-0xff): dc fe 60 00 61 00 00 00 24 14 70 c8 ab 77 80 00 00 00 00 00 01 00 00 00
[ 133.087775] SDIO Func1 (0xe8-0xff): dc fe c4 00 6c 00 00 00 24 14 70 c8 ab 77 80 00 00 00 00 00 01 00 00 00
[ 133.087808] Cancel all pending cmd and txrx queue
[ 133.087844] IOCTL failed: c5cf7800 id=0x10000, sub_id=0x10003 action=1, status_code=0x80000007 [CMD_CANCEL]
[ 133.087864] flush scan queue: cmd 0x107
[ 133.087914] Wakeup device...
[ 133.088389] wlan0: 133.069104 : Event: EXT_SCAN_REPORT [0x58]
[ 133.088460] EVENT: EXT_SCAN Report (2416)
[ 133.088757] wlan0: 133.069476 : Event: EXT_SCAN_REPORT [0x58]
[ 133.088814] EVENT: EXT_SCAN Report (463)
[ 133.089067] wlan0: 133.069787 : Event: EXT_SCAN_STATUS_REPORT [0x7f]
[ 133.089121] EVENT: EXT_SCAN status report (151)
[ 133.089143] ext_scan_status: status 0 (scan success), buf_len 144
[ 133.089163] chan=1, noise=-89, total_network=1 scan_duration=78, busy_duration=37
[ 133.089181] chan=2, noise=-90, total_network=0 scan_duration=78, busy_duration=32
[ 133.089198] chan=3, noise=-90, total_network=1 scan_duration=78, busy_duration=23
[ 133.089213] chan=4, noise=-81, total_network=0 scan_duration=78, busy_duration=12
[ 133.089229] chan=5, noise=-84, total_network=1 scan_duration=78, busy_duration=30
[ 133.089246] chan=6, noise=-84, total_network=2 scan_duration=78, busy_duration=52
[ 133.089261] chan=7, noise=-87, total_network=0 scan_duration=78, busy_duration=17
[ 133.089358] chan=8, noise=-87, total_network=0 scan_duration=78, busy_duration=12
[ 133.089375] chan=9, noise=-89, total_network=1 scan_duration=78, busy_duration=27
[ 133.089392] chan=10, noise=-89, total_network=0 scan_duration=78, busy_duration=27
[ 133.089409] chan=11, noise=-89, total_network=1 scan_duration=78, busy_duration=41
[ 133.089425] chan=12, noise=-87, total_network=1 scan_duration=78, busy_duration=32
[ 133.089440] chan=13, noise=-88, total_network=1 scan_duration=78, busy_duration=32
[ 133.089456] chan=14, noise=-91, total_network=0 scan_duration=78, busy_duration=8
[ 133.089479] chan=1, min_rssi=0, max_rssi=0 noise=-89 min_rss=89, max_rss=89
[ 133.089496] chan=2, min_rssi=0, max_rssi=0 noise=-90 min_rss=90, max_rss=90
[ 133.089511] chan=3, min_rssi=0, max_rssi=0 noise=-90 min_rss=90, max_rss=90
[ 133.089526] chan=4, min_rssi=0, max_rssi=0 noise=-81 min_rss=81, max_rss=81
[ 133.089542] chan=5, min_rssi=0, max_rssi=0 noise=-84 min_rss=84, max_rss=84
[ 133.089558] chan=6, min_rssi=0, max_rssi=0 noise=-84 min_rss=84, max_rss=84
[ 133.089574] chan=7, min_rssi=0, max_rssi=0 noise=-87 min_rss=87, max_rss=87
[ 133.089589] chan=8, min_rssi=0, max_rssi=0 noise=-87 min_rss=87, max_rss=87
[ 133.089605] chan=9, min_rssi=0, max_rssi=0 noise=-89 min_rss=89, max_rss=89
[ 133.089620] chan=10, min_rssi=0, max_rssi=0 noise=-89 min_rss=89, max_rss=89
[ 133.089636] chan=11, min_rssi=0, max_rssi=0 noise=-89 min_rss=89, max_rss=89
[ 133.089652] chan=12, min_rssi=0, max_rssi=0 noise=-87 min_rss=87, max_rss=87
[ 133.089668] chan=13, min_rssi=0, max_rssi=0 noise=-88 min_rss=88, max_rss=88
[ 133.089683] chan=14, min_rssi=0, max_rssi=0 noise=-91 min_rss=91, max_rss=91
[ 133.089702] wlan: SCAN COMPLETED: scanned AP count=0
[ 133.089721] event id:0x80000009
[ 133.089748] IOCTL is not allowed while the device is not present or hang
[ 133.089767] IOCTL is not allowed while the device is not present or hang
[ 133.093278] IOCTL is not allowed while the device is not present or hang
[ 133.099459] ====SDIO FW DUMP EVENT MODE START ====
[ 133.099802] FW trigger fw dump
[ 133.099845] ==== Start Receive FW dump event ====
[ 133.099942] Create directory /data/dump_133 error, try create dir in /var
[ 133.100015] Create directory /var/dump_133 successfully
[ 133.100036] Firmware Dump directory name is /var/dump_133
[ 133.100048] === START DRIVER INFO DUMP===
[ 133.100161] DRV dump data in /var/dump_133/file_drv_info
[ 133.100594] Wakeup device...
[ 133.231641] Drv info total bytes = 421143 (0x66d17)
[ 133.231676] === DRIVER INFO DUMP END===
[ 134.887580] ==== FW DUMP END: 1408768 bytes ====
[ 134.887652] wlan: Notify FW dump complete event
[ 134.887668] vendor event :0x1
[ 134.887750] Start to process hanging
[ 134.888400] IOCTL is not allowed while the device is not present or hang
[ 134.888744] Cancel all pending cmd and txrx queue
[ 134.888883] vendor event :0x4
[ 134.888939] WIFI auto_fw_reload: fw_reload=1
[ 134.888995] ========START IN-BAND RESET===========
[ 134.889037] vendor event :0x2
[ 134.889227] IOCTL is not allowed while the device is not present or hang
[ 134.889259] woal_reset_intf: get bss info failed
[ 134.889375] Cancel all pending cmd and txrx queue
[ 134.889499] IOCTL is not allowed while the device is not present or hang
[ 134.889793] IOCTL is not allowed while the device is not present or hang
[ 135.068048] FW wake up
[ 135.082732] SDIO Trigger FW In-band Reset success
[ 135.082764] Free module params
[ 135.082815] No module param cfg file specified
[ 135.082867] SDIO: sdio_blk_size=256 max_blk_count=512 max_segs=64 max_seg_size=4096
[ 135.082883] rx_work=0 cpu_num=1
[ 135.082903] Enable moal_recv_amsdu_packet
[ 135.082990] Attach mlan adapter operations.card_type is 0x109.
[ 135.091840] wlan: Enable TX SG mode
[ 135.091876] wlan: mpa_tx.buf_size=4096
[ 135.091888] wlan: Enable RX SG mode
[ 135.091899] wlan: mpa_rx.buf_size=4096
[ 135.091945] Request firmware: nxp/sd_w61x_v1.bin.se
[ 135.097580] Wakeup device...
[ 135.361419] Wlan: FW download over, firmwarelen=681308 downloaded 565508
[ 135.779436] WLAN FW is active
[ 135.779479] on_time is 135760213003
[ 135.779928] QUEUE_CMD: FUNC_INIT [0xa9] is queued
[ 135.779961] QUEUE_CMD: GET_HW_SPEC [0x3] is queued
[ 135.780007] DNLD_CMD (135.760717): FUNC_INIT [0xa9], act 0x263, len 16, seqno 0x1 timeout 5000
[ 135.802877] CMD_RESP (135.783563): FUNC_INIT [0x80a9], result 0, len 16, seqno 0x1
[ 135.802941] DNLD_CMD (135.783651): GET_HW_SPEC [0x3], act 0x0, len 71, seqno 0x2 timeout 5000
[ 135.803276] 135.783976 : Event: VDLL_IND [0x81]
[ 135.803320] VDLL_IND (OFFSET): offset=0x1c458
[ 135.804257] VDLL image: len=115800
[ 135.804558] CMD_RESP (135.785256): GET_HW_SPEC [0x8003], result 0, len 205, seqno 0x2
[ 135.804586] fw_cap_info=0x487cff03, dev_cap_mask=0xffffffff
[ 135.804603] GET_HW_SPEC: country_code=0x0
[ 135.804615] num_ant=1, antinfo=0x0
[ 135.804631] GET_HW_SPEC: hw_mpdu_density=4 dev_mcs_support=0x11
[ 135.804641] Enable Beamforming
[ 135.804656] GET_HW_SPEC: mgmt IE count=13
[ 135.804672] FW: SDIO rx aggr disabled 0x487cff03
[ 135.804687] pmadapter->ecsa_enable=1
[ 135.804722] QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 135.804735] pmadapter->getlog_enable=1
[ 135.804758] chanrpt api ver=14.1
[ 135.804772] fw_cap_info=0x487cff03 fw_cap_ext=0x2182b5
[ 135.804786] uuid: c10d697cf87d596cab35c831392df315
[ 135.804798] fw hotfix ver=11
[ 135.804810] fw ver=15.1
[ 135.804820] uap fw ver=2.0
[ 135.804832] max_p2p_conn = 8, max_sta_conn = 16
[ 135.804849] wlan_set_regiontable: 2.4G 0x10
[ 135.804868] wlan_set_regiontable: 5G 0x10
[ 135.804904] Get Hw Spec done, fw_cap=0x487cff03
[ 135.804931] org_drv_mode=0x7 drv_mode=0x7
[ 135.805473] Enable Beamforming
[ 135.805531] QUEUE_CMD: 802_11_FW_WAKE_METHOD [0x74] is queued
[ 135.805558] set tx_buf = 4096
[ 135.805578] QUEUE_CMD: RECONFIGURE_TX_BUFF [0xd9] is queued
[ 135.805603] PS Command: action = 0x6, bitmap = 0x1
[ 135.805623] QUEUE_CMD: 802_11_PS_MODE_ENH [0xe4] is queued
[ 135.805653] QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 135.805684] QUEUE_CMD: 802_11_RF_ANTENNA [0x20] is queued
[ 135.805715] QUEUE_CMD: CHAN_REGION_CFG [0x242] is queued
[ 135.805747] QUEUE_CMD: TX_RATE_CFG [0xd6] is queued
[ 135.805775] QUEUE_CMD: 802_11_RF_TX_POWER [0x1e] is queued
[ 135.805803] QUEUE_CMD: AMSDU_AGGR_CTRL [0xdf] is queued
[ 135.805831] QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 135.805873] DNLD_CMD (135.786585): 802_11_SNMP_MIB [0x16], act 0x1, len 15, seqno 0x3 timeout 5000
[ 135.806273] CMD_RESP (135.786970): 802_11_SNMP_MIB [0x8016], result 0, len 15, seqno 0x3
[ 135.806326] DNLD_CMD (135.787037): 802_11_FW_WAKE_METHOD [0x74], act 0x0, len 12, seqno 0x4 timeout 5000
[ 135.806657] CMD_RESP (135.787354): 802_11_FW_WAKE_METHOD [0x8074], result 0, len 18, seqno 0x4
[ 135.806681] FW wakeup method=1, gpio=0
[ 135.806720] DNLD_CMD (135.787431): RECONFIGURE_TX_BUFF [0xd9], act 0x1, len 16, seqno 0x5 timeout 5000
[ 135.807784] CMD_RESP (135.788482): RECONFIGURE_TX_BUFF [0x80d9], result 0, len 16, seqno 0x5
[ 135.807813] end port 32, data port mask ffffffff
[ 135.807828] max_tx_buf_size=4096, tx_buf_size=3328
[ 135.807867] DNLD_CMD (135.788578): 802_11_PS_MODE_ENH [0xe4], act 0x6, len 20, seqno 0x6 timeout 5000
[ 135.808197] CMD_RESP (135.788896): 802_11_PS_MODE_ENH [0x80e4], result 0, len 20, seqno 0x6
[ 135.808246] DNLD_CMD (135.788958): 802_11_SNMP_MIB [0x16], act 0x1, len 18, seqno 0x7 timeout 5000
[ 135.808578] CMD_RESP (135.789278): 802_11_SNMP_MIB [0x8016], result 0, len 18, seqno 0x7
[ 135.808627] DNLD_CMD (135.789339): 802_11_RF_ANTENNA [0x20], act 0xc, len 16, seqno 0x8 timeout 5000
[ 135.808952] CMD_RESP (135.789651): 802_11_RF_ANTENNA [0x8020], result 0, len 16, seqno 0x8
[ 135.809004] DNLD_CMD (135.789713): CHAN_REGION_CFG [0x242], act 0x0, len 11, seqno 0x9 timeout 5000
[ 135.810351] CMD_RESP (135.791038): CHAN_REGION_CFG [0x8242], result 0, len 1297, seqno 0x9
[ 135.810455] DNLD_CMD (135.791160): TX_RATE_CFG [0xd6], act 0x0, len 76, seqno 0xa timeout 5000
[ 135.811124] CMD_RESP (135.791819): TX_RATE_CFG [0x80d6], result 0, len 832, seqno 0xa
[ 135.811184] DNLD_CMD (135.791892): 802_11_RF_TX_POWER [0x1e], act 0x0, len 14, seqno 0xb timeout 5000
[ 135.811540] CMD_RESP (135.792237): 802_11_RF_TX_POWER [0x801e], result 0, len 14, seqno 0xb
[ 135.811591] DNLD_CMD (135.792300): AMSDU_AGGR_CTRL [0xdf], act 0x1, len 14, seqno 0xc timeout 5000
[ 135.811920] CMD_RESP (135.792619): AMSDU_AGGR_CTRL [0x80df], result 0, len 14, seqno 0xc
[ 135.811966] DNLD_CMD (135.792678): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0xd timeout 5000
[ 135.812382] CMD_RESP (135.793082): MAC_CONTROL [0x8028], result 0, len 12, seqno 0xd
[ 135.812434] QUEUE_CMD: APCMD_SYS_CONFIGURE [0xb0] is queued
[ 135.812472] DNLD_CMD (135.793183): APCMD_SYS_CONFIGURE [0xb0], act 0x0, len 20, seqno 0x100e timeout 5000
[ 135.813545] CMD_RESP (135.794232): APCMD_SYS_CONFIGURE [0x80b0], result 0, len 20, seqno 0x100e
[ 135.813606] QUEUE_CMD: TX_RATE_CFG [0xd6] is queued
[ 135.813637] QUEUE_CMD: 802_11_RF_TX_POWER [0x1e] is queued
[ 135.813666] QUEUE_CMD: AMSDU_AGGR_CTRL [0xdf] is queued
[ 135.813693] QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 135.813720] QUEUE_CMD: 802_11_MAC_ADDRESS [0x4d] is queued
[ 135.813757] DNLD_CMD (135.794468): TX_RATE_CFG [0xd6], act 0x0, len 76, seqno 0x200f timeout 5000
[ 135.818050] CMD_RESP (135.798739): TX_RATE_CFG [0x80d6], result 0, len 832, seqno 0x200f
[ 135.818115] DNLD_CMD (135.798822): 802_11_RF_TX_POWER [0x1e], act 0x0, len 14, seqno 0x2010 timeout 5000
[ 135.818477] CMD_RESP (135.799175): 802_11_RF_TX_POWER [0x801e], result 0, len 14, seqno 0x2010
[ 135.818528] DNLD_CMD (135.799237): AMSDU_AGGR_CTRL [0xdf], act 0x1, len 14, seqno 0x2011 timeout 5000
[ 135.818860] CMD_RESP (135.799557): AMSDU_AGGR_CTRL [0x80df], result 0, len 14, seqno 0x2011
[ 135.818909] DNLD_CMD (135.799620): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0x2012 timeout 5000
[ 135.819230] CMD_RESP (135.799930): MAC_CONTROL [0x8028], result 0, len 12, seqno 0x2012
[ 135.819353] DNLD_CMD (135.800057): 802_11_MAC_ADDRESS [0x4d], act 0x0, len 16, seqno 0x2013 timeout 5000
[ 135.819695] CMD_RESP (135.800394): 802_11_MAC_ADDRESS [0x804d], result 0, len 16, seqno 0x2013
[ 135.819753] QUEUE_CMD: WMM_PARAM_CONFIG [0x23a] is queued
[ 135.819806] DNLD_CMD (135.800516): WMM_PARAM_CONFIG [0x23a], act 0x2, len 26, seqno 0x14 timeout 5000
[ 135.820154] CMD_RESP (135.800851): WMM_PARAM_CONFIG [0x823a], result 0, len 26, seqno 0x14
[ 135.820247] woal_proc_init: proc_wlan is already exist adapter0
[ 135.820490] Set wiphy max_ap_assoc_sta=8
[ 135.820580] max_rate=390M
[ 135.820595] max_rate=390M
[ 135.820613] vht_cap=0x33d07030 rx_mcs_map=0xfffe rx_max=0x186 tx_mcs_map=0xfffe tx_max=0x186
[ 135.820633] max_rate=390M
[ 135.820644] max_rate=390M
[ 135.820660] vht_cap=0x33d07030 rx_mcs_map=0xfffe rx_max=0x186 tx_mcs_map=0xfffe tx_max=0x186
[ 135.820694] wlan%d: QUEUE_CMD: 802_11_RF_ANTENNA [0x20] is queued
[ 135.820792] wlan%d: DNLD_CMD (135.801516): 802_11_RF_ANTENNA [0x20], act 0xc, len 16, seqno 0x15 timeout 5000
[ 135.821252] wlan%d: CMD_RESP (135.801969): 802_11_RF_ANTENNA [0x8020], result 0, len 16, seqno 0x15
[ 135.821410] wlan%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 135.821486] wlan%d: DNLD_CMD (135.802211): 802_11_SNMP_MIB [0x16], act 0x0, len 142, seqno 0x16 timeout 5000
[ 135.821909] wlan%d: CMD_RESP (135.802626): 802_11_SNMP_MIB [0x8016], result 0, len 142, seqno 0x16
[ 135.822058] wlan%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 135.822131] wlan%d: DNLD_CMD (135.802857): 802_11_SNMP_MIB [0x16], act 0x0, len 142, seqno 0x17 timeout 5000
[ 135.822556] wlan%d: CMD_RESP (135.803274): 802_11_SNMP_MIB [0x8016], result 0, len 142, seqno 0x17
[ 135.823588] wlan%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 135.823686] wlan%d: DNLD_CMD (135.804409): 802_11_SNMP_MIB [0x16], act 0x0, len 142, seqno 0x18 timeout 5000
[ 135.824156] wlan%d: CMD_RESP (135.804874): 802_11_SNMP_MIB [0x8016], result 0, len 142, seqno 0x18
[ 135.824697] cfg80211 regulatory domain callback 00 initiator=0 dfs_region=0
[ 135.824756] Regulatory domain BY_CORE
[ 135.824824] wlan%d: QUEUE_CMD: 802_11_RF_ANTENNA [0x20] is queued
[ 135.825063] wlan%d: DNLD_CMD (135.805783): 802_11_RF_ANTENNA [0x20], act 0xc, len 16, seqno 0x19 timeout 5000
[ 135.825563] wlan%d: CMD_RESP (135.806278): 802_11_RF_ANTENNA [0x8020], result 0, len 16, seqno 0x19
[ 135.830566] PS Command: action = 0x0, bitmap = 0x0
[ 135.830603] wlan%d: QUEUE_CMD: 802_11_PS_MODE_ENH [0xe4] is queued
[ 135.830705] wlan%d: DNLD_CMD (135.811429): 802_11_PS_MODE_ENH [0xe4], act 0x0, len 12, seqno 0x1a timeout 5000
[ 135.831207] wlan%d: CMD_RESP (135.811924): 802_11_PS_MODE_ENH [0x80e4], result 0, len 68, seqno 0x1a
[ 135.831257] ps_bitmap=0x0
[ 135.832483] CFG80211: Country=00, band=0, no_of_sub_band=1
[ 135.832537] wlan%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 135.832595] 11D:Country=WW band=0 sub-band=1 dfs_region=0
[ 135.832612] 11D: first chan=1 no_of_chan=14, max_tx_pwr=20
[ 135.832627] wlan%d: QUEUE_CMD: 802_11D_DOMAIN_INFO [0x5b] is queued
[ 135.832654] wlan_set_regiontable: 2.4G 0x0
[ 135.832679] wlan_set_regiontable: 5G 0x0
[ 135.832765] wlan%d: DNLD_CMD (135.813487): 802_11_SNMP_MIB [0x16], act 0x1, len 16, seqno 0x1b timeout 5000
[ 135.833246] wlan%d: CMD_RESP (135.813963): 802_11_SNMP_MIB [0x8016], result 0, len 16, seqno 0x1b
[ 135.833311] wlan%d: DNLD_CMD (135.814036): 802_11D_DOMAIN_INFO [0x5b], act 0x1, len 32, seqno 0x1c timeout 5000
[ 135.833767] wlan%d: 135.814485 : Event: VDLL_IND [0x81]
[ 135.833837] VDLL_IND: type=0 ID=23 offset = 0xe808 len = 600
[ 135.833865] wlan%d: DNLD_VDLL : block_len=600
[ 135.852281] wlan%d: 135.832993 : Event: VDLL_IND [0x81]
[ 135.852365] VDLL_IND: type=0 ID=23 offset = 0xea60 len = 600
[ 135.852394] wlan%d: DNLD_VDLL : block_len=600
[ 135.853090] wlan%d: 135.833806 : Event: VDLL_IND [0x81]
[ 135.853163] VDLL_IND: type=0 ID=23 offset = 0xecb8 len = 600
[ 135.853190] wlan%d: DNLD_VDLL : block_len=600
[ 135.853763] wlan%d: 135.834478 : Event: VDLL_IND [0x81]
[ 135.853834] VDLL_IND: type=0 ID=23 offset = 0xef10 len = 600
[ 135.853862] wlan%d: DNLD_VDLL : block_len=600
[ 135.854423] wlan%d: 135.835138 : Event: VDLL_IND [0x81]
[ 135.854495] VDLL_IND: type=0 ID=23 offset = 0xf168 len = 600
[ 135.854520] wlan%d: DNLD_VDLL : block_len=600
[ 135.855156] wlan%d: 135.835873 : Event: VDLL_IND [0x81]
[ 135.855227] VDLL_IND: type=0 ID=23 offset = 0xf3c0 len = 600
[ 135.855253] wlan%d: DNLD_VDLL : block_len=600
[ 135.855840] wlan%d: 135.836555 : Event: VDLL_IND [0x81]
[ 135.855914] VDLL_IND: type=0 ID=23 offset = 0xf618 len = 600
[ 135.855940] wlan%d: DNLD_VDLL : block_len=600
[ 135.856506] wlan%d: 135.837222 : Event: VDLL_IND [0x81]
[ 135.856579] VDLL_IND: type=0 ID=23 offset = 0xf870 len = 600
[ 135.856605] wlan%d: DNLD_VDLL : block_len=600
[ 135.857176] wlan%d: 135.837891 : Event: VDLL_IND [0x81]
[ 135.857249] VDLL_IND: type=0 ID=23 offset = 0xfac8 len = 600
[ 135.857273] wlan%d: DNLD_VDLL : block_len=600
[ 135.871435] wlan%d: 135.852148 : Event: VDLL_IND [0x81]
[ 135.871518] VDLL_IND: type=0 ID=18 offset = 0xc4e0 len = 600
[ 135.871546] wlan%d: DNLD_VDLL : block_len=600
[ 135.889846] wlan%d: 135.870559 : Event: VDLL_IND [0x81]
[ 135.889927] VDLL_IND: type=0 ID=18 offset = 0xc738 len = 600
[ 135.889954] wlan%d: DNLD_VDLL : block_len=600
[ 135.890572] wlan%d: 135.871288 : Event: VDLL_IND [0x81]
[ 135.890641] VDLL_IND: type=0 ID=18 offset = 0xc990 len = 600
[ 135.890667] wlan%d: DNLD_VDLL : block_len=600
[ 135.891189] wlan%d: 135.871907 : Event: VDLL_IND [0x81]
[ 135.891256] VDLL_IND: type=0 ID=18 offset = 0xcbe8 len = 600
[ 135.891281] wlan%d: DNLD_VDLL : block_len=600
[ 135.891805] wlan%d: 135.872522 : Event: VDLL_IND [0x81]
[ 135.891874] VDLL_IND: type=0 ID=18 offset = 0xce40 len = 600
[ 135.891899] wlan%d: DNLD_VDLL : block_len=600
[ 135.892608] wlan%d: CMD_RESP (135.873325): 802_11D_DOMAIN_INFO [0x805b], result 0, len 32, seqno 0x1c
[ 135.892748] CFG80211: Country=00, band=1, no_of_sub_band=25
[ 135.892808] 11D:Country=WW band=1 sub-band=25 dfs_region=0
[ 135.892823] 11D: first chan=36 no_of_chan=1, max_tx_pwr=20
[ 135.892836] 11D: first chan=40 no_of_chan=1, max_tx_pwr=20
[ 135.892848] 11D: first chan=44 no_of_chan=1, max_tx_pwr=20
[ 135.892860] 11D: first chan=48 no_of_chan=1, max_tx_pwr=20
[ 135.892872] 11D: first chan=52 no_of_chan=1, max_tx_pwr=20
[ 135.892883] 11D: first chan=56 no_of_chan=1, max_tx_pwr=20
[ 135.892895] 11D: first chan=60 no_of_chan=1, max_tx_pwr=20
[ 135.892906] 11D: first chan=64 no_of_chan=1, max_tx_pwr=20
[ 135.892919] 11D: first chan=100 no_of_chan=1, max_tx_pwr=20
[ 135.892930] 11D: first chan=104 no_of_chan=1, max_tx_pwr=20
[ 135.892942] 11D: first chan=108 no_of_chan=1, max_tx_pwr=20
[ 135.892954] 11D: first chan=112 no_of_chan=1, max_tx_pwr=20
[ 135.892966] 11D: first chan=116 no_of_chan=1, max_tx_pwr=20
[ 135.892978] 11D: first chan=120 no_of_chan=1, max_tx_pwr=20
[ 135.892991] 11D: first chan=124 no_of_chan=1, max_tx_pwr=20
[ 135.893003] 11D: first chan=128 no_of_chan=1, max_tx_pwr=20
[ 135.893015] 11D: first chan=132 no_of_chan=1, max_tx_pwr=20
[ 135.893026] 11D: first chan=136 no_of_chan=1, max_tx_pwr=20
[ 135.893038] 11D: first chan=140 no_of_chan=1, max_tx_pwr=20
[ 135.893050] 11D: first chan=144 no_of_chan=1, max_tx_pwr=20
[ 135.893062] 11D: first chan=149 no_of_chan=1, max_tx_pwr=20
[ 135.893074] 11D: first chan=153 no_of_chan=1, max_tx_pwr=20
[ 135.893086] 11D: first chan=157 no_of_chan=1, max_tx_pwr=20
[ 135.893098] 11D: first chan=161 no_of_chan=1, max_tx_pwr=20
[ 135.893111] 11D: first chan=165 no_of_chan=1, max_tx_pwr=20
[ 135.893129] wlan%d: QUEUE_CMD: 802_11D_DOMAIN_INFO [0x5b] is queued
[ 135.893162] wlan_set_regiontable: 2.4G 0x0
[ 135.893182] wlan_set_regiontable: 5G 0x0
[ 135.893262] wlan%d: DNLD_CMD (135.873985): 802_11D_DOMAIN_INFO [0x5b], act 0x1, len 104, seqno 0x1d timeout 5000
[ 135.914842] wlan%d: CMD_RESP (135.895556): 802_11D_DOMAIN_INFO [0x805b], result 0, len 104, seqno 0x1d
[ 135.915464] Set wlan%d interface addr: 30:XX:XX:XX:8c:11
[ 135.915527] wlan%d: QUEUE_CMD: 802_11_MAC_ADDRESS [0x4d] is queued
[ 135.915612] wlan%d: DNLD_CMD (135.896337): 802_11_MAC_ADDRESS [0x4d], act 0x1, len 16, seqno 0x1e timeout 5000
[ 135.916084] wlan%d: CMD_RESP (135.896801): 802_11_MAC_ADDRESS [0x804d], result 0, len 16, seqno 0x1e
[ 135.917741] Register NXP 802.11 Adapter wlan0
[ 135.918123] uap%d: QUEUE_CMD: 11AX_CFG [0x266] is queued
[ 135.918242] wlan0 set multicast_list
[ 135.918284] wlan0: QUEUE_CMD: MAC_MULTICAST_ADR [0x10] is queued
[ 135.918321] wlan0: QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 135.919456] uap%d: DNLD_CMD (135.900169): 11AX_CFG [0x266], act 0x1, len 39, seqno 0x101f timeout 5000
[ 135.922208] wlan0: 135.902922 : Event: VDLL_IND [0x81]
[ 135.922289] VDLL_IND: type=0 ID=24 offset = 0xfd20 len = 600
[ 135.922317] wlan0: DNLD_VDLL : block_len=600
[ 135.924116] wlan0: QUEUE_CMD: TXPWR_CFG [0xd1] is queued
[ 135.940962] wlan0: 135.921674 : Event: VDLL_IND [0x81]
[ 135.941045] VDLL_IND: type=0 ID=24 offset = 0xff78 len = 600
[ 135.941072] wlan0: DNLD_VDLL : block_len=600
[ 135.941803] wlan0: 135.922519 : Event: VDLL_IND [0x81]
[ 135.941878] VDLL_IND: type=0 ID=24 offset = 0x101d0 len = 600
[ 135.941907] wlan0: DNLD_VDLL : block_len=600
[ 135.942533] wlan0: 135.923247 : Event: VDLL_IND [0x81]
[ 135.942609] VDLL_IND: type=0 ID=24 offset = 0x10428 len = 600
[ 135.942636] wlan0: DNLD_VDLL : block_len=600
[ 135.943225] wlan0: 135.923941 : Event: VDLL_IND [0x81]
[ 135.943295] VDLL_IND: type=0 ID=24 offset = 0x10680 len = 600
[ 135.943321] wlan0: DNLD_VDLL : block_len=600
[ 135.943880] wlan0: 135.924596 : Event: VDLL_IND [0x81]
[ 135.943953] VDLL_IND: type=0 ID=24 offset = 0x108d8 len = 600
[ 135.943980] wlan0: DNLD_VDLL : block_len=600
[ 135.944770] uap%d: CMD_RESP (135.925484): 11AX_CFG [0x8266], result 0, len 39, seqno 0x101f
[ 135.944838] user_2g_hecap_len=28
[ 135.944887] wlan0: DNLD_CMD (135.925611): MAC_MULTICAST_ADR [0x10], act 0x1, len 204, seqno 0x20 timeout 5000
[ 135.945344] wlan0: CMD_RESP (135.926062): MAC_MULTICAST_ADR [0x8010], result 0, len 204, seqno 0x20
[ 135.945402] wlan0: DNLD_CMD (135.926128): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0x21 timeout 5000
[ 135.945714] wlan0: CMD_RESP (135.926433): MAC_CONTROL [0x8028], result 0, len 12, seqno 0x21
[ 135.945784] wlan0: DNLD_CMD (135.926508): TXPWR_CFG [0xd1], act 0x0, len 16, seqno 0x22 timeout 5000
[ 135.946203] wlan0: CMD_RESP (135.926922): TXPWR_CFG [0x80d1], result 0, len 100, seqno 0x22
[ 135.946372] uap%d: QUEUE_CMD: 11AX_CFG [0x266] is queued
[ 135.946458] uap%d: DNLD_CMD (135.927182): 11AX_CFG [0x266], act 0x1, len 39, seqno 0x1023 timeout 5000
[ 135.946898] uap%d: CMD_RESP (135.927614): 11AX_CFG [0x8266], result 0, len 39, seqno 0x1023
[ 135.946950] user_hecap_len=28
[ 135.947917] wlan0: QUEUE_CMD: 802_11_RF_ANTENNA [0x20] is queued
[ 135.948036] wlan0: DNLD_CMD (135.928760): 802_11_RF_ANTENNA [0x20], act 0xc, len 16, seqno 0x24 timeout 5000
[ 135.948531] wlan0: CMD_RESP (135.929248): 802_11_RF_ANTENNA [0x8020], result 0, len 16, seqno 0x24
[ 135.952904] wlan0: QUEUE_CMD: TXPWR_CFG [0xd1] is queued
[ 135.953030] wlan0: DNLD_CMD (135.933753): TXPWR_CFG [0xd1], act 0x0, len 16, seqno 0x25 timeout 5000
[ 135.953530] wlan0: CMD_RESP (135.934248): TXPWR_CFG [0x80d1], result 0, len 100, seqno 0x25
[ 135.980353] Set uap%d interface addr: 32:XX:XX:XX:8d:11
[ 135.980421] uap%d: QUEUE_CMD: APCMD_SYS_CONFIGURE [0xb0] is queued
[ 135.980519] uap%d: DNLD_CMD (135.961243): APCMD_SYS_CONFIGURE [0xb0], act 0x1, len 20, seqno 0x1026 timeout 5000
[ 135.981001] uap%d: CMD_RESP (135.961718): APCMD_SYS_CONFIGURE [0x80b0], result 0, len 20, seqno 0x1026
[ 135.982691] Register NXP 802.11 Adapter uap0
[ 135.983020] PS Command: action = 0x0, bitmap = 0x0
[ 135.983047] p2p%d: QUEUE_CMD: 802_11_PS_MODE_ENH [0xe4] is queued
[ 135.983151] uap0 set multicast_list
[ 135.983219] p2p%d: DNLD_CMD (135.963942): 802_11_PS_MODE_ENH [0xe4], act 0x0, len 12, seqno 0x2027 timeout 5000
[ 135.984207] p2p%d: CMD_RESP (135.964920): 802_11_PS_MODE_ENH [0x80e4], result 0, len 68, seqno 0x2027
[ 135.984265] ps_bitmap=0x0
[ 135.984403] CFG80211: Country=00, band=0, no_of_sub_band=1
[ 135.984449] p2p%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 135.984505] 11D:Country=WW band=0 sub-band=1 dfs_region=0
[ 135.984522] 11D: first chan=1 no_of_chan=14, max_tx_pwr=20
[ 135.984537] p2p%d: QUEUE_CMD: 802_11D_DOMAIN_INFO [0x5b] is queued
[ 135.984568] wlan_set_regiontable: 2.4G 0x0
[ 135.984587] wlan_set_regiontable: 5G 0x0
[ 135.984659] p2p%d: DNLD_CMD (135.965381): 802_11_SNMP_MIB [0x16], act 0x1, len 16, seqno 0x2028 timeout 5000
[ 135.985112] p2p%d: CMD_RESP (135.965828): 802_11_SNMP_MIB [0x8016], result 0, len 16, seqno 0x2028
[ 135.985176] p2p%d: DNLD_CMD (135.965901): 802_11D_DOMAIN_INFO [0x5b], act 0x1, len 32, seqno 0x2029 timeout 5000
[ 135.985893] wlan0: QUEUE_CMD: RX_MGMT_IND [0x10c] is queued
[ 136.006674] p2p%d: CMD_RESP (135.987387): 802_11D_DOMAIN_INFO [0x805b], result 0, len 32, seqno 0x2029
[ 136.006769] wlan0: DNLD_CMD (135.987493): RX_MGMT_IND [0x10c], act 0x1, len 14, seqno 0x2a timeout 5000
[ 136.007116] wlan0: CMD_RESP (135.987835): RX_MGMT_IND [0x810c], result 0, len 14, seqno 0x2a
[ 136.007258] CFG80211: Country=00, band=1, no_of_sub_band=25
[ 136.007319] 11D:Country=WW band=1 sub-band=25 dfs_region=0
[ 136.007334] 11D: first chan=36 no_of_chan=1, max_tx_pwr=20
[ 136.007347] 11D: first chan=40 no_of_chan=1, max_tx_pwr=20
[ 136.007359] 11D: first chan=44 no_of_chan=1, max_tx_pwr=20
[ 136.007371] 11D: first chan=48 no_of_chan=1, max_tx_pwr=20
[ 136.007382] 11D: first chan=52 no_of_chan=1, max_tx_pwr=20
[ 136.007394] 11D: first chan=56 no_of_chan=1, max_tx_pwr=20
[ 136.007405] 11D: first chan=60 no_of_chan=1, max_tx_pwr=20
[ 136.007417] 11D: first chan=64 no_of_chan=1, max_tx_pwr=20
[ 136.007429] 11D: first chan=100 no_of_chan=1, max_tx_pwr=20
[ 136.007441] 11D: first chan=104 no_of_chan=1, max_tx_pwr=20
[ 136.007453] 11D: first chan=108 no_of_chan=1, max_tx_pwr=20
[ 136.007465] 11D: first chan=112 no_of_chan=1, max_tx_pwr=20
[ 136.007476] 11D: first chan=116 no_of_chan=1, max_tx_pwr=20
[ 136.007488] 11D: first chan=120 no_of_chan=1, max_tx_pwr=20
[ 136.007500] 11D: first chan=124 no_of_chan=1, max_tx_pwr=20
[ 136.007512] 11D: first chan=128 no_of_chan=1, max_tx_pwr=20
[ 136.007524] 11D: first chan=132 no_of_chan=1, max_tx_pwr=20
[ 136.007536] 11D: first chan=136 no_of_chan=1, max_tx_pwr=20
[ 136.007548] 11D: first chan=140 no_of_chan=1, max_tx_pwr=20
[ 136.007560] 11D: first chan=144 no_of_chan=1, max_tx_pwr=20
[ 136.007572] 11D: first chan=149 no_of_chan=1, max_tx_pwr=20
[ 136.007583] 11D: first chan=153 no_of_chan=1, max_tx_pwr=20
[ 136.007595] 11D: first chan=157 no_of_chan=1, max_tx_pwr=20
[ 136.007607] 11D: first chan=161 no_of_chan=1, max_tx_pwr=20
[ 136.007619] 11D: first chan=165 no_of_chan=1, max_tx_pwr=20
[ 136.007637] p2p%d: QUEUE_CMD: 802_11D_DOMAIN_INFO [0x5b] is queued
[ 136.007669] wlan_set_regiontable: 2.4G 0x0
[ 136.007691] wlan_set_regiontable: 5G 0x0
[ 136.007772] p2p%d: DNLD_CMD (135.988494): 802_11D_DOMAIN_INFO [0x5b], act 0x1, len 104, seqno 0x202b timeout 5000
[ 136.029473] p2p%d: CMD_RESP (136.010184): 802_11D_DOMAIN_INFO [0x805b], result 0, len 104, seqno 0x202b
[ 136.048176] Set WFD device addr: 32:XX:XX:XX:8c:11
[ 136.048243] p2p%d: QUEUE_CMD: 802_11_MAC_ADDRESS [0x4d] is queued
[ 136.048342] p2p%d: DNLD_CMD (136.029066): 802_11_MAC_ADDRESS [0x4d], act 0x1, len 16, seqno 0x202c timeout 5000
[ 136.048852] p2p%d: CMD_RESP (136.029568): 802_11_MAC_ADDRESS [0x804d], result 0, len 16, seqno 0x202c
[ 136.050691] Register NXP 802.11 Adapter p2p0
[ 136.050845] wlan: version = SDIW612---18.99.3.p26.11-MM6X18540.p17-(FP92)
[ 136.050911] wlan0: QUEUE_CMD: REG_ACCESS [0x27c] is queued
[ 136.051016] p2p0 set multicast_list
[ 136.051054] p2p0: QUEUE_CMD: MAC_MULTICAST_ADR [0x10] is queued
[ 136.051086] p2p0: QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 136.051145] wlan0: DNLD_CMD (136.031870): REG_ACCESS [0x27c], act 0x0, len 20, seqno 0x2d timeout 5000
[ 136.052103] wlan0: CMD_RESP (136.032816): REG_ACCESS [0x827c], result 0, len 20, seqno 0x2d
[ 136.052193] p2p0: DNLD_CMD (136.032918): MAC_MULTICAST_ADR [0x10], act 0x1, len 204, seqno 0x202e timeout 5000
[ 136.052627] p2p0: CMD_RESP (136.033345): MAC_MULTICAST_ADR [0x8010], result 0, len 204, seqno 0x202e
[ 136.052682] p2p0: DNLD_CMD (136.033408): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0x202f timeout 5000
[ 136.052998] p2p0: CMD_RESP (136.033717): MAC_CONTROL [0x8028], result 0, len 12, seqno 0x202f
[ 136.053200] wlan0: QUEUE_CMD: INDEPENDENT_RESET_CFG [0x243] is queued
[ 136.053281] wlan0: DNLD_CMD (136.034005): INDEPENDENT_RESET_CFG [0x243], act 0x0, len 12, seqno 0x30 timeout 5000
[ 136.053716] wlan0: CMD_RESP (136.034434): INDEPENDENT_RESET_CFG [0x8243], result 0, len 12, seqno 0x30
[ 136.054120] vendor event :0x2
[ 136.054174] ========END IN-BAND RESET===========
[ 136.112302] wlan0: QUEUE_CMD: TXPWR_CFG [0xd1] is queued
[ 136.112439] wlan0: DNLD_CMD (136.093162): TXPWR_CFG [0xd1], act 0x0, len 16, seqno 0x31 timeout 5000
[ 136.112959] wlan0: CMD_RESP (136.093675): TXPWR_CFG [0x80d1], result 0, len 100, seqno 0x31
[ 136.123000] wlan0 set multicast_list
[ 136.123064] wlan0: QUEUE_CMD: MAC_MULTICAST_ADR [0x10] is queued
[ 136.123110] wlan0: QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 136.123195] wlan0: DNLD_CMD (136.103918): MAC_MULTICAST_ADR [0x10], act 0x1, len 204, seqno 0x32 timeout 5000
[ 136.123686] wlan0: CMD_RESP (136.104404): MAC_MULTICAST_ADR [0x8010], result 0, len 204, seqno 0x32
[ 136.123751] wlan0: DNLD_CMD (136.104476): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0x33 timeout 5000
[ 136.124071] wlan0: CMD_RESP (136.104789): MAC_CONTROL [0x8028], result 0, len 12, seqno 0x33
[ 136.127648] wlan0: QUEUE_CMD: TXPWR_CFG [0xd1] is queued
[ 136.127786] wlan0: DNLD_CMD (136.108509): TXPWR_CFG [0xd1], act 0x0, len 16, seqno 0x34 timeout 5000
[ 136.128291] wlan0: CMD_RESP (136.109008): TXPWR_CFG [0x80d1], result 0, len 100, seqno 0x34
11 回复数
1,465 次查看
weidong_sun
Dear @eric25 ,
OK, could you please provide these information?
1. full linux logs which include loading wifi driver, and  stating wpa_supplicant
2. wpa_supplicant.conf
Let see it again.
Thanks!
weidong
1,524 次查看
weidong_sun
Dear @eric25 ,
Based on the information you provided, our initial assessment is that the wpa_supplicant version on your system is too old. Since your platform is running a Linux 4.4.19 kernel, the wpa_supplicant included in such systems is typically no newer than version 2.5. Older versions do not fully support the required nl80211 scanning mechanisms, which can lead to the scan timeout and inability to detect Wi‑Fi hotspots that you are observing.
We recommend that you cross‑compile wpa_supplicant version 2.10, or alternatively 2.11 or 2.12, and replace the old version on your board. After updating wpa_supplicant, please repeat your original test steps and check whether the Wi‑Fi scan works properly.
Try it, please!
Thanks!
Weidong
1,462 次查看
eric25
YES,
the wifi driver version is aw611_driver\p26.11\WIFI-BT-AAU_6_1_55-IMX8--MM6X18540.p17_V3-GPL\wlan_src\, provided by UTA.
the log and dmesg is here:
https://pan.quark.cn/s/5e926a94d760
wpa_supplicant.conf
破坏者
update_config=1
ctrl_interface=/var/run/wpa_supplicant
eapol_version=1
ap_scan=1
fast_reauth=1
driver_param=use_p2p_group_interface=1p2p_device=1
#device_name=I1587-s_wifi
device_type=10-0050F204-5
config_methods=virtual_push_button physical_display keyboard
hs20=1
interworking=1
dmesg0326-2.txt
破坏者
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.4.19 (root@AndroidSev) (gcc version 4.9.3 20141031 (prerelease) (Linaro GCC 2014.11) ) #226 Thu Mar 26 11:48:39 CST 2026
[ 0.000000] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: SAMA5D3 Xplained
[ 0.000000] Reserved memory: created CMA memory pool at 0x26c00000, size 16 MiB
[ 0.000000] Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 32512
[ 0.000000] free_area_init_node: node 0, pgdat c0643dd0, node_mem_map c7df2000
[ 0.000000] Normal zone: 254 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32512 pages, LIFO batch:7
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32258
[ 0.000000] Kernel command line: noinitrd console=ttyS0,115200 clk_ignore_unused rootfstype=ubifs ubi.mtd=3 root=ubi0:rootfs ro rootwait init=/sbin/sinit
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 105740K/130048K available (4696K kernel code, 145K rwdata, 1360K rodata, 180K init, 159K bss, 7924K reserved, 16384K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc8000000 - 0xff800000 ( 888 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc7f00000 ( 127 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc05f22d4 (6057 kB)
[ 0.000000] .init : 0xc05f3000 - 0xc0620000 ( 180 kB)
[ 0.000000] .data : 0xc0620000 - 0xc06447a0 ( 146 kB)
[ 0.000000] .bss : 0xc06447a0 - 0xc066c72c ( 160 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] clocksource: timer@f0010000: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 115833966437 ns
[ 0.000022] sched_clock: 32 bits at 16MHz, resolution 60ns, wraps every 130150523873ns
[ 0.000048] Switching to timer-based delay loop, resolution 60ns
[ 0.027983] clocksource: pit: mask: 0xfffffff max_cycles: 0xfffffff, max_idle_ns: 14479245754 ns
[ 0.028414] Console: colour dummy device 80x30
[ 0.028472] Calibrating delay loop (skipped), value calculated using timer frequency.. 33.00 BogoMIPS (lpj=165000)
[ 0.028501] pid_max: default: 32768 minimum: 301
[ 0.028689] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.028718] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.029699] CPU: Testing write buffer coherency: ok
[ 0.030370] Setting up static identity map for 0x20008200 - 0x20008258
[ 0.051134] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[ 0.051225] [dri_chk_init(241)]: init ok
[ 0.051855] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.053706] pinctrl core: initialized pinctrl subsystem
[ 0.055024] unidebug_init: abort_log_paddr: 0xc0c07bf0 -> 0xc8020000, size: 0x10000
[ 0.055056] Abort log buffer addr: 0xc8020000, head: 0, tail: 0
[ 0.055102] unidebug_init: realtime_log_paddr: 0xc0c07bf8 -> 0xc8040000, size: 0x30000
[ 0.055125] realtime log buffer addr: 0xc8040000, head: 0, tail: 751, current messages size: 751
[ 0.055448] dt_uni_dbg_flag: uni_dbg_flag addr:value -> 0xc8010f00 : 0x55d454d4
[ 0.056903] NET: Registered protocol family 16
[ 0.061074] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.061161] [uni_register_pm_check_unit(119)]: register main func:[pm-driver-selfcheck], fun = 0xc0043044
[ 0.063487] AT91: Detected SoC family: sama5d3
[ 0.063517] AT91: Detected SoC: sama5d31, revision 3
[ 0.078086] irq: no irq domain found for /ahb/apb/pinctrl@fffff200/gpio@fffffa00 !
[ 0.089307] gpio-at91 fffff200.gpio: at address c8018200
[ 0.090542] gpio-at91 fffff400.gpio: at address c801a400
[ 0.091861] gpio-at91 fffff600.gpio: at address c801c600
[ 0.093208] gpio-at91 fffff800.gpio: at address c801e800
[ 0.094664] gpio-at91 fffffa00.gpio: at address c8032a00
[ 0.096164] pinctrl-at91 ahb:apb:pinctrl@fffff200: initialized AT91 pinctrl driver
[ 0.097460] kernel version: br03_v01p01d_wifi_bt_UTA2_0326
[ 0.097489] HW version: br03
[ 0.097504] of node name:bootparas
[ 0.097544] boot_mode registers at 0x27ffff80 mapped at c8034f80
[ 0.097567] reset_reason registers at 0x27ffffc0 mapped at c8036fc0
[ 0.098054] reset reason from SDRAM: 0x17554444
[ 0.098074] Device start to power up!
[ 0.098087] reset reason:POWR
[ 0.098099] write reset reason: 0x53525748
[ 0.098110] read boot mode: 0x55554451
[ 0.098126] read boot mode:0xffffffff --> random in SDRAM
[ 0.098464] sysclk ctrl io: 21
[ 0.098556] index: 0
[ 0.098606] cnt: 0
[ 0.098910] bootparas driver probe [OK]
[ 0.159347] at_hdmac ffffe600.dma-controller: Atmel AHB DMA Controller ( cpy set slave sg-cpy ), 8 channels
[ 0.161569] at_hdmac ffffe800.dma-controller: Atmel AHB DMA Controller ( cpy set slave sg-cpy ), 8 channels
[ 0.165426] usbcore: registered new interface driver usbfs
[ 0.165610] usbcore: registered new interface driver hub
[ 0.165780] usbcore: registered new device driver usb
[ 0.166087] I2C FPGA KEYPAD INIT [ OK ]
[ 0.166215] I2C FPGA GPI INIT [OK]
[ 0.167819] at91_i2c f0014000.i2c: AT91 i2c bus driver (hw version: 0x402).
[ 0.169063] I2C FPGA GPI Probe,addr:0x70 [OK]
[ 0.169439] <5>fpga_keypad_probe(168): I2C FPGA KEYPAD i2c client addr: 0x72
[ 0.169477] I2C FPGA KEYPAD Probe [ OK ]
[ 0.183675] gpio-ice40lp1k probe [OK]
[ 0.184153] mcu-boot-ctrl-pin 196 init 1 ok
[ 0.184285] at91_i2c f0018000.i2c: AT91 i2c bus driver (hw version: 0x402).
[ 0.185739] Advanced Linux Sound Architecture Driver Initialized.
[ 0.186998] Bluetooth: Core ver 2.21
[ 0.187115] NET: Registered protocol family 31
[ 0.187136] Bluetooth: HCI device and connection manager initialized
[ 0.187173] Bluetooth: HCI socket layer initialized
[ 0.187199] Bluetooth: L2CAP socket layer initialized
[ 0.187226] Bluetooth: SCO socket layer initialized
[ 0.187851] ------------[ cut here ]------------
[ 0.187902] WARNING: CPU: 0 PID: 1 at net/wireless/reg.c:523 regulatory_init+0x84/0x128()
[ 0.187916] db.txt is empty, you should update it...
[ 0.187928] Modules linked in:
[ 0.187958] CPU: 0 PID: 1 Comm: swapper Not tainted 4.4.19 #226
[ 0.187973] Hardware name: Atmel SAMA5
[ 0.188039] [<c001499c>] (unwind_backtrace) from [<c00125dc>] (show_stack+0x10/0x14)
[ 0.188084] [<c00125dc>] (show_stack) from [<c001fbd0>] (warn_slowpath_common+0x80/0xac)
[ 0.188120] [<c001fbd0>] (warn_slowpath_common) from [<c001fc2c>] (warn_slowpath_fmt+0x30/0x40)
[ 0.188153] [<c001fc2c>] (warn_slowpath_fmt) from [<c06133c0>] (regulatory_init+0x84/0x128)
[ 0.188185] [<c06133c0>] (regulatory_init) from [<c06132c4>] (cfg80211_init+0x54/0xcc)
[ 0.188216] [<c06132c4>] (cfg80211_init) from [<c000961c>] (do_one_initcall+0x90/0x1d8)
[ 0.188260] [<c000961c>] (do_one_initcall) from [<c05f3d80>] (kernel_init_freeable+0x130/0x1d0)
[ 0.188305] [<c05f3d80>] (kernel_init_freeable) from [<c0479308>] (kernel_init+0xc/0xe8)
[ 0.188341] [<c0479308>] (kernel_init) from [<c000f3f8>] (ret_from_fork+0x14/0x3c)
[ 0.188400] ---[ end trace db6e7ed398e5acc9 ]---
[ 0.192800] clocksource: Switched to clocksource timer@f0010000
[ 0.208795] NET: Registered protocol family 2
[ 0.209929] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.209988] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.210031] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.210207] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.210254] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.210579] NET: Registered protocol family 1
[ 0.211421] input: Unspecified device as /devices/virtual/input/input0
[ 0.211463] <5>si_key_probe(171): Key: register sama5d3-key input device
[ 0.229580] SI core probe [ OK ]
[ 0.229863] SI core init [ OK ]
[ 0.232200] <5>parse_dt(569): bt ref clk is not from ref clk node
[ 0.232249] <5>parse_dt(578): bt clk is not from bt clk node
[ 0.232400] bt driver probe [ OK ]
[ 0.234678] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.261119] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.271996] Key type asymmetric registered
[ 0.272046] Asymmetric key parser 'x509' registered
[ 0.272142] io scheduler noop registered (default)
[ 0.275288] f001c000.serial: ttyS1 at MMIO 0xf001c000 (irq = 32, base_baud = 4125000) is a ATMEL_SERIAL
[ 0.276372] f8024000.serial: ttyS4 at MMIO 0xf8024000 (irq = 34, base_baud = 4125000) is a ATMEL_SERIAL
[ 0.278040] aquire gps boot gpio pin error, not use it!
[ 0.278239] kfifo: size =1024, recsize=0, esize=1, inited=1023
[ 0.278268] sama5d3-gps gps: gps init ok
[ 0.279091] <3>acc_init_ctl_io(987): Failed to get io0_sel gpio
[ 0.279141] <3>acc_init_ctl_io(994): Failed to get io1_sel gpio
[ 0.279497] uni-acc uni_acc0: acc0 init ok
[ 0.289728] brd: module loaded
[ 0.300025] loop: module loaded
[ 0.300727] ssc f0008000.ssc.0: Atmel SSC device at 0xc80d8000 (irq 29)
[ 0.301156] ssc f800c000.ssc.1: Atmel SSC device at 0xc80e0000 (irq 33)
[ 0.302061] at24 0-0050: 512 byte 24c04 EEPROM, writable, 16 bytes/write
[ 0.306971] atmel_nand_nfc 70000000.nfc: NFC is probed.
[ 0.307215] atmel_nand 60000000.nand: Use On Flash BBT
[ 0.308380] atmel_nand 60000000.nand: Using dma0chan0 for DMA transfers.
[ 0.309744] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xa3
[ 0.309772] nand: Micron MT29F8G08ABBCAH4
[ 0.309794] nand: 1024 MiB, SLC, erase size: 256 KiB, page size: 4096, OOB size: 224
[ 0.309826] atmel_nand 60000000.nand: minimum ECC: 8 bits in 512 bytes
[ 0.309850] atmel_nand 60000000.nand: Initialize PMECC params, cap: 12, sector: 512
[ 0.309956] atmel_nand 60000000.nand: Using NFC Sram read
[ 0.311307] Bad block table found at page 262080, version 0x01
[ 0.312151] Bad block table found at page 262016, version 0x01
[ 0.312999] 4 ofpart partitions found on MTD device atmel_nand
[ 0.313028] Creating 4 MTD partitions on "atmel_nand":
[ 0.313059] 0x000000000000-0x000000040000 : "iplp1"
[ 0.313770] 0x000000040000-0x000001080000 : "minisys"
[ 0.314417] 0x000001080000-0x000002480000 : "workbin"
[ 0.315035] 0x000002480000-0x000040000000 : "user-fs"
[ 0.317794] <3>dsp_output_probe(348): register dsp output0
[ 0.317885] dsp-output dsp-output0: dsp_output driver probe
[ 0.318003] <3>dsp_output_probe(354): register dsp output1
[ 0.318070] dsp-output dsp-output1: dsp_output driver probe
[ 0.318552] <3>dsp_input_probe(334): register dsp input0,ret=0
[ 0.318652] dsp-input dsp-input0: dsp_input driver probe
[ 0.318772] <3>dsp_input_probe(340): register dsp input1,ret=0
[ 0.318839] dsp-input dsp-input1: dsp_input driver probe
[ 0.320816] atmel_spi f8008000.spi: version: 0x213
[ 0.321306] atmel_spi f8008000.spi: Using dma1chan0 (tx) and dma1chan1 (rx) for DMA transfers
[ 0.321433] atmel-spi register pio-irq, ret = 0
[ 0.321481] atmel_spi f8008000.spi: Atmel SPI Controller at 0xf8008000 (irq 27)
[ 0.324620] spi_master spi32766: will run message pump with realtime priority
[ 0.325692] <3>dsp_spi_probe(2295): spi named br03-dsp-spi1 probing
[ 0.325746] <3>dsp_spi_probe(2304): malloc 607 size of dsp driver, spidev = 0xc6969c00, spi = 0xc6969800, maste<3>dsp_spi_probe(2334): register dsp master1
[ 0.325823] dspmaster spi32766.0: dsp spi probe speed(3000000) dev 0x0f800001
[ 1.127630] [uni_register_pm_check_unit(153)]: register DSP1-INT, func = 0xc0254700
[ 1.128522] m25p80 spi32766.1: m25p10-nonjedec (128 Kbytes)
[ 1.130820] atmel_spi f0004000.spi: version: 0x213
[ 1.131300] atmel_spi f0004000.spi: Using dma0chan1 (tx) and dma0chan2 (rx) for DMA transfers
[ 1.131396] atmel-spi register pio-irq, ret = 0
[ 1.131441] atmel_spi f0004000.spi: Atmel SPI Controller at 0xf0004000 (irq 28)
[ 1.132565] spi_master spi32765: will run message pump with realtime priority
[ 1.133707] <3>dsp_spi_probe(2295): spi named br03-dsp-spi0 probing
[ 1.133760] <3>dsp_spi_probe(2304): malloc 607 size of dsp driver, spidev = 0xc6a05000, spi = 0xc6a04c00, maste<3>dsp_spi_probe(2326): register dsp master0
[ 1.133836] dspmaster spi32765.0: dsp spi probe speed(3000000) dev 0x0f800000
[ 1.134065] <5>dsp_hw_init(1705): can not find pwr-gpio in dts
[ 1.134099] <5>dsp_hw_init(1705): can not find rf_6V_pwr_en-gpio in dts
[ 1.134130] <5>dsp_hw_init(1705): can not find fpga_reset-gpio in dts
[ 1.134157] <5>dsp_hw_init(1705): can not find dsp_switch_ctl_A in dts
[ 1.134184] <5>dsp_hw_init(1705): can not find dsp_switch_ctl_B in dts
[ 1.134211] <5>dsp_hw_init(1705): can not find dsp_fpga_done in dts
[ 1.135118] <5>dsp_fault_save_timestamp(1541): dspmaster[0] dsp_fault_save_timestamp
[ 1.135390] <3>host_ctl_rf_power(350): dspmaster[0] cannot ctl pwr io
[ 1.935625] <3>host_ctl_rf_power(350): dspmaster[0] cannot ctl pwr io
[ 1.935669] [uni_register_pm_check_unit(153)]: register DSP0-INT, func = 0xc0254700
[ 1.936358] usbcore: registered new interface driver asix
[ 1.936535] usbcore: registered new interface driver ax88179_178a
[ 1.936693] usbcore: registered new interface driver cdc_ether
[ 1.936844] usbcore: registered new interface driver net1080
[ 1.936996] usbcore: registered new interface driver rndis_host
[ 1.937143] usbcore: registered new interface driver cdc_subset
[ 1.937291] usbcore: registered new interface driver zaurus
[ 1.937549] usbcore: registered new interface driver cdc_ncm
[ 1.937585] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.937614] ehci-atmel: EHCI Atmel driver
[ 1.938029] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.938067] ohci-atmel: OHCI Atmel driver
[ 1.938829] at91_ohci 600000.ohci: USB Host Controller
[ 1.938918] at91_ohci 600000.ohci: new USB bus registered, assigned bus number 1
[ 1.939060] <3>host_timer_enable(1109): dspmaster[0] disable host timer
[ 1.940111] at91_ohci 600000.ohci: irq 47, io mem 0x00600000
[ 1.998637] hub 1-0:1.0: USB hub found
[ 1.998899] hub 1-0:1.0: 1 port detected
[ 2.001020] atmel_usba_udc 500000.gadget: MMIO registers at 0xf8030000 mapped at c80e8000
[ 2.001125] atmel_usba_udc 500000.gadget: FIFO at 0x00500000 mapped at c8600000
[ 2.003751] using random self ethernet address
[ 2.003796] using random host ethernet address
[ 2.003829] using host ethernet address: be:6e:3b:3e:6f:6b
[ 2.003847] using self ethernet address: 12:56:59:21:22:05<6>[ 2.005248] usb0: HOST MAC be:6e:3b:3e:6f:6b
[ 2.005345] usb0: MAC 12:56:59:21:22:05
[ 2.005441] g_multi gadget: Multifunction Composite Gadget
[ 2.005464] g_multi gadget: userspace failed to provide iSerialNumber
[ 2.005480] g_multi gadget: g_multi ready
[ 2.010574] <5>fpga_keypad_probe(529): fpga keypad gpio (status): 158 (1), virq: 207
[ 2.010697] [uni_register_pm_check_unit(153)]: register keypad, func = 0xc02b8794
[ 2.011893] <5>fpga_keypad_probe(568): pck1 rate = 24000000, is_enable = 0
[ 2.011978] fpga keypad driver probe [ OK ]
[ 2.022710] <5>fpga_channel_knob_probe(353): Channel: ch_num(16) != evnet_code_end(16)
[ 2.022954] [uni_register_pm_check_unit(153)]: register channel_knob, func = 0xc02b8d98
[ 2.024185] fpga channel knob driver probe [ OK ]
[ 2.025204] <5>keypad_backlight_probe(161): keypad_backlight gpio[0/1]: 181
[ 2.025256] keypad backlight driver probe [ OK ]
[ 2.025803] vox fpga init ok [ OK ]
[ 2.026681] rtc rtc0: alarm rollover not handled
[ 2.026720] rtc rtc0: invalid alarm value: 1900-1-1 0:0:0
[ 2.027090] rtc rtc0: fffffeb0.rtc: dev (254:0)
[ 2.027149] at91_rtc fffffeb0.rtc: rtc core: registered fffffeb0.rtc as rtc0
[ 2.027245] at91_rtc fffffeb0.rtc: AT91 Real Time Clock driver.
[ 2.027521] i2c /dev entries driver
[ 2.029303] AT91: Starting after wakeup
[ 2.029773] <5>bq40z80_i2c_probe(69): bq40z80 i2c probe successfully.
[ 2.030367] at91_wdt fffffe40.watchdog: disable
[ 2.030404] <5>of_at91wdt_init(519): sama5d3 watchdog : sama5d3 watchdog status default disabled in the dts.
[ 2.030457] <5>at91wdt_check_mask(571): sama5d3 watchdog : 0x57155155
[ 2.030496] <5>at91wdt_probe(647): sama5d3 watchdog : sama5d3 watchdog status set enable by sysfs.
[ 2.031079] <5>at91wdt_probe(670): sama5d3 watchdog : sama5d3 watchdog register watchdog device successfully.
[ 2.031163] <5>at91wdt_probe(679): sama5d3 watchdog : AT91 WDT init ok
[ 2.031624] <5>fpga_wdt_get_dts(677): fpga watchdog : fpga watchdog default enable in the dts.
[ 2.032776] <3>fpga_wdt_reg_status_read(157): fpga watchdog : fpga wdt read from status reg failed.
[ 2.032938] <3>fpga_wdt_config(693): fpga watchdog : fpga watchdog read status reg on setup failed.
[ 2.032981] <3>fpga_wdt_probe(764): fpga watchdog : failed to config fpga wdt.
[ 2.033018] <5>fpga_wdt_probe(770): fpga watchdog : fpga watchdog probe ok.
[ 2.033272] Bluetooth: HCI UART driver ver 2.3
[ 2.033305] Bluetooth: HCI UART protocol BCSP registered
[ 2.034207] atmel_mci f0000000.mmc: version: 0x505
[ 2.034841] atmel_mci f0000000.mmc: using dma0chan3 for DMA transfers
[ 2.072889] atmel_mci f0000000.mmc: Atmel MCI controller at 0xf0000000 irq 26, 1 slots
[ 2.074162] <5>sama5d3_gpio_leds_probe(499): led0_gpio0 ctrl signal init success
[ 2.074606] <5>sama5d3_gpio_leds_probe(526): led0_gpio1 ctrl signal init success
[ 2.075024] <5>sama5d3_gpio_leds_probe(577): sama5d3 led driver probe led0 OK
[ 2.076547] <5>sama5d3_gpio_leds_probe(499): led1_gpio0 ctrl signal init success
[ 2.078705] <5>sama5d3_gpio_leds_probe(526): led1_gpio1 ctrl signal init success
[ 2.079168] <5>sama5d3_gpio_leds_probe(577): sama5d3 led driver probe led1 OK
[ 2.079734] <5>sama5d3_gpio_leds_probe(499): led2_gpio0 ctrl signal init success
[ 2.080221] <5>sama5d3_gpio_leds_probe(526): led2_gpio1 ctrl signal init success
[ 2.080603] <5>sama5d3_gpio_leds_probe(577): sama5d3 led driver probe led2 OK
[ 2.081202] <5>sama5d3_gpio_leds_probe(499): led3_gpio0 ctrl signal init success
[ 2.081727] <5>sama5d3_gpio_leds_probe(526): led3_gpio1 ctrl signal init success
[ 2.082124] <5>sama5d3_gpio_leds_probe(577): sama5d3 led driver probe led3 OK
[ 2.082759] <5>sama5d3_gpio_leds_probe(499): led4_gpio0 ctrl signal init success
[ 2.083352] <5>sama5d3_gpio_leds_probe(526): led4_gpio1 ctrl signal init success
[ 2.083817] <5>sama5d3_gpio_leds_probe(577): sama5d3 led driver probe led4 OK
[ 2.085076] <5>sama5d3_gpio_leds_probe(499): led5_gpio0 ctrl signal init success
[ 2.085465] <5>sama5d3_gpio_leds_probe(577): sama5d3 led driver probe led5 OK
[ 2.086755] <5>sama5d3_gpio_leds_probe(499): led6_gpio0 ctrl signal init success
[ 2.087271] <5>sama5d3_gpio_leds_probe(526): led6_gpio1 ctrl signal init success
[ 2.087737] <5>sama5d3_gpio_leds_probe(577): sama5d3 led driver probe led6 OK
[ 2.088347] <5>sama5d3_gpio_leds_probe(499): led7_gpio0 ctrl signal init success
[ 2.088871] <5>sama5d3_gpio_leds_probe(526): led7_gpio1 ctrl signal init success
[ 2.089315] <5>sama5d3_gpio_leds_probe(577): sama5d3 led driver probe led7 OK
[ 2.089890] usbcore: registered new interface driver usbhid
[ 2.089912] usbhid: USB HID core driver
[ 2.092923] <5>mcp47feb01_probe(218): MCP47FEB01C DAC chip init successfully.
[ 2.095692] bt-sco bt-sco: register codec ok
[ 2.096381] tlv320aic32x4 1-0018: aic32x4_i2c_probe(27): probe
[ 2.096583] <5>tlvaic32x4_probe(1325): tlvaic32x4 probe OK
[ 2.120032] mmc0: new high speed SDIO card at address 0001
[ 2.135421] <5>aic32x4_probe(1154): probe OK
[ 2.135537] tlv320aic32x4 1-0018: ASoC: no sink widget found for HPR Power
[ 2.135569] tlv320aic32x4 1-0018: ASoC: Failed to add route Left DAC route to HPR -> direct -> HPR Power
[ 2.135593] tlv320aic32x4 1-0018: ASoC: no source widget found for HPR Power
[ 2.135616] tlv320aic32x4 1-0018: ASoC: Failed to add route HPR Power -> direct -> HPR
[ 2.135638] tlv320aic32x4 1-0018: ASoC: no source widget found for Mic
[ 2.135660] tlv320aic32x4 1-0018: ASoC: Failed to add route Mic -> direct -> Mic Bias
[ 2.137683] atmel-tlv320aic32x4-audio sound: tlv320aic32x4-i2s <-> f800c000.ssc.1 mapping ok
[ 2.139543] <5>atmel_asoc_tlv320aic32x4_probe(570): atmel asco tlv320aic32x4 probe Ok
[ 2.142314] atmel-bluetooth-audio bluetooth_sound: bt-sco-pcm <-> f0008000.ssc.0 mapping ok
[ 2.144936] atmel-bluetooth-audio bluetooth_sound: ALSA resigster dummy bluetooth codec OK
[ 2.145674] NET: Registered protocol family 17
[ 2.145846] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.146597] Bluetooth: RFCOMM TTY layer initialized
[ 2.146657] Bluetooth: RFCOMM socket layer initialized
[ 2.146676] Bluetooth: RFCOMM ver 1.11
[ 2.146719] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.146737] Bluetooth: BNEP filters: protocol multicast
[ 2.146766] Bluetooth: BNEP socket layer initialized
[ 2.146797] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.146825] Bluetooth: HIDP socket layer initialized
[ 2.146854] lib80211: common routines for IEEE802.11 drivers
[ 2.146871] lib80211_crypt: registered algorithm 'NULL'
[ 2.146900] lib80211_crypt: registered algorithm 'WEP'
[ 2.146928] lib80211_crypt: registered algorithm 'CCMP'
[ 2.146955] lib80211_crypt: registered algorithm 'TKIP'
[ 2.154283] <5>sama5d3_oledfb_of_init(2150): of_init: oled_cs = 1, OLED_CS_BASE got 0x40000000
[ 2.154410] <5>sama5d3_oledfb_of_init(2164): of_init: oled_data_phy_addr = 0x40004000
[ 2.154458] <5>sama5d3_oledfb_of_init(2176): of_init: SMC_BASE_ADDR got 0xFFFFC614
[ 2.154635] <5>sama5d3_oledfb_of_init(2206): of_infi: select band_width (8 bit)
[ 2.154678] <5>sama5d3_oledfb_of_init(2212): of_init: has dma
[ 2.154716] [uni_register_pm_check_unit(153)]: register oled_not_in_sleep, func = 0xc01d0774
[ 2.156126] <5>set_dma_config(953): oled using dma0chan6 for DMA transfer
[ 2.156517] <5>get_ft2308_id(294): Expected OLED id is 0x01,0x02,0x00
[ 2.156565] <5>get_ft2308_id(295): Get OLED ID1~DI3: 0xda,0xdb,0xdc
[ 2.189820] ubi0: default fastmap pool size: 195
[ 2.189849] ubi0: default fastmap WL pool size: 97
[ 2.189865] ubi0: attaching mtd3
[ 2.312533] g_multi gadget: full-speed config #1: Multifunction with RNDIS
[ 2.734519] ubi0: attached by fastmap
[ 2.734549] ubi0: fastmap pool size: 195
[ 2.734562] ubi0: fastmap WL pool size: 97
[ 2.753987] ubi0: attached mtd3 (name "user-fs", size 987 MiB)
[ 2.754018] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
[ 2.754035] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
[ 2.754050] ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
[ 2.754064] ubi0: good PEBs: 3946, bad PEBs: 4, corrupted PEBs: 0
[ 2.754078] ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
[ 2.754096] ubi0: max/mean erase counter: 214/116, WL threshold: 4096, image sequence number: 1635931764
[ 2.754110] ubi0: available PEBs: 0, total reserved PEBs: 3946, PEBs reserved for bad PEB handling: 76
[ 2.754858] [uni_register_pm_check_unit(153)]: register power_knob, func = 0xc02b73d4
[ 2.754896] <5>aux_register_key(94): not AUX key, PASS
[ 2.755003] <5>aux_register_key(94): not AUX key, PASS
[ 2.755105] <5>aux_register_key(100): get key: aux_eptt_key.
[ 2.755203] <5>aux_register_key(100): get key: aux_ignition_key.
[ 2.755297] gpio key driver probe [ OK ]
[ 2.755725] at91_rtc fffffeb0.rtc: setting system clock to 2007-01-01 00:00:06 UTC (1167609606)
[ 2.757268] /ltc4020: could not get #io-channel-cells for /ahb/apb/adc@f8018000
[ 2.757303] ERROR: could not get IIO channel /ltc4020:vbat-sense(0)
[ 2.757331] <3>ltc4020_iio_chn_init(343): find vbat-sense in dts failed.
[ 2.757366] <3>ltc4020_probe(1255): ltc4020 iio chn init failed.
[ 2.757778] ubi0: background thread "ubi_bgt0d" started, PID 658
[ 2.763788] ltc4020: probe of ltc4020 failed with error -1
[ 2.764889] <5>fan_probe(403): fan level table :
[ 2.764936] <5>fan_probe(408): fan rotate level : 0, fan pwr en state : 0, dac0 reg val : 0x64.
[ 2.764980] <5>fan_probe(408): fan rotate level : 1, fan pwr en state : 1, dac0 reg val : 0x64.
[ 2.765022] <5>fan_probe(408): fan rotate level : 2, fan pwr en state : 1, dac0 reg val : 0x55.
[ 2.765063] <5>fan_probe(408): fan rotate level : 3, fan pwr en state : 1, dac0 reg val : 0x46.
[ 2.765103] <5>fan_probe(408): fan rotate level : 4, fan pwr en state : 1, dac0 reg val : 0x3d.
[ 2.765289] <5>fan_probe(436): fan driver init successfully.
[ 2.765542] clk: Not disabling unused clocks
[ 2.765581] ALSA device list:
[ 2.765598] #0: tlv320aic3204 @ SAMA5D3
[ 2.765611] #1: bluetooth audio @ SAMA5D3
[ 2.765808] Warning: unable to open an initial console.
[ 2.832155] UBIFS (ubi0:1): recovery needed
[ 3.154783] UBIFS (ubi0:1): recovery deferred
[ 3.154823] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "rootfs", R/O mode
[ 3.154846] UBIFS (ubi0:1): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 3.154868] UBIFS (ubi0:1): FS size: 64757760 bytes (61 MiB, 255 LEBs), journal size 9142272 bytes (8 MiB, 36 LEBs)
[ 3.154883] UBIFS (ubi0:1): reserved for root: 0 bytes (0 KiB)
[ 3.154911] UBIFS (ubi0:1): media format: w4/r0 (latest is w4/r0), UUID 1BACF5C4-B91E-47B4-ACA8-82F0D21AEE55, small LPT model
[ 3.157150] VFS: Mounted root (ubifs filesystem) readonly on device 0:12.
[ 3.157697] Freeing unused kernel memory: 180K (c05f3000 - c0620000)
[ 3.471780] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "calibration", R/O mode
[ 3.471821] UBIFS (ubi0:0): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 3.471847] UBIFS (ubi0:0): FS size: 22855680 bytes (21 MiB, 90 LEBs), journal size 3809280 bytes (3 MiB, 15 LEBs)
[ 3.471864] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
[ 3.471890] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 8C0A841D-9F6D-4F4B-A47B-242F17AF30D2, small LPT model
[ 3.514476] random: nonblocking pool is initialized
[ 3.634316] UBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name "qpe", R/O mode
[ 3.634356] UBIFS (ubi0:2): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 3.634381] UBIFS (ubi0:2): FS size: 131801088 bytes (125 MiB, 519 LEBs), journal size 9404416 bytes (8 MiB, 38 LEBs)
[ 3.634397] UBIFS (ubi0:2): reserved for root: 0 bytes (0 KiB)
[ 3.634424] UBIFS (ubi0:2): media format: w4/r0 (latest is w4/r0), UUID E83FECA1-27DE-4703-B7D8-CB5079BD58DE, small LPT model
[ 3.761127] UBIFS (ubi0:3): UBIFS: mounted UBI device 0, volume 3, name "defpara", R/O mode
[ 3.761166] UBIFS (ubi0:3): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 3.761190] UBIFS (ubi0:3): FS size: 18538496 bytes (17 MiB, 73 LEBs), journal size 3301376 bytes (3 MiB, 13 LEBs)
[ 3.761206] UBIFS (ubi0:3): reserved for root: 0 bytes (0 KiB)
[ 3.761232] UBIFS (ubi0:3): media format: w4/r0 (latest is w4/r0), UUID A7AE1FB4-18F3-456E-B406-88BF6D1EB1A0, small LPT model
[ 3.870579] UBIFS (ubi0:4): UBIFS: mounted UBI device 0, volume 4, name "otapara", R/O mode
[ 3.870616] UBIFS (ubi0:4): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 3.870639] UBIFS (ubi0:4): FS size: 18538496 bytes (17 MiB, 73 LEBs), journal size 3301376 bytes (3 MiB, 13 LEBs)
[ 3.870654] UBIFS (ubi0:4): reserved for root: 0 bytes (0 KiB)
[ 3.870680] UBIFS (ubi0:4): media format: w4/r0 (latest is w4/r0), UUID 2BAEEFB9-96BE-4423-B712-4BB6807A7EBE, small LPT model
[ 3.892982] UBIFS (ubi0:7): background thread "ubifs_bgt0_7" started, PID 677
[ 3.950282] UBIFS (ubi0:7): recovery needed
[ 4.132101] UBIFS (ubi0:7): recovery completed
[ 4.132143] UBIFS (ubi0:7): UBIFS: mounted UBI device 0, volume 7, name "userdata"
[ 4.132166] UBIFS (ubi0:7): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 4.132191] UBIFS (ubi0:7): FS size: 520855552 bytes (496 MiB, 2051 LEBs), journal size 9404416 bytes (8 MiB, 38 LEBs)
[ 4.132207] UBIFS (ubi0:7): reserved for root: 0 bytes (0 KiB)
[ 4.132235] UBIFS (ubi0:7): media format: w4/r0 (latest is w4/r0), UUID E88A1FD7-4C14-4993-BB64-B06940D639FD, small LPT model
[ 4.138639] UBIFS (ubi0:5): background thread "ubifs_bgt0_5" started, PID 686
[ 4.205510] UBIFS (ubi0:5): recovery needed
[ 4.272093] UBIFS (ubi0:5): recovery completed
[ 4.272135] UBIFS (ubi0:5): UBIFS: mounted UBI device 0, volume 5, name "runpara"
[ 4.272158] UBIFS (ubi0:5): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 4.272180] UBIFS (ubi0:5): FS size: 18538496 bytes (17 MiB, 73 LEBs), journal size 3301376 bytes (3 MiB, 13 LEBs)
[ 4.272195] UBIFS (ubi0:5): reserved for root: 0 bytes (0 KiB)
[ 4.272223] UBIFS (ubi0:5): media format: w4/r0 (latest is w4/r0), UUID 20E891E0-AAB5-43B6-9068-CAEE4CCFA6B4, small LPT model
[ 4.283106] UBIFS (ubi0:6): background thread "ubifs_bgt0_6" started, PID 689
[ 4.333357] UBIFS (ubi0:6): recovery needed
[ 4.498782] UBIFS (ubi0:6): recovery completed
[ 4.498825] UBIFS (ubi0:6): UBIFS: mounted UBI device 0, volume 6, name "log"
[ 4.498848] UBIFS (ubi0:6): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 4.498870] UBIFS (ubi0:6): FS size: 31236096 bytes (29 MiB, 123 LEBs), journal size 4825088 bytes (4 MiB, 19 LEBs)
[ 4.498885] UBIFS (ubi0:6): reserved for root: 0 bytes (0 KiB)
[ 4.498912] UBIFS (ubi0:6): media format: w4/r0 (latest is w4/r0), UUID B53E2A40-EB64-4248-9C15-A08B82484E92, small LPT model
[ 4.683284] <5>at91_wdt_start(313): sama5d3 watchdog : mcu watchdog disabled, can not start.
[ 5.620927] UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 732
[ 5.816472] UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "update"
[ 5.816514] UBIFS (ubi0:8): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 5.816541] UBIFS (ubi0:8): FS size: 130785280 bytes (124 MiB, 515 LEBs), journal size 6602752 bytes (6 MiB, 26 LEBs)
[ 5.816557] UBIFS (ubi0:8): reserved for root: 4952683 bytes (4836 KiB)
[ 5.816584] UBIFS (ubi0:8): media format: w4/r0 (latest is w4/r0), UUID 9C8DF7E6-05DA-4D41-A3C5-0029C4D16B41, small LPT model
[ 5.954423] UBIFS (ubi0:8): un-mount UBI device 0
[ 5.954498] UBIFS (ubi0:8): background thread "ubifs_bgt0_8" stops
[ 106.889343] wlan: Loading MWLAN driver
[ 106.893826] wlan: Register to Bus Driver...
[ 106.957922] vendor=0x0471 device=0x0205 class=0 function=1
[ 106.958180] Attach moal handle ops, card interface type: 0x109
[ 106.958223] No module param cfg file specified
[ 106.958246] combo fw:nxp/sduart_nw61x.bin.se wlan fw:nxp/sd_w61x.bin.se
[ 106.958290] SDIO: sdio_blk_size=256 max_blk_count=512 max_segs=64 max_seg_size=4096
[ 106.958304] rx_work=0 cpu_num=1
[ 106.958324] Enable moal_recv_amsdu_packet
[ 106.958422] Attach mlan adapter operations.card_type is 0x109.
[ 106.959647] wlan: Enable TX SG mode
[ 106.959677] wlan: mpa_tx.buf_size=4096
[ 106.959689] wlan: Enable RX SG mode
[ 106.959700] wlan: mpa_rx.buf_size=4096
[ 106.965857] Request firmware: nxp/sd_w61x_v1.bin.se
[ 107.096406] Wakeup device...
[ 107.344529] Wlan: FW download over, firmwarelen=681308 downloaded 565508
[ 107.742950] WLAN FW is active
[ 107.742992] on_time is 107730209917
[ 107.743440] QUEUE_CMD: FUNC_INIT [0xa9] is queued
[ 107.743473] QUEUE_CMD: GET_HW_SPEC [0x3] is queued
[ 107.743517] DNLD_CMD (107.730716): FUNC_INIT [0xa9], act 0x263, len 16, seqno 0x1 timeout 5000
[ 107.766158] CMD_RESP (107.753332): FUNC_INIT [0x80a9], result 0, len 16, seqno 0x1
[ 107.766220] DNLD_CMD (107.753417): GET_HW_SPEC [0x3], act 0x0, len 71, seqno 0x2 timeout 5000
[ 107.766565] 107.753753 : Event: VDLL_IND [0x81]
[ 107.766612] VDLL_IND (OFFSET): offset=0x1c458
[ 107.767544] VDLL image: len=115800
[ 107.767850] CMD_RESP (107.755035): GET_HW_SPEC [0x8003], result 0, len 205, seqno 0x2
[ 107.767880] fw_cap_info=0x487cff03, dev_cap_mask=0xffffffff
[ 107.767897] GET_HW_SPEC: country_code=0x0
[ 107.767909] num_ant=1, antinfo=0x0
[ 107.767923] GET_HW_SPEC: hw_mpdu_density=4 dev_mcs_support=0x11
[ 107.767934] Enable Beamforming
[ 107.767950] GET_HW_SPEC: mgmt IE count=13
[ 107.767965] FW: SDIO rx aggr disabled 0x487cff03
[ 107.767981] pmadapter->ecsa_enable=1
[ 107.768016] QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 107.768030] pmadapter->getlog_enable=1
[ 107.768052] chanrpt api ver=14.1
[ 107.768067] fw_cap_info=0x487cff03 fw_cap_ext=0x2182b5
[ 107.768082] uuid: c10d697cf87d596cab35c831392df315
[ 107.768093] fw hotfix ver=11
[ 107.768105] fw ver=15.1
[ 107.768116] uap fw ver=2.0
[ 107.768127] max_p2p_conn = 8, max_sta_conn = 16
[ 107.768145] wlan_set_regiontable: 2.4G 0x10
[ 107.768166] wlan_set_regiontable: 5G 0x10
[ 107.768202] Get Hw Spec done, fw_cap=0x487cff03
[ 107.768231] org_drv_mode=0x7 drv_mode=0x7
[ 107.768815] Enable Beamforming
[ 107.768873] QUEUE_CMD: 802_11_FW_WAKE_METHOD [0x74] is queued
[ 107.768901] set tx_buf = 4096
[ 107.768922] QUEUE_CMD: RECONFIGURE_TX_BUFF [0xd9] is queued
[ 107.768949] PS Command: action = 0x6, bitmap = 0x1
[ 107.768969] QUEUE_CMD: 802_11_PS_MODE_ENH [0xe4] is queued
[ 107.768999] QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 107.769028] QUEUE_CMD: 802_11_RF_ANTENNA [0x20] is queued
[ 107.769060] QUEUE_CMD: CHAN_REGION_CFG [0x242] is queued
[ 107.769091] QUEUE_CMD: TX_RATE_CFG [0xd6] is queued
[ 107.769118] QUEUE_CMD: 802_11_RF_TX_POWER [0x1e] is queued
[ 107.769146] QUEUE_CMD: AMSDU_AGGR_CTRL [0xdf] is queued
[ 107.769174] QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 107.769216] DNLD_CMD (107.756415): 802_11_SNMP_MIB [0x16], act 0x1, len 15, seqno 0x3 timeout 5000
[ 107.769607] CMD_RESP (107.756793): 802_11_SNMP_MIB [0x8016], result 0, len 15, seqno 0x3
[ 107.769662] DNLD_CMD (107.756860): 802_11_FW_WAKE_METHOD [0x74], act 0x0, len 12, seqno 0x4 timeout 5000
[ 107.769996] CMD_RESP (107.757182): 802_11_FW_WAKE_METHOD [0x8074], result 0, len 18, seqno 0x4
[ 107.770023] FW wakeup method=1, gpio=0
[ 107.770063] DNLD_CMD (107.757261): RECONFIGURE_TX_BUFF [0xd9], act 0x1, len 16, seqno 0x5 timeout 5000
[ 107.771157] CMD_RESP (107.758341): RECONFIGURE_TX_BUFF [0x80d9], result 0, len 16, seqno 0x5
[ 107.771188] end port 32, data port mask ffffffff
[ 107.771204] max_tx_buf_size=4096, tx_buf_size=3328
[ 107.771246] DNLD_CMD (107.758444): 802_11_PS_MODE_ENH [0xe4], act 0x6, len 20, seqno 0x6 timeout 5000
[ 107.771595] CMD_RESP (107.758781): 802_11_PS_MODE_ENH [0x80e4], result 0, len 20, seqno 0x6
[ 107.771644] DNLD_CMD (107.758844): 802_11_SNMP_MIB [0x16], act 0x1, len 18, seqno 0x7 timeout 5000
[ 107.771973] CMD_RESP (107.759162): 802_11_SNMP_MIB [0x8016], result 0, len 18, seqno 0x7
[ 107.772022] DNLD_CMD (107.759222): 802_11_RF_ANTENNA [0x20], act 0xc, len 16, seqno 0x8 timeout 5000
[ 107.772352] CMD_RESP (107.759539): 802_11_RF_ANTENNA [0x8020], result 0, len 16, seqno 0x8
[ 107.772407] DNLD_CMD (107.759602): CHAN_REGION_CFG [0x242], act 0x0, len 11, seqno 0x9 timeout 5000
[ 107.773717] CMD_RESP (107.760894): CHAN_REGION_CFG [0x8242], result 0, len 1297, seqno 0x9
[ 107.773819] DNLD_CMD (107.761014): TX_RATE_CFG [0xd6], act 0x0, len 76, seqno 0xa timeout 5000
[ 107.774478] CMD_RESP (107.761658): TX_RATE_CFG [0x80d6], result 0, len 832, seqno 0xa
[ 107.774538] DNLD_CMD (107.761736): 802_11_RF_TX_POWER [0x1e], act 0x0, len 14, seqno 0xb timeout 5000
[ 107.774893] CMD_RESP (107.762080): 802_11_RF_TX_POWER [0x801e], result 0, len 14, seqno 0xb
[ 107.774946] DNLD_CMD (107.762143): AMSDU_AGGR_CTRL [0xdf], act 0x1, len 14, seqno 0xc timeout 5000
[ 107.775283] CMD_RESP (107.762469): AMSDU_AGGR_CTRL [0x80df], result 0, len 14, seqno 0xc
[ 107.775329] DNLD_CMD (107.762529): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0xd timeout 5000
[ 107.775658] CMD_RESP (107.762846): MAC_CONTROL [0x8028], result 0, len 12, seqno 0xd
[ 107.775711] QUEUE_CMD: APCMD_SYS_CONFIGURE [0xb0] is queued
[ 107.775749] DNLD_CMD (107.762949): APCMD_SYS_CONFIGURE [0xb0], act 0x0, len 20, seqno 0x100e timeout 5000
[ 107.776811] CMD_RESP (107.763986): APCMD_SYS_CONFIGURE [0x80b0], result 0, len 20, seqno 0x100e
[ 107.776874] QUEUE_CMD: TX_RATE_CFG [0xd6] is queued
[ 107.776907] QUEUE_CMD: 802_11_RF_TX_POWER [0x1e] is queued
[ 107.776937] QUEUE_CMD: AMSDU_AGGR_CTRL [0xdf] is queued
[ 107.776966] QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 107.776994] QUEUE_CMD: 802_11_MAC_ADDRESS [0x4d] is queued
[ 107.777031] DNLD_CMD (107.764231): TX_RATE_CFG [0xd6], act 0x0, len 76, seqno 0x200f timeout 5000
[ 107.781332] CMD_RESP (107.768504): TX_RATE_CFG [0x80d6], result 0, len 832, seqno 0x200f
[ 107.781397] DNLD_CMD (107.768592): 802_11_RF_TX_POWER [0x1e], act 0x0, len 14, seqno 0x2010 timeout 5000
[ 107.781772] CMD_RESP (107.768958): 802_11_RF_TX_POWER [0x801e], result 0, len 14, seqno 0x2010
[ 107.781826] DNLD_CMD (107.769023): AMSDU_AGGR_CTRL [0xdf], act 0x1, len 14, seqno 0x2011 timeout 5000
[ 107.782166] CMD_RESP (107.769351): AMSDU_AGGR_CTRL [0x80df], result 0, len 14, seqno 0x2011
[ 107.782215] DNLD_CMD (107.769414): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0x2012 timeout 5000
[ 107.782555] CMD_RESP (107.769741): MAC_CONTROL [0x8028], result 0, len 12, seqno 0x2012
[ 107.782608] DNLD_CMD (107.769805): 802_11_MAC_ADDRESS [0x4d], act 0x0, len 16, seqno 0x2013 timeout 5000
[ 107.783021] CMD_RESP (107.770204): 802_11_MAC_ADDRESS [0x804d], result 0, len 16, seqno 0x2013
[ 107.783082] QUEUE_CMD: WMM_PARAM_CONFIG [0x23a] is queued
[ 107.783132] DNLD_CMD (107.770330): WMM_PARAM_CONFIG [0x23a], act 0x2, len 26, seqno 0x14 timeout 5000
[ 107.783476] CMD_RESP (107.770660): WMM_PARAM_CONFIG [0x823a], result 0, len 26, seqno 0x14
[ 107.784828] Set wiphy max_ap_assoc_sta=8
[ 107.784919] max_rate=390M
[ 107.784934] max_rate=390M
[ 107.784952] vht_cap=0x33d07030 rx_mcs_map=0xfffe rx_max=0x186 tx_mcs_map=0xfffe tx_max=0x186
[ 107.784970] max_rate=390M
[ 107.784980] max_rate=390M
[ 107.784996] vht_cap=0x33d07030 rx_mcs_map=0xfffe rx_max=0x186 tx_mcs_map=0xfffe tx_max=0x186
[ 107.785031] wlan%d: QUEUE_CMD: 802_11_RF_ANTENNA [0x20] is queued
[ 107.789721] wlan%d: DNLD_CMD (107.776929): 802_11_RF_ANTENNA [0x20], act 0xc, len 16, seqno 0x15 timeout 5000
[ 107.790230] wlan%d: CMD_RESP (107.777434): 802_11_RF_ANTENNA [0x8020], result 0, len 16, seqno 0x15
[ 107.790404] wlan%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 107.790479] wlan%d: DNLD_CMD (107.777692): 802_11_SNMP_MIB [0x16], act 0x0, len 142, seqno 0x16 timeout 5000
[ 107.790921] wlan%d: CMD_RESP (107.778126): 802_11_SNMP_MIB [0x8016], result 0, len 142, seqno 0x16
[ 107.791073] wlan%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 107.791142] wlan%d: DNLD_CMD (107.778356): 802_11_SNMP_MIB [0x16], act 0x0, len 142, seqno 0x17 timeout 5000
[ 107.791587] wlan%d: CMD_RESP (107.778791): 802_11_SNMP_MIB [0x8016], result 0, len 142, seqno 0x17
[ 107.791740] wlan%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 107.791812] wlan%d: DNLD_CMD (107.779024): 802_11_SNMP_MIB [0x16], act 0x0, len 142, seqno 0x18 timeout 5000
[ 107.792245] wlan%d: CMD_RESP (107.779451): 802_11_SNMP_MIB [0x8016], result 0, len 142, seqno 0x18
[ 107.792781] cfg80211 regulatory domain callback 00 initiator=0 dfs_region=0
[ 107.792933] Regulatory domain BY_CORE
[ 107.793004] wlan%d: QUEUE_CMD: 802_11_RF_ANTENNA [0x20] is queued
[ 107.793250] wlan%d: DNLD_CMD (107.780459): 802_11_RF_ANTENNA [0x20], act 0xc, len 16, seqno 0x19 timeout 5000
[ 107.793746] wlan%d: CMD_RESP (107.780950): 802_11_RF_ANTENNA [0x8020], result 0, len 16, seqno 0x19
[ 107.794103] PS Command: action = 0x0, bitmap = 0x0
[ 107.794134] wlan%d: QUEUE_CMD: 802_11_PS_MODE_ENH [0xe4] is queued
[ 107.794212] wlan%d: DNLD_CMD (107.781424): 802_11_PS_MODE_ENH [0xe4], act 0x0, len 12, seqno 0x1a timeout 5000
[ 107.794667] wlan%d: CMD_RESP (107.781872): 802_11_PS_MODE_ENH [0x80e4], result 0, len 68, seqno 0x1a
[ 107.794721] ps_bitmap=0x0
[ 107.794847] CFG80211: Country=00, band=0, no_of_sub_band=1
[ 107.794888] wlan%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 107.794943] 11D:Country=WW band=0 sub-band=1 dfs_region=0
[ 107.794960] 11D: first chan=1 no_of_chan=14, max_tx_pwr=20
[ 107.794976] wlan%d: QUEUE_CMD: 802_11D_DOMAIN_INFO [0x5b] is queued
[ 107.795005] wlan_set_regiontable: 2.4G 0x0
[ 107.795030] wlan_set_regiontable: 5G 0x0
[ 107.795106] wlan%d: DNLD_CMD (107.782316): 802_11_SNMP_MIB [0x16], act 0x1, len 16, seqno 0x1b timeout 5000
[ 107.795546] wlan%d: CMD_RESP (107.782751): 802_11_SNMP_MIB [0x8016], result 0, len 16, seqno 0x1b
[ 107.795609] wlan%d: DNLD_CMD (107.782821): 802_11D_DOMAIN_INFO [0x5b], act 0x1, len 32, seqno 0x1c timeout 5000
[ 107.796041] wlan%d: 107.783248 : Event: VDLL_IND [0x81]
[ 107.796108] VDLL_IND: type=0 ID=23 offset = 0xe808 len = 600
[ 107.796136] wlan%d: DNLD_VDLL : block_len=600
[ 107.814067] wlan%d: 107.801266 : Event: VDLL_IND [0x81]
[ 107.814148] VDLL_IND: type=0 ID=23 offset = 0xea60 len = 600
[ 107.814175] wlan%d: DNLD_VDLL : block_len=600
[ 107.814855] wlan%d: 107.802058 : Event: VDLL_IND [0x81]
[ 107.814929] VDLL_IND: type=0 ID=23 offset = 0xecb8 len = 600
[ 107.814956] wlan%d: DNLD_VDLL : block_len=600
[ 107.815552] wlan%d: 107.802757 : Event: VDLL_IND [0x81]
[ 107.815622] VDLL_IND: type=0 ID=23 offset = 0xef10 len = 600
[ 107.815648] wlan%d: DNLD_VDLL : block_len=600
[ 107.816282] wlan%d: 107.803486 : Event: VDLL_IND [0x81]
[ 107.816354] VDLL_IND: type=0 ID=23 offset = 0xf168 len = 600
[ 107.816381] wlan%d: DNLD_VDLL : block_len=600
[ 107.817006] wlan%d: 107.804210 : Event: VDLL_IND [0x81]
[ 107.817078] VDLL_IND: type=0 ID=23 offset = 0xf3c0 len = 600
[ 107.817104] wlan%d: DNLD_VDLL : block_len=600
[ 107.817661] wlan%d: 107.804863 : Event: VDLL_IND [0x81]
[ 107.817734] VDLL_IND: type=0 ID=23 offset = 0xf618 len = 600
[ 107.817764] wlan%d: DNLD_VDLL : block_len=600
[ 107.818332] wlan%d: 107.805535 : Event: VDLL_IND [0x81]
[ 107.818407] VDLL_IND: type=0 ID=23 offset = 0xf870 len = 600
[ 107.818434] wlan%d: DNLD_VDLL : block_len=600
[ 107.818999] wlan%d: 107.806202 : Event: VDLL_IND [0x81]
[ 107.819071] VDLL_IND: type=0 ID=23 offset = 0xfac8 len = 600
[ 107.819097] wlan%d: DNLD_VDLL : block_len=600
[ 107.833214] wlan%d: 107.820414 : Event: VDLL_IND [0x81]
[ 107.833298] VDLL_IND: type=0 ID=18 offset = 0xc4e0 len = 600
[ 107.833326] wlan%d: DNLD_VDLL : block_len=600
[ 107.851074] wlan%d: 107.838275 : Event: VDLL_IND [0x81]
[ 107.851152] VDLL_IND: type=0 ID=18 offset = 0xc738 len = 600
[ 107.851180] wlan%d: DNLD_VDLL : block_len=600
[ 107.851793] wlan%d: 107.838999 : Event: VDLL_IND [0x81]
[ 107.851865] VDLL_IND: type=0 ID=18 offset = 0xc990 len = 600
[ 107.851892] wlan%d: DNLD_VDLL : block_len=600
[ 107.852417] wlan%d: 107.839623 : Event: VDLL_IND [0x81]
[ 107.852488] VDLL_IND: type=0 ID=18 offset = 0xcbe8 len = 600
[ 107.852514] wlan%d: DNLD_VDLL : block_len=600
[ 107.853067] wlan%d: 107.840270 : Event: VDLL_IND [0x81]
[ 107.853139] VDLL_IND: type=0 ID=18 offset = 0xce40 len = 600
[ 107.853165] wlan%d: DNLD_VDLL : block_len=600
[ 107.853917] wlan%d: CMD_RESP (107.841120): 802_11D_DOMAIN_INFO [0x805b], result 0, len 32, seqno 0x1c
[ 107.854070] CFG80211: Country=00, band=1, no_of_sub_band=25
[ 107.854131] 11D:Country=WW band=1 sub-band=25 dfs_region=0
[ 107.854147] 11D: first chan=36 no_of_chan=1, max_tx_pwr=20
[ 107.854160] 11D: first chan=40 no_of_chan=1, max_tx_pwr=20
[ 107.854171] 11D: first chan=44 no_of_chan=1, max_tx_pwr=20
[ 107.854182] 11D: first chan=48 no_of_chan=1, max_tx_pwr=20
[ 107.854193] 11D: first chan=52 no_of_chan=1, max_tx_pwr=20
[ 107.854205] 11D: first chan=56 no_of_chan=1, max_tx_pwr=20
[ 107.854216] 11D: first chan=60 no_of_chan=1, max_tx_pwr=20
[ 107.854228] 11D: first chan=64 no_of_chan=1, max_tx_pwr=20
[ 107.854239] 11D: first chan=100 no_of_chan=1, max_tx_pwr=20
[ 107.854251] 11D: first chan=104 no_of_chan=1, max_tx_pwr=20
[ 107.854263] 11D: first chan=108 no_of_chan=1, max_tx_pwr=20
[ 107.854275] 11D: first chan=112 no_of_chan=1, max_tx_pwr=20
[ 107.854286] 11D: first chan=116 no_of_chan=1, max_tx_pwr=20
[ 107.854298] 11D: first chan=120 no_of_chan=1, max_tx_pwr=20
[ 107.854310] 11D: first chan=124 no_of_chan=1, max_tx_pwr=20
[ 107.854322] 11D: first chan=128 no_of_chan=1, max_tx_pwr=20
[ 107.854333] 11D: first chan=132 no_of_chan=1, max_tx_pwr=20
[ 107.854345] 11D: first chan=136 no_of_chan=1, max_tx_pwr=20
[ 107.854357] 11D: first chan=140 no_of_chan=1, max_tx_pwr=20
[ 107.854368] 11D: first chan=144 no_of_chan=1, max_tx_pwr=20
[ 107.854380] 11D: first chan=149 no_of_chan=1, max_tx_pwr=20
[ 107.854392] 11D: first chan=153 no_of_chan=1, max_tx_pwr=20
[ 107.854404] 11D: first chan=157 no_of_chan=1, max_tx_pwr=20
[ 107.854416] 11D: first chan=161 no_of_chan=1, max_tx_pwr=20
[ 107.854428] 11D: first chan=165 no_of_chan=1, max_tx_pwr=20
[ 107.854445] wlan%d: QUEUE_CMD: 802_11D_DOMAIN_INFO [0x5b] is queued
[ 107.854475] wlan_set_regiontable: 2.4G 0x0
[ 107.854495] wlan_set_regiontable: 5G 0x0
[ 107.854574] wlan%d: DNLD_CMD (107.841784): 802_11D_DOMAIN_INFO [0x5b], act 0x1, len 104, seqno 0x1d timeout 5000
[ 107.876156] wlan%d: CMD_RESP (107.863356): 802_11D_DOMAIN_INFO [0x805b], result 0, len 104, seqno 0x1d
[ 107.876808] Set wlan%d interface addr: 30:XX:XX:XX:8c:11
[ 107.876870] wlan%d: QUEUE_CMD: 802_11_MAC_ADDRESS [0x4d] is queued
[ 107.876956] wlan%d: DNLD_CMD (107.864168): 802_11_MAC_ADDRESS [0x4d], act 0x1, len 16, seqno 0x1e timeout 5000
[ 107.877442] wlan%d: CMD_RESP (107.864647): 802_11_MAC_ADDRESS [0x804d], result 0, len 16, seqno 0x1e
[ 107.879187] Register NXP 802.11 Adapter wlan0
[ 107.879583] uap%d: QUEUE_CMD: 11AX_CFG [0x266] is queued
[ 107.879698] wlan0 set multicast_list
[ 107.879738] wlan0: QUEUE_CMD: MAC_MULTICAST_ADR [0x10] is queued
[ 107.879772] wlan0: QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 107.892976] uap%d: DNLD_CMD (107.880175): 11AX_CFG [0x266], act 0x1, len 39, seqno 0x101f timeout 5000
[ 107.893507] wlan0: 107.880712 : Event: VDLL_IND [0x81]
[ 107.893585] VDLL_IND: type=0 ID=24 offset = 0xfd20 len = 600
[ 107.893614] wlan0: DNLD_VDLL : block_len=600
[ 107.911756] wlan0: 107.898955 : Event: VDLL_IND [0x81]
[ 107.911843] VDLL_IND: type=0 ID=24 offset = 0xff78 len = 600
[ 107.911872] wlan0: DNLD_VDLL : block_len=600
[ 107.912558] wlan0: 107.899762 : Event: VDLL_IND [0x81]
[ 107.912635] VDLL_IND: type=0 ID=24 offset = 0x101d0 len = 600
[ 107.912662] wlan0: DNLD_VDLL : block_len=600
[ 107.913268] wlan0: 107.900472 : Event: VDLL_IND [0x81]
[ 107.913341] VDLL_IND: type=0 ID=24 offset = 0x10428 len = 600
[ 107.913367] wlan0: DNLD_VDLL : block_len=600
[ 107.913915] wlan0: 107.901118 : Event: VDLL_IND [0x81]
[ 107.913988] VDLL_IND: type=0 ID=24 offset = 0x10680 len = 600
[ 107.914012] wlan0: DNLD_VDLL : block_len=600
[ 107.914567] wlan0: 107.901770 : Event: VDLL_IND [0x81]
[ 107.914645] VDLL_IND: type=0 ID=24 offset = 0x108d8 len = 600
[ 107.914672] wlan0: DNLD_VDLL : block_len=600
[ 107.915343] uap%d: CMD_RESP (107.902546): 11AX_CFG [0x8266], result 0, len 39, seqno 0x101f
[ 107.915409] user_2g_hecap_len=28
[ 107.915456] wlan0: DNLD_CMD (107.902667): MAC_MULTICAST_ADR [0x10], act 0x1, len 204, seqno 0x20 timeout 5000
[ 107.915901] wlan0: CMD_RESP (107.903108): MAC_MULTICAST_ADR [0x8010], result 0, len 204, seqno 0x20
[ 107.915958] wlan0: DNLD_CMD (107.903171): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0x21 timeout 5000
[ 107.916292] wlan0: CMD_RESP (107.903500): MAC_CONTROL [0x8028], result 0, len 12, seqno 0x21
[ 107.916457] uap%d: QUEUE_CMD: 11AX_CFG [0x266] is queued
[ 107.916542] uap%d: DNLD_CMD (107.903755): 11AX_CFG [0x266], act 0x1, len 39, seqno 0x1022 timeout 5000
[ 107.917004] uap%d: CMD_RESP (107.904210): 11AX_CFG [0x8266], result 0, len 39, seqno 0x1022
[ 107.917062] user_hecap_len=28
[ 107.925724] Set uap%d interface addr: 32:XX:XX:XX:8d:11
[ 107.925790] uap%d: QUEUE_CMD: APCMD_SYS_CONFIGURE [0xb0] is queued
[ 107.925886] uap%d: DNLD_CMD (107.913098): APCMD_SYS_CONFIGURE [0xb0], act 0x1, len 20, seqno 0x1023 timeout 5000
[ 107.926382] uap%d: CMD_RESP (107.913587): APCMD_SYS_CONFIGURE [0x80b0], result 0, len 20, seqno 0x1023
[ 107.928101] Register NXP 802.11 Adapter uap0
[ 107.928429] PS Command: action = 0x0, bitmap = 0x0
[ 107.928457] p2p%d: QUEUE_CMD: 802_11_PS_MODE_ENH [0xe4] is queued
[ 107.928543] uap0 set multicast_list
[ 107.929049] p2p%d: DNLD_CMD (107.916254): 802_11_PS_MODE_ENH [0xe4], act 0x0, len 12, seqno 0x2024 timeout 5000
[ 107.929566] p2p%d: CMD_RESP (107.916771): 802_11_PS_MODE_ENH [0x80e4], result 0, len 68, seqno 0x2024
[ 107.929623] ps_bitmap=0x0
[ 107.929729] CFG80211: Country=00, band=0, no_of_sub_band=1
[ 107.929770] p2p%d: QUEUE_CMD: 802_11_SNMP_MIB [0x16] is queued
[ 107.929823] 11D:Country=WW band=0 sub-band=1 dfs_region=0
[ 107.929840] 11D: first chan=1 no_of_chan=14, max_tx_pwr=20
[ 107.929856] p2p%d: QUEUE_CMD: 802_11D_DOMAIN_INFO [0x5b] is queued
[ 107.929885] wlan_set_regiontable: 2.4G 0x0
[ 107.929906] wlan_set_regiontable: 5G 0x0
[ 107.929995] p2p%d: DNLD_CMD (107.917205): 802_11_SNMP_MIB [0x16], act 0x1, len 16, seqno 0x2025 timeout 5000
[ 107.930461] p2p%d: CMD_RESP (107.917665): 802_11_SNMP_MIB [0x8016], result 0, len 16, seqno 0x2025
[ 107.930524] p2p%d: DNLD_CMD (107.917737): 802_11D_DOMAIN_INFO [0x5b], act 0x1, len 32, seqno 0x2026 timeout 5000
[ 107.952050] p2p%d: CMD_RESP (107.939248): 802_11D_DOMAIN_INFO [0x805b], result 0, len 32, seqno 0x2026
[ 107.952237] CFG80211: Country=00, band=1, no_of_sub_band=25
[ 107.952300] 11D:Country=WW band=1 sub-band=25 dfs_region=0
[ 107.952316] 11D: first chan=36 no_of_chan=1, max_tx_pwr=20
[ 107.952329] 11D: first chan=40 no_of_chan=1, max_tx_pwr=20
[ 107.952341] 11D: first chan=44 no_of_chan=1, max_tx_pwr=20
[ 107.952353] 11D: first chan=48 no_of_chan=1, max_tx_pwr=20
[ 107.952364] 11D: first chan=52 no_of_chan=1, max_tx_pwr=20
[ 107.952376] 11D: first chan=56 no_of_chan=1, max_tx_pwr=20
[ 107.952388] 11D: first chan=60 no_of_chan=1, max_tx_pwr=20
[ 107.952399] 11D: first chan=64 no_of_chan=1, max_tx_pwr=20
[ 107.952411] 11D: first chan=100 no_of_chan=1, max_tx_pwr=20
[ 107.952423] 11D: first chan=104 no_of_chan=1, max_tx_pwr=20
[ 107.952435] 11D: first chan=108 no_of_chan=1, max_tx_pwr=20
[ 107.952447] 11D: first chan=112 no_of_chan=1, max_tx_pwr=20
[ 107.952458] 11D: first chan=116 no_of_chan=1, max_tx_pwr=20
[ 107.952470] 11D: first chan=120 no_of_chan=1, max_tx_pwr=20
[ 107.952482] 11D: first chan=124 no_of_chan=1, max_tx_pwr=20
[ 107.952494] 11D: first chan=128 no_of_chan=1, max_tx_pwr=20
[ 107.952505] 11D: first chan=132 no_of_chan=1, max_tx_pwr=20
[ 107.952517] 11D: first chan=136 no_of_chan=1, max_tx_pwr=20
[ 107.952529] 11D: first chan=140 no_of_chan=1, max_tx_pwr=20
[ 107.952541] 11D: first chan=144 no_of_chan=1, max_tx_pwr=20
[ 107.952553] 11D: first chan=149 no_of_chan=1, max_tx_pwr=20
[ 107.952565] 11D: first chan=153 no_of_chan=1, max_tx_pwr=20
[ 107.952576] 11D: first chan=157 no_of_chan=1, max_tx_pwr=20
[ 107.952588] 11D: first chan=161 no_of_chan=1, max_tx_pwr=20
[ 107.952600] 11D: first chan=165 no_of_chan=1, max_tx_pwr=20
[ 107.952618] p2p%d: QUEUE_CMD: 802_11D_DOMAIN_INFO [0x5b] is queued
[ 107.952652] wlan_set_regiontable: 2.4G 0x0
[ 107.952673] wlan_set_regiontable: 5G 0x0
[ 107.952749] p2p%d: DNLD_CMD (107.939958): 802_11D_DOMAIN_INFO [0x5b], act 0x1, len 104, seqno 0x2027 timeout 5000
[ 107.974398] p2p%d: CMD_RESP (107.961599): 802_11D_DOMAIN_INFO [0x805b], result 0, len 104, seqno 0x2027
[ 107.975810] Set WFD device addr: 32:XX:XX:XX:8c:11
[ 107.975874] p2p%d: QUEUE_CMD: 802_11_MAC_ADDRESS [0x4d] is queued
[ 107.975962] p2p%d: DNLD_CMD (107.963174): 802_11_MAC_ADDRESS [0x4d], act 0x1, len 16, seqno 0x2028 timeout 5000
[ 107.976455] p2p%d: CMD_RESP (107.963659): 802_11_MAC_ADDRESS [0x804d], result 0, len 16, seqno 0x2028
[ 107.978205] Register NXP 802.11 Adapter p2p0
[ 107.978352] wlan: version = SDIW612---18.99.3.p26.11-MM6X18540.p17-(FP92)
[ 107.978415] wlan0: QUEUE_CMD: REG_ACCESS [0x27c] is queued
[ 107.979033] p2p0 set multicast_list
[ 107.979084] p2p0: QUEUE_CMD: MAC_MULTICAST_ADR [0x10] is queued
[ 107.979124] p2p0: QUEUE_CMD: MAC_CONTROL [0x28] is queued
[ 107.979189] wlan0: DNLD_CMD (107.966402): REG_ACCESS [0x27c], act 0x0, len 20, seqno 0x29 timeout 5000
[ 107.979694] wlan0: CMD_RESP (107.966899): REG_ACCESS [0x827c], result 0, len 20, seqno 0x29
[ 107.979776] p2p0: DNLD_CMD (107.966989): MAC_MULTICAST_ADR [0x10], act 0x1, len 204, seqno 0x202a timeout 5000
[ 107.980228] p2p0: CMD_RESP (107.967434): MAC_MULTICAST_ADR [0x8010], result 0, len 204, seqno 0x202a
[ 107.980285] p2p0: DNLD_CMD (107.967498): MAC_CONTROL [0x28], act 0x213, len 12, seqno 0x202b timeout 5000
[ 107.980607] p2p0: CMD_RESP (107.967814): MAC_CONTROL [0x8028], result 0, len 12, seqno 0x202b
[ 108.023067] Set REG 0x90002328: 0x13d57 slew_rate=3
[ 108.023135] wlan0: QUEUE_CMD: REG_ACCESS [0x27c] is queued
[ 108.023231] wlan0: DNLD_CMD (108.010442): REG_ACCESS [0x27c], act 0x1, len 20, seqno 0x2c timeout 5000
[ 108.023738] wlan0: CMD_RESP (108.010941): REG_ACCESS [0x827c], result 0, len 20, seqno 0x2c
[ 108.023925] wlan0: QUEUE_CMD: INDEPENDENT_RESET_CFG [0x243] is queued
[ 108.024006] wlan0: DNLD_CMD (108.011218): INDEPENDENT_RESET_CFG [0x243], act 0x0, len 12, seqno 0x2d timeout 5000
[ 108.024460] wlan0: CMD_RESP (108.011666): INDEPENDENT_RESET_CFG [0x8243], result 0, len 12, seqno 0x2d
[ 108.025121] wlan: Register to Bus Driver Done
[ 108.025146] wlan: Driver loaded successfully
log0326.txt
破坏者
(none) login:
(none) login: root
Password:
[root@br03 ~]# cd /userdata
[root@br03 /userdata]# rm dmesg0325
dmesg0325-1.txt dmesg0325-2.txt dmesg0325.txt
[root@br03 /userdata]# rm dmesg0325*
[root@br03 /userdata]# dmesg >dmesg0326-1.txt
[root@br03 /userdata]# insmod mlan.ko
[root@br03 /userdata]# insmod moal.ko drv_mode=7 ps_mode=2 auto_ds=2 host_mlme=1 cal_data_cfg=n
one fw_name=nxp/sd_w61x_v1.bin.se sta_name=wlan wfd_name=p2p cfg80211_wext=0xf drvdbg=0x80037
[root@br03 /userdata]# dmesg >dmesg0326-2.txt
[root@br03 /userdata]# ./w
wifi_mod_para.conf wpa_cli wpa_supplicant wpa_supplicant.conf
wlan.ko wpa_cli-old wpa_supplicant-old
[root@br03 /userdata]# ./wpa_supplicant
[root@br03 /userdata]# ls -lh wpa_*
-rwxr-xr-x 1 root 0 313.8K Jan 1 00:03 wpa_cli
-rwxr-xr-x 1 root 0 83.6K Jan 1 00:14 wpa_cli-old
-rwxr-xr-x 1 root 0 14.7M Jan 1 00:02 wpa_supplicant
-rwxr-xr-x 1 root 0 1.8M Jan 1 00:13 wpa_supplicant-old
-rw-r--r-- 1 root 0 281 Jan 1 2007 wpa_supplicant.conf
[root@br03 /userdata]# ./wpa_supplicant -B -Dnl80211 -iwlan0 -c /etc/wpa_supplicant.conf
Successfully initialized wpa_supplicant
rfkill: Cannot open RFKILL control device
[root@br03 /userdata]# ps|grep wpa
1358 root 0:00 ./wpa_supplicant -B -Dnl80211 -iwlan0 -c /etc/wpa_supplicant.conf
1372 root 0:00 grep wpa
[root@br03 /userdata]# ifconfig -a
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
p2p0 Link encap:Ethernet HWaddr 32:4A:C4:9E:8C:11
BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
uap0 Link encap:Ethernet HWaddr 32:4A:C4:9E:8D:11
usb0 Link encap:Ethernet HWaddr 12:56:59:21:22:05
inet addr:10.10.0.12 Bcast:0.0.0.0 Mask:255.255.0.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:740 errors:0 dropped:124 overruns:0 frame:0
TX packets:360 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:38831 (37.9 KiB) TX bytes:106517 (104.0 KiB)
wlan0 Link encap:Ethernet HWaddr 30:4A:C4:9E:8C:11
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:750 errors:0 dropped:124 overruns:0 frame:0
TX packets:367 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:39238 (38.3 KiB) TX bytes:109073 (106.5 KiB)
[root@br03 /userdata]# ./wpa_cli -i wlan0 -g/var/run/wpa_supplicant/wlan0 ap_scan 1
OK
[root@br03 /userdata]# ./wpa_cli -i wlan0 -g/var/run/wpa_supplicant/wlan0 scan
OK
[root@br03 /userdata]# wpa_cli -i wlan0 -g/var/run/wpa_supplicant/wlan0 scan_result
bssid / frequency / signal level / flags / ssid
[root@br03 /userdata]# dmesg > dmesg0326-3.txt
[root@br03 /userdata]# rm file_
file_drv_info file_fwdump
[root@br03 /userdata]# rm file_*
[root@br03 /userdata]# cp /var/
dump_332/ lib/ run/
[root@br03 /userdata]# cp /var/dump_332/file_
[root@br03 /userdata]# cp /var/dump_332/file_* ./
[root@br03 /userdata]# ./download.sh dmesg0326-1.txt
dmesg0326-1.txt 100% |************************************************************| 32427 0:00:00 ETA
-rw-r--r-- 1 root 0 31.7K Jan 1 00:01 dmesg0326-1.txt
[root@br03 /userdata]# ./download.sh dmesg0326-2.txt
dmesg0326-2.txt 100% |************************************************************| 55782 0:00:00 ETA
-rw-r--r-- 1 root 0 54.5K Jan 1 00:03 dmesg0326-2.txt
[root@br03 /userdata]# ./download.sh dmesg0326-3.txt
dmesg0326-3.txt 100% |************************************************************| 62694 0:00:00 ETA
-rw-r--r-- 1 root 0 61.2K Jan 1 00:06 dmesg0326-3.txt
[root@br03 /userdata]# ./download.sh file_fwdump
file_fwdump 100% |************************************************************| 1375k 0:00:00 ETA
-rw-r--r-- 1 root 0 1.3M Jan 1 00:06 file_fwdump
[root@br03 /userdata]# ./download.sh file_drv_info
file_drv_info 100% |************************************************************| 411k 0:00:00 ETA
-rw-r--r-- 1 root 0 411.3K Jan 1 00:06 file_drv_info
1,459 次查看
eric25
I can upload the attachment now.
1,518 次查看
eric25
I check the vervion, it's wpa_supplicant v2.11
[root@br03 ~]# wpa_supplicant -v
wpa_supplicant v2.11-devel-hostap_2_10-386-gb859b9bce
Copyright (c) 2003-2022, Jouni Malinen <j@w1.fi> and contributors
[root@br03 ~]#
[root@br03 ~]# wpa
wpa.conf wpa_cli wpa_supplicant
[root@br03 ~]# wpa
[root@br03 ~]# wpa_cli
wpa_cli v2.11-devel-hostap_2_10-386-gb859b9bce
Copyright (c) 2004-2022, Jouni Malinen <j@w1.fi> and contributors
This software may be distributed under the terms of the BSD license.
See README for more details.
Interactive mode
Could not connect to wpa_supplicant: (nil) - re-trying
[root@br03 ~]# wpa_cli -v
[root@br03 ~]#
1,492 次查看
eric25
wpa_supplicant was compiled by me from source code, not the one provided by the system. Is it possible that the Makefile options used during compilation are incorrect? Do you have any guidance on how to compile it?
1,480 次查看
weidong_sun
Dear @eric25 ,
I compiled wpa_supplicant-2.11 with static building mode.
all steps are recorded in the attachment, for your reference.
Thanks!
weidong
1,470 次查看
eric25
I compiled wpa_supplicant(wpa_supplicant-2.11) following the documentation you provided. The only difference is that the source code versions I used are libnl-3.11.0 and openssl-3.5.0 (which I had already downloaded). The configuration during compilation strictly followed your instructions. However, when testing with the final compiled wpa_supplicant and wpa_cli, scanning for Wi-Fi still times out, and the log is the same as before. Attached are the .config and Makefile used when compiling wpa_supplicant-2.11. Do you have any other suggestions?
It seems I am unable to upload the attachment.
.config
破坏者
# Example wpa_supplicant build time configuration
# This file lists the configuration options that are used when building the
# wpa_supplicant binary. All lines starting with # are ignored. Configuration
# option lines must be commented out complete, if they are not to be included,
# i.e., just setting VARIABLE=n is not disabling that variable.
# This file is included in Makefile, so variables like CFLAGS and LIBS can also
# be modified from here. In most cases, these lines should use += in order not
# to override previous values of the variables.
# Uncomment following two lines and fix the paths if you have installed OpenSSL
# or GnuTLS in non-default location
#CFLAGS += -I/usr/local/openssl/include
#LIBS += -L/usr/local/openssl/lib
# Some Red Hat versions seem to include kerberos header files from OpenSSL, but
# the kerberos files are not in the default include path. Following line can be
# used to fix build issues on such systems (krb5.h not found).
#CFLAGS += -I/usr/include/kerberos
# Driver interface for generic Linux wireless extensions
# Note: WEXT is deprecated in the current Linux kernel version and no new
# functionality is added to it. nl80211-based interface is the new
# replacement for WEXT and its use allows wpa_supplicant to properly control
# the driver to improve existing functionality like roaming and to support new
# functionality.
CONFIG_DRIVER_WEXT=y
# Driver interface for Linux drivers using the nl80211 kernel interface
CONFIG_DRIVER_NL80211=y
# QCA vendor extensions to nl80211
#CONFIG_DRIVER_NL80211_QCA=y
# driver_nl80211.c requires libnl. If you are compiling it yourself
# you may need to point hostapd to your version of libnl.
#CFLAGS += -I$<path to libnl include files>
#LIBS += -L$<path to libnl library files>
# Use libnl v2.0 (or 3.0) libraries.
#CONFIG_LIBNL20=y
# Use libnl 3.2 libraries (if this is selected, CONFIG_LIBNL20 is ignored)
CONFIG_LIBNL32=y
# Driver interface for FreeBSD net80211 layer (e.g., Atheros driver)
#CONFIG_DRIVER_BSD=y
#CFLAGS += -I/usr/local/include
#LIBS += -L/usr/local/lib
#LIBS_p += -L/usr/local/lib
#LIBS_c += -L/usr/local/lib
# Driver interface for Windows NDIS
#CONFIG_DRIVER_NDIS=y
#CFLAGS += -I/usr/include/w32api/ddk
# For native build using mingw
#CONFIG_NATIVE_WINDOWS=y
# Additional directories for cross-compilation on Linux host for mingw target
#CFLAGS += -I/opt/mingw/mingw32/include/ddk
#LIBS += -L/opt/mingw/mingw32/lib
#CC=mingw32-gcc
# By default, driver_ndis uses WinPcap for low-level operations. This can be
# replaced with the following option which replaces WinPcap calls with NDISUIO.
# However, this requires that WZC is disabled (net stop wzcsvc) before starting
# wpa_supplicant.
# CONFIG_USE_NDISUIO=y
# Driver interface for wired Ethernet drivers
CONFIG_DRIVER_WIRED=y
# Driver interface for MACsec capable Qualcomm Atheros drivers
#CONFIG_DRIVER_MACSEC_QCA=y
# Driver interface for Linux MACsec drivers
#CONFIG_DRIVER_MACSEC_LINUX=y
# Driver interface for the Broadcom RoboSwitch family
#CONFIG_DRIVER_ROBOSWITCH=y
# Driver interface for no driver (e.g., WPS ER only)
#CONFIG_DRIVER_NONE=y
# Solaris libraries
#LIBS += -lsocket -ldlpi -lnsl
#LIBS_c += -lsocket
# Enable IEEE 802.1X Supplicant (automatically included if any EAP method or
# MACsec is included)
CONFIG_IEEE8021X_EAPOL=y
# EAP-MD5
CONFIG_EAP_MD5=y
# EAP-MSCHAPv2
CONFIG_EAP_MSCHAPV2=y
# EAP-TLS
CONFIG_EAP_TLS=y
# Enable EAP-TLSv1.3 support by default (currently disabled unless explicitly
# enabled in network configuration)
#CONFIG_EAP_TLSV1_3=y
# EAL-PEAP
CONFIG_EAP_PEAP=y
# EAP-TTLS
CONFIG_EAP_TTLS=y
CONFIG_EAP_SAE=y
# EAP-FAST
CONFIG_EAP_FAST=y
# EAP-TEAP
# Note: The current EAP-TEAP implementation is experimental and should not be
# enabled for production use. The IETF RFC 7170 that defines EAP-TEAP has number
# of conflicting statements and missing details and the implementation has
# vendor specific workarounds for those and as such, may not interoperate with
# any other implementation. This should not be used for anything else than
# experimentation and interoperability testing until those issues has been
# resolved.
#CONFIG_EAP_TEAP=y
# EAP-GTC
CONFIG_EAP_GTC=y
# EAP-OTP
CONFIG_EAP_OTP=y
# EAP-SIM (enable CONFIG_PCSC, if EAP-SIM is used)
#CONFIG_EAP_SIM=y
# Enable SIM simulator (Milenage) for EAP-SIM
#CONFIG_SIM_SIMULATOR=y
# EAP-PSK (experimental; this is _not_ needed for WPA-PSK)
#CONFIG_EAP_PSK=y
# EAP-pwd (secure authentication using only a password)
CONFIG_EAP_PWD=y
# EAP-PAX
CONFIG_EAP_PAX=y
# LEAP
CONFIG_EAP_LEAP=y
# EAP-AKA (enable CONFIG_PCSC, if EAP-AKA is used)
#CONFIG_EAP_AKA=y
# EAP-AKA' (enable CONFIG_PCSC, if EAP-AKA' is used).
# This requires CONFIG_EAP_AKA to be enabled, too.
#CONFIG_EAP_AKA_PRIME=y
# Enable USIM simulator (Milenage) for EAP-AKA
#CONFIG_USIM_SIMULATOR=y
# EAP-SAKE
CONFIG_EAP_SAKE=y
# EAP-GPSK
CONFIG_EAP_GPSK=y
# Include support for optional SHA256 cipher suite in EAP-GPSK
CONFIG_EAP_GPSK_SHA256=y
# EAP-TNC and related Trusted Network Connect support (experimental)
CONFIG_EAP_TNC=y
# Wi-Fi Protected Setup (WPS)
CONFIG_WPS=y
# Enable WPS external registrar functionality
#CONFIG_WPS_ER=y
# Disable credentials for an open network by default when acting as a WPS
# registrar.
#CONFIG_WPS_REG_DISABLE_OPEN=y
# Enable WPS support with NFC config method
#CONFIG_WPS_NFC=y
# EAP-IKEv2
CONFIG_EAP_IKEV2=y
# EAP-EKE
#CONFIG_EAP_EKE=y
# MACsec
CONFIG_MACSEC=y
# PKCS#12 (PFX) support (used to read private key and certificate file from
# a file that usually has extension .p12 or .pfx)
CONFIG_PKCS12=y
# Smartcard support (i.e., private key on a smartcard), e.g., with openssl
# engine.
CONFIG_SMARTCARD=y
# PC/SC interface for smartcards (USIM, GSM SIM)
# Enable this if EAP-SIM or EAP-AKA is included
#CONFIG_PCSC=y
# Support HT overrides (disable HT/HT40, mask MCS rates, etc.)
#CONFIG_HT_OVERRIDES=y
# Support VHT overrides (disable VHT, mask MCS rates, etc.)
#CONFIG_VHT_OVERRIDES=y
# Support HE overrides
#CONFIG_HE_OVERRIDES=y
# Development testing
#CONFIG_EAPOL_TEST=y
# Support IPv6
CONFIG_IPV6=y
# Select control interface backend for external programs, e.g, wpa_cli:
# unix = UNIX domain sockets (default for Linux/*BSD)
# udp = UDP sockets using localhost (127.0.0.1)
# udp6 = UDP IPv6 sockets using localhost (::1)
# named_pipe = Windows Named Pipe (default for Windows)
# udp-remote = UDP sockets with remote access (only for tests systems/purpose)
# udp6-remote = UDP IPv6 sockets with remote access (only for tests purpose)
# y = use default (backwards compatibility)
# If this option is commented out, control interface is not included in the
# build.
CONFIG_CTRL_IFACE=y
# Include support for GNU Readline and History Libraries in wpa_cli.
# When building a wpa_cli binary for distribution, please note that these
# libraries are licensed under GPL and as such, BSD license may not apply for
# the resulting binary.
#CONFIG_READLINE=y
# Include internal line edit mode in wpa_cli. This can be used as a replacement
# for GNU Readline to provide limited command line editing and history support.
#CONFIG_WPA_CLI_EDIT=y
# Remove debugging code that is printing out debug message to stdout.
# This can be used to reduce the size of the wpa_supplicant considerably
# if debugging code is not needed. The size reduction can be around 35%
# (e.g., 90 kB).
#CONFIG_NO_STDOUT_DEBUG=y
# Remove WPA support, e.g., for wired-only IEEE 802.1X supplicant, to save
# 35-50 kB in code size.
#CONFIG_NO_WPA=y
# Remove IEEE 802.11i/WPA-Personal ASCII passphrase support
# This option can be used to reduce code size by removing support for
# converting ASCII passphrases into PSK. If this functionality is removed, the
# PSK can only be configured as the 64-octet hexstring (e.g., from
# wpa_passphrase). This saves about 0.5 kB in code size.
#CONFIG_NO_WPA_PASSPHRASE=y
# Simultaneous Authentication of Equals (SAE), WPA3-Personal
CONFIG_SAE=y
CONFIG_IEEE80211W=y
CONFIG_IEEE80211N=y
CONFIG_WPA3=y
# SAE Public Key, WPA3-Personal
#CONFIG_SAE_PK=y
# Disable scan result processing (ap_scan=1) to save code size by about 1 kB.
# This can be used if ap_scan=1 mode is never enabled.
#CONFIG_NO_SCAN_PROCESSING=y
# Select configuration backend:
# file = text file (e.g., wpa_supplicant.conf; note: the configuration file
# path is given on command line, not here; this option is just used to
# select the backend that allows configuration files to be used)
# winreg = Windows registry (see win_example.reg for an example)
CONFIG_BACKEND=file
# Remove configuration write functionality (i.e., to allow the configuration
# file to be updated based on runtime configuration changes). The runtime
# configuration can still be changed, the changes are just not going to be
# persistent over restarts. This option can be used to reduce code size by
# about 3.5 kB.
#CONFIG_NO_CONFIG_WRITE=y
# Remove support for configuration blobs to reduce code size by about 1.5 kB.
#CONFIG_NO_CONFIG_BLOBS=y
# Select program entry point implementation:
# main = UNIX/POSIX like main() function (default)
# main_winsvc = Windows service (read parameters from registry)
# main_none = Very basic example (development use only)
#CONFIG_MAIN=main
# Select wrapper for operating system and C library specific functions
# unix = UNIX/POSIX like systems (default)
# win32 = Windows systems
# none = Empty template
#CONFIG_OS=unix
# Select event loop implementation
# eloop = select() loop (default)
# eloop_win = Windows events and WaitForMultipleObject() loop
#CONFIG_ELOOP=eloop
# Should we use poll instead of select? Select is used by default.
#CONFIG_ELOOP_POLL=y
# Should we use epoll instead of select? Select is used by default.
#CONFIG_ELOOP_EPOLL=y
# Should we use kqueue instead of select? Select is used by default.
#CONFIG_ELOOP_KQUEUE=y
# Select layer 2 packet implementation
# linux = Linux packet socket (default)
# pcap = libpcap/libdnet/WinPcap
# freebsd = FreeBSD libpcap
# winpcap = WinPcap with receive thread
# ndis = Windows NDISUIO (note: requires CONFIG_USE_NDISUIO=y)
#CONFIG_L2_PACKET=linux
# Disable Linux packet socket workaround applicable for station interface
# in a bridge for EAPOL frames. This should be uncommented only if the kernel
# is known to not have the regression issue in packet socket behavior with
# bridge interfaces (commit 'bridge: respect RFC2863 operational state')').
#CONFIG_NO_LINUX_PACKET_SOCKET_WAR=y
# Support Operating Channel Validation
#CONFIG_OCV=y
# Select TLS implementation
# openssl = OpenSSL (default)
# gnutls = GnuTLS
# internal = Internal TLSv1 implementation (experimental)
# linux = Linux kernel AF_ALG and internal TLSv1 implementation (experimental)
CONFIG_TLS=openssl
# TLS-based EAP methods require at least TLS v1.0. Newer version of TLS (v1.1)
# can be enabled to get a stronger construction of messages when block ciphers
# are used. It should be noted that some existing TLS v1.0 -based
# implementation may not be compatible with TLS v1.1 message (ClientHello is
# sent prior to negotiating which version will be used)
#CONFIG_TLSV11=y
# TLS-based EAP methods require at least TLS v1.0. Newer version of TLS (v1.2)
# can be enabled to enable use of stronger crypto algorithms. It should be
# noted that some existing TLS v1.0 -based implementation may not be compatible
# with TLS v1.2 message (ClientHello is sent prior to negotiating which version
# will be used)
#CONFIG_TLSV12=y
# Select which ciphers to use by default with OpenSSL if the user does not
# specify them.
#CONFIG_TLS_DEFAULT_CIPHERS="DEFAULT:!EXP:!LOW"
# If CONFIG_TLS=internal is used, additional library and include paths are
# needed for LibTomMath. Alternatively, an integrated, minimal version of
# LibTomMath can be used. See beginning of libtommath.c for details on benefits
# and drawbacks of this option.
#CONFIG_INTERNAL_LIBTOMMATH=y
#ifndef CONFIG_INTERNAL_LIBTOMMATH
#LTM_PATH=/usr/src/libtommath-0.39
#CFLAGS += -I$(LTM_PATH)
#LIBS += -L$(LTM_PATH)
#LIBS_p += -L$(LTM_PATH)
#endif
# At the cost of about 4 kB of additional binary size, the internal LibTomMath
# can be configured to include faster routines for exptmod, sqr, and div to
# speed up DH and RSA calculation considerably
#CONFIG_INTERNAL_LIBTOMMATH_FAST=y
# Include NDIS event processing through WMI into wpa_supplicant/wpasvc.
# This is only for Windows builds and requires WMI-related header files and
# WbemUuid.Lib from Platform SDK even when building with MinGW.
#CONFIG_NDIS_EVENTS_INTEGRATED=y
#PLATFORMSDKLIB="/opt/Program Files/Microsoft Platform SDK/Lib"
# Add support for new DBus control interface
# (fi.w1.wpa_supplicant1)
#CONFIG_CTRL_IFACE_DBUS_NEW=y
# Add introspection support for new DBus control interface
#CONFIG_CTRL_IFACE_DBUS_INTRO=y
# Add support for loading EAP methods dynamically as shared libraries.
# When this option is enabled, each EAP method can be either included
# statically (CONFIG_EAP_<method>=y) or dynamically (CONFIG_EAP_<method>=dyn).
# Dynamic EAP methods are build as shared objects (eap_*.so) and they need to
# be loaded in the beginning of the wpa_supplicant configuration file
# (see load_dynamic_eap parameter in the example file) before being used in
# the network blocks.
# Note that some shared parts of EAP methods are included in the main program
# and in order to be able to use dynamic EAP methods using these parts, the
# main program must have been build with the EAP method enabled (=y or =dyn).
# This means that EAP-TLS/PEAP/TTLS/FAST cannot be added as dynamic libraries
# unless at least one of them was included in the main build to force inclusion
# of the shared code. Similarly, at least one of EAP-SIM/AKA must be included
# in the main build to be able to load these methods dynamically.
# Please also note that using dynamic libraries will increase the total binary
# size. Thus, it may not be the best option for targets that have limited
# amount of memory/flash.
#CONFIG_DYNAMIC_EAP_METHODS=y
# Dynamic library loading
# Add the ability to configure libraries to load at compile time.
# If set, these disable dynamic configuration.
#CONFIG_PKCS11_ENGINE_PATH - pkcs11_engine library location.
#CONFIG_PKCS11_MODULE_PATH - pkcs11_module library location.
#CONFIG_OPENSC_ENGINE_PATH - opensc_engine library location.
# Prevent library loading at runtime
#CONFIG_NO_PKCS11_ENGINE_PATH=y # prevents loading pkcs11_engine library.
#CONFIG_NO_PKCS11_MODULE_PATH=y # prevents loading pkcs11_module library.
# CONFIG_NO_OPENSC_ENGINE_PATH=y # prevents loading opensc_engine library.
# Prevents loading EAP libraries at runtime
#CONFIG_NO_LOAD_DYNAMIC_EAP=y
# IEEE Std 802.11r-2008 (Fast BSS Transition) for station mode
CONFIG_IEEE80211R=y
# Add support for writing debug log to a file (/tmp/wpa_supplicant-log-#.txt)
CONFIG_DEBUG_FILE=y
# Send debug messages to syslog instead of stdout
CONFIG_DEBUG_SYSLOG=y
# Set syslog facility for debug messages
#CONFIG_DEBUG_SYSLOG_FACILITY=LOG_DAEMON
# Add support for sending all debug messages (regardless of debug verbosity)
# to the Linux kernel tracing facility. This helps debug the entire stack by
# making it easy to record everything happening from the driver up into the
# same file, e.g., using trace-cmd.
#CONFIG_DEBUG_LINUX_TRACING=y
# Add support for writing debug log to Android logcat instead of standard
# output
#CONFIG_ANDROID_LOG=y
# Enable privilege separation (see README 'Privilege separation' for details)
#CONFIG_PRIVSEP=y
# Enable mitigation against certain attacks against TKIP by delaying Michael
# MIC error reports by a random amount of time between 0 and 60 seconds
#CONFIG_DELAYED_MIC_ERROR_REPORT=y
# Enable tracing code for developer debugging
# This tracks use of memory allocations and other registrations and reports
# incorrect use with a backtrace of call (or allocation) location.
#CONFIG_WPA_TRACE=y
# For BSD, uncomment these.
#LIBS += -lexecinfo
#LIBS_p += -lexecinfo
#LIBS_c += -lexecinfo
# Use libbfd to get more details for developer debugging
# This enables use of libbfd to get more detailed symbols for the backtraces
# generated by CONFIG_WPA_TRACE=y.
#CONFIG_WPA_TRACE_BFD=y
#LIBS += -lbfd -liberty -lz
#LIBS_p += -lbfd -liberty -lz
#LIBS_c += -lbfd -liberty -lz
# wpa_supplicant depends on strong random number generation being available
# from the operating system. os_get_random() function is used to fetch random
# data when needed, e.g., for key generation. On Linux and BSD systems, this
# works by reading /dev/urandom. It should be noted that the OS entropy pool
# needs to be properly initialized before wpa_supplicant is started. This is
# important especially on embedded devices that do not have a hardware random
# number generator and may by default start up with minimal entropy available
# for random number generation.
# As a safety net, wpa_supplicant is by default trying to internally collect
# additional entropy for generating random data to mix in with the data fetched
# from the OS. This by itself is not considered to be very strong, but it may
# help in cases where the system pool is not initialized properly. However, it
# is very strongly recommended that the system pool is initialized with enough
# entropy either by using hardware assisted random number generator or by
# storing state over device reboots.
# wpa_supplicant can be configured to maintain its own entropy store over
# restarts to enhance random number generation. This is not perfect, but it is
# much more secure than using the same sequence of random numbers after every
# reboot. This can be enabled with -e<entropy file> command line option. The
# specified file needs to be readable and writable by wpa_supplicant.
# If the os_get_random() is known to provide strong random data (e.g., on
# Linux/BSD, the board in question is known to have reliable source of random
# data from /dev/urandom), the internal wpa_supplicant random pool can be
# disabled. This will save some in binary size and CPU use. However, this
# should only be considered for builds that are known to be used on devices
# that meet the requirements described above.
#CONFIG_NO_RANDOM_POOL=y
# Should we attempt to use the getrandom(2) call that provides more reliable
# yet secure randomness source than /dev/random on Linux 3.17 and newer.
# Requires glibc 2.25 to build, falls back to /dev/random if unavailable.
#CONFIG_GETRANDOM=y
# IEEE 802.11ac (Very High Throughput) support (mainly for AP mode)
CONFIG_IEEE80211AC=y
# IEEE 802.11ax HE support (mainly for AP mode)
CONFIG_IEEE80211AX=y
# IEEE 802.11be EHT support (mainly for AP mode)
# CONFIG_IEEE80211AX is mandatory for setting CONFIG_IEEE80211BE.
# Note: This is experimental and work in progress. The definitions are still
# subject to change and this should not be expected to interoperate with the
# final IEEE 802.11be version.
#CONFIG_IEEE80211BE=y
# Wireless Network Management (IEEE Std 802.11v-2011)
# Note: This is experimental and not complete implementation.
#CONFIG_WNM=y
# Interworking (IEEE 802.11u)
# This can be used to enable functionality to improve interworking with
# external networks (GAS/ANQP to learn more about the networks and network
# selection based on available credentials).
CONFIG_INTERWORKING=y
# Hotspot 2.0
CONFIG_HS20=y
# Enable interface matching in wpa_supplicant
#CONFIG_MATCH_IFACE=y
# Disable roaming in wpa_supplicant
#CONFIG_NO_ROAMING=y
# AP mode operations with wpa_supplicant
# This can be used for controlling AP mode operations with wpa_supplicant. It
# should be noted that this is mainly aimed at simple cases like
# WPA2-Personal while more complex configurations like WPA2-Enterprise with an
# external RADIUS server can be supported with hostapd.
CONFIG_AP=y
# P2P (Wi-Fi Direct)
# This can be used to enable P2P support in wpa_supplicant. See README-P2P for
# more information on P2P operations.
CONFIG_P2P=y
# Enable TDLS support
CONFIG_TDLS=y
# Wi-Fi Display
# This can be used to enable Wi-Fi Display extensions for P2P using an external
# program to control the additional information exchanges in the messages.
CONFIG_WIFI_DISPLAY=y
# Autoscan
# This can be used to enable automatic scan support in wpa_supplicant.
# See wpa_supplicant.conf for more information on autoscan usage.
# Enabling directly a module will enable autoscan support.
# For exponential module:
#CONFIG_AUTOSCAN_EXPONENTIAL=y
# For periodic module:
#CONFIG_AUTOSCAN_PERIODIC=y
# Password (and passphrase, etc.) backend for external storage
# These optional mechanisms can be used to add support for storing passwords
# and other secrets in external (to wpa_supplicant) location. This allows, for
# example, operating system specific key storage to be used
# External password backend for testing purposes (developer use)
#CONFIG_EXT_PASSWORD_TEST=y
# File-based backend to read passwords from an external file.
#CONFIG_EXT_PASSWORD_FILE=y
# Enable Fast Session Transfer (FST)
#CONFIG_FST=y
# Enable CLI commands for FST testing
#CONFIG_FST_TEST=y
# OS X builds. This is only for building eapol_test.
#CONFIG_OSX=y
# Automatic Channel Selection
# This will allow wpa_supplicant to pick the channel automatically when channel
# is set to "0".
# TODO: Extend parser to be able to parse "channel=acs_survey" as an alternative
# to "channel=0". This would enable us to eventually add other ACS algorithms in
# similar way.
# Automatic selection is currently only done through initialization, later on
# we hope to do background checks to keep us moving to more ideal channels as
# time goes by. ACS is currently only supported through the nl80211 driver and
# your driver must have survey dump capability that is filled by the driver
# during scanning.
# TODO: In analogy to hostapd be able to customize the ACS survey algorithm with
# a newly to create wpa_supplicant.conf variable acs_num_scans.
# Supported ACS drivers:
# * ath9k
# * ath5k
# * ath10k
# For more details refer to:
# http://wireless.kernel.org/en/users/Documentation/acs
#CONFIG_ACS=y
# Support Multi Band Operation
#CONFIG_MBO=y
# Fast Initial Link Setup (FILS) (IEEE 802.11ai)
CONFIG_FILS=y
# FILS shared key authentication with PFS
#CONFIG_FILS_SK_PFS=y
# Support RSN on IBSS networks
# This is needed to be able to use mode=1 network profile with proto=RSN and
# key_mgmt=WPA-PSK (i.e., full key management instead of WPA-None).
CONFIG_IBSS_RSN=y
# External PMKSA cache control
# This can be used to enable control interface commands that allow the current
# PMKSA cache entries to be fetched and new entries to be added.
#CONFIG_PMKSA_CACHE_EXTERNAL=y
# Mesh Networking (IEEE 802.11s)
#CONFIG_MESH=y
# Background scanning modules
# These can be used to request wpa_supplicant to perform background scanning
# operations for roaming within an ESS (same SSID). See the bgscan parameter in
# the wpa_supplicant.conf file for more details.
# Periodic background scans based on signal strength
CONFIG_BGSCAN_SIMPLE=y
# Learn channels used by the network and try to avoid bgscans on other
# channels (experimental)
#CONFIG_BGSCAN_LEARN=y
# Opportunistic Wireless Encryption (OWE)
# Experimental implementation of draft-harkins-owe-07.txt
#CONFIG_OWE=y
# Device Provisioning Protocol (DPP) (also known as Wi-Fi Easy Connect)
CONFIG_DPP=y
# DPP version 2 support
CONFIG_DPP2=y
# DPP version 3 support (experimental and still changing; do not enable for
# production use)
#CONFIG_DPP3=y
# Wired equivalent privacy (WEP)
# WEP is an obsolete cryptographic data confidentiality algorithm that is not
# considered secure. It should not be used for anything anymore. The
# functionality needed to use WEP is available in the current wpa_supplicant
# release under this optional build parameter. This functionality is subject to
# be completely removed in a future release.
#CONFIG_WEP=y
# Remove all TKIP functionality
# TKIP is an old cryptographic data confidentiality algorithm that is not
# considered secure. It should not be used anymore for anything else than a
# backwards compatibility option as a group cipher when connecting to APs that
# use WPA+WPA2 mixed mode. For now, the default wpa_supplicant build includes
# support for this by default, but that functionality is subject to be removed
# in the future.
#CONFIG_NO_TKIP=y
# Pre-Association Security Negotiation (PASN)
# Experimental implementation based on IEEE P802.11z/D2.6 and the protocol
# design is still subject to change. As such, this should not yet be enabled in
# production use.
#CONFIG_PASN=y
# Disable support for Radio Measurement (IEEE 802.11k) and supported operating
# class indication. Removing these is not recommended since they can help the
# AP manage the network and STA steering.
#CONFIG_NO_RRM=y
# Disable support for Robust AV streaming for consumer and enterprise Wi-Fi
# applications; IEEE Std 802.11-2020, 4.3.24; SCS, MSCS, QoS Management
#CONFIG_NO_ROBUST_AV=y
# Disable support for WMM admission control
#CONFIG_NO_WMM_AC=y
# Wi-Fi Aware unsynchronized service discovery (NAN USD)
#CONFIG_NAN_USD=y
Makefile
破坏者
1,415 次查看
weidong_sun
Dear @eric25 ,
Let me share my wpa_supplicant.conf with you.
use the configuration to test your connection to AP. on AP side, wpa2 should be set, please pay attention to this point.
ctrl_interface=/var/run/wpa_supplicant
update_config=1
p2p_no_group_iface=1
network={
    ssid="YOUR SSID"
    psk="YOUR PASSWORK"
    proto=RSN
    key_mgmt=WPA-PSK
    pairwise=CCMP
    group=CCMP
Please fill out your SSID of AP and pass word to replace "YOUR SSID", "YOUR PASSWORD".
Weidong
1,082 次查看
eric25
Thank you for your thorough response. However,I follow your advice. the issue still persists — it continues to show a scan timeout and cannot connect to any Wi-Fi hotspot. Based on the log, could you help analyze the possible cause?
1,074 次查看
weidong_sun
Dear @eric25 ,
我看到你的log文件是中文,那么我这里用中文和你讨论,请用下面命令确认是否你的系统有rfkill,阻止了WIFI工作,从扫描结果看:你的WIFI wlan0,没有扫描到AP。扫描结果是空的。
如果还不行,请把你WIFI部分的原理图给我看一下,这是我的邮件:weidong.sun@nxp.com。
rfkill unblock all
ifconfig wlan0 down
ifconfig wlan0 up
然后,在启动wpa supplicant, 测试一下,主要看有没有扫描的AP。
谢谢!
伟东
%3CLINGO-SUB%20id%3D%22lingo-sub-2339069%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAW611%20Wi-Fi%20%E8%8A%AF%E7%89%87%20Wi-Fi%20%E6%89%AB%E6%8F%8F%E8%B6%85%E6%97%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339069%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%E3%80%81%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E8%B0%83%E8%AF%95%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%EF%BC%9A%E6%88%90%E5%8A%9F%E5%8A%A0%E8%BD%BD%20Wi-Fi%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%90%8E%EF%BC%8C%E5%9C%A8%20Wi-Fi%20%E7%83%AD%E7%82%B9%E6%89%AB%E6%8F%8F%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%20Wi-Fi%20%E7%83%AD%E7%82%B9%EF%BC%88%E6%89%8B%E6%9C%BA%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%B5%8B%E5%88%B0%E7%83%AD%E7%82%B9%EF%BC%8C%E7%83%AD%E7%82%B9%E7%A6%BB%20Wi-Fi%20%E6%A8%A1%E5%9D%97%E5%BE%88%E8%BF%91%EF%BC%8C%E8%80%8C%E4%B8%94%E6%A8%A1%E5%9D%97%E5%AE%89%E8%A3%85%E4%BA%86%E5%A4%A9%E7%BA%BF%EF%BC%89%E3%80%82%E6%A3%80%E6%9F%A5%20dmesg%20%E4%BC%BC%E4%B9%8E%E6%98%BE%E7%A4%BA%E8%B6%85%E6%97%B6%E3%80%82%E8%AF%A6%E7%BB%86%E6%97%A5%E5%BF%97%E8%AF%B7%E5%8F%82%E8%A7%81%E9%99%84%E4%BB%B6%E3%80%82%E6%82%A8%E8%83%BD%E5%B8%AE%E5%BF%99%E5%88%86%E6%9E%90%E4%B8%80%E4%B8%8B%E5%8E%9F%E5%9B%A0%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E6%93%8D%E4%BD%9C%E6%AD%A5%E9%AA%A4%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E1.%E5%B9%B3%E5%8F%B0%EF%BC%9Asama5d3%EF%BC%8CLinux%20%E7%89%88%E6%9C%AC%EF%BC%9A4.4.19%3C%2FP%3E%3CP%3E2.%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%8A%A0%E8%BD%BD%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8Cdmesg%20%E6%98%BE%E7%A4%BA%E5%8A%A0%E8%BD%BD%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3Einsmod%20mlan.ko%3CBR%20%2F%3Einsmod%20moal.ko%20drv_mode%3D7%20ps_mode%3D2%20auto_ds%3D2%20host_mlme%3D1%20cal_data_cfg%3Dnone%20fw_name%3Dnxp%2Fsd_w61x_v1.bin.se%20sta_name%3Dwlan%20wfd_name%3Dp2p%20cfg80211_wext%3D0xf%20drvdbg%3D0x80037%3C%2FP%3E%3CP%3E3.%E4%BD%BF%E7%94%A8%20wlan0%20%E8%AE%BE%E5%A4%87%E6%89%AB%E6%8F%8F%20Wi-Fi%20%E7%83%AD%E7%82%B9%20%3CBR%20%2F%3E%20ifconfig%20wlan0%20u%20%3CBR%20%2F%3E%20p%20wpa_supplicant-B-Dnl80211-iwlan0-c%20%2Fetc%2Fwpa.conf%20%3CBR%20%2F%3Ewpa_cli%20-i%20wlan0%20-g%2Fvar%2Frun%2Fwpa_supplicant%2Fwlan0%20ap_scan%201%3CBR%20%2F%3Ewpa_cli%20-i%20wlan0%20scan%3CBR%20%2F%3Ewpa_cli%20-i%20wlan0%20scan_result%3C%2FP%3E%3CP%3E4.%E6%89%A7%E8%A1%8C%20wpa_cli%20-i%20wlan0%20%E6%89%AB%E6%8F%8F%E5%91%BD%E4%BB%A4%E6%97%B6%EF%BC%8Cdmesg%20%E4%BC%9A%E6%98%BE%E7%A4%BA%E4%BB%A5%E4%B8%8B%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%B2%A1%E6%9C%89%E5%8F%91%E7%8E%B0%E7%83%AD%E7%82%B9%EF%BC%88%E6%89%8B%E6%9C%BA%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%B5%8B%E5%88%B0%E5%A4%9A%E4%B8%AA%E7%83%AD%E7%82%B9%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3EJan%201%2006%3A20%3A45%20(none)%20user.alert%20kernel%EF%BC%9A%5B%20750.575641%5D%20wlan%3A%20wlan0%20START%20SCAN%3CBR%20%2F%3EJan%201%2006%3A21%3A05%20(none)%20user.warn%20kernel%EF%BC%9A%5B%20770.653428%5D%20Ext%20scan%20enh%20timeout%3CBR%20%2F%3EJan%201%2006%3A21%3A05%20(none)%20user.warn%20kernel%EF%BC%9A%5B%20770.653465%5D%20------------Dump%20info-----------%3CBR%20%2F%3EJan%201%2006%3A21%3A05%20(none)%20user.warn%20kernel%EF%BC%9A%5B%20770.653478%5D%20EXT_SCAN_STATUS%20%E4%BA%8B%E4%BB%B6%E8%B6%85%E6%97%B6%3CBR%20%2F%3EJan%201%2006%3A21%3A05%20(none)%20user.warn%20kernel%EF%BC%9A%5B%20770.653490%5D%20CurCmd%20Empty%3C%2FP%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%89%A7%E9%80%8F%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E9%AB%98%E4%BA%AE%E9%83%A8%E5%88%86%E5%8F%AF%E4%BE%9B%E9%98%85%E8%AF%BB%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%5B5.416061%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E4%B8%BA%E6%A0%B9%E7%94%A8%E6%88%B7%E4%BF%9D%E7%95%99%EF%BC%9A4952683%20%E5%AD%97%E8%8A%82%20(4836%20KiB)%20%3CBR%20%2F%3E%20%5B5.416088%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E4%B8%BA%20w4%2Fr0%EF%BC%89%E3%80%81UUID%209C8DF7E6-05DA-4D41-A3C5-0029C4D16B41%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%5B5.557978%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E5%8D%B8%E8%BD%BD%20UBI%20%E8%AE%BE%E5%A4%87%200%20%3CBR%20%2F%3E%20%5B5.5.r0%5D%5D%20UBIFS%20(ubi%200%3A8)%EF%BC%9A%E5%90%8E%E5%8F%B0%E8%AF%9D%E9%A2%98%20%22%20ubifs_bgt0_8%20%22%20%E5%81%9C%E6%AD%A2%20%5B82.542976%5D%20wlan%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20MWLAN%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5B82.550306%5D%20wlan%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%88%B0%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%5B82.613986%5D%20vendor%3D0x0471%20device%3D0x0205%20class%3D0%20function%3D1%20%5B82.614205%5D%20Attach%20moal%20handle%20ops%EF%BC%8C%E5%8D%A1%E7%89%87%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%EF%BC%9A0x109%20%5B82.614248%5D%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E6%9C%AA%E6%8C%87%E5%AE%9A%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%20cfg%20%E6%96%87%E4%BB%B6%3CBR%20%2F%3E%5B%2082.614273%5D%20combo%20fw%3Anxp%2Fsduart_nw61x.bin.se%20wlan%20fw%3Anxp%2Fsd_w61x.bin.se%3CBR%20%2F%3E%5B%2082.614317%5D%20SDIO%3A%20sdio_blk_size%3D256%20max_blk_count%3D512%20max_segs%3D64%20max_seg_size%3D4096%3CBR%20%2F%3E%5B%2082.614333%5D%20rx_work%3D0%20cpu_num%3D1%3CBR%20%2F%3E%5B%2082.614354%5D%20Enable%20moal_recv_amsdu_packet%3CBR%20%2F%3E%5B%2082.614448%5D%20Attach%20mlan%20adapter%20operations.card_type%20is%200x109.%3CBR%20%2F%3E%5B%2082.615544%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20TX%20SG%20%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%2082.615573%5D%20wlan%3A%20mpa_tx.buf_size%3D4096%3CBR%20%2F%3E%5B%2082.615583%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20RX%20SG%20%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%2082.615594%5D%20wlan%EF%BC%9A%20mpa_rx.buf_size%3D4096%3CBR%20%2F%3E%5B%2082.622224%5D%20%E8%AF%B7%E6%B1%82%E5%9B%BA%E4%BB%B6%EF%BC%9Anxp%2Fsd_w61x_v1.bin.se%3CBR%20%2F%3E%5B82.748653%5D%20%E5%94%A4%E9%86%92%E8%AE%BE%E5%A4%87...%3CBR%20%2F%3E%5B82.952631%5D%20%E6%97%A0%E7%BA%BF%E5%B1%80%E5%9F%9F%E7%BD%91%EF%BC%9A%E5%9B%BA%E4%BB%B6%E4%B8%8B%E8%BD%BD%E7%BB%93%E6%9D%9F%EF%BC%8Cfirmwarelen%3D681308%20%E5%B7%B2%E4%B8%8B%E8%BD%BD%20565508%20%5B83.349412%5D%20%E6%97%A0%E7%BA%BF%E5%B1%80%E5%9F%9F%E7%BD%91%E5%9B%BA%E4%BB%B6%E5%A4%84%E4%BA%8E%E6%B4%BB%E5%8A%A8%E7%8A%B6%E6%80%81%20%5B83.349451%5D%20on_time%20%E6%98%AF%2083330185801%20%5B83.349895%5D%20QUEUE_CMD%EF%BC%9AFUNC_INIT%20%3CBR%20%2F%3E%20%5B0xa9%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.349930%5D%20QUEUE_CMD%EF%BC%9AFUNC_INIT%20%5B0xa9%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%3CBR%20%2F%3E%20%5B83.349930%5D%20QUEUE_CMD%20E_CMD%EF%BC%9AGET_HW_SPEC%20%5B0x3%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.349974%5D%20DNLD_CMD%20(83.33068%20%3CBR%20%2F%3E%209)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3EFUNC_INIT%20%5B0xa9%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x263%E3%80%81len%2016%E3%80%81seqno%200x1%20%E8%B6%85%E6%97%B6%205000%20%5B83.372560%5D%20CMD_RESP%20(83.353254)%EF%BC%9A%3CBR%20%2F%3EFUNC_INIT%20%5B0x80a9%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1%3CBR%20%2F%3E%5B%2083.372622%5D%20DNLD_CMD%20(83.353337)%EF%BC%9AGET_HW_SPEC%20%5B0x3%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x0%E3%80%81len%2071%E3%80%81seqno%200x2%20%E8%B6%85%E6%97%B6%205000%20%5B83.372964%5D%2083.353669%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%3CBR%20%2F%3E%20%5B83.373008%5D%20VDLL_IND%EF%BC%88%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%89%EF%BC%9Aoffset%3D0x1c458%20%5B83.373947%5D%20VDLL%20%E5%9B%BE%E7%89%87%EF%BC%9Alen%3D115800%20%5B83.37800%5D%204253%5D%20CMD_RESP%20(83.354955)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EGET_HW_SPEC%20%5B0x8003%5D%2C%20result%200%2C%20len%20205%2C%20seqno%200x2%3CBR%20%2F%3E%5B%2083.374281%5D%20fw_cap_info%3D0x487cff03%2C%20dev_cap_mask%3D0xffffffff%3CBR%20%2F%3E%5B%2083.374299%5D%20GET_HW_SPEC%3A%20country_code%3D0x0%3CBR%20%2F%3E%5B%2083.374310%5D%20num_ant%3D1%2C%20antinfo%3D0x0%3CBR%20%2F%3E%5B%2083.374324%5D%20GET_HW_SPEC%3A%20hw_mpdu_density%3D4%20dev_mcs_support%3D0x11%3CBR%20%2F%3E%5B%2083.374335%5D%20Enable%20%E6%B3%A2%E6%9D%9F%E8%B5%8B%E5%BD%A2%3CBR%20%2F%3E%5B%2083.374350%5D%20GET_HW_SPEC%3A%20mgmt%20IE%20count%3D13%3CBR%20%2F%3E%5B%2083.374365%5D%20FW%3A%20SDIO%20rx%20aggr%20disabled%200x487cff03%3CBR%20%2F%3E%5B%2083.374381%5D%20pmadapter-%26gt%3Becsa_enable%3D1%3CBR%20%2F%3E%5B%2083.374415%5D%20QUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.374429%5D%20pmadapter-%26gt%3Bgetlog_enable%3D1%3CBR%20%2F%3E%5B%2083.374451%5D%20chanrpt%20api%20ver%3D14.1%3CBR%20%2F%3E%5B%2083.374464%5D%20fw_cap_info%3D0x487cff03%20fw_cap_ext%3D0x2182b5%3CBR%20%2F%3E%5B%2083.374479%5D%20uuid%3A%20c10d697cf87d596cab35c831392df315%3CBR%20%2F%3E%5B%2083.374491%5D%20fw%20hotfix%20ver%3D11%3CBR%20%2F%3E%5B%2083.374502%5D%20fw%20ver%3D15.1%3CBR%20%2F%3E%5B%2083.374512%5D%20uap%20fw%20ver%3D2.0%3CBR%20%2F%3E%5B%2083.374523%5D%20max_p2p_conn%20%3D%208%2C%20max_sta_conn%20%3D%2016%3CBR%20%2F%3E%5B%2083.374541%5D%20wlan_set_regiontable%3A%202.4G%200x10%3CBR%20%2F%3E%5B%2083.374561%5D%20wlan_set_regiontable%3A%205G%200x10%3CBR%20%2F%3E%5B%2083.374599%5D%20Get%20Hw%20Spec%20done%2C%20fw_cap%3D0x487cff03%3CBR%20%2F%3E%5B%2083.374630%5D%20org_drv_mode%3D0x7%20drv_mode%3D0x7%3CBR%20%2F%3E%5B%2083.375214%5D%20Enable%20%E6%B3%A2%E6%9D%9F%E8%B5%8B%E5%BD%A2%3CBR%20%2F%3E%5B%2083.375274%5D%20QUEUE_CMD%3A%20802_11_FW_WAKE_METHOD%20%5B0x74%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.375301%5D%20set%20tx_buf%20%3D%204096%3CBR%20%2F%3E%5B%2083.375321%5D%20QUEUE_CMD%3A%20RECONFIGURE_TX_BUFF%20%5B0xd9%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.375347%5D%20PS%20Command%3A%20action%20%3D%200x6%2C%20bitmap%20%3D%200x1%3CBR%20%2F%3E%5B%2083.375365%5D%20QUEUE_CMD%3A%20802_11_PS_MODE_ENH%20%5B0xe4%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.375395%5D%20QUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.375424%5D%20QUEUE_CMD%3A%20802_11_RF_ANTENNA%20%5B0x20%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.375453%5D%20QUEUE_CMD%3A%20CHAN_REGION_CFG%20%5B0x242%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.375484%5D%20QUEUE_CMD%3A%20TX_RATE_CFG%20%5B0xd6%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.375511%5D%20QUEUE_CMD%3A%20802_11_RF_TX_POWER%20%5B0x1e%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.375539%5D%20QUEUE_CMD%3A%20AMSDU_AGGR_CTRL%20%5B0xdf%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.375566%5D%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.375609%5D%20DNLD_CMD%20(83.356326)%3A%20802_11_SNMP_MIB%20%5B0x16%5D%2C%20act%200x1%2C%20len%2015%2C%20seqno%200x3%20timeout%205000%3CBR%20%2F%3E%5B%2083.376003%5D%20CMD_RESP%20(83.356703)%3A%20802_11_SNMP_MIB%20%5B0x8016%5D%2C%20result%200%2C%20len%2015%2C%20seqno%200x3%3CBR%20%2F%3E%5B%2083.376057%5D%20DNLD_CMD%20(83.356773)%3A%20802_11_FW_WAKE_METHOD%20%5B0x74%5D%2C%20act%200x0%2C%20len%2012%2C%20seqno%200x4%20timeout%205000%3CBR%20%2F%3E%5B%2083.376391%5D%20CMD_RESP%20(83.357094)%3A%20802_11_FW_WAKE_METHOD%20%5B0x8074%5D%2C%20result%200%2C%20len%2018%2C%20seqno%200x4%3CBR%20%2F%3E%5B%2083.376416%5D%20FW%20wakeup%20method%3D1%2C%20gpio%3D0%3CBR%20%2F%3E%5B%2083.376454%5D%20DNLD_CMD%20(83.357172)%3ARECONFIGURE_TX_BUFF%20%5B0xd9%5D%E3%80%81act%200x1%E3%80%81len%2016%E3%80%81seqno%200x5%20%E8%B6%85%E6%97%B6%205000%20%5B83.377529%5D%20CMD_RESP%20(83.358231)%EF%BC%9A%3CBR%20%2F%3ERECONFIGURE_TX_BUFF%20%5B0x80d9%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x5%3CBR%20%2F%3E%5B%2083.377559%5D%20end%20port%2032%EF%BC%8C%E6%95%B0%E6%8D%AE%E7%AB%AF%E5%8F%A3%E6%8E%A9%E7%A0%81%20ffffffff%3CBR%20%2F%3E%5B%2083.377575%5D%20max_tx_buf_size%3D4096%EF%BC%8Ctx_buf_size%3D3328%3CBR%20%2F%3E%5B%2083.377612%5D%20DNLD_CMD%20(83.358329)%3A%20802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x6%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x6%20timeout%205000%3CBR%20%2F%3E%5B%2083.377947%5D%20CMD_RESP%20(83.358650)%3A%20802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x6%3CBR%20%2F%3E%5B%2083.377995%5D%20DNLD_CMD%20(83.358713)%3A%20802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2018%EF%BC%8Cseqno%200x7%20timeout%205000%3CBR%20%2F%3E%5B%2083.378324%5D%20CMD_RESP%20(83.359029)%3A%20802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2018%EF%BC%8Cseqno%200x7%3CBR%20%2F%3E%5B%2083.378374%5D%20DNLD_CMD%20(83.359090)%3A%20802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x8%20timeout%205000%3CBR%20%2F%3E%5B%2083.378707%5D%20CMD_RESP%20(83.359411)%3A%20802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x8%3CBR%20%2F%3E%5B%2083.378757%5D%20DNLD_CMD%20(83.359472)%3A%20CHAN_REGION_CFG%20%5B0x242%5D%E3%80%81act%200x0%E3%80%81len%2011%E3%80%81seqno%200x9%20%E8%B6%85%E6%97%B6%205000%20%5B83.380238%5D%20CMD_RESP%20(83.360924)%EF%BC%9A%3CBR%20%2F%3ECHAN_REGION_CFG%20%5B0x8242%5D%EF%BC%8Cresult%200%EF%BC%8Clen%201297%EF%BC%8Cseqno%200x9%3CBR%20%2F%3E%5B%2083.380344%5D%20DNLD_CMD%20(83.361055)%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2076%EF%BC%8Cseqno%200xa%20%E8%B6%85%E6%97%B6%205000%20%5B83.381077%5D%20CMD_RESP%20(83.361775)%EF%BC%9A%3CBR%20%2F%3ETX_RATE_CFG%20%5B0x80d6%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20832%EF%BC%8C%E5%BA%8F%E5%88%97%200xa%20%5B83.381136%5D%20DNLD_CMD%20(83.361851)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2014%EF%BC%8C%E9%A1%BA%E5%BA%8F%200xb%20%E8%B6%85%E6%97%B6%205000%20%3CBR%20%2F%3E%20%5B83.381490%5D%20CMD_RESP%20(8x1e)%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2014%EF%BC%8C%E9%A1%BA%E5%BA%8F%200xb%20%E8%B6%85%E6%97%B6%205000%20%5B83.381490%5D%20CMD_RESP%20(8x1e)%203.362193)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x801e%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8C%E5%BA%8F%E5%88%97%200xb%20%5B83.381539%5D%20DNLD_CMD%20(83.362255)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3EAMSDU_AGGR_CTRL%20%5B0xdf%5D%E3%80%81act%200x1%E3%80%81len%2014%E3%80%81seqno%200xc%20%E8%B6%85%E6%97%B6%205000%20%5B83.381859%5D%20CMD_RESP%20(83.362563)%EF%BC%9A%3CBR%20%2F%3EAMSDU_AGGR_CTRL%20%5B0x80df%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200xc%3CBR%20%2F%3E%5B%2083.381908%5D%20DNLD_CMD%20(83.362624)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200xd%20%E8%B6%85%E6%97%B6%205000%20%5B83.382235%5D%20CMD_RESP%20(83.362940)%EF%BC%9A%3CBR%20%2F%3EMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200xd%3CBR%20%2F%3E%5B%2083.382289%5D%20QUEUE_CMD%3A%20APCMD_SYS_CONFIGURE%20%5B0xb0%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.382328%5D%20DNLD_CMD%20(83.363045)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x100e%20%E8%B6%85%E6%97%B6%205000%20%5B83.383416%5D%20CMD_RESP%20(83.364108)%EF%BC%9A%3CBR%20%2F%3EAPCMD_SYS_CONFIGURE%20%5B0x80b0%5D%2C%20result%200%2C%20len%2020%2C%20seqno%200x100e%3CBR%20%2F%3E%5B%2083.383478%5D%20QUEUE_CMD%3A%20TX_RATE_CFG%20%5B0xd6%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.383510%5D%20QUEUE_CMD%3A%20802_11_RF_TX_POWER%20%5B0x1e%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.383539%5D%20QUEUE_CMD%3A%20AMSDU_AGGR_CTRL%20%5B0xdf%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%20%5B%2083.383567%5D%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x1e%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F383539%5D%20QUEUE_CMD%3A%20AMSDU_AGGR_CTRL%20%5B0xdf%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.383567%5D%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.383593%5D%20QUEUE_CMD%3A%20802_11_MAC_ADDRESS%20%5B0x4d%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.383630%5D%20DNLD_CMD%20(83.364347)%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2076%EF%BC%8Cseqno%200x200f%20%E8%B6%85%E6%97%B6%205000%20%5B83.387943%5D%20CMD_RESP%20(83.368633)%EF%BC%9A%3CBR%20%2F%3ETX_RATE_CFG%20%5B0x80d6%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20832%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x200f%20%5B83.388009%5D%20DNLD_CMD%20(83.368722)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2010%20%E8%B6%85%E6%97%B6%205000%20%3CBR%20%2F%3E%20%5B83.388382%5D%20CMD_POWER%20%5B0x1e%5D%20RESP%20(83.369085)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x801e%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8C%E7%AC%AC%2014%20%E8%A1%8C%EF%BC%8C%E5%BA%8F%E5%88%97%200x2010%20%5B83.388433%5D%20DNLD_CMD%20(83.369149)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3EAMSDU_AGGR_CTRL%20%5B0xdf%5D%EF%BC%8Cact%200x1%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2011%20%E8%B6%85%E6%97%B6%205000%20%5B83.38775%5D%20CMD_RESP%20(83.369478)%EF%BC%9A%3CBR%20%2F%3EAMSDU_AGGR_CTRL%20%5B0x80df%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2011%3CBR%20%2F%3E%5B%2083.388825%5D%20DNLD_CMD%20(83.369541)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200x2012%20%E8%B6%85%E6%97%B6%205000%20%5B83.389139%5D%20CMD_RESP%20(83.369844)%EF%BC%9A%3CBR%20%2F%3EMAC_CONTROL%20%5B0x8028%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2012%3CBR%20%2F%3E%5B%2083.389187%5D%20DNLD_CMD%20(83.369904)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2016%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x2013%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.389639%5D%20CMD_RESP%20(83.370340)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2013%3CBR%20%2F%3E%5B%2083.389700%5D%20QUEUE_CMD%EF%BC%9AWMM_PARAM_CONFIG%20%5B0x23a%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.389749%5D%20DNLD_CMD%20(83.370464)%EF%BC%9AWMM_PARAM_CONFIG%20%5B0x23a%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x2%E3%80%81len%2026%E3%80%81seqno%200x14%20%E8%B6%85%E6%97%B6%205000%20%5B83.390091%5D%20CMD_RESP%20(83.370793)%EF%BC%9A%3CBR%20%2F%3EWMM_PARAM_CONFIG%20%5B0x823a%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2026%EF%BC%8C%E5%BA%8F%E5%88%97%200x14%3CBR%20%2F%3E%5B%2083.392977%5D%20%E8%AE%BE%E7%BD%AE%20wiphy%20max_ap_assoc_sta%3D8%3CBR%20%2F%3E%5B%2083.393072%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%2083.393089%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%2083.393108%5D%20vht_cap%3D0x33d07030%20rx_mcs_map%3D0xfffe%20rx_max%3D0x186%20tx_mcs_map%3D0xfffe%20tx_max%3D0x186%3CBR%20%2F%3E%5B%2083.393129%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%2083.393139%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%2083.393155%5D%20vht_cap%3D0x33d07030%20rx_mcs_map%3D0xfffe%20rx_max%3D0x186%20tx_mcs_map%3D0xfffe%20tx_max%3D0x186%3CBR%20%2F%3E%5B%2083.393191%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.407537%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.388260)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x15%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.408034%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.388756)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x15%3CBR%20%2F%3E%5B%2083.408202%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.408278%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.389008)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%20142%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x16%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.408707%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.389430)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20142%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x16%3CBR%20%2F%3E%5B%2083.408860%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.408930%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.389661)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x0%E3%80%81len%20142%E3%80%81seqno%200x17%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.409425%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.390146)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x17%3CBR%20%2F%3E%5B%2083.409582%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.409653%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.390383)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%20142%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x18%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.410075%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.390798)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x18%3CBR%20%2F%3E%5B%2083.410606%5D%20cfg80211%20%E7%9B%91%E7%AE%A1%E5%9F%9F%E5%9B%9E%E8%B0%83%2000%20%E5%90%AF%E5%8A%A8%E5%99%A8%3D0%20dfs_region%3D0%3CBR%20%2F%3E%5B%2083.410668%5D%20%E7%9B%91%E7%AE%A1%E5%9F%9F%20BY_CORE%3CBR%20%2F%3E%5B%2083.410738%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.410973%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.391699)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x19%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.411461%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.392183)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x19%3CBR%20%2F%3E%5B%2083.411802%5D%20PS%20%E5%91%BD%E4%BB%A4%EF%BC%9A%E5%8A%A8%E4%BD%9C%20%3D%200x0%EF%BC%8C%E4%BD%8D%E5%9B%BE%20%3D%200x0%3CBR%20%2F%3E%5B%2083.411833%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.411914%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.392643)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x0%E3%80%81len%2012%E3%80%81seqno%200x1a%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.412367%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.393090)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2068%EF%BC%8Cseqno%200x1a%3CBR%20%2F%3E%5B%2083.412416%5D%20ps_bitmap%3D0x0%3CBR%20%2F%3E%5B%2083.412535%5D%20CFG80211%EF%BC%9ACountry%3D00%EF%BC%8Cband%3D0%EF%BC%8Cno_of_sub_band%3D1%3CBR%20%2F%3E%5B%2083.412577%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.412633%5D%2011D%3ACountry%3DWW%20band%3D0%20sub-band%3D1%20dfs_region%3D0%3CBR%20%2F%3E%5B%2083.412650%5D%2011D%3A%20first%20chan%3D1%20no_of_chan%3D14%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.412665%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.412694%5D%20wlan_set_regiontable%EF%BC%9A2.4G%200x0%3CBR%20%2F%3E%5B%2083.412718%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%3CBR%20%2F%3E%5B%2083.412794%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.393523)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2016%E3%80%81seqno%200x1b%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.413234%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.393957)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E5%BA%8F%E5%88%97%200x1b%3CBR%20%2F%3E%5B%2083.413292%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.394022)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2032%EF%BC%8Cseqno%200x1c%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.413739%5D%20wlan%25d%EF%BC%9A83.394463%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.413802%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xe808%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.413827%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.431747%5D%20wlan%25d%EF%BC%9A83.412467%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.431826%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xea60%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.431855%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.432517%5D%20wlan%25d%EF%BC%9A83.413237%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.432590%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xecb8%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.432617%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.433205%5D%20wlan%25d%EF%BC%9A83.413926%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.433276%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xef10%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.433301%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.434255%5D%20wlan%25d%EF%BC%9A83.414977%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.434325%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf168%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.434348%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.434915%5D%20wlan%25d%EF%BC%9A83.415636%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.434987%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf3c0%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.435010%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.435581%5D%20wlan%25d%EF%BC%9A83.416302%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.435652%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf618%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.435675%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.436242%5D%20wlan%25d%EF%BC%9A83.416962%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.436313%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf870%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.436338%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.436923%5D%20wlan%25d%EF%BC%9A83.417645%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.436995%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xfac8%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.437019%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.451150%5D%20wlan%25d%EF%BC%9A83.431867%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.451232%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xc4e0%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.451260%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.469048%5D%20wlan%25d%EF%BC%9A83.449766%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.469131%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xc738%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.469158%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.469811%5D%20wlan%25d%EF%BC%9A83.450531%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.469883%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xc990%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.469909%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.470486%5D%20wlan%25d%EF%BC%9A83.451207%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.470558%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xcbe8%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.470584%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.471148%5D%20wlan%25d%EF%BC%9A83.451869%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.471220%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xce40%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.471247%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.471960%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.452682)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2032%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x1c%3CBR%20%2F%3E%5B%2083.472106%5D%20CFG80211%EF%BC%9ACountry%3D00%EF%BC%8Cband%3D1%EF%BC%8Cno_of_sub_band%3D25%3CBR%20%2F%3E%5B%2083.472166%5D%2011D%3ACountry%3DWW%20band%3D1%20%E5%AD%90%E6%B3%A2%E6%AE%B5%20%3D25%20dfs_region%3D0%3CBR%20%2F%3E%5B%2083.472182%5D%2011D%3A%20first%20chan%3D36%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472194%5D%2011D%3A%20first%20chan%3D40%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472205%5D%2011D%3A%20first%20chan%3D44%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472216%5D%2011D%3A%20first%20chan%3D48%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472227%5D%2011D%3A%20first%20chan%3D52%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472239%5D%2011D%3A%20first%20chan%3D56%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472249%5D%2011D%3A%20first%20chan%3D60%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472261%5D%2011D%3A%20first%20chan%3D64%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472272%5D%2011D%3A%20first%20chan%3D100%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472284%5D%2011D%3A%20first%20chan%3D104%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472295%5D%2011D%3A%20first%20chan%3D108%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472307%5D%2011D%3A%20first%20chan%3D112%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472318%5D%2011D%3A%20first%20chan%3D116%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472330%5D%2011D%3A%20first%20chan%3D120%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472341%5D%2011D%3A%20first%20chan%3D124%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472353%5D%2011D%3A%20first%20chan%3D128%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472365%5D%2011D%3A%20first%20chan%3D132%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472376%5D%2011D%3A%20first%20chan%3D136%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472388%5D%2011D%3A%20first%20chan%3D140%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472399%5D%2011D%3A%20first%20chan%3D144%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472411%5D%2011D%3A%20first%20chan%3D149%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472422%5D%2011D%3A%20first%20chan%3D153%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472434%5D%2011D%3A%20first%20chan%3D157%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472446%5D%2011D%3A%20first%20chan%3D161%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472457%5D%2011D%3A%20first%20chan%3D165%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.472475%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.472507%5D%20wlan_set_regiontable%EF%BC%9A2.4G%200x0%3CBR%20%2F%3E%5B%2083.472526%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%3CBR%20%2F%3E%5B%2083.472603%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.453331)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%20104%E3%80%81seqno%200x1d%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.494139%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.474857)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20104%EF%BC%8Cseqno%200x1d%3CBR%20%2F%3E%5B%2083.494780%5D%20%E8%AE%BE%E7%BD%AE%20wlan%25d%20%E6%8E%A5%E5%8F%A3%E5%9C%B0%E5%9D%80%EF%BC%9A30%3AXX%3AXX%3AXX%3A8c%3A11%3CBR%20%2F%3E%5B%2083.494841%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.494928%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.475657)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4D%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2016%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x1e%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.495415%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.476138)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x1e%3CBR%20%2F%3E%5B%2083.497089%5D%20%E6%B3%A8%E5%86%8C%20NXP%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20wlan0%3CBR%20%2F%3E%5B%2083.497471%5D%20uap%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A11AX_CFG%20%5B0x266%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.497582%5D%20wlan0%20set%20multicast_list%3CBR%20%2F%3E%5B%2083.497622%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.497654%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.509486%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(83.490204)%EF%BC%9A11AX_CFG%20%5B0x266%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2039%E3%80%81seqno%200x101f%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.510032%5D%20wlan0%EF%BC%9A83.490754%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.510109%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xfd20%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.510135%5D%20wlan0%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.528293%5D%20wlan0%EF%BC%9A83.509009%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.528377%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xff78%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.528405%5D%20wlan0%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.529075%5D%20wlan0%EF%BC%9A83.509795%EF%BC%9A%E6%B4%BB%E5%8A%A8%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.529151%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x101d0%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.529176%5D%20wlan0%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.529781%5D%20wlan0%EF%BC%9A83.510504%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.529849%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x10428%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.529871%5D%20wlan0%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.530444%5D%20wlan0%EF%BC%9A83.511164%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.530517%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x10680%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.530541%5D%20wlan0%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.531107%5D%20wlan0%EF%BC%9A83.511826%EF%BC%9A%E6%B4%BB%E5%8A%A8%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%2083.531178%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x108d8%20len%20%3D%20600%3CBR%20%2F%3E%5B%2083.531202%5D%20wlan0%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%3CBR%20%2F%3E%5B%2083.531884%5D%20uap%25d%EF%BC%9ACMD_RESP%20(83.512604)%EF%BC%9A11AX_CFG%20%5B0x8266%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2039%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x101f%3CBR%20%2F%3E%5B%2083.531948%5D%20user_2g_hecap_len%3D28%3CBR%20%2F%3E%5B%2083.531997%5D%20wlan0%EF%BC%9ADNLD_CMD%20(83.512726)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%20204%E3%80%81seqno%200x20%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.532430%5D%20wlan0%EF%BC%9ACMD_RESP%20(83.513154)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x20%3CBR%20%2F%3E%5B%2083.532484%5D%20wlan0%3A%20DNLD_CMD%20(83.513216)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81act%200x213%E3%80%81len%2012%E3%80%81seqno%200x21%20%E8%B6%85%E6%97%B6%205000%20%3CBR%20%2F%3E%20%5B83.532797%5D%20wlan0%EF%BC%9ACMD_RESP%20(83.513521)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8C%E5%BA%8F%E5%88%97%200x21%20%5B83.532964%5D%20uap%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A11AX_CFG%20%5B0x266%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%3CBR%20%2F%3E%20%5B83.533051%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(83.513779)%EF%BC%9A11AX_CFG%20%5B0x266%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2039%EF%BC%8Cseqno%200x1022%20%E8%B6%85%E6%97%B6%205000%20%5B83.533496%5D%20uap%25d%EF%BC%9ACMD_RESP%20(83.514218)%EF%BC%9A11AX_CFG%20%3CBR%20%2F%3E%20%5B0x8266%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2039%EF%BC%8Cseqno%200x1022%20%5B83.533548%5D%20user_hecap_len%3D28%20%5B83.539872%5D%20%E8%AE%BE%E7%BD%AE%20uap%25d%20%E6%8E%A5%E5%8F%A3%E5%9C%B0%E5%9D%80%EF%BC%9A32%3Axx%3Axx%3Axx%3A8d%3A11%20%5B83.539937%5D%20uap%25d%EF%BC%9AQUEUE_CMD%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%3CBR%20%2F%3E%20%5B83.540028%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(83.520757)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%E3%80%81act%200x1%E3%80%81len%2020%E3%80%81seqno%200x1023%20%E8%B6%85%E6%97%B6%205000%20%5B83.540517%5D%20uap%25d%EF%BC%9ACMD_RESP%20(83.521240)%EF%BC%9A%3CBR%20%2F%3EAPCMD_SYS_CONFIGURE%20%5B0x80b0%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2020%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x1023%3CBR%20%2F%3E%5B%2083.542165%5D%20%E6%B3%A8%E5%86%8C%E6%81%A9%E6%99%BA%E6%B5%A6%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20uap0%3CBR%20%2F%3E%5B%2083.542494%5D%20PS%20%E5%91%BD%E4%BB%A4%EF%BC%9A%E6%93%8D%E4%BD%9C%20%3D%200x0%EF%BC%8C%E4%BD%8D%E5%9B%BE%20%3D%200x0%3CBR%20%2F%3E%5B%2083.542521%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.542607%5D%20uap0%20%E8%AE%BE%E7%BD%AE%E5%A4%9A%E6%92%AD%E5%88%97%E8%A1%A8%3CBR%20%2F%3E%5B%2083.543135%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(83.523858)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2024%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.543643%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(83.524364)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2068%EF%BC%8C%E5%BA%8F%E5%88%97%200x2024%3CBR%20%2F%3E%5B%2083.543693%5D%20ps_bitmap%3D0x0%3CBR%20%2F%3E%5B%2083.543799%5D%20CFG80211%EF%BC%9ACountry%3D00%EF%BC%8Cband%3D0%EF%BC%8Cno_of_sub_band%3D1%3CBR%20%2F%3E%5B%2083.543841%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.543895%5D%2011D%EF%BC%9ACountry%3DWW%20band%3D0%20sub-band%3D1%20dfs_region%3D0%3CBR%20%2F%3E%5B%2083.543910%5D%2011D%EF%BC%9Afirst%20chan%3D1%20no_of_chan%3D14%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.543925%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.543954%5D%20wlan_set_regiontable%EF%BC%9A2.4G%200x0%3CBR%20%2F%3E%5B%2083.543973%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%3CBR%20%2F%3E%5B%2083.544059%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(83.524786)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2025%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.544517%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(83.525239)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2025%3CBR%20%2F%3E%5B%2083.544580%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(83.525310)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2032%EF%BC%8Cseqno%200x2026%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.566231%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(83.546947)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2032%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2026%3CBR%20%2F%3E%5B%2083.566411%5D%20CFG80211%EF%BC%9ACountry%3D00%EF%BC%8Cband%3D1%EF%BC%8Cno_of_sub_band%3D25%3CBR%20%2F%3E%5B%2083.566474%5D%2011D%EF%BC%9ACountry%3DWW%20band%3D1%20sub-band%3D25%20dfs_region%3D0%3CBR%20%2F%3E%5B%2083.566489%5D%2011D%EF%BC%9Afirst%20chan%3D36%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566501%5D%2011D%EF%BC%9Afirst%20chan%3D40%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566513%5D%2011D%EF%BC%9Afirst%20chan%3D44%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566524%5D%2011D%EF%BC%9Afirst%20chan%3D48%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566535%5D%2011D%EF%BC%9Afirst%20chan%3D52%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566546%5D%2011D%EF%BC%9Afirst%20chan%3D56%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566557%5D%2011D%EF%BC%9Afirst%20chan%3D60%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566569%5D%2011D%EF%BC%9Afirst%20chan%3D64%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566580%5D%2011D%EF%BC%9Afirst%20chan%3D100%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566592%5D%2011D%EF%BC%9Afirst%20chan%3D104%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566604%5D%2011D%EF%BC%9Afirst%20chan%3D108%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566615%5D%2011D%EF%BC%9Afirst%20chan%3D112%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566627%5D%2011D%EF%BC%9Afirst%20chan%3D116%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566638%5D%2011D%EF%BC%9Afirst%20chan%3D120%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566650%5D%2011D%EF%BC%9Afirst%20chan%3D124%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566661%5D%2011D%EF%BC%9Afirst%20chan%3D128%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566673%5D%2011D%EF%BC%9Afirst%20chan%3D132%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566685%5D%2011D%EF%BC%9Afirst%20chan%3D136%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566696%5D%2011D%EF%BC%9Afirst%20chan%3D140%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566708%5D%2011D%EF%BC%9Afirst%20chan%3D144%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566720%5D%2011D%EF%BC%9Afirst%20chan%3D149%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566731%5D%2011D%EF%BC%9Afirst%20chan%3D153%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566743%5D%2011D%EF%BC%9Afirst%20chan%3D157%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566755%5D%2011D%EF%BC%9Afirst%20chan%3D161%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566767%5D%2011D%EF%BC%9Afirst%20chan%3D165%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%2083.566784%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.566815%5D%20wlan_set_regiontable%EF%BC%9A2.4G%200x0%3CBR%20%2F%3E%5B%2083.566835%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%3CBR%20%2F%3E%5B%2083.566911%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(83.547640)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%20104%EF%BC%8Cseqno%200x2027%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.588510%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(83.569226)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20104%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2027%3CBR%20%2F%3E%5B%2083.598432%5D%20%E8%AE%BE%E7%BD%AE%20WFD%20%E8%AE%BE%E5%A4%87%E5%9C%B0%E5%9D%80%EF%BC%9A32%3AXX%3AXX%3AXX%3A8c%3A11%3CBR%20%2F%3E%5B%2083.598498%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.598592%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(83.579322)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2028%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.599075%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(83.579798)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2028%3CBR%20%2F%3E%5B%2083.600896%5D%20%E6%B3%A8%E5%86%8C%E6%81%A9%E6%99%BA%E6%B5%A6%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20p2p0%3CBR%20%2F%3E%5B%2083.601044%5D%20wlan%EF%BC%9Aversion%20%3D%20SDIW612---18.99.3.p26.11-MM6X18540.p17-(FP92)%3CBR%20%2F%3E%5B%2083.601125%5D%20wlan0%3A%20QUEUE_CMD%3A%20REG_ACCESS%20%5B0x27c%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.601706%5D%20p2p0%20set%20multicast_list%3CBR%20%2F%3E%5B%2083.601758%5D%20p2p0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.601798%5D%20p2p0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.601862%5D%20wlan0%3A%20DNLD_CMD%20(83.582592)%EF%BC%9AREG_ACCESS%20%5B0x27c%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x0%E3%80%81len%2020%E3%80%81seqno%200x29%20%E8%B6%85%E6%97%B6%205000%20%5B83.602352%5D%20wlan0%EF%BC%9ACMD_RESP%20(83.583074)%EF%BC%9A%3CBR%20%2F%3EREG_ACCESS%20%5B0x827c%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x29%3CBR%20%2F%3E%5B%2083.602435%5D%20p2p0%3A%20DNLD_CMD%20(83.583164)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%20204%E3%80%81seqno%200x202a%20%E8%B6%85%E6%97%B6%205000%20%5B83.602875%5D%20p2p0%EF%BC%9ACMD_RESP%20(83.583599)%EF%BC%9A%3CBR%20%2F%3EMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x202a%3CBR%20%2F%3E%5B%2083.602933%5D%20p2p0%3A%20DNLD_CMD%20(83.583663)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200x202b%20%E8%B6%85%E6%97%B6%205000%20%5B83.603253%5D%20p2p0%EF%BC%9ACMD_RESP%20(83.583977)%EF%BC%9A%3CBR%20%2F%3EMAC_CONTROL%20%5B0x8028%5D%2C%20result%200%2C%20len%2012%2C%20seqno%200x202b%3CBR%20%2F%3E%5B%2083.649540%5D%20%E8%AE%BE%E7%BD%AE%20REG%200x90002328%3A%200x13d57%20slew_rate%3D3%3CBR%20%2F%3E%5B%2083.649608%5D%20wlan0%3A%20QUEUE_CMD%3A%20REG_ACCESS%20%5B0x27c%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2083.649704%5D%20wlan0%3A%20DNLD_CMD%20(83.630433)%EF%BC%9AREG_ACCESS%20%5B0x27c%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2020%E3%80%81seqno%200x2c%20%E8%B6%85%E6%97%B6%205000%20%3CBR%20%2F%3E%20%5B83.650198%5D%20wlan0%EF%BC%9ACMD_RESP%20(83.630922)%EF%BC%9AREG_ACCESS%20%5B0x827c%5D%2C%20result%200%2C%20len%2020%2C%20seqno%200x2c%3CBR%20%2F%3E%5B%2083.650381%5D%20wlan0%3A%20QUEUE_CMD%3A%20INDEPENDENT_RESET_CFG%20%5B0x243%5D%20is%20queued%3CBR%20%2F%3E%5B%2083.650456%5D%20wlan0%3A%20DNLD_CMD%20(83.631187)%EF%BC%9AINDEPENDENT_RESET_CFG%20%5B0x243%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2d%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2083.650885%5D%20wlan0%EF%BC%9ACMD_RESP%20(83.631608)%EF%BC%9AINDEPENDENT_RESET_CFG%20%5B0x8243%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2d%20%5B83.651544%5D%20wlan%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%88%B0%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%AE%8C%E6%88%90%20%3CBR%20%2F%3E%20%5B83.651568%5D%20wlan%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%88%90%E5%8A%9F%E5%8A%A0%E8%BD%BD%20%5B91.250327%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%3CBR%20%2F%3E%20%5B91.250455%5D%20wlan%20lan0%EF%BC%9ADNLD_CMD%20(91.231183)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3ETXPWR_CFG%20%5B0xd1%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2e%20%E8%B6%85%E6%97%B6%205000%20%5B91.250979%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.231700)%EF%BC%9A%3CBR%20%2F%3ETXPWR_CFG%20%5B0x80d1%5D%2C%20result%200%2C%20len%20140%2C%20seqno%200x2e%3CBR%20%2F%3E%5B%2091.251505%5D%20wlan0%3A%20QUEUE_CMD%3A%20TXPWR_CFG%20%5B0xd1%5D%20is%20queued%3CBR%20%2F%3E%5B%2091.251610%5D%20wlan0%3A%20DNLD_CMD%20(91.232338)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2f%20%E8%B6%85%E6%97%B6%205000%20%5B91.252073%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.232795)%EF%BC%9A%3CBR%20%2F%3ETXPWR_CFG%20%5B0x80d1%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20140%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2f%20%5B91.256518%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%3CBR%20%2F%3E%20%5B91.256644%5D%20wlan0%EF%BC%9ADNLD_CMD%20(91.237371)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20x20%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200xc%E3%80%81len%2016%E3%80%81seqno%200x30%20%E8%B6%85%E6%97%B6%205000%20%5B91.257138%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.237860)%EF%BC%9A802_11_RF_ANTENNA%20%3CBR%20%2F%3E%20%5B0x8020%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x30%20%5B91.262751%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B91.262879%5D%20wlan0%EF%BC%9ADNLD_CMD%20(91.243606)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3ETXPWR_CFG%20%5B0xd1%5D%E3%80%81act%200x0%E3%80%81len%2016%E3%80%81seqno%200x31%20%E8%B6%85%E6%97%B6%205000%20%5B91.263360%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.244082)%EF%BC%9A%3CBR%20%2F%3ETXPWR_CFG%20%5B0x80d1%5D%2C%20result%200%2C%20len%20140%2C%20seqno%200x31%3CBR%20%2F%3E%5B%2091.263875%5D%20wlan0%3A%20QUEUE_CMD%3A%20TXPWR_CFG%20%5B0xd1%5D%20is%20queued%3CBR%20%2F%3E%5B%2091.263981%5D%20wlan0%3A%20DNLD_CMD%20(91.244710)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x32%20%E8%B6%85%E6%97%B6%205000%20%5B91.264440%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.245161)%EF%BC%9A%3CBR%20%2F%3ETXPWR_CFG%20%5B0x80d1%5D%2C%20result%200%2C%20len%20140%2C%20seqno%200x32%3CBR%20%2F%3E%5B%2091.273598%5D%20wlan0%3A%20QUEUE_CMD%3A%20RX_MGMT_IND%20%5B0x10c%5D%20is%20queued%3CBR%20%2F%3E%5B%2091.273755%5D%20wlan0%3A%20DNLD_CMD%20(91.254481)%EF%BC%9ARX_MGMT_IND%20%5B0x10c%5D%E3%80%81act%200x1%E3%80%81len%2014%E3%80%81seqno%200x33%20%E8%B6%85%E6%97%B6%205000%20%5B91.274249%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.254971)%EF%BC%9A%3CBR%20%2F%3ERX_MGMT_IND%20%5B0x810c%5D%2C%20result%200%2C%20len%2014%2C%20seqno%200x33%3CBR%20%2F%3E%5B%2091.285501%5D%20wlan0%3A%20QUEUE_CMD%3A%20TXPWR_CFG%20%5B0xd1%5D%20is%20queued%3CBR%20%2F%3E%5B%2091.285628%5D%20wlan0%3A%20DNLD_CMD%20(91.266356)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%E3%80%81act%200x0%E3%80%81len%2016%E3%80%81seqno%200x34%20%E8%B6%85%E6%97%B6%205000%20%5B91.286112%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.266833)%EF%BC%9A%3CBR%20%2F%3ETXPWR_CFG%20%5B0x80d1%5D%2C%20result%200%2C%20len%20140%2C%20seqno%200x34%3CBR%20%2F%3E%5B%2091.286736%5D%20wlan0%20set%20multicast_list%3CBR%20%2F%3E%5B%2091.286794%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20is%20queued%3CBR%20%2F%3E%5B%2091.286835%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20is%20queued%3CBR%20%2F%3E%5B%2091.286916%5D%20wlan0%3A%20DNLD_CMD%20(91.267643)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81act%200x1%E3%80%81len%20204%E3%80%81seqno%200x35%20%E8%B6%85%E6%97%B6%205000%20%5B91.287407%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.268128)%EF%BC%9A%3CBR%20%2F%3EMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x35%3CBR%20%2F%3E%5B%2091.287469%5D%20wlan0%3A%20DNLD_CMD%20(91.268199)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81act%200x213%E3%80%81len%2012%E3%80%81seqno%200x36%20%E8%B6%85%E6%97%B6%205000%20%3CBR%20%2F%3E%20%5B91.287894%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.268617)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8C%E5%BA%8F%E5%88%97%200x36%3CBR%20%2F%3E%5B%2091.297629%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%2091.297755%5D%20wlan0%EF%BC%9ADNLD_CMD%20(91.278484)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200xc%EF%BC%8Clen%2016%EF%BC%8C%E5%BA%8F%E5%88%97%200x37%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%2091.298244%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.278966)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x37%3CBR%20%2F%3E%5B%20112.909482%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9AMGMT_IE_LIST%20%5B0xf2%5D%20%E6%98%AF%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20112.909610%5D%20wlan0%EF%BC%9ADNLD_CMD%20(112.890335)%EF%BC%9AMGMT_IE_LIST%20%5B0xf2%5D%E3%80%81act%200x1%E3%80%81len%20127%E3%80%81seqno%200x38%20%E8%B6%85%E6%97%B6%205000%20%5B112.910138%5D%20wlan0%EF%BC%9ACMD_RESP%20(112.890857)%EF%BC%9A%3CBR%20%2F%3EMGMT_IE_LIST%20%5B0x80f2%5D%2C%20result%200%2C%20len%20127%2C%20seqno%200x38%3CBR%20%2F%3E%5B%20112.910277%5D%20probereq%20ie%20length%20%3D%20107%3CBR%20%2F%3E%5B%20112.910302%5D%20beacon%3Dffffff%20assocresp%3Dffff%20proberesp%3Dffff%20probereq%3D0%3CBR%20%2F%3E%5B%20112.910324%5D%20wlan%3Arandom_mac%2000%3AXX%3AXX%3AXX%3A00%3A00%3CBR%20%2F%3E%5B%20112.910848%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%20112.910869%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%20112.910887%5D%20Set%EF%BC%9AHE%20rx%20mcs%20set%200x0000fffe%20tx%20mcs%20set%200x0000fffe%3CBR%20%2F%3E%5B%20112.910946%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%20112.910957%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%20112.910972%5D%20Set%EF%BC%9AHE%20rx%20mcs%20set%200x0000fffe%20tx%20mcs%20set%200x0000fffe%3CBR%20%2F%3E%5B%20112.911000%5D%20wlan0%3A%20QUEUE_CMD%3A%20802_11_SCAN_EXT%20%5B0x107%5D%20is%20queued%3CBR%20%2F%3E%5B%20112.911052%5D%20wlan%3A%20wlan0%20START%20SCAN%3CBR%20%2F%3E%5B%20112.911216%5D%20wlan0%3A%20DNLD_CMD%20(112.891939)%EF%BC%9A802_11_SCAN_EXT%20%5B0x107%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%20266%E3%80%81seqno%200x39%20%E8%B6%85%E6%97%B6%2020000%20%5B112.921346%5D%20wlan0%EF%BC%9ACMD_RESP%20(112.902062)%EF%BC%9A%3CBR%20%2F%3E802_11_SCAN_EXT%20%5B0x8107%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x39%3CBR%20%2F%3E%5B%20132.979298%5D%20Ext%20scan%20enh%20%E8%B6%85%E6%97%B6%3CBR%20%2F%3E%5B%20132.979336%5D%20------------Dump%20info-----------%3CBR%20%2F%3E%5B%20132.979347%5D%20EXT_SCAN_STATUS%20%E4%BA%8B%E4%BB%B6%E8%B6%85%E6%97%B6%3CBR%20%2F%3E%5B%20132.979360%5D%20CurCmd%20Empty%3CBR%20%2F%3E%5B%20132.979372%5D%20mlan_processing%20%3D0%3CBR%20%2F%3E%5B%20132.979382%5D%20main_lock_flag%20%3D0%3CBR%20%2F%3E%5B%20132.979392%5D%20main_process_cnt%20%3D125%3CBR%20%2F%3E%5B%20132.979401%5D%20delay_task_flag%20%3D0%3CBR%20%2F%3E%5B%20132.979410%5D%20mlan_rx_processing%20%3D0%3CBR%20%2F%3E%5B%20132.979419%5D%20rx_pkts_queued%3D0%3CBR%20%2F%3E%5B%20132.979428%5D%20more_task_flag%20%3D%200%3CBR%20%2F%3E%5B%20132.979437%5D%20num_cmd_timeout%20%3D%200%3CBR%20%2F%3E%5B%20132.979446%5D%20last_cmd_index%20%3D%207%3CBR%20%2F%3E%5B%20132.979455%5D%20last_cmd_id%20%3D%200xd1%200x10c%200xd1%200x10%200x28%200x20%200xf2%200x107%200x20%200xd1%3CBR%20%2F%3E%5B%20132.979499%5D%20last_cmd_act%20%3D%200x0%200x1%200x0%200x1%200x213%200xc%200x1%200x1%200xc%200x0%3CBR%20%2F%3E%5B%20132.979535%5D%20last_cmd_resp_index%20%3D%207%3CBR%20%2F%3E%5B%20132.979544%5D%20last_cmd_resp_id%20%3D%200x80d1%200x810c%200x80d1%200x8010%200x8028%200x8020%200x80f2%200x8107%200x8020%200x80d1%3CBR%20%2F%3E%5B%20132.979583%5D%20last_event_index%20%3D%201%3CBR%20%2F%3E%5B%20132.979592%5D%20last_event%20%3D%200x81%200x81%200x81%200x81%200x81%200x81%200x81%200x81%3CBR%20%2F%3E%5B%20132.979630%5D%20num_data_h2c_failure%20%3D%200%3CBR%20%2F%3E%5B%20132.979642%5D%20num_cmd_h2c_failure%20%3D%200%3CBR%20%2F%3E%5B%20132.979653%5D%20num_data_c2h_failure%20%3D%200%3CBR%20%2F%3E%5B%20132.979663%5D%20num_cmdevt_c2h_failure%20%3D%200%3CBR%20%2F%3E%5B%20132.979673%5D%20num_int_read_failure%20%3D%200%3CBR%20%2F%3E%5B%20132.979683%5D%20last_int_status%20%3D%2064%3CBR%20%2F%3E%5B%20132.979692%5D%20num_alloc_buffer_failure%20%3D%200%3CBR%20%2F%3E%5B%20132.979701%5D%20num_pkt_dropped%20%3D%200%3CBR%20%2F%3E%5B%20132.979710%5D%20num_noo_cmd_node%20%3D%200%3CBR%20%2F%3E%5B%20132.979719%5D%20num_event_deauth%20%3D%200%3CBR%20%2F%3E%5B%20132.979728%5D%20num_event_disassoc%20%3D%200%3CBR%20%2F%3E%5B%20132.979737%5D%20num_event_link_lost%20%3D%200%3CBR%20%2F%3E%5B%20132.979746%5D%20num_cmd_deauth%20%3D%200%3CBR%20%2F%3E%5B%20132.979756%5D%20num_cmd_assoc_success%20%3D%200%3CBR%20%2F%3E%5B%20132.979766%5D%20num_cmd_assoc_failure%20%3D%200%3CBR%20%2F%3E%5B%20132.979776%5D%20num_cons_assoc_failure%20%3D%200%3CBR%20%2F%3E%5B%20132.979785%5D%20cmd_resp_received%3D0%3CBR%20%2F%3E%5B%20132.979794%5D%20event_received%3D0%3CBR%20%2F%3E%5B%20132.979804%5D%20max_tx_buf_size%3D4096%3CBR%20%2F%3E%5B%20132.979813%5D%20tx_buf_size%3D3328%3CBR%20%2F%3E%5B%20132.979822%5D%20curr_tx_buf_size%3D3328%3CBR%20%2F%3E%5B%20132.979832%5D%20data_sent%3D0%20cmd_sent%3D0%3CBR%20%2F%3E%5B%20132.979843%5D%20ps_mode%3D0%20ps_state%3D0%3CBR%20%2F%3E%5B%20132.979855%5D%20wakeup_dev_req%3D0%20wakeup_tries%3D0%20wakeup_timeout%3D0%3CBR%20%2F%3E%5B%20132.979866%5D%20hs_configured%3D0%20hs_activated%3D0%3CBR%20%2F%3E%5B%20132.979877%5D%20pps_uapsd_mode%3D0%20sleep_pd%3D0%3CBR%20%2F%3E%5B%20132.979886%5D%20tx_lock_flag%20%3D%200%3CBR%20%2F%3E%5B%20132.979896%5D%20scan_processing%20%3D%201%3CBR%20%2F%3E%5B%20132.979906%5D%20scan_state%20%3D%200x5%3CBR%20%2F%3E%5B%20132.979915%5D%20bypass_pkt_count%3D0%3CBR%20%2F%3E%5B%20132.979927%5D%20mp_rd_bitmap%3D0x0%20curr_rd_port%3D0x0%3CBR%20%2F%3E%5B%20132.979939%5D%20mp_wr_bitmap%3D0xffffff%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%20132.979949%5D%20mp_data_port_mask%20%3D%200xffffffff%3CBR%20%2F%3E%5B%20132.979960%5D%20last_recv_rd_bitmap%3D0x0%20mp_invalid_update%3D0%3CBR%20%2F%3E%5B%20132.979972%5D%20last_recv_wr_bitmap%3D0xffffff%20last_mp_index%3D0%3CBR%20%2F%3E%5B%20132.979986%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%20132.979995%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%3CBR%20%2F%3E%5B%20132.980048%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%20132.980058%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%3CBR%20%2F%3E%5B%20132.980111%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%20132.980120%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%3CBR%20%2F%3E%5B%20132.980172%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%20132.980182%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%3CBR%20%2F%3E%5B%20132.980234%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%20132.980244%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%3CBR%20%2F%3E%5B%20132.980297%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%20132.980306%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%3CBR%20%2F%3E%5B%20132.980359%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%20132.980368%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%3CBR%20%2F%3E%5B%20132.980420%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%20132.980430%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%3CBR%20%2F%3E%5B%20132.980482%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%20132.980491%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%3CBR%20%2F%3E%5B%20132.980542%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%3CBR%20%2F%3E%5B%20132.980552%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%3CBR%20%2F%3E%5B%20132.980604%5D%20bss_index%20%3D%200%EF%BC%8Ctx_pkts_queued%20%3D%200%20tx_pause%3CBR%20%2F%3E%5B%20132.980619%5D%20bss_index%20%3D%201%EF%BC%8Ctx_pkts_queued%20%3D%200%20tx_pause%3CBR%20%2F%3E%5B%20132.980631%5D%20bss_index%20%3D%202%EF%BC%8Ctx_pkts_queued%20%3D%200%20tx_pause%3CBR%20%2F%3E%5B%20132.980647%5D%20bss_index%20%3D%203%2C%20tx_pkts_queued%20%3D%200%20tx_pause%3CBR%20%2F%3E%5B%20132.980663%5D%20event%20id%3A0x80000012%3CBR%20%2F%3E%5B%20132.980702%5D%20Host%3Abr03%20Timestamp%3Ac0623ac4%3CBR%20%2F%3E%5B%20132.980730%5D%20Driver%20version%20%3D%20SDIW612---18.99.3.p26.11-MM6X18540.p17-(FP92)%3CBR%20%2F%3E%5B132.980743%5D%20main_state%20%3D%204%3CBR%20%2F%3E%5B%20132.980753%5D%20ioctl_pending%20%3D%201%3CBR%20%2F%3E%5B%20132.980762%5D%20tx_pending%20%3D%200%3CBR%20%2F%3E%5B%20132.980772%5D%20wmm_tx_pending%5B0%5D%20%3D%200%3CBR%20%2F%3E%5B%20132.980781%5D%20wmm_tx_pending%5B1%5D%20%3D%200%3CBR%20%2F%3E%5B%20132.980790%5D%20wmm_tx_pending%5B2%5D%20%3D%200%3CBR%20%2F%3E%5B%20132.980800%5D%20wmm_tx_pending%5B3%5D%20%3D%200%3CBR%20%2F%3E%5B%20132.980810%5D%20rx_pending%20%3D%200%3CBR%20%2F%3E%5B%20132.980819%5D%20lock_count%20%3D%20111%3CBR%20%2F%3E%5B%20132.980828%5D%20malloc_count%20%3D%2052%3CBR%20%2F%3E%5B%20132.980837%5D%20mbufalloc_count%20%3D%200%3CBR%20%2F%3E%5B%20132.980846%5D%20hs_skip_count%20%3D%200%3CBR%20%2F%3E%5B%20132.980856%5D%20hs_force_count%20%3D%200%3CBR%20%2F%3E%5B%20132.980868%5D%20Media%20state%20%3D%20%22Disconnected%22%3CBR%20%2F%3E%5B%20132.980881%5D%20carrier%20off%3CBR%20%2F%3E%5B%20132.980894%5D%20tx%20queue%200%3A%20stopped%3CBR%20%2F%3E%5B%20132.980907%5D%20tx%20queue%201%3A%20stopped%3CBR%20%2F%3E%5B%20132.980920%5D%20tx%20queue%202%3A%20stopped%3CBR%20%2F%3E%5B%20132.980933%5D%20tx%20queue%203%3A%20stopped%3CBR%20%2F%3E%5B%20132.980946%5D%20wlan0%3A%20num_tx_timeout%20%3D%200%3CBR%20%2F%3E%5B%20132.980960%5D%20uap0%3A%20num_tx_timeout%20%3D%200%3CBR%20%2F%3E%5B%20132.980973%5D%20p2p0%3A%20num_tx_timeout%20%3D%200%3CBR%20%2F%3E%5B%20132.981005%5D%20--------%20Dump%20info%20End---------%3CBR%20%2F%3E%5B%20132.981063%5D%20Wakeup%20%E8%AE%BE%E5%A4%87...%3CBR%20%2F%3E%5B%20132.981682%5D%20SDIO%20Func0%20(0x0-0x9)%3A%2043%2003%2002%2002%2003%2002%2008%2002%2003%2000%3CBR%20%2F%3E%5B%20132.982016%5D%20SDIO%20Func1%20(0x10-0x17)%3A%2000%2000%2000%2000%20ff%20ff%20ff%20ff%3CBR%20%2F%3E%5B%20132.982575%5D%20SDIO%20Func1%3A%20(0x8)%20c3%20(0x58)%2000%20(0x5c)%2048%20(0x5d)%2000%20(0x60)%2087%20(0x61)%200c%20(0x62)%2000%20(0x64)%2010%20(0x65)%2000%20(0x66)%2000%20(0x68)%2000%20(0x69)%2000%20(0x6a)%2000%3CBR%20%2F%3E%5B%20132.983518%5D%20SDIO%20Func1%20(0xe8-0xff)%3A%20dc%20fe%2060%2000%2061%2000%2000%2000%2024%2014%2070%20c8%20ab%2077%2080%2000%2000%2000%2000%2000%2001%2000%2000%2000%3CBR%20%2F%3E%5B%20133.087775%5D%20SDIO%20Func1%20(0xe8-0xff)%3A%20dc%20fe%20c4%2000%206c%2000%2000%2000%2024%2014%2070%20c8%20ab%2077%2080%2000%2000%2000%2000%2000%2001%2000%2000%2000%3CBR%20%2F%3E%5B%20133.087808%5D%20Cancel%20all%20pending%20cmd%20and%20txrx%20queue%3CBR%20%2F%3E%5B%20133.087844%5D%20IOCTL%20failed%3A%20c5cf7800%20id%3D0x10000%2C%20sub_id%3D0x10003%20action%3D1%2C%20status_code%3D0x80000007%20%5BCMD_CANCEL%5D%3CBR%20%2F%3E%5B%20133.087864%5D%20flush%20scan%20queue%3A%20cmd%200x107%3CBR%20%2F%3E%5B%20133.087914%5D%20Wakeup%20%E8%AE%BE%E5%A4%87...%3CBR%20%2F%3E%5B%20133.088389%5D%20wlan0%3A%20133.069104%20%3A%20Event%3A%20EXT_SCAN_REPORT%20%5B0x58%5D%3CBR%20%2F%3E%5B%20133.088460%5D%20EVENT%3A%20EXT_SCAN%20Report%20(2416)%3CBR%20%2F%3E%5B%20133.088757%5D%20wlan0%3A%20133.069476%20%3A%20Event%3A%20EXT_SCAN_REPORT%20%5B0x58%5D%3CBR%20%2F%3E%5B%20133.088814%5D%20EVENT%3A%20EXT_SCAN%20Report%20(463)%3CBR%20%2F%3E%5B%20133.089067%5D%20wlan0%3A%20133.069787%20%3A%20Event%3A%20EXT_SCAN_STATUS_REPORT%20%5B0x7f%5D%3CBR%20%2F%3E%5B%20133.089121%5D%20EVENT%3A%20EXT_SCAN%20status%20report%20(151)%3CBR%20%2F%3E%5B%20133.089143%5D%20ext_scan_status%3A%20status%200%20(scan%20success)%2C%20buf_len%20144%3CBR%20%2F%3E%5B%20133.089163%5D%20chan%3D1%2C%20noise%3D-89%2C%20total_network%3D1%20scan_duration%3D78%2C%20busy_duration%3D37%3CBR%20%2F%3E%5B%20133.089181%5D%20chan%3D2%2C%20noise%3D-90%2C%20total_network%3D0%20scan_duration%3D78%2C%20busy_duration%3D32%3CBR%20%2F%3E%5B%20133.089198%5D%20chan%3D3%2C%20noise%3D-90%2C%20total_network%3D1%20scan_duration%3D78%2C%20busy_duration%3D23%3CBR%20%2F%3E%5B%20133.089213%5D%20chan%3D4%2C%20noise%3D-81%2C%20total_network%3D0%20scan_duration%3D78%2C%20busy_duration%3D12%3CBR%20%2F%3E%5B%20133.089229%5D%20chan%3D5%2C%20noise%3D-84%2C%20total_network%3D1%20scan_duration%3D78%2C%20busy_duration%3D30%3CBR%20%2F%3E%5B%20133.089246%5D%20chan%3D6%2C%20noise%3D-84%2C%20total_network%3D2%20scan_duration%3D78%2C%20busy_duration%3D52%3CBR%20%2F%3E%5B%20133.089261%5D%20chan%3D7%2C%20noise%3D-87%2C%20total_network%3D0%20scan_duration%3D78%2C%20busy_duration%3D17%3CBR%20%2F%3E%5B%20133.089358%5D%20chan%3D8%2C%20noise%3D-87%2C%20total_network%3D0%20scan_duration%3D78%2C%20busy_duration%3D12%3CBR%20%2F%3E%5B%20133.089375%5D%20chan%3D9%2C%20noise%3D-89%2C%20total_network%3D1%20scan_duration%3D78%2C%20busy_duration%3D27%3CBR%20%2F%3E%5B%20133.089392%5D%20chan%3D10%2C%20noise%3D-89%2C%20total_network%3D0%20scan_duration%3D78%2C%20busy_duration%3D27%3CBR%20%2F%3E%5B%20133.089409%5D%20chan%3D11%2C%20noise%3D-89%2C%20total_network%3D1%20scan_duration%3D78%2C%20busy_duration%3D41%3CBR%20%2F%3E%5B%20133.089425%5D%20chan%3D12%2C%20noise%3D-87%2C%20total_network%3D1%20scan_duration%3D78%2C%20busy_duration%3D32%3CBR%20%2F%3E%5B%20133.089440%5D%20chan%3D13%2C%20noise%3D-88%2C%20total_network%3D1%20scan_duration%3D78%2C%20busy_duration%3D32%3CBR%20%2F%3E%5B%20133.089456%5D%20chan%3D14%2C%20noise%3D-91%2C%20total_network%3D0%20scan_duration%3D78%2C%20busy_duration%3D8%3CBR%20%2F%3E%5B%20133.089479%5D%20chan%3D1%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-89%20min_rss%3D89%2C%20max_rss%3D89%3CBR%20%2F%3E%5B%20133.089496%5D%20chan%3D2%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-90%20min_rss%3D90%2C%20max_rss%3D90%3CBR%20%2F%3E%5B%20133.089511%5D%20chan%3D3%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-90%20min_rss%3D90%2C%20max_rss%3D90%3CBR%20%2F%3E%5B%20133.089526%5D%20chan%3D4%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-81%20min_rss%3D81%2C%20max_rss%3D81%3CBR%20%2F%3E%5B%20133.089542%5D%20chan%3D5%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-84%20min_rss%3D84%2C%20max_rss%3D84%3CBR%20%2F%3E%5B%20133.089558%5D%20chan%3D6%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-84%20min_rss%3D84%2C%20max_rss%3D84%3CBR%20%2F%3E%5B%20133.089574%5D%20chan%3D7%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-87%20min_rss%3D87%2C%20max_rss%3D87%3CBR%20%2F%3E%5B%20133.089589%5D%20chan%3D8%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-87%20min_rss%3D87%2C%20max_rss%3D87%3CBR%20%2F%3E%5B%20133.089605%5D%20chan%3D9%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-89%20min_rss%3D89%2C%20max_rss%3D89%3CBR%20%2F%3E%5B%20133.089620%5D%20chan%3D10%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-89%20min_rss%3D89%2C%20max_rss%3D89%3CBR%20%2F%3E%5B%20133.089636%5D%20chan%3D11%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-89%20min_rss%3D89%2C%20max_rss%3D89%3CBR%20%2F%3E%5B%20133.089652%5D%20chan%3D12%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-87%20min_rss%3D87%2C%20max_rss%3D87%3CBR%20%2F%3E%5B%20133.089668%5D%20chan%3D13%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-88%20min_rss%3D88%2C%20max_rss%3D88%3CBR%20%2F%3E%5B%20133.089683%5D%20chan%3D14%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-91%20min_rss%3D91%2C%20max_rss%3D91%3CBR%20%2F%3E%5B%20133.089702%5D%20wlan%3A%20SCAN%20COMPLETED%3A%20scanned%20AP%20count%3D0%3CBR%20%2F%3E%5B%20133.089721%5D%20event%20id%3A0x80000009%3CBR%20%2F%3E%5B%20133.089748%5D%20IOCTL%20is%20not%20allowed%20while%20the%20%E8%AE%BE%E5%A4%87%20is%20not%20present%20or%20hang%3CBR%20%2F%3E%5B%20133.089767%5D%20IOCTL%20is%20not%20allowed%20while%20the%20%E8%AE%BE%E5%A4%87%20is%20not%20present%20or%20hang%3CBR%20%2F%3E%5B%20133.093278%5D%20IOCTL%20is%20not%20allowed%20while%20the%20%E8%AE%BE%E5%A4%87%20is%20not%20present%20or%20hang%3CBR%20%2F%3E%5B%20133.099459%5D%20%3D%3D%3D%3DSDIO%20FW%20DUMP%20EVENT%20MODE%20START%20%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20133.099802%5D%20FW%20trigger%20fw%20dump%3CBR%20%2F%3E%5B%20133.099845%5D%20%3D%3D%3D%3D%20Start%20Receive%20FW%20dump%20event%20%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20133.099942%5D%20Create%20directory%20%2Fdata%2Fdump_133%20error%2C%20try%20create%20dir%20in%20%2Fvar%3CBR%20%2F%3E%5B%20133.100015%5D%20Create%20directory%20%2Fvar%2Fdump_133%20successfully%3CBR%20%2F%3E%5B%20133.100036%5D%20Firmware%20Dump%20directory%20name%20is%20%2Fvar%2Fdump_133%3CBR%20%2F%3E%5B%20133.100048%5D%20%3D%3D%3D%20START%20DRIVER%20INFO%20DUMP%3D%3D%3D%3CBR%20%2F%3E%5B%20133.100161%5D%20DRV%20dump%20data%20in%20%2Fvar%2Fdump_133%2Ffile_drv_info%3CBR%20%2F%3E%5B%20133.100594%5D%20Wakeup%20%E8%AE%BE%E5%A4%87...%3CBR%20%2F%3E%5B%20133.231641%5D%20Drv%20info%20total%20%E5%AD%97%E8%8A%82s%20%3D%20421143%20(0x66d17)%3CBR%20%2F%3E%5B%20133.231676%5D%20%3D%3D%3D%20DRIVER%20INFO%20DUMP%20END%3D%3D%3D%3CBR%20%2F%3E%5B%20134.887580%5D%20%3D%3D%3D%3D%20FW%20DUMP%20END%3A%201408768%20%E5%AD%97%E8%8A%82s%20%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20134.887652%5D%20wlan%3A%20Notify%20FW%20dump%20complete%20event%3CBR%20%2F%3E%5B%20134.887668%5D%20vendor%20event%20%3A0x1%3CBR%20%2F%3E%5B%20134.887750%5D%20Start%20to%20process%20hanging%3CBR%20%2F%3E%5B%20134.888400%5D%20IOCTL%20is%20not%20allowed%20while%20the%20%E8%AE%BE%E5%A4%87%20is%20not%20present%20or%20hang%3CBR%20%2F%3E%5B%20134.888744%5D%20Cancel%20all%20pending%20cmd%20and%20txrx%20queue%3CBR%20%2F%3E%5B%20134.888883%5D%20vendor%20event%20%3A0x4%3CBR%20%2F%3E%5B%20134.888939%5D%20WIFI%20auto_fw_reload%3A%20fw_reload%3D1%3CBR%20%2F%3E%5B%20134.888995%5D%20%3D%3D%3D%3D%3D%3D%3D%3DSTART%20IN-BAND%20RESET%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20134.889037%5D%20vendor%20event%20%3A0x2%3CBR%20%2F%3E%5B%20134.889227%5D%20IOCTL%20is%20not%20allowed%20while%20the%20%E8%AE%BE%E5%A4%87%20is%20not%20present%20or%20hang%3CBR%20%2F%3E%5B%20134.889259%5D%20woal_reset_intf%3A%20get%20bss%20info%20failed%3CBR%20%2F%3E%5B%20134.889375%5D%20Cancel%20all%20pending%20cmd%20and%20txrx%20queue%3CBR%20%2F%3E%5B%20134.889499%5D%20IOCTL%20is%20not%20allowed%20while%20the%20%E8%AE%BE%E5%A4%87%20is%20not%20present%20or%20hang%3CBR%20%2F%3E%5B%20134.889793%5D%20IOCTL%20is%20not%20allowed%20while%20the%20%E8%AE%BE%E5%A4%87%20is%20not%20present%20or%20hang%3CBR%20%2F%3E%5B%20135.068048%5D%20FW%20wake%20up%3CBR%20%2F%3E%5B%20135.082732%5D%20SDIO%20Trigger%20FW%20In-band%20RESET%20success%3CBR%20%2F%3E%5B%20135.082764%5D%20Free%20module%20params%3CBR%20%2F%3E%5B%20135.082815%5D%E6%9C%AA%E6%8C%87%E5%AE%9A%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%20cfg%20%E6%96%87%E4%BB%B6%3CBR%20%2F%3E%5B%20135.082867%5D%20SDIO%3A%20sdio_blk_size%3D256%20max_blk_count%3D512%20max_segs%3D64%20max_seg_size%3D4096%3CBR%20%2F%3E%5B%20135.082883%5D%20rx_work%3D0%20cpu_num%3D1%3CBR%20%2F%3E%5B%20135.082903%5D%20Enable%20moal_recv_amsdu_packet%3CBR%20%2F%3E%5B%20135.082990%5D%20Attach%20mlan%20adapter%20operations.card_type%20is%200x109.%3CBR%20%2F%3E%5B%20135.091840%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20TX%20SG%20%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%20135.091876%5D%20wlan%3A%20mpa_tx.buf_size%3D4096%3CBR%20%2F%3E%5B%20135.091888%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20RX%20SG%20%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%20135.091899%5D%20wlan%3A%20mpa_rx.buf_size%3D4096%3CBR%20%2F%3E%5B%20135.091945%5D%20%E8%AF%B7%E6%B1%82%E5%9B%BA%E4%BB%B6%EF%BC%9Anxp%2Fsd_w61x_v1.bin.se%3CBR%20%2F%3E%5B135.097580%5D%20%E5%94%A4%E9%86%92%E8%AE%BE%E5%A4%87...%3CBR%20%2F%3E%5B135.361419%5D%20%E6%97%A0%E7%BA%BF%E5%B1%80%E5%9F%9F%E7%BD%91%EF%BC%9A%E5%9B%BA%E4%BB%B6%E4%B8%8B%E8%BD%BD%E7%BB%93%E6%9D%9F%EF%BC%8C%E5%9B%BA%E4%BB%B6%3D681308%20%E5%B7%B2%E4%B8%8B%E8%BD%BD%20565508%20%5B135.779436%5D%20%E6%97%A0%E7%BA%BF%E5%B1%80%E5%9F%9F%E7%BD%91%E5%9B%BA%E4%BB%B6%E5%A4%84%E4%BA%8E%E6%B4%BB%E5%8A%A8%E7%8A%B6%E6%80%81%20%5B135.779479%5D%20on_time%20%E6%98%AF%20135760213003%20%3CBR%20%2F%3E%20%5B135.779928%5D%20QUEUE_CMD%EF%BC%9AFUNC_INIT%20%5B0xa9%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B135.779961%5D%20QUEUE_CMD%3A%20GET_HW_SPEC%20%3CBR%20%2F%3E%20%5B0x3%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B135.780007%5D%20DNLD_CMD%20(135.7607%20%3CBR%20%2F%3E%2017)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3EFUNC_INIT%20%5B0xa9%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x263%E3%80%81len%2016%E3%80%81seqno%200x1%20%E8%B6%85%E6%97%B6%205000%20%5B135.802877%5D%20CMD_RESP%20(135.783563)%EF%BC%9A%3CBR%20%2F%3EFUNC_INIT%20%5B0x80a9%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1%3CBR%20%2F%3E%5B%20135.802941%5D%20DNLD_CMD%20(135.783651)%EF%BC%9AGET_HW_SPEC%20%5B0x3%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x0%E3%80%81len%2071%E3%80%81seqno%200x2%20%E8%B6%85%E6%97%B6%205000%20%5B135.803276%5D%20135.783976%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%3CBR%20%2F%3E%20%5B135.803320%5D%20VDLL_IND%20(OFFSET)%EF%BC%9Aoffset%3D0x1c458%20%5B135.804257%5D%20VDLL%20%E5%9B%BE%E7%89%87%EF%BC%9Alen%3D115800%20%5B135.804257%5D%20VDLL%20%E5%9B%BE%E7%89%87%EF%BC%9Alen%3D115800%20%5B13800%5D%20%5B5.804558%5D%20CMD_RESP%20(135.785256)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EGET_HW_SPEC%20%5B0x8003%5D%2C%20result%200%2C%20len%20205%2C%20seqno%200x2%3CBR%20%2F%3E%5B%20135.804586%5D%20fw_cap_info%3D0x487cff03%2C%20dev_cap_mask%3D0xffffffff%3CBR%20%2F%3E%5B%20135.804603%5D%20GET_HW_SPEC%3A%20country_code%3D0x0%3CBR%20%2F%3E%5B%20135.804615%5D%20num_ant%3D1%2C%20antinfo%3D0x0%3CBR%20%2F%3E%5B%20135.804631%5D%20GET_HW_SPEC%3A%20hw_mpdu_density%3D4%20dev_mcs_support%3D0x11%3CBR%20%2F%3E%5B%20135.804641%5D%20Enable%20%E6%B3%A2%E6%9D%9F%E8%B5%8B%E5%BD%A2%3CBR%20%2F%3E%5B%20135.804656%5D%20GET_HW_SPEC%3A%20mgmt%20IE%20count%3D13%3CBR%20%2F%3E%5B%20135.804672%5D%20FW%3A%20SDIO%20rx%20aggr%20disabled%200x487cff03%3CBR%20%2F%3E%5B%20135.804687%5D%20pmadapter-%26gt%3Becsa_enable%3D1%3CBR%20%2F%3E%5B%20135.804722%5D%20QUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.804735%5D%20pmadapter-%26gt%3Bgetlog_enable%3D1%3CBR%20%2F%3E%5B%20135.804758%5D%20chanrpt%20api%20ver%3D14.1%3CBR%20%2F%3E%5B%20135.804772%5D%20fw_cap_info%3D0x487cff03%20fw_cap_ext%3D0x2182b5%3CBR%20%2F%3E%5B%20135.804786%5D%20uuid%3A%20c10d697cf87d596cab35c831392df315%3CBR%20%2F%3E%5B%20135.804798%5D%20fw%20hotfix%20ver%3D11%3CBR%20%2F%3E%5B%20135.804810%5D%20fw%20ver%3D15.1%3CBR%20%2F%3E%5B%20135.804820%5D%20uap%20fw%20ver%3D2.0%3CBR%20%2F%3E%5B%20135.804832%5D%20max_p2p_conn%20%3D%208%2C%20max_sta_conn%20%3D%2016%3CBR%20%2F%3E%5B%20135.804849%5D%20wlan_set_regiontable%3A%202.4G%200x10%3CBR%20%2F%3E%5B%20135.804868%5D%20wlan_set_regiontable%3A%205G%200x10%3CBR%20%2F%3E%5B%20135.804904%5D%20%E5%AE%8C%E6%88%90%E7%A1%AC%E4%BB%B6%E8%A7%84%E8%8C%83%EF%BC%8Cfw_cap%3D0x487cff03%3CBR%20%2F%3E%5B%20135.804931%5D%20org_drv_mode%3D0x7%20drv_mode%3D0x7%3CBR%20%2F%3E%5B%20135.805473%5D%20%E5%90%AF%E7%94%A8%E6%B3%A2%E6%9D%9F%E8%B5%8B%E5%BD%A2%3CBR%20%2F%3E%5B%20135.805531%5D%20QUEUE_CMD%3A%20802_11_FW_WAKE_METHOD%20%5B0x74%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.805558%5D%20%E8%AE%BE%E7%BD%AE%20tx_buf%20%3D%204096%3CBR%20%2F%3E%5B%20135.805578%5D%20QUEUE_CMD%3A%20RECONFIGURE_TX_BUFF%20%5B0xd9%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.805603%5D%20PS%20Command%3A%20action%20%3D%200x6%2C%20bitmap%20%3D%200x1%3CBR%20%2F%3E%5B%20135.805623%5D%20QUEUE_CMD%3A%20802_11_PS_MODE_ENH%20%5B0xe4%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.805653%5D%20QUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.805684%5D%20QUEUE_CMD%3A%20802_11_RF_ANTENNA%20%5B0x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.805715%5D%20QUEUE_CMD%3A%20CHAN_REGION_CFG%20%5B0x242%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.805747%5D%20QUEUE_CMD%3A%20TX_RATE_CFG%20%5B0xd6%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.805775%5D%20QUEUE_CMD%3A%20802_11_RF_TX_POWER%20%5B0x1e%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.805803%5D%20QUEUE_CMD%3A%20AMSDU_AGGR_CTRL%20%5B0xdf%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.805831%5D%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.805873%5D%20DNLD_CMD%20(135.786585)%3A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81act%200x1%E3%80%81len%2015%E3%80%81seqno%200x3%20%E8%B6%85%E6%97%B6%205000%20%5B135.806273%5D%20CMD_RESP%20(135.786970)%EF%BC%9A%3CBR%20%2F%3E802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2015%EF%BC%8Cseqno%200x3%3CBR%20%2F%3E%5B%20135.806326%5D%20DNLD_CMD%20(135.787037)%EF%BC%9A802_11_FW_WAKE_METHOD%20%5B0x74%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x4%20%E8%B6%85%E6%97%B6%205000%20%5B135.806657%5D%20CMD_RESP%20(135.787354)%EF%BC%9A%3CBR%20%2F%3E802_11_FW_WAKE_METHOD%20%5B0x8074%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2018%EF%BC%8Cseqno%200x4%3CBR%20%2F%3E%5B%20135.806681%5D%20FW%20%E5%94%A4%E9%86%92%E6%96%B9%E6%B3%95%3D1%EF%BC%8Cgpio%3D0%3CBR%20%2F%3E%5B%20135.806720%5D%20DNLD_CMD%20(135.787431)%EF%BC%9ARECONFIGURE_TX_BUFF%20%5B0xd9%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2016%E3%80%81seqno%200x5%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20135.807784%5D%20CMD_RESP%20(135.788482)%EF%BC%9ARECONFIGURE_TX_BUFF%20%5B0x80d9%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x5%3CBR%20%2F%3E%5B%20135.807813%5D%20end%20port%2032%EF%BC%8Cdata%20port%20mask%20ffffffff%3CBR%20%2F%3E%5B%20135.807828%5D%20max_tx_buf_size%3D4096%EF%BC%8Ctx_buf_size%3D3328%3CBR%20%2F%3E%5B%20135.807867%5D%20DNLD_CMD%20(135.788578)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8Cact%200x6%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x6%20%E8%B6%85%E6%97%B6%205000%20%5B135.808197%5D%20CMD_RESP%20(135.788896)%EF%BC%9A%3CBR%20%2F%3E802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x6%3CBR%20%2F%3E%5B%20135.808246%5D%20DNLD_CMD%20(135.788958)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81act%200x1%E3%80%81len%2018%E3%80%81seqno%200x7%20%E8%B6%85%E6%97%B6%205000%20%5B135.808578%5D%20CMD_RESP%20(135.789278)%EF%BC%9A%3CBR%20%2F%3E802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2018%EF%BC%8Cseqno%200x7%3CBR%20%2F%3E%5B%20135.808627%5D%20DNLD_CMD%20(135.789339)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8Cact%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x8%20%E8%B6%85%E6%97%B6%205000%20%5B135.808952%5D%20CMD_RESP%20(135.789651)%EF%BC%9A%3CBR%20%2F%3E802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x8%3CBR%20%2F%3E%5B%20135.809004%5D%20DNLD_CMD%20(135.789713)%EF%BC%9ACHAN_REGION_CFG%20%5B0x242%5D%E3%80%81act%200x0%E3%80%81len%2011%E3%80%81seqno%200x9%20%E8%B6%85%E6%97%B6%205000%20%5B135.810351%5D%20CMD_RESP%20(135.791038)%EF%BC%9A%3CBR%20%2F%3ECHAN_REGION_CFG%20%5B0x8242%5D%EF%BC%8Cresult%200%EF%BC%8Clen%201297%EF%BC%8Cseqno%200x9%3CBR%20%2F%3E%5B%20135.810455%5D%20DNLD_CMD%20(135.791160)%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2076%EF%BC%8Cseqno%200xa%20%E8%B6%85%E6%97%B6%205000%20%5B135.811124%5D%20CMD_RESP%20(135.791819)%EF%BC%9A%3CBR%20%2F%3ETX_RATE_CFG%20%5B0x80d6%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20832%EF%BC%8Cseqno%200xa%3CBR%20%2F%3E%5B%20135.811184%5D%20DNLD_CMD%20(135.791892)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2014%EF%BC%8Cseqno%200xb%20%E8%B6%85%E6%97%B6%205000%20%5B135.811540%5D%20CMD_RESP%20(135.792237)%EF%BC%9A%3CBR%20%2F%3E802_11_RF_TX_POWER%20%5B0x801e%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200xb%3CBR%20%2F%3E%5B%20135.811591%5D%20DNLD_CMD%20(135.792300)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0xdf%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2014%EF%BC%8Cseqno%200xc%20%E8%B6%85%E6%97%B6%205000%20%5B135.811920%5D%20CMD_RESP%20(135.792619)%EF%BC%9A%3CBR%20%2F%3EAMSDU_AGGR_CTRL%20%5B0x80df%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200xc%3CBR%20%2F%3E%5B%20135.811966%5D%20DNLD_CMD%20(135.792678)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81act%200x213%E3%80%81len%2012%E3%80%81seqno%200xd%20%E8%B6%85%E6%97%B6%205000%20%5B135.812382%5D%20CMD_RESP%20(135.793082)%EF%BC%9A%3CBR%20%2F%3EMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200xd%3CBR%20%2F%3E%5B%20135.812434%5D%20QUEUE_CMD%3A%20APCMD_SYS_CONFIGURE%20%5B0xb0%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.812472%5D%20DNLD_CMD%20(135.793183)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%E3%80%81act%200x0%E3%80%81len%2020%E3%80%81seqno%200x100e%20%E8%B6%85%E6%97%B6%205000%20%5B135.813545%5D%20CMD_RESP%20(135.794232)%EF%BC%9A%3CBR%20%2F%3EAPCMD_SYS_CONFIGURE%20%5B0x80b0%5D%2C%20result%200%2C%20len%2020%2C%20seqno%200x100e%3CBR%20%2F%3E%5B%20135.813606%5D%20QUEUE_CMD%3A%20TX_RATE_CFG%20%5B0xd6%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.813637%5D%20QUEUE_CMD%3A%20802_11_RF_TX_POWER%20%5B0x1e%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.813666%5D%20QUEUE_CMD%3A%20AMSDU_AGGR_CTRL%20%5B0xdf%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.813693%5D%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.813720%5D%20QUEUE_CMD%3A%20802_11_MAC_ADDRESS%20%5B0x4d%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.813757%5D%20DNLD_CMD%20(135.794468)%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2076%EF%BC%8Cseqno%200x200f%20%E8%B6%85%E6%97%B6%205000%20%5B135.818050%5D%20CMD_RESP%20(135.798739)%EF%BC%9A%3CBR%20%2F%3ETX_RATE_CFG%20%5B0x80d6%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20832%EF%BC%8Cseqno%200x200f%3CBR%20%2F%3E%5B%20135.818115%5D%20DNLD_CMD%20(135.798822)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2010%20%E8%B6%85%E6%97%B6%205000%20%5B135.818477%5D%20CMD_RESP%20(135.799175)%EF%BC%9A%3CBR%20%2F%3E802_11_RF_TX_POWER%20%5B0x801e%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2010%3CBR%20%2F%3E%5B%20135.818528%5D%20DNLD_CMD%20(135.799237)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0xdf%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2011%20%E8%B6%85%E6%97%B6%205000%20%5B135.818860%5D%20CMD_RESP%20(135.799557)%EF%BC%9A%3CBR%20%2F%3EAMSDU_AGGR_CTRL%20%5B0x80df%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2011%3CBR%20%2F%3E%5B%20135.818909%5D%20DNLD_CMD%20(135.799620)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200x2012%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20135.819230%5D%20CMD_RESP%20(135.799930)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2012%3CBR%20%2F%3E%5B%20135.819353%5D%20DNLD_CMD%20(135.800057)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2013%20%E8%B6%85%E6%97%B6%205000%20%5B135.819695%5D%20CMD_RESP%20(135.800394)%EF%BC%9A%3CBR%20%2F%3E802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2013%3CBR%20%2F%3E%5B%20135.819753%5D%20QUEUE_CMD%3A%20WMM_PARAM_CONFIG%20%5B0x23a%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.819806%5D%20DNLD_CMD%20(135.800516)%EF%BC%9AWMM_PARAM_CONFIG%20%5B0x23a%5D%E3%80%81act%200x2%E3%80%81len%2026%E3%80%81seqno%200x14%20%E8%B6%85%E6%97%B6%205000%20%5B135.820154%5D%20CMD_RESP%20(135.800851)%EF%BC%9A%3CBR%20%2F%3EWMM_PARAM_CONFIG%20%5B0x823a%5D%2C%20result%200%2C%20len%2026%2C%20seqno%200x14%3CBR%20%2F%3E%5B%20135.820247%5D%20woal_proc_init%3A%20proc_wlan%20is%20already%20exist%20adapter0%3CBR%20%2F%3E%5B%20135.820490%5D%20Set%20wiphy%20max_ap_assoc_sta%3D8%3CBR%20%2F%3E%5B%20135.820580%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%20135.820595%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%20135.820613%5D%20vht_cap%3D0x33d07030%20rx_mcs_map%3D0xfffe%20rx_max%3D0x186%20tx_mcs_map%3D0xfffe%20tx_max%3D0x186%3CBR%20%2F%3E%5B%20135.820633%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%20135.820644%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%20135.820660%5D%20vht_cap%3D0x33d07030%20rx_mcs_map%3D0xfffe%20rx_max%3D0x186%20tx_mcs_map%3D0xfffe%20tx_max%3D0x186%3CBR%20%2F%3E%5B%20135.820694%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_RF_ANTENNA%20%5B0x20%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.820792%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.801516)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8Cact%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x15%20%E8%B6%85%E6%97%B6%205000%20%5B135.821252%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.801969)%EF%BC%9A%3CBR%20%2F%3E802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x15%3CBR%20%2F%3E%5B%20135.821410%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.821486%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.802211)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x16%20%E8%B6%85%E6%97%B6%205000%20%5B135.821909%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.802626)%EF%BC%9A%3CBR%20%2F%3E802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x16%3CBR%20%2F%3E%5B%20135.822058%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.822131%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.802857)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x17%20%E8%B6%85%E6%97%B6%205000%20%5B135.822556%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.803274)%EF%BC%9A%3CBR%20%2F%3E802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x17%3CBR%20%2F%3E%5B%20135.823588%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.823686%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.804409)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x18%20%E8%B6%85%E6%97%B6%205000%20%5B135.824156%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.804874)%EF%BC%9A%3CBR%20%2F%3E802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20142%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x18%20%5B135.824697%5D%20cfg80211%20%E7%9B%91%E7%AE%A1%E5%9F%9F%E5%9B%9E%E8%B0%83%2000%20%E5%90%AF%E5%8A%A8%E5%99%A8%3D0%20dfs_region%3D0%20%5B135.824756%5D%20%E7%9B%91%E7%AE%A1%E5%9F%9F%20by_CORE%20%3CBR%20%2F%3E%20%5B135.824824%5D%20wlan%25d%EF%BC%9AQUEE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0%20x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B135.825063%5D%20wlan%25d%EF%BC%9ADNLD_%20%3CBR%20%2F%3E%20CMD%20(135.805783)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x19%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20135.825563%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.806278)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x19%3CBR%20%2F%3E%5B%20135.830566%5D%20PS%20%E5%91%BD%E4%BB%A4%EF%BC%9Aaction%20%3D%200x0%EF%BC%8Cbitmap%20%3D%200x0%3CBR%20%2F%3E%5B%20135.830603%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_PS_MODE_ENH%20%5B0xe4%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.830705%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.811429)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x1a%20%E8%B6%85%E6%97%B6%205000%20%5B135.831207%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.811924)%EF%BC%9A%3CBR%20%2F%3E802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8C%20result%200%EF%BC%8C%20len%2068%EF%BC%8C%20seqno%200x1a%3CBR%20%2F%3E%5B%20135.831257%5D%20ps_bitmap%3D0x0%3CBR%20%2F%3E%5B%20135.832483%5D%20CFG80211%3A%20Country%3D00%2C%20band%3D0%2C%20no_of_sub_band%3D1%3CBR%20%2F%3E%5B%20135.832537%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.832595%5D%2011D%3ACountry%3DWW%20band%3D0%20sub-band%3D1%20dfs_region%3D0%3CBR%20%2F%3E%5B%20135.832612%5D%2011D%3A%20first%20chan%3D1%20no_of_chan%3D14%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.832627%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.832654%5D%20wlan_set_regiontable%3A%202.4G%200x0%3CBR%20%2F%3E%5B%20135.832679%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%3CBR%20%2F%3E%5B%20135.832765%5D%20wlan%25d%EF%BC%9Adnld_cmd%20(135.813487)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2016%E3%80%81seqno%200x1b%20%E8%B6%85%E6%97%B6%205000%20%5B135.833246%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.813963)%EF%BC%9A%3CBR%20%2F%3E802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1b%3CBR%20%2F%3E%5B%20135.833311%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.814036)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2032%E3%80%81seqno%200x1c%20%E8%B6%85%E6%97%B6%205000%20%5B135.833767%5D%20wlan%25d%EF%BC%9A135.814485%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B135.833837%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xe808%20len%20%3D%20600%20%3CBR%20%2F%3E%20%5B135.833837%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xe808%20len%20%3D%20600%20%5B135.833837%5D%203865%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B135.852281%5D%20wlan%25d%EF%BC%9A135.832993%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%3CBR%20%2F%3E%20%5B0x81%5D%20%5B135.852365%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xea60%20len%20%3D%20600%20%5B135.852394%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%3A%20block_len%3D600%20%3CBR%20%2F%3E%20%5B135.853090%5D%20wlan%25d%EF%BC%9A135.833806%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B135.853163%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xecb8%20len%20%3D%20600%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%5B135.853190%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B135.853763%5D%20wlan%25d%EF%BC%9A135.834478%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%3CBR%20%2F%3E%20%5B135.853834%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xef10%20len%20%3D%20600%20%5B135.853862%5D%20wlan%25d%EF%BC%9ADN%25D%20LD_VDLL%EF%BC%9Ablock_len%3D600%20%5B135.854423%5D%20wlan%25d%EF%BC%9A135.835138%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%3CBR%20%2F%3E%20%5B135.854495%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf168%20len%20%3D%20600%20%5B135.854520%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B135.4520%5D%20855156%5D%20wlan%25d%EF%BC%9A135.835873%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%3CBR%20%2F%3E%20%5B0x81%5D%20%5B135.855227%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf3c%20%3CBR%20%2F%3E%200%20len%20%3D%20600%20%5B135.855253%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%3CBR%20%2F%3E%20%5B135.855840%5D%20wlan%25d%EF%BC%9A135.836555%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B135.855914%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf618%20len%20%3D%20600%20%5B135.855940%5D%20wlan%25d%EF%BC%9ADNLD_D%20VDLL%EF%BC%9Ablock_len%3D600%20%5B135.856506%5D%20wlan%25d%EF%BC%9A135.837222%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%3CBR%20%2F%3E%20%5B0x81%5D%20%5B135.856579%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf870%20len%20%3D%20600%20%5B135.856605%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%3CBR%20%2F%3E%20%5B135.5.600%5D%20857176%5D%20wlan%25d%EF%BC%9A135.837891%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B135.857249%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xfac8%20len%20%3D%20600%20%3CBR%20%2F%3E%20%5B135.857273%5D%20wlan%25d%EF%BC%9ADNLD_%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3EVDLL%EF%BC%9Ablock_len%3D600%20%3CBR%20%2F%3E%20%5B135.871435%5D%20wlan%25d%EF%BC%9A135.852148%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B135.871518%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xc4e0%20len%20%3D%20600%20%5B135.871546%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%3CBR%20%2F%3E%20%5B135.881546%5D%209846%5D%20wlan%25d%EF%BC%9A135.870559%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B135.889927%5D%20VDLL_IND%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20type%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xc738%20len%20%3D%20600%20%3CBR%20%2F%3E%20%5B135.889954%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B135.890572%5D%20wlan%25d%EF%BC%9A135.871288%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B135.890641%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xc81%20990%20len%20%3D%20600%20%3CBR%20%2F%3E%20%5B135.890667%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B135.891189%5D%20wlan%25d%EF%BC%9A135.871907%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B135.891256%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xcbe8%20len%20%3D%20600%20%3CBR%20%2F%3E%20%5B135.891281%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B135.891805%5D%20wlan%25d%EF%BC%9A135.872522%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%3CBR%20%2F%3E%20%5B135.891874%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Eoffset%20%3D%200xce40%20len%20%3D%20600%20%3CBR%20%2F%3E%20%5B135.891899%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B135.892608%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.873325)%EF%BC%9A%3CBR%20%2F%3E802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%20result%200%EF%BC%8C%20len%2032%EF%BC%8C%20seqno%200x1c%3CBR%20%2F%3E%5B%20135.892748%5D%20CFG80211%3A%20Country%3D00%2C%20band%3D1%2C%20no_of_sub_band%3D25%3CBR%20%2F%3E%5B%20135.892808%5D%2011D%3ACountry%3DWW%20band%3D1%20sub-band%3D25%20dfs_region%3D0%3CBR%20%2F%3E%5B%20135.892823%5D%2011D%3A%20first%20chan%3D36%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892836%5D%2011D%3A%20first%20chan%3D40%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892848%5D%2011D%3A%20first%20chan%3D44%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892860%5D%2011D%3A%20first%20chan%3D48%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892872%5D%2011D%3A%20first%20chan%3D52%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892883%5D%2011D%3A%20first%20chan%3D56%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892895%5D%2011D%3A%20first%20chan%3D60%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892906%5D%2011D%3A%20first%20chan%3D64%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892919%5D%2011D%3A%20first%20chan%3D100%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892930%5D%2011D%3A%20first%20chan%3D104%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892942%5D%2011D%3A%20first%20chan%3D108%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892954%5D%2011D%3A%20first%20chan%3D112%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892966%5D%2011D%3A%20first%20chan%3D116%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892978%5D%2011D%3A%20first%20chan%3D120%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.892991%5D%2011D%3A%20first%20chan%3D124%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.893003%5D%2011D%3A%20first%20chan%3D128%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.893015%5D%2011D%3A%20first%20chan%3D132%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.893026%5D%2011D%3A%20first%20chan%3D136%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.893038%5D%2011D%3A%20first%20chan%3D140%20no_of_chan%3D1%E3%80%81%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.893050%5D%2011D%3A%20first%20chan%3D144%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.893062%5D%2011D%3A%20first%20chan%3D149%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.893074%5D%2011D%3A%20first%20chan%3D153%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.893086%5D%2011D%3A%20first%20chan%3D157%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%20%5B%20135.893098%5D%2011D%3A%20first%20chan%3D161%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%20893086%5D%2011D%3A%20first%20chan%3D157%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.893098%5D%2011D%3A%20first%20chan%3D161%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.893111%5D%2011D%3A%20first%20chan%3D165%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.893129%5D%20wlan%25D%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.893162%5D%20wlan_set_regiontable%3A%202.4G%200x0%3CBR%20%2F%3E%5B%20135.893182%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%3CBR%20%2F%3E%5B%20135.893262%5D%20wlan%25d%EF%BC%9Adnld_cmd%20(135.873985)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81act%200x1%E3%80%81len%20104%E3%80%81seqno%200x1d%20%E8%B6%85%E6%97%B6%205000%20%5B135.914842%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.895556)%EF%BC%9A%3CBR%20%2F%3E802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20104%EF%BC%8Cseqno%200x1d%3CBR%20%2F%3E%5B%20135.915464%5D%20%E8%AE%BE%E7%BD%AE%20wlan%25d%20%E6%8E%A5%E5%8F%A3%E5%9C%B0%E5%9D%80%EF%BC%9A30%3AXX%3AXX%3AXX%3A8c%3A11%3CBR%20%2F%3E%5B%20135.915527%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_MAC_ADDRESS%20%5B0x4d%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.915612%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.896337)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2016%E3%80%81seqno%200x1e%20%E8%B6%85%E6%97%B6%205000%20%5B135.916084%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.896801)%EF%BC%9A%3CBR%20%2F%3E802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1e%3CBR%20%2F%3E%5B%20135.917741%5D%20Register%20NXP%20802.11%20Adapter%20wlan0%3CBR%20%2F%3E%5B%20135.918123%5D%20uap%25d%EF%BC%9AQUEUE_CMD%3A%2011AX_CFG%20%5B0x266%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.918242%5D%20wlan0%20set%20multicast_list%3CBR%20%2F%3E%5B%20135.918284%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.918321%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.919456%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(135.900169)%EF%BC%9A11AX_CFG%20%5B0x266%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2039%E3%80%81seqno%200x101f%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20135.922208%5D%20wlan0%EF%BC%9A135.902922%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20135.922289%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xfd20%20len%20%3D%20600%3CBR%20%2F%3E%5B%20135.922317%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20135.924116%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.940962%5D%20wlan0%EF%BC%9A135.921674%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20135.941045%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xff78%20len%20%3D%20600%3CBR%20%2F%3E%5B%20135.941072%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20135.941803%5D%20wlan0%EF%BC%9A135.922519%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20135.941878%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x101d0%20len%20%3D%20600%3CBR%20%2F%3E%5B%20135.941907%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20135.942533%5D%20wlan0%EF%BC%9A135.923247%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20135.942609%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20offset%20%3D%200x10428%20len%20%3D%20600%3CBR%20%2F%3E%5B%20135.942636%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20135.943225%5D%20wlan0%EF%BC%9A135.923941%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20135.943295%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x10680%20len%20%3D%20600%3CBR%20%2F%3E%5B%20135.943321%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20135.943880%5D%20wlan0%EF%BC%9A135.924596%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20135.943953%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x108d8%20len%20%3D%20600%3CBR%20%2F%3E%5B%20135.943980%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20135.944770%5D%20uap%25d%EF%BC%9ACMD_RESP%20(135.925484)%EF%BC%9A11AX_CFG%20%5B0x8266%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2039%EF%BC%8Cseqno%200x101f%3CBR%20%2F%3E%5B%20135.944838%5D%20user_2g_hecap_len%3D28%3CBR%20%2F%3E%5B%20135.944887%5D%20wlan0%3A%20DNLD_CMD%20(135.925611)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81act%200x1%E3%80%81len%20204%E3%80%81seqno%200x20%20%E8%B6%85%E6%97%B6%205000%20%5B135.945344%5D%20wlan0%EF%BC%9ACMD_RESP%20(135.926062)%EF%BC%9A%3CBR%20%2F%3EMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x20%3CBR%20%2F%3E%5B%20135.945402%5D%20wlan0%3A%20DNLD_CMD%20(135.926128)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81act%200x213%E3%80%81len%2012%E3%80%81seqno%200x21%20%E8%B6%85%E6%97%B6%205000%20%3CBR%20%2F%3E%20%5B135.945714%5D%20wlan0%EF%BC%9ACMD_RESP%20(135.926433)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x21%3CBR%20%2F%3E%5B%20135.945784%5D%20wlan0%3A%20DNLD_CMD%20(135.926508)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x22%20%E8%B6%85%E6%97%B6%205000%20%5B135.946203%5D%20wlan0%EF%BC%9ACMD_RESP%20(135.926922)%EF%BC%9A%3CBR%20%2F%3ETXPWR_CFG%20%5B0x80d1%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20100%EF%BC%8Cseqno%200x22%3CBR%20%2F%3E%5B%20135.946372%5D%20uap%25d%EF%BC%9AQUEUE_CMD%3A%2011AX_CFG%20%5B0x266%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.946458%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(135.927182)%EF%BC%9A11AX_CFG%20%5B0x266%5D%E3%80%81act%200x1%E3%80%81len%2039%E3%80%81seqno%200x1023%20%E8%B6%85%E6%97%B6%205000%20%5B135.946898%5D%20uap%25d%EF%BC%9ACMD_RESP%20(135.927614)%EF%BC%9A%3CBR%20%2F%3E11AX_CFG%20%5B0x8266%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2039%EF%BC%8Cseqno%200x1023%3CBR%20%2F%3E%5B%20135.946950%5D%20user_hecap_len%3D28%3CBR%20%2F%3E%5B%20135.947917%5D%20wlan0%3A%20QUEUE_CMD%3A%20802_11_RF_ANTENNA%20%5B0x20%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.948036%5D%20wlan0%3A%20DNLD_CMD%20(135.928760)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x24%20%E8%B6%85%E6%97%B6%205000%20%5B135.948531%5D%20wlan0%EF%BC%9ACMD_RESP%20(135.929248)%EF%BC%9A%3CBR%20%2F%3E802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x24%3CBR%20%2F%3E%5B%20135.952904%5D%20wlan0%3A%20QUEUE_CMD%3A%20TXPWR_CFG%20%5B0xd1%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20135.953030%5D%20wlan0%3A%20DNLD_CMD%20(135.933753)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x25%20%E8%B6%85%E6%97%B6%205000%20%5B135.953530%5D%20wlan0%EF%BC%9ACMD_RESP%20(135.934248)%EF%BC%9A%3CBR%20%2F%3ETXPWR_CFG%20%5B0x80d1%5D%EF%BC%8C%20result%200%EF%BC%8C%20len%20100%EF%BC%8C%20seqno%200x25%3CBR%20%2F%3E%5B%20135.980353%5D%20Set%20uap%25d%20interface%20addr%3A%2032%3AXX%3AXX%3AXX%3A8d%3A11%3CBR%20%2F%3E%5B%20135.980421%5D%20uap%25d%EF%BC%9AQUEUE_CMD%3A%20APCMD_SYS_CONFIGURE%20%5B0xb0%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.980519%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(135.961243)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%E3%80%81act%200x1%E3%80%81len%2020%E3%80%81seqno%200x1026%20%E8%B6%85%E6%97%B6%205000%20%5B135.981001%5D%20uap%25d%EF%BC%9ACMD_RESP%20(135.961718)%EF%BC%9A%3CBR%20%2F%3EAPCMD_SYS_CONFIGURE%20%5B0x80b0%5D%EF%BC%8C%20result%200%EF%BC%8C%20len%2020%EF%BC%8C%20seqno%200x1026%3CBR%20%2F%3E%5B%20135.982691%5D%20Register%20NXP%20802.11%20Adapter%20uap0%3CBR%20%2F%3E%5B%20135.983020%5D%20PS%20Command%3A%20action%20%3D%200x0%EF%BC%8C%20bitmap%20%3D%200x0%3CBR%20%2F%3E%5B%20135.983047%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_PS_MODE_ENH%20%5B0xe4%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.983151%5D%20uap0%20set%20multicast_list%3CBR%20%2F%3E%5B%20135.983219%5D%20p2p%25d%EF%BC%9Adnld_cmd%20(135.963942)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2027%20%E8%B6%85%E6%97%B6%205000%20%5B135.984207%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(135.964920)%EF%BC%9A%3CBR%20%2F%3E802_11_PS_MODE_ENH%20%5B0x80e4%5D%2C%20result%200%2C%20len%2068%2C%20seqno%200x2027%3CBR%20%2F%3E%5B%20135.984265%5D%20ps_bitmap%3D0x0%3CBR%20%2F%3E%5B%20135.984403%5D%20CFG80211%3A%20Country%3D00%2C%20band%3D0%2C%20no_of_sub_band%3D1%3CBR%20%2F%3E%5B%20135.984449%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.984505%5D%2011D%3ACountry%3DWW%20band%3D0%20sub-band%3D1%20dfs_region%3D0%3CBR%20%2F%3E%5B%20135.984522%5D%2011D%3A%20first%20chan%3D1%20no_of_chan%3D14%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20135.984537%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%3CBR%20%2F%3E%5B%20135.984568%5D%20wlan_set_regiontable%3A%202.4G%200x0%3CBR%20%2F%3E%5B%20135.984587%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%3CBR%20%2F%3E%5B%20135.984659%5D%20p2p%25d%EF%BC%9Adnld_cmd%20(135.965381)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81act%200x1%E3%80%81len%2016%E3%80%81seqno%200x2028%20%E8%B6%85%E6%97%B6%205000%20%5B135.985112%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(135.965828)%EF%BC%9A%3CBR%20%2F%3E802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2028%3CBR%20%2F%3E%5B%20135.985176%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(135.965901)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81act%200x1%E3%80%81len%2032%E3%80%81seqno%200x2029%20%E8%B6%85%E6%97%B6%205000%20%5B135.985893%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9ARX_MGMT_IND%20%5B0x10c%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%3CBR%20%2F%3E%20%5B136.006674%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(135.987387)%EF%BC%9A%3CBR%20%2F%3E802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2032%EF%BC%8Cseqno%200x2029%3CBR%20%2F%3E%5B%20136.006769%5D%20wlan0%3A%20DNLD_CMD%20(135.987493)%EF%BC%9ARX_MGMT_IND%20%5B0x10c%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2014%E3%80%81seqno%200x2a%20%E8%B6%85%E6%97%B6%205000%20%5B136.007116%5D%20wlan0%EF%BC%9ACMD_RESP%20(135.987835)%EF%BC%9A%3CBR%20%2F%3ERX_MGMT_IND%20%5B0x810c%5D%2C%20result%200%2C%20len%2014%2C%20seqno%200x2a%3CBR%20%2F%3E%5B%20136.007258%5D%20CFG80211%3A%20Country%3D00%2C%20band%3D1%2C%20no_of_sub_band%3D25%3CBR%20%2F%3E%5B%20136.007319%5D%2011D%3ACountry%3DWW%20band%3D1%20sub-band%3D25%20dfs_region%3D0%3CBR%20%2F%3E%5B%20136.007334%5D%2011D%3A%20first%20chan%3D36%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007347%5D%2011D%3A%20first%20chan%3D40%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007359%5D%2011D%3A%20first%20chan%3D44%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007371%5D%2011D%3A%20first%20chan%3D48%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007382%5D%2011D%3A%20first%20chan%3D52%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007394%5D%2011D%EF%BC%9A%20%E7%AC%AC%E4%B8%80%E4%B8%AA%20chan%3D56%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007405%5D%2011D%EF%BC%9A%20%E7%AC%AC%E4%B8%80%E4%B8%AA%20chan%3D60%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007417%5D%2011D%EF%BC%9A%20%E7%AC%AC%E4%B8%80%E4%B8%AA%20chan%3D64%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007429%5D%2011D%3A%20first%20chan%3D100%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007441%5D%2011D%3A%20first%20chan%3D104%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007453%5D%2011D%3A%20first%20chan%3D108%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007465%5D%2011D%3A%20first%20chan%3D112%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007476%5D%2011D%3A%20first%20chan%3D116%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007488%5D%2011D%3A%20first%20chan%3D120%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007500%5D%2011D%3A%20first%20chan%3D124%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007512%5D%2011D%3A%20first%20chan%3D128%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007524%5D%2011D%3A%20first%20chan%3D132%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007536%5D%2011D%3A%20first%20chan%3D136%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007548%5D%2011D%3A%20first%20chan%3D140%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007560%5D%2011D%3A%20first%20chan%3D144%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007572%5D%2011D%3A%20first%20chan%3D149%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007583%5D%2011D%3A%20first%20chan%3D153%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007595%5D%2011D%3A%20first%20chan%3D157%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007607%5D%2011D%3A%20first%20chan%3D161%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007619%5D%2011D%3A%20first%20chan%3D165%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20136.007637%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%3CBR%20%2F%3E%5B%20136.007669%5D%20wlan_set_regiontable%3A%202.4G%200x0%3CBR%20%2F%3E%5B%20136.007691%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%3CBR%20%2F%3E%5B%20136.007772%5D%20p2p%25d%EF%BC%9Adnld_cmd%20(135.988494)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81act%200x1%E3%80%81len%20104%E3%80%81seqno%200x202b%20%E8%B6%85%E6%97%B6%205000%20%5B136.029473%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(136.010184)%EF%BC%9A%3CBR%20%2F%3E802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20104%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x202b%20%5B136.048176%5D%20%E8%AE%BE%E7%BD%AE%20WFD%20%E8%AE%BE%E5%A4%87%E5%9C%B0%E5%9D%80%EF%BC%9A32%20%3CBR%20%2F%3E%20%3Axx%3Axx%3A%20xx%3A8c%3A11%20%5B136.048243%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_MAC_ADDRESS%20%3CBR%20%2F%3E%20%5B0x4d%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B136.04d%5D%2048342%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(136.029066)%EF%BC%9A%3CBR%20%2F%3E802_11_MAC_ADDRESS%20%5B0x4d%5D%E3%80%81act%200x1%E3%80%81len%2016%E3%80%81seqno%200x202c%20%E8%B6%85%E6%97%B6%205000%20%5B136.048852%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(136.029568)%EF%BC%9A%3CBR%20%2F%3E802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x202c%3CBR%20%2F%3E%5B%20136.050691%5D%20Register%20NXP%20802.11%20Adapter%20p2p0%3CBR%20%2F%3E%5B%20136.050845%5D%20wlan%3A%20version%20%3D%20SDIW612---18.99.3.p26.11-MM6X18540.p17-(FP92)%3CBR%20%2F%3E%5B%20136.050911%5D%20wlan0%3A%20QUEUE_CMD%3A%20REG_ACCESS%20%5B0x27c%5D%20is%20queued%3CBR%20%2F%3E%5B%20136.051016%5D%20p2p0%20set%20multicast_list%3CBR%20%2F%3E%5B%20136.051054%5D%20p2p0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20is%20queued%3CBR%20%2F%3E%5B%20136.051086%5D%20p2p0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20is%20queued%3CBR%20%2F%3E%5B%20136.051145%5D%20wlan0%3A%20DNLD_CMD%20(136.031870)%EF%BC%9AREG_ACCESS%20%5B0x27c%5D%E3%80%81act%200x0%E3%80%81len%2020%E3%80%81seqno%200x2d%20%E8%B6%85%E6%97%B6%205000%20%5B136.052103%5D%20wlan0%EF%BC%9ACMD_RESP%20(136.032816)%EF%BC%9A%3CBR%20%2F%3EREG_ACCESS%20%5B0x827c%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x2d%3CBR%20%2F%3E%5B%20136.052193%5D%20p2p0%3A%20DNLD_CMD%20(136.032918)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%20204%E3%80%81seqno%200x202e%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20136.052627%5D%20p2p0%EF%BC%9ACMD_RESP%20(136.033345)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x202e%3CBR%20%2F%3E%5B%20136.052682%5D%20p2p0%3A%20DNLD_CMD%20(136.033408)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200x202f%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20136.052998%5D%20p2p0%EF%BC%9ACMD_RESP%20(136.033717)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%2C%20result%200%2C%20len%2012%2C%20seqno%200x202f%3CBR%20%2F%3E%5B%20136.053200%5D%20wlan0%3A%20QUEUE_CMD%3A%20INDEPENDENT_RESET_CFG%20%5B0x243%5D%20is%20queued%3CBR%20%2F%3E%5B%20136.053281%5D%20wlan0%3A%20DNLD_CMD%20(136.034005)%EF%BC%9AINDEPENDENT_RESET_CFG%20%5B0x243%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x0%E3%80%81len%2012%E3%80%81seqno%200x30%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20136.053716%5D%20wlan0%EF%BC%9ACMD_RESP%20(136.034434)%EF%BC%9AINDEPENDENT_RESET_CFG%20%5B0x8243%5D%2C%20%E7%BB%93%E6%9E%9C%200%2C%20len%2012%2C%20seqno%200x30%3CBR%20%2F%3E%5B%20136.054120%5D%20vendor%20event%20%3A0x2%3CBR%20%2F%3E%5B%20136.054174%5D%20%3D%3D%3D%3D%3D%3D%3D%3DEND%20IN-BAND%20RESET%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20136.112302%5D%20wlan0%3A%20QUEUE_CMD%3A%20TXPWR_CFG%20%5B0xd1%5D%20is%20queued%3CBR%20%2F%3E%5B%20136.112439%5D%20wlan0%3A%20DNLD_CMD%20(136.093162)%3A%20TXPWR_CFG%20%5B0xd1%5D%E3%80%81act%200x0%E3%80%81len%2016%E3%80%81seqno%200x31%20%E8%B6%85%E6%97%B6%205000%20%5B136.112959%5D%20wlan0%EF%BC%9ACMD_RESP%20(136.093675)%EF%BC%9A%3CBR%20%2F%3ETXPWR_CFG%20%5B0x80d1%5D%EF%BC%8C%20result%200%EF%BC%8C%20len%20100%EF%BC%8C%20seqno%200x31%3CBR%20%2F%3E%5B%20136.123000%5D%20wlan0%20set%20multicast_list%3CBR%20%2F%3E%5B%20136.123064%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20is%20queued%3CBR%20%2F%3E%5B%20136.123110%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20is%20queued%3CBR%20%2F%3E%5B%20136.123195%5D%20wlan0%3A%20DNLD_CMD%20(136.103918)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81act%200x1%E3%80%81len%20204%E3%80%81seqno%200x32%20%E8%B6%85%E6%97%B6%205000%20%5B136.123686%5D%20wlan0%EF%BC%9ACMD_RESP%20(136.104404)%EF%BC%9A%3CBR%20%2F%3EMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x32%3CBR%20%2F%3E%5B%20136.123751%5D%20wlan0%3A%20DNLD_CMD%20(136.104476)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81act%200x213%E3%80%81len%2012%E3%80%81seqno%200x33%20%E8%B6%85%E6%97%B6%205000%20%3CBR%20%2F%3E%20%5B136.124071%5D%20wlan0%EF%BC%9ACMD_RESP%20(136.104789)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x33%3CBR%20%2F%3E%5B%20136.127648%5D%20wlan0%3A%20QUEUE_CMD%3A%20TXPWR_CFG%20%5B0xd1%5D%20is%20queued%3CBR%20%2F%3E%5B%20136.127786%5D%20wlan0%3A%20DNLD_CMD%20(136.108509)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x34%20%E8%B6%85%E6%97%B6%205000%20%5B136.128291%5D%20wlan0%EF%BC%9ACMD_RESP%20(136.109008)%EF%BC%9A%3CBR%20%2F%3ETXPWR_CFG%20%5B0x80d1%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20100%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x34%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%5B5.416061%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E4%B8%BA%E6%A0%B9%E7%94%A8%E6%88%B7%E4%BF%9D%E7%95%99%EF%BC%9A4952683%20%E5%AD%97%E8%8A%82%20(4836%20KiB)%20%5B5.416088%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E4%B8%BA%20w4%2Fr0%EF%BC%89%E3%80%81UUID%209C8DF7E6-05DA-4D41-A3C5-0029C4D16B41%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%5B5.557978%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E5%8D%B8%E8%BD%BD%20UBI%20%E8%AE%BE%E5%A4%87%200%20%5B5.5.r0%5D%5D%20UBIFS%20(ubi%200%3A8)%EF%BC%9A%E5%90%8E%E5%8F%B0%E8%AF%9D%E9%A2%98%20%22%20ubifs_bgt0_8%20%22%20%E5%81%9C%E6%AD%A2%20%5B82.542976%5D%20%E6%97%A0%E7%BA%BF%E5%B1%80%E5%9F%9F%E7%BD%91%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20MWLAN%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5B82.550306%5D%20wlan%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%88%B0%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%20%5B82.613986%5D%20vendor%3D0x0471%20device%3D0x0205%20class%3D0%20function%3D1%20%5B82.614205%5D%20Attach%20moal%20%E5%A4%84%E7%90%86%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%8D%A1%E7%89%8C%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%EF%BC%9A0x109%20%5B82.614248%5D%E6%9C%AA%E6%8C%87%E5%AE%9A%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%20cfg%20%E6%96%87%E4%BB%B6%5B%2082.614273%5D%20combo%20fw%3Anxp%2Fsduart_nw61x.bin.se%20wlan%20fw%3Anxp%2Fsd_w61x.bin.se%5B%2082.614273%5D%20combo%20fw%3Anxp%2Fsduart_nw61x.bin.se%20wlan%20fw%3Anxp%2Fsd_w61x.bin.se82.614317%5DSDIO%3A%20sdio_blk_size%3D256%20max_blk_count%3D512%20max_segs%3D64%20max_seg_size%3D4096%5B%2082.614333%5D%20rx_work%3D0%20cpu_num%3D1%5B%2082.614354%5D%20%E5%90%AF%E7%94%A8%20moal_recv_amsdu_packet%5B%2082.614448%5D%20%E9%99%84%E5%8A%A0%20mlan%20%E9%80%82%E9%85%8D%E5%99%A8%E6%93%8D%E4%BD%9C%E3%80%82card_type%20%E4%B8%BA%200x109%E3%80%8282.615544%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20TX%20SG%20%E6%A8%A1%E5%BC%8F%5B%2082.615573%5D%20wlan%3A%20mpa_tx.buf_size%3D4096%5B82.615583%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20RX%20SG%20%E6%A8%A1%E5%BC%8F%5B%2082.615594%5D%20wlan%3A%20mpa_rx.buf_size%3D4096%5B82.622224%5D%E8%AF%B7%E6%B1%82%E5%9B%BA%E4%BB%B6%EF%BC%9Anxp%2Fsd_w61x_v1.bin.se%5B82.748653%5D%20%E5%94%A4%E9%86%92%E8%AE%BE%E5%A4%87...%20%5B82.952631%5D%20%E6%97%A0%E7%BA%BF%E5%B1%80%E5%9F%9F%E7%BD%91%EF%BC%9A%E5%9B%BA%E4%BB%B6%E4%B8%8B%E8%BD%BD%E5%AE%8C%E6%AF%95%EF%BC%8C%E5%9B%BA%E4%BB%B6%3D681308%20%E5%B7%B2%E4%B8%8B%E8%BD%BD%20565508%20%5B83.349412%5D%20%E6%97%A0%E7%BA%BF%E5%B1%80%E5%9F%9F%E7%BD%91%E5%9B%BA%E4%BB%B6%E5%A4%84%E4%BA%8E%E6%B4%BB%E5%8A%A8%E7%8A%B6%E6%80%81%20%5B83.349451%5D%20on_time%20%E6%98%AF%2083330185801%20%5B83.349895%5D%20QUEUE_CMD%EF%BC%9AFUNC_INIT%20%5B0xa9%5D%20%E6%98%AF%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.349930%5D%20QUEUE_CMD%EF%BC%9AGET_HW_SPEC%20%5B0x3%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.349974%5D%20DNLD_CMD%20(83.330689)%EF%BC%9AFUNC_INIT%20%5B0xa9%5D%E3%80%81act%200x263%E3%80%81len%2016%E3%80%81seqno%200x1%20%E8%B6%85%E6%97%B6%205000%20%5B83.372560%5D%20CMD_RESP%20(83.353254)%EF%BC%9AFUNC_INIT%20%5B0x80a9%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1%5B%2083.372622%5D%20DNLD_CMD%20(83.353337)%EF%BC%9AGET_HW_SPEC%20%5B0x3%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x0%E3%80%81len%2071%E3%80%81seqno%200x2%20%E8%B6%85%E6%97%B6%205000%20%5B83.372964%5D%2083.353669%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.373008%5D%20VDLL_IND%EF%BC%88%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%89%EF%BC%9Aoffset%3D0x1c458%20%5B83.373947%5D%20VDLL%20%E5%9B%BE%E7%89%87%EF%BC%9Alen%3D115800%20%5B83.37800%5D%204253%5D%20CMD_RESP%20(83.354955)%EF%BC%9AGET_HW_SPEC%20%5B0x8003%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20205%EF%BC%8C%E5%BA%8F%E5%88%97%200x2%20%5B83.374281%5D%20fw_cap_info%3D0x487cff03%EF%BC%8Cdev_cap_mask%3D0xffffff%20%5B83.374299%5D%20GET_HW_SPEC%EF%BC%9Acountry_code%3D0x0%20%5B83.374310%5D%20num_ant%3D1%EF%BC%8Cantinfo%3D0%20x0%20%5B83.374324%5D%20GET_HW_SPEC%EF%BC%9Ahw_mpdu_density%3D4%20dev_mcs_support%3D0x11%20%5B83.374335%5D%20%E5%90%AF%E7%94%A8%E6%B3%A2%E6%9D%9F%E8%B5%8B%E5%BD%A2%20%5B83.374350%5D%20GET_HW_SPEC%EF%BC%9Amgmt%20IE%20count%3D13%20%5B83.374365%5D%20FW%EF%BC%9ASDIO%20rx%20aggr%20%E5%B7%B2%E7%A6%81%E7%94%A8%200x487cff03%20%5B83.374381%5D%5D%20pmadapter-%26gt%3B%20ecsa_enable%3D1%20%5B83.374415%5D%20QUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.374429%5D%20pmadapter-%26gt%3B%20getlog_enable%3D1%20%5B83.374451%5D%20chanrpt%20api%20ver%3D14.1%20%5B83.374464%5D%20fw_cap_info%3D0x487cff03%20fw_cap_ext%3D0x2182b5%5B%2083.374479%5D%20uuid%3A%20c10d697cf87d596cab35c831392df315%5B%2083.374491%5D%20fw%20hotfix%20ver%3D11%5B%2083.374502%5D%20fw%20ver%3D15.1%5B83.374512%5D%20uap%20fw%20ver%3D2.0%5B83.374523%5D%20max_p2p_conn%20%3D%208%EF%BC%8Cmax_sta_conn%20%3D%2016%20%5B83.374541%5D%20wlan_set_regiontable%EF%BC%9A2.4G%200x10%20%5B83.374561%5D%20wlan_set_regiontable%EF%BC%9A5G%200x10%20%5B83.374599%5D%20%E5%AE%8C%E6%88%90%E6%93%8D%E4%BD%9C%E8%A7%84%E8%8C%83%EF%BC%8Cfw_cap%3D0x487cff03%20%5B83.374630%5D%20_drv_mode%3D0x7%20drv_mode%3D0x7%20%5B83.375214%5D%20%E5%90%AF%E7%94%A8%E6%B3%A2%E6%9D%9F%E8%B5%8B%E5%BD%A2%20%5B83.375274%5D%20QUEUE_CMD%EF%BC%9A802_11_FW_WAKE_METHOD%20%5B0x74%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.375301%5D%20%E8%AE%BE%E7%BD%AE%20tx_buf%20%3D%204096%20%5B83.375321%5D%20QUEUE_CMD%EF%BC%9ARECONFIGURE_TX_BUD%20FF%20%5B0xd9%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.375347%5DPS%20%E5%91%BD%E4%BB%A4%EF%BC%9A%E5%8A%A8%E4%BD%9C%20%3D%200x6%EF%BC%8C%E4%BD%8D%E5%9B%BE%20%3D%200x1%20%5B83.375365%5D%20QUEUE_CMD%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.375395%5D%20QUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.375424%5D%20QUEUE_CMD%EF%BC%9A802_11_RF_%E5%A4%A9%E7%BA%BF%20%5B0x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.375453%5D%20QUEUE_CMD%EF%BC%9ACHAN_REGION_CFG%20%5B0x242%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.375484%5D%20QUEUE_CMD%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.375511%5D%20QUEUE_CMD%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%20%E6%98%AF%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.375539%5D%20QUEUE_CMD%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0xdf%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.375566%5D%20QUEUE_CMD%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.375609%5D%20DNLD_CMD%20(83.356326)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8C%E7%AC%AC%2015%20%E8%BD%AE%EF%BC%8C%E5%BA%8F%E5%88%97%200x3%20%E8%B6%85%E6%97%B6%205000%20%5B83.376003%5D%20CMD_RESP%20(83.356703)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2015%EF%BC%8C%E5%BA%8F%E5%88%97%200x3%20%5B83.376057%5D%20DNLD_CMD%20(83.356773)%EF%BC%9A802_11_FW_WAKE_METHOD%20%5B0x74%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x4%20%E8%B6%85%E6%97%B6%205000%20%5B83.376391%5D%20CMD_RESP%20(83.357094)%EF%BC%9A802_11_FW_WAKE_METHOD%20%5B0x8074%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2018%EF%BC%8Cseqno%200x4%20%5B83.376416%5D%20FW%20%E5%94%A4%E9%86%92%E6%96%B9%E6%B3%95%20%3D1%EF%BC%8Cgpio%3D0%20%5B83.376454%5D%20DNLD_CMD%20(83.357172)%EF%BC%9ARECONFIGURE_TX_BUFF%20%5B0xd9%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2016%E3%80%81seqno%200x5%20%E8%B6%85%E6%97%B6%205000%20%5B83.377529%5D%20CMD_RESP%20(83.358231)%EF%BC%9A%E9%87%8D%E6%96%B0%E9%85%8D%E7%BD%AE_TX_BUFF%20%5B0x80d9%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E5%BA%8F%E5%88%97%200x5%20%5B83.377559%5D%20%E7%AB%AF%E5%8F%A3%2032%EF%BC%8C%E6%95%B0%E6%8D%AE%E7%AB%AF%E5%8F%A3%E6%8E%A9%E7%A0%81%20fffffff%20%5B83.377575%5D%20max_tx_buf_size%3D4096%EF%BC%8Ctx_buf_size%3D3328%20%5B83.377612%5D%20DNLD_CMD%20(83.35837)%2029)%3A%20802_11_PS_MODE_ENH%20%5B0xe4%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x6%E3%80%81len%2020%E3%80%81seqno%200x6%20%E8%B6%85%E6%97%B6%205000%20%5B83.377947%5D%20CMD_RESP%20(83.358650)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2020%EF%BC%8C%E5%BA%8F%E5%88%97%200x6%20%5B83.377995%5D%20DNLD_CMD%20(83.358713)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2018%E3%80%81seqno%200x7%20%E8%B6%85%E6%97%B6%205000%20%5B83.378324%5D%20CMD_RESP%20(83.359029)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2018%EF%BC%8C%E5%BA%8F%E5%88%97%200x7%20%5B8x7%5D%203.378374%5D%20DNLD_CMD%20(83.359090)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200xc%E3%80%81len%2016%E3%80%81seqno%200x8%20%E8%B6%85%E6%97%B6%205000%20%5B83.378707%5D%20CMD_RESP%20(83.359411)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x8%20%5B83.378757%5D%20DNLD_CMD%20(83.3594947)%2072)%3ACHAN_REGION_CFG%20%5B0x242%5D%E3%80%81act%200x0%E3%80%81len%2011%E3%80%81seqno%200x9%20%E8%B6%85%E6%97%B6%205000%20%5B83.380238%5D%20CMD_RESP%20(83.360924)%EF%BC%9ACHAN_REGION_CFG%20%5B0x8242%5D%EF%BC%8Cresult%200%EF%BC%8Clen%201297%EF%BC%8Cseqno%200x9%5B%2083.380344%5D%20DNLD_CMD%20(83.361055)%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2076%EF%BC%8Cseqno%200xa%20%E8%B6%85%E6%97%B6%205000%20%5B83.381077%5D%20CMD_RESP%20(83.361775)%EF%BC%9ATX_RATE_CFG%20%5B0x80d6%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20832%EF%BC%8C%E5%BA%8F%E5%88%97%200xa%20%5B83.381136%5D%20DNLD_CMD%20(83.361851)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2014%EF%BC%8C%E9%A1%BA%E5%BA%8F%200xb%20%E8%B6%85%E6%97%B6%205000%20%5B83.381490%5D%20CMD_RESP%20(8x1e)%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2014%EF%BC%8C%E9%A1%BA%E5%BA%8F%200xb%20%E8%B6%85%E6%97%B6%205000%20%5B83.381490%5D%20CMD_RESP%20(8x1e)%203.362193)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x801e%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8C%E5%BA%8F%E5%88%97%200xb%20%5B83.381539%5D%20DNLD_CMD%20(83.362255)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0xdf%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2014%E3%80%81seqno%200xc%20%E8%B6%85%E6%97%B6%205000%20%5B83.381859%5D%20CMD_RESP%20(83.362563)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0x80df%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200xc%5B%2083.381908%5D%20DNLD_CMD%20(83.362624)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200xd%20%E8%B6%85%E6%97%B6%205000%20%5B83.382235%5D%20CMD_RESP%20(83.362940)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200xd%5B%2083.382289%5D%20QUEUE_CMD%3A%20APCMD_SYS_CONFIGURE%20%5B0xb0%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%2083.382328%5D%20DNLD_CMD%20(83.363045)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x100e%20%E8%B6%85%E6%97%B6%205000%20%5B83.383416%5D%20CMD_RESP%20(83.364108)%EF%BC%9AQUEUE_CMD%3A%20MAC_CONTROL%20%5B0x80b0%5D%2C%20result%200%2C%20len%2020%2C%20seqno%200x100e%5B%2083.383478%5D%20QUEUE_CMD%3A%20TX_RATE_CFG%20%5B0xd6%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%2083.383510%5D%20QUEUE_CMD%3A%20802_11_RF_TX_POWER%20%5B0x1e%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%2083.383539%5D%20QUEUE_CMD%3A%20AMSDU_AGGR_CTRL%20%5B0xdf%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%2083.383567%5D%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x80b0%5D%2C%20result%200%2C%20len%2020%2C%20seqno%200x100e%5B%2083.383478QUEUE_CMD%3A%20802_11_RF_TX_POWER%20%5B0x1e%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%E4%B8%AD%5B%2083.383539%5D%20QUEUE_CMD%3A%20AMSDU_AGGR_CTRL%20%5B0xdf%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%E4%B8%AD%5B%2083.383567%5D%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%E4%B8%AD%5B%2083.383593%5D%20QUEUE_CMD%3A%20802_11_MAC_ADDRESS%20%5B0x4d%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%E4%B8%AD%5B%2083.383630%5D%20DNLD_CMD%20(83.364347)%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2076%EF%BC%8Cseqno%200x200f%20%E8%B6%85%E6%97%B6%205000%20%5B83.387943%5D%20CMD_RESP%20(83.368633)%EF%BC%9ATX_RATE_CFG%20%5B0x80d6%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20832%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x200f%20%5B83.388009%5D%20DNLD_CMD%20(83.368722)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2010%20%E8%B6%85%E6%97%B6%205000%20%5B83.388382%5D%20CMD_POWER%20%5B0x1e%5D%20RESP%20(83.369085)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x801e%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8C%E7%AC%AC%2014%20%E8%A1%8C%EF%BC%8C%E5%BA%8F%E5%88%97%200x2010%20%5B83.388433%5D%20DNLD_CMD%20(83.369149)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0xdf%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2011%20%E8%B6%85%E6%97%B6%205000%20%5B83.38775%5D%20CMD_RESP%20(83.369478)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0x80df%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2011%5B%2083.388825%5D%20DNLD_CMD%20(83.369541)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81act%200x213%E3%80%81len%2012%E3%80%81seqno%200x2012%20%E8%B6%85%E6%97%B6%205000%20%5B83.389139%5D%20CMD_RESP%20(83.369844)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2012%20%5B83.389187%5D%20DNLD_CMD%20(83.369904)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4D%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2016%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x2013%20%E8%B6%85%E6%97%B6%205000%20%5B83.389639%5D%20CMD_RESP%20(83.370340)%EF%BC%9A80%202_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2013%20%5B83.389700%5D%20QUEUE_CMD%EF%BC%9AWMM_PARAM_CONFIG%20%5B0x23a%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.389749%5D%20DNLD_CMD%20(83.370464)%EF%BC%9AWMM_PARAM_CONFIG%20%5B0x23a%5D%E3%80%81act%200x2%E3%80%81len%2026%E3%80%81seqno%200x14%20%E8%B6%85%E6%97%B6%205000%20%5B83.390091%5D%20CMD_RESP%20(83.370793)%EF%BC%9AWMM_PARAM_CONFIG%20%5B0x823a%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2026%EF%BC%8C%E5%BA%8F%E5%88%97%200x14%20%5B83.392977%5D%20%E8%AE%BE%E7%BD%AE%20wiphy%20max_ap_assoc_sta%3D8%20%5B83.393072%5D%20max_rate%3D390M%20%5B83.393089%5D%20max_rate%3D390M%20%5B83.393108%5D%20vht_cap%3D0x33d07030%20rx_mcs_map%3D0xffe%20rx_max%3D0x186%20tx_mcs_map%3D0xfffe%20tx_max%3D0x186%20%5B83.393129%5D%20max_rate%3D390m%20%5B83.393139%5D%20max_rate%3D390M%20%5B83.393155%5D%20vht_cap%3D0x33d07030%20rx_mcs_map%3D0xffe%20rx_max%3D0xffe%20rx_max%3D0xffe%20rx_max%3D0xffe%20rx_max%3D0xffe%20rx_max%3D0xffe%20rx_max%3D0xffe%20rx_max0x186%20tx_mcs_map%3D0xffe%20tx_max%3D0x186%20%5B83.393191%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.407537%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.388260)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200xc%EF%BC%8Clen%2016%EF%BC%8C%E5%BA%8F%E5%88%97%200x15%20%E8%B6%85%E6%97%B6%205000%20%5B83.408034%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.38856)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x15%20%5B83.408202%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.408278%5D%20wlan%25d%20d%EF%BC%9ADNLD_CMD%20(83.389008)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x0%E3%80%81len%20142%E3%80%81seqno%200x16%20%E8%B6%85%E6%97%B6%205000%20%5B83.408707%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.389430)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x16%20%5B83.408860%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.408930%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.389661)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%20142%EF%BC%8Cseqno%200no%20x17%20%E8%B6%85%E6%97%B6%205000%20%5B83.409425%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.390146)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20142%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x17%20%5B83.409582%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.409653%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.390383)%3A%20802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x0%E3%80%81len%20142%E3%80%81seqno%200x18%20%E8%B6%85%E6%97%B6%205000%20%5B83.410075%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.390798)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20142%EF%BC%8C%E5%BA%8F%E5%88%97%200x18%20%5B83.410606%5D%5D%20cfg80211%20%E7%9B%91%E7%AE%A1%E5%8A%9F%E8%83%BD%E5%9F%9F%E5%9B%9E%E8%B0%83%2000%20%E5%90%AF%E5%8A%A8%E5%99%A8%3D0%20dfs_region%3D0%20%5B83.410668%5D%20%E7%9B%91%E7%AE%A1%E5%8A%9F%E8%83%BD%E5%9F%9F%20BY_CORE%20%5B83.410738%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.410973%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.391699)%EF%BC%9A802_111199%20_RF_%E5%A4%A9%E7%BA%BF%20%5B0x20%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200xc%E3%80%81len%2016%E3%80%81seqno%200x19%20%E8%B6%85%E6%97%B6%205000%20%5B83.411461%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.392183)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x19%20%5B83.411802%5DPS%20%E5%91%BD%E4%BB%A4%EF%BC%9A%E5%8A%A8%E4%BD%9C%20%3D%200x0%EF%BC%8C%E4%BD%8D%E5%9B%BE%20%3D%200x0%20%5B83.411833%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.411914%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.392643)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2012%EF%BC%8C%E5%BA%8F%E5%88%97%200x1a%20%E8%B6%85%E6%97%B6%205000%20%5B83.412367%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.393090)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2068%EF%BC%8C%E9%A1%BA%E5%BA%8F%E5%8F%B7%200x1a%20%5B83.412416%5D%20ps_bitmap%3D0x0%20%5B83.412535%5D%20CFG80211%3A%20country%3D00%EF%BC%8Cband%3D0%EF%BC%8Cno_of_sub_band%3D1%20%5B83.412577%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.412633%5D%2011D%3A%20country%3DWW%20band%3D0%20subband%3D1%20dfs_region%3D0%20%5B83.412650%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D1%20no_of_chan%20%3D%2014%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.412665%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.412694%5D%20wlan_set_regiontable%EF%BC%9A2.4G%200x0%20%5B83.412794%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%20%5B83.412794%5D%20wlan_set_regiontable%20lan%25d%EF%BC%9ADNLD_CMD%20(83.393523)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2016%E3%80%81seqno%200x1b%20%E8%B6%85%E6%97%B6%205000%20%5B83.413234%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.393957)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1b%20%5B83.413292%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.394022)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2032%EF%BC%8Cseqno%200x1c%20%E8%B6%85%E6%97%B6%205000%20%5B83.413739%5D%20wlan%25d%EF%BC%9A83.394463%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x1c%5D%20%E8%B6%85%E6%97%B6%205000%20%5B83.413739%5D%20wlan%25d%EF%BC%9A83.394463%EF%BC%9A%E6%B4%BB%E5%8A%A8%EF%BC%9AVDLL_IND%20%5B0x1c%5D%20x81%5D%20%5B83.413802%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23offset%20%3D%200xe808%20len%20%3D%20600%20%5B83.413827%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.431747%5D%20wlan%25d%EF%BC%9A83.412467%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.41826%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xea60%20len%20%3D%20600%20%5B83.431826%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xea60%20len%20%3D%20600%20431855%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.432517%5D%20wlan%25d%EF%BC%9A83.413237%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.432590%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xecb8%20len%20%3D%20600%20%5B83.432617%5D%20wlan%25d%EF%BC%9ADNLD_VLD%20DLL%EF%BC%9Ablock_len%3D600%20%5B83.433205%5D%20wlan%25d%EF%BC%9A83.413926%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.433276%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xef10%20len%20%3D%20600%20%5B83.433301%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.434301%5D%20255%5Dwlan%25d%EF%BC%9A83.414977%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.434325%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf168%20len%20%3D%20600%20%5B83.434348%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.434915%5D%20wlan%25d%EF%BC%9A83.415636%3A%20%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.434987%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf3c0%20len%20%3D%20600%20%5B83.435010%5D%20wlan%25d%EF%BC%9A%20%E8%A1%8C%E5%8A%A8_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.435581%5D%20wlan%25d%EF%BC%9A83.416302%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.435652%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf618%20len%20%3D%20600%20%5B83.435675%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3DDLL%20600%20%5B83.436242%5D%20wlan%25d%EF%BC%9A83.416962%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.436313%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf870%20len%20%3D%20600%20%5B83.436338%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.436923%5D%20wlan%25d%EF%BC%9Ablock_len%3D600%20%5B83.436923%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.436923%5D%20wlan%25d%20lan%25d%EF%BC%9A83.417645%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.436995%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xfac8%20len%20%3D%20600%20%5B83.437019%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.451150%5D%20wlan%25d%EF%BC%9A%E6%B4%BB%E5%8A%A8%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83%5D.451232%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xc4e0%20len%20%3D%20600%20%5B83.451260%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.469048%5D%20wlan%25d%EF%BC%9A83.449766%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.469131%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xc738%20len%20%3D%20600%20%5B83.469158%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.469811%5D%20wlan%25d%EF%BC%9A83.450531%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.469883%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xc81%20990%20len%20%3D%20600%20%5B83.469909%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.470486%5D%20wlan%25d%EF%BC%9A83.451207%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.470558%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xcbe8%20len%20%3D%20600%20%5B83.470558%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xcbe8%20len%20%3D%20600%20%5B83.470558%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xcbe8%20584%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.471148%5D%20wlan%25d%EF%BC%9A83.451869%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.471220%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xce40%20len%20%3D%20600%20%5B83.471247%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.471960%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.452682)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2032%EF%BC%8Cseqno%200x1c%20%5B83.472106%5D%20CFG80211%EF%BC%9ACountry%3D0%EF%BC%8Cband%3D1%EF%BC%8Cno_of_sub_band%3D25%20%5B83.472166%5D%2011d%3A%20country%3DWW%20band%3D1%20subband%3D25%20df_band%3D25%20s_region%3D0%20%5B83.472182%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E4%B8%AA%20chan%3D36%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472194%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E4%B8%AA%20chan%3D40%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472205%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E4%B8%AA%20chan%3D44%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472216%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D48%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472227%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D52%20no_of_chan%3D1%EF%BC%8Cmax_twr%3D20%20%5B83.472239%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D56%20no_of_chan%3D1%EF%BC%8Cmax_twr%3D1%20x_pwr%3D20%20%5B83.472249%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D60%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472261%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D64%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%20%5B83.472272%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D100%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472284%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D104%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472295%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D108%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472307%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D112%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472318%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D116%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472330%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D120%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D1%EF%BC%8Cmax_tx_pwr%3D20%20_tx_pwr%3D20%20%5B83.472341%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D124%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472353%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D128%20no_of_chan%3D1%EF%BC%8Cmax_twr%3D20%20%5B83.472365%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D132%20no_of_chan%3D1%EF%BC%8Cmax_twr%3D1%20x_pwr%3D20%20%5B83.472376%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E4%B8%AA%20chan%3D136%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472388%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E4%B8%AA%20chan%3D140%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472399%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D144%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472411%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%E6%9C%BA%E4%BC%9A%20%3D149%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472422%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D153%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472434%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D157%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472446%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D161%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472457%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D165%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.472475%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.472507%5D%20wlan_set_set_%E5%8C%BA%E5%9F%9F%E8%A1%A8%EF%BC%9A2.4G0x0%20%5B83.472526%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%20%5B83.472603%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.453331)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%20104%E3%80%81seqno%200x1d%20%E8%B6%85%E6%97%B6%205000%20%5B83.494139%5D%20wlan%25d%EF%BC%9ACMD_D%20RESP%20(83.474857)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20104%EF%BC%8Cseqno%200x1d%20%5B83.494780%5D%20%E8%AE%BE%E7%BD%AE%20wlan%25d%20%E6%8E%A5%E5%8F%A3%E5%9C%B0%E5%9D%80%EF%BC%9A30%3Axx%3Axx%3Axx%3A8c%3A11%20%5B83.494841%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_MAC_ADDRESS%20%5B02_11_MAC_ADDRESS%20%5B02%5D%20x4d%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.494928%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(83.475657)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2016%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x1e%20%E8%B6%85%E6%97%B6%205000%20%5B83.495415%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(83.476138)%EF%BC%9A802_11_MAC_MAC_138%20%E5%9C%B0%E5%9D%80%20%5B0x804d%5D%EF%BC%8C%E7%BB%93%E6%9E%9C0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1e%20%5B83.497089%5D%20%E6%B3%A8%E5%86%8C%E6%81%A9%E6%99%BA%E6%B5%A6%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20wlan0%20%5B83.497471%5D%20uap%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A11AX_CFG%20%5B0x266%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.497582%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9AMAC_MULTICAST_CMD%20_ADR%20%5B0x10%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.497654%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B%2083.509486%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(83.490204)%EF%BC%9A11AX_CFG%20%5B0x266%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2039%EF%BC%8Cseqno%200x101f%20%E8%B6%85%E6%97%B6%205000%20%5B83.510032%5D%20wlan0%EF%BC%9A83.490754%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.510109%5D%20VDLL_IND%3A%20type%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xfd20%20len%20%3D%20600%20%5B83.510135%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.528293%5D%20wlan0%EF%BC%9A83.509009%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.528377%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xff78%20len%20%3D%20600%20%5B83.528405%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.529075%5D%20wlan0%EF%BC%9A83.509795%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.529151%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x101d0%20len%20%3D%20600%20%5B83.529176%5D%20wlan0%3A%20DNLD_VDLL%3Ablock_len%3D600%20%5B83.529781%5D%20wlan0%EF%BC%9A83.510504%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.529849%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x10428%20len%20%3D%20600%20%5B83.529871%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.530428%5D%20len%20%3D%20600%20%5B83.529871%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%2044%5D%20wlan0%EF%BC%9A83.511164%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B83.530517%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x10680%20len%20%3D%20600%20%5B83.530541%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.531107%5D%20wlan0%EF%BC%9A83.511826%EF%BC%9A%E4%BA%8B%E4%BB%B6%3AVDLL_IND%20%5B0x81%5D%20%5B83.531178%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x108d8%20len%20%3D%20600%20%5B83.531202%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B83.531884%5D%20uap%25d%EF%BC%9ACMD_RESP%20(83.512604)%EF%BC%9A11AX_CFG%20%5B0x8266%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen39%EF%BC%8Cseqno%200x101f%20%5B83.531948%5D%20user_2g_hecap_len%3D28%20%5B83.531997%5D%20wlan0%EF%BC%9ADNLD_CMD%20(83.512726)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81act%200x1%E3%80%81len%20204%E3%80%81seqno%200x20%20%E8%B6%85%E6%97%B6%205000%20%5B83.532430%5D%20wlan0%EF%BC%9ACMD_RESP%20(83.513154)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x20%5B%2083.532484%5D%20wlan0%3A%20DNLD_CMD%20(83.513216)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200x21%20%E8%B6%85%E6%97%B6%205000%20%5B83.532797%5D%20wlan0%EF%BC%9ACMD_RESP%20(83.513521)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8C%E5%BA%8F%E5%88%97%200x21%20%5B83.532964%5D%20uap%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A11AX_CFG%20%5B0x266%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.533051%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(83.513779)%EF%BC%9A11AX_CFG%20%5B0x266%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2039%EF%BC%8Cseqno%200x1022%20%E8%B6%85%E6%97%B6%205000%20%5B83.533496%5D%20uap%25d%EF%BC%9ACMD_RESP%20(83.514218)%EF%BC%9A11AX_CFG%20%5B0x8266%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2039%EF%BC%8Cseqno%200x1022%20%5B83.533548%5D%20user_hecap_len%3D28%20%5B83.539872%5D%20%E8%AE%BE%E7%BD%AE%20uap%25d%20%E6%8E%A5%E5%8F%A3%E5%9C%B0%E5%9D%80%EF%BC%9A32%3Axx%3Axx%3Axx%3A8d%3A11%20%5B83.539937%5D%20uap%25d%EF%BC%9AQUEUE_CMD%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.540028%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(83.520757)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%E3%80%81act%200x1%E3%80%81len%2020%E3%80%81seqno%200x1023%20%E8%B6%85%E6%97%B6%205000%20%5B83.540517%5D%20uap%25d%EF%BC%9ACMD_RESP%20(83.521240)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0x80b0%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x1023%5B%2083.542165%5D%20%E6%B3%A8%E5%86%8C%E6%81%A9%E6%99%BA%E6%B5%A6%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20uap0%5B%2083.542494%5DPS%20%E5%91%BD%E4%BB%A4%EF%BC%9A%E5%8A%A8%E4%BD%9C%20%3D%200x0%EF%BC%8C%E4%BD%8D%E5%9B%BE%20%3D%200x0%20%5B83.542521%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.542607%5D%20uap0%20%E8%AE%BE%E7%BD%AE%E5%A4%9A%E6%92%AD%E5%88%97%E8%A1%A8%20%5B83.543135%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(83.523858)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x0%E3%80%81len%2012%E3%80%81seqno%200x2024%20%E8%B6%85%E6%97%B6%205000%20%5B83.543643%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(83.524364)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2068%EF%BC%8C%E5%BA%8F%E5%88%97%200x2024%20%5B83.54364%5D%20ps_bitmap%3D0x0%20%5B83.543799%5D%20CFG80211%EF%BC%9ACountry%3D00%EF%BC%8Cband%3D0%EF%BC%8Cno_of_sub_band%3D1%20%5B83.543841%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.543895%5D%2011d%3A%20country%3DWW%20band%3D0%20subband%3D1%20dfs_band%3D1%20dfs_1%20region%3D0%20%5B83.543910%5D11D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D1%20no_of_chan%3D14%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.543925%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.543954%5D%20wlan_set_regiontable%EF%BC%9A2.4G%200x0%20%5B83.543973%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%20%5B83.544059%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(83.524786)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2016%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x2025%20%E8%B6%85%E6%97%B6%205000%20%5B83.544517%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(83.525239)%EF%BC%9A802_11_SN_SNN9%20MP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x2025%20%5B83.544580%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(83.525310)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2032%E3%80%81seqno%200x2026%20%E8%B6%85%E6%97%B6%205000%20%5B83.566231%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(83.546947)%3A%20802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2032%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2026%20%5B83.566411%5D%20CFG80211%EF%BC%9ACountry%3D00%EF%BC%8Cband%3D1%EF%BC%8Cno_of_sub_band%3D25%20%5B83.566474%5D%2011D%3A%20country%3DWW%20band%3D1%20%E5%AD%90%E6%B3%A2%E6%AE%B5%3D25%20dfs_region%3D0%20%5B83.566489%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D36%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566501%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D40%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566513%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D44%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566524%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D48%20no_chan%3D20%20_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566535%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D52%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566546%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D56%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566557%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D60%20no_of_chan%20%3D1%2Cmax_tx_pwr%3D20%20%5B83.566569%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D64%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566580%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D100%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566592%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D104%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566604%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D108%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566615%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D112%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566627%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D116%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566638%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D120%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566650%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D124%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566661%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D128%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566673%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D132%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566685%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D128%20136%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566696%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D140%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566708%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D144%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566720%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%E6%9C%BA%E4%BC%9A%20%3D149%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566731%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D153%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566743%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D157%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566755%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D161%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566767%5D%2011D%EF%BC%9A%E7%AC%AC%E4%B8%80%E6%AC%A1%20chan%3D165%20no_of_chan%3D1%EF%BC%8Cmax_tx_pwr%3D20%20%5B83.566784%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.566815%5D%20wlan_set_regiontable%EF%BC%9A2.4G%200x0%20%5B83.566835%5D%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%20%5B83.566911%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(83.547640)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%20104%E3%80%81seqno%200x2027%20%E8%B6%85%E6%97%B6%205000%20%5B83.588510%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(83.5585)%2069226)%3A%20802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20104%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2027%20%5B83.598432%5D%20%E8%AE%BE%E7%BD%AE%20WFD%20%E8%AE%BE%E5%A4%87%E5%9C%B0%E5%9D%80%EF%BC%9A32%3Axx%3Axx%3Axx%3A8c%3A11%20%5B83.598498%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B83.598592%5D%20p2p%25d%EF%BC%9ADNLD_D%20CMD%20(83.579322)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4D%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2016%E3%80%81seqno%200x2028%20%E8%B6%85%E6%97%B6%205000%20%5B83.599075%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(83.579798)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2028%208%20%5B83.600896%5D%20%E6%B3%A8%E5%86%8C%E6%81%A9%E6%99%BA%E6%B5%A6%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20p2p0%20%5B83.601044%5D%20%E6%97%A0%E7%BA%BF%E5%B1%80%E5%9F%9F%E7%BD%91%EF%BC%9A%E7%89%88%E6%9C%AC%20%3D%20sdiw612---18.99.3.p26.11-mm6x18540.p17-(FP92)%20%5B83.601125%5D%20wlan0%3A%20QUEUE_CMD%3A%20REG_ACCESS%20%5B0x27c%5D%20is%20queued%5B%2083.601706%5D%20p2p0%20set%20multicast_list%5B%2083.601758%5D%20p2p0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%2083.601798%5D%20p2p0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%2083.601862%5D%20wlan0%3A%20DNLD_CMD%20(83.582592)%EF%BC%9AREG_ACCESS%20%5B0x27c%5D%E3%80%81act%200x0%E3%80%81len%2020%E3%80%81seqno%200x29%20%E8%B6%85%E6%97%B6%205000%20%5B83.602352%5D%20wlan0%EF%BC%9ACMD_RESP%20(83.583074)%EF%BC%9AREG_ACCESS%20%5B0x827c%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x29%5B%2083.602435%5D%20p2p0%3A%20DNLD_CMD%20(83.583164)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%20204%E3%80%81seqno%200x202a%20%E8%B6%85%E6%97%B6%205000%20%5B83.602875%5D%20p2p0%EF%BC%9ACMD_RESP%20(83.583599)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x202a%5B%2083.602933%5D%20p2p0%3A%20DNLD_CMD%20(83.583663)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81act%200x213%E3%80%81len%2012%E3%80%81seqno%200x202b%20%E8%B6%85%E6%97%B6%205000%20%5B83.603253%5D%20p2p0%EF%BC%9ACMD_RESP%20(83.583977)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x202b%5B%2083.649540%5D%20%E8%AE%BE%E7%BD%AE%20REG%200x90002328%EF%BC%9A0x13d57%20slew_rate%3D3%5B%2083.649608%5D%20wlan0%3A%20QUEUE_CMD%3A%20REG_ACCESS%20%5B0x27c%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%2083.649704%5D%20wlan0%3A%20DNLD_CMD%20(83.630433)%EF%BC%9AREG_ACCESS%20%5B0x27c%5D%E3%80%81act%200x1%E3%80%81len%2020%E3%80%81seqno%200x2c%20%E8%B6%85%E6%97%B6%205000%20%5B83.650198%5D%20wlan0%EF%BC%9ACMD_RESP%20(83.630922)%EF%BC%9AREG_ACCESS%20%5B0x827c%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x2c%5B%2083.650381%5D%20wlan0%3A%20QUEUE_CMD%3A%20INDEPENDENT_RESET_CFG%20%5B0x243%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%2083.650456%5D%20wlan0%3A%20DNLD_CMD%20(83.631187)%EF%BC%9AINDEPENDENT_RESET_CFG%20%5B0x243%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2d%20%E8%B6%85%E6%97%B6%205000%20%5B83.650885%5D%20wlan0%EF%BC%9ACMD_RESP%20(83.631608)%EF%BC%9AINDEPENDENT_RESET_CFG%20%5B0x8243%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2d%20%5B83.651544%5D%20wlan%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%88%B0%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%AE%8C%E6%88%90%20%5B83.651568%5D%20wlan%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%88%90%E5%8A%9F%E5%8A%A0%E8%BD%BD%20%5B91.250327%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B91.250455%5D%20wlan%20lan0%EF%BC%9ADNLD_CMD%20(91.231183)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2e%20%E8%B6%85%E6%97%B6%205000%20%5B91.250979%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.231700)%EF%BC%9ATXPWR_CFG%20%5B0x80d1%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20140%EF%BC%8Cseqno%200x2e%5B%2091.251505%5D%20wlan0%3A%20QUEUE_CMD%3A%20TXPWR_CFG%20%5B0xd1%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%2091.251610%5D%20wlan0%3A%20DNLD_CMD%20(91.232338)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2f%20%E8%B6%85%E6%97%B6%205000%20%5B91.252073%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.232795)%EF%BC%9ATXPWR_CFG%20%5B0x80d1%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20140%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2f%20%5B91.256518%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B91.256644%5D%20wlan0%EF%BC%9ADNLD_CMD%20(91.237371)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20x20%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200xc%E3%80%81len%2016%E3%80%81seqno%200x30%20%E8%B6%85%E6%97%B6%205000%20%5B91.257138%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.237860)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x30%20%5B91.262751%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B91.262879%5D%20wlan0%EF%BC%9ADNLD_CMD%20(91.243606)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%E3%80%81act%200x0%E3%80%81len%2016%E3%80%81seqno%200x31%20%E8%B6%85%E6%97%B6%205000%20%5B91.263360%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.244082)%EF%BC%9ATXPWR_CFG%20%5B0x80d1%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20140%EF%BC%8Cseqno%200x31%5B%2091.263875%5D%20wlan0%3A%20QUEUE_CMD%3A%20TXPWR_CFG%20%5B0xd1%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%2091.263981%5D%20wlan0%3A%20DNLD_CMD%20(91.244710)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x32%20%E8%B6%85%E6%97%B6%205000%20%5B91.264440%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.245161)%EF%BC%9ATXPWR_CFG%20%5B0x80d1%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20140%EF%BC%8Cseqno%200x32%5B%2091.273598%5D%20wlan0%3A%20QUEUE_CMD%EF%BC%9ARX_MGMT_IND%20%5B0x10c%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%2091.273755%5D%20wlan0%3A%20DNLD_CMD%20(91.254481)%EF%BC%9ARX_MGMT_IND%20%5B0x10c%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2014%E3%80%81seqno%200x33%20%E8%B6%85%E6%97%B6%205000%20%5B91.274249%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.254971)%EF%BC%9ARX_MGMT_IND%20%5B0x810c%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x33%5B%2091.285501%5D%20wlan0%3A%20QUEUE_CMD%3A%20TXPWR_CFG%20%5B0xd1%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%2091.285628%5D%20wlan0%3A%20DNLD_CMD%20(91.266356)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%E3%80%81act%200x0%E3%80%81len%2016%E3%80%81seqno%200x34%20%E8%B6%85%E6%97%B6%205000%20%5B91.286112%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.266833)%EF%BC%9ATXPWR_CFG%20%5B0x80d1%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20140%EF%BC%8Cseqno%200x34%5B%2091.286736%5D%20wlan0%20set%20multicast_list%5B%2091.286794%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%2091.286835%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%2091.286916%5D%20wlan0%3A%20DNLD_CMD%20(91.267643)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81act%200x1%E3%80%81len%20204%E3%80%81seqno%200x35%20%E8%B6%85%E6%97%B6%205000%20%5B91.287407%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.268128)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x35%5B%2091.287469%5D%20wlan0%3A%20DNLD_CMD%20(91.268199)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200x36%20%E8%B6%85%E6%97%B6%205000%20%5B91.287894%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.268617)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8C%E5%BA%8F%E5%88%97%200x36%20%5B91.297629%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B91.297755%5D%20wlan0%EF%BC%9ADNLD_CMD%20(91.278484)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200xc%EF%BC%8Clen%2016%EF%BC%8C%E5%BA%8F%E5%88%97%200x37%20%E8%B6%85%E6%97%B6%205000%20%5B91.298244%5D%20wlan0%EF%BC%9ACMD_RESP%20(91.278966)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8C%E9%A1%BA%E5%BA%8F%200x37%20%5B112.909482%5D%20wlan0%EF%BC%9AQUEE_CMD%EF%BC%9AMGMT_IE_LIST%20%5B0xf2%5D%20%E6%98%AF%E6%8E%92%E9%98%9F%20%5B112.909610%5D%20wlan0%EF%BC%9ADNLD_CMD%20(112.890335)%EF%BC%9AMGMT_IE_LIST%20%5B0xf2%5D%E3%80%81act%200x1%E3%80%81len%20127%E3%80%81seqno%200x38%20%E8%B6%85%E6%97%B6%205000%20%5B112.910138%5D%20wlan0%EF%BC%9ACMD_RESP%20(112.890857)%EF%BC%9AMGMT_IE_LIST%20%5B0x80f2%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20127%EF%BC%8Cseqno%200x38%5B%20112.910277%5D%20probereq%20ie%20length%20%3D%20107%5B%20112.910302%5D%20beacon%3Dffffff%20assocresp%3Dffffff%20proberesp%3Dffff%20probereq%3D0%5B%20112.910324%5D%20wlan%3Arandom_mac%2000%3AXX%3AXX%3AXX%3A00%3A00%5B%20112.910848%5D%20max_rate%3D390M%5B%20112.910869%5D%20max_rate%3D390M%5B%20112.910887%5D%20max_rate%3D390M%5B%20112.%E8%AE%BE%E7%BD%AE%EF%BC%9AHE%20rx%20mcs%20set%200x0000fffe%20tx%20mcs%20set%200x0000fffe%5B%20112.910946%5D%20max_rate%3D390M%5B%20112.910957%5D%20max_rate%3D390M%5B%20112.910972%EF%BC%BD%E8%AE%BE%E7%BD%AE%EF%BC%9AHE%20rx%20mcs%20set%200x0000fffe%20tx%20mcs%20set%200x0000fffe%5B%20112.911000%5D%20wlan0%3A%20QUEUE_CMD%3A%20802_11_SCAN_EXT%20%5B0x107%5D%20is%20queued%5B%20112.911052%5D%20wlan%3A%20wlan0%20START%20SCAN%5B%20112.911216%5D%20wlan0%3A%20DNLD_CMD%20(112.891939)%EF%BC%9A802_11_SCAN_EXT%20%5B0x107%5D%E3%80%81act%200x1%E3%80%81len%20266%E3%80%81seqno%200x39%20%E8%B6%85%E6%97%B6%2020000%20%5B112.921346%5D%20wlan0%EF%BC%9ACMD_RESP%20(112.902062)%EF%BC%9A802_11_SCAN_EXT%20%5B0x8107%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x39%5B%20132.979298%5DExt%20scan%20enh%20timeout%5B%20132.979336%5D%20------------Dump%20info-----------%5B%20132.979347%5DEXT_SCAN_STATUS%20%E4%BA%8B%E4%BB%B6%E8%B6%85%E6%97%B6%5B%20132.979360%5DCurCmd%20Empty%5B%20132.979372%5D%20mlan_processing%20%3D0%5B%20132.979382%5D%20main_lock_flag%20%3D0%5B%20132.979392%5D%20main_process_cnt%20%3D125%5B%20132.979401%5D%20delay_task_flag%20%3D0%5B%20132.979410%5D%20mlan_rx_processing%20%3D0%5B%20132.979419%5D%20rx_pkts_queued%3D0%5B%20132.979428%5D%20more_task_flag%20%3D%200%5B%20132.979437%5D%20num_cmd_timeout%20%3D%200%5B%20132.979446%5D%20last_cmd_index%20%3D%207%5B%20132.979455%5D%20last_cmd_id%20%3D%200xd1%200x10c%200xd1%200x10%200x28%200x20%200xf2%200x107%200x20%200xd1%5B%20132.979499%5D%20last_cmd_act%20%3D%200x0%200x1%200x0%200x1%200x213%200xc%200x1%200x1%200xc%200x0%5B%20132.979535%5D%20last_cmd_resp_index%20%3D%207%5B%20132.979544%5D%20last_cmd_resp_id%20%3D%200x80d1%200x810c%200x80d1%200x8010%200x8028%200x8020%200x80f2%200x8107%200x8020%200x80d1%5B%20132.979583%5D%20last_event_index%20%3D%201%5B%20132.979592%5D%20last_event%20%3D%200x81%200x81%200x81%200x81%200x81%200x81%200x81%200x81%5B%20132.979630%5D%20num_data_h2c_failure%20%3D%200%5B%20132.979642%5D%20num_cmd_h2c_failure%20%3D%200%5B%20132.979653%5D%20num_data_c2h_failure%20%3D%200%5B%20132.979663%5D%20num_cmdevt_c2h_failure%20%3D%200%5B%20132.979673%5D%20num_int_read_failure%20%3D%200%5B%20132.979683%5D%20last_int_status%20%3D%2064%5B%20132.979692%5D%20num_alloc_buffer_failure%20%3D%200%5B%20132.979701%5D%20num_pkt_dropped%20%3D%200%5B%20132.979710%5D%20num_noo_cmd_node%20%3D%200%5B%20132.979719%5D%20num_event_deauth%20%3D%200%5B%20132.979728%5D%20num_event_disassoc%20%3D%200%5B%20132.979737%5D%20num_event_link_lost%20%3D%200%5B%20132.979746%5D%20num_cmd_deauth%20%3D%200%5B%20132.979756%5D%20num_cmd_assoc_success%20%3D%200%5B%20132.979766%5D%20num_cmd_assoc_failure%20%3D%200%5B%20132.979776%5D%20num_cons_assoc_failure%20%3D%200%5B%20132.979785%5D%20cmd_resp_received%3D0%5B%20132.979794%5D%20event_received%3D0%5B%20132.979804%5D%20max_tx_buf_size%3D4096%5B%20132.979813%5D%20tx_buf_size%3D3328%5B%20132.979822%5D%20curr_tx_buf_size%3D3328%5B%20132.979832%5D%20data_sent%3D0%20cmd_sent%3D0%5B%20132.979843%5D%20ps_mode%3D0%20ps_state%3D0%5B%20132.979855%5D%20wakeup_dev_req%3D0%20wakeup_tries%3D0%20wakeup_timeout%3D0%5B%20132.979866%5D%20hs_configured%3D0%20hs_activated%3D0%5B%20132.979877%5D%20pps_uapsd_mode%3D0%20sleep_pd%3D0%5B%20132.979886%5D%20tx_lock_flag%20%3D%200%5B%20132.979896%5D%20scan_processing%20%3D%201%5B%20132.979906%5D%20scan_state%20%3D%200x5%5B%20132.979915%5D%20bypass_pkt_count%3D0%5B%20132.979927%5D%20mp_rd_bitmap%3D0x0%20curr_rd_port%3D0x0%5B%20132.979939%5D%20mp_wr_bitmap%3D0xffffff%20curr_wr_port%3D0x0%5B%20132.979949%5D%20mp_data_port_mask%20%3D%200xffffffff%5B%20132.979960%5D%20last_recv_rd_bitmap%3D0x0%20mp_invalid_update%3D0%5B%20132.979972%5D%20last_recv_wr_bitmap%3D0xffffff%20last_mp_index%3D0%5B%20132.979986%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%5B%20132.979995%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%5B%20132.980048%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%5B%20132.980058%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%5B%20132.980111%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%5B%20132.980120%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%5B%20132.980172%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%5B%20132.980182%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%5B%20132.980234%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%5B%20132.980244%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%5B%20132.980297%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%5B%20132.980306%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%5B%20132.980359%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%5B%20132.980368%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%5B%20132.980420%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%5B%20132.980430%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%5B%20132.980482%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%5B%20132.980491%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%5B%20132.980542%5D%20mp_wr_bitmap%EF%BC%9A0x0%20mp_wr_ports%3D0x0%20len%3D0%20curr_wr_port%3D0x0%5B%20132.980552%5D%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%200x00%5B%20132.980604%5D%20bss_index%20%3D%200%2C%20tx_pkts_queued%20%3D%200%20tx_pause%5B%20132.980619%5D%20bss_index%20%3D%201%2C%20tx_pkts_queued%20%3D%200%20tx_pause%5B%20132.980631%5D%20bss_index%20%3D%202%2C%20tx_pkts_queued%20%3D%200%20tx_pause%5B%20132.980647%5D%20bss_index%20%3D%203%2C%20tx_pkts_queued%20%3D%200%20tx_pause%5B%20132.980663%5D%20%E4%BA%8B%E4%BB%B6%20ID%3A0x80000012%5B%20132.980702%EF%BC%BD%E4%B8%BB%E6%9C%BA%EF%BC%9Abr03%20%E6%97%B6%E9%97%B4%E6%88%B3%EF%BC%9Ac0623ac4%5B%20132.980730%5D%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%20%3D%20SDIW612---18.99.3.p26.11-MM6X18540.p17-(FP92)%5B132.980743%5D%20main_state%20%3D%204%5B%20132.980753%5D%20ioctl_pending%20%3D%201%5B%20132.980762%5D%20tx_pending%20%3D%200%5B%20132.980772%5D%20wmm_tx_pending%5B0%5D%20%3D%200%5B%20132.980781%5D%20wmm_tx_pending%5B1%5D%20%3D%200%5B%20132.980790%5D%20wmm_tx_pending%5B2%5D%20%3D%200%5B%20132.980800%5D%20wmm_tx_pending%5B3%5D%20%3D%200%5B%20132.980810%5D%20rx_pending%20%3D%200%5B%20132.980819%5D%20lock_count%20%3D%20111%5B%20132.980828%5D%20malloc_count%20%3D%2052%5B%20132.980837%5D%20mbufalloc_count%20%3D%200%5B%20132.980846%5D%20hs_skip_count%20%3D%200%5B%20132.980856%5D%20hs_force_count%20%3D%200%5B%20132.980868%EF%BC%BD%E5%AA%92%E4%BD%93%E7%8A%B6%E6%80%81%20%3D%22%E6%96%AD%E5%BC%80%E8%BF%9E%E6%8E%A5%22%5B%20132.980881%5D%20%E8%BD%BD%E6%B3%A2%E5%85%B3%E9%97%AD%5B%20132.980894%5D%20tx%20%E9%98%9F%E5%88%97%200%3A%20%E5%B7%B2%E5%81%9C%E6%AD%A2%5B%20132.980907%5D%20tx%20%E9%98%9F%E5%88%97%201%3A%20%E5%B7%B2%E5%81%9C%E6%AD%A2%5B%20132.980920%5D%20tx%20%E9%98%9F%E5%88%97%202%3A%20%E5%B7%B2%E5%81%9C%E6%AD%A2%5B%20132.980933%5D%20tx%20%E9%98%9F%E5%88%97%203%3A%20%E5%B7%B2%E5%81%9C%E6%AD%A2%5B%20132.980946%5D%20wlan0%3A%20num_tx_timeout%20%3D%200%5B%20132.980960%5D%20uap0%3A%20num_tx_timeout%20%3D%200%5B%20132.980973%5D%20p2p0%3A%20num_tx_timeout%20%3D%200%5B%20132.981005%5D%20--------%20Dump%20info%20End---------%5B%20132.981063%5D%E5%94%A4%E9%86%92%E8%AE%BE%E5%A4%87...%20%5B132.981682%5DSDIO%20Func0%20(0x0-0x9)%EF%BC%9A43%2003%2002%2002%2003%2002%2008%2002%2003%2000%5B%20132.982016%5DSDIO%20Func1%20(0x10-0x17)%EF%BC%9A00%2000%2000%20ff%20ff%20ff%20ff%5B%20132.982575%5DSDIO%20Func1%EF%BC%9A%20(0x8)%20c3%20(0x58)%2000%20(0x5c)%2048%20(0x5d)%2000%20(0x60)%2087%20(0x61)%200c%20(0x62)%2000%20(0x64)%2010%20(0x65)%2000%20(0x66)%2000%20(0x68)%2000%20(0x69)%2000%20(0x6a)%2000%5B%20132.983518%5DSDIO%20Func1%20(0xe8-0xff)%3A%20DC%20fe%2060%2000%2061%2000%2000%2024%2014%2070%20c8%20ab%2077%2080%2000%2000%2000%2001%2000%2000%2000%5B%20133.087775%5DSDIO%20Func1%20(0xe8-0xff)%3A%20DC%20FE%20C4%2000%206C%2000%2000%2024%2014%2070%20C8%20AB%2077%2080%2000%2000%2000%2001%2000%2000%2000%5B%20133.087808%5D%E5%8F%96%E6%B6%88%E6%89%80%E6%9C%89%E5%BE%85%E5%A4%84%E7%90%86%E7%9A%84%20cmd%20%E5%92%8C%20txrx%20%E9%98%9F%E5%88%97%5B%20133.087844%5DIOCTL%20%E5%A4%B1%E8%B4%A5%EF%BC%9Ac5cf7800%20id%3D0x10000%2C%20sub_id%3D0x10003%20action%3D1%2C%20status_code%3D0x80000007%20%5BCMD_CANCEL%5D%5B%20133.087864%5D%20%E5%88%B7%E6%96%B0%E6%89%AB%E6%8F%8F%E9%98%9F%E5%88%97%EF%BC%9Acmd%200x107%5B%20133.087914%5D%E5%94%A4%E9%86%92%E8%AE%BE%E5%A4%87...%20%5B133.088389%5D%20wlan0%EF%BC%9A133.069104%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AEXT_SCAN_REPORT%20%5B0x58%5D%20%5B133.088460%5D%E4%BA%8B%E4%BB%B6%EF%BC%9AEXT_SCAN%20%E6%8A%A5%E5%91%8A%20(2416)%5B%20133.088757%5D%20wlan0%3A%20133.069476%20%3A%20%E4%BA%8B%E4%BB%B6%EF%BC%9AEXT_SCAN_REPORT%20%5B0x58%5D%5B%20133.088814%EF%BC%BDEVENT%3A%20EXT_SCAN%20Report%20(463)%5B%20133.089067%5D%20wlan0%3A%20133.069787%20%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9A%20EXT_SCAN_STATUS_REPORT%20%5B0x7fEXT_SCAN_STATUS_REPORT%20%5B0x7f%5D%5B%20133.089121%EF%BC%BDEVENT%3A%20EXT_SCAN%20status%20report%20(151)%5B%20133.089143%5D%20ext_scan_status%3A%20status%200%20(%E6%89%AB%E6%8F%8F%E6%88%90%E5%8A%9F)%2C%20buf_len%20144%5B%20133.089163%5D%20chan%3D1%2C%20noise%3D-89%2C%20total_network%3D1%20scan_duration%3D78%2C%20busy_duration%3D37%5B%20133.089181%5D%20chan%3D2%EF%BC%8Cnoise%3D-90%EF%BC%8Ctotal_network%3D0%20%E6%89%AB%E6%8F%8F%E6%8C%81%E7%BB%AD%E6%97%B6%E9%97%B4%3D78%EF%BC%8C%20busy_duration%3D32%5B%20133.089198%5D%20chan%3D3%EF%BC%8Cnoise%3D-90%EF%BC%8Ctotal_network%3D1%20%E6%89%AB%E6%8F%8F%E6%8C%81%E7%BB%AD%E6%97%B6%E9%97%B4%3D78%EF%BC%8C%20busy_duration%3D23%5B%20133.089213%5D%20chan%3D4%2C%20noise%3D-81%2C%20total_network%3D0%20scan_duration%3D78%2C%20busy_duration%3D12%5B%20133.089229%5D%20chan%3D5%2C%20noise%3D-84%2C%20total_network%3D1%20scan_duration%3D78%2C%20busy_duration%3D30%5B%20133.089246%5D%20chan%3D6%EF%BC%8Cnoise%3D-84%EF%BC%8Ctotal_network%3D2%20%E6%89%AB%E6%8F%8F%E6%8C%81%E7%BB%AD%E6%97%B6%E9%97%B4%3D78%EF%BC%8Cbusy_duration%3D52%5B%20133.089261%5D%20chan%3D7%EF%BC%8Cnoise%3D-87%EF%BC%8Ctotal_network%3D0%20%E6%89%AB%E6%8F%8F%E6%8C%81%E7%BB%AD%E6%97%B6%E9%97%B4%3D78%EF%BC%8Cbusy_duration%3D17%5B%20133.089358%5D%20chan%3D8%EF%BC%8Cnoise%3D-87%EF%BC%8Ctotal_network%3D0%20%E6%89%AB%E6%8F%8F%E6%8C%81%E7%BB%AD%E6%97%B6%E9%97%B4%3D78%EF%BC%8Cbusy_duration%3D17%5B%20133.089358089358%5D%20chan%3D8%2C%20noise%3D-87%2C%20total_network%3D0%20scan_duration%3D78%2C%20busy_duration%3D12%5B%20133.089375%5D%20chan%3D9%2C%20noise%3D-89%2C%20total_network%3D1%20scan_duration%3D78%2C%20busy_duration%3D27%5B%20133.089392%5D%20chan%3D10%2C%20noise%3D-89%2C%20total_network%3D0%20scan_duration%3D78%2C%20busy_duration%3D27%5B%20133.089409%5D%20chan%3D11%2C%20noise%3D-89%2C%20total_network%3D1%20scan_duration%3D78%2C%20busy_duration%3D41%5B%20133.089425%5D%20chan%3D12%2C%20noise%3D-87%2C%20total_network%3D1%20scan_duration%3D78%2C%20busy_duration%3D32%5B%20133.089440%5D%20chan%3D13%EF%BC%8Cnoise%3D-88%EF%BC%8Ctotal_network%3D1%20%E6%89%AB%E6%8F%8F%E6%8C%81%E7%BB%AD%E6%97%B6%E9%97%B4%3D78%EF%BC%8C%20busy_duration%3D32%5B%20133.089456%5D%20chan%3D14%EF%BC%8Cnoise%3D-91%EF%BC%8Ctotal_network%3D0%20%E6%89%AB%E6%8F%8F%E6%8C%81%E7%BB%AD%E6%97%B6%E9%97%B4%3D78%EF%BC%8C%20busy_duration%3D8%5B%20133.089456089479%5D%20chan%3D1%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-89%20min_rss%3D89%2C%20max_rss%3D89%5B%20133.089496%5D%20chan%3D2%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-90%20min_rss%3D90%2C%20max_rss%3D90%5B%20133.089511%5D%20chan%3D3%E3%80%81%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-90%20min_rss%3D90%2C%20max_rss%3D90%5B%20133.089526%5D%20chan%3D4%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-81%20min_rss%3D81%2C%20max_rss%3D81%5B%20133.089542%5D%20chan%3D5%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-84%20min_rss%3D84%2C%20max_rss%3D84%5B%20133.089558%5D%20chan%3D6%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-84%20min_rss%3D84%2C%20max_rss%3D84%5B%20133.089574%5D%20chan%3D7%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-87%20min_rss%3D87%2C%20max_rss%3D87%5B%20133.089589%5D%20chan%3D8%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-87%20min_rss%3D87%2C%20max_rss%3D87%5B%20133.089605%5D%20chan%3D9%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-89%20min_rss%3D89%2C%20max_rss%3D89%5B%20133.089620%5D%20chan%3D10%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-89%20min_rss%3D89%2C%20max_rss%3D89%5B%20133.089636%5D%20chan%3D11%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-89%20min_rss%3D89%2C%20max_rss%3D89%5B%20133.089652%5D%20chan%3D12%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-87%20min_rss%3D87%2C%20max_rss%3D87%5B%20133.089668%5D%20chan%3D13%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-88%20min_rss%3D88%2C%20max_rss%3D88%5B%20133.089683%5D%20chan%3D14%2C%20min_rssi%3D0%2C%20max_rssi%3D0%20noise%3D-91%20min_rss%3D91%2C%20max_rss%3D91%5B%20133.089702%5D%20wlan%EF%BC%9ASCAN%20COMPLETED%3A%20scanned%20AP%20count%3D0%5B%20133.089721%5D%20event%20id%3A0x80000009%5B%20133.089748%5D%E8%AE%BE%E5%A4%87%E4%B8%8D%E5%AD%98%E5%9C%A8%E6%88%96%E6%8C%82%E8%B5%B7%E6%97%B6%E4%B8%8D%E5%85%81%E8%AE%B8%20IOCTL%20%5B133.089767%5D%E8%AE%BE%E5%A4%87%E4%B8%8D%E5%AD%98%E5%9C%A8%E6%88%96%E6%8C%82%E8%B5%B7%E6%97%B6%E4%B8%8D%E5%85%81%E8%AE%B8%20IOCTL%20%5B133.093278%5D%E8%AE%BE%E5%A4%87%E4%B8%8D%E5%AD%98%E5%9C%A8%E6%88%96%E6%8C%82%E8%B5%B7%E6%97%B6%E4%B8%8D%E5%85%81%E8%AE%B8%20IOCTL%20%5B133.099459%5D%20%3D%3D%3D%3D%3DSDIO%20%E5%9B%BA%E4%BB%B6%E8%BD%AC%E5%82%A8%E4%BA%8B%E4%BB%B6%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%20%3D%3D%3D%3D%20%5B133.099802%5D%E5%9B%BA%E4%BB%B6%E8%A7%A6%E5%8F%91%20fw%20dump%20%5B133.099845%5D%20%3D%3D%3D%3D%20%E5%BC%80%E5%A7%8B%E6%8E%A5%E6%94%B6%E5%9B%BA%E4%BB%B6%E8%BD%AC%E5%82%A8%E4%BA%8B%E4%BB%B6%20%3D%3D%3D%3D%20%5B133.099942%5D%E5%88%9B%E5%BB%BA%E7%9B%AE%E5%BD%95%20%2Fdata%2Fdump_133%20%E9%94%99%E8%AF%AF%EF%BC%8C%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%9C%A8%20%2Fvar%20%E4%B8%AD%E5%88%9B%E5%BB%BA%E7%9B%AE%E5%BD%95%5B%20133.100015%EF%BC%BD%E6%88%90%E5%8A%9F%E5%88%9B%E5%BB%BA%E7%9B%AE%E5%BD%95%20%2Fvar%2Fdump_133%5B%20133.100036%5D%E5%9B%BA%E4%BB%B6%E8%BD%AC%E5%82%A8%E7%9B%AE%E5%BD%95%E5%90%8D%E7%A7%B0%E4%B8%BA%20%2Fvar%2Fdump_133%5B%20133.100048%5D%20%3D%3D%3D%20%E5%90%AF%E5%8A%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BF%A1%E6%81%AF%E8%BD%AC%E5%82%A8%3D%3D%3D%5B%20133.100161%EF%BC%BDDRV%20%E8%BD%AC%E5%82%A8%E6%95%B0%E6%8D%AE%E5%9C%A8%20%2Fvar%2Fdump_133%2Ffile_drv_info%5B%20133.100594%5D%20%E4%B8%AD%E3%80%82%E5%94%A4%E9%86%92%E8%AE%BE%E5%A4%87...%20%5B133.231641%5Ddrv%20%E4%BF%A1%E6%81%AF%E6%80%BB%E5%AD%97%E8%8A%82%E6%95%B0%20%3D%20421143%20(0x66d17)%20%5B133.231676%5D%20%3D%3D%3D%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BF%A1%E6%81%AF%E8%BD%AC%E5%82%A8%E7%BB%93%E6%9D%9F%3D%3D%3D%20%5B134.887580%5D%20%3D%3D%3D%3D%20%E5%9B%BA%E4%BB%B6%E8%BD%AC%E5%82%A8%E7%BB%93%E6%9D%9F%EF%BC%9A1408768%20%E5%AD%97%E8%8A%82%20%3D%3D%3D%3D%20%5B134.887652%5D%20wlan%EF%BC%9A%E9%80%9A%E7%9F%A5%E5%9B%BA%E4%BB%B6%E8%BD%AC%E5%82%A8%E5%AE%8C%E6%88%90%E4%BA%8B%E4%BB%B6%20%5B134.887668%5D%20%E4%BE%9B%E5%BA%94%E5%95%86%E4%BA%8B%E4%BB%B6%EF%BC%9A0x1%20%5B134.887750%5D%E5%BC%80%E5%A7%8B%E5%A4%84%E7%90%86%E6%8C%82%E8%B5%B7%5B%20134.888400%EF%BC%BD%E8%AE%BE%E5%A4%87%E4%B8%8D%E5%AD%98%E5%9C%A8%E6%88%96%E6%8C%82%E8%B5%B7%E6%97%B6%E4%B8%8D%E5%85%81%E8%AE%B8%20IOCTL%20%5B134.888744%5D%E5%8F%96%E6%B6%88%E6%89%80%E6%9C%89%E5%BE%85%E5%A4%84%E7%90%86%E7%9A%84%20cmd%20%E5%92%8C%20txrx%20%E9%98%9F%E5%88%97%5B%20134.888883%5D%20%E4%BE%9B%E5%BA%94%E5%95%86%E4%BA%8B%E4%BB%B6%20%3A0x4%5B%20134.888939%5DWIFI%20auto_fw_reload%EF%BC%9Afw_reload%3D1%20%5B134.888995%5D%20%3D%3D%3D%3D%3D%3D%3D%E5%BC%80%E5%A7%8B%E5%B8%A6%E5%86%85RESET%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%5B134.889037%5D%20%E4%BE%9B%E5%BA%94%E5%95%86%E6%B4%BB%E5%8A%A8%EF%BC%9A0x2%20%5B134.889227%5D%E8%AE%BE%E5%A4%87%E4%B8%8D%E5%AD%98%E5%9C%A8%E6%88%96%E6%8C%82%E8%B5%B7%E6%97%B6%E4%B8%8D%E5%85%81%E8%AE%B8%20IOCTL%20%5B134.889259%5D%20woal_reset_intf%EF%BC%9A%E8%8E%B7%E5%8F%96%20bss%20%E4%BF%A1%E6%81%AF%E5%A4%B1%E8%B4%A5%20%5B134.889375%5D%E5%8F%96%E6%B6%88%E6%89%80%E6%9C%89%E5%BE%85%E5%A4%84%E7%90%86%E7%9A%84%20cmd%20%E5%92%8C%20txrx%20%E9%98%9F%E5%88%97%5B%20134.889499%5D%E8%AE%BE%E5%A4%87%E4%B8%8D%E5%AD%98%E5%9C%A8%E6%88%96%E6%8C%82%E8%B5%B7%E6%97%B6%E4%B8%8D%E5%85%81%E8%AE%B8%20IOCTL%20%5B134.889793%5D%E8%AE%BE%E5%A4%87%E4%B8%8D%E5%AD%98%E5%9C%A8%E6%88%96%E6%8C%82%E8%B5%B7%E6%97%B6%E4%B8%8D%E5%85%81%E8%AE%B8%20IOCTL%20%5B135.068048%5DFW%20%E5%94%A4%E9%86%92%5B%20135.082732%EF%BC%BDSDIO%20Trigger%20%E5%9B%BA%E4%BB%B6%E5%B8%A6%E5%86%85RESET%E6%88%90%E5%8A%9F%20%5B135.082764%5D%E9%87%8A%E6%94%BE%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%5B%20135.082815%5D%E6%9C%AA%E6%8C%87%E5%AE%9A%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%20cfg%20%E6%96%87%E4%BB%B6%5B%20135.082867%5DSDIO%3A%20sdio_blk_size%3D256%20max_blk_count%3D512%20max_segs%3D64%20max_seg_size%3D4096%5B%20135.082883%5D%20rx_work%3D0%20cpu_num%3D1%5B%20135.082903%5D%E5%90%AF%E7%94%A8%20moal_recv_amsdu_packet%5B%20135.082990%5D%E9%99%84%E5%8A%A0%20mlan%20%E9%80%82%E9%85%8D%E5%99%A8%E6%93%8D%E4%BD%9C%E3%80%82card_type%20%E4%B8%BA%200x109%E3%80%82135.091840%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20TX%20SG%20%E6%A8%A1%E5%BC%8F%5B%20135.091876%5D%20wlan%3A%20mpa_tx.buf_size%3D4096%5B135.091888%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20RX%20SG%20%E6%A8%A1%E5%BC%8F%5B%20135.091899%5D%20wlan%3A%20mpa_rx.buf_size%3D4096%5B135.091945%5D%E8%AF%B7%E6%B1%82%E5%9B%BA%E4%BB%B6%EF%BC%9A%20nxp%2Fsd_w61x_v1.bin.se%5B135.097580%5D%E5%94%A4%E9%86%92%E8%AE%BE%E5%A4%87...%20%5B135.361419%5DWlan%EF%BC%9AFW%20%E4%B8%8B%E8%BD%BD%E7%BB%93%E6%9D%9F%EF%BC%8Cfirmwarelen%3D681308%20%E5%B7%B2%E4%B8%8B%E8%BD%BD%20565508%5B%20135.779436%5DWLAN%20FW%20%E5%A4%84%E4%BA%8E%E6%B4%BB%E5%8A%A8%E7%8A%B6%E6%80%81%5B%20135.779479%5D%20on_time%20is%20135760213003%5B%20135.779928%5DQUEUE_CMD%EF%BC%9AFUNC_INIT%20%5B0xa9%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%20135.779961%5DQUEUE_CMD%EF%BC%9AGET_HW_SPEC%20%5B0x3%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%20135.780007%5Ddnld_cmd%20(135.760717)%EF%BC%9AFUNC_INIT%20%5B0xa9%5D%E3%80%81act%200x263%E3%80%81len%2016%E3%80%81seqno%200x1%20%E8%B6%85%E6%97%B6%205000%20%5B135.802877%5Dcmd_resp%20(135.783563)%EF%BC%9AFUNC_INIT%20%5B0x80a9%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1%5B%20135.802941%5Ddnld_cmd%20(135.783651)%EF%BC%9AGET_HW_SPEC%20%5B0x3%5D%E3%80%81act%200x0%E3%80%81len%2071%E3%80%81seqno%200x2%20%E8%B6%85%E6%97%B6%205000%20%5B135.803276%5D%20135.783976%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B135.803320%5DVDLL_IND%20(OFFSET)%3A%20offset%3D0x1c458%5B%20135.804257%5DVDLL%20%E6%98%A0%E5%83%8F%EF%BC%9Alen%3D115800%5B%20135.804558%5Dcmd_resp%20(135.785256)%EF%BC%9AGET_HW_SPEC%20%5B0x8003%5D%EF%BC%8C%20result%200%EF%BC%8C%20len%20205%EF%BC%8C%20seqno%200x2%5B%20135.804586%5D%20fw_cap_info%3D0x487cff03%2C%20dev_cap_mask%3D0xffffffff%5B%20135.804603%5DGET_HW_SPEC%3A%20country_code%3D0x0%5B%20135.804615%5D%20num_ant%3D1%2C%20antinfo%3D0x0%5B%20135.804631%5DGET_HW_SPEC%3A%20hw_mpdu_density%3D4%20dev_mcs_support%3D0x11%5B%20135.804641%5D%E5%90%AF%E7%94%A8%E6%B3%A2%E6%9D%9F%E8%B5%8B%E5%BD%A2%20%5B135.804656%5DGET_HW_SPEC%3A%20mgmt%20IE%20count%3D13%5B%20135.804672%5DFW%3A%20SDIO%20rx%20aggr%20disabled%200x487cff03%5B%20135.804687%5D%20pmadapter-%26gt%3Becsa_enable%3D1%5B%20135.804722%5DQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%5B%20135.804735%5D%20pmadapter-%26gt%3Bgetlog_enable%3D1%5B%20135.804758%5D%20chanrpt%20api%20ver%3D14.1%5B135.804772%5D%20fw_cap_info%3D0x487cff03%20fw_cap_ext%3D0x2182b5%5B%20135.804786%5D%20uuid%3A%20c10d697cf87d596cab35c831392df315%5B%20135.804798%5D%20fw%20hotfix%20ver%3D11%5B%20135.804810%5D%20fw%20ver%3D15.1%5B%20135.804810%5D%20fw%20ver%3D15.1%5B%20135.804810%5D%20c10d697cf87d596cab35c831392df315135.804820%5D%20uap%20fw%20ver%3D2.0%5B135.804832%5D%20max_p2p_conn%20%3D%208%2C%20max_sta_conn%20%3D%2016%5B%20135.804849%5D%20wlan_set_regiontable%3A%202.4G%200x10%5B%20135.804868%5D%20wlan_set_regiontable%EF%BC%9A2.4G%200x10%5B%20135.804868%5D%20wlan_set_regiontable%3A%205G%200x10%5B%20135.804904%E8%8E%B7%E5%8F%96%20Hw%20Spec%20%E5%AE%8C%E6%88%90%EF%BC%8Cfw_cap%3D0x487cff03%5B%20135.804931%5D%20org_drv_mode%3D0x7%20drv_mode%3D0x7%5B%20135.805473%5D%E5%90%AF%E7%94%A8%E6%B3%A2%E6%9D%9F%E8%B5%8B%E5%BD%A2%20%5B135.805531%5DQUEUE_CMD%3A%20802_11_FW_WAKE_METHOD%20%5B0x74%5D%20is%20queued%5B%20135.805558%5D%20set%20tx_buf%20%3D%204096%5B%20135.805578%5DQUEUE_CMD%3A%20RECONFIGURE_TX_BUFF%20%5B0xd9%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20135.805603%5DPS%20%E5%91%BD%E4%BB%A4%EF%BC%9A%E6%93%8D%E4%BD%9C%20%3D%200x6%EF%BC%8C%E4%BD%8D%E5%9B%BE%20%3D%200x1%5B%20135.805623%5DQUEUE_CMD%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20135.805653%5DQUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20135.805684%5DQUEUE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20135.805715%5DQUEUE_CMD%EF%BC%9ACHAN_REGION_CFG%20%5B0x242%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20135.805747%5DQUEUE_CMD%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%E5%B7%B2%E6%8E%92%E9%98%9F%5B%20135.805775%EF%BC%BDQUEUE_CMD%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20135.805803%5DQUEUE_CMD%EF%BC%9AAMSDU_AGR_CTRL%20%5B0xdf%5D%E5%B7%B2%E6%8E%92%E9%98%9F%5B%20135.805831%5D%E3%80%82QUEUE_CMD%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E5%B7%B2%E6%8E%92%E9%98%9F%5B%20135.805873%EF%BC%BDdnld_cmd%20(135.786585)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81act%200x1%E3%80%81len%2015%E3%80%81seqno%200x3%20%E8%B6%85%E6%97%B6%205000%20%5B135.806273%5Dcmd_resp%20(135.786970)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2015%EF%BC%8Cseqno%200x3%5B%20135.806326%5Ddnld_cmd%20(135.787037)%EF%BC%9A802_11_FW_WAKE_METHOD%20%5B0x74%5D%E3%80%81act%200x0%E3%80%81len%2012%E3%80%81seqno%200x4%20%E8%B6%85%E6%97%B6%205000%20%5B135.806657%5Dcmd_resp%20(135.787354)%EF%BC%9A802_11_FW_WAKE_METHOD%20%5B0x8074%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2018%EF%BC%8Cseqno%200x4%5B%20135.806681%5DFW%20%E5%94%A4%E9%86%92%E6%96%B9%E6%B3%95%3D1%EF%BC%8Cgpio%3D0%5B%20135.806720%EF%BC%BDdnld_cmd%20(135.787431)%EF%BC%9ARECONFIGURE_TX_BUFF%20%5B0xd9%5D%E3%80%81act%200x1%E3%80%81len%2016%E3%80%81seqno%200x5%20%E8%B6%85%E6%97%B6%205000%20%5B135.807784%5Dcmd_resp%EF%BC%88135.788482%EF%BC%89%EF%BC%9ARECONFIGURE_TX_BUFF%20%5B0x80d9%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x5%5B%20135.807813%5D%20end%20port%2032%EF%BC%8Cdata%20port%20mask%20ffffffff%5B%20135.807828%5D%20max_tx_buf_size%3D4096%EF%BC%8Ctx_buf_size%3D3328%5B%20135.807867%EF%BC%BDdnld_cmd%20(135.788578)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%E3%80%81act%200x6%E3%80%81len%2020%E3%80%81seqno%200x6%20%E8%B6%85%E6%97%B6%205000%20%5B135.808197%5Dcmd_resp%20(135.788896)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2020%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x6%5B135.808246%5D%E3%80%82dnld_cmd%20(135.788958)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81act%200x1%E3%80%81len%2018%E3%80%81seqno%200x7%20%E8%B6%85%E6%97%B6%205000%20%5B135.808578%5Dcmd_resp%20(135.789278)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2018%EF%BC%8Cseqno%200x7%5B%20135.808627%5Ddnld_cmd%20(135.789339)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%E3%80%81act%200xc%E3%80%81len%2016%E3%80%81seqno%200x8%20%E8%B6%85%E6%97%B6%205000%20%5B135.808952%5Dcmd_resp%20(135.789651)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x8%5B%20135.809004%5Ddnld_cmd%20(135.789713)%EF%BC%9ACHAN_REGION_CFG%20%5B0x242%5D%E3%80%81act%200x0%E3%80%81len%2011%E3%80%81seqno%200x9%20%E8%B6%85%E6%97%B6%205000%20%5B135.810351%5Dcmd_resp%EF%BC%88135.791038%EF%BC%89%EF%BC%9ACHAN_REGION_CFG%20%5B0x8242%5D%EF%BC%8Cresult%200%EF%BC%8Clen%201297%EF%BC%8Cseqno%200x9%5B%20135.810455%5Ddnld_cmd%20(135.791160)%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2076%EF%BC%8Cseqno%200xa%20%E8%B6%85%E6%97%B6%205000%20%5B135.811124%5Dcmd_resp%20(135.791819)%EF%BC%9ATX_RATE_CFG%20%5B0x80d6%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20832%EF%BC%8Cseqno%200xa%5B%20135.811184%5Ddnld_cmd%20(135.791892)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%E3%80%81act%200x0%E3%80%81len%2014%E3%80%81seqno%200xb%20%E8%B6%85%E6%97%B6%205000%20%5B135.811540%5Dcmd_resp%20(135.792237)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x801e%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200xb%5B%20135.811591%5Ddnld_cmd%20(135.792300)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0xdf%5D%E3%80%81act%200x1%E3%80%81len%2014%E3%80%81seqno%200xc%20%E8%B6%85%E6%97%B6%205000%20%5B135.811920%5Dcmd_resp%20(135.792619)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0x80df%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200xc%5B135.811966%5D%E3%80%82dnld_cmd%20(135.792678)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81act%200x213%E3%80%81len%2012%E3%80%81seqno%200xd%20%E8%B6%85%E6%97%B6%205000%20%5B135.812382%5Dcmd_resp%20(135.793082)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200xd%5B%20135.812434%5DQUEUE_CMD%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20135.812472%5Ddnld_cmd%20(135.793183)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%E3%80%81act%200x0%E3%80%81len%2020%E3%80%81seqno%200x100e%20%E8%B6%85%E6%97%B6%205000%20%5B135.813545%5Dcmd_resp%20(135.794232)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0x80b0%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x100e%5B%20135.813606%5DQUEUE_CMD%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%E5%B7%B2%E6%8E%92%E9%98%9F%5B%20135.813637%EF%BC%BDQUEUE_CMD%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20135.813666%5DQUEUE_CMD%EF%BC%9AAMSDU_AGR_CTRL%20%5B0xdf%5D%20%E5%B7%B2%E6%8E%92%E5%85%A5%E9%98%9F%E5%88%97%5B%20135.813693%5DQUEUE_CMD%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%E7%AD%89%E5%BE%85%5B%20135.813720%5DQUEUE_CMD%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20135.813757%5Ddnld_cmd%20(135.794468)%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2076%EF%BC%8Cseqno%200x200f%20%E8%B6%85%E6%97%B6%205000%20%5B135.818050%5Dcmd_resp%20(135.798739)%EF%BC%9ATX_RATE_CFG%20%5B0x80d6%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20832%EF%BC%8Cseqno%200x200f%5B%20135.818115%5Ddnld_cmd%20(135.798822)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%E3%80%81act%200x0%E3%80%81len%2014%E3%80%81seqno%200x2010%20%E8%B6%85%E6%97%B6%205000%20%5B135.818477%5Dcmd_resp%20(135.799175)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x801e%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2010%5B%20135.818528%5Ddnld_cmd%20(135.799237)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0xdf%5D%E3%80%81act%200x1%E3%80%81len%2014%E3%80%81seqno%200x2011%20%E8%B6%85%E6%97%B6%205000%20%5B135.818860%5Dcmd_resp%20(135.799557)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0x80df%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2011%5B%20135.818909%5Ddnld_cmd%20(135.799620)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200x2012%20%E8%B6%85%E6%97%B6%205000%20%5B135.819230%5Dcmd_resp%20(135.799930)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2012%5B%20135.819353%5Ddnld_cmd%20(135.800057)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2013%20%E8%B6%85%E6%97%B6%205000%20%5B135.819695%5Dcmd_resp%EF%BC%88135.800394%EF%BC%89%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2013%5B%20135.819753%5DQUEUE_CMD%3A%20WMM_PARAM_CONFIG%20%5B0x23a%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20135.819806%5Ddnld_cmd%20(135.800516)%EF%BC%9AWMM_PARAM_CONFIG%20%5B0x23a%5D%E3%80%81act%200x2%E3%80%81len%2026%E3%80%81seqno%200x14%20%E8%B6%85%E6%97%B6%205000%20%5B135.820154%5Dcmd_resp%EF%BC%88135.800851%EF%BC%89%EF%BC%9AWMM_PARAM_CONFIG%20%5B0x823a%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2026%EF%BC%8Cseqno%200x14%5B%20135.820247%5D%20woal_proc_init%EF%BC%9Aproc_wlan%20%E5%B7%B2%E7%BB%8F%E5%AD%98%E5%9C%A8%20adapter0%5B%20135.820490%5D%E8%AE%BE%E7%BD%AE%20wiphy%20max_ap_assoc_sta%3D8%5B%20135.820580%5D%20max_rate%3D390M%5B%20135.820595%5D%20max_rate%3D390M%5B%20135.820613%5D%20vht_cap%3D0x33d07030%20rx_mcs_map%3D0xfffe%20rx_max%3D0x186%20tx_mcs_map%3D0xfffe%20tx_max%3D0x186%5B%20135.820633%5D%20max_rate%3D390M%5B%20135.820644%5D%20max_rate%3D390M%5B%20135.820660%5D%20vht_cap%3D0x33d07030%20rx_mcs_map%3D0xfffe%20rx_max%3D0x186%20tx_mcs_map%3D0xfffe%20tx_max%3D0x186%5B%20135.820694%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_RF_ANTENNA%20%5B0x20%5D%20is%20queued%5B%20135.820792%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.801516)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x15%20%E8%B6%85%E6%97%B6%205000%20%5B135.821252%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.801969)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x15%5B%20135.821410%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%5B%20135.821486%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.802211)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x16%20%E8%B6%85%E6%97%B6%205000%20%5B135.821909%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.802626)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x16%5B%20135.822058%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%5B%20135.822131%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.802857)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x17%20%E8%B6%85%E6%97%B6%205000%20%5B135.822556%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.803274)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x17%5B%20135.823588%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%5B%20135.823686%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.804409)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x18%20%E8%B6%85%E6%97%B6%205000%20%5B135.824156%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.804874)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x18%20%5B135.824697%5D%20cfg80211%20%E7%9B%91%E7%AE%A1%E5%8A%9F%E8%83%BD%E5%9F%9F%E5%9B%9E%E8%B0%83%2000%20%E5%90%AF%E5%8A%A8%E5%99%A8%3D0%20dfs_region%3D0%20%5B135.824756%5D%E7%9B%91%E7%AE%A1%E5%8A%9F%E8%83%BD%E5%9F%9F%20BY_CORE%20%5B135.824824%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B135.825063%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.805783)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8Cact%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x19%20%E8%B6%85%E6%97%B6%205000%20%5B135.825563%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.806278)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x19%5B%20135.830566%5DPS%20%E5%91%BD%E4%BB%A4%EF%BC%9A%E6%93%8D%E4%BD%9C%20%3D%200x0%EF%BC%8C%E4%BD%8D%E5%9B%BE%20%3D%200x0%5B%20135.830603%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_PS_MODE_ENH%20%5B0xe4%5D%20is%20queued%5B%20135.830705%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.811429)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x1a%20%E8%B6%85%E6%97%B6%205000%20%5B135.831207%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.811924)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2068%EF%BC%8Cseqno%200x1a%5B%20135.831257%5D%20ps_bitmap%3D0x0%5B%20135.832483%5DCFG80211%3A%20Country%3D00%2C%20band%3D0%2C%20no_of_sub_band%3D1%5B%20135.832537%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%5B%20135.832595%5D%2011D%3ACountry%3DWW%20band%3D0%20sub-band%3D1%20dfs_region%3D0%5B%20135.832612%5D%2011D%3A%20first%20chan%3D1%20no_of_chan%3D14%2C%20max_tx_pwr%3D20%5B%20135.832627%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%5B%20135.832654%5D%20wlan_set_regiontable%3A%202.4G%200x0%5B%20135.832679%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%5B%20135.832765%5D%20wlan%25d%EF%BC%9Adnld_cmd%20(135.813487)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2016%E3%80%81seqno%200x1b%20%E8%B6%85%E6%97%B6%205000%20%5B135.833246%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.813963)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1b%5B%20135.833311%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.814036)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81act%200x1%E3%80%81len%2032%E3%80%81seqno%200x1c%20%E8%B6%85%E6%97%B6%205000%20%5B135.833767%5D%20wlan%25d%EF%BC%9A135.814485%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B135.833837%5DVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xe808%20len%20%3D%20600%5B%20135.833865%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.852281%5D%20wlan%25d%3A%20135.832993%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.852365%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xea60%20len%20%3D%20600%5B%20135.852394%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.853090%5D%20wlan%25d%3A%20135.833806%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.853163%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xecb8%20len%20%3D%20600%5B%20135.853190%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.853763%5D%20wlan%25d%3A%20135.834478%20%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.853834%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xef10%20len%20%3D%20600%5B%20135.853862%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.854423%5D%20wlan%25d%3A%20135.835138%20%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.854495%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xf168%20len%20%3D%20600%5B%20135.854520%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.855156%5D%20wlan%25d%3A%20135.835873%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.855227%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xf3c0%20len%20%3D%20600%5B%20135.855253%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.855840%5D%20wlan%25d%3A%20135.836555%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.855914%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xf618%20len%20%3D%20600%5B%20135.855940%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.856506%5D%20wlan%25d%3A%20135.837222%20%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.856579%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xf870%20len%20%3D%20600%5B%20135.856605%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.857176%5D%20wlan%25d%3A%20135.837891%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.857249%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xfac8%20len%20%3D%20600%5B%20135.857273%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.871435%5D%20wlan%25d%3A%20135.852148%20%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.871518%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D18%20offset%20%3D%200xc4e0%20len%20%3D%20600%5B%20135.871546%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.889846%5D%20wlan%25d%3A%20135.870559%20%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.889927%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D18%20offset%20%3D%200xc738%20len%20%3D%20600%5B%20135.889954%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.890572%5D%20wlan%25d%3A%20135.871288%20%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.890641%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D18%20offset%20%3D%200xc990%20len%20%3D%20600%5B%20135.890667%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.891189%5D%20wlan%25d%3A%20135.871907%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.891256%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D18%20offset%20%3D%200xcbe8%20len%20%3D%20600%5B%20135.891281%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.891805%5D%20wlan%25d%3A%20135.872522%20%EF%BC%9AEvent%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.891874%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D18%20offset%20%3D%200xce40%20len%20%3D%20600%5B%20135.891899%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20135.892608%5D%20wlan%25d%EF%BC%9Acmd_resp%20(135.873325)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2032%EF%BC%8Cseqno%200x1c%5B%20135.892748%5DCFG80211%3A%20Country%3D00%2C%20band%3D1%2C%20no_of_sub_band%3D25%5B%20135.892808%5D%2011D%3ACountry%3DWW%20band%3D1%20sub-band%3D25%20dfs_region%3D0%5B%20135.892823%5D%2011D%3A%20first%20chan%3D36%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892836%5D%2011D%3A%20first%20chan%3D40%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892848%5D%2011D%3A%20first%20chan%3D44%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892860%5D%2011D%3A%20first%20chan%3D48%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892872%5D%2011D%3A%20first%20chan%3D52%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892883%5D%2011D%3A%20first%20chan%3D56%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892895%5D%2011D%3A%20first%20chan%3D60%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892906%5D%2011D%3A%20first%20chan%3D64%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892919%5D%2011D%3A%20first%20chan%3D100%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892930%5D%2011D%3A%20first%20chan%3D104%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892942%5D%2011D%3A%20first%20chan%3D108%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892954%5D%2011D%3A%20first%20chan%3D112%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892966%5D%2011D%3A%20first%20chan%3D116%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892978%5D%2011D%3A%20first%20chan%3D120%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.892991%5D%2011D%3A%20first%20chan%3D124%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.893003%5D%2011D%3A%20first%20chan%3D128%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.893015%5D%2011D%3A%20%E7%AC%AC%E4%B8%80%20Chan%3D132%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.893026%5D%2011D%3A%20%E7%AC%AC%E4%B8%80%20Chan%3D136%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.893038%5D%2011D%3A%20%E7%AC%AC%E4%B8%80%20Chan%3D140%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.893050%5D%2011D%3A%20%E7%AC%AC%E4%B8%80%E6%89%AB%E6%8F%8F%E6%8C%AF%E5%B9%85%3D144%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.893062%5D%2011D%3A%20%E7%AC%AC%E4%B8%80%E6%89%AB%E6%8F%8F%E6%8C%AF%E5%B9%85%3D149%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.893074%5D%2011D%3A%20%E7%AC%AC%E4%B8%80%E6%89%AB%E6%8F%8F%E6%8C%AF%E5%B9%85%3D153%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.%20135.893086%5D11D%3A%20first%20chan%3D157%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.893098%5D%2011D%3A%20first%20chan%3D161%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.893111%5D%2011D%3A%20first%20chan%3D165%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20135.893129%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%5B%20135.893162%5D%20wlan_set_regiontable%3A%202.4G%200x0%5B%20135.893182%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%5B%20135.893262%5D%20wlan%25d%EF%BC%9Adnld_cmd%20(135.873985)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81act%200x1%E3%80%81len%20104%E3%80%81seqno%200x1d%20%E8%B6%85%E6%97%B6%205000%20%5B135.914842%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.895556)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20104%EF%BC%8Cseqno%200x1d%5B%20135.915464%5D%E8%AE%BE%E7%BD%AE%20wlan%25d%20%E6%8E%A5%E5%8F%A3%E5%9C%B0%E5%9D%80%EF%BC%9A30%3AXX%3AXX%3AXX%3A8c%3A11%5B%20135.915527%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_MAC_ADDRESS%20%5B0x4d%5D%20is%20queued%5B%20135.915612%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(135.896337)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2016%E3%80%81seqno%200x1e%20%E8%B6%85%E6%97%B6%205000%20%5B135.916084%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(135.896801)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1e%5B%20135.917741%5D%E6%B3%A8%E5%86%8C%E6%81%A9%E6%99%BA%E6%B5%A6%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20wlan0%5B%20135.918123%5D%20uap%25d%EF%BC%9AQUEUE_CMD%3A%2011AX_CFG%20%5B0x266%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%E7%AD%89%E5%BE%85%5B%20135.918242%5D%20wlan0%20set%20multicast_list%5B%20135.918284%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%E7%AD%89%E5%BE%85%5B%20135.918321%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%E7%AD%89%E5%BE%85%5B%20135.919456%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(135.900169)%EF%BC%9A11AX_CFG%20%5B0x266%5D%E3%80%81act%200x1%E3%80%81len%2039%E3%80%81seqno%200x101f%20%E8%B6%85%E6%97%B6%205000%20%5B135.922208%5D%20wlan0%EF%BC%9A135.902922%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B135.922289%5DVDLL_IND%3A%20type%3D0%20ID%3D24%20offset%20%3D%200xfd20%20len%20%3D%20600%5B%20135.922317%5D%20wlan0%3A%20DNLD_VDLL%20%3A%20block_len%3D600%5B%20135.924116%5D%20wlan0%3A%20QUEUE_CMD%3A%20TXPWR_CFG%20%5B0xd1%5D%20is%20queued%5B%20135.940962%5D%20wlan0%3A%20135.921674%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.941045%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D24%20offset%20%3D%200xff78%20len%20%3D%20600%5B%20135.941072%5D%20wlan0%3A%20DNLD_VDLL%20%3A%20block_len%3D600%5B%20135.941803%5D%20wlan0%3A%20135.922519%20%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.941878%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D24%20offset%20%3D%200x101d0%20len%20%3D%20600%5B%20135.941907%5D%20wlan0%3A%20DNLD_VDLL%20%3A%20block_len%3D600%5B%20135.942533%5D%20wlan0%3A%20135.923247%20%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.942609%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D24%20offset%20%3D%200x10428%20len%20%3D%20600%5B%20135.942636%5D%20wlan0%3A%20DNLD_VDLL%20%3A%20block_len%3D600%5B%20135.943225%5D%20wlan0%3A%20135.923941%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.943295%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D24%20offset%20%3D%200x10680%20len%20%3D%20600%5B%20135.943321%5D%20wlan0%3A%20DNLD_VDLL%20%3A%20block_len%3D600%5B%20135.943880%5D%20wlan0%3A%20135.924596%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20135.943953%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D24%20offset%20%3D%200x108d8%20len%20%3D%20600%5B%20135.943980%5D%20wlan0%3A%20DNLD_VDLL%20%3A%20block_len%3D600%5B%20135.944770%5D%20uap%25d%EF%BC%9Acmd_resp%20(135.925484)%EF%BC%9A11AX_CFG%20%5B0x8266%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2039%EF%BC%8Cseqno%200x101f%5B%20135.944838%5D%20user_2g_hecap_len%3D28%5B%20135.944887%5D%20wlan0%3A%20DNLD_CMD%20(135.925611)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81act%200x1%E3%80%81len%20204%E3%80%81seqno%200x20%20%E8%B6%85%E6%97%B6%205000%20%5B135.945344%5D%20wlan0%EF%BC%9ACMD_RESP%20(135.926062)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x20%5B%20135.945402%5D%20wlan0%3A%20DNLD_CMD%20(135.926128)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200x21%20%E8%B6%85%E6%97%B6%205000%20%5B135.945714%5D%20wlan0%EF%BC%9ACMD_RESP%20(135.926433)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x21%5B%20135.945784%5D%20wlan0%3A%20DNLD_CMD%20(135.926508)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x22%20%E8%B6%85%E6%97%B6%205000%20%5B135.946203%5D%20wlan0%EF%BC%9ACMD_RESP%20(135.926922)%EF%BC%9ATXPWR_CFG%20%5B0x80d1%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20100%EF%BC%8Cseqno%200x22%5B%20135.946372%5D%20uap%25d%EF%BC%9AQUEUE_CMD%3A%2011AX_CFG%20%5B0x266%5D%20is%20queued%5B%20135.946458%5D%20uap%25d%EF%BC%9Adnld_cmd%20(135.927182)%EF%BC%9A11AX_CFG%20%5B0x266%5D%E3%80%81act%200x1%E3%80%81len%2039%E3%80%81seqno%200x1023%20%E8%B6%85%E6%97%B6%205000%20%5B135.946898%5D%20uap%25d%EF%BC%9ACMD_RESP%20(135.927614)%EF%BC%9A11AX_CFG%20%5B0x8266%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2039%EF%BC%8Cseqno%200x1023%5B%20135.946950%5D%20user_hecap_len%3D28%5B%20135.947917%5D%20wlan0%3A%20QUEUE_CMD%3A%20802_11_RF_ANTENNA%20%5B0x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%20135.948036%5D%20wlan0%3A%20DNLD_CMD%20(135.928760)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8Cact%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x24%20%E8%B6%85%E6%97%B6%205000%20%5B135.948531%5D%20wlan0%EF%BC%9ACMD_RESP%20(135.929248)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x24%5B%20135.952904%5D%20wlan0%3A%20QUEUE_CMD%3A%20TXPWR_CFG%20%5B0xd1%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%20135.953030%5D%20wlan0%3A%20DNLD_CMD%20(135.933753)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x25%20%E8%B6%85%E6%97%B6%205000%20%5B135.953530%5D%20wlan0%EF%BC%9ACMD_RESP%20(135.934248)%EF%BC%9ATXPWR_CFG%20%5B0x80d1%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20100%EF%BC%8Cseqno%200x25%5B%20135.980353%5D%E8%AE%BE%E7%BD%AE%20uap%25d%20%E6%8E%A5%E5%8F%A3%E5%9C%B0%E5%9D%80%EF%BC%9A32%3AXX%3AXX%3AXX%3A8d%3A11%5B%20135.980421%5D%20uap%25d%EF%BC%9AQUEUE_CMD%3A%20APCMD_SYS_CONFIGURE%20%5B0xb0%5D%20is%20queued%5B%20135.980519%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(135.961243)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%E3%80%81act%200x1%E3%80%81len%2020%E3%80%81seqno%200x1026%20%E8%B6%85%E6%97%B6%205000%20%5B135.981001%5D%20uap%25d%EF%BC%9ACMD_RESP%20(135.961718)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0x80b0%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x1026%5B%20135.982691%5D%E6%B3%A8%E5%86%8C%E6%81%A9%E6%99%BA%E6%B5%A6%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20uap0%5B%20135.983020%5DPS%20%E5%91%BD%E4%BB%A4%EF%BC%9A%E6%93%8D%E4%BD%9C%20%3D%200x0%EF%BC%8C%E4%BD%8D%E5%9B%BE%20%3D%200x0%5B%20135.983047%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_PS_MODE_ENH%20%5B0xe4%5D%20is%20queued%5B%20135.983151%5D%20uap0%20set%20multicast_list%5B%20135.983219%5D%20p2p%25d%EF%BC%9Adnld_cmd%20(135.963942)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2027%20%E8%B6%85%E6%97%B6%205000%20%5B135.984207%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(135.964920)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2068%EF%BC%8Cseqno%200x2027%5B%20135.984265%5D%20ps_bitmap%3D0x0%5B%20135.984403%5DCFG80211%3A%20Country%3D00%2C%20band%3D0%2C%20no_of_sub_band%3D1%5B%20135.984449%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%5B%20135.984505%5D%2011D%3ACountry%3DWW%20band%3D0%20sub-band%3D1%20dfs_region%3D0%5B%20135.984522%5D%2011D%3A%20first%20chan%3D1%20no_of_chan%3D14%2C%20max_tx_pwr%3D20%5B%20135.984537%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%5B%20135.984568%5D%20wlan_set_regiontable%3A%202.4G%200x0%5B%20135.984587%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%5B%20135.984659%5D%20p2p%25d%EF%BC%9Adnld_cmd%20(135.965381)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81act%200x1%E3%80%81len%2016%E3%80%81seqno%200x2028%20%E8%B6%85%E6%97%B6%205000%20%5B135.985112%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(135.965828)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2028%5B%20135.985176%5D%20p2p%25d%EF%BC%9Adnld_cmd%20(135.965901)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81act%200x1%E3%80%81len%2032%E3%80%81seqno%200x2029%20%E8%B6%85%E6%97%B6%205000%20%5B135.985893%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9ARX_MGMT_IND%20%5B0x10c%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B136.006674%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(135.987387)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2032%EF%BC%8Cseqno%200x2029%5B%20136.006769%5D%20wlan0%3A%20DNLD_CMD%20(135.987493)%EF%BC%9ARX_MGMT_IND%20%5B0x10c%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2014%E3%80%81seqno%200x2a%20%E8%B6%85%E6%97%B6%205000%20%5B136.007116%5D%20wlan0%EF%BC%9ACMD_RESP%20(135.987835)%EF%BC%9ARX_MGMT_IND%20%5B0x810c%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2a%5B%20136.007258%5DCFG80211%3A%20Country%3D00%2C%20band%3D1%2C%20no_of_sub_band%3D25%5B%20136.007319%5D%2011D%3ACountry%3DWW%20band%3D1%20sub-band%3D25%20dfs_region%3D0%5B%20136.007334%5D%2011D%3A%20first%20chan%3D36%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007347%5D%2011D%3A%20first%20chan%3D40%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007359%5D%2011D%3A%20first%20chan%3D44%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007371%5D%2011D%3A%20first%20chan%3D48%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007382%5D%2011D%3A%20first%20chan%3D52%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007394%5D%2011D%3A%20first%20chan%3D56%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007405%5D%2011D%3A%20first%20chan%3D60%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007417%5D%2011D%3A%20first%20chan%3D64%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007429%5D%2011D%3A%20first%20chan%3D100%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007441%5D%2011D%3A%20first%20chan%3D104%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007453%5D%2011D%3A%20first%20chan%3D108%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007465%5D%2011D%3A%20first%20chan%3D112%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007476%5D%2011D%3A%20first%20chan%3D116%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007488%5D%2011D%3A%20first%20chan%3D120%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007500%5D%2011D%3A%20first%20chan%3D124%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007512%5D%2011D%3A%20first%20chan%3D128%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007524%5D%2011D%3A%20first%20chan%3D132%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007536%5D%2011D%3A%20first%20chan%3D136%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007548%5D%2011D%3A%20first%20chan%3D140%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007560%5D%2011D%3A%20first%20chan%3D144%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007572%5D%2011D%3A%20first%20chan%3D149%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007583%5D%2011D%3A%20first%20chan%3D153%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.%20136.007595%5D%2011D%3A%20first%20chan%3D157%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007607%5D%2011D%3A%20first%20chan%3D161%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007619%5D%2011D%3A%20first%20chan%3D165%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20136.007637%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%5B%20136.007669%5D%20wlan_set_regiontable%3A%202.4G%200x0%5B%20136.007691%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%5B%20136.007772%5D%20p2p%25d%EF%BC%9Adnld_cmd%20(135.988494)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%20104%E3%80%81seqno%200x202b%20%E8%B6%85%E6%97%B6%205000%20%5B136.029473%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(136.010184)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20104%EF%BC%8Cseqno%200x202b%5B%20136.048176%5D%E8%AE%BE%E7%BD%AE%20WFD%20%E8%AE%BE%E5%A4%87%E5%9C%B0%E5%9D%80%EF%BC%9A32%3Axx%3Axx%3Axx%3A8c%3A11%20%5B136.048243%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B136.048342%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(136.029066)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%E3%80%81act%200x1%E3%80%81len%2016%E3%80%81seqno%200x202c%20%E8%B6%85%E6%97%B6%205000%20%5B136.048852%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(136.029568)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x202c%5B%20136.050691%5DRegister%20NXP%20802.11%20Adapter%20p2p0%5B%20136.050845%5D%20wlan%3A%20version%20%3D%20SDIW612---18.99.3.p26.11-MM6X18540.p17-(FP92)%5B136.050911%5D%20wlan0%3A%20QUEUE_CMD%3A%20REG_ACCESS%20%5B0x27c%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20136.051016%5D%20p2p0%20set%20multicast_list%5B%20136.051054%5D%20p2p0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20136.051086051054%5D%20p2p0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20136.051086%5D%20p2p0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20136.051145%5D%20wlan0%3A%20DNLD_CMD%20(136.031870)%EF%BC%9AREG_ACCESS%20%5B0x27c%5D%E3%80%81act%200x0%E3%80%81len%2020%E3%80%81seqno%200x2d%20%E8%B6%85%E6%97%B6%205000%20%5B136.052103%5D%20wlan0%EF%BC%9ACMD_RESP%20(136.032816)%EF%BC%9AREG_ACCESS%20%5B0x827c%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x2d%5B%20136.052193%5D%20p2p0%3A%20DNLD_CMD%20(136.032918)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81act%200x1%E3%80%81len%20204%E3%80%81seqno%200x202e%20%E8%B6%85%E6%97%B6%205000%20%5B136.052627%5D%20p2p0%EF%BC%9ACMD_RESP%20(136.033345)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x202e%5B%20136.052682%5D%20p2p0%3A%20DNLD_CMD%20(136.033408)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81act%200x213%E3%80%81len%2012%E3%80%81seqno%200x202f%20%E8%B6%85%E6%97%B6%205000%20%5B136.052998%5D%20p2p0%EF%BC%9ACMD_RESP%20(136.033717)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x202f%5B%20136.053200%5D%20wlan0%3A%20QUEUE_CMD%EF%BC%9AINDEPENDENT_RESET_CFG%20%5B0x243%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%20136.053281%5D%20wlan0%3A%20DNLD_CMD%20(136.034005)%EF%BC%9AINDEPENDENT_RESET_CFG%20%5B0x243%5D%E3%80%81act%200x0%E3%80%81len%2012%E3%80%81seqno%200x30%20%E8%B6%85%E6%97%B6%205000%20%5B136.053716%5D%20wlan0%EF%BC%9ACMD_RESP%20(136.034434)%EF%BC%9AINDEPENDENT_RESET_CFG%20%5B0x8243%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x30%20%5B136.054120%5D%20%E4%BE%9B%E5%BA%94%E5%95%86%E4%BA%8B%E4%BB%B6%EF%BC%9A0x2%20%5B136.054174%5D%20%3D%3D%3D%3D%3D%3D%3D%3DEND%20IN-BAND%20RESET%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%5B%20136.112302%5D%20wlan0%EF%BC%9AQUEUE_CMD%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B136.112439%5D%20wlan0%EF%BC%9ADNLD_CMD%20(136.093162)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%E3%80%81act%200x0%E3%80%81len%2016%E3%80%81seqno%200x31%20%E8%B6%85%E6%97%B6%205000%20%5B136.112959%5D%20wlan0%EF%BC%9ACMD_RESP%20(136.093675)%EF%BC%9ATXPWR_CFG%20%5B0x80d1%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20100%EF%BC%8Cseqno%200x31%5B%20136.123000%5D%20wlan0%20set%20multicast_list%5B%20136.123064%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20136.123110%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20136.123195%5D%20wlan0%3A%20DNLD_CMD%20(136.103918)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81act%200x1%E3%80%81len%20204%E3%80%81seqno%200x32%20%E8%B6%85%E6%97%B6%205000%20%5B136.123686%5D%20wlan0%EF%BC%9ACMD_RESP%20(136.104404)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x32%5B%20136.123751%5D%20wlan0%3A%20DNLD_CMD%20(136.104476)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200x33%20%E8%B6%85%E6%97%B6%205000%20%5B136.124071%5D%20wlan0%EF%BC%9ACMD_RESP%20(136.104789)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x33%5B%20136.127648%5D%20wlan0%3A%20QUEUE_CMD%3A%20TXPWR_CFG%20%5B0xd1%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%20136.127786%5D%20wlan0%3A%20DNLD_CMD%20(136.108509)%EF%BC%9ATXPWR_CFG%20%5B0xd1%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x34%20%E8%B6%85%E6%97%B6%205000%20%5B136.128291%5D%20wlan0%EF%BC%9ACMD_RESP%20(136.109008)%EF%BC%9ATXPWR_CFG%20%5B0x80d1%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20100%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x34%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AW611%20WiFi%20chip%20Wi-Fi%20scan%20timeout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F250148%22%20target%3D%22_blank%22%3E%40eric25%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E6%8F%90%E4%BE%9B%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%EF%BC%9F%3C%2FP%3E%0A%3CP%3E1.%20%E5%AE%8C%E6%95%B4%E7%9A%84%20Linux%20%E6%97%A5%E5%BF%97%EF%BC%8C%E5%8C%85%E6%8B%AC%E5%8A%A0%E8%BD%BD%20WIFI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%92%8C%E8%AF%B4%E6%98%8E%20wpa_supplicant%20%3C%2FP%3E%0A%3CP%3E2.%20wpa_supplicant.conf%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AE%A9%E6%88%91%E4%BB%AC%E5%86%8D%E7%9C%8B%E4%B8%80%E9%81%8D%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E5%8D%AB%E4%B8%9C%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AW611%20WiFi%20chip%20Wi-Fi%20scan%20timeout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMakefile%3C%2FP%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%89%A7%E9%80%8F%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E9%AB%98%E4%BA%AE%E9%83%A8%E5%88%86%E5%8F%AF%E4%BE%9B%E9%98%85%E8%AF%BB%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%3CDIV%3EBINALL%3Dwpa_supplicant%20wpa_cli%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E5%85%A8%E9%83%A8%20%3D%20%24(binall)%3C%2FDIV%3E%3CDIV%3EALL%20%2B%3D%20systemd%2Fwpa_supplicant.service%3C%2FDIV%3E%3CDIV%3EALL%20%2B%3D%20systemd%2Fwpa_supplicant%40.service%3C%2FDIV%3E%3CDIV%3EALL%20%2B%3D%20systemd%2Fwpa_supplicant-nl80211%40.service%3C%2FDIV%3E%3CDIV%3EALL%20%2B%3D%20systemd%2Fwpa_supplicant-wired%40.service%3C%2FDIV%3E%3CDIV%3EALL%20%2B%3D%20dbus%2Ffi.w1.wpa_supplicant1.service%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EEXTRA_TARGETS%3Ddynamic_eap_methods%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECONFIG_FILE%3D.config%3C%2FDIV%3E%3CDIV%3E%E5%8C%85%E6%8B%AC%20..%2Fsrc%2F%E7%89%88%E6%9C%AC.rules%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_BUILD_PASN_SO%3C%2FDIV%3E%3CDIV%3E%23%20%E8%BF%99%E6%A0%B7%E6%B7%BB%E5%8A%A0%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%EF%BC%8C%E4%BB%A5%E5%85%81%E8%AE%B8%20CONFIG_BUILD_PASN_SO%3C%2FDIV%3E%3CDIV%3E%23%20%E5%9C%A8%20%E7%89%88%E6%9C%AC.rules%20%E8%AF%BB%E5%8F%96%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%AD%E8%AE%BE%E7%BD%AE%3C%2FDIV%3E%3CDIV%3E%E5%85%A8%E9%83%A8%EF%BC%9Alibpasn.so%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_BUILD_WPA_CLIENT_SO%3C%2FDIV%3E%3CDIV%3E%23%20%E8%BF%99%E6%A0%B7%E6%B7%BB%E5%8A%A0%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%EF%BC%8C%E4%BB%A5%E5%85%81%E8%AE%B8%20CONFIG_BUILD_WPA_CLIENT_SO%3C%2FDIV%3E%3CDIV%3E%23%20%E5%9C%A8%20%E7%89%88%E6%9C%AC.rules%20%E8%AF%BB%E5%8F%96%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%AD%E8%AE%BE%E7%BD%AE%3C%2FDIV%3E%3CDIV%3E%E5%85%A8%E9%83%A8%EF%BC%9Alibwpa_client.so%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_NO_WPA_PASSPHRASE%3C%2FDIV%3E%3CDIV%3E%23%20%E8%BF%99%E6%A0%B7%E6%B7%BB%E5%8A%A0%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%EF%BC%8C%E4%BB%A5%E5%85%81%E8%AE%B8%20CONFIG_NO_WPA_PASSPHRASE%3C%2FDIV%3E%3CDIV%3E%23%20%E5%9C%A8%20%E7%89%88%E6%9C%AC.rules%20%E8%AF%BB%E5%8F%96%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%AD%E8%AE%BE%E7%BD%AE%3C%2FDIV%3E%3CDIV%3E_all%3A%20wpa_passphrase%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20LIBS%3C%2FDIV%3E%3CDIV%3E%23%20%E5%A6%82%E6%9E%9C%20LIBS%20%E8%AE%BE%E7%BD%AE%E4%BA%86%E6%9F%90%E4%BA%9B%E5%85%A8%E5%B1%80%E7%89%88%E6%9C%AC%E7%B3%BB%E7%BB%9F%E7%9A%84%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%8C%E8%AF%B7%E5%85%8B%E9%9A%86%E8%BF%99%E4%BA%9B%E9%BB%98%E8%AE%A4%E5%80%BC%3C%2FDIV%3E%3CDIV%3E%23%20LIBS_c%20%E5%92%8C%20LIBS_p%20%E4%B9%9F%E6%B6%B5%E7%9B%96%20wpa_passphrase%20%E5%92%8C%20wpa_cli%E3%80%82%3C%2FDIV%3E%3CDIV%3Eifndef%20LIBS_c%3C%2FDIV%3E%3CDIV%3ELIBS_c%20%3A%3D%20%24(LIBS)%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifndef%20LIBS_p%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%3A%3D%20%24(LIBS)%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eexport%20LIBDIR%20%3F%3D%20%2Fusr%2Flocal%2Flib%3C%2FDIV%3E%3CDIV%3Eexport%20INCDIR%20%3F%3D%20%2Fusr%2Flocal%2Finclude%3C%2FDIV%3E%3CDIV%3Eexport%20BINDIR%20%3F%3D%20%2Fusr%2Flocal%2Fsbin%3C%2FDIV%3E%3CDIV%3EPKG_CONFIG%20%3F%3D%20pkg-config%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20%24(extra_cflags)%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20-I%24(abspath%20..%2Fsrc)%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20-I%24(abspath%20..%2Fsrc%2Futils)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECC%3D%24(CROSS_COMPILE)gcc%3C%2FDIV%3E%3CDIV%3E%23libnl%20lib%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20-I%2Fhome%2Feric%2Fwork%2Fthirdpartyutils%2Fwpa_supplicant%2Flibnl-3.11.0%2F_install%2Finclude%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20-I%2Fhome%2Feric%2Fwork%2Fthirdpartyutils%2Fwpa_supplicant%2Flibnl-3.11.0%2F_install%2Finclude%2Flibnl3%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-L%2Fhome%2Feric%2Fwork%2Fthirdpartyutils%2Fwpa_supplicant%2Flibnl-3.11.0%2F_install%2Flib%3C%2FDIV%3E%3CDIV%3ELDFLAGS%20%2B%3D%20-L%2Fhome%2Feric%2Fwork%2Fthirdpartyutils%2Fwpa_supplicant%2Flibnl-3.11.0%2F_install%2Flib%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%23openssl%20lib%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20-I%2Fhome%2Feric%2Fwork%2Fthirdpartyutils%2Fwpa_supplicant%2Fopenssl-3.5.0%2F_install%2Finclude%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-L%2Fhome%2Feric%2Fwork%2Fthirdpartyutils%2Fwpa_supplicant%2Fopenssl-3.5.0%2F_install%2Flib%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%2B%3D%20-L%2Fhome%2Feric%2Fwork%2Fthirdpartyutils%2Fwpa_supplicant%2Fopenssl-3.5.0%2F_install%2Flib%3C%2FDIV%3E%3CDIV%3ELDFLAGS%20%2B%3D%20-L%2Fhome%2Feric%2Fwork%2Fthirdpartyutils%2Fwpa_supplicant%2Fopenssl-3.5.0%2F_install%2Flib%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lpthread%3C%2FDIV%3E%3CDIV%3ELDFLAGS%20%2B%3D%20-lm%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_NO_GITVER%3C%2FDIV%3E%3CDIV%3E%23%20%E4%B8%BA%E6%9D%A5%E8%87%AA%20git%20%E5%AD%98%E5%82%A8%E5%BA%93%E7%9A%84%E7%89%88%E6%9C%AC%E6%B7%BB%E5%8A%A0%20VERSION_STR%20%E5%90%8E%E7%BC%80%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(wildcard%20..%2F.git)%2C..%2F.git)%3C%2FDIV%3E%3CDIV%3EGITVER%20%3A%3D%20%24(shell%20git%20describe%20--dirty%3D%2B)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(GITVER)%2C)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dgit_version_str_postfix%3D%5C%22-%24(gitver)%5C%22%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_TESTING_OPTIONS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_testing_options%3C%2FDIV%3E%3CDIV%3ECONFIG_WPS_TESTING%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_TDLS_TESTING%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_AES_WRAP%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Emkconfig%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40if%20%5B%20-f%20.config%5D%EF%BC%9B%E9%82%A3%E4%B9%88%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eecho%20'.config%20exists%20-%20did%20not%20replace%20it'%3B%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eexit%201%3B%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Efi%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eecho%20CONFIG_DRIVER_HOSTAP%3Dy%26gt%3B%26gt%3B%20.config%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eecho%20CONFIG_DRIVER_WEXT%3Dy%26gt%3B%26gt%3B%20.config%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%24(destdir)%24(bindir)%2F%25%20%EF%BC%9A%25%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einstall%20-D%20%24(%26lt%3B)%20%24(%40)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E5%AE%89%E8%A3%85%EF%BC%9A%24(addprefix%20%24(DESTDIR)%24(BINDIR)%2F%2C%24(BINALL))%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(MAKE)%20-C%20..%2Fsrc%20install%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_NO_WPA_PASSPHRASE%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einstall%20-D%20wpa_passphrase%20%24(DESTDIR)%2F%24(BINDIR)%2Fwpa_passphrase%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_BUILD_PASN_SO%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einstall%20-m%200644%20-D%20libpasn.so%20%24(DESTDIR)%2F%24(LIBDIR)%2Flibpasn.so%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_BUILD_WPA_CLIENT_SO%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einstall%20-m%200644%20-D%20libwpa_client.so%20%24(DESTDIR)%2F%24(LIBDIR)%2Flibwpa_client.so%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einstall%20-m%200644%20-D%20..%2Fsrc%2Fcommon%2Fwpa_ctrl.h%20%24(DESTDIR)%2F%24(INCDIR)%2Fwpa_ctrl.h%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif%20ls%20eap_*.so%26gt%3B%2Fdev%2Fnull%202%26gt%3B%26amp%3B%201%3B%20then%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einstall%20-d%20%24(DESTDIR)%24(LIBDIR)%2Fwpa_supplicant%26amp%3B%26amp%3B%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecp%20*.so%20%24(DESTDIR)%24(LIBDIR)%2Fwpa_supplicant%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3B%20fi%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_FIPS%3C%2FDIV%3E%3CDIV%3Econfig_noo_random_pool%3D%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EOBJS%20%3D%20config.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20notify.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20bss.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20eap_register.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fcommon.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fconfig.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fwpa_debug.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fwpabuf.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fbitfield.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fip_addr.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fcrc32.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fptksa_cache.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Frsn_supp%2Fpmksa_cache.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20twt.o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%3D%20wpa_passphrase.o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20..%2Fsrc%2Futils%2Fcommon.o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20..%2Fsrc%2Futils%2Fwpa_debug.o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20..%2Fsrc%2Futils%2Fwpabuf.o%3C%2FDIV%3E%3CDIV%3EOBJS_c%20%3D%20wpa_cli.o..%2Fsrc%2Fcommon%2Fwpa_ctrl.o%3C%2FDIV%3E%3CDIV%3EOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2Fwpa_debug.o%3C%2FDIV%3E%3CDIV%3EOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2Fcommon.o%3C%2FDIV%3E%3CDIV%3EOBJS_c%20%2B%3D%20..%2Fsrc%2Fcommon%2Fcli.o%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_OS%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NATIVE_WINDOWS%3C%2FDIV%3E%3CDIV%3ECONFIG_OS%3Dwin32%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3ECONFIG_OS%3Dunix%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_OS)%2C%20internal)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dos_noo_c_lib_defines%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fos_%24(CONFIG_OS).o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20..%2Fsrc%2Futils%2Fos_%24(CONFIG_OS).o%3C%2FDIV%3E%3CDIV%3EOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2Fos_%24(CONFIG_OS).o%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPA_TRACE%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dwpa_trace%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.o%3C%2FDIV%3E%3CDIV%3EOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.o%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.o%3C%2FDIV%3E%3CDIV%3ELIBCTRL%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.o%3C%2FDIV%3E%3CDIV%3ELIBCTRLSO%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.c%3C%2FDIV%3E%3CDIV%3ELDFLAGS%20%2B%3D%20-rdynamic%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20-funwind-tables%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPA_TRACE_BFD%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20-DPACKAGE%3D%22wpa_supplicant%22%20-DWPA_TRACE_BFD%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lbfd%20-ldl%20-liberty%20-lz%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%2B%3D%20-lbfd%20-ldl%20-liberty%20-lz%3C%2FDIV%3E%3CDIV%3ELIBS_c%20%2B%3D%20-lbfd%20-ldl%20-liberty%20-lz%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_ELOOP%3C%2FDIV%3E%3CDIV%3ECONFIG_ELOOP%3Deloop%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2F%24(CONFIG_ELOOP).o%3C%2FDIV%3E%3CDIV%3EOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2F%24(CONFIG_ELOOP).o%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_OSX%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_ELOOP)%2C%20eloop)%3C%2FDIV%3E%3CDIV%3E%23%20%E4%BD%BF%E7%94%A8%20glibc%26lt%3B%202.17%20%E6%97%B6%EF%BC%8Cclock_gettime()%20%E9%9C%80%E8%A6%81%20-lrt%3C%2FDIV%3E%3CDIV%3E%23%20OS%20X%20%E6%9C%89%E5%8F%A6%E4%B8%80%E7%A7%8D%E5%AE%9E%E7%8E%B0%E6%96%B9%E5%BC%8F%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lrt%3C%2FDIV%3E%3CDIV%3ELIBS_c%20%2B%3D%20-lrt%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%2B%3D%20-lrt%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_ELOOP_POLL%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_eloop_poll%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_ELOOP_EPOLL%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_eloop_epoll%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_ELOOP_KQUEUE%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_eloop_kqueue%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAPOL_TEST%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20-Werror%20-DEAPOL_TEST%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_CODE_COVERAGE%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20-O0%20-fprofile-arcs%20-ftest-coverage%20-U_FORTIFY_SOURCE%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lgcov%3C%2FDIV%3E%3CDIV%3ELIBS_c%20%2B%3D%20-lgcov%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%2B%3D%20-lgcov%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_HT_OVERRIDES%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ht_overrides%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_VHT_OVERRIDES%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_vht_overrides%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_HE_OVERRIDES%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_he_overrides%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_BACKEND%3C%2FDIV%3E%3CDIV%3ECONFIG_BACKEND%3Dfile%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_BACKEND)%2C%20file)%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20config_file.o%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_NO_CONFIG_BLOBS%3C%2FDIV%3E%3CDIV%3ENEED_BASE64%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_backend_file%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_BACKEND)%2C%20winreg)%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20config_winreg.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_BACKEND)%2C%20none)%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20config_none.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_CONFIG_WRITE%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_config_write%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_CONFIG_BLOBS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_config_blobs%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_SCAN_PROCESSING%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_scan_processing%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_SUITEB%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_suiteb%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_SUITEB192%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_suiteb192%3C%2FDIV%3E%3CDIV%3ENEED_SHA384%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_OCV%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ocv%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Focv.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_IEEE80211R%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ieee80211r%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Frsn_supp%2Fwpa_ft.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_MESH%3C%2FDIV%3E%3CDIV%3ENEED_80211_COMMON%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_AES_SIV%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_SAE%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_AP%3Dy%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_mesh%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20mesh.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20mesh_mpm.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20mesh_rsn.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_SAE%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_sae%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fsae.o%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_SAE_PK%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_sae_pk%3C%2FDIV%3E%3CDIV%3ENEED_AES_SIV%3Dy%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fsae_pk.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ENEED_ECC%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_DH_GROUPS%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_HMAC_SHA256_KDF%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_DRAGONFLY%3Dy%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_TESTING_OPTIONS%3C%2FDIV%3E%3CDIV%3ENEED_DH_GROUPS_ALL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_DPP%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_dpp%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdpp.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdpp_auth.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdpp_backup.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdpp_crypto.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdpp_pkex.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdpp_reconfig.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdpp_tcp.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20dpp_supplicant.o%3C%2FDIV%3E%3CDIV%3ENEED_AES_SIV%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_HMAC_SHA256_KDF%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_HMAC_SHA384_KDF%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_HMAC_SHA512_KDF%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_SHA384%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_SHA512%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_ECC%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_JSON%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_GAS_SERVER%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_BASE64%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_ASN1%3Dy%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_DPP2%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_dpp2%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_DPP3%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_dpp3%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NAN_USD%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fnan_de.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20nan_usd.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_nan_usd%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_OWE%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_owe%3C%2FDIV%3E%3CDIV%3ENEED_ECC%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_HMAC_SHA256_KDF%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_HMAC_SHA384_KDF%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_HMAC_SHA512_KDF%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_SHA384%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_SHA512%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_FILS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_fils%3C%2FDIV%3E%3CDIV%3ENEED_SHA384%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_AES_SIV%3Dy%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_FILS_SK_PFS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_fils_sk_pfs%3C%2FDIV%3E%3CDIV%3ENEED_ECC%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_MBO%3C%2FDIV%3E%3CDIV%3ECONFIG_WNM%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_BGSCAN_SIMPLE%3C%2FDIV%3E%3CDIV%3ECONFIG_WNM%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WNM%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_wnm%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20wnm_sta.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_TDLS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_tdls%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Frsn_supp%2Ftdls.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_TDLS_TESTING%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_tdls_testing%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_PMKSA_CACHE_EXTERNAL%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_pmksa_cache_external%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_NO_WPA%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Frsn_supp%2Fwpa.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Frsn_supp%2Fpreauth.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Frsn_supp%2Fwpa_ie.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fwpa_common.o%3C%2FDIV%3E%3CDIV%3ENEED_AES%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_SHA1%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_MD5%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_RC4%3Dy%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_wpa%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_TLS)%2C%20internal)%3C%2FDIV%3E%3CDIV%3ENEED_SHA1%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_MD5%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_IBSS_RSN%3C%2FDIV%3E%3CDIV%3ENEED_RSN_AUTHENTICATOR%3Dy%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ibss_rsn%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_vlan%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20ibss_rsn.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_MATCH_IFACE%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_match_iface%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_P2P%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20p2p_supplicant.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20p2p_supplicant_sd.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fp2p%2Fp2p.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fp2p%2Fp2p_utils.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fp2p%2Fp2p_parse.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fp2p%2Fp2p_build.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fp2p%2Fp2p_go_neg.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fp2p%2Fp2p_sd.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fp2p%2Fp2p_pd.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fp2p%2Fp2p_invitation.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fp2p%2Fp2p_dev_disc.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fp2p%2Fp2p_group.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fp2p_hostapd.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_p2p%3C%2FDIV%3E%3CDIV%3ENEED_GAS%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_OFFCHANNEL%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_WPS%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_AP%3Dy%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_P2P_STRICT%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_p2p_strict%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WIFI_DISPLAY%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_wifi_display%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20wifi_display.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_PASN%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_pasn%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ptksa_cache%3C%2FDIV%3E%3CDIV%3ENEED_HMAC_SHA256_KDF%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_HMAC_SHA384_KDF%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_SHA256%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_SHA384%3Dy%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fpasn%2Fpasn_initiator.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fpasn%2Fpasn_common.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20pasn_supplicant.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_HS20%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20hs20_supplicant.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_hs20%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERWORKING%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERWORKING%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20interworking.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_interworking%3C%2FDIV%3E%3CDIV%3ENEED_GAS%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_ROAMING%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_roaming%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_OPENSC_ENGINE_PATH%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_opensc_engine_path%3D%5C%22%24(config_opensc_engine_path)%5C%22%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_OPENSC_ENGINE_PATH%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_opensc_engine_path%3Dnull%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_PKCS11_ENGINE_PATH%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_pkcs11_engine_path%3D%5C%22%24(config_pkcs11_engine_path)%5C%22%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_PKCS11_ENGINE_PATH%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_pkcs11_engine_path%3Dnull%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_PKCS11_MODULE_PATH%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_pkcs11_module_path%3D%5C%22%24(config_pkcs11_module_path)%5C%22%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_PKCS11_MODULE_PATH%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_pkcs11_module_path%3Dnull%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_LOAD_DYNAMIC_EAP%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_load_dynamic_eap%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_RRM%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_rrm%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20rrm.o%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_AP%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Frrm.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20op_classes.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_WMM_AC%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_wmm_ac%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20wmm_ac.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_ROBUST_AV%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_robust_av%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20robust_av.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Einclude%20..%2Fsrc%2Fdrivers%2Fdrivers.mak%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_AP%3C%2FDIV%3E%3CDIV%3EOBJS_d%20%2B%3D%20%24(DRV_BOTH_OBJS)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20%24(drv_both_cflags)%3C%2FDIV%3E%3CDIV%3Eldflags%20%2B%3D%20%24(drv_both_ldflags)%3C%2FDIV%3E%3CDIV%3Elibs%20%2B%3D%20%24(drv_both_libs)%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3ENEED_AP_MLME%3D%3C%2FDIV%3E%3CDIV%3EOBJS_d%20%2B%3D%20%24(DRV_WPA_OBJS)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20%24(drv_wpa_cflags)%3C%2FDIV%3E%3CDIV%3Eldflags%20%2B%3D%20%24(drv_wpa_ldflags)%3C%2FDIV%3E%3CDIV%3Elibs%20%2B%3D%20%24(drv_wpa_libs)%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_L2_PACKET%3C%2FDIV%3E%3CDIV%3ECONFIG_L2_PACKET%3Dlinux%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EOBJS_l2%20%2B%3D%20..%2Fsrc%2Fl2_packet%2Fl2_packet_%24(CONFIG_L2_PACKET).o%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_L2_PACKET)%2C%20pcap)%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WINPCAP%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_winpcap%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lwpcap%20-lpacket%3C%2FDIV%3E%3CDIV%3ELIBS_w%20%2B%3D%20-lwpcap%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-ldnet%20-lpcap%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_L2_PACKET)%2C%20winpcap)%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lwpcap%20-lpacket%3C%2FDIV%3E%3CDIV%3ELIBS_w%20%2B%3D%20-lwpcap%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_L2_PACKET)%2C%20freebsd)%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lpcap%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_ERP%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_erp%3C%2FDIV%3E%3CDIV%3ENEED_HMAC_SHA256_KDF%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_TLS%3C%2FDIV%3E%3CDIV%3E%23%20EAP-TLS%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_TLS)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_tls_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_tls.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_tls%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_tls.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ETLS_FUNCS%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_TLSV1_3%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_tlsv1_3%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_UNAUTH_TLS%3C%2FDIV%3E%3CDIV%3E%23%20eap-unauth-tls%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_unauth_tls%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_EAP_TLS%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_tls.o%3C%2FDIV%3E%3CDIV%3ETLS_FUNCS%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_PEAP%3C%2FDIV%3E%3CDIV%3E%23%20EAP-PEAP%3C%2FDIV%3E%3CDIV%3ESRC_EAP_PEAP%20%3D%20..%2Fsrc%2Feap_peer%2Feap_peap.c%20..%2Fsrc%2Feap_common%2Feap_peap_common.c%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_PEAP)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_peap_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_peap.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_peap%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_PEAP))%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ETLS_FUNCS%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_TTLS%3C%2FDIV%3E%3CDIV%3E%23%20EAP-TTLS%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_TTLS)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_ttls_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_ttls.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_ttls%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_ttls.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ETLS_FUNCS%3Dy%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_FIPS%3C%2FDIV%3E%3CDIV%3EMS_FUNCS%3Dy%3C%2FDIV%3E%3CDIV%3ECHAP%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_MD5%3C%2FDIV%3E%3CDIV%3E%23%20EAP-MD5%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_MD5)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_md5_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_md5.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_md5%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_md5.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECHAP%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%23%20%E5%90%91%E5%90%8E%E5%85%BC%E5%AE%B9%E6%97%A7%E6%8B%BC%E5%86%99%E6%B3%95%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_MSCHAPV2%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_EAP_MSCHAPV2%3C%2FDIV%3E%3CDIV%3ECONFIG_EAP_MSCHAPV2%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_MSCHAPV2%3C%2FDIV%3E%3CDIV%3E%23%20EAP-MSCHAPv2%3C%2FDIV%3E%3CDIV%3ESRC_EAP_MSCHAPV2%20%3D%20..%2Fsrc%2Feap_peer%2Feap_mschapv2.c%20..%2Fsrc%2Feap_peer%2Fmschapv2.c%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_MSCHAPV2)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20-DEAP_MSCHAPv2_DYNAMIC%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_mschapv2.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20-DEAP_MSCHAPv2%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_MSCHAPV2))%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EMS_FUNCS%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_GTC%3C%2FDIV%3E%3CDIV%3E%23%20EAP-GTC%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_GTC)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_gtc_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_gtc.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_gtc%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_gtc.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_OTP%3C%2FDIV%3E%3CDIV%3E%23%20EAP-OTP%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_OTP)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_otp_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_otp.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_otp%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_otp.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_SIM%3C%2FDIV%3E%3CDIV%3E%23%20EAP-SIM%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_SIM)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_sim_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_sim.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_sim%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_sim.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_EAP_SIM_COMMON%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_AES_CBC%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_LEAP%3C%2FDIV%3E%3CDIV%3E%23%20EAP-LEAP%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_LEAP)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_leap_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_leap.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_leap%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_leap.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EMS_FUNCS%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_PSK%3C%2FDIV%3E%3CDIV%3E%23%20EAP-PSK%3C%2FDIV%3E%3CDIV%3ESRC_EAP_PSK%20%3D%20..%2Fsrc%2Feap_peer%2Feap_psk.c%20..%2Fsrc%2Feap_common%2Feap_psk_common.c%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_PSK)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_psk_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_psk.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_psk%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_PSK))%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_AES%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_AES_ENCBLOCK%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_AES_EAX%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_AKA%3C%2FDIV%3E%3CDIV%3E%23%20EAP-AKA%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_AKA)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_aka_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_aka.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_aka%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_aka.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_EAP_SIM_COMMON%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_AES_CBC%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_PROXY%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_eap_proxy%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_proxy_%24(CONFIG_EAP_PROXY).o%3C%2FDIV%3E%3CDIV%3Einclude%20eap_proxy_%24(CONFIG_EAP_PROXY).mak%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_AKA_PRIME%3C%2FDIV%3E%3CDIV%3E%23%20EAP-AKA'%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_AKA_PRIME)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_aka_prime_dynamic%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_aka_prime%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_SIM_COMMON%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_common%2Feap_sim_common.o%3C%2FDIV%3E%3CDIV%3ENEED_AES%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_FIPS186_2_PRF%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_FAST%3C%2FDIV%3E%3CDIV%3E%23%20EAP-FAST%3C%2FDIV%3E%3CDIV%3ESRC_EAP_FAST%20%3D%20..%2Fsrc%2Feap_peer%2Feap_fast.c%20..%2Fsrc%2Feap_peer%2Feap_fast_pac.c%3C%2FDIV%3E%3CDIV%3ESRC_EAP_FAST%20%2B%3D%20..%2Fsrc%2Feap_common%2Feap_fast_common.c%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_FAST)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_fast_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_fast.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_fast%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_FAST))%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ETLS_FUNCS%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_T_PRF%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_TEAP%3C%2FDIV%3E%3CDIV%3E%23%20EAP-TEAP%3C%2FDIV%3E%3CDIV%3ESRC_EAP_TEAP%20%3D%20..%2Fsrc%2Feap_peer%2Feap_teap.c%20..%2Fsrc%2Feap_peer%2Feap_teap_pac.c%3C%2FDIV%3E%3CDIV%3ESRC_EAP_TEAP%20%2B%3D%20..%2Fsrc%2Feap_common%2Feap_teap_common.c%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_TEAP)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_teap_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_teap.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_teap%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_TEAP))%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ETLS_FUNCS%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_T_PRF%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_SHA384%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_TLS_PRF_SHA256%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_TLS_PRF_SHA384%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_PAX%3C%2FDIV%3E%3CDIV%3E%23%20EAP-PAX%3C%2FDIV%3E%3CDIV%3ESRC_EAP_PAX%20%3D%20..%2Fsrc%2Feap_peer%2Feap_pax.c%20..%2Fsrc%2Feap_common%2Feap_pax_common.c%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_PAX)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_pax_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_pax.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_pax%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_PAX))%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_SAKE%3C%2FDIV%3E%3CDIV%3E%23%20EAP-SAKE%3C%2FDIV%3E%3CDIV%3ESRC_EAP_SAKE%20%3D%20..%2Fsrc%2Feap_peer%2Feap_sake.c%20..%2Fsrc%2Feap_common%2Feap_sake_common.c%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_SAKE)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_sake_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_sake.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_sake%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_SAKE))%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_GPSK%3C%2FDIV%3E%3CDIV%3E%23%20EAP-GPSK%3C%2FDIV%3E%3CDIV%3ESRC_EAP_GPSK%20%3D%20..%2Fsrc%2Feap_peer%2Feap_gpsk.c%20..%2Fsrc%2Feap_common%2Feap_gpsk_common.c%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_GPSK)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_gpsk_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_gpsk.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_gpsk%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_GPSK))%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_GPSK_SHA256%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_gpsk_sha256%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_PWD%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_pwd%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_TLS)%2C%20wolfssl)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ecc%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_pwd.o%20..%2Fsrc%2Feap_common%2Feap_pwd_common.o%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_ECC%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_DRAGONFLY%3Dy%3C%2FDIV%3E%3CDIV%3EMS_FUNCS%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_EKE%3C%2FDIV%3E%3CDIV%3E%23%20EAP-EKE%3C%2FDIV%3E%3CDIV%3ESRC_EAP_EKE%20%3D%20..%2Fsrc%2Feap_peer%2Feap_eke.c%20..%2Fsrc%2Feap_common%2Feap_eke_common.c%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_EKE)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_eke_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_eke.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_eke%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_EKE))%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_DH_GROUPS%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_DH_GROUPS_ALL%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_AES_CBC%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPS%3C%2FDIV%3E%3CDIV%3E%23%20EAP-WSC%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_wps%20-deap_wsc%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20wps_supplicant.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fuuid.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_wsc.o%20..%2Fsrc%2Feap_common%2Feap_wsc_common.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_common.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_attr_parse.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_attr_build.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_attr_process.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_dev_attr.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_enrollee.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_registrar.o%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_DH_GROUPS%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_BASE64%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_AES_CBC%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_MODEXP%3Dy%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPS_NFC%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_wps_nfc%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fndef.o%3C%2FDIV%3E%3CDIV%3ENEED_WPS_OOB%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_WPS_OOB%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_wps_oob%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPS_ER%3C%2FDIV%3E%3CDIV%3ECONFIG_WPS_UPNP%3Dy%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_wps_er%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_er.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_er_ssdp.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPS_UPNP%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_wps_upnp%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_upnp.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_upnp_ssdp.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_upnp_web.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_upnp_event.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_upnp_ap.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fupnp_xml.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fhttpread.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fhttp_client.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fhttp_server.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPS_STRICT%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_wps_strict%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_validate.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPS_TESTING%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_wps_testing%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPS_REG_DISABLE_OPEN%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_wps_reg_disable_open%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_IKEV2%3C%2FDIV%3E%3CDIV%3E%23%20EAP-IKEv2%3C%2FDIV%3E%3CDIV%3ESRC_EAP_IKEV2%20%3D%20..%2Fsrc%2Feap_peer%2Feap_ikev2.c%3C%2FDIV%3E%3CDIV%3ESRC_EAP_IKEV2%20%2B%3D%20..%2Fsrc%2Feap_peer%2Fikev2.c%3C%2FDIV%3E%3CDIV%3ESRC_EAP_IKEV2%20%2B%3D%20..%2Fsrc%2Feap_common%2Feap_ikev2_common.c%3C%2FDIV%3E%3CDIV%3ESRC_EAP_IKEV2%20%2B%3D%20..%2Fsrc%2Feap_common%2Fikev2_common.c%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_IKEV2)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_ikev2_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_ikev2.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_ikev2%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_IKEV2))%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_DH_GROUPS%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_DH_GROUPS_ALL%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_MODEXP%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_CIPHER%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_VENDOR_TEST%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_EAP_VENDOR_TEST)%2C%20dyn)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_vendor_test_dynamic%3C%2FDIV%3E%3CDIV%3EEAPDYN%20%2B%3D%20eap_vendor_test.so%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_vendor_test%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_vendor_test.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EAP_TNC%3C%2FDIV%3E%3CDIV%3E%23%20EAP-TNC%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_tnc%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_tnc.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Ftncc.o%3C%2FDIV%3E%3CDIV%3ENEED_BASE64%3Dy%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_NATIVE_WINDOWS%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_DRIVER_BSD%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-ldl%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_MACSEC%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_macsec%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_AES_ENCBLOCK%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_AES_UNWRAP%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_AES_WRAP%3Dy%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20wpas_kay.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fpae%2Fieee802_1x_cp.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fpae%2Fieee802_1x_kay.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fpae%2Fieee802_1x_key.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fpae%2Fieee802_1x_secy_ops.o%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_AP%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwpa_auth_kay.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_IEEE8021X_EAPOL%3C%2FDIV%3E%3CDIV%3E%23%20IEEE%20802.1X%2FEAPOL%20%E7%8A%B6%E6%80%81%E6%9C%BA%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E7%94%A8%E4%BA%8E%20RADIUS%20%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%EF%BC%89%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dieee8021x_eapol%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feapol_supp%2Feapol_supp_sm.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap.o%20..%2Fsrc%2Feap_peer%2Feap_methods.o%3C%2FDIV%3E%3CDIV%3ENEED_EAP_COMMON%3Dy%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_DYNAMIC_EAP_METHODS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_dynamic_eap_methods%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-ldl%20-rdynamic%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_AP%3C%2FDIV%3E%3CDIV%3ENEED_EAP_COMMON%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_RSN_AUTHENTICATOR%3Dy%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ap%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20ap.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_radius%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_accounting%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_vlan%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fhostapd.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwpa_auth_glue.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Futils.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fauthsrv.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fap_config.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fsta_info.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Ftkip_countermeasures.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fap_mlme.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fieee802_1x.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feapol_auth%2Feapol_auth_sm.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fieee802_11_auth.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fieee802_11_shared.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fdrv_callbacks.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fap_drv_ops.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fbeacon.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fbss_load.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Feap_user_db.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fneighbor_db.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fieee802_11_ht.o%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_IEEE80211AC%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fieee802_11_vht.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_IEEE80211AX%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fieee802_11_he.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_IEEE80211BE%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fieee802_11_eht.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WNM_AP%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_wnm_ap%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwnm_ap.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_MBO%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fmbo_ap.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_FILS%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Ffils_hlp.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_CTRL_IFACE%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fctrl_iface_ap.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_server%20-deap_server_identity%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_server%2Feap_server.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_server%2Feap_server_identity.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_server%2Feap_server_methods.o%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_IEEE80211AC%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ieee80211ac%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_IEEE80211BE%3C%2FDIV%3E%3CDIV%3ECONFIG_IEEE80211AX%3Dy%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ieee80211be%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_IEEE80211AX%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ieee80211ax%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_AP_MLME%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwmm.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fap_list.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fcomeback_token.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fpasn%2Fpasn_responder.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fieee802_11.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fhw_features.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fdfs.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dneed_ap_mlme%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_server_wsc%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwps_hostapd.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_server%2Feap_server_wsc.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_DPP%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fdpp_hostapd.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fgas_query_ap.o%3C%2FDIV%3E%3CDIV%3ENEED_AP_GAS_SERV%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NAN_USD%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fnan_usd_ap.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERWORKING%3C%2FDIV%3E%3CDIV%3ENEED_AP_GAS_SERV%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_AP_GAS_SERV%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fgas_serv.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_HS20%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fhs20.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_MBO%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20mbo.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_mbo%3C%2FDIV%3E%3CDIV%3ENEED_GAS%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_RSN_AUTHENTICATOR%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_radius%3C%2FDIV%3E%3CDIV%3ENEED_AES_WRAP%3Dy%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwpa_auth.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwpa_auth_ie.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fpmksa_cache_auth.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_ACS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_acs%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Facs.o%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lm%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_PCSC%3C%2FDIV%3E%3CDIV%3E%23%20%E7%94%A8%E4%BA%8E%E6%99%BA%E8%83%BD%E5%8D%A1%EF%BC%88USIM%E3%80%81GSM%20SIM%EF%BC%89%E7%9A%84%20PC%2FSC%20%E6%8E%A5%E5%8F%A3%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dpcsc_funcs%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fpcsc_funcs.o%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NATIVE_WINDOWS%3C%2FDIV%3E%3CDIV%3E%23%E4%B8%80%E6%97%A6%20MinGW%20%E8%8E%B7%E5%BE%97%20WinScard%20%E6%94%AF%E6%8C%81%EF%BC%8C%E5%B0%B1%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20-lwinscard%20%E4%BB%A3%E6%9B%BF%3C%2FDIV%3E%3CDIV%3E%23%E7%8E%B0%E5%9C%A8%20pcsc_funcs.c%20%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E5%8A%A8%E6%80%81%E7%AC%A6%E5%8F%B7%E5%8A%A0%E8%BD%BD%3C%2FDIV%3E%3CDIV%3E%23LIBS%20%2B%3D%20-lwinscard%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20-I%2Fusr%2Finclude%2FPCSC%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_OSX%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-%E6%A1%86%E6%9E%B6%20PCSC%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20-I%2Fusr%2Finclude%2FPCSC%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20%24(shell%20%24(PKG_CONFIG)%20--libs%20libpcsclite)%3C%2FDIV%3E%3CDIV%3ECFLAGS%20%2B%3D%20%24(shell%20%24(PKG_CONFIG)%20--cflags%20libpcsclite)%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_SIM_SIMULATOR%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_sim_simulator%3C%2FDIV%3E%3CDIV%3ENEED_MILENAGE%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_USIM_SIMULATOR%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_usim_simulator%3C%2FDIV%3E%3CDIV%3ENEED_MILENAGE%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_MILENAGE%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fmilenage.o%3C%2FDIV%3E%3CDIV%3ENEED_AES_ENCBLOCK%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_PKCS12%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dpkcs12_funcs%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_SMARTCARD%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_smartcard%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_DRAGONFLY%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdragonfly.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20MS_FUNCS%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fms_funcs.o%3C%2FDIV%3E%3CDIV%3ENEED_DES%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_MD4%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CHAP%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_common%2Fchap.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20TLS_FUNCS%3C%2FDIV%3E%3CDIV%3ENEED_DES%3Dy%3C%2FDIV%3E%3CDIV%3E%23%20%E5%85%B1%E4%BA%AB%20TLS%20%E5%8A%9F%E8%83%BD%EF%BC%88EAP_TLS%E3%80%81EAP_PEAP%E3%80%81EAP_TTLS%E3%80%81EAP_FAST%20%E5%92%8C%3C%2FDIV%3E%3CDIV%3E%23%20EAP_TEAP)%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_tls_common.o%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_FIPS%3C%2FDIV%3E%3CDIV%3ENEED_TLS_PRF%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_SHA1%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_MD5%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_TLS%3C%2FDIV%3E%3CDIV%3ECONFIG_TLS%3Dopenssl%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_TLSV11%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_tlsv11%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_TLSV12%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_tlsv12%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_RADIUS_TLS%3C%2FDIV%3E%3CDIV%3ETLS_FUNCS%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_TLS)%2C%20wolfssl)%3C%2FDIV%3E%3CDIV%3Eifdef%20TLS_FUNCS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dwolfssl_der_load%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_wolfssl.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_wolfssl.o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_wolfssl.o%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_FIPS186_2_PRF%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ffips_prf_wolfssl.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ENEED_TLS_PRF_SHA256%3Dy%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lwolfssl%20-lm%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%2B%3D%20-lwolfssl%20-lm%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_TLS)%2C%20openssl)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dcrypto_rsa_oaep_sha256%3C%2FDIV%3E%3CDIV%3Eifdef%20TLS_FUNCS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_tls_openssl%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_openssl.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_openssl_ocsp.o%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lssl%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_openssl.o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_openssl.o%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_openssl.o%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_FIPS186_2_PRF%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ffips_prf_openssl.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ENEED_TLS_PRF_SHA256%3Dy%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lcrypto%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%2B%3D%20-lcrypto%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_TLS_ADD_DL%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-ldl%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%2B%3D%20-ldl%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_TLS_DEFAULT_CIPHERS%3C%2FDIV%3E%3CDIV%3Econfig_tls_default_ciphers%20%3D%22default%3A!exp%3A!low%22%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dtls_default_ciphers%3D%5C%22%24(config_tls_default_ciphers)%5C%22%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_TLS)%2C%20gnutls)%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_CRYPTO%3C%2FDIV%3E%3CDIV%3E%23%20%E9%BB%98%E8%AE%A4%E4%B8%BA%20libgcrypt%3C%2FDIV%3E%3CDIV%3ECONFIG_CRYPTO%3Dgnutls%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20TLS_FUNCS%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_gnutls.o%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lgnutls%20-lgpg-error%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_%24(CONFIG_CRYPTO).o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_%24(CONFIG_CRYPTO).o%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_%24(CONFIG_CRYPTO).o%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_FIPS186_2_PRF%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ffips_prf_internal.o%3C%2FDIV%3E%3CDIV%3ESHA1OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha1-internal.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_CRYPTO)%2C%20gnutls)%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lgcrypt%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%2B%3D%20-lgcrypt%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_RC4%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_DH_GROUP5%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_CRYPTO)%2C%20nettle)%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lnettle%20-lgmp%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%2B%3D%20-lnettle%20-lgmp%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_RC4%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_DH_GROUP5%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_TLS)%2C%20internal)%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_CRYPTO%3C%2FDIV%3E%3CDIV%3ECONFIG_CRYPTO%3D%20%E5%86%85%E9%83%A8%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20TLS_FUNCS%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_internal-rsa.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_internal.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_common.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_record.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_cred.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_client.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_client_write.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_client_read.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_client_ocsp.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Frsa.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fx509v3.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fpkcs1.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fpkcs5.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fpkcs8.o%3C%2FDIV%3E%3CDIV%3ENEED_ASN1%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_BASE64%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_TLS_PRF%3Dy%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_TLSV12%3C%2FDIV%3E%3CDIV%3ENEED_TLS_PRF_SHA256%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ENEED_MODEXP%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_CIPHER%3Dy%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_tls_internal_client%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_CIPHER%3C%2FDIV%3E%3CDIV%3ENEED_DES%3Dy%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_internal-cipher.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_MODEXP%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_internal-modexp.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fbignum.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_CRYPTO)%2C%20libtomcrypt)%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_libtomcrypt.o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_libtomcrypt.o%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-ltomcrypt%20-ltfm%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%2B%3D%20-ltomcrypt%20-ltfm%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_SHA256%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_RC4%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_DH_GROUP5%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_CRYPTO)%2C%20internal)%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_internal.o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_internal.o%3C%2FDIV%3E%3CDIV%3ENEED_AES_ENC%3Dy%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_crypto_internal%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERNAL_LIBTOMMATH%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_internal_libtommath%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERNAL_LIBTOMMATH_FAST%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dltm_fast%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-ltommath%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%2B%3D%20-ltommath%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_AES%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_DES%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_SHA1%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_MD4%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_MD5%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_SHA256%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_SHA384%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_SHA512%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_RC4%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_DH_GROUP5%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_CRYPTO)%2C%20cryptoapi)%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_cryptoapi.o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_cryptoapi.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_crypto_cryptoapi%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_SHA256%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_RC4%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_TLS)%2C%20linux)%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_linux.o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_linux.o%3C%2FDIV%3E%3CDIV%3Eifdef%20TLS_FUNCS%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_internal-rsa.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_internal.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_common.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_record.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_cred.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_client.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_client_write.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_client_read.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_client_ocsp.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Frsa.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fx509v3.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fpkcs1.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fpkcs5.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fpkcs8.o%3C%2FDIV%3E%3CDIV%3ENEED_ASN1%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_BASE64%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_TLS_PRF%3Dy%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_TLSV12%3C%2FDIV%3E%3CDIV%3ENEED_TLS_PRF_SHA256%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ENEED_MODEXP%3Dy%3C%2FDIV%3E%3CDIV%3ENEED_CIPHER%3Dy%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_tls_internal_client%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_MODEXP%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_internal-modexp.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fbignum.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_internal_libtommath%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dltm_fast%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_DH_GROUP5%3Dy%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_FIPS186_2_PRF%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ffips_prf_internal.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha1-internal.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_TLS)%2C%20none)%3C%2FDIV%3E%3CDIV%3Eifdef%20TLS_FUNCS%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_none.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-deap_tls_none%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_AES%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_SHA1%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_MD5%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_none.o%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_none.o%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_SHA256%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_RC4%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20TLS_FUNCS%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_SMARTCARD%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_NATIVE_WINDOWS%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_L2_PACKET)%2C%20freebsd)%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-ldl%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20TLS_FUNCS%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_none.o%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_TLS)%2C%20internal)%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_AES%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_SHA1%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_MD5%3Dy%3C%2FDIV%3E%3CDIV%3ECONFIG_INTERNAL_RC4%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EAESOBJS%20%3D%20%23%20%E7%9B%AE%E5%89%8D%E6%B2%A1%E6%9C%89%EF%BC%88%E8%A7%81%E4%B8%8B%E6%96%87%EF%BC%89%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERNAL_AES%3C%2FDIV%3E%3CDIV%3EAESOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-internal.o%20..%2Fsrc%2Fcrypto%2Faes-internal-dec.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20openssl)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)%3C%2FDIV%3E%3CDIV%3ENEED_INTERNAL_AES_WRAP%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_OPENSSL_INTERNAL_AES_WRAP%3C%2FDIV%3E%3CDIV%3E%23%20%E4%BC%BC%E4%B9%8E%E8%87%B3%E5%B0%91%E5%9C%A8%E4%BD%BF%E7%94%A8%20BoringSSL%20%E6%97%B6%E9%9C%80%E8%A6%81%E8%BF%99%E6%A0%B7%E5%81%9A%3C%2FDIV%3E%3CDIV%3ENEED_INTERNAL_AES_WRAP%3Dy%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_openssl_internal_aes_wrap%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_FIPS%3C%2FDIV%3E%3CDIV%3E%23%20%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%20AES%20%E5%AF%86%E9%92%A5%E5%B0%81%E8%A3%85%E4%BE%8B%E7%A8%8B%E6%89%8D%E8%83%BD%E4%BD%BF%E7%94%A8%20OpenSSL%20EVP%EF%BC%8C%E5%9B%A0%E4%B8%BA%3C%2FDIV%3E%3CDIV%3E%23%20OpenSSL%20AES_wrap_key()%2FAES_unwrap_key()%20API%20%E5%9C%A8%20FIPS%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%E4%B8%8D%E5%8F%AF%E7%94%A8%E3%80%82%3C%2FDIV%3E%3CDIV%3ENEED_INTERNAL_AES_WRAP%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_INTERNAL_AES_WRAP%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20linux)%3C%2FDIV%3E%3CDIV%3EAESOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-unwrap.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_AES_EAX%3C%2FDIV%3E%3CDIV%3EAESOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-eax.o%3C%2FDIV%3E%3CDIV%3ENEED_AES_CTR%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_AES_SIV%3C%2FDIV%3E%3CDIV%3EAESOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-siv.o%3C%2FDIV%3E%3CDIV%3ENEED_AES_CTR%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_AES_CTR%3C%2FDIV%3E%3CDIV%3EAESOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-ctr.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_AES_ENCBLOCK%3C%2FDIV%3E%3CDIV%3EAESOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-encblock.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ENEED_AES_ENC%3Dy%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20openssl)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20linux)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)%3C%2FDIV%3E%3CDIV%3EAESOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-omac1.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_AES_WRAP%3C%2FDIV%3E%3CDIV%3ENEED_AES_ENC%3Dy%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_INTERNAL_AES_WRAP%3C%2FDIV%3E%3CDIV%3EAESOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-wrap.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_AES_CBC%3C%2FDIV%3E%3CDIV%3ENEED_AES_ENC%3Dy%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20openssl)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20linux)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)%3C%2FDIV%3E%3CDIV%3EAESOBJS%20%2B%3D..%2Fsrc%2Fcrypto%2Faes-cbc.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_AES_ENC%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERNAL_AES%3C%2FDIV%3E%3CDIV%3EAESOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-internal-enc.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_AES%3C%2FDIV%3E%3CDIV%3Eobjs%20%2B%3D%20%24(aesobjs)%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_SHA1%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20openssl)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20linux)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20gnutls)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)%3C%2FDIV%3E%3CDIV%3ESHA1OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha1.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ESHA1OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha1-prf.o%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERNAL_SHA1%3C%2FDIV%3E%3CDIV%3ESHA1OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha1-internal.o%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_FIPS186_2_PRF%3C%2FDIV%3E%3CDIV%3ESHA1OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ffips_prf_internal.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_WPA_PASSPHRASE%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_pbkdf2%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20openssl)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)%3C%2FDIV%3E%3CDIV%3ESHA1OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha1-pbkdf2.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_T_PRF%3C%2FDIV%3E%3CDIV%3ESHA1OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha1-tprf.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_TLS_PRF%3C%2FDIV%3E%3CDIV%3ESHA1OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha1-tlsprf.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_FIPS%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20openssl)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20linux)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20gnutls)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)%3C%2FDIV%3E%3CDIV%3EMD5OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fmd5.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_MD5%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERNAL_MD5%3C%2FDIV%3E%3CDIV%3EMD5OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fmd5-internal.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eobjs%20%2B%3D%20%24(md5objs)%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20%24(MD5OBJS)%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20%24(MD5OBJS)%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_MD4%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERNAL_MD4%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fmd4-internal.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EDESOBJS%20%3D%20%23%20%E9%9D%9E%E5%86%85%E9%83%A8%E6%97%B6%E4%B8%8D%E9%9C%80%E8%A6%81%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_DES%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_FIPS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_des%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERNAL_DES%3C%2FDIV%3E%3CDIV%3EDESOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fdes-internal.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_RC4%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_rc4%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_RC4%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERNAL_RC4%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_NO_RC4%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Frc4.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_SAE%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_SHA384%3C%2FDIV%3E%3CDIV%3E%23%20%E5%A6%82%E6%9E%9C%E5%90%AF%E7%94%A8%E4%BA%86%20SHA384%EF%BC%8C%E8%BF%98%E9%9C%80%E8%A6%81%E6%B7%BB%E5%8A%A0%20HMAC-SHA384%20KDF%E3%80%82%3C%2FDIV%3E%3CDIV%3ENEED_HMAC_SHA384_KDF%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_SHA512%3C%2FDIV%3E%3CDIV%3E%23%20%E5%A6%82%E6%9E%9C%E5%90%AF%E7%94%A8%E4%BA%86%20SHA512%EF%BC%8C%E8%BF%98%E9%9C%80%E8%A6%81%E6%B7%BB%E5%8A%A0%20HMAC-SHA512%20KDF%E3%80%82%3C%2FDIV%3E%3CDIV%3ENEED_HMAC_SHA512_KDF%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ESHA256OBJS%20%3D%20%23%20%E9%BB%98%E8%AE%A4%E4%B8%BA%E6%97%A0%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_sha256%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20openssl)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20linux)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20gnutls)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)%3C%2FDIV%3E%3CDIV%3ESHA256OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3ESHA256OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256-prf.o%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERNAL_SHA256%3C%2FDIV%3E%3CDIV%3ESHA256OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256-internal.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERNAL_SHA384%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_internal_sha384%3C%2FDIV%3E%3CDIV%3ESHA256OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha384-internal.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERNAL_SHA512%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_internal_sha512%3C%2FDIV%3E%3CDIV%3ESHA256OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha512-internal.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_TLS_PRF_SHA256%3C%2FDIV%3E%3CDIV%3ESHA256OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256-tlsprf.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_TLS_PRF_SHA384%3C%2FDIV%3E%3CDIV%3ESHA256OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha384-tlsprf.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_HMAC_SHA256_KDF%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_hmac_sha256_kdf%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256-kdf.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_HMAC_SHA384_KDF%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_hmac_sha384_kdf%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha384-kdf.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_HMAC_SHA512_KDF%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_hmac_sha512_kdf%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha512-kdf.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eobjs%20%2B%3D%20%24(sha256objs)%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_SHA384%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20openssl)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20linux)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20gnutls)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha384.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_sha384%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha384-prf.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_SHA512%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20openssl)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20linux)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20gnutls)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha512.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_sha512%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha512-prf.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_ASN1%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fasn1.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_DH_GROUPS%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fdh_groups.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_DH_GROUPS_ALL%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dall_dh_groups%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_INTERNAL_DH_GROUP5%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_DH_GROUPS%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fdh_group5.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_ECC%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ecc%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_RANDOM_POOL%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_random_pool%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_GETRANDOM%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_getrandom%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Frandom.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_CTRL_IFACE%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_CTRL_IFACE)%2C%20y)%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NATIVE_WINDOWS%3C%2FDIV%3E%3CDIV%3ECONFIG_CTRL_IFACE%3Dnamed_pipe%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3ECONFIG_CTRL_IFACE%3Dunix%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ctrl_iface%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_CTRL_IFACE)%2C%20unix)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ctrl_iface_unix%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fctrl_iface_common.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_CTRL_IFACE)%2C%20udp)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ctrl_iface_udp%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_CTRL_IFACE)%2C%20udp6)%3C%2FDIV%3E%3CDIV%3ECONFIG_CTRL_IFACE%3Dudp%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ctrl_iface_udp%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ctrl_iface_udp_ipv6%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_CTRL_IFACE)%2C%20named_pipe)%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ctrl_iface_named_pipe%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_CTRL_IFACE)%2C%20udp-remote)%3C%2FDIV%3E%3CDIV%3ECONFIG_CTRL_IFACE%3Dudp%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ctrl_iface_udp%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ctrl_iface_udp_remote%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_CTRL_IFACE)%2C%20udp6-remote)%3C%2FDIV%3E%3CDIV%3ECONFIG_CTRL_IFACE%3Dudp%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ctrl_iface_udp%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ctrl_iface_udp_remote%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ctrl_iface_udp_ipv6%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20ctrl_iface.octrl_iface_%24(CONFIG_CTRL_IFACE).o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_CTRL_IFACE_DBUS_NEW%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ctrl_iface_dbus_new%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20dbus%2Fdbus_dict_helpers.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20dbus%2Fdbus_new_helpers.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20dbus%2Fdbus_new.odbus%2Fdbus_new_handlers.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20dbus%2Fdbus_common.o%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPS%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20dbus%2Fdbus_new_handlers_wps.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_P2P%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20dbus%2Fdbus_new_handlers_p2p.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifndef%20DBUS_LIBS%3C%2FDIV%3E%3CDIV%3EDBUS_LIBS%20%3A%3D%20%24(shell%20%24(PKG_CONFIG)%20--libs%20dbus-1)%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifndef%20DBUS_INCLUDE%3C%2FDIV%3E%3CDIV%3EDBUS_INCLUDE%20%3A%3D%20%24(shell%20%24(PKG_CONFIG)%20--cflags%20dbus-1)%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_CTRL_IFACE_DBUS_INTRO%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20dbus%2Fdbus_new_introspect.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ctrl_iface_dbus_intro%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20%24(dbus_include)%3C%2FDIV%3E%3CDIV%3Elibs%20%2B%3D%20%24(dbus_libs)%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_READLINE%3C%2FDIV%3E%3CDIV%3EOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2Fedit_readline.o%3C%2FDIV%3E%3CDIV%3ELIBS_c%20%2B%3D%20-lreadline%20-lncurses%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPA_CLI_EDIT%3C%2FDIV%3E%3CDIV%3EOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2Fedit.o%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3EOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2Fedit_simple.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NATIVE_WINDOWS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_native_windows%3C%2FDIV%3E%3CDIV%3ELIBS%20%2B%3D%20-lws2_32%20-lgdi32%20-lcrypt32%3C%2FDIV%3E%3CDIV%3ELIBS_c%20%2B%3D%20-lws2_32%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%2B%3D%20-lws2_32%20-lgdi32%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_CRYPTO)%2C%20cryptoapi)%3C%2FDIV%3E%3CDIV%3ELIBS_p%20%2B%3D%20-lcrypt32%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_STDOUT_DEBUG%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_stdout_debug%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_CTRL_IFACE%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_wpa_msg%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_IPV6%3C%2FDIV%3E%3CDIV%3E%23%20%E4%BB%85%E7%94%A8%E4%BA%8E%20eapol_test%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ipv6%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_LINUX_PACKET_SOCKET_WAR%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_linux_packet_socket_war%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_BASE64%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fbase64.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_SME%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20sme.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_sme%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fieee802_11_common.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fhw_features_common.o%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_EAP_COMMON%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Feap_common%2Feap_common.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_MAIN%3C%2FDIV%3E%3CDIV%3ECONFIG_MAIN%3Dmain%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_DEBUG_SYSLOG%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_debug_syslog%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_DEBUG_SYSLOG_FACILITY%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dlog_hostapd%3D%22%24(config_debug_syslog_facility)%22%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_DEBUG_LINUX_TRACING%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_debug_linux_tracing%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_DEBUG_FILE%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_debug_file%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_DELAYED_MIC_ERROR_REPORT%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_delayed_mic_error_report%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_FIPS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_fips%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20openssl)%3C%2FDIV%3E%3CDIV%3Eifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)%3C%2FDIV%3E%3CDIV%3E%24(error%20CONFIG_FIPS%3Dy%20requires%20CONFIG_TLS%3Dopenssl)%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eobjs%20%2B%3D%20%24(sha1objs)%20%24(desobjs)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20%24(SHA1OBJS)%3C%2FDIV%3E%3CDIV%3EOBJS_p%20%2B%3D%20%24(SHA256OBJS)%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20%24(SHA1OBJS)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_BGSCAN_SIMPLE%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_bgscan_simple%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20bgscan_simple.o%3C%2FDIV%3E%3CDIV%3ENEED_BGSCAN%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_BGSCAN_LEARN%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_bgscan_learn%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20bgscan_learn.o%3C%2FDIV%3E%3CDIV%3ENEED_BGSCAN%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_BGSCAN%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_bgscan%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20bgscan.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_AUTOSCAN_EXPONENTIAL%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_autoscan_exponential%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20autoscan_exponential.o%3C%2FDIV%3E%3CDIV%3ENEED_AUTOSCAN%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_AUTOSCAN_PERIODIC%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_autoscan_periodic%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20autoscan_periodic.o%3C%2FDIV%3E%3CDIV%3ENEED_AUTOSCAN%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_AUTOSCAN%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_autoscan%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20autoscan.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EXT_PASSWORD_TEST%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fext_password_test.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ext_password_test%3C%2FDIV%3E%3CDIV%3ENEED_EXT_PASSWORD%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EXT_PASSWORD_FILE%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fext_password_file.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ext_password_file%3C%2FDIV%3E%3CDIV%3ENEED_EXT_PASSWORD%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_EXT_PASSWORD%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fext_password.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ext_password%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_GAS_SERVER%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fgas_server.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_gas_server%3C%2FDIV%3E%3CDIV%3ENEED_GAS%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_GAS%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fgas.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20gas_query.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_gas%3C%2FDIV%3E%3CDIV%3ENEED_OFFCHANNEL%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_OFFCHANNEL%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20offchannel.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_offchannel%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_JSON%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fjson.o%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_json%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_MODULE_TESTS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_module_tests%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20wpas_module_tests.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Futils_module_tests.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fcommon_module_tests.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_module_tests.o%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPS%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_module_tests.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fdrivers%2Fdriver_common.o%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20..%2Fsrc%2Fdrivers%2Fdriver_common.o%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20wpa_supplicant.o%E4%BA%8B%E4%BB%B6.obssid_ignore.owpas_glue.o%E6%89%AB%E6%8F%8F.o%3C%2FDIV%3E%3CDIV%3EOBJS_t%20%3A%3D%20%24(OBJS)%20%24(OBJS_l2)%20eapol_test.o%3C%2FDIV%3E%3CDIV%3EOBJS_t%20%2B%3D%20..%2Fsrc%2Fradius%2Fradius_client.o%3C%2FDIV%3E%3CDIV%3EOBJS_t%20%2B%3D%20..%2Fsrc%2Fradius%2Fradius.o%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_RADIUS_TLS%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_radius_tls%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EOBJS_t2%20%3A%3D%20%24(OBJS)%20%24(OBJS_l2)%20preauth_test.o%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EOBJS_nfc%20%3A%3D%20%24(OBJS)%20%24(OBJS_l2)%20nfc_pw_token.o%3C%2FDIV%3E%3CDIV%3EOBJS_nfc%20%2B%3D%20%24(OBJS_d)%20..%2Fsrc%2Fdrivers%2Fdrivers.o%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20%24(CONFIG_MAIN).o%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_PRIVSEP%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20%24(OBJS_d)%20..%2Fsrc%2Fdrivers%2Fdrivers.o%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20%24(OBJS_l2)%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20..%2Fsrc%2Futils%2Fos_%24(CONFIG_OS).o%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20..%2Fsrc%2Futils%2F%24(CONFIG_ELOOP).o%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20..%2Fsrc%2Futils%2Fcommon.o%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20..%2Fsrc%2Futils%2Fwpa_debug.o%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20..%2Fsrc%2Futils%2Fwpabuf.o%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20wpa_priv.o%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_DRIVER_NL80211%3C%2FDIV%3E%3CDIV%3EOBJS_priv%20%2B%3D%20..%2Fsrc%2Fcommon%2Fieee802_11_common.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fl2_packet%2Fl2_packet_privsep.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fdrivers%2Fdriver_privsep.o%3C%2FDIV%3E%3CDIV%3EEXTRA_progs%20%2B%3D%20wpa_priv%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20%24(OBJS_d)%20..%2Fsrc%2Fdrivers%2Fdrivers.o%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20%24(OBJS_l2)%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NDIS_EVENTS_INTEGRATED%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_ndis_events_integrated%3C%2FDIV%3E%3CDIV%3EOBJS%20%2B%3D%20..%2Fsrc%2Fdrivers%2Fndis_events.o%3C%2FDIV%3E%3CDIV%3EEXTRALIBS%20%2B%3D%20-loleaut32%20-lole32%20-luuid%3C%2FDIV%3E%3CDIV%3Eifdef%20PLATFORMSDKLIB%3C%2FDIV%3E%3CDIV%3EEXTRALIBS%20%2B%3D%20%24(PLATFORMSDKLIB)%2FWbemUuid.Lib%3C%2FDIV%3E%3CDIV%3Eelse%3C%2FDIV%3E%3CDIV%3EEXTRALIBS%20%2B%3D%20WbemUuid.Lib%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_FST%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_fst%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_FST_TEST%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_fst_test%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3EFST_OBJS%20%2B%3D%20..%2Fsrc%2Ffst%2Ffst.o%3C%2FDIV%3E%3CDIV%3EFST_OBJS%20%2B%3D%20..%2Fsrc%2Ffst%2Ffst_session.o%3C%2FDIV%3E%3CDIV%3EFST_OBJS%20%2B%3D%20..%2Fsrc%2Ffst%2Ffst_iface.o%3C%2FDIV%3E%3CDIV%3EFST_OBJS%20%2B%3D%20..%2Fsrc%2Ffst%2Ffst_group.o%3C%2FDIV%3E%3CDIV%3EFST_OBJS%20%2B%3D%20..%2Fsrc%2Ffst%2Ffst_ctrl_aux.o%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_CTRL_IFACE%3C%2FDIV%3E%3CDIV%3EFST_OBJS%20%2B%3D%20..%2Fsrc%2Ffst%2Ffst_ctrl_iface.o%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eobjs%20%2B%3D%20%24(fst_objs)%3C%2FDIV%3E%3CDIV%3EOBJS_t%20%2B%3D%20%24(FST_OBJS)%3C%2FDIV%3E%3CDIV%3EOBJS_t2%20%2B%3D%20%24(FST_OBJS)%3C%2FDIV%3E%3CDIV%3EOBJS_nfc%20%2B%3D%20%24(FST_OBJS)%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WEP%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_wep%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_NO_TKIP%3C%2FDIV%3E%3CDIV%3Ecflags%20%2B%3D%20-dconfig_noo_tkip%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Edynamic_eap_methods%3A%20%24(EAPDYN)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E_OBJS_VAR%20%3A%3D%20OBJS_priv%3C%2FDIV%3E%3CDIV%3Einclude%20..%2Fsrc%2Fobjs.mk%3C%2FDIV%3E%3CDIV%3Ewpa_priv%3A%20%24(BCHECK)%20%24(OBJS_priv)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24%20(Q)%20%24%20(LDO)%20%24%20(LDFLAGS)-o%20wpa_priv%20%24%20(objs_PRIV)%20%24%20(LIBS)%20%24%20(LIBS)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(E)%22%20LD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E_objs_var%20%3A%3D%20objs%3C%2FDIV%3E%3CDIV%3Einclude%20..%2Fsrc%2Fobjs.mk%3C%2FDIV%3E%3CDIV%3Ewpa_supplicant%3A%20%24(BCHECK)%20%24(OBJS)%20%24(EXTRA_progs)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24%20(Q)%20%24%20(LDO)%20%24%20(LDFLAGS)-o%20wpa_supplicant%20%24%20(OBJS)%20%24%20(LIBS)%20%24%20(LIBS)%20%24%20(EXTRALIBS)%20%24%20(EXTRALIBS)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(E)%22%20LD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E_OBJS_VAR%20%3A%3D%20OBJS_t%3C%2FDIV%3E%3CDIV%3Einclude%20..%2Fsrc%2Fobjs.mk%3C%2FDIV%3E%3CDIV%3Eeapol_test%3A%20%24(OBJS_t)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24%20(Q)%20%24%20(LDO)%20%24%20(LDFLAGS)-o%20eapol_test%20%24%20(OBJS_T)%20%24%20(LIBS)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(E)%22%20LD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E_OBJS_VAR%20%3A%3D%20OBJS_t2%3C%2FDIV%3E%3CDIV%3Einclude%20..%2Fsrc%2Fobjs.mk%3C%2FDIV%3E%3CDIV%3Epreauth_test%3A%20%24(OBJS_t2)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24%20(Q)%20%24%20(LDO)%20%24%20(LDFLAGS)-o%20preauth_test%20%24%20(objs_t2)%20%24%20(LIBS)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(E)%22%20LD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E_OBJS_VAR%20%3A%3D%20OBJS_p%3C%2FDIV%3E%3CDIV%3Einclude%20..%2Fsrc%2Fobjs.mk%3C%2FDIV%3E%3CDIV%3Ewpa_passphrase%3A%20%24(OBJS_p)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24%20(Q)%20%24%20(LDO)%20%24%20(LDFLAGS)-o%20wpa_passphrase%20%24%20(objs_P)%20%24%20(libs_P)%20%24%20(libs_P)%20%24%20(LIBS)%20%24%20(LIBS)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(E)%22%20LD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E_OBJS_VAR%20%3A%3D%20OBJS_c%3C%2FDIV%3E%3CDIV%3Einclude%20..%2Fsrc%2Fobjs.mk%3C%2FDIV%3E%3CDIV%3Ewpa_cli%3A%20%24(OBJS_c)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%E4%BD%8E%E5%8E%8B%E5%B7%AE%E7%BA%BF%E6%80%A7%E7%A8%B3%E5%8E%8B%E5%99%A8%5C(LDO%5C)%20%24(LDFLAGS)%20-o%20wpa_cli%20%24(OBJS_c)%20%24(LIBS_c)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(E)%22%20LD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ELIBCTRL%20%2B%3D%20..%2Fsrc%2Fcommon%2Fwpa_ctrl.o%3C%2FDIV%3E%3CDIV%3ELIBCTRL%20%2B%3D%20..%2Fsrc%2Futils%2Fos_%24(CONFIG_OS).o%3C%2FDIV%3E%3CDIV%3ELIBCTRL%20%2B%3D%20..%2Fsrc%2Futils%2Fcommon.o%3C%2FDIV%3E%3CDIV%3ELIBCTRL%20%2B%3D%20..%2Fsrc%2Futils%2Fwpa_debug.o%3C%2FDIV%3E%3CDIV%3ELIBCTRLSO%20%2B%3D%20..%2Fsrc%2Fcommon%2Fwpa_ctrl.c%3C%2FDIV%3E%3CDIV%3ELIBCTRLSO%20%2B%3D%20..%2Fsrc%2Futils%2Fos_%24(CONFIG_OS).c%3C%2FDIV%3E%3CDIV%3ELIBCTRLSO%20%2B%3D%20..%2Fsrc%2Futils%2Fcommon.c%3C%2FDIV%3E%3CDIV%3ELIBCTRLSO%20%2B%3D%20..%2Fsrc%2Futils%2Fwpa_debug.c%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E_objs_var%20%3A%3D%20libctrl%3C%2FDIV%3E%3CDIV%3Einclude%20..%2Fsrc%2Fobjs.mk%3C%2FDIV%3E%3CDIV%3Elibwpa_client.a%3A%20%24(LIBCTRL)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)rm%20-f%20%24%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(AR)%20crs%20%24%40%20%24%3F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(E)%22%20AR%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elibwpa_client.so%3A%20%24(LIBCTRLSO)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(e)%22%20cc%20%24%40%20(%24%5E)%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-fPIC%20%24%5E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EOBJS_wpatest%20%3A%3D%20libwpa_test.o%3C%2FDIV%3E%3CDIV%3E_OBJS_VAR%20%3A%3D%20OBJS_wpatest%3C%2FDIV%3E%3CDIV%3Einclude%20..%2Fsrc%2Fobjs.mk%3C%2FDIV%3E%3CDIV%3Elibwpa_test1%3A%20%24(OBJS_wpatest)%20libwpa_client.a%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(%E4%BD%8E%E5%8E%8B%E5%B7%AE%E7%BA%BF%E6%80%A7%E7%A8%B3%E5%8E%8B%E5%99%A8%5C%5C(LDO%5C%5C))%20%24(LDFLAGS)%20-o%20libwpa_test1%20%24(OBJS_wpatest)%20libwpa_client.a%20%24(LIBS_c)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(E)%22%20LD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elibwpa_test2%3A%20%24(OBJS_wpatest)%20libwpa_client.so%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(%E4%BD%8E%E5%8E%8B%E5%B7%AE%E7%BA%BF%E6%80%A7%E7%A8%B3%E5%8E%8B%E5%99%A8(LDO))%20%24(LDFLAGS)%20-o%20libwpa_test2%20%24(OBJS_wpatest)%20-L.-lwpa_client%20%24(LIBS_c)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(E)%22%20LD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E_OBJS_VAR%20%3A%3D%20OBJS_nfc%3C%2FDIV%3E%3CDIV%3Einclude%20..%2Fsrc%2Fobjs.mk%3C%2FDIV%3E%3CDIV%3Enfc_pw_token%3A%20%24(OBJS_nfc)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24%20(Q)%20%24%20(LDO)%20%24%20(LDFLAGS)-o%20nfc_pw_token%20%24%20(objs_NFC)%20%24%20(LIBS)%20%24%20(LIBS)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(E)%22%20LD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ewin_if_list%3A%20win_if_list.c%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24%20(Q)%20%24%20(LDO)%20%24%20(LDFLAGS)-o%20%24%40%20win_if_list.c%24(CFLAGS)%20%24(LIBS_w)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(E)%22%20LD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eeap_psk.so%3A%20%24(SRC_EAP_PSK)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-Deap_peer_psk_register%3Deap_peer_method_dynamic_init%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(e)%22%20CC%2FLD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eeap_pax.so%3A%20%24(SRC_EAP_PAX)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(e)%22%20CC%2FLD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eeap_peap.so%EF%BC%9A%24(src_eap_peap)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(e)%22%20CC%2FLD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eeap_sake.so%EF%BC%9A%24(src_eap_sake)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(e)%22%20CC%2FLD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eeap_ikev2.so%EF%BC%9A%24(src_eap_ikev2)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(e)%22%20CC%2FLD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eeap_eke.so%3A%20%24(SRC_EAP_EKE)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(e)%22%20CC%2FLD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eeap_mschapv2.so%EF%BC%9A%24(src_eap_mschapv2)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(e)%22%20CC%2FLD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eeap_fast.so%EF%BC%9A%24(src_eap_fast)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(e)%22%20CC%2FLD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eeap_teap.so%EF%BC%9A%24(src_eap_teap)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(e)%22%20CC%2FLD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eeap_gpsk.so%EF%BC%9A%24(src_eap_gpsk)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(e)%22%20CC%2FLD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%25.so%3A%20..%2Fsrc%2Feap_peer%2F%25.c%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%26lt%3B%20%5C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-D%24(*F%3Aeap_%25%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(e)%22%20CC%2FLD%22%20%24%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%25.service%3A%25.service.in%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)sed%20-e%20's%7C%5C%40BINDIR%5C%40%7C%24(BINDIR)%7Cg'%20%24%26lt%3B%20%26gt%3B%20%24%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(E)%22%20sed%22%20%24%26lt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%25%40.service%3A%25.service.arg.in%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)sed%20-e%20's%7C%5C%40BINDIR%5C%40%7C%24(BINDIR)%7Cg'%20%24%26lt%3B%20%26gt%3B%20%24%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(E)%22%20sed%22%20%24%26lt%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ewpa_supplicant.exe%EF%BC%9Awpa_supplicant%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emv%20-f%20%24%26lt%3B%20%24%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Ewpa_cli.exe%3A%20wpa_cli%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emv%20-f%20%24%26lt%3B%20%24%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Ewpa_passphrase.exe%EF%BC%9Awpa_passphrase%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emv%20-f%20%24%26lt%3B%20%24%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Ewin_if_list.exe%EF%BC%9Awin_if_list%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emv%20-f%20%24%26lt%3B%20%24%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Eeapol_test.exe%3A%20eapol_test%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emv%20-f%20%24%26lt%3B%20%24%40%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EWINALL%3Dwpa_supplicant.exe%20wpa_cli.exe%20wpa_passphrase.exe%20win_if_list.exe%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ewindows-bin%3A%20%24(WINALL)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(%E5%89%A5%E7%A6%BB)%20%24(winall)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ewpa_gui%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F3933%22%20target%3D%22_blank%22%3E%40echo%3C%2FA%3E%20%22wpa_gui%20%E5%B7%B2%E8%A2%AB%E7%A7%BB%E9%99%A4%20-%20%E8%AF%B7%E5%8F%82%E9%98%85%20wpa_gui-qt4%20%E4%BB%A5%E8%BF%9B%E8%A1%8C%E6%9B%BF%E6%8D%A2%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ewpa_gui-qt4%2FMakefile%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eqmake%20-o%20wpa_gui-qt4%2FMakefile%20wpa_gui-qt4%2Fwpa_gui.pro%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ewpa_gui-qt4%2Flang%2Fwpa_gui_de.qm%3A%20wpa_gui-qt4%2Flang%2Fwpa_gui_de.ts%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Elrelease%20wpa_gui-qt4%2Fwpa_gui.pro%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ewpa_gui-qt4%3A%20wpa_gui-qt4%2FMakefile%20wpa_gui-qt4%2Flang%2Fwpa_gui_de.qm%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(MAKE)%20-C%20wpa_gui-qt4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EFIPSDIR%3D%2Fusr%2Flocal%2Fssl%2Ffips-2.0%3C%2FDIV%3E%3CDIV%3EFIPSLD%3D%24(FIPSDIR)%2Fbin%2Ffipsld%3C%2FDIV%3E%3CDIV%3Efips%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(make)%20cc%3D%24(fipsld)%20fipsld_cc%3D%22%24(cc)%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E.PHONY%3A%20lcov-html%3C%2FDIV%3E%3CDIV%3Elcov-html%EF%BC%9A%24(call%20BUILDOBJ%2Cwpa_supplicant.gcda)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Elcov%20-c%20-d%20%24(BUILDDIR)%26gt%3B%20lcov.info%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Egenhtml%20lcov.info%20--output-directory%20lcov-html%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Epasn_cflags%20%3A%3D%20%24(cflags)%3C%2FDIV%3E%3CDIV%3Epasn_cflags%20%2B%3D%20-dconfig_pasn%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%3A%3D%20..%2Fsrc%2Futils%2F%24(CONFIG_ELOOP).c%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Fwpa_debug.c%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Fwpabuf.c%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Fos_%24(CONFIG_OS).c%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Fconfig.c%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Fcommon.c%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_BASE64%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Fbase64.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_WPA_TRACE%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EXT_PASSWORD_FILE%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Fext_password_file.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_EXT_PASSWORD_TEST%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Fext_password_test.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_EXT_PASSWORD%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Fext_password.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_SAE%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcommon%2Fsae.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_SAE_PK%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcommon%2Fsae_pk.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_NO_WPA%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcommon%2Fwpa_common.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcommon%2Fieee802_11_common.c%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_DRAGONFLY%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdragonfly.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcommon%2Fptksa_cache.c%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Frsn_supp%2Fpmksa_cache.c%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifndef%20CONFIG_NO_WPA%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Frsn_supp%2Fwpa_ie.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fap%2Fcomeback_token.c%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fap%2Fpmksa_cache_auth.c%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_EAP_COMMON%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Feap_common%2Feap_common.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CHAP%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Feap_common%2Fchap.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20CONFIG_IEEE8021X_EAPOL%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap.c%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_methods.c%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Feapol_supp%2Feapol_supp_sm.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_TLS)%2C%20wolfssl)%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_wolfssl.c%3C%2FDIV%3E%3CDIV%3Eifdef%20TLS_FUNCS%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_wolfssl.c%3C%2FDIV%3E%3CDIV%3ENEED_TLS_PRF_SHA256%3Dy%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20-lwolfssl%20-lm%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_TLS)%2C%20openssl)%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_openssl.c%3C%2FDIV%3E%3CDIV%3Eifdef%20TLS_FUNCS%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_openssl.c%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20-lssl%20-lcrypto%3C%2FDIV%3E%3CDIV%3ENEED_TLS_PRF_SHA256%3Dy%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifeq%20(%24(CONFIG_TLS)%2C%20gnutls)%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_%24(CONFIG_CRYPTO).c%3C%2FDIV%3E%3CDIV%3Eifdef%20TLS_FUNCS%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_gnutls.c%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20-lgnutls%20-lgpg-error%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20-lgcrypt%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_TLS_PRF_SHA256%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256-tlsprf.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_SHA512%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha512-prf.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_SHA384%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha384-prf.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256-prf.c%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_HMAC_SHA512_KDF%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha512-kdf.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_HMAC_SHA384_KDF%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha384-kdf.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_HMAC_SHA256_KDF%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256-kdf.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_DH_GROUPS%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fdh_groups.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_AES_SIV%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-siv.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_AES_CTR%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-ctr.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_SHA1%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha1-prf.c%3C%2FDIV%3E%3CDIV%3Eifdef%20NEED_TLS_PRF%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha1-tlsprf.c%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3Eendif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fpasn%2Fpasn_initiator.c%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fpasn%2Fpasn_responder.c%3C%2FDIV%3E%3CDIV%3ELIBPASNSO%20%2B%3D%20..%2Fsrc%2Fpasn%2Fpasn_common.c%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elibpasn.so%3A%20%24(LIBPASNSO)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%40%24(e)%22%20cc%20%24%40%20(%24%5E)%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(PASN_CFLAGS)%20-shared%20-fPIC%20-lcrypto%20%24%5E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%B8%85%E6%B4%81%EF%BC%9A%E6%99%AE%E9%80%9A%E6%B8%85%E6%B4%81%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(MAKE)%20-C%20..%2Fsrc%20clean%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%24(MAKE)%20-C%20dbus%20clean%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Erm%20-f%20core%20*~%20*.o%20*.d%20*.gcno%20*.gcda%20*.gcov%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Erm%20-f%20eap_*.so%24(WINALL)%20eapol_test%20preauth_test%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Erm%20-f%20wpa_priv%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Erm%20-f%20nfc_pw_token%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Erm%20-f%20lcov.info%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Erm%20-rf%20lcov-html%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Erm%20-f%20libwpa_client.a%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Erm%20-f%20libpasn.so%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Erm%20-f%20libwpa_client.so%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Erm%20-f%20libwpa_test1%20libwpa_test2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Erm%20-f%20wpa_passphrase%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3EBINALL%3Dwpa_supplicant%20wpa_cli%20ALL%20%3D%20%24(BINALL)ALL%20%2B%3D%20systemd%2Fwpa_supplicant.serviceALL%20%2B%3D%20systemd%2Fwpa_supplicant%40.serviceALL%20%2B%3D%20systemd%2Fwpa_supplicant-nl80211%40.serviceALL%2B%3D%20systemd%2Fwpa_supplicant-wired%40.serviceALL%2B%3D%20dbus%2Ffi.w1.wpa_supplicant1.service%20EXTRA_TARGETS%3Ddynamic_eap_methods%20CONFIG_FILE%3D.configinclude..%2Fsrc%2F%E7%89%88%E6%9C%AC.ruleifdef%20CONFIG_BUILD_PASN_SO%23%20%E4%BB%A5%E8%BF%99%E7%A7%8D%E6%96%B9%E5%BC%8F%E6%B7%BB%E5%8A%A0%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%EF%BC%8C%E5%85%81%E8%AE%B8%E5%9C%A8%20build.rules_all%20%E8%AF%BB%E5%8F%96%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%AD%E8%AE%BE%E7%BD%AE%20CONFIG_BUILD_PASN_SO%23%EF%BC%9Alibpasn.soendif%20ifdef%20CONFIG_BUILD_WPA_CLIENT_SO%23%20%E4%BB%A5%E8%BF%99%E7%A7%8D%E6%96%B9%E5%BC%8F%E6%B7%BB%E5%8A%A0%E4%BE%9D%E8%B5%96%E5%85%B3%E7%B3%BB%EF%BC%8C%E4%BB%A5%E5%85%81%E8%AE%B8%E5%9C%A8%20build.rules_all%20%E8%AF%BB%E5%8F%96%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%AD%E8%AE%BE%E7%BD%AE%20CONFIG_BUILD_WPA_CLIENT_SO%23%EF%BC%9Alibwpa_client.soendif%20ifndef%20CONFIG_NO_WPA_PASSPHRASE%20%23%20%E4%BB%A5%E8%BF%99%E7%A7%8D%E6%96%B9%E5%BC%8F%E6%B7%BB%E5%8A%A0%E4%BE%9D%E8%B5%96%E9%A1%B9%E4%BB%A5%E5%85%81%E8%AE%B8%E5%9C%A8%20build.rules_all%20%E8%AF%BB%E5%8F%96%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%AD%E8%AE%BE%E7%BD%AE%20CONFIG_NO_WPA_PASSPHRASE%20%23%EF%BC%9Awpa_passphraseendif%20ifdef%20LIBS%23%20%E5%A6%82%E6%9E%9C%20LIBS%20%E8%AE%BE%E7%BD%AE%E4%BA%86%E6%9F%90%E4%BA%9B%E5%85%A8%E5%B1%80%E7%89%88%E6%9C%AC%E7%B3%BB%E7%BB%9F%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%8C%E8%AF%B7%E5%85%8B%E9%9A%86%20%23%20libs_C%20%E5%92%8C%20libs_P%20%E7%9A%84%E9%82%A3%E4%BA%9B%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%8C%E4%BD%BF%E5%85%B6%E4%B9%9F%E6%B6%B5%E7%9B%96%20wpa_passphrase%20%E5%92%8C%20wpa_cli%E3%80%82ifndef%20libs_clibs_C%3A%20%3D%20%24%20(LIBS)%20endifndef%20libs_p%3A%20%3D%20%24%20(LIBS)%20endiffndef%20libs_p%3A%20%3D%20%24%20(LIBS)%20endiffndef%20libs_p%3A%20%3D%20%24%20(LIBS)%20endiffndef%20libs_p%3A%20%3D%20%24%20(LIBS)%20endiffnd%E5%AF%BC%E5%87%BA%20libdir%EF%BC%9F%3D%20%2Fusr%2Flocal%2Flibexport%20INCDIR%EF%BC%9F%3D%20%2Fusr%2Flocal%2Fincludeexport%20BINDIR%EF%BC%9F%3D%20%2Fusr%2Flocal%2Fsbinpkg_config%EF%BC%9F%3D%20pkg-config%20CFLAGS%20%2B%3D%20%24%20(EXTRA_CFLAGS)%20CFLAGS%20%2B%3D-I%24%20(abspath..%2Fsrc)%20CFLAGS%20%2B%3D-I%24%20(abspath..%2Fsrc%2Futils)%20CC%3D%24%20(CROSS_COMPILE)%20gcc%20%23libnl%20libcFLAGS%20%2B%3D-i%2FHOME%2FERIC%2Fwork%2FThirdpartyUtils%2Fwpa_supplicant%2Flibnl-3.11.0%2F_install%2Finclude%2Finclude%2Flibnl3liflags%20%2B%3D-i%2Fhome%2Feric%2Fwork%2FThirdpartyUtils%2FWPA_supplicant%2Flibnl3liflags%20%2B%3D-i%2Fhome%2Feric%2Fwork%2FThirdpartyUtils%2FWPA_supbs%20%2B%3D-L%2FHOME%2FERIC%2FWork%2FThirdpartyUtils%2Fwork%2FThirdpartyUtils%2Fwork%2FThirdpartyUtils%2Fwork%2Fwork%2Fwork%2Fwork%2FThirdpartyUtils%2FWPA_Supplicant%2Flibnl-3.11.0%2F_install%2Flib%20%23openssl%20libcFlags%20%2B%3D-i%2FHOME%2FERIC%2FWork%2FThirdpartyUtils%2Fwork%2FThirdpartyUtils%2FWPA_Supplicant%2Flib%20libcFlags%20%2B%3D-i%2Fant%2FopenSSL-3.5.0%2F_install%2FincludeLibs%20%2B%3D-L%2FHOME%2FERIC%2FWork%2FThirdpartyUtils%2FWPA_Supplicant%2FOpenSSL-3.5.0%2F_install%2Fliblibs_P%20%2B%3D-L%2FHOME%2FERIC%2FWork%2FThirdpartyUtils%2Fwpa_supplicant%2FopenSSL-3.5.0%2F_install%2FlibldFlags%20%2B%3D-lm%20home%2Feric%2Fwork%2FThirdpartyUtils%2Fopensl-3.5.0%2F_install%2FlibldFlags%20%2B%3D-lm%20ifndef%20CONFIG_NO_NO_FLAGS%20%2B%3D-lm%20ifndef%20CONFIG_NO_NO_FLAGS%20%2B%3D-lm%20ifndef%20CONFIG_NO__GITVER%23%20%E4%B8%BA%E6%9D%A5%E8%87%AA%20git%20%E5%AD%98%E5%82%A8%E5%BA%93%E7%9A%84%E7%89%88%E6%9C%AC%E6%B7%BB%E5%8A%A0%20VERSION_STR%20%E5%90%8E%E7%BC%80%20yifeq%20(%24%EF%BC%88%E9%80%9A%E9%85%8D%E7%AC%A6..%20%2F.git%EF%BC%89%EF%BC%8C...%20%2F.git)%20GITVER%3A%20%3D%20%24%20(shell%20git%20describe--dirty%3D%2B)%20ifneq%20(%24%20(GITVER)%EF%BC%8C)%20CFLAGS%20%2B%3D-DGIT_VERSION_STR_POSTFIX%3D%5C%20%22-%24%20(GITVER)%5C%20%22%20endifendif%20def%20CONFIG_TESTING_OPTIONSCFLAGS%20%2B%3D-dconfig_testing_optionsconfig_wps_testing%3Dyconfig_tdls_testing%3Dyneed_aes_wrap%3Dyendif%20mkconfig%EF%BC%9A%40if%20%5B-f%20.configthen%20%5Cecho%20'.config%20exists%20-%20did%20not%20replace%20it'%3B%20%5Cexit%201%3B%20%5Cfiecho%20CONFIG_DRIVER_HOSTAP%3Dy%26gt%3B%26gt%3B%20.configechoCONFIG_DRIVER_WEXT%3Dy%26gt%3B%26gt%3B%20.config%20%24(DESTDIR)%24(BINDIR)%2F%25%3A%25install%20-D%20%24(%26lt%3B)%20%24(%40)%20install%EF%BC%9A%24(addprefix%20%24(DESTDIR)%24(BINDIR)%2F%2C%24(BINALL))%24(MAKE)%20-C%20.%2Fsrc%20installifndef%20CONFIG_NO_WPA_PASSPHRASEinstall%20-D%20wpa_passphrase%20%24(DESTDIR)%2F%24(BINDIR)%2Fwpa_passphraseendif%20ifdef%20CONFIG_BUILD_PASN_SOinstall%20-m%200644%20-D%20libpasn.so%20%24(DESTDIR)%2F%24(LIBDIR)%2Flibpasn.soendif%20ifdef%20CONFIG_BUILD_WPA_CLIENT_SOinstall%20-m%200644%20-D%20libwpa_client.so%20%24(DESTDIR)%2F%24(LIBDIR)%2Flibwpa_client.soinstall%20-m%200644%20-D%20..%2Fsrc%2Fcommon%2Fwpa_ctrl.h%20%24(DESTDIR)%2F%24(INCDIR)%2Fwpa_ctrl.hendif%20ls%20eap_*.so%26gt%3B%2Fdev%2Fnull%202%26gt%3B%26amp%3B%201%3B%20then%20%5Cinstall%20-d%20%24(DESTDIR)%24(LIBDIR)%2Fwpa_supplicant%26amp%3B%26amp%3B%20%5Ccp%20*.so%20%24(DESTDIR)%24(LIBDIR)%2Fwpa_supplicant%20%5C%3B%20fi%20ifdef%20CONFIG_FIPSCONFIG_NO_RANDOM_POOL%3Dendif%20OBJS%20%3D%20config.oOBJS%20%2B%3D%20notify.oOBJS%20%2B%3D%20bss.oOBJS%20%2B%3D%20eap_register.oOBJS%20%2B%3D%20..%20%2Fsrc%2Futils%2Fcommon.oOBJS%20%2B%3D%20...%2Fsrc%2Futils%2Fconfig.oOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fwpa_debug.oOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fwpabuf.oOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fbitfield.oOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fip_addr.oOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fcrc32.oOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fptksa_cache.oOBJS%20%2B%3D%20..%2Fsrc%2Frsn_supp%2Fpmksa_cache.oOBJS%20%2B%3D%20twt.oOBJS_p%20%3D%20wpa_passphrase.oOBJS_p%2B%3D%20..%2Fsrc%2Futils%2Fcommon.oOBJS_p%20%2B%3D%20..%2Fsrc%2Futils%2Fwpa_debug.oOBJS_p%20%2B%3D%20..%2Fsrc%2Futils%2Fwpabuf.oOBJS_c%20%3D%20wpa_cli.o..%2Fsrc%2Fcommon%2Fwpa_ctrl.oOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2Fwpa_debug.oOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2Fcommon.oOBJS_c%20%2B%3D%20..%2Fsrc%2Fcommon%2Fcli.o%20ifndef%20CONFIG_OSifdef%20CONFIG_NATIVE_WINDOWSCONFIG_OS%3Dwin32elseCONFIG_OS%3Dunixendifendif%20ifeq%20(%24(CONFIG_OS)%2C%20internal)CFLAGS%20%2B%3D%20-DOS_NO_C_LIB_DEFINESendif%20OBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fos_%24(CONFIG_OS).oOBJS_p%20%2B%3D%20..%2Fsrc%2Futils%2Fos_%24(CONFIG_OS).oOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2Fos_%24(CONFIG_OS).o%20ifdef%20CONFIG_WPA_TRACECFLAGS%20%2B%3D%20-DWPA_TRACEOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.oOBJS_p%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.oOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.oOBJS_priv%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.oLIBCTRL%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.oLIBCTRLSO%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.oLIBCTRLSO%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.oLIBCTRLSOcLDFLAGS%20%2B%3D%20-rdynamicCFLAGS%20%2B%3D%20-funwind-tablesifdef%20CONFIG_WPA_TRACE_BFDCFLAGS%20%2B%3D%20-DPACKAGE%3D%22wpa_supplicant%22%20-DWPA_TRACE_BFDLIBS%20%2B%3D%20-lbfd%20-ldl%20-...liberty%20-lzLIBS_p%20%2B%3D%20-lbfd%20-ldl%20-liberty%20-lzLIBS_c%20%2B%3D%20-lbfd%20-ldl%20-liberty%20-lzendifendif%20ifndef%20CONFIG_ELOOPCONFIG_ELOOP%3DeloopendifOBJS%20%2B%3D%20..%2Fsrc%2Futils%2F%24(CONFIG_ELOOP).oOBJS_c%20%2B%3D%20.%2Fsrc%2Futils%2F%24(CONFIG_ELOOP).o%20ifndef%20CONFIG_OSXifeq%20(%24(CONFIG_ELOOP)%2C%20eloop)%23%20%E4%BD%BF%E7%94%A8%20glibc%26lt%3B%202.17%20%E6%97%B6%E9%92%9F_gettime()%E9%9C%80%E8%A6%81%20-lrt%20%23%20OS%20X%20%E6%9C%89%E5%8F%A6%E4%B8%80%E7%A7%8D%E5%AE%9E%E7%8E%B0LIBS%20%2B%3D%20-lrtLIBS_c%20%2B%3D%20-lrtLIBS_p%20%2B%3D%20-lrtendifendif%20ifdef%20CONFIG_ELOOP_POLLCFLAGS%20%2B%3D%20-DCONFIG_ELOOP_POLLendif%20ifdef%20CONFIG_ELOOP_EPOLLCFLAGS%20%2B%3D%20-DCONFIG_ELOOP_EPOLLendif%20ifdef%20CONFIG_ELOOP_KQUEUECFLAGS%20%2B%3D%20-DCONFIG_ELOOP_KQUEUEendif%20ifdef%20CONFIG_EAPOL_TESTCFLAGS%20%2B%3D%20-Werror%20-DEAPOL_TESTendif%20ifdef%20CONFIG_CODE_COVERAGECFLAGS%20%2B%3D%20-O0%20-fprofile-arcs%20-ftest-coverage%20-U_FORTIFY_SOURCELIBS%20%2B%3D%20-lgcovLIBS_c%20%2B%3D%20-lgcovLIBS_p%20%2B%3D%20-lgcovendif%20ifdef%20CONFIG_HT_OVERRIDESCFLAGS%20%2B%3D%20-%20DCONFIG_VHT_OVERRIDESendif%20ifdef%20CONFIG_VHT_OVERRIDESCFLAGS%20%2B%3D%20-DCONFIG_VHT_OVERRIDESendifDCONFIG_HT_OVERRIDESendif%20ifdef%20CONFIG_VHT_OVERRIDESCFLAGS%20%2B%3D%20-DCONFIG_VHT_OVERRIDESendif%20ifdef%20CONFIG_HE_OVERRIDESCFLAGS%20%2B%3D%20-DCONFIG_HE_OVERRIDESendif%20ifndef%20CONFIG_BACKENDCONFIG_BACKEND%3Dfileendif%20ifeq%20(%24(CONFIG_BACKEND)%E3%80%81%E6%96%87%E4%BB%B6%EF%BC%89OBJS%20%2B%3D%20config_file%E3%80%82oifndef%20CONFIG_NO_CONFIG_BLOBSNEED_BASE64%3DyendifCFLAGS%20%2B%3D%20-DCONFIG_BACKEND_FILEendif%20ifeq%20(%24(CONFIG_BACKEND)%2C%20winreg)OBJS%20%2B%3D%20config_winreg.oendif%20ifeq%20(%24(CONFIG_BACKEND)%2C%20none)OBJS%20%2B%3D%20config_none.oendif%20ifdef%20CONFIG_NO_CONFIG_WRITECFLAGS%20%2B%3D%20-DCONFIG_NO_CONFIG_WRITEendif%20ifdef%20CONFIG_NO_CONFIG_LOBBSCFLAGS%20%2B%3D%20-DCONFIG_NO_CONFIG_BLOBSendif%20ifdef%20CONFIG_NO_SCAN_PROCESSINGCFLAGS%20%2B%3D%20-DCONFIG_NO_SCAN_PROCESSINGendif%20ifdef%20CONFIG_SUITEBCFLAGS%20%2B%3D%20-DCONFIG_SUITEBendif%20ifdef%20CONFIG_SUITEBCFLAGS%20%2B%3D%20-DCONFIG_SUITEBendifDCONFIG_NO_SCAN_PROCESSINGendif%20ifdef%20CONFIG_SUITEBCFLAGS%20%2B%3D%20-DCONFIG_SUITEBendif%20ifdef%20CONFIG_SUITEB192CFLAGS%20%2B%3D%20-DCONFIG_SUITEB192NEED_SHA384%3Dyendif%20ifdef%20CONFIG_OCVCFLAGS%20%2B%3D%20-DCONFIG_OCVOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Focv.oendif%20ifdef%20CONFIG_IEEE80211RCFLAGS%20%2B%3D%20-DCONFIG_IEEE80211ROBJS%20%2B%3D%20.%2Fsrc%2Frsn_supp%2Fwpa_ft.oendif%20ifdef%20CONFIG_MESHNEED_80211_COMMON%3DyNEED_AES_SIV%3DyCONFIG_SAE%3DyCONFIG_AP%3DyCFLAGS%20%2B%3D%20-DCONFIG_MESHOBJS%20%2B%3D%20mesh.oOBJS%20%2B%3D%20mesh_mpm.oOBJS%20%2B%3D%20mesh_rsn.oendif%20ifdef%20CONFIG_SAECFLAGS%20%2B%3D%20-DCONFIG_SAEOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fsae.oifdef%20CONFIG_SAE_PKCFLAGS%20%2B%3D%20-DCONFIG_SAE_PKNEED_AES_SIV%3DyOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fsae_pk.oendifNEED_ECC%3DyNEED_DH_GROUPS%3DyNEED_HMAC_SHA256_KDF%3DyNEED_DRAGONFLY%3Dyifdef%20CONFIG_TESTING_OPTIONSNEED_DH_GROUPS_ALL%3Dyendifendif%20ifdef%20CONFIG_DPPCFLAGS%20%2B%3D%20-DCONFIG_DPPOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdpp.oOBJS%20%2B%3D%20.%2Fsrc%2Fcommon%2Fdpp_auth.oOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdpp_backup.oOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdpp_crypto.oOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdpp_pkex.oOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdpp_reconfig.oOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdpp_tcp.oOBJS%20%2B%3D%20dpp_supplicant.oOBJS%E3%80%82oNEED_AES_SIV%3DyNEED_HMAC_SHA256_KDF%3DyNEED_HMAC_SHA384_KDF%3DyNEED_HMAC_SHA512_KDF%3DyNEED_SHA384%3DyNEED_SHA512%3DyNEED_ECC%3DyNEED_JSON%3DyNEED_GAS_SERVER%3DyNEED_BASE64%3DyNEED_ASN1%3DyifdefCONFIG_DPP2CFLAGS%20%2B%3D%20-DCONFIG_DPP2endififdef%20CONFIG_DPP3CFLAGS%20%2B%3D%20-DCONFIG_DPP3endifififdef%20CONFIG_NAN_USDOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fnan_de.oOBJS%20%2B%3D%20nan_usd.oCFLAGS%20%2B%3D%20-DCONFIG_NAN_USDendif%20ifdef%20CONFIG_OWECFLAGS%20%2B%3D%20-DCONFIG_OWENEED_ECC%3DyNEED_HMAC_SHA256_KDF%3DyNEED_HMAC_SHA384_KDF%3DyNEED_HMAC_SHA512_KDF%3DyNEED_SHA384%3DyNEED_SHA512%3Dyendif%20ifdef%20CONFIG_FILSCFLAGS%20%2B%3D%20-DCONFIG_NAN_USDendifDCONFIG_FILSNEED_SHA384%3DyNEED_AES_SIV%3Dyifdef%20CONFIG_FILS_SK_PFSCFLAGS%20%2B%3D%20-DCONFIG_FILS_SK_PFSNEED_ECC%3Dyendifendif%20ifdef%20CONFIG_MBOCONFIG_WNM%3Dyendif%20ifdef%20CONFIG_BGSCAN_SIMPLECONFIG_WNM%3Dyendif%20ifdef%20CONFIG_WNMCFLAGS%20%2B%3D%20-DCONFIG_WNMOBJS%20%2B%3D%20wnm_sta%E3%80%82oendif%20ifdef%20CONFIG_TDLSCFLAGS%20%2B%3D%20-DCONFIG_TDLSOBJS%20%2B%3D%20..%2Fsrc%2Frsn_supp%2Ftdls.oendif%20ifdef%20CONFIG_TDLS_TESTINGCFLAGS%20%2B%3D%20-DCONFIG_TDLS_TESTINGendif%20ifdef%20CONFIG_PMKSA_CACHE_EXTERNALCFLAGS%20%2B%3D%20-DCONFIG_PMKSA_CACHE_EXTERNALendif%20ifndef%20CONFIG_NO_WPAOBJS%20%2B%3D%20..%2Fsrc%2Frsn_supp%2Fwpa.oOBJS%20%2B%3D%20.%2Fsrc%2Frsn_supp%2Fpreauth.oOBJS%20%2B%3D%20.%2Fsrc%2Frsn_supp%2Fwpa_ie.oOBJS%20%2B%3D%20.%2Fsrc%2Fcommon%2Fwpa_common.oOBJS%20%2B%3D%20.%2Fsrc%2Frsn_supp%2Fwpa_ie.oOBJS%20%2B%3D%20.oNEED_AES%3DyNEED_SHA1%3DyNEED_MD5%3DyNEED_RC4%3DyelseCFLAGS%20%2B%3D%20-DCONFIG_NO_WPAifeq%20(%24(CONFIG_TLS)%E3%80%81internal)NEED_SHA1%3DyNEED_MD5%3Dyendifendif%20ifdef%20CONFIG_IBSS_RSNNEED_RSN_AUTHENTICATOR%3DyCFLAGS%20%2B%3D%20-DCONFIG_IBSS_RSNCFLAGS%20%2B%3D%20-DCONFIG_NO_VLANOBJS%20%2B%3D%20ibss_rsn.oendif%20ifdef%20CONFIG_MATCH_IFACECFLAGS%20%2B%3D%20-DCONFIG_MATCH_IFACEendif%20ifdef%20CONFIG_P2POBJS%20%2B%3D%20p2p_supplicant.oOBJS%20%2B%3D%20p2p_supplicant_sd.oOBJS%20%2B%3D%20..%2Fsrc%2Fp2p%2Fp2p.oOBJS%20%2B%3D%20...%2Fsrc%2Fp2p%2Fp2p_utils.oOBJS%20%2B%3D%20.%2Fsrc%2Fp2p%2Fp2p_parse.oOBJS%20%2B%3D%20.%2Fsrc%2Fp2p%2Fp2p_build.oOBJS%20%2B%3D%20.%2Fsrc%2Fp2p%2Fp2p_go_neg.oOBJS%20%2B%3D%20.%2Fsrc%2Fp2p%2Fp2p_sd.oOBJS%20%2B%3D%20.%2Fsrc%2Fp2p%2Fp2p_pd.oOBJS%20%2B%3D%20...%2Fsrc%2Fp2p%2Fp2p_invitation.oOBJS%20%2B%3D%20..%2Fsrc%2Fp2p%2Fp2p_dev_disc.oOBJS%20%2B%3D%20..%2Fsrc%2Fp2p%2Fp2p_group.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fp2p_hostapd.oCFLAGS%20%2B%3D%20-DCONFIG_P2PNEED_GAS%3DyNEED_OFFCHANNEL%3DyCONFIG_WPS%3DyCONFIG_AP%3Dyifdef%20CONFIG_P2P_STRICTCFLAGS%20%2B%3D%20-DCONFIG_P2P_STRICTendififdef%20CONFIG_WIFI_DISPLAYCFLAGS%20%2B%3D%20-DCONFIG_WIFI_DISPLAYOBJS%20%2B%3D%20wifi_display.oendifendif%20ifdef%20CONFIG_PASNCFLAGS%20%2B%3D%20-DCONFIG_PASNCFLAGS%20%2B%3D%20-DCONFIG_PTKSA_CACHENEED_HMAC_SHA256_KDF%3DyNEED_HMAC_SHA384_KDF%3DyNEED_SHA256%3DyNEED_SHA384%3DyOBJS%20%2B%3D%20..%2Fsrc%2Fpasn%2Fpasn_initiator.oOBJS%20%2B%3D%20.%2Fsrc%2Fpasn%2Fpasn_common.oOBJS%20%2B%3D%20pasn_supplicant.oendif%20ifdef%20CONFIG_HS20OBJS%20%2B%3D%20hs20_supplicant.oCFLAGS%20%2B%3D%20-DCONFIG_HS20CONFIG_INTERWORKING%3Dyendif%20ifdef%20CONFIG_INTERWORKINGOBJS%20%2B%3D%20interworking.oCFLAGS%20%2B%3D%20-DCONFIG_INTERWORKINGNEED_GAS%3Dyendif%20ifdef%20CONFIG_NO_ROAMINGCFLAGS%20%2B%3D%20-DCONFIG_NO_ROAMINGendif%20ifdef%20CONFIG_OPENSC_ENGINE_PATHCFLAGS%20%2B%3D%20-DCONFIG_OPENSC_ENGINE_PATHCFLAGS%20%2B%3D%20-DCONFIG_OPENSC_ENGINE_PATHCFLAGSDCONFIG_OPENSC_ENGINE_PATH%3D%5C%22%24(CONFIG_OPENSC_ENGINE_PATH)%5C%22endif%20ifdef%20CONFIG_NO_OPENSC_ENGINE_PATHCFLAGS%20%2B%3D%20-DCONFIG_OPENSC_ENGINE_PATH%3DNULLendif%20ifdef%20CONFIG_PKCS11_ENGINE_PATHCFLAGS%20%2B%3D%20-DCONFIG_PKCS11_ENGINE_PATH%3D%5C%22%24(CONFIG_PKCS11_ENGINE_PATH)%5C%22endif%20ifdef%20CONFIG_NO_PKCS11_ENGINE_PATHCFLAGS%20%2B%3D%20-DCONFIG_PKCS11_ENGINE_PATHCFLAGS%20%2B%3D%20-DCONFIG_OPENSC_ENGINE_PATH%3DNULLendifDCONFIG_PKCS11_ENGINE_PATH%3DNULLendif%20ifdef%20CONFIG_PKCS11_MODULE_PATHCFLAGS%20%2B%3D%20-DCONFIG_PKCS11_MODULE_PATH%3D%5C%22%24(CONFIG_PKCS11_MODULE_PATH)%5C%22endif%20ifdef%20CONFIG_NO_PKCS11_MODULE_PATHCFLAGS%20%2B%3D%20-DCONFIG_PKCS11_ENGINE_PATH%3DNULLendifDCONFIG_PKCS11_MODULE_PATH%3DNULLendif%20ifdef%20CONFIG_NO_LOAD_DYNAMIC_EAPCFLAGS%20%2B%3D%20-DCONFIG_NO_LOAD_DYNAMIC_EAPendif%20ifdef%20CONFIG_NO_RRMCFLAGS%20%2B%3D%20-DCONFIG_NO_RRMelseOBJS%20%2B%3D%20rrm.oifdef%20CONFIG_APOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Frrm.oendifOBJS%20%2B%3D%20op_classes.oendif%20ifdef%20CONFIG_NO_WMM_ACCFLAGS%20%2B%3D%20-DCONFIG_NO_WMM_ACelseOBJS%20%2B%3D%20wmm_ac.oendif%20ifdef%20CONFIG_NO_ROBUST_AVCFLAGS%20%2B%3D%20-DCONFIG_NO_ROBUST_AVelseOBJS%20%2B%3D%20robust_av.oendif%20include%20..%2Fsrc%2Fdrivers%2Fdrivers.makifdef%20CONFIG_APOBJS_d%20%2B%3D%20%24(DRV_BOTH_OBJS)CFLAGS%20%2B%3D%20%24(DRV_BOTH_CFLAGS)LDFLAGS%20%2B%3D%20%24(DRV_BOTH_LDFLAGS)LIBS%20%2B%3D%20%24(DRV_BOTH_LIBS)elseNEED_AP_MLME%3DOBJS_d%20%2B%3D%24(DRV_WPA_OBJS)CFLAGS%20%2B%3D%20%24(DRV_WPA_CFLAGS)LDFLAGS%20%2B%3D%20%24(DRV_WPA_LDFLAGS)LIBS%20%2B%3D%20%24(DRV_WPA_LIBS)endif%20ifndef%20CONFIG_L2_PACKETCONFIG_L2_PACKET%3Dlinuxendif%20OBJS_l2%20%2B%3D%20..%2Fsrc%2Fl2_packet%2Fl2_packet_%24(CONFIG_L2_PACKET).o%20ifeq%20(%24(CONFIG_L2_PACKET)%2C%20pcap)ifdef%20CONFIG_WINPCAPCFLAGS%20%2B%3D%20-DCONFIG_WINPCAPLIBS%20%2B%3D%20-lwpcap%20-lpacketLIBS_w%20%2B%3D%20-lwpcapelseLIBS%20%2B%3D%20-ldnet%20-lpcapendifendif%20ifeq%20(%24(CONFIG_L2_PACKET)%E3%80%81winpcap)LIBS%20%2B%3D%20-lwpcap%20-lpacketLIBS_w%20%2B%3D%20-lwpcapendif%20ifeq%20(%24(CONFIG_L2_PACKET)%E3%80%81freebsd)LIBS%20%2B%3D%20-lpcapendif%20ifdef%20CONFIG_ERPCFLAGS%20%2B%3D%20-DCONFIG_ERPNEED_HMAC_SHA256_KDF%3Dyendif%20ifdef%20CONFIG_EAP_TLS%23%20EAP-TLSifeq%20(%24(CONFIG_EAP_TLS)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_TLS_DYNAMICEAPDYN%20%2B%3D%20eap_tls.%E6%89%80%E4%BB%A5CFLAGS%2B%3D%20-DEAP_TLSOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_tls.oendifTLS_FUNCS%3DyCONFIG_IEEE8021X_EAPOL%3Dyifdef%20CONFIG_EAP_TLSV1_3CFLAGS%20%2B%3D%20-DEAP_TLSV1_3endifendif%20ifdef%20CONFIG_EAP_UNAUTH_TLS%23%20EAP-UNAUTH-TLSCFLAGS%20%2B%3D%20-DEAP_UNAUTH_TLSifndef%20CONFIG_EAP_TLSOBJS%20%2B%3D%20...%2Fsrc%2Feap_peer%2Feap_tls.oTLS_FUNCS%3DyendifCONFIG_IEEE8021X_EAPOL%3Dyendif%20ifdef%20CONFIG_EAP_PEAP%23%20EAP-PEAPSRC_EAP_PEAP%20%3D%20..%2Fsrc%2Feap_peer%2Feap_peap.c%20..%2Fsrc%2Feap_common%2Feap_peap_common.cifeq%20(%24(CONFIG_EAP_PEAP)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_PEAP_DYNAMICEAPDYN%20%2B%3D%20eap_peap.soelseCFLAGS%2B%3D%20-DEAP_PEAPOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_PEAP))endifTLS_FUNCS%3DyCONFIG_IEEE8021X_EAPOL%3Dyendif%20ifdef%20CONFIG_EAP_TTLS%23%20EAP-TTLSifeq%20(%24(CONFIG_EAP_TTLS)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_TTLS_DYNAMICEAPDYN%20%2B%3D%20eap_ttls.soelseCFLAGS%2B%3D%20-DEAP_TTLSOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_ttls.oendifTLS_FUNCS%3Dyifndef%20CONFIG_FIPSMS_FUNCS%3DyCHAP%3DyendifCONFIG_IEEE8021X_EAPOL%3Dyendif%20ifdef%20CONFIG_EAP_MD5%23%20EAP-MD5ifeq%20(%24(CONFIG_EAP_MD5)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_MD5_DYNAMICEAPDYN%20%2B%3D%20eap_md5.soelseCFLAGS%2B%3D%20-DEAP_MD5OBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_md5.oendifCHAP%3DyCONFIG_IEEE8021X_EAPOL%3Dyendif%20%23%20%E5%90%91%E5%90%8E%E5%85%BC%E5%AE%B9%E6%97%A7%E6%8B%BC%E5%86%99ifdef%20CONFIG_MSCHAPV2ifndef%20CONFIG_EAP_MSCHAPV2CONFIG_EAP_MSCHAPV2%3Dyendifendif%20ifdef%20CONFIG_EAP_MSCHAPV2%23%20EAP-MSCHAPv2SRC_EAP_MSCHAPV2%20%3D%20..%2Fsrc%2Feap_peer%2Feap_mschapv2.c%20.%2Fsrc%2Feap_peer%2Fmschapv2.cifeq%20(%24(CONFIG_EAP_MSCHAPV2)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_MSCHAPv2_DYNAMICEAPDYN%20%2B%3D%20eap_mschapv2.soelseCFLAGS%2B%3D%20-DEAP_MSCHAPv2OBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_MSCHAPV2))endifMS_FUNCS%3DyCONFIG_IEEE8021X_EAPOL%3Dyendif%20ifdef%20CONFIG_EAP_GTC%23%20EAP-GTCifeq%20(%24(CONFIG_EAP_GTC)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_GTC_DYNAMICEAPDYN%20%2B%3D%20eap_gtc.soelseCFLAGS%2B%3D%20-DEAP_GTCOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_gtc.oendifCONFIG_IEEE8021X_EAPOL%3Dyendif%20ifdef%20CONFIG_EAP_OTP%23%20EAP-OTPifeq%20(%24(CONFIG_EAP_OTP)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_OTP_DYNAMICEAPDYN%20%2B%3D%20eap_otp.soelseCFLAGS%2B%3D%20-DEAP_OTPOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_otp.oendifCONFIG_IEEE8021X_EAPOL%3Dyendif%20ifdef%20CONFIG_EAP_SIM%23%20EAP-SIMifeq%20(%24(CONFIG_EAP_SIM)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_SIM_DYNAMICEAPDYN%20%2B%3D%20eap_sim.soelseCFLAGS%2B%3D%20-DEAP_SIMOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_sim.oendifCONFIG_IEEE8021X_EAPOL%3DyCONFIG_EAP_SIM_COMMON%3DyNEED_AES_CBC%3Dyendif%20ifdef%20CONFIG_EAP_LEAP%23%20EAP-LEAPifeq%20(%24(CONFIG_EAP_LEAP)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_LEAP_DYNAMICEAPDYN%20%2B%3D%20eap_leap.soelseCFLAGS%2B%3D%20-DEAP_LEAPOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_leap.oendifMS_FUNCS%3DyCONFIG_IEEE8021X_EAPOL%3Dyendif%20ifdef%20CONFIG_EAP_PSK%23%20EAP-PSKSRC_EAP_PSK%20%3D%20.%2Fsrc%2Feap_peer%2Feap_psk.c%20..%2Fsrc%2Feap_common%2Feap_psk_common.cifeq%20(%24(CONFIG_EAP_PSK)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_PSK_DYNAMICEAPDYN%20%2B%3D%20eap_psk.soelseCFLAGS%2B%3D%20-DEAP_PSKOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_PSK))endifCONFIG_IEEE8021X_EAPOL%3DyNEED_AES%3DyNEED_AES_ENCBLOCK%3DyNEED_AES_EAX%3Dyendif%20ifdef%20CONFIG_EAP_AKA%23%20EAP-AKAifeq%20(%24(CONFIG_EAP_AKA)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_AKA_DYNAMICEAPDYN%20%2B%3D%20eap_aka.soelseCFLAGS%2B%3D%20-DEAP_AKAOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_aka.oendifCONFIG_IEEE8021X_EAPOL%3DyCONFIG_EAP_SIM_COMMON%3DyNEED_AES_CBC%3Dyendif%20ifdef%20CONFIG_EAP_PROXYCFLAGS%20%2B%3D%20-DCONFIG_EAP_PROXYOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_proxy_%24(CONFIG_EAP_PROXY).oinclude%20eap_proxy_%24(CONFIG_EAP_PROXY).makCONFIG_IEEE8021X_EAPOL%3Dyendif%20ifdef%20CONFIG_EAP_AKA_PRIME%23%20EAP-AKA'ifeq%20(%24(CONFIG_EAP_AKA_PRIME)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_AKA_PRIME_DYNAMICelseCFLAGS%20%2B%3D%20-DEAP_AKA_PRIMEendifif%20ifdef%20CONFIG_EAP_SIM_COMMONOBJS%20%2B%3D%20..%2Fsrc%2Feap_common%2Feap_sim_common.oNEED_AES%3DyNEED_FIPS186_2_PRF%3Dyendif%20ifdef%20CONFIG_EAP_FAST%23%20EAP-FASTSRC_EAP_FAST%20%3D%20..%2Fsrc%2Feap_peer%2Feap_fast.c%20..%2Fsrc%2Feap_peer%2Feap_fast_pac.cSRC_EAP_FAST%20%2B%3D%20..%2Fsrc%2Feap_common%2Feap_fast_common.cifeq%20(%24(CONFIG_EAP_FAST)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_FAST_DYNAMICEAPDYN%20%2B%3D%20eap_fast.soelseCFLAGS%2B%3D%20-DEAP_FASTOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_FAST))endifTLS_FUNCS%3DyCONFIG_IEEE8021X_EAPOL%3DyNEED_T_PRF%3Dyendif%20ifdef%20CONFIG_EAP_TEAP%23%20EAP-TEAPSRC_EAP_TEAP%20%3D%20..%2Fsrc%2Feap_peer%2Feap_teap...%2Fsrc%2Feap_peer%2Feap_teap_pac.cSRC_EAP_TEAP%20%2B%3D%20..%2Fsrc%2Feap_common%2Feap_teap_common.cifeq%20(%24(CONFIG_EAP_TEAP)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_TEAP_DYNAMICEAPDYN%20%2B%3D%20eap_teap.soelseCFLAGS%2B%3D%20-DEAP_TEAPOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_TEAP))endifTLS_FUNCS%3DyCONFIG_IEEE8021X_EAPOL%3DyNEED_T_PRF%3DyNEED_SHA384%3DyNEED_TLS_PRF_SHA256%3DyNEED_TLS_PRF_SHA384%3Dyendif%20ifdef%20CONFIG_EAP_PAX%23%20EAP-PAXSRC_EAP_PAX%20%3D%20..%2Fsrc%2Feap_peer%2Feap_pax.c%20.%2Fsrc%2Feap_common%2Feap_pax_common.cifeq%20(%24(CONFIG_EAP_PAX)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_PAX_DYNAMICEAPDYN%20%2B%3D%20eap_pax.soelseCFLAGS%2B%3D%20-DEAP_PAXOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_PAX))endifCONFIG_IEEE8021X_EAPOL%3Dyendif%20ifdef%20CONFIG_EAP_SAKE%23%20EAP-SAKESRC_EAP_SAKE%20%3D%20...%2Fsrc%2Feap_peer%2Feap_sake.c%20..%2Fsrc%2Feap_common%2Feap_sake_common.cifeq%20(%24(CONFIG_EAP_SAKE)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_SAKE_DYNAMICEAPDYN%20%2B%3D%20eap_sake.soelseCFLAGS%2B%3D%20-DEAP_SAKEOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_SAKE))endifCONFIG_IEEE8021X_EAPOL%3Dyendif%20ifdef%20CONFIG_EAP_GPSK%23%20EAP-GPSKSRC_EAP_GPSK%20%3D%20...%2Fsrc%2Feap_peer%2Feap_gpsk.c%20..%2Fsrc%2Feap_common%2Feap_gpsk_common.cifeq%20(%24(CONFIG_EAP_GPSK)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_GPSK_DYNAMICEAPDYN%20%2B%3D%20eap_gpsk.soelseCFLAGS%2B%3D%20-DEAP_GPSKOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_GPSK))endifCONFIG_IEEE8021X_EAPOL%3Dyifdef%20CONFIG_EAP_GPSK_SHA256CFLAGS%20%2B%3D%20-DEAP_GPSK_SHA256endifendif%20ifdef%20CONFIG_EAP_PWDCFLAGS%20%2B%3D%20-DEAP_PWDifeq%20(%24(CONFIG_TLS)%2C%20wolfssl)CFLAGS%20%2B%3D%20-DCONFIG_ECCendifOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_pwd.o%20.%2Fsrc%2Feap_common%2Feap_pwd_common.oCONFIG_IEEE8021X_EAPOL%3DyNEED_ECC%3DyNEED_DRAGONFLY%3DyMS_FUNCS%3Dyendif%20ifdef%20CONFIG_EAP_EKE%23%20EAP-EKESRC_EAP_EKE%20%3D%20.%2Fsrc%2Feap_peer%2Feap_eke.c%20..%2Fsrc%2Feap_common%2Feap_eke_common.cifeq%20(%24(CONFIG_EAP_EKE)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_EKE_DYNAMICEAPDYN%20%2B%3D%20eap_eke.soelseCFLAGS%2B%3D%20-DEAP_EKEOBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_EKE))endifCONFIG_IEEE8021X_EAPOL%3DyNEED_DH_GROUPS%3DyNEED_DH_GROUPS_ALL%3DyNEED_AES_CBC%3Dyendif%20ifdef%20CONFIG_WPS%23%20EAP-WSCCFLAGS%20%2B%3D%20-DCONFIG_WPS%20-DEAP_WSCOBJS%20%2B%3D%20wps_supplicant.oOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fuuid.oOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_wsc.o%20..%2Fsrc%2Feap_common%2Feap_wsc_common.oOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps.oOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_common.oOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_attr_parse.oOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_attr_build.oOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_attr_process.oOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_dev_attr.oOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_enrollee.oOBJS%20%2B%3D%20...%2Fsrc%2Fwps%2Fwps_enrollee.oOBJS%20%2B%3D%20...%2Fsrc%2Fwps%2Fwps_dev_attr.oOBJS%20%2B%3D%20...%2Fsrc%2Fwps%2Fwps_enrollee.oOBJS%20%2B%3D%20...%2Fsrc%2Fwps%2Fwps_registrar.oCONFIG_IEEE8021X_EAPOL%3DyNEED_DH_GROUPS%3DyNEED_BASE64%3DyNEED_AES_CBC%3DyNEED_MODEXP%3Dy%20ifdef%20CONFIG_WPS_NFCCFLAGS%20%2B%3D%20-DCONFIG_WPS_NFCOBJS%20%2B%3D%20...%2Fsrc%2Fwps%2Fndef.oNEED_WPS_OOB%3Dyendif%20ifdef%20NEED_WPS_OOBCFLAGS%20%2B%3D%20-DCONFIG_WPS_OOBendif%20ifdef%20CONFIG_WPS_ERCONFIG_WPS_UPNP%3DyCFLAGS%20%2B%3D%20-DCONFIG_WPS_EROBJS%20%2B%3D%20...%2Fsrc%2Fwps%2Fwps_er.oOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_er_ssdp.oendif%20ifdef%20CONFIG_WPS_UPNPCFLAGS%20%2B%3D%20-DCONFIG_WPS_UPNPOBJS%20%2B%3D%20...%2Fsrc%2Fwps%2Fwps_upnp.oOBJS%20%2B%3D%20.%2Fsrc%2Fwps%2Fwps_upnp_ssdp.oOBJS%2B%3D.%2Fsrc%2Fwps%2Fwps_upnp_web.oOBJS%2B%3D.%2Fsrc%2Fwps%2Fwps_upnp_event.oOBJS%2B%3D.%2Fsrc%2Fwps%2Fwps_upnp_ap.oOBJS%2B%3D%20.oOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fupnp_xml.oOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fhttpread.oOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fhttp_client.oOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fhttp_server.oendif%20ifdef%20CONFIG_WPS_STRICTCFLAGS%20%2B%3D%20-DCONFIG_WPS_STRICTOBJS%20%2B%3D%20..%2Fsrc%2Fwps%2Fwps_validate.oendif%20ifdef%20CONFIG_WPS_TESTINGCFLAGS%20%2B%3D%20-DCONFIG_WPS_TESTINGendif%20ifdef%20CONFIG_WPS_REG_DISABLE_OPENCFLAGS%20%2B%3D%20-DCONFIG_WPS_REG_DISABLE_OPENENendif%20endif%20ifdef%20CONFIG_EAP_IKEV2%23%20EAP-IKEv2SRC_EAP_IKEV2%20%3D%20..%2Fsrc%2Feap_peer%2Feap_ikev2.cSRC_EAP_IKEV2%20%2B%3D%20.%2Fsrc%2Feap_peer%2Fikev2.cSRC_EAP_IKEV2%20%2B%3D%20.%2Fsrc%2Feap_common%2Feap_ikev2_common.cSRC_EAP_IKEV2%20%2B%3D%20..%2Fsrc%2Feap_common%2Fikev2_common.cifeq%20(%24(CONFIG_EAP_IKEV2)%2C%20dyn)CFLAGS%20%2B%3D%20-DEAP_IKEV2_DYNAMICEAPDYN%20%2B%3D%20eap_ikev2.soelseCFLAGS%2B%3D%20-DEAP_IKEV2OBJS%20%2B%3D%20%24(patsubst%25.c%2C%25.o%2C%20%24(SRC_EAP_IKEV2))endifCONFIG_IEEE8021X_EAPOL%3DyNEED_DH_GROUPS%3DyNEED_DH_GROUPS_ALL%3DyNEED_MODEXP%3DyNEED_CIPHER%3Dyendif%20ifdef%20CONFIG_EAP_VENDOR_TESTifeq%20(%24(CONFIG_EAP_VENDOR_TEST)%E3%80%81dyn)CFLAGS%20%2B%3D%20-DEAP_VENDOR_TEST_DYNAMICEAPDYN%20%2B%3D%20eap_vendor_test%E3%80%82%E6%89%80%E4%BB%A5CFLAGS%2B%3D%20-DEAP_VENDOR_TESTOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_vendor_test.oendifCONFIG_IEEE8021X_EAPOL%3Dyendif%20ifdef%20CONFIG_EAP_TNC%23%20EAP-TNCCFLAGS%20%2B%3D%20-DEAP_TNCOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_tnc.oOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Ftncc.oNEED_BASE64%3Dyifndef%20CONFIG_NATIVE_WINDOWSifndef%20CONFIG_DRIVER_BSDLIBS%20%2B%3D%20-ldlendififendifif%20ifdef%20CONFIG_MACSECCFLAGS%20%2B%3D%20-DCONFIG_MACSECCONFIG_IEEE8021X_EAPOL%3DyNEED_AES_ENCBLOCK%3DyNEED_AES_UNWRAP%3DyNEED_AES_WRAP%3DyOBJS%20%2B%3D%20wpas_kay.oOBJS%20%2B%3D%20..%2Fsrc%2Fpae%2Fieee802_1x_cp.oOBJS%20%2B%3D%20..%2Fsrc%2Fpae%2Fieee802_1x_kay.oOBJS%20%2B%3D%20..%2Fsrc%2Fpae%2Fieee802_1x_key.oOBJS%20%2B%3D%20..%2Fsrc%2Fpae%2Fieee802_1x_secy_ops.oifdef%20CONFIG_APOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwpa_auth_kay.oendifendif%20ifdef%20CONFIG_IEEE8021X_EAPOL%23%20IEEE%20802.1X%2FEAPOL%20%E7%8A%B6%E6%80%81%E6%9C%BA%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E7%94%A8%E4%BA%8E%20RADIUS%20%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%EF%BC%89%E3%80%81CFLAGS%20%2B%3D%20-DIEEE8021X_EAPOLOBJS%20%2B%3D%20..%2Fsrc%2Feapol_supp%2Feapol_supp_sm.oOBJS%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap.o%20..%2Fsrc%2Feap_peer%2Feap_methods.oNEED_EAP_COMMON%3Dyifdef%20CONFIG_DYNAMIC_EAP_METHODSCFLAGS%20%2B%3D%20-DCONFIG_DYNAMIC_EAP_METHODSLIBS%20%2B%3D%20-ldl%20-rdynamicendifendif%20ifdef%20CONFIG_APNEED_EAP_COMMON%3DyNEED_RSN_AUTHENTICATOR%3DyCFLAGS%20%2B%3D%20-DCONFIG_APOBJS%20%2B%3D%20ap.oCFLAGS%20%2B%3D%20-DCONFIG_NO_RADIUSCFLAGS%20%2B%3D%20-DCONFIG_NO_ACCOUNTINGCFLAGS%20%2B%3D%20-DCONFIG_NO_VLANOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fhostapd.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwpa_auth_glue.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Futils.oOBJS%20%2B%3D%20...%2Fsrc%2Fap%2Fauthsrv.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fap_config.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fsta_info.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Ftkip_countermeasures.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fap_mlme.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fieee802_1x.oOBJS%20%2B%3D%20..%2Fsrc%2Feapol_auth%2Feapol_auth_sm.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fieee802_11_auth.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fieee802_11_shared.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fdrv_callbacks.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fap_drv_ops.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fbeacon.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fbss_load.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Feap_user_db.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fneighbor_db.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fieee802_11_ht.oifdef%20CONFIG_IEEE80211ACOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fieee802_11_vht.oendifdef%20CONFIG_IEEE80211AXOBJS%20%2B%3D%20.%2Fsrc%2Fap%2Fieee802_11_he.oendifdef%20CONFIG_IEEE80211BEOBJS%20%2B%3D%20.%2Fsrc%2Fap%2Fieee802_11_eht.oendifdef%20CONFIG_WNM_APCFLAGS%20%2B%3D%20-DCONFIG_WNM_APOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwnm_ap.oendifdef%20CONFIG_MBOOBJS%20%2B%3D%20.%2Fsrc%2Fap%2Fmbo_ap.oendifdef%20CONFIG_FILSOBJS%20%2B%3D%20.%2Fsrc%2Fap%2Ffils_hlp.oendifdef%20CONFIG_CTRL_IFACEOBJS%20%2B%3D%20.%2Fsrc%2Fap%2Fctrl_iface_ap.oendif%20CFLAGS%20%2B%3D%20-DEAP_SERVER%20-DEAP_SERVER_IDENTITYOBJS%20%2B%3D%20..%2Fsrc%2Feap_server%2Feap_server.oOBJS%20%2B%3D%20..%2Fsrc%2Feap_server%2Feap_server_identity.oOBJS%20%2B%3D%20..%2Fsrc%2Feap_server%2Feap_server_methods.o%20ifdef%20CONFIG_IEEE80211ACCFLAGS%20%2B%3D%20-DCONFIG_IEEE80211ACendifdef%20CONFIG_IEEE80211BECONFIG_IEEE80211AX%3DyCFLAGS%20%2B%3D%20-DCONFIG_IEEE80211BEendifdef%20CONFIG_IEEE80211AXCFLAGS%20%2B%3D%20-DCONFIG_IEEE80211AXendif%20ifdef%20NEED_AP_MLMEOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwmm.oOBJS%20%2B%3D%20.%2Fsrc%2Fap%2Fap_list.oOBJS%20%2B%3D%20.%2Fsrc%2Fap%2Fcomeback_token.oOBJS%20%2B%3D%20.%2Fsrc%2Fpasn%2Fpasn_responder.oOBJS%20%2B%3D%20.%2Fsrc%2Fap%2Fieee802_11.oOBJS%20%2B%3D%20.%2Fsrc%2Fap%2Fhw_features.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fdfs.oCFLAGS%20%2B%3D%20-DNEED_AP_MLMEendifdef%20CONFIG_WPSCFLAGS%20%2B%3D%20-DEAP_SERVER_WSCOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwps_hostapd.oOBJS%20%2B%3D%20..%2Fsrc%2Feap_server%2Feap_server_wsc.oendififdef%20CONFIG_DPPOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fdpp_hostapd.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fgas_query_ap.oNEED_AP_GAS_SERV%3DyendififdefCONFIG_NAN_USDOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fnan_usd_ap.oendififdef%20CONFIG_INTERWORKINGNEED_AP_GAS_SERV%3Dyendifdef%20NEED_AP_GAS_SERVOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fgas_serv.oendififdef%20CONFIG_HS20OBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fhs20.oCFLAGS%20%2B%3D%20-DCONFIG_MBONEED_GAS%3Dyendififoendifendif%20ifdef%20CONFIG_MBOOBJS%20%2B%3D%20mbo.oCFLAGS%20%2B%3D%20-DCONFIG_MBONEED_GAS%3Dyendif%20ifdef%20NEED_RSN_AUTHENTICATORCFLAGS%20%2B%3D%20-DCONFIG_NO_RADIUSNEED_AES_WRAP%3DyOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwpa_auth.oOBJS%20%2B%3D%20..%2Fsrc%2Fap%2Fwpa_auth_ie.oOBJS%20%2B%3D%20.%2Fsrc%2Fap%2Fpmksa_cache_auth.oendif%20ifdef%20CONFIG_ACSCFLAGS%20%2B%3D%20-DCONFIG_ACSOBJS%20%2B%3D%20.%2Fsrc%2Fap%2Facs.oLIBS%20%2B%3D%20-lmendif%20ifdef%20CONFIG_PCSC%23%20%E7%94%A8%E4%BA%8E%E6%99%BA%E8%83%BD%E5%8D%A1%EF%BC%88USIM%E3%80%81GSM%20SIM%EF%BC%89%E7%9A%84%20PC%2FSC%20%E6%8E%A5%E5%8F%A3%20CFLAGS%20%2B%3D%20-DPCSC_FUNCSOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fpcsc_funcs.oifdef%20CONFIG_NATIVE_WINDOWS%23%E4%B8%80%E6%97%A6%20MinGW%20%E8%8E%B7%E5%BE%97%20WinScard%20%E6%94%AF%E6%8C%81%EF%BC%8C%E5%B0%B1%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20-lwinscard%20%E4%BB%A3%E6%9B%BF%E7%8E%B0%E5%9C%A8%20pcsc_funcs.c%23LIBS%20%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E5%8A%A8%E6%80%81%E7%AC%A6%E5%8F%B7%E5%8A%A0%E8%BD%BD%E3%80%82%2B%3D%20-lwinscardCFLAGS%20%2B%3D%20-I%2Fusr%2Finclude%2FPCSCelseifdef%20CONFIG_OSXLIBS%20%2B%3D%20-framework%20PCSCCFLAGS%20%2B%3D%20-I%2Fusr%2Finclude%2FPCSCelseLIBS%20%2B%3D%20%24(shell%20%24(PKG_CONFIG)%20--libs%20libpcsclite)CFLAGS%20%2B%3D%20%24(shell%20%24(PKG_CONFIG)%20--libs%20libpcsclite)endifendifendif%20ifdef%20CONFIG_SIM_SIM_SIMULATORCFLAGS%20%2B%3D%20-DCONFIG_SIM_SIMULATORNEVENTIFcflags%20libpcsclite)endifendif%20ifdef%20CONFIG_SIM_SIMULATORCFLAGS%20%2B%3D%20-DCONFIG_SIM_SIMULATORNEED_MILENAGE%3Dyendif%20ifdef%20CONFIG_USIM_SIMULATORCFLAGS%20%2B%3D%20-DCONFIG_USIM_SIMULATORNEED_MILENAGE%3Dyendif%20ifdef%20NEED_MILENAGEOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fmilenage.oNEED_AES_ENCBLOCK%3Dyendif%20ifdef%20CONFIG_PKCS12CFLAGS%20%2B%3D%20-DPKCS12_FUNCSendif%20ifdef%20CONFIG_SMARTCARDCFLAGS%20%2B%3D%20-DCONFIG_SMARTCARDendif%20ifdef%20NEED_DRAGONFLYOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fdragonfly.oendif%20ifdef%20MS_FUNCSOBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fms_funcs.oNEED_DES%3DyNEED_MD4%3Dyendif%20ifdef%20CHAPOBJS%20%2B%3D%20..%2Fsrc%2Feap_common%2Fchap.oendif%20ifdef%20TLS_FUNCSNEED_DES%3Dy%23%20%E5%85%B1%E4%BA%AB%20TLS%20%E5%8A%9F%E8%83%BD%EF%BC%88EAP_TLS%E3%80%81EAP_PEAP%E3%80%81EAP_TTLS%E3%80%81EAP_FAST%20%E5%92%8C%20EAP_TEAP%20%E5%9D%87%E9%9C%80%E8%A6%81%EF%BC%89%20OBJS%20%2B%3D%20.%2Fsrc%2Feap_peer%2Feap_tls_common.oneed_DES%3Dy%23%20%E5%85%B1%E4%BA%AB%20TLS%20%E5%8A%9F%E8%83%BD%EF%BC%88EAP_TLS%E3%80%81EAP_PEAP%E3%80%81EAP_TTLS%E3%80%81EAP_FAST%20%E5%92%8C%20EAP_TEAP%20%E5%9D%87%E9%9C%80%E8%A6%81%EF%BC%89%20OBJS%20%2B%3D%20.oifndef%20CONFIG_FIPSNEED_TLS_PRF%3DyNEED_SHA1%3DyNEED_MD5%3Dyendifendif%20ifndef%20CONFIG_TLSCONFIG_TLS%3Dopensslendif%20ifdef%20CONFIG_TLSV11CFLAGS%20%2B%3D%20-...%2Frc%2Feap_peer%2Feap_tls_common.DCONFIG_TLSV11endif%20ifdef%20CONFIG_TLSV12CFLAGS%20%2B%3D%20-DCONFIG_TLSV12endif%20ifdef%20CONFIG_RADIUS_TLSTLS_FUNCS%3Dyendif%20ifeq%20(%24(CONFIG_TLS)%E3%80%81wolfssl)ifdef%20TLS_FUNCSCFLAGS%20%2B%3D%20-DWOLFSSL_DER_LOADOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_wolfssl.oendifOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_wolfssl.oOBJS_p%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_wolfssl.oifdef%20NEED_FIPS186_2_PRFOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ffips_prf_wolfssl.oendifNEED_TLS_PRF_SHA256%3DyLIBS%20%2B%3D%20-.lwolfssl%20-lmLIBS_p%20%2B%3D%20-lwolfssl%20-lmendif%20ifeq%20(%24(CONFIG_TLS)%2C%20openssl)CFLAGS%20%2B%3D%20-DCRYPTO_RSA_OAEP_SHA256ifdef%20TLS_FUNCSCFLAGS%20%2B%3D%20-DEAP_TLS_OPENSSLOBJS%20%2B%3D%20....%2Fsrc%2Fcrypto%2Ftls_openssl.oOBJS%20%2B%3D%20...%2Fsrc%2Fcrypto%2Ftls_openssl_ocsp.oLIBS%20%2B%3D%20-lsslendifOBJS%20%2B%3D%20...%2Fsrc%2Fcrypto%2Fcrypto_openssl.oOBJS_p%20%2B%3D%20...%2Fsrc%2Fcrypto%2Fcrypto_openssl.oOBJS_priv%20%2B%3D%20...%2Fsrc%2Fcrypto%2Ftls_openssl.oLIBS%20%2B%3D%20-lsslendifOBJS%20%2B%3D%20...%2Fsrc%2Fcrypto%2Ftls_openssl.oOBJS_boOBJS_priv%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_openssl.oifdef%20NEED_FIPS186_2_PRFOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ffips_prf_openssl.oendifNEED_TLS_PRF_SHA256%3DyLIBS%20%2B%3D%20-lcryptoLIBS_p%20%2B%3D%20-lcryptoifdef%20CONFIG_TLS_ADD_DLLIBS%20%2B%3D%20-ldlLIBS_p%20%2B%3D%20-ldlendifndef%20CONFIG_TLS_DEFAULT_CIPHERSCONFIG_TLS_DEFAULT_CIPHERS%20%3D%22DEFAULT%3A!EXP%3A%EF%BC%81LOW%22endifCFLAGS%20%2B%3D%20-DTLS_DEFAULT_CIPHERS%3D%5C%22%24(CONFIG_TLS_DEFAULT_CIPHERS)%5C%22endif%20ifeq%20(%24(CONFIG_TLS)%2C%20gnutls)ifndef%20CONFIG_CRYPTO%23%20%E9%BB%98%E8%AE%A4%E4%B8%BA%20libgcryptCONFIG_CRYPTO%3Dgnutlsendififdef%20TLS_FUNCSOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_gnutls.oLIBS%20%2B%3D%20-lgnutls%20-lgpg-errorendifOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_%24(CONFIG_CRYPTO).oOBJS_p%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fcrypto_%24(CONFIG_CRYPTO).oOBJS_priv%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fcrypto_%24(CONFIG_CRYPTO).oifdef%20NEED_FIPS186_2_PRFOBJS%20%2B%3D%20...%2Fsrc%2Fcrypto%2Ffips_prf_internal.oSHA1OBJS%2B%3D...%2Fsrc%2Fcrypto%2Fsha1-internal%E3%80%82oendififeq%20(%24(CONFIG_CRYPTO)%2C%20gnutls)LIBS%20%2B%3D%20-lgcryptLIBS_p%20%2B%3D%20-lgcryptCONFIG_INTERNAL_RC4%3DyCONFIG_INTERNAL_DH_GROUP5%3Dyendififeq%20(%24(CONFIG_CRYPTO)%E3%80%81nettle)LIBS%20%2B%3D%20-lnettle%20-lgmpLIBS_p%20%2B%3D%20-lnettle%20-lgmpCONFIG_INTERNAL_RC4%3DyCONFIG_INTERNAL_DH_GROUP5%3Dyendifendif%20ifeq%20(%24(CONFIG_TLS)%2C%20internal)ifndef%20CONFIG_CRYPTOCONFIG_CRYPTO%3Dinternalendififdef%20TLS_FUNCSOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_internal-rsa.oOBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Ftls_internal.oOBJS%20%2B%3D%20.oOBJS%20%2B%3D%20.%2Fsrc%2Ftls%2Ftlsv1_common.oOBJS%20%2B%3D%20.%2Fsrc%2Ftls%2Ftlsv1_record.oOBJS%20%2B%3D%20.%2Fsrc%2Ftls%2Ftlsv1_cred.oOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_client.oOBJS%20%2B%3D%20.%2Fsrc%2Ftls%2Ftlsv1_client_write.oOBJS%20%2B%3D%20.%2Fsrc%2Ftls%2Ftlsv1_client_read.oOBJS%20%2B%3D%20.%2Fsrc%2Ftls%2Ftlsv1_client_ocsp.oOBJS%20%2B%3D%20.%2Fsrc%2Ftls%2Frsa.oOBJS%20%2B%3D%20.%2Fsrc%2Ftls%2Fx509v3.oOBJS%20%2B%3D%20.%2Fsrc%2Ftls%2Fpkcs1.oOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fpkcs5.oOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fpkcs8.oNEED_ASN1%3DyNEED_BASE64%3DyNEED_TLS_PRF%3DyifdefCONFIG_TLSV12NEED_TLS_PRF_SHA256%3DyendifNEED_MODEXP%3DyNEED_CIPHER%3DyCFLAGS%20%2B%3D%20-DCONFIG_TLS_INTERNAL_CLIENTendifdef%20NEED_CIPHERNEED_DES%3DyOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_internal-cipher.oendififdef%20NEED_MODEXPOBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fcrypto_internal-modexp.oOBJS%20%2B%3D%20.%2Fsrc%2Ftls%2Fbignum.oendififeq%20(%24(CONFIG_CRYPTO)%2C%20libtomcrypt)OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_libtomcrypt.oOBJS_p%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fcrypto_libtomcrypt.oLIBS%20%2B%3D%20-libtomcrypt.oOBJS_p%20%2B%3D%20.oLIBS%20%2B%3D%20-ltomcrypt%20-ltfmLIBS_p%20%2B%3D%20-ltomcrypt%20-ltfmCONFIG_INTERNAL_SHA256%3DyCONFIG_INTERNAL_RC4%3DyCONFIG_INTERNAL_DH_GROUP5%3Dyendififeq%20(%24(CONFIG_CRYPTO)%2C%20internal)OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_internal.oOBJS_p%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_internal.oNEED_AES_ENC%3DyCFLAGS%20%2B%3D%20-DCONFIG_CRYPTO_INTERNALifdef%20CONFIG_INTERNAL_LIBTOMMATHCFLAGS%20%2B%3D%20-DCONFIG_INTERNAL_LIBTOMMATHifdef%20CONFIG_INTERNAL_LIBTOMMATH_FASTCFLAGS%20%2B%3D%20-DLTM_FASTendifelseLIBS%20%2B%3D%20-ltommathLIBS_p%20%2B%3D%20-.ltommathendifCONFIG_INTERNAL_AES%3DyCONFIG_INTERNAL_DES%3DyCONFIG_INTERNAL_SHA1%3DyCONFIG_INTERNAL_MD4%3DyCONFIG_INTERNAL_MD5%3DyCONFIG_INTERNAL_SHA256%3DyCONFIG_INTERNAL_SHA384%3DyCONFIG_INTERNAL_SHA512%3DyCONFIG_INTERNAL_RC4%3DyCONFIG_INTERNAL_DH_GROUP5%3Dyendififeq(%24(config_crypto)%E3%80%81cryptoapi)OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_cryptoapi.oOBJS_p%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fcrypto_cryptoapi.oCFLAGS%20%2B%3D%20-DCONFIG_CRYPTO_CRYPTOAPICONFIG_INTERNAL_SHA256%3DyCONFIG_INTERNAL_RC4%3Dyendifendif%20ifeq%20(%24(CONFIG_TLS)%2C%20linux)OBJS%20%2B%3D%20...%2Fsrc%2Fcrypto%2Fcrypto_linux.oOBJS_p%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_linux.oifdef%20TLS_FUNCSOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_internal-rsa.oOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ftls_internal.oOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_common.oOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_record.oOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_cred.oOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_client.oOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Ftlsv1_client_write.oOBJS%20%2B%3D%20...%2Fsrc%2Ftls%2Ftlsv1_client_read.oOBJS%20%2B%3D%20...%2Fsrc%2Ftls%2Ftlsv1_client_ocsp.oOBJS%20%2B%3D%20...%2Fsrc%2Ftls%2Frsa.oOBJS%20%2B%3D%20...%2Fsrc%2Ftls%2Fx509v3.oOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fpkcs1.oOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fpkcs5.oOBJS%20%2B%3D%20..%2Fsrc%2Ftls%2Fpkcs8.oNEED_ASN1%3DyNEED_BASE64%3DyNEED_TLS_PRF%3DyifdefCONFIG_TLSV12NEED_TLS_PRF_SHA256%3DyendifNEED_MODEXP%3DyNEED_CIPHER%3DyCFLAGS%20%2B%3D%20-DCONFIG_TLS_INTERNAL_CLIENTendifdef%20NEED_MODEXPOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_internal-modexp.oOBJS%20%2B%3D%20.%2Fsrc%2Ftls%2Fbignum.oCFLAGS%20%2B%3D%20-DCONFIG_INTERNAL_LIBTOMMATHCFLAGS%20%2B%3D%20-DLTM_FASTendifCONFIG_INTERNAL_DH_GROUP5%3Dyifdef%20NEED_FIPS186_2_PRFOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Ffips_prf_internal.oOBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fsha1-internal.oendifendif%20ifeq%20(%24(CONFIG_TLS)%2C%20none)ifdef%20TLS_FUNCSOBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Ftls_none.oCFLAGS%20%2B%3D%20-DEAP_TLS_NONECONFIG_INTERNAL_AES%3DyCONFIG_INTERNAL_SHA1%3DyCONFIG_INTERNAL_MD5%3DyendifOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_none.oOBJS_p%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_none.oCONFIG_INTERNAL_SHA256%3DyCONFIG_INTERNAL_RC4%3Dyendif%20ifndef%20TLS_FUNCSifdef%20CONFIG_SMARTCARDifndef%20CONFIG_NATIVE_WINDOWSifneq%20(%24(CONFIG_L2_PACKET)%2C%20freebsd)LIBS%20%2B%3D%20-ldlendifendifendif%20ifndef%20TLS_FUNCSOBJS%20%2B%3D%20...%2Fsrc%2Fcrypto%2Ftls_none.oifeq%20(%24(CONFIG_TLS)%2C%20internal)CONFIG_INTERNAL_AES%3DyCONFIG_INTERNAL_SHA1%3DyCONFIG_INTERNAL_MD5%3DyCONFIG_INTERNAL_RC4%3Dyendifendif%20AESOBJS%20%3D%20%23%20%E7%9B%AE%E5%89%8D%E6%B2%A1%E6%9C%89%EF%BC%88%E8%A7%81%E4%B8%8B%E6%96%87%EF%BC%89ifdef%20CONFIG_INTERNAL_AESAESOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-internal.o%20.%2Fsrc%2Fcrypto%2Faes-internal-dec.oendif%20ifneq%20(%24(CONFIG_TLS)%2C%20openssl)ifneq%20(%24(CONFIG_TLS)%E3%80%81wolfssl)NEED_INTERNAL_AES_WRAP%3Dyendifendifdef%20CONFIG_OPENSSL_INTERNAL_AES_WRAP%23%20%E4%BC%BC%E4%B9%8E%E8%87%B3%E5%B0%91%E5%9C%A8%20BoringSSL%20%E4%B8%AD%E9%9C%80%E8%A6%81NEED_INTERNAL_AES_WRAP%3DyCFLAGS%20%2B%3D%20-DCONFIG_OPENSSL_INTERNAL_AES_WRAPendifdef%20CONFIG_FIPS%23%20%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%20AES%20%E5%AF%86%E9%92%A5%E5%B0%81%E8%A3%85%E4%BE%8B%E7%A8%8B%EF%BC%8C%E4%BB%A5%E4%BE%BF%20NEED_INTERNAL_AES_WRAP%3Dyendif%20ifdef%20NEED_INTERNAL_AES_WRAPifneq%20(%24(CONFIG_TLS)%2C%20linux)AESOBJS%20%2B%3D%20....%2Fsrc%2Fcrypto%2Faes-unwrap.oendifendifdef%20NEED_AES_EAXAESOBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Faes-eax.oNEED_AES_CTR%3Dyendifdef%20NEED_AES_SIVAESOBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Faes-siv.oNEED_AES_CTR%3Dyendifdef%20NEED_AES_CTRAESOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-ctr.oendifdef%20NEED_AES_ENCBLOCKAESOBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Faes-encblock.oendifNEED_AES_ENC%3Dyifneq%20(%24(CONFIG_TLS)%2C%20openssl)ifneq%20(%24(CONFIG_TLS)%2C%20linux)ifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)AESOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Faes-omac1.oendifendififdef%20NEED_AES_WRAPNEED_AES_ENC%3Dyifdef%20NEED_INTERNAL_AES_WRAPAESOBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Faes-wrap.oendifendififdefneed_aes_%E5%AF%86%E7%A0%81%E5%9D%97%E9%93%BE%E6%8E%A5%5C(CBC%5C)need_aes_enc%3Dyifneq%20(%24%20(CONFIG_TLS)%EF%BC%8Copenssl)%20ifneq%20(%24%20(CONFIG_TLS)%EF%BC%8Clinux)%20ifneq%20(%24%20(CONFIG_TLS)%EF%BC%8Cwolfssl)%20AESOBJS%20%2B%3D..%2Fsrc%2Fcrypto%2Faes-cbc.oendifendifdef%20need_aes_encifdef%20CONFIFDEF%20CONFIG_INTERNAL_AESAESOBJS%20%2B%3D...%2Fsrc%2Fcrypto%2Faes-internal-enc.oendiffef%20NEED_AESOBJS%20%2B%3D%20%24%20(AESOBJS)%20endif%20ifdef%20need_sha1ifneq%20(%24%20(CONFIG_TLS)%EF%BC%8Copenssl)%20ifneq%20(%24%20(CONFIG_TLS)%20ifneq%20(%24%20(CONFIG_TLS)%EF%BC%8Clinux)%20ifneq%20(%24%20(CONFIG_TLS)%20ifneq%20(%24%20(CONFIG_TLS))%2C%20wolfssl)%20SHA1OBJS%20%2B%3D..%2Fsrc%2Fcrypto%2Fsha1.oendifendifendifendifendifsha1objs%20%2B%3D..%2Fsrc%2Fcrypto%2Fsha1-prf.oifdef%20CONFIG_INTERNAL_SHA1SHA1OBJS%20%2B%3D..%2Fsrc%2Fcrypto%2Fsha1-internal.oifdef%20NEED_FIPS186_2_PRFSHA1OBJS%20%2B%3D..%2Fsrc%2Fcrypto%2Ffips_prf_internal.oendiffedef%20CONFIG_NO_WPA_PASSPHRASECFLAGS%20%2B%3D-dconfig_no_pbkdf2elseifneq%20(%24%20(CONFIG_TLS)%EF%BC%8Copenssl)%20ifneq%20(%24%20(CONFIG_TLS)%EF%BC%8Cwolfssl)%20SHA1OBJS%20%2B%3D...%2Fsrc%2Fcrypto%2Fsha1-pbkdf2.oendifd2.oendifdef%20NEED_T_PRFSHA1OBJS%20%2B%3D...%2Fsrc%2Fcrypto%2Fsha1-tprf.oendiffef%20NEED_TLS_PRFSHA1OBJS%20%2B%3D..%2Fsrc%2Fcrypto%2Fsha1-tlsprf.oendif%20ifndef%20config_fipsIFNEQ%EF%BC%88%24%EF%BC%88CONFIG_TLS%EF%BC%89%EF%BC%8Copenssl%EF%BC%89ifneq%EF%BC%88%24%EF%BC%88CONFIG_TLS%EF%BC%89%EF%BC%8Clinux%EF%BC%89ifneq%EF%BC%88%24%EF%BC%88CONFIG_TLS%EF%BC%89%EF%BC%8Cwolfssl%EF%BC%89ifneq%EF%BC%88%24%EF%BC%88CONFIG_TLS%EF%BC%89%EF%BC%8Cwolfssl%EF%BC%89MD5OBJS%20%2B%3D...%2Fsrc%2Fcrypto%2Fmd5.oendifendifendifedifendifdefNEED_MD5ifdef%20CONFIG_INTERNAL_MD5MD5OBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fmd5-internal.oendifOBJS%20%2B%3D%20%24(MD5OBJS)OBJS_p%20%2B%3D%20%24(MD5OBJS)OBJS_priv%20%2B%3D%20%24(MD5OBJS)endif%20ifdef%20NEED_MD4ifdef%20CONFIG_INTERNAL_MD4OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fmd4-internal.oendifendif%20DESOBJS%20%3D%20%23%20%E9%9D%9E%E5%86%85%E9%83%A8%E6%97%B6%E4%B8%8D%E9%9C%80%E8%A6%81ifdef%20NEED_DESifndef%20CONFIG_FIPSCFLAGS%20%2B%3D%20-DCONFIG_DESendifdef%20CONFIG_INTERNAL_DESDESOBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fdes-internal.oendifendif%20ifdef%20CONFIG_NO_RC4CFLAGS%20%2B%3D%20-DCONFIG_NO_RC4endif%20ifdef%20NEED_RC4ifdef%20CONFIG_INTERNAL_RC4ifndef%20CONFIG_NO_RC4OBJS%20%2B%3D%20...%2Fsrc%2Fcrypto%2Frc4.oendifendifif%20ifdef%20CONFIG_SAEifdef%20NEED_SHA384%23%20%E5%A6%82%E6%9E%9C%E5%90%AF%E7%94%A8%E4%BA%86%20SHA384%EF%BC%8C%E8%BF%98%E9%9C%80%E8%A6%81%E6%B7%BB%E5%8A%A0%20HMAC-SHA384%20KDF%E3%80%82NEED_HMAC_SHA512_KDF%3Dyendifendif%20SHA256OBJS%20%3D%20%23%20%E9%BB%98%E8%AE%A4%E4%B8%BA%E6%97%A0CFLAGS%20%2B%3D%20-DCONFIG_SHA256ifneq%20(%24(CONFIG_TLS)%2C%20openssl)ifneq%20(%24(CONFIG_TLS)%2C%20linux)ifneq%20(%24(CONFIG_TLS)%2C%20gnutls)ifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)SHA256OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256.oendifendifSHA256OBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fsha256-prf.oifdef%20CONFIG_INTERNAL_SHA256SHA256OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256-internal.oendifdef%20CONFIG_INTERNAL_SHA384CFLAGS%20%2B%3D%20-DCONFIG_INTERNAL_SHA384SHA256OBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fsha384-internal.oendifdef%20CONFIG_INTERNAL_SHA384CFLAGS%20%2B%3D%20-DCONFIG_INTERNAL_SHA384SHA256OBJS%20%2B%3D%20.oendififdef%20CONFIG_INTERNAL_SHA512CFLAGS%20%2B%3D%20-DCONFIG_INTERNAL_SHA512SHA256OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha512-internal.oendififdef%20NEED_TLS_PRF_SHA256SHA256OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256-tlsprf.oendififdef%20NEED_TLS_PRF_SHA384SHA256OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha384-tlsprf.oendifdef%20NEED_HMAC_SHA256_KDFCFLAGS%20%2B%3D%20-DCONFIG_HMAC_SHA256_KDFOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256-kdf.oendifdef%20NEED_HMAC_SHA384_KDFCFLAGS%20%2B%3D%20-DCONFIG_HMAC_SHA384_KDFOBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fsha384-kdf.oendifdef%20NEED_HMAC_SHA384_KDFCFLAGS%20%2B%3D%20-DCONFIG_HMAC_SHA384_KDFOBJS%20%2B%3D%20.oendififdef%20NEED_HMAC_SHA512_KDFCFLAGS%20%2B%3D%20-DCONFIG_HMAC_SHA512_KDFOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha512-kdf.oendifOBJS%20%2B%3D%20%24(SHA256OBJS)ifdef%20NEED_SHA384ifneq%20(%24(CONFIG_TLS)%2C%20openssl)ifneq%20(%24(CONFIG_TLS)%2C%20linux)ifneq%20(%24(CONFIG_TLS)%2C%20gnutls)ifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha384.oendifendifendifCFLAGS%20%2B%3D%20-DCONFIG_SHA384OBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fsha384-prf.oendififdef%20NEED_SHA512ifneq%20(%24(CONFIG_TLS)%2C%20openssl)ifneq%20(%24(CONFIG_TLS)%2C%20linux)ifneq%20(%24(CONFIG_TLS)%2C%20gnutls)ifneq%20(%24(CONFIG_TLS)%2C%20wolfssl)OBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha512.oendifendifendifCFLAGS%20%2B%3D%20-DCONFIG_SHA512OBJS%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fsha512-prf.oendif%20ifdef%20NEED_ASN1OBJS%20%2B%3D%20.%2Fsrc%2Ftls%2Fasn1.oendif%20ifdef%20NEED_DH_GROUPSOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fdh_groups.oendififdef%20NEED_DH_GROUPS_ALLCFLAGS%20%2B%3D%20-DALL_DH_GROUPSendififdef%20CONFIG_INTERNAL_DH_GROUP5ifdef%20NEED_DH_GROUPSOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fdh_group5.oendifendif%20ifdef%20NEED_ECCCFLAGS%20%2B%3D%20-DCONFIG_ECCendif%20ifdef%20CONFIG_NO_RANDOM_POOLCFLAGS%20%2B%3D%20-DCONFIG_NO_RANDOM_POOLelseifdef%20CONFIG_GETRANDOMCFLAGS%20%2B%3D%20-DCONFIG_GETRANDOMendifOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Frandom.oendif%20ifdef%20CONFIG_CTRL_IFACEifeq%20(%24(CONFIG_CTRL_IFACE)%E3%80%81y)ifdef%20CONFIG_NATIVE_WINDOWSCONFIG_CTRL_IFACE%3Dnamed_pipeelseCONFIG_CTRL_IFACE%3DunixendifendifCFLAGS%20%2B%3D%20-DCONFIG_CTRL_IFACEifeq%20(%24(CONFIG_CTRL_IFACE)%2C%20unix)CFLAGS%20%2B%3D%20-DCONFIG_CTRL_IFACE_UNIXOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fctrl_iface_common.oendififeq%20(%24(CONFIG_CTRL_IFACE)%2C%20udp)CFLAGS%20%2B%3D%20-DCONFIG_CTRL_IFACE_UDPendififeq%20(%24(CONFIG_CTRL_IFACE)%E3%80%81udp6)CONFIG_CTRL_IFACE%3DudpCFLAGS%20%2B%3D%20-DCONFIG_CTRL_IFACE_UDPCFLAGS%20%2B%3D%20-DCONFIG_CTRL_IFACE_UDP_IPV6endififeq%20(%24(CONFIG_CTRL_IFACE)%2C%20named_pipe)CFLAGS%20%2B%3D%20-DCONFIG_CTRL_IFACE_NAMED_PIPEendififeq%20(%24(CONFIG_CTRL_IFACE)%E3%80%81udp-remote)CONFIG_CTRL_IFACE%3DudpCFLAGS%20%2B%3D%20-DCONFIG_CTRL_IFACE_UDPCFLAGS%20%2B%3D%20-DCONFIG_CTRL_IFACE_UDP_REMOTEendififeq%20(%24(CONFIG_CTRL_IFACE)%E3%80%81udp6-remote)CONFIG_CTRL_IFACE%3DudpCFLAGS%20%2B%3D%20-DCONFIG_CTRL_IFACE_UDPCFLAGS%20%2B%3D%20-DCONFIG_CTRL_IFACE_UDP_REMOTECFLAGS%20%2B%3D%20-DCONFIG_CTRL_IFACE_UDP_IPV6endifOBJS%20%2B%3D%20ctrl_iface%E3%80%82octrl_iface_%24(CONFIG_CTRL_IFACE).oendif%20ifdef%20CONFIG_CTRL_IFACE_DBUS_NEWCFLAGS%20%2B%3D%20-DCONFIG_CTRL_IFACE_DBUS_NEWOBJS%20%2B%3D%20dbus%2Fdbus_dict_helpers.oOBJS%20%2B%3D%20dbus%2Fdbus_new_helpers.oOBJS%20%2B%3D%20dbus%2Fdbus_new.odbus%2Fdbus_new_handlers.oOBJS%20%2B%3D%20dbus%2Fdbus_common.oifdef%20CONFIG_WPSOBJS%20%2B%3D%20dbus%2Fdbus_new_handlers_wps.oendififdef%20CONFIG_P2POBJS%20%2B%3D%20dbus%2Fdbus_new_handlers_p2p.oendififndefDBUS_LIBSDBUS_LIBS%20%3A%3D%20%24(shell%20%24(PKG_CONFIG)%20--libs%20dbus-1)endifndef%20DBUS_INCLUDEDBUS_INCLUDE%20%3A%3D%20%24(shell%20%24(PKG_CONFIG)%20--cflags%20dbus-1)endififdef%20CONFIG_CTRL_IFACE_DBUS_INTROBJS%20%2B%3D%20dbus%2Fdbus_new_introspect.oCFLAGS%20%2B%3D%20-DCONFIG_CTRL_IFACE_DBUS_INTROendifCFLAGS%20%2B%3D%20%24(DBUS_INCLUDE)LIBS%20%2B%3D%20%24(DBUS_LIBS)endif%20ifdef%20CONFIG_READLINEOBJS_c%20%2B%3D%20...%2Fsrc%2Futils%2Fedit_readline.oLIBS_c%20%2B%3D%20-lreadline%20-lncurseselseifdef%20CONFIG_WPA_CLI_EDITOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2Fedit.oelseOBJS_c%20%2B%3D%20..%2Fsrc%2Futils%2Fedit_simple.oendifendif%20ifdef%20CONFIG_NATIVE_WINDOWSCFLAGS%20%2B%3D%20-DCONFIG_NATIVE_WINDOWSLIBS%20%2B%3D%20-lws2_32%20-lgdi32%20-lcrypt32LIBS_c%20%2B%3D%20-lws2_32LIBS_p%20%2B%3D%20-lws2_32%20-lgdi32ifeq%20(%24(CONFIG_CRYPTO)%E3%80%81cryptoapi)LIBS_p%20%2B%3D%20-lcrypt32endifendif%20ifdef%20CONFIG_NO_STDOUT_DEBUGCFLAGS%20%2B%3D%20-DCONFIG_NO_STDOUT_DEBUGifndef%20CONFIG_CTRL_IFACECFLAGS%20%2B%3D%20-DCONFIG_NO_WTDOUT_EBUGifndef%20CONFIG_CTRL_IFACECFLAGS%20%2B%3D%20-DCONFIG_NO_WTDOUT_EBUGFDCONFIG_NO_WPA_MSGendifendif%20ifdef%20CONFIG_IPV6%23%20for%20eapol_test%20onlyCFLAGS%20%2B%3D%20-DCONFIG_IPV6endif%20ifdef%20CONFIG_NO_LINUX_PACKET_SOCKET_WARCFLAGS%20%2B%3D%20-DCONFIG_NO_LINUX_PACKET_SOCKET_WARendif%20ifdef%20NEED_BASE64OBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fbase64.oendif%20ifdef%20NEED_SMEOBJS%20%2B%3D%20sme.oCFLAGS%20%2B%3D%20-DCONFIG_SMEendif%20OBJS%20%2B%3D%20.%2Fsrc%2Fcommon%2Fieee802_11_common.oOBJS%20%2B%3D%20.%2Fsrc%2Fcommon%2Fhw_features_common.o%20ifdef%20NEED_EAP_COMMONOBJS%20%2B%3D%20..%2Fsrc%2Feap_common%2Feap_common.oendif%20ifndef%20CONFIG_MAINCONFIG_MAIN%3Dmainendif%20ifdef%20CONFIG_DEBUG_SYSLOGCFLAGS%20%2B%3D%20-DCONFIG_DEBUG_SYSLOGifdef%20CONFIG_DEBUG_SYSLOG_FACILITYCFLAGS%20%2B%3D%20-DLOG_HOSTAPD%3D%22%24(CONFIG_DEBUG_SYSLOG_FACILITY)%22endifendif%20ifdef%20CONFIG_DEBUG_LINUX_TRACINGCFLAGS%20%2B%3D%20-DCONFIG_DEBUG_LINUX_TRACINGendif%20ifdef%20CONFIG_DEBUG_FILECFLAGS%20%2B%3D%20-DCONFIG_DEBUG_FILECFLAGSDCONFIG_DEBUG_FILEendif%20ifdef%20CONFIG_DELAYED_MIC_ERROR_REPORTCFLAGS%20%2B%3D%20-DCONFIG_DELAYED_MIC_ERROR_REPORTendif%20ifdef%20CONFIG_FIPSCFLAGS%20%2B%3D%20-DCONFIG_FIPSifneq%20(%24(CONFIG_TLS)%E3%80%81openssl)ifneq%20(%24(CONFIG_TLS)%E3%80%81wolfssl)%24(error%20CONFIG_FIPS%3Dy%20requires%20CONFIG_TLS%3Dopenssl)endifendifendif%20OBJS%20%2B%3D%20%24(SHA1OBJS)%20%24(DESOBJS)%20OBJS_p%20%2B%3D%20%24(SHA1OBJS)OBJS_p%20%2B%3D%20%24(SHA256OBJS)OBJS_priv%20%2B%3D%20%24(SHA1OBJS)%20ifdef%20CONFIG_BGSCAN_SIMPLECFLAGS%20%2B%3D%20-DCONFIG_FIPSDCONFIG_BGSCAN_SIMPLEOBJS%20%2B%3D%20bgscan_simple%E3%80%82oNEED_BGSCAN%3Dyendif%20ifdef%20CONFIG_BGSCAN_LEARNCFLAGS%20%2B%3D%20-DCONFIG_BGSCAN_LEARNOBJS%20%2B%3D%20bgscan_learn.oNEED_BGSCAN%3Dyendif%20ifdef%20NEED_BGSCANCFLAGS%20%2B%3D%20-DCONFIG_BGSCANOBJS%20%2B%3D%20bgscan.oendif%20ifdef%20CONFIG_AUTOSCAN_EXPONENTIALCFLAGS%20%2B%3D%20-DCONFIG_AUTOSCAN_EXPONENTIALOBJS%20%2B%3D%20autoscan_exponential%E3%80%82oNEED_AUTOSCAN%3Dyendif%20ifdef%20CONFIG_AUTOSCAN_PERIODICCFLAGS%20%2B%3D%20-DCONFIG_AUTOSCAN_PERIODICOBJS%20%2B%3D%20autoscan_periodic.oNEED_AUTOSCAN%3Dyendif%20ifdef%20NEED_AUTOSCANCFLAGS%20%2B%3D%20-DCONFIG_AUTOSCANOBJS%20%2B%3D%20autoscan.oendif%20ifdef%20CONFIG_EXT_PASSWORD_TESTTOBJS%20%2B%3D%20.%2Fsrc%2Futils%2Fext_password_test.oCFLAGS%20%2B%3D%20-DCONFIG_EXT_PASSWORD_TESTNEED_EXT_PASSWORD%3Dyendif%20ifdef%20CONFIG_EXT_PASSWORD_FILEOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fext_password_file.oCFLAGS%20%2B%3D%20-DCONFIG_EXT_PASSWORD_FILENEED_EXT_PASSWORD%3Dyendif%20ifdef%20NEED_EXT_PASSWORDOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fext_password.oCFLAGS%20%2B%3D%20-DCONFIG_EXT_PASSWORDendif%20ifdef%20NEED_GAS_SERVEROBJS%20%2B%3D%20.%2Fsrc%2Fcommon%2Fgas_server.oCFLAGS%20%2B%3D%20-DCONFIG_GAS_SERVERNEED_GAS%3Dyendif%20ifdef%20NEED_GASOBJS%20%2B%3D%20.%2Fsrc%2Fcommon%2Fgas.oOBJS%20%2B%3D%20gas_query.oCFLAGS%20%2B%3D%20-DCONFIG_GASNEED_OFFCHANNEL%3Dyendif%20ifdef%20NEED_OFFCHANNELOBJS%20%2B%3D%20offchannel.oCFLAGS%20%2B%3D%20-DCONFIG_OFFCHANNELendif%20ifdef%20NEED_JSONOBJS%20%2B%3D%20..%2Fsrc%2Futils%2Fjson.oCFLAGS%20%2B%3D%20-DCONFIG_JSONendif%20ifdef%20CONFIG_MODULE_TESTSCFLAGS%20%2B%3D%20-DCONFIG_MODULE_TESTSOBJS%20%2B%3D%20wpas_module_tests.oOBJS%20%2B%3D%20.%2Fsrc%2Futils%2Futils_module_tests.oOBJS%20%2B%3D%20..%2Fsrc%2Fcommon%2Fcommon_module_tests.oOBJS%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_module_tests.oifdef%20CONFIG_WPSOBJS%20%2B%3D%20...%2Fsrc%2Fwps%2Fwps_module_tests.oendifendif%20OBJS%20%2B%3D%20..%2Fsrc%2Fdrivers%2Fdriver_common.oOBJS_priv%20%2B%3D%20..%2Fsrc%2Fdrivers%2Fdriver_common.o%20OBJS%20%2B%3D%20wpa_supplicant.o%E4%BA%8B%E4%BB%B6.obssid_ignore.owpas_glue.oscan.oOBJS_t%3A%3D%20%24(OBJS)%20%24(OBJS_l2)%20eapol_test.oOBJS_t%2B%3D%20..%2Fsrc%2Fradius%2Fradius_client.oOBJS_t%20%2B%3D%20..%2Fsrc%2Fradius%2Fradius.oifdef%20CONFIG_RADIUS_TLSCFLAGS%20%2B%3D%20-DCONFIG_RADIUS_TLSendifOBJS_t2%20%3A%3D%20%24(OBJS)%20%24(OBJS_l2)%20preauth_test.o%20OBJS_nfc%20%3A%3D%20%24(OBJS)%20%24(OBJS_l2)%20nfc_pw_token.oOBJS_nfc%2B%3D%20%24(OBJS_d)%20..%2Fsrc%2Fdrivers%2Fdrivers.o%20OBJS%20%2B%3D%20%24(CONFIG_MAIN).o%20ifdef%20config_privsepObjs_priv%20%2B%3D%20%24%20(objs_D)..%2Fsrc%2Fdrivers%2Fdrivers.oobjs_priv%20%2B%3D%20%24%20(objs_L2)%20objs_priv%20%2B%3D..%2Fsrc%2Futils%2Fos_%20%24%20(CONFIG_OS)%20.oobjs_priv%20%2B%3D..%2Fsrc%2Futils%2F%20%24%20(CONFIG_ELOOP)%20.oobjs_priv%20%2B%3D..%2Fsrc%2Futils%2Fcommon.oobjs_priv%20%2B%3D..%2Fsrc%2Futils%2Fwpa_debug.oobjs_priv%20%2B%3D..%2Fsrc%2Futils%2Fwpabuf.oobjs_priv%20%2B%3D%20wpa_priv.oifdef%20config_driver_nl80211objs_priv%20%2B%3D...%2Fsrc%2Fcommon%2FIEEE802_11_common.oendifobJS%20%2B%3D..%2Fsrc%2Fl2_packet%2Fl2_packet_privsep.oobjs%20%2B%3D..%2Fsrc%2FDrivers%2Fdriver_privsep.oextra_progs%20%2B%3D%20wpa_privelseOBJS%20%2B%3D%20%24%20(objs_D)..%2Fsrc%2Fdrivers%2Fdrivers.OOBJS%20%2B%3D%20%24%20(objs_L2)%20endif%20ifdef%20CONFIG_NDIS_EVENTS_INTEGRATEDCFLAGS%20%2B%3D-DCONFIG_NDIS_EVENTS_EVENTS_INTEGRATEDOBJS%20%2B%3D...%2Fsrc%2Fdrivers%2Fndis_events.oextraLibs%20%2B%3D-loleaut32-lole32-luuidifdef%20PLATFORMSDKLIBEXTRALIBS%20%2B%3D%20%24%20(PLATFORMSDKLIB)%20%2Fwbemuid.libelseExtraLibs%20%2B%3D%20wbemuid.libendifendif%20ifdef%20PLATFORMSDKLIBS%20%2B%3D-dconfig_fstifFLAGS%20%2B%3D-dconfig_fstifFLAGS%20%2B%3D-dconfig_fstifFLAGS%20%2B%3D-dconfig_def%20CONFIG_FST_TESTCFLAGS%20%2B%3D-dconfig_fst_testenDiffst_objs%20%2B%3D..%2Fsrc%2Ffst%2Ffst.ofst_objs%20%2B%3D..%2Fsrc%2Ffst%2Ffst_session.ofst_objs%20%2B%3D..%2Fsrc%2Ffst%2Ffst_iface.ofst_objs%20%2B%3D..%2Fsrc%2Ffst%2Ffst_group.ofst_objs%20%2B%3D..%2Fsrc%2Ffst%2Ffst_ctrl_aux.oifdef%20CONFIG_CTRL_IFACEFST_OBJS%20%2B%3D..%2Fsrc%2Ffst%2Ffst_ctrl_iface.OENDIFOBJS%20%2B%3D%20%24%20(FST_OBJS)%20objs_T%20%2B%3D%20%24%20(FST_OBJS)%20objs_t2%20%2B%3D%20%24%20(FST_OBJS)%20objs_NFC%20%2B%3D%20%24%20(FST_OBJS)%20endif%20ifdef%20CONFIG_WEPCFLAGS%20%2B%3D-dconfig_wependif%20ifdef%20CONFIG%20_NO_TKIPCFLAGS%20%2B%3D-dconfig_no_tkipendif%20dynamic_eap_methods%EF%BC%9A%24%20(EAPDYN)%20_OBJS_VAR%3A%20%3D%20objs_privInclude..%2Fsrc%2Fobjs.mkwpa_priv%EF%BC%9A%24%20(BCHECK)%20%24%20(OBJS_PRIV)%20%24%20(Q)%20%24%20(%E4%BD%8E%E5%8E%8B%E5%B7%AE%E7%BA%BF%E6%80%A7%E7%A8%B3%E5%8E%8B%E5%99%A8(LDO))-o%20wpa_priv%20%24%20(objs_priv)%20%24%20(LIBS)%20%40%24%20(E)%20%22%20LD%20%22%20%24%40%40%20_objs_VAR%3A%20%3D%20objsInclude..%2Fsrc%2Fobjs.mkwpa_supplicant%EF%BC%9A%24%20(BCHECK)%20%24%20(OBJS)%20%24%20(Extra_Progs)%20%24%20(Q)%20%24%20(%E4%BD%8E%E5%8E%8B%E5%B7%AE%E7%BA%BF%E6%80%A7%E7%A8%B3%E5%8E%8B%E5%99%A8(LDO))-o%20wpa_supplicant%20%24%20(OBJS)%20%24%20(IBS)%20%24%20(EXTRALIBS)%20%40%24%20(E)%20%22%20LD%20%22%20%24%40%40%20_OBJS_VAR%3A%20%3D%20objs_tInclude..%2Fsrc%2Fobjs.mkeapol_test%EF%BC%9A%24%20(objs_T)%20%24%20(Q)%20%24%20(%E4%BD%8E%E5%8E%8B%E5%B7%AE%E7%BA%BF%E6%80%A7%E7%A8%B3%E5%8E%8B%E5%99%A8(LDO))%20%24%20(%E4%BD%8E%E5%8E%8B%E5%B7%AE%E7%BA%BF%E6%80%A7%E7%A8%B3%E5%8E%8B%E5%99%A8(LDO))%20%24%20(LDFLAGS)-o%20eapol_test%20%24%20(objs_T)%20%24%20(LIBS)%20%40%24%20(E)%20%22%20LD%20%22%20%24%40%40%20_objs_var%3A%20%3D%20objs_t2include%E3%80%82%E3%80%82%2Fsrc%2Fobjs.mkpreauth_test%EF%BC%9A%24%20(objs_t2)%20%24%20(Q)%20%24%20(%E4%BD%8E%E5%8E%8B%E5%B7%AE%E7%BA%BF%E6%80%A7%E7%A8%B3%E5%8E%8B%E5%99%A8(LDO))%20%24%20(LDFLAGS)-o%20preauth_test%20%24%20(objs_t2)%20%24%20(LIBS)%20%40%24%20(E)%20%22%20LD%20%22%20%24%40%40%20_objs_VAR%3A%20%3D%20objs_pInclude..%2Fsrc%2Fobjs.mkwpa_passphrase%EF%BC%9A%24%20(OBJS_P)%20%24%20(Q)%20%24%20(%E4%BD%8E%E5%8E%8B%E5%B7%AE%E7%BA%BF%E6%80%A7%E7%A8%B3%E5%8E%8B%E5%99%A8(LDO))%20%24%20(LDFLAGS)-o%20wpa_passphrase%20%24%20(objs_P)%20%24%20(libs_P)%20%24%20(LIBS)%20%40%24%20(E)%20%22%20LD%20%22%20%24%40%40%20_objs_VAR%3A%20%3D%20objs_cInclude..%2Fsrc%2Fobjs.mkwpa_cli%EF%BC%9A%24%20(objs_C)%20%24%20(Q)%20%24%20(%E4%BD%8E%E5%8E%8B%E5%B7%AE%E7%BA%BF%E6%80%A7%E7%A8%B3%E5%8E%8B%E5%99%A8(LDO))%20%24%20(LDFLAGS)-o%20wpa_cli%20%24%20(objs_C)%20%24%20(libs_C)%20%40%24%20(E)%20%22%20LD%20%22%20%24%40%40%20libCtrl%20%2B%3D...%2Fsrc%2Fcommon%2Fwpa_ctrl.olibCtrl%20%2B%3D..%2Fsrc%2Futils%2Fos_%20%24%20(CONFIG_OS)%20.olibCtrl%20%2B%3D..%2Fsrc%2Futils%2Fcommon.olibCtrl%20%2B%3D..%2Fsrc%2Futils%2Fwpa_debug.olibCtrlsO%20%2B%3D..%2Fsrc%2Fcommon%2Fwpa_ctrl.clibCtrlsO%20%2B%3D..%2Fsrc%2Futils%2Fos_%20%24%20(CONFIG_OS)%20.clibCtrlSO%20%2B%3D..%2Fsrc%2Futils%2Fcommon.clibCtrlsO%20%2B%3D..%2Fsrc%2Futils%2Fwpa_debug.c%20_OBJS_VAR%3A%20%3D%20libCtrlInclude..%2Fsrc%2Fobjs.mklibwpa_client.a%3A%24(LIBCTRL)%24(Q)rm%20-f%20%24%40%24(Q)%24(AR)%20crs%20%24%40%20%24%3F%40%24(E)%22%20AR%22%20%24%40%20libwpa_client.so%EF%BC%9A%24(LIBCTRLSO)%40%24(E)%22%20CC%20%24%40%20(%24%5E)%22%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-fPIC%20%24%5E%20OBJS_wpatest%20%3A%3D%20libwpa_test.o_OBJS_VAR%3A%3D%20objs_wpatestInclude..%2Fsrc%2Fobjs.mklibwpa_test1%EF%BC%9A%24%20(objs_WPatest)%20libwpa_client.a%24%20(Q)%20%24%20(%E4%BD%8E%E5%8E%8B%E5%B7%AE%E7%BA%BF%E6%80%A7%E7%A8%B3%E5%8E%8B%E5%99%A8%5C(LDO%5C))%24(LDFLAGS)%20-o%20libwpa_test1%20%24(OBJS_wpatest)%20libwpa_client.a%24%20(libs_C)%20%40%24%20(E)%20%22%20LD%20%22%20%24%40%40%20libwpa_test2%EF%BC%9A%24%20(objs_wpatest)%20libwpa_Client.so%24%20(q)%20%E4%BD%8E%E5%8E%8B%E5%B7%AE%E7%BA%BF%E6%80%A7%E7%A8%B3%E5%8E%8B%E5%99%A8%5C(LDO%5C)%24(LDFLAGS)%20-o%20libwpa_test2%20%24(OBJS_wpatest)%20-L.-lwpa_client%20%24%20(libs_C)%20%40%24%20(E)%20%22%20LD%20%22%20%24%40%40%20_objs_var%3A%20%3D%20objs_nfcInclude..%2Fsrc%2Fobjs.mknfc_pw_token%EF%BC%9A%24%20(OBJS_NFC)%20%24%20(Q)%20%24%20(LDO)%20%24%20(LDFLAGS)-o%20nfc_pw_token%20%24%20(objs_NFC)%20%24%20(LIBS)%20%40%24%20(E)%20%22%20LD%20%22%20%24%40%40%20win_if_List%EF%BC%9Awin_if_list.c%24%20(Q)%20%24%20(LDO)%20%24%20(LDO)%24(LDFLAGS)%20-o%20%24%40%20win_if_list.c%24(CFLAGS)%20%24(LIBS_w)%40%24(E)%22%20LD%22%20%24%40%20eap_psk.so%EF%BC%9A%24(SRC_EAP_PSK)%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C-Deap_peer_psk_register%3Deap_peer_method_dynamic_init%40%24(E)%22%20CC%2FLD%22%20%24%40%40%20eap_pax.so%EF%BC%9A%24(SRC_EAP_PAX)%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%40%24(E)%22%20CC%2FLD%22%20%24%40%40%20eap_peap.so%EF%BC%9A%24(SRC_EAP_PEAP)%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%40%24(E)%22%20CC%2FLD%22%20%24%40%40%20eap_sake.so%EF%BC%9A%24(SRC_EAP_SAKE)%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%40%24(E)%22%20CC%2FLD%22%20%24%40%40%20eap_ikev2.so%EF%BC%9A%24(SRC_EAP_IKEV2)%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%40%24(E)%22%20CC%2FLD%22%20%24%40%40%20eap_eke.so%EF%BC%9A%24(SRC_EAP_EKE)%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%40%24(E)%22%20CC%2FLD%22%20%24%40%40%20eap_mschapv2.so%EF%BC%9A%24(SRC_EAP_MSCHAPV2)%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%40%24(E)%22%20CC%2FLD%22%20%24%40%40%20eap_fast.so%EF%BC%9A%24(SRC_EAP_FAST)%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%40%24(E)%22%20CC%2FLD%22%20%24%40%40%20eap_teap.so%EF%BC%9A%24(SRC_EAP_TEAP)%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%40%24(E)%22%20CC%2FLD%22%20%24%40%40%20eap_gpsk.so%EF%BC%9A%24(SRC_EAP_GPSK)%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%5E%20%5C-D%24(%40F%3Aeap_%25.so%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%40%24(E)%22%20CC%2FLD%22%20%24%40%20%24%40%25.so%3A%20..%2Fsrc%2Feap_peer%2F%25.c%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(CFLAGS)%20-shared%20-rdynamic%20-fPIC%20%24%26lt%3B%20%5C-D%24(*F%3Aeap_%25%3Deap_peer_%25)_register%3Deap_peer_method_dynamic_init%40%24(E)%22%20CC%2FLD%22%20%24%40%25.service%3A%25.service.in%24(Q)sed-e%20's%7C%5C%40BINDIR%5C%40%7C%24(BINDIR)%7Cg'%20%24%26lt%3B%20%26gt%3B%20%24%40%40%24(E)%22%20sed%22%20%24%26lt%3B%20%25%20%40.service%3A%25.service.arg.in%24(Q)sed-e%20's%7C%5C%40BINDIR%5C%40%7C%24(BINDIR)%7Cg'%20%24%26lt%3B%20%26gt%3B%20%24%40%40%24(E)%22%20sed%22%20%24%26lt%3B%20wpa_supplicant.exe%EF%BC%9Awpa_supplicantmv%20-f%20%24%26lt%3B%20%24%40wpa_cli.exe%EF%BC%9Awpa_climv%20-f%20%24%26lt%3B%20%24%40wpa_passphrase.exe%EF%BC%9Awpa_passphrasemv%20-f%20%24%26lt%3B%20%24%40win_if_list.exe%EF%BC%9Awin_if_listmv%20-f%20%24%26lt%3B%20%24%40eapol_test.exe%EF%BC%9Aeapol_testmv%20-f%20%24%26lt%3B%20%24%40%20WINALL%3Dwpa_supplicant.exe%20wpa_cli.exe%20wpa_passphrase.exe%20win_if_list.exe%20windows-bin%3A%20%24(WINALL)%24(STRIP)%20%24(WINALL)%20wpa_gui%3A%22wpa_gui%20%E5%B7%B2%E8%A2%AB%E7%A7%BB%E9%99%A4%20-%20%E8%AF%B7%E5%8F%82%E9%98%85%20wpa_gui-qt4%20%E4%BB%A5%E8%8E%B7%E5%8F%96%E6%9B%BF%E4%BB%A3%22%20wpa_gui-qt4%2FMakefile%3Aqmake%20-o%20wpa_gui-qt4%2FMakefile%20wpa_gui-qt4%2Fwpa_gui.pro%20wpa_gui-qt4%2Flang%2Fwpa_gui_de.qm%EF%BC%9Awpa_gui-qt4%2Flang%2Fwpa_gui_de.tslrelease%20wpa_gui-qt4%2Fwpa_gui.pro%20wpa_gui-qt4%3A%20wpa_gui-qt4%2FMakefile%20wpa_gui-qt4%2Flang%2Fwpa_gui_de.qm%24(MAKE)-C%20wpa_gui-qt4%20FIPSDIR%3D%2Fusr%2Flocal%2Fssl%2Ffips-2.0FIPSLD%3D%24(FIPSDIR)%2Fbin%2Ffipsldfips%3A%24(MAKE)CC%3D%24(FIPSLD)%20FIPSLD_CC%3D%22%24(CC)%22.PHONY%EF%BC%9Alcov-htmllcov-html%EF%BC%9A%24(call%20BUILDOBJ%2Cwpa_supplicant.gcda)lcov%20-c%20-d%20%24(BUILDDIR)%26gt%3B%20lcov.infogenhtml%20lcov.info%20--output-directory%20lcov-html%20PASN_CFLAGS%20%3A%3D%20%24(CFLAGS)PASN_CFLAGS%20%2B%3D%20-DCONFIG_PASN%20LIBPASNSO%20%3A%3D%20..%2Fsrc%2Futils%2F%24(CONFIG_ELOOP).cLIBPASNSO%20%2B%3D%20.%2Fsrc%2Futils%2Fwpa_debug.cLIBPASNSO%20%2B%3D%20.%2Fsrc%2Futils%2Fwpabuf.cLIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Fos_%24(CONFIG_OS).cLIBPASNSO%20%2B%3D%20.%2Fsrc%2Futils%2Fconfig.cLIBPASNSO%20%2B%3D%20.%2Fsrc%2Futils%2Fcommon.c%20ifdef%20NEED_BASE64LIBPASNSO%20%2B%3D%20.%2Fsrc%2Futils%2Fbase64.cLIBPASNSO%20%2B%3D%20.%2Fsrc%2Futils%2Fbase64.cLIBPASNSO%20%2B%3D%20.cendif%20ifdef%20CONFIG_WPA_TRACELIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Ftrace.cendif%20ifdef%20CONFIG_EXT_PASSWORD_FILELIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Fext_password_file.cendif%20ifdef%20CONFIG_EXT_PASSWORD_TESTLIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Fext_password_test.cendif%20ifdef%20NEED_EXT_PASSWORDLIBPASNSO%20%2B%3D%20..%2Fsrc%2Futils%2Fext_password.cendif%20ifdef%20CONFIG_SAELIBPASNSO%20%2B%3D%20.%2Fsrc%2Fcommon%2Fsae.cendif%20ifdef%20CONFIG_SAE_PKLIBPASNSO%20%2B%3D%20.%2Fsrc%2Fcommon%2Fsae_pk.cendif%20ifndef%20CONFIG_NO_WPALIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcommon%2Fwpa_common.cendif%20LIBPASNSO%20%2B%3D%20.%2Fsrc%2Fcommon%2Fieee802_11_common.c%20ifdef%20NEED_DRAGONFLYLIBPASNSO%20%2B%3D%20.%2Fsrc%2Fcommon%2Fdragonfly.cendif%20LIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcommon%2Fptksa_cache.cLIBPASNSO%20%2B%3D%20..%2Fsrc%2Frsn_supp%2Fpmksa_cache.c%20ifndef%20CONFIG_NO_WPALIBPASNSO%20%2B%3D%20..%2Fsrc%2Frsn_supp%2Fwpa_ie.cendif%20LIBPASNSO%20%2B%3D%20..%2Fsrc%2Fap%2Fcomeback_token.cLIBPASNSO%20%2B%3D%20..%2Fsrc%2Fap%2Fpmksa_cache_auth.c%20ifdef%20NEED_EAP_COMMONLIBPASNSO%20%2B%3D%20..%2Fsrc%2Feap_common%2Feap_common.cendif%20ifdef%20CHAPLIBPASNSO%20%2B%3D%20..%2Fsrc%2Feap_common%2Fchap.cendif%20ifdef%20CONFIG_IEEE8021X_EAPOLLIBPASNSO%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap.cLIBPASNSO%20%2B%3D%20..%2Fsrc%2Feap_peer%2Feap_methods.cLIBPASNSO%20%2B%3D%20.%2Fsrc%2Feapol_supp%2Feapol_supp_sm.cendif%20ifeq%20(%24(CONFIG_TLS)%2C%20wolfssl)LIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_wolfssl.cifdef%20TLS_FUNCSLIBPASNSO%20%2B%3D%20.%2Fsrc%2Fcrypto%2Ftls_wolfssl.cNEED_TLS_PRF_SHA256%3DyLIBPASNSO%20%2B%3D%20-lwolfssl%20-lmendifendif%20ifeq%20(%24(CONFIG_TLS)%2C%20openssl)LIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_openssl.cifdef%20TLS_FUNCSLIBPASNSO%20%2B%3D%20.%2Fsrc%2Fcrypto%2Ftls_openssl.cLIBPASNSO%20%2B%3D%20-lssl%20-lcryptoNEED_TLS_PRF_SHA256%3Dyendifendif%20ifeq%20(%24(CONFIG_TLS)%2C%20gnutls)LIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fcrypto_%24(CONFIG_CRYPTO).cifdef%20TLS_FUNCSLIBPASNSO%20%2B%3D%20.%2Fsrc%2Fcrypto%2Ftls_gnutls.cLIBPASNSO%20%2B%3D%20-lgnutls%20-lgpg-errorLIBPASNSO%20%2B%3D%20-lgcryptendifendif%20ifdef%20NEED_TLS_PRF_SHA256LIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256-tlsprf.cendif%20ifdef%20NEED_SHA512LIBPASNSO%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fsha512-prf.cendif%20ifdef%20NEED_SHA384LIBPASNSO%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fsha384-prf.cendif%20LIBPASNSO%20%2B%3D%20-lgcryptendifcendif%20LIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256-prf.c%20ifdef%20NEED_HMAC_SHA512_KDFLIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha512-kdf.cendif%20ifdef%20NEED_HMAC_SHA384_KDFLIBPASNSO%20%2B%3D%20...%2Fsrc%2Fcrypto%2Fsha384-kdf.cendif%20ifdef%20NEED_HMAC_SHA256_KDFLIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha256-kdf.cendif%20ifdef%20NEED_DH_GROUPSLIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fdh_groups.cendif%20ifdef%20NEED_AES_SIVLIBPASNSO%20%2B%3D%20.%2Fsrc%2Fcrypto%2Faes-siv.cendif%20ifdef%20NEED_AES_CTRLIBPASNSO%20%2B%3D%20.%2Fsrc%2Fcrypto%2Faes-ctr.cendif%20ifdef%20NEED_SHA1LIBPASNSO%20%2B%3D%20.%2Fsrc%2Fcrypto%2Fsha1-prf.cifdef%20NEED_TLS_PRFLIBPASNSO%20%2B%3D%20..%2Fsrc%2Fcrypto%2Fsha1-tlsprf.cendifendif%20LIBPASNSO%20%2B%3D%20.%2Fsrc%2Fpasn%2Fpasn_initiator.cLIBPASNSO%20%2B%3D%20.%2Fsrc%2Fpasn%2Fpasn_responder.cLIBPASNSO%20%2B%3D%20.%2Fsrc%2Fpasn%2Fpasn_common.c%20libpasn.so%EF%BC%9A%24(LIBPASNSO)%40%24(E)%22%20CC%20%24%40%20(%24%5E)%22%24(Q)%24(CC)%20%24(LDFLAGS)%20-o%20%24%40%20%24(PASN_CFLAGS)%20-shared%20-fPIC%20-lcrypto%20%24%5E%20clean%3A%20common-clean%24(MAKE)%20-C%20..%2Fsrc%20clean%24(MAKE)%20-C%20dbus%20cleanrm%20-f%20core%20*~%20*.o%20*.d%20*.gcno%20*.gcda%20*.gcovrm%20-f%20eap_*.so%24%20(WINALL)%20eapol_test%20preauth_testrm-f%20wpa_privrm-f%20nfc_pw_tokenrm-f%20lcov.inform-rf%20lcov-htmlrm-f%20libwpa_client.arm-f%20libwpa_test2rm-f%20libwpa_test2rm-f%20libwpa_test2rm-f%20libwpa_test2rm-f%20libwpa_test2rm-f%20libwpa_test2rm-f%20libwpa_test2rm%20%E7%9F%AD%E8%AF%AD%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AW611%20WiFi%20chip%20Wi-Fi%20scan%20timeout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E7%BC%96%E8%AF%91%E4%BA%86%20wpa_supplicant(wpa_supplicant-2.11)%E3%80%82%E8%AF%B7%E6%8C%89%E7%85%A7%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E6%96%87%E4%BB%B6%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%E5%94%AF%E4%B8%80%E4%B8%8D%E5%90%8C%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%E7%89%88%E6%9C%AC%E6%98%AF%20libnl-3.11.0%20%E5%92%8C%20openssl-3.5.0%EF%BC%88%E6%88%91%E5%B7%B2%E7%BB%8F%E4%B8%8B%E8%BD%BD%E4%BA%86%EF%BC%89%E3%80%82%E7%BC%96%E8%AF%91%E6%97%B6%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%A5%E6%A0%BC%E9%81%B5%E5%BE%AA%E4%BA%86%E6%82%A8%E7%9A%84%E6%8C%87%E7%A4%BA%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E5%9C%A8%E4%BD%BF%E7%94%A8%E6%9C%80%E7%BB%88%E7%BC%96%E8%AF%91%E7%9A%84%20wpa_supplicant%20%E5%92%8C%20wpa_cli%20%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E6%97%B6%EF%BC%8C%E6%89%AB%E6%8F%8F%20Wi-Fi%20%E4%BB%8D%E4%BC%9A%E8%B6%85%E6%97%B6%EF%BC%8C%E6%97%A5%E5%BF%97%E4%B9%9F%E4%B8%8E%E4%B9%8B%E5%89%8D%E4%B8%80%E6%A0%B7%E3%80%82%E9%99%84%E4%B8%8A%20.config%E5%92%8C%E7%BC%96%E8%AF%91%20wpa_supplicant-2.11%20%E6%97%B6%E4%BD%BF%E7%94%A8%E7%9A%84%20Makefile%E3%80%82%E6%82%A8%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E4%BC%BC%E4%B9%8E%E6%97%A0%E6%B3%95%E4%B8%8A%E4%BC%A0%E9%99%84%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2026-03-26_16-44-08.jpg%22%20style%3D%22width%3A%20847px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2026-03-26_16-44-08.jpg%22%20style%3D%22width%3A%20847px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2026-03-26_16-44-08.jpg%22%20style%3D%22width%3A%20847px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2026-03-26_16-44-08.jpg%22%20style%3D%22width%3A%20847px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2026-03-26_16-44-08.jpg%22%20style%3D%22width%3A%20847px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2026-03-26_16-44-08.jpg%22%20style%3D%22width%3A%20847px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2026-03-26_16-44-08.jpg%22%20style%3D%22width%3A%20847px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380470i3A5415A70D0288C6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snipaste_2026-03-26_16-44-08.jpg%22%20alt%3D%22Snipaste_2026-03-26_16-44-08.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%89%A7%E9%80%8F%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E9%AB%98%E4%BA%AE%E9%83%A8%E5%88%86%E5%8F%AF%E4%BE%9B%E9%98%85%E8%AF%BB%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%3CP%3E%23%20%E7%A4%BA%E4%BE%8B%20wpa_supplicant%20%E7%BC%96%E8%AF%91%E6%97%B6%E9%85%8D%E7%BD%AE%20%3CBR%20%2F%3E%20%23%20%23%20%E6%AD%A4%E6%96%87%E4%BB%B6%E5%88%97%E5%87%BA%E4%BA%86%E6%9E%84%E5%BB%BA%20%3CBR%20%2F%3E%20%23%20wpa_supplicant%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E6%97%B6%E4%BD%BF%E7%94%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E9%80%89%E9%A1%B9%E3%80%82%3CBR%20%2F%3E%E6%89%80%E6%9C%89%E4%BB%A5%20%23%20%E5%BC%80%E5%A4%B4%E7%9A%84%E8%A1%8C%E9%83%BD%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%E3%80%82%E9%85%8D%E7%BD%AE%3CBR%20%2F%3E%23%20%E5%A6%82%E6%9E%9C%E4%B8%8D%E5%8C%85%E6%8B%AC%E9%80%89%E9%A1%B9%E8%A1%8C%EF%BC%8C%E5%88%99%E5%BF%85%E9%A1%BB%E5%B0%86%E5%85%B6%E5%AE%8C%E6%95%B4%E6%B3%A8%E9%87%8A%E5%87%BA%E6%9D%A5%EF%BC%8C%3CBR%20%2F%3E%23%20%E4%B9%9F%E5%B0%B1%E6%98%AF%E8%AF%B4%EF%BC%8C%E4%BB%85%E4%BB%85%E8%AE%BE%E7%BD%AE%20VARIABLE%3Dn%20%E5%B9%B6%E4%B8%8D%E8%83%BD%E7%A6%81%E7%94%A8%E8%AF%A5%E5%8F%98%E9%87%8F%E3%80%82%3CBR%20%2F%3E%23%3CBR%20%2F%3E%23%20%E6%AD%A4%E6%96%87%E4%BB%B6%E5%8C%85%E5%90%AB%E5%9C%A8%20Makefile%20%E4%B8%AD%EF%BC%8C%E5%9B%A0%E6%AD%A4%20CFLAGS%20%E5%92%8C%20LIBS%20%E7%AD%89%E5%8F%98%E9%87%8F%E4%B9%9F%E5%8F%AF%E4%BB%A5%3CBR%20%2F%3E%23%20%E4%BB%8E%E8%BF%99%E9%87%8C%E4%BF%AE%E6%94%B9%E3%80%82%E5%9C%A8%E5%A4%A7%E5%A4%9A%E6%95%B0%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E8%BF%99%E4%BA%9B%E8%A1%8C%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20%2B%3D%20%E4%BB%A5%E9%81%BF%E5%85%8D%3CBR%20%2F%3E%23%20%E8%A6%86%E7%9B%96%E5%8F%98%E9%87%8F%E4%BB%A5%E5%89%8D%E7%9A%84%E5%80%BC%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%23%20%E5%A6%82%E6%9E%9C%E5%9C%A8%E9%9D%9E%E9%BB%98%E8%AE%A4%E4%BD%8D%E7%BD%AE%E5%AE%89%E8%A3%85%E4%BA%86%20OpenSSL%3CBR%20%2F%3E%23%20%E6%88%96%20GnuTLS%3CBR%20%2F%3E%23CFLAGS%20%2B%3D%20-I%2Fusr%2Flocal%2Fopenssl%2Finclude%3CBR%20%2F%3E%23LIBS%20%2B%3D%20-L%2Fusr%2Flocal%2Fopenssl%2Flib%3C%2FP%3E%3CP%3E%23%20%E6%9F%90%E4%BA%9B%20Red%20Hat%20%E7%89%88%E6%9C%AC%E4%BC%BC%E4%B9%8E%E5%8C%85%E5%90%AB%20OpenSSL%20%E7%9A%84%20kerberos%20%E5%A4%B4%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%3CBR%20%2F%3E%23%20%E9%BB%98%E8%AE%A4%E5%8C%85%E5%90%AB%E8%B7%AF%E5%BE%84%E4%B8%AD%E6%B2%A1%E6%9C%89%20kerberos%20%E6%96%87%E4%BB%B6%E3%80%82%E4%BB%A5%E4%B8%8B%E8%A1%8C%E5%8F%AF%E7%94%A8%E4%BA%8E%20%3CBR%20%2F%3E%20%23%20%E4%BF%AE%E5%A4%8D%E6%AD%A4%E7%B1%BB%E7%B3%BB%E7%BB%9F%E4%B8%8A%E7%9A%84%E7%89%88%E6%9C%AC%E9%97%AE%E9%A2%98%20(krb5.h)%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%89%E3%80%82%3CBR%20%2F%3E%23CFLAGS%20%2B%3D%20-I%2Fusr%2Finclude%2Fkerberos%3C%2FP%3E%3CP%3E%23%20%E9%80%9A%E7%94%A8%20Linux%20%E6%97%A0%E7%BA%BF%E6%89%A9%E5%B1%95%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3E%23%20%E6%B3%A8%E6%84%8F%EF%BC%9AWEXT%20%E5%9C%A8%E5%BD%93%E5%89%8D%E7%9A%84%20Linux%20%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E4%B8%AD%E5%B7%B2%E8%A2%AB%E5%BC%83%E7%94%A8%EF%BC%8C%E4%B9%9F%E6%B2%A1%E6%9C%89%E4%B8%BA%E5%85%B6%E6%B7%BB%E5%8A%A0%E6%96%B0%E7%9A%84%3CBR%20%2F%3E%23%20%E5%8A%9F%E8%83%BD%E3%80%82%E5%9F%BA%E4%BA%8E%20nl80211%20%E7%9A%84%E6%8E%A5%E5%8F%A3%E6%98%AF%20WEXT%20%E7%9A%84%E6%96%B0%3CBR%20%2F%3E%23%20%E6%9B%BF%E4%BB%A3%E5%93%81%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%AE%83%E5%8F%AF%E4%BB%A5%E8%AE%A9%20wpa_supplicant%20%E6%AD%A3%E7%A1%AE%E6%8E%A7%E5%88%B6%3CBR%20%2F%3E%23%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BB%A5%E6%94%B9%E8%BF%9B%E7%8E%B0%E6%9C%89%E5%8A%9F%E8%83%BD%EF%BC%88%E5%A6%82%E6%BC%AB%E6%B8%B8%EF%BC%89%E5%B9%B6%E6%94%AF%E6%8C%81%E6%96%B0%E7%9A%84%3CBR%20%2F%3E%23%20%E5%8A%9F%E8%83%BD%E3%80%82%3CBR%20%2F%3ECONFIG_DRIVER_WEXT%3Dy%3C%2FP%3E%3CP%3E%23%20%E4%BD%BF%E7%94%A8%20nl80211%20%E5%86%85%E6%A0%B8%E6%8E%A5%E5%8F%A3%E7%9A%84%20Linux%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3ECONFIG_DRIVER_NL80211%3Dy%3C%2FP%3E%3CP%3E%23%20QCA%20%E4%BE%9B%E5%BA%94%E5%95%86%E5%AF%B9%20nl80211%20%E7%9A%84%E6%89%A9%E5%B1%95%3CBR%20%2F%3E%23CONFIG_DRIVER_NL80211_QCA%3Dy%3C%2FP%3E%3CP%3E%23%20driver_nl80211.c%E9%9C%80%E8%A6%81%20libnl.%E5%A6%82%E6%9E%9C%E6%82%A8%E8%87%AA%E8%A1%8C%E7%BC%96%E8%AF%91%EF%BC%8C%3CBR%20%2F%3E%23%20%E6%82%A8%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E5%B0%86%20hostapd%20%E6%8C%87%E5%90%91%E6%82%A8%E7%9A%84%20libnl%20%E7%89%88%E6%9C%AC%E3%80%82%3CBR%20%2F%3E%23%3CBR%20%2F%3E%20%23CFLAGS%20%2B%3D%20-I%24%3CPATH%20to%3D%22%22%20libnl%3D%22%22%20include%3D%22%22%20files%3D%22%22%3E%3CBR%20%2F%3E%20%23LIBS%20%2B%3D%20-L%24%3CPATH%20to%3D%22%22%20libnl%3D%22%22%20library%3D%22%22%20files%3D%22%22%3E%3C%2FPATH%3E%3C%2FPATH%3E%3C%2FP%3E%3CP%3E%23%20%E4%BD%BF%E7%94%A8%20libnl%20v2.0%EF%BC%88%E6%88%96%203.0%EF%BC%89%E5%BA%93%E3%80%82%3CBR%20%2F%3E%23CONFIG_LIBNL20%3Dy%3C%2FP%3E%3CP%3E%23%20%E4%BD%BF%E7%94%A8%20libnl%203.2%20%E5%BA%93%EF%BC%88%E5%A6%82%E6%9E%9C%E9%80%89%E6%8B%A9%E6%AD%A4%E9%80%89%E9%A1%B9%EF%BC%8C%E5%88%99%E5%BF%BD%E7%95%A5%20CONFIG_LIBNL20%EF%BC%89%3CBR%20%2F%3ECONFIG_LIBNL32%3Dy%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%23%20FreeBSD%20net80211%20%E5%B1%82%E7%9A%84%E9%A9%B1%E5%8A%A8%E6%8E%A5%E5%8F%A3%EF%BC%88%E4%BE%8B%E5%A6%82%20Atheros%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%89%3CBR%20%2F%3E%23CONFIG_DRIVER_BSD%20%3Dy%20%3CBR%20%2F%3E%20%23CFLAGS%20%2B%3D-i%2Fusr%2FLocal%2FInclude%20%23LIBS%20%2B%3D-L%2FUSR%2FLocal%2Flib%20%23LIBS_p%20%2B%3D-L%2FUSR%2FLocal%2Flib%20%2B%3D-L%2FUSR%2FLocal%2Flib%20%23LIBS_c%20%2B%3D-L%2FUSR%2FLocal%2Flib%20%2B%3D-L%2FUSR%2FLoc%20%3CBR%20%2F%3E%20al%2Flib%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%23%20Windows%20NDIS%20%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%20%3CBR%20%2F%3E%20%23CONFIG_DRIVER_NDIS%20%3Dy%20%3CBR%20%2F%3E%20%23CFLAGS%20%2B%3D-i%2Fusr%2FInclude%2Fw32API%2FDDK%20%3CBR%20%2F%3E%20%23LIBS%20%2B%3D-L%2FUSR%2FLocal%2Flib%20%23%20%E4%BD%BF%E7%94%A8%20mingw%20%E8%BF%9B%E8%A1%8C%E5%8E%9F%E7%94%9F%E7%89%88%E6%9C%AC%20%3CBR%20%2F%3E%20%23CONFIG_NATIVE_WINDOWS%20%3Dy%20%3CBR%20%2F%3E%20%23%20%E5%9C%A8%20Linux%20%E4%B8%BB%E6%9C%BA%E4%B8%8A%E7%94%A8%E4%BA%8E%20mingw%20%E7%9B%AE%E6%A0%87%E7%9A%84%E5%85%B6%E4%BB%96%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E7%9B%AE%E5%BD%95%20%23CFLAGS%20%2B%3D-i%2Fopt%2FMINGW%2FMINGW32%2Flib%20%23CC%20%3Dmingw32%2Flib%20%3Dmingw32%2Flib%20%3Dmingw32%2Flib%20%3Dmingw32%2Flib%2032-gcc%20%3CBR%20%2F%3E%20%23%20%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8Cdriver_ndis%20%E4%BD%BF%E7%94%A8%20WinpCap%20%E8%BF%9B%E8%A1%8C%E4%BD%8E%E7%BA%A7%E6%93%8D%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%23LIBS%3CBR%20%2F%3E%23%20%E5%8F%AF%E7%94%A8%E4%BB%A5%E4%B8%8B%E9%80%89%E9%A1%B9%E4%BB%A3%E6%9B%BF%EF%BC%8C%E5%8D%B3%E7%94%A8%20NDISUIO%20%E4%BB%A3%E6%9B%BF%20WinPcap%20%E8%B0%83%E7%94%A8%E3%80%82%3CBR%20%2F%3E%23%20%E4%B8%8D%E8%BF%87%EF%BC%8C%E8%BF%99%E8%A6%81%E6%B1%82%E5%9C%A8%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%23%20wpa_supplicant%20%E4%B9%8B%E5%89%8D%E7%A6%81%E7%94%A8%20WZC%EF%BC%88net%20stop%20wzcsvc%EF%BC%89%E3%80%82%3CBR%20%2F%3E%23%20CONFIG_USE_NDISUIO%3Dy%3C%2FP%3E%3CP%3E%23%20%E7%94%A8%E4%BA%8E%E6%9C%89%E7%BA%BF%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3ECONFIG_DRIVER_WIRED%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%94%AF%E6%8C%81%20MACsec%20%E7%9A%84%E9%AB%98%E9%80%9A%E5%88%9B%E9%94%90%E8%AE%AF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3E%23CONFIG_DRIVER_MACSEC_QCA%3Dy%3C%2FP%3E%3CP%3E%23%20Linux%20MACsec%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3E%23CONFIG_DRIVER_MACSEC_LINUX%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%8D%9A%E9%80%9A%20RoboSwitch%20%E7%B3%BB%E5%88%97%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%20%23CONFIG_DRIVER_ROBOSWITCH%20%3Dy%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%23%20%E6%97%A0%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E4%BB%85%20WPS%20ER%EF%BC%89%3CBR%20%2F%3E%23CONFIG_DRIVER_NONE%3Dy%3C%2FP%3E%3CP%3E%23%20Solaris%20%E5%BA%93%3CBR%20%2F%3E%23LIBS%20%2B%3D%20-lsocket%20-ldlpi%20-lnsl%3CBR%20%2F%3E%23LIBS_c%20%2B%3D%20-lsocket%3C%2FP%3E%3CP%3E%23%20%E5%90%AF%E7%94%A8%20IEEE%20802.1X%20Supplicant%EF%BC%88%E5%A6%82%E6%9E%9C%E5%8C%85%E5%90%AB%E4%BB%BB%E4%BD%95%20EAP%20%E6%96%B9%E6%B3%95%E6%88%96%3CBR%20%2F%3E%23%20MACsec%EF%BC%8C%E5%88%99%E8%87%AA%E5%8A%A8%E5%8C%85%E5%90%AB%EF%BC%89%3CBR%20%2F%3ECONFIG_IEEE8021X_EAPOL%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-MD5%3CBR%20%2F%3ECONFIG_EAP_MD5%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-MSCHAPv2%3CBR%20%2F%3ECONFIG_EAP_MSCHAPV2%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-TLS%3CBR%20%2F%3ECONFIG_EAP_TLS%3Dy%3CBR%20%2F%3E%23%20%E5%90%AF%E7%94%A8%20EAP-TLSv1.3%E9%BB%98%E8%AE%A4%E6%94%AF%E6%8C%81%EF%BC%88%E7%9B%AE%E5%89%8D%E5%B7%B2%E7%A6%81%E7%94%A8%EF%BC%8C%E9%99%A4%E9%9D%9E%E5%9C%A8%E7%BD%91%E7%BB%9C%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%98%8E%E7%A1%AE%3CBR%20%2F%3E%23%20%E5%90%AF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%23CONFIG_EAP_TLSV1_3%3Dy%3C%2FP%3E%3CP%3E%23%20EAL-PEAP%3CBR%20%2F%3ECONFIG_EAP_PEAP%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-TTLS%3CBR%20%2F%3ECONFIG_EAP_TTLS%3Dy%3C%2FP%3E%3CP%3ECONFIG_EAP_SAE%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-FAST%3CBR%20%2F%3ECONFIG_EAP_FAST%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-TEAP%3CBR%20%2F%3E%23%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E5%BD%93%E5%89%8D%E7%9A%84%20EAP-TEAP%20%E5%AE%9E%E7%8E%B0%E6%98%AF%E8%AF%95%E9%AA%8C%E6%80%A7%E7%9A%84%EF%BC%8C%E4%B8%8D%E5%BA%94%E5%9C%A8%E7%94%9F%E4%BA%A7%E4%BD%BF%E7%94%A8%E4%B8%AD%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%23%E3%80%82%E5%AE%9A%E4%B9%89%20EAP-TEAP%20%E7%9A%84%20IETF%20RFC%207170%20%E6%9C%89%E4%B8%80%E4%BA%9B%3CBR%20%2F%3E%23%20%E7%9B%B8%E4%BA%92%E5%86%B2%E7%AA%81%E7%9A%84%E5%A3%B0%E6%98%8E%E5%92%8C%E7%BC%BA%E5%A4%B1%E7%9A%84%E7%BB%86%E8%8A%82%EF%BC%8C%E8%80%8C%E5%AE%9E%E6%96%BD%E6%96%B9%E6%A1%88%E6%9C%89%3CBR%20%2F%3E%23%20%E4%BE%9B%E5%BA%94%E5%95%86%E7%89%B9%E5%AE%9A%E7%9A%84%E5%8F%98%E9%80%9A%E6%96%B9%E6%B3%95%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%8F%AF%E8%83%BD%E6%97%A0%E6%B3%95%E4%B8%8E%3CBR%20%2F%3E%23%20%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E5%AE%9E%E6%96%BD%E6%96%B9%E6%A1%88%E4%BA%92%E6%93%8D%E4%BD%9C%E3%80%82%E5%9C%A8%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%E5%BE%97%E5%88%B0%E8%A7%A3%E5%86%B3%20%23%20%E4%B9%8B%E5%89%8D%EF%BC%8C%E4%B8%8D%E5%BA%94%E5%B0%86%E5%85%B6%E7%94%A8%E4%BA%8E%20%3CBR%20%2F%3E%20%23%20%E5%AE%9E%E9%AA%8C%E5%92%8C%E4%BA%92%E6%93%8D%E4%BD%9C%E6%80%A7%E6%B5%8B%E8%AF%95%E4%BB%A5%E5%A4%96%E7%9A%84%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E7%94%A8%E9%80%94%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%23CONFIG_EAP_TEAP%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-GTC%3CBR%20%2F%3ECONFIG_EAP_GTC%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-OTP%3CBR%20%2F%3ECONFIG_EAP_OTP%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-SIM%EF%BC%88%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20EAP-SIM%EF%BC%8C%E5%88%99%E5%90%AF%E7%94%A8%20CONFIG_PCSC%EF%BC%89%3CBR%20%2F%3E%23CONFIG_EAP_SIM%3Dy%3C%2FP%3E%3CP%3E%23%20%E4%B8%BA%20EAP-SIM%20%E5%90%AF%E7%94%A8%20SIM%20%E5%8D%A1%E6%A8%A1%E6%8B%9F%E5%99%A8%20(Milenage)%3CBR%20%2F%3E%23CONFIG_SIM_SIMULATOR%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-PSK%EF%BC%88%E8%AF%95%E9%AA%8C%E6%80%A7%EF%BC%9BWPA-PSK%20%E4%B8%8D%E9%9C%80%E8%A6%81%EF%BC%89%3CBR%20%2F%3E%23CONFIG_EAP_PSK%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-pwd%EF%BC%88%E4%BB%85%E4%BD%BF%E7%94%A8%E5%AF%86%E7%A0%81%E7%9A%84%E5%AE%89%E5%85%A8%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%EF%BC%89%3CBR%20%2F%3ECONFIG_EAP_PWD%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-PAX%3CBR%20%2F%3ECONFIG_EAP_PAX%3Dy%3C%2FP%3E%3CP%3E%23%20LEAP%3CBR%20%2F%3ECONFIG_EAP_LEAP%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-AKA%EF%BC%88%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20EAP-AKA%EF%BC%8C%E5%88%99%E5%90%AF%E7%94%A8%20CONFIG_PCSC%EF%BC%89%3CBR%20%2F%3E%23CONFIG_EAP_AKA%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-AKA'%EF%BC%88%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20EAP-AKA'%EF%BC%8C%E5%88%99%E5%90%AF%E7%94%A8%20CONFIG_PCSC%EF%BC%89%E3%80%82%3CBR%20%2F%3E%23%20%E8%BF%99%E9%9C%80%E8%A6%81%E5%90%8C%E6%97%B6%E5%90%AF%E7%94%A8%20CONFIG_EAP_AKA%E3%80%82%3CBR%20%2F%3E%23CONFIG_EAP_AKA_PRIME%3Dy%3C%2FP%3E%3CP%3E%23%20%E4%B8%BA%20EAP-AKA%20%E5%90%AF%E7%94%A8%20USIM%20%E6%A8%A1%E6%8B%9F%E5%99%A8%20(Milenage)%3CBR%20%2F%3E%23CONFIG_USIM_SIMULATOR%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-SAKE%3CBR%20%2F%3ECONFIG_EAP_SAKE%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-GPSK%20%3CBR%20%2F%3E%20config_eap_gpsk%3DY%20%23%20%E5%9C%A8%20EAP-GPSK%20config_eap_gpsk_sha256%3DY%20%E4%B8%AD%E5%8C%85%E6%8B%AC%3CBR%20%2F%3E%E5%AF%B9%E5%8F%AF%E9%80%89%E7%9A%84%20SHA256%20%E5%AF%86%E7%A0%81%E5%A5%97%E4%BB%B6%E7%9A%84%E6%94%AF%E6%8C%81%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%23%20EAP-TNC%20%E5%92%8C%E7%9B%B8%E5%85%B3%E7%9A%84%E5%8F%AF%E4%BF%A1%E7%BD%91%E7%BB%9C%E8%BF%9E%E6%8E%A5%E6%94%AF%E6%8C%81%EF%BC%88%E8%AF%95%E9%AA%8C%E6%80%A7%EF%BC%89%3CBR%20%2F%3ECONFIG_EAP_TNC%3Dy%3C%2FP%3E%3CP%3E%23%20Wi-Fi%20%E4%BF%9D%E6%8A%A4%E8%AE%BE%E7%BD%AE%20(WPS)%3CBR%20%2F%3ECONFIG_WPS%3Dy%3CBR%20%2F%3E%23%20%E5%90%AF%E7%94%A8%20WPS%20%E5%A4%96%E9%83%A8%E6%B3%A8%E5%86%8C%E5%99%A8%E5%8A%9F%E8%83%BD%3CBR%20%2F%3E%23CONFIG_WPS_ER%3Dy%3CBR%20%2F%3E%23%20%E4%BD%9C%E4%B8%BA%20WPS%3CBR%20%2F%3E%23%20%E6%B3%A8%E5%86%8C%E5%99%A8%E6%97%B6%EF%BC%8C%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E7%A6%81%E7%94%A8%E5%BC%80%E6%94%BE%E7%BD%91%E7%BB%9C%E7%9A%84%E5%87%AD%E8%AF%81%E3%80%82%3CBR%20%2F%3E%23CONFIG_WPS_REG_DISABLE_OPEN%3Dy%3CBR%20%2F%3E%23%20%E4%BD%BF%E7%94%A8%20NFC%20%E9%85%8D%E7%BD%AE%E6%96%B9%E6%B3%95%E5%90%AF%E7%94%A8%20WPS%20%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%23CONFIG_WPS_NFC%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-IKEv2%3CBR%20%2F%3ECONFIG_EAP_IKEV2%3Dy%3C%2FP%3E%3CP%3E%23%20EAP-EKE%3CBR%20%2F%3E%23CONFIG_EAP_EKE%3Dy%3C%2FP%3E%3CP%3E%23%20MACsec%3CBR%20%2F%3ECONFIG_MACSEC%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%94%AF%E6%8C%81%20PKCS%2312%20(PFX)%EF%BC%88%E7%94%A8%E4%BA%8E%E4%BB%8E%3CBR%20%2F%3E%23%20%E8%AF%BB%E5%8F%96%E7%A7%81%E9%92%A5%E5%92%8C%E8%AF%81%E4%B9%A6%E6%96%87%E4%BB%B6%EF%BC%8C%E6%96%87%E4%BB%B6%E6%89%A9%E5%B1%95%E5%90%8D%E9%80%9A%E5%B8%B8%E4%B8%BA%20.p12%E6%88%96%20.pfx)%3CBR%20%2F%3ECONFIG_PKCS12%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%94%AF%E6%8C%81%E6%99%BA%E8%83%BD%E5%8D%A1%EF%BC%88%E5%8D%B3%E6%99%BA%E8%83%BD%E5%8D%A1%E4%B8%8A%E7%9A%84%E7%A7%81%E9%92%A5%EF%BC%89%EF%BC%8C%E5%A6%82%E4%BD%BF%E7%94%A8%20openssl%3CBR%20%2F%3E%23%20%E5%BC%95%E6%93%8E%E3%80%82%3CBR%20%2F%3ECONFIG_SMARTCARD%3Dy%3C%2FP%3E%3CP%3E%23%20%E7%94%A8%E4%BA%8E%E6%99%BA%E8%83%BD%E5%8D%A1%EF%BC%88USIM%E3%80%81GSM%20SIM%EF%BC%89%E7%9A%84%20PC%2FSC%20%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3E%23%20%E5%A6%82%E6%9E%9C%E5%8C%85%E5%90%AB%20EAP-SIM%20%E6%88%96%20EAP-AKA%20%E5%88%99%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%23CONFIG_PCSC%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%94%AF%E6%8C%81%20HT%20%E9%87%8D%E8%BD%BD%EF%BC%88%E7%A6%81%E7%94%A8%20HT%2FHT40%E3%80%81%E5%B1%8F%E8%94%BD%20MCS%20%E9%80%9F%E7%8E%87%E7%AD%89%EF%BC%89%3CBR%20%2F%3E%23CONFIG_HT_OVERRIDES%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%94%AF%E6%8C%81%20VHT%20%E9%87%8D%E8%BD%BD%EF%BC%88%E7%A6%81%E7%94%A8%20VHT%E3%80%81%E5%B1%8F%E8%94%BD%20MCS%20%E9%80%9F%E7%8E%87%E7%AD%89%EF%BC%89%3CBR%20%2F%3E%23CONFIG_VHT_OVERRIDES%3Dy%3C%2FP%3E%3CP%3E%23%20Support%20HE%20overrides%3CBR%20%2F%3E%23CONFIG_HE_OVERRIDES%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%BC%80%E5%8F%91%E6%B5%8B%E8%AF%95%3CBR%20%2F%3E%23CONFIG_EAPOL_TEST%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%94%AF%E6%8C%81%20IPv6%3CBR%20%2F%3ECONFIG_IPV6%3Dy%3C%2FP%3E%3CP%3E%23%20%E4%B8%BA%E5%A4%96%E9%83%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E4%BE%8B%E5%A6%82%20wpa_cli%EF%BC%89%E9%80%89%E6%8B%A9%E6%8E%A7%E5%88%B6%E6%8E%A5%E5%8F%A3%E5%90%8E%E7%AB%AF%EF%BC%9A%3CBR%20%2F%3E%23%20unix%20%3D%20UNIX%20%E5%8A%9F%E8%83%BD%E5%9F%9F%E5%A5%97%E6%8E%A5%E5%AD%97%EF%BC%88Linux%2F*BSD%20%E7%9A%84%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%89%23%20udp%20%3D%20%E4%BD%BF%E7%94%A8%E6%9C%AC%E5%9C%B0%E4%B8%BB%E6%9C%BA%E7%9A%84%20UDP%20%E5%A5%97%E6%8E%A5%E5%AD%97%20(127.0.0.1)%20%3CBR%20%2F%3E%20%23%20udp6%20%3D%20%E4%BD%BF%E7%94%A8%E6%9C%AC%E5%9C%B0%E4%B8%BB%E6%9C%BA%E7%9A%84%20UDP%20IPv6%20%E5%A5%97%E6%8E%A5%E5%AD%97%20(%3A%3A1)%20%3CBR%20%2F%3E%20%23%20named_pipe%20%3D%20Windows%20%E5%91%BD%E5%90%8D%E7%AE%A1%E9%81%93%EF%BC%88Windows%20%E7%9A%84%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%89%3CBR%20%2F%3E%23%20udp-remote%20%3D%20%E5%85%B7%E6%9C%89%E8%BF%9C%E7%A8%8B%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%E7%9A%84%20UDP%20%E5%A5%97%E6%8E%A5%E5%AD%97%EF%BC%88%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%E6%B5%8B%E8%AF%95%E7%B3%BB%E7%BB%9F%2F%20%E7%9B%AE%E7%9A%84)%20%3CBR%20%2F%3E%20%23%20udp6-remote%20%3D%20%E5%85%B7%E6%9C%89%E8%BF%9C%E7%A8%8B%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%E7%9A%84%20UDP%20IPv6%20%E5%A5%97%E6%8E%A5%E5%AD%97%EF%BC%88%E4%BB%85%E7%94%A8%E4%BA%8E%E6%B5%8B%E8%AF%95%E7%9B%AE%E7%9A%84%EF%BC%89%3CBR%20%2F%3E%23%20y%20%3D%20%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%88%E5%90%91%E5%90%8E%E5%85%BC%E5%AE%B9%EF%BC%89%23%20%E5%A6%82%E6%9E%9C%E6%B3%A8%E9%87%8A%E6%8E%89%E6%AD%A4%E9%80%89%E9%A1%B9%EF%BC%8C%E6%8E%A7%E5%88%B6%E6%8E%A5%E5%8F%A3%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E4%B8%8D%E5%8C%85%E5%90%AB%E5%9C%A8%20%3CBR%20%2F%3E%20%23%20%E7%89%88%E6%9C%AC%E4%B8%AD%E3%80%82%3CBR%20%2F%3ECONFIG_CTRL_IFACE%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%9C%A8%20wpa_cli%20%E4%B8%AD%E5%8A%A0%E5%85%A5%E5%AF%B9%20GNU%20Readline%20%E5%92%8C%E5%8E%86%E5%8F%B2%E5%BA%93%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3CBR%20%2F%3E%23%20%E5%9C%A8%E6%9E%84%E5%BB%BA%20wpa_cli%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E4%BB%A5%E4%BE%9B%E5%88%86%E5%8F%91%E6%97%B6%EF%BC%8C%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E8%BF%99%E4%BA%9B%20%3CBR%20%2F%3E%20%23%20%E5%BA%93%E6%98%AF%E6%A0%B9%E6%8D%AE%20GPL%20%E8%AE%B8%E5%8F%AF%E7%9A%84%EF%BC%8C%E5%9B%A0%E6%AD%A4%EF%BC%8CBSD%20%E8%AE%B8%E5%8F%AF%E8%AF%81%E5%8F%AF%E8%83%BD%E4%B8%8D%E9%80%82%E7%94%A8%E4%BA%8E%20%3CBR%20%2F%3E%20%23%20%E7%94%9F%E6%88%90%E7%9A%84%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%23CONFIG_READLINE%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%9C%A8%20wpa_cli%20%E4%B8%AD%E5%8A%A0%E5%85%A5%E5%86%85%E9%83%A8%E8%A1%8C%E7%BC%96%E8%BE%91%E6%A8%A1%E5%BC%8F%E3%80%82%E5%AE%83%E5%8F%AF%E4%BB%A5%E7%94%A8%E6%9D%A5%E6%9B%BF%E4%BB%A3%3CBR%20%2F%3E%23%20GNU%20Readline%EF%BC%8C%E6%8F%90%E4%BE%9B%E6%9C%89%E9%99%90%E7%9A%84%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%BC%96%E8%BE%91%E5%92%8C%E5%8E%86%E5%8F%B2%E8%AE%B0%E5%BD%95%E6%94%AF%E6%8C%81%E3%80%82%3CBR%20%2F%3E%23CONFIG_WPA_CLI_EDIT%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%88%A0%E9%99%A4%E5%90%91%20stdout%20%E8%BE%93%E5%87%BA%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%E7%9A%84%E8%B0%83%E8%AF%95%E4%BB%A3%E7%A0%81%E3%80%82%3CBR%20%2F%3E%23%20%E5%A6%82%E6%9E%9C%E4%B8%8D%E9%9C%80%E8%A6%81%E8%B0%83%E8%AF%95%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%8F%AF%E4%BD%BF%E7%94%A8%E6%AD%A4%E6%96%B9%E6%B3%95%E5%A4%A7%E5%A4%A7%E7%BC%A9%E5%B0%8F%20wpa_supplicant%20%E7%9A%84%E5%A4%A7%E5%B0%8F%3CBR%20%2F%3E%23%E3%80%82%E5%A4%A7%E5%B0%8F%E5%8F%AF%E5%87%8F%E5%B0%91%E7%BA%A6%2035%25%3CBR%20%2F%3E%20%23%20%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C90%20kB%EF%BC%89%E3%80%82%3CBR%20%2F%3E%23CONFIG_NO_STDOUT_DEBUG%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%8F%96%E6%B6%88%20WPA%20%E6%94%AF%E6%8C%81%EF%BC%8C%E4%BE%8B%E5%A6%82%E5%8F%AA%E6%94%AF%E6%8C%81%E6%9C%89%E7%BA%BF%20IEEE%20802.1X%20supplicant%EF%BC%8C%E4%BB%A5%E8%8A%82%E7%9C%81%3CBR%20%2F%3E%23%2035-50%20kB%20%E7%9A%84%E4%BB%A3%E7%A0%81%E5%A4%A7%E5%B0%8F%E3%80%82%3CBR%20%2F%3E%23CONFIG_NO_WPA%3Dy%3C%2FP%3E%3CP%3E%23%20%E7%A7%BB%E9%99%A4%20IEEE%20802.11i%2FWPA-PersonalASCII%20%E5%8F%A3%E4%BB%A4%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%23%20%E8%AF%A5%E9%80%89%E9%A1%B9%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%8F%96%E6%B6%88%E5%AF%B9%3CBR%20%2F%3E%23%20%E5%B0%86%20ASCII%20%E5%8F%A3%E4%BB%A4%E8%BD%AC%E6%8D%A2%E4%B8%BA%20PSK%20%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%8C%E4%BB%8E%E8%80%8C%E5%87%8F%E5%B0%8F%E4%BB%A3%E7%A0%81%E5%A4%A7%E5%B0%8F%E3%80%82%E5%A6%82%E6%9E%9C%E5%88%A0%E9%99%A4%E6%AD%A4%E5%8A%9F%E8%83%BD%EF%BC%8C%3CBR%20%2F%3E%23%20PSK%20%E5%8F%AA%E8%83%BD%E9%85%8D%E7%BD%AE%E4%B8%BA%2064%20%E5%85%AB%E4%BD%8D%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E4%BB%8E%3CBR%20%2F%3E%23%20wpa_passphrase%EF%BC%89%E3%80%82%E8%BF%99%E6%A0%B7%E5%8F%AF%E4%BB%A5%E8%8A%82%E7%9C%81%E5%A4%A7%E7%BA%A6%200.5%20kB%20%E7%9A%84%E4%BB%A3%E7%A0%81%E9%87%8F%E3%80%82%3CBR%20%2F%3E%23CONFIG_NO_WPA_PASSPHRASE%3Dy%3C%2FP%3E%3CP%3E%23%20%E7%AD%89%E6%95%88%E5%90%8C%E6%AD%A5%E9%AA%8C%E8%AF%81%EF%BC%88SAE%EF%BC%89%EF%BC%8CWPA3-%E4%B8%AA%E4%BA%BA%3CBR%20%2F%3ECONFIG_SAE%3Dy%3C%2FP%3E%3CP%3ECONFIG_IEEE80211W%3Dy%3CBR%20%2F%3ECONFIG_IEEE80211N%3Dy%3C%2FP%3E%3CP%3ECONFIG_WPA3%3Dy%3C%2FP%3E%3CP%3E%23%20SAE%20%E5%85%AC%E9%92%A5%EF%BC%8CWPA3-%E4%B8%AA%E4%BA%BA%3CBR%20%2F%3E%23CONFIG_SAE_PK%3Dy%3C%2FP%3E%3CP%3E%23%20%E7%A6%81%E7%94%A8%E6%89%AB%E6%8F%8F%E7%BB%93%E6%9E%9C%E5%A4%84%E7%90%86%EF%BC%88ap_scan%3D1%EF%BC%89%EF%BC%8C%E4%BB%A5%E8%8A%82%E7%9C%81%E7%BA%A6%201%20kB%20%E7%9A%84%E4%BB%A3%E7%A0%81%E5%A4%A7%E5%B0%8F%E3%80%82%3CBR%20%2F%3E%23%20%E5%A6%82%E6%9E%9C%E4%BB%8E%E6%9C%AA%E5%90%AF%E7%94%A8%20ap_scan%3D1%20%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BD%BF%E7%94%A8%E6%AD%A4%E5%8A%9F%E8%83%BD%E3%80%82%3CBR%20%2F%3E%23CONFIG_NO_SCAN_PROCESSING%3DY%3C%2FP%3E%3CP%3E%23%20%E9%80%89%E6%8B%A9%E9%85%8D%E7%BD%AE%E5%90%8E%E7%AB%AF%EF%BC%9A%3CBR%20%2F%3E%23%20%E6%96%87%E4%BB%B6%20%3D%20%E6%96%87%E6%9C%AC%E6%96%87%E4%BB%B6%EF%BC%88%E5%A6%82%20wpa_supplicant.conf%EF%BC%9B%E6%B3%A8%E6%84%8F%EF%BC%9A%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%3CBR%20%2F%3E%23%20%E8%B7%AF%E5%BE%84%E5%9C%A8%E5%91%BD%E4%BB%A4%E8%A1%8C%E4%B8%AD%E7%BB%99%E5%87%BA%EF%BC%8C%E4%B8%8D%E5%9C%A8%E6%AD%A4%E5%A4%84%EF%BC%9B%E8%AF%A5%E9%80%89%E9%A1%B9%E5%8F%AA%E6%98%AF%E7%94%A8%E6%9D%A5%3CBR%20%2F%3E%23%20%E9%80%89%E6%8B%A9%E5%85%81%E8%AE%B8%E4%BD%BF%E7%94%A8%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E7%9A%84%E5%90%8E%E7%AB%AF%EF%BC%89%3CBR%20%2F%3E%23%20winreg%20%3D%20Windows%20%E6%B3%A8%E5%86%8C%E8%A1%A8%EF%BC%88%E7%A4%BA%E4%BE%8B%E8%A7%81%20win_example.reg%EF%BC%89%3CBR%20%2F%3ECONFIG_BACKEND%3Dfile%3C%2FP%3E%3CP%3E%23%20%E5%88%A0%E9%99%A4%E9%85%8D%E7%BD%AE%E5%86%99%E5%85%A5%E5%8A%9F%E8%83%BD%EF%BC%88%E5%8D%B3%E5%85%81%E8%AE%B8%E6%A0%B9%E6%8D%AE%E8%BF%90%E8%A1%8C%E6%97%B6%E7%9A%84%E9%85%8D%E7%BD%AE%E6%9B%B4%E6%94%B9%E6%9B%B4%E6%96%B0%E9%85%8D%E7%BD%AE%3CBR%20%2F%3E%23%20%E6%96%87%E4%BB%B6%EF%BC%89%E3%80%82%E8%BF%90%E8%A1%8C%E6%97%B6%3CBR%20%2F%3E%23%20%E9%85%8D%E7%BD%AE%E4%BB%8D%E5%8F%AF%E6%9B%B4%E6%94%B9%EF%BC%8C%E5%8F%AA%E6%98%AF%E6%9B%B4%E6%94%B9%E4%B8%8D%E4%BC%9A%E5%9C%A8%E9%87%8D%E5%90%AF%E6%97%B6%3CBR%20%2F%3E%23%20%E6%8C%81%E4%B9%85%E3%80%82%3CBR%20%2F%3E%23%20%E7%BA%A6%203.5%20kB%E3%80%82%3CBR%20%2F%3E%23CONFIG_NO_CONFIG_WRITE%3Dy%3C%2FP%3E%3CP%3E%23%3CBR%20%2F%3E%23CONFIG_NO_CONFIG_BLOBS%3Dy%3C%2FP%3E%3CP%3E%23%20%E9%80%89%E6%8B%A9%E7%A8%8B%E5%BA%8F%E5%85%A5%E5%8F%A3%E7%82%B9%E5%AE%9E%E7%8E%B0%EF%BC%9A%3CBR%20%2F%3E%23%20main%20%3D%20UNIX%2FPOSIX%20%E7%B1%BB%E4%BC%BC%E7%9A%84%20main()%20%E5%87%BD%E6%95%B0%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3CBR%20%2F%3E%23%20main_winsvc%20%3D%20Windows%20%E6%9C%8D%E5%8A%A1%EF%BC%88%E4%BB%8E%E6%B3%A8%E5%86%8C%E8%A1%A8%E8%AF%BB%E5%8F%96%E5%8F%82%E6%95%B0%EF%BC%89%3CBR%20%2F%3E%23%20main_none%20%3D%20%E9%9D%9E%E5%B8%B8%E5%9F%BA%E6%9C%AC%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%88%E4%BB%85%E4%BE%9B%E5%BC%80%E5%8F%91%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%23CONFIG_MAIN%3Dmain%3C%2FP%3E%3CP%3E%23%20%E9%80%89%E6%8B%A9%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E5%92%8C%20C%20%E5%BA%93%E7%89%B9%E5%AE%9A%E5%87%BD%E6%95%B0%E7%9A%84%E5%B0%81%E8%A3%85%E5%99%A8%3CBR%20%2F%3E%23%20unix%20%3D%20%E7%B1%BB%20UNIX%2FPOSIX%20%E7%B3%BB%E7%BB%9F%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3CBR%20%2F%3E%23%20win32%20%3D%20Windows%20%E7%B3%BB%E7%BB%9F%3CBR%20%2F%3E%23%20none%20%3D%20%E7%A9%BA%E6%A8%A1%E6%9D%BF%3CBR%20%2F%3E%23CONFIG_OS%3Dunix%3C%2FP%3E%3CP%3E%23%20%E9%80%89%E6%8B%A9%E4%BA%8B%E4%BB%B6%E5%BE%AA%E7%8E%AF%E5%AE%9E%E7%8E%B0%3CBR%20%2F%3E%23%20eloop%20%3D%20select()%20%E5%BE%AA%E7%8E%AF%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3CBR%20%2F%3E%23%20eloop_win%20%3D%20Windows%20%E4%BA%8B%E4%BB%B6%E5%92%8C%20WaitForMultipleObject()%20%E5%BE%AA%E7%8E%AF%3CBR%20%2F%3E%23CONFIG_ELOOP%3Deloop%3C%2FP%3E%3CP%3E%23%20%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20poll%20%E8%80%8C%E4%B8%8D%E6%98%AF%20select%20%E5%90%97%EF%BC%9F%E9%BB%98%E8%AE%A4%E4%BD%BF%E7%94%A8%20%22%E9%80%89%E6%8B%A9%22%E3%80%82%3CBR%20%2F%3E%23CONFIG_ELOOP_POLL%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20epoll%20%E8%80%8C%E4%B8%8D%E6%98%AF%20select%20%E5%90%97%EF%BC%9F%E9%BB%98%E8%AE%A4%E4%BD%BF%E7%94%A8%20%22%E9%80%89%E6%8B%A9%22%E3%80%82%3CBR%20%2F%3E%23CONFIG_ELOOP_EPOLL%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20kqueue%20%E8%80%8C%E4%B8%8D%E6%98%AF%20select%20%E5%90%97%EF%BC%9F%E9%BB%98%E8%AE%A4%E4%BD%BF%E7%94%A8%20%22%E9%80%89%E6%8B%A9%22%E3%80%82%3CBR%20%2F%3E%23CONFIG_ELOOP_KQUEUE%3Dy%3C%2FP%3E%3CP%3E%23%20%E9%80%89%E6%8B%A9%E7%AC%AC%202%20%E5%B1%82%E6%95%B0%E6%8D%AE%E5%8C%85%E5%AE%9E%E7%8E%B0%20%23%20linux%20%3D%20Linux%20%E6%95%B0%E6%8D%AE%E5%8C%85%E5%A5%97%E6%8E%A5%E5%AD%97%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3CBR%20%2F%3E%23%20pcap%20%3D%20libpcap%2Flibdnet%2Fwinpcap%20%3CBR%20%2F%3E%20%23%20freebsd%20%3D%20FreeBSD%20libpcap%20%23%20winpcap%20%3D%20%E5%B8%A6%E6%8E%A5%E6%94%B6%E7%BA%BF%E7%A8%8B%E7%9A%84%20Winpcap%20%3CBR%20%2F%3E%20%23%20nedis%20%3D%20Windows%20NDISUIO%EF%BC%88%E6%B3%A8%E6%84%8F%EF%BC%9A%E9%9C%80%E8%A6%81%20config_use_ndisuio%3DY%EF%BC%89%3CBR%20%2F%3E%23%20%E6%97%A0%20%3D%20%E7%A9%BA%E6%A8%A1%E6%9D%BF%20%23CONFIG_L2_PACKET%20%3Dlinux%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%23%20%E7%A6%81%E7%94%A8%E9%80%82%E7%94%A8%E4%BA%8E%20EAPOL%20%E5%B8%A7%E7%9A%84%E7%BD%91%E6%A1%A5%E4%B8%AD%E7%9A%84%E7%AB%99%E6%8E%A5%E5%8F%A3%3CBR%20%2F%3E%23%20%E7%9A%84%20Linux%20%E6%95%B0%E6%8D%AE%E5%8C%85%E5%A5%97%E6%8E%A5%E5%AD%97%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E3%80%82%E5%8F%AA%E6%9C%89%E5%BD%93%E5%86%85%E6%A0%B8%3CBR%20%2F%3E%23%20%E5%B7%B2%E7%9F%A5%E4%B8%8E%3CBR%20%2F%3E%23%20%E7%BD%91%E6%A1%A5%E6%8E%A5%E5%8F%A3%EF%BC%88%E6%8F%90%E4%BA%A4%20%22bridge%3A%20respect%20RFC2863%20operational%20state%22%EF%BC%89%E7%9A%84%E6%95%B0%E6%8D%AE%E5%8C%85%E5%A5%97%E6%8E%A5%E5%AD%97%E8%A1%8C%E4%B8%BA%E4%B8%8D%E5%AD%98%E5%9C%A8%E5%9B%9E%E5%BD%92%E9%97%AE%E9%A2%98%E6%97%B6%EF%BC%8C%E6%89%8D%E5%BA%94%E5%8F%96%E6%B6%88%E6%B3%A8%E9%87%8A%E3%80%82%EF%BC%89%3CBR%20%2F%3E%23CONFIG_NO_LINUX_PACKET_SOCKET_WAR%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%94%AF%E6%8C%81%E8%BF%90%E8%A1%8C%E9%80%9A%E9%81%93%E9%AA%8C%E8%AF%81%3CBR%20%2F%3E%23CONFIG_OCV%3Dy%3C%2FP%3E%3CP%3E%23%20%E9%80%89%E6%8B%A9%20TLS%20%E5%AE%9E%E7%8E%B0%3CBR%20%2F%3E%23%20openssl%20%3D%20OpenSSL%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3CBR%20%2F%3E%23%20gnutls%20%3D%20GnuTLS%3CBR%20%2F%3E%23%20internal%20%3D%20%E5%86%85%E9%83%A8%20TLSv1%20%E5%AE%9E%E7%8E%B0%EF%BC%88%E5%AE%9E%E9%AA%8C%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%23%20linux%20%3D%20Linux%20%E5%86%85%E6%A0%B8%20AF_ALG%20%E5%92%8C%E5%86%85%E9%83%A8%20TLSv1%20%E5%AE%9E%E7%8E%B0%EF%BC%88%E5%AE%9E%E9%AA%8C%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%23%20none%20%3D%20%E7%A9%BA%E6%A8%A1%E6%9D%BF%3CBR%20%2F%3ECONFIG_TLS%3Dopenssl%3C%2FP%3E%3CP%3E%23%20%E5%9F%BA%E4%BA%8E%20TLS%20%E7%9A%84%20EAP%20%E6%96%B9%E6%B3%95%E8%87%B3%E5%B0%91%E9%9C%80%E8%A6%81%20TLS%20v1.0%E3%80%82%E5%BD%93%E4%BD%BF%E7%94%A8%E5%9D%97%E5%AF%86%E7%A0%81%3CBR%20%2F%3E%23%20%E6%97%B6%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%90%AF%E7%94%A8%E8%BE%83%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20TLS%20(v1.1)%3CBR%20%2F%3E%23%20%E4%BB%A5%E8%8E%B7%E5%BE%97%E6%9B%B4%E5%BC%BA%E7%9A%84%E4%BF%A1%E6%81%AF%E7%BB%93%E6%9E%84%E3%80%82%E9%9C%80%E8%A6%81%E6%B3%A8%E6%84%8F%E7%9A%84%E6%98%AF%EF%BC%8C%E6%9F%90%E4%BA%9B%E7%8E%B0%E6%9C%89%E7%9A%84%E5%9F%BA%E4%BA%8E%20TLS%20v1.0%20%E7%9A%84%3CBR%20%2F%3E%23%20%E5%AE%9E%E7%8E%B0%E5%8F%AF%E8%83%BD%E4%B8%8E%20TLS%20v1.1%20%E6%B6%88%E6%81%AF%E4%B8%8D%E5%85%BC%E5%AE%B9%EF%BC%88ClientHello%20%E6%98%AF%3CBR%20%2F%3E%23%20%E5%9C%A8%E5%8D%8F%E5%95%86%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E4%B9%8B%E5%89%8D%E5%8F%91%E9%80%81%E7%9A%84%EF%BC%89%3CBR%20%2F%3E%23CONFIG_TLSV11%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%9F%BA%E4%BA%8E%20TLS%20%E7%9A%84%20EAP%20%E6%96%B9%E6%B3%95%E8%87%B3%E5%B0%91%E9%9C%80%E8%A6%81%20TLS%20v1.0%E3%80%82%E5%8F%AF%E4%BB%A5%E5%90%AF%E7%94%A8%E8%BE%83%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20TLS%EF%BC%88v1.2%EF%BC%89%3CBR%20%2F%3E%23%EF%BC%8C%E4%BB%A5%E4%BE%BF%E4%BD%BF%E7%94%A8%E6%9B%B4%E5%BC%BA%E7%9A%84%E5%8A%A0%E5%AF%86%E7%AE%97%E6%B3%95%E3%80%82%3CBR%20%2F%3E%23%20%E9%9C%80%E8%A6%81%E6%B3%A8%E6%84%8F%E7%9A%84%E6%98%AF%EF%BC%8C%E6%9F%90%E4%BA%9B%E5%9F%BA%E4%BA%8E%20TLS%20v1.0%20%E7%9A%84%E7%8E%B0%E6%9C%89%E5%AE%9E%E7%8E%B0%E5%8F%AF%E8%83%BD%E4%B8%8E%20TLS%20v1.2%20%E6%B6%88%E6%81%AF%E4%B8%8D%E5%85%BC%E5%AE%B9%3CBR%20%2F%3E%23%20%EF%BC%88%E5%9C%A8%E5%8D%8F%E5%95%86%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%3CBR%20%2F%3E%23%20%E4%B9%8B%E5%89%8D%E4%BC%9A%E5%8F%91%E9%80%81%20ClientHello%EF%BC%89%3CBR%20%2F%3E%23CONFIG_TLSV12%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%A6%82%E6%9E%9C%E7%94%A8%E6%88%B7%E6%B2%A1%E6%9C%89%3CBR%20%2F%3E%23%20%E6%8C%87%E5%AE%9A%E5%AF%86%E7%A0%81%EF%BC%8C%E5%88%99%E9%80%89%E6%8B%A9%20OpenSSL%20%E9%BB%98%E8%AE%A4%E4%BD%BF%E7%94%A8%E7%9A%84%E5%AF%86%E7%A0%81%E3%80%82%3CBR%20%2F%3E%23config_tls_default_ciphers%3D%22default%3A!exp%3A!low%22%3C%2FP%3E%3CP%3E%23%20%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20CONFIG_TLS%3Dinternal%EF%BC%8CLibTomMath%20%E5%B0%86%E9%9C%80%E8%A6%81%E9%A2%9D%E5%A4%96%E7%9A%84%E5%BA%93%E5%92%8C%20include%20%E8%B7%AF%E5%BE%84%3CBR%20%2F%3E%23%E3%80%82%E6%88%96%E8%80%85%EF%BC%8C%E4%B9%9F%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%23%20LibTomMath%20%E7%9A%84%E9%9B%86%E6%88%90%E6%9C%80%E5%B0%8F%E7%89%88%E6%9C%AC%E3%80%82%E6%9C%89%E5%85%B3%E8%AF%A5%E9%80%89%E9%A1%B9%E7%9A%84%E4%BC%98%E7%82%B9%3CBR%20%2F%3E%23%20%E5%92%8C%E7%BC%BA%E7%82%B9%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20libtommath.c%20%E7%9A%84%E5%BC%80%E5%A4%B4%E9%83%A8%E5%88%86%E3%80%82%3CBR%20%2F%3E%23CONFIG_INTERNAL_LIBTOMMATH%3Dy%3CBR%20%2F%3E%23ifndef%20CONFIG_INTERNAL_LIBTOMMATH%3CBR%20%2F%3E%23LTM_PATH%3D%2Fusr%2Fsrc%2Flibtommath-0.39%3CBR%20%2F%3E%23CFLAGS%20%2B%3D%20-I%24(LTM_PATH)%3CBR%20%2F%3E%23LIBS%20%2B%3D%20-L%24(LTM_PATH)%3CBR%20%2F%3E%23LIBS_p%20%2B%3D%20-L%24(LTM_PATH)%3CBR%20%2F%3E%23endif%3CBR%20%2F%3E%23%20At%20the%20cost%20of%20about%204%20kB%20of%20additional%20%E4%BA%8C%E8%BF%9B%E5%88%B6%20size%2C%20the%20internal%20LibTomMath%3CBR%20%2F%3E%23%20can%20be%20configured%20to%20include%20faster%20routines%20for%20exptmod%2C%20sqr%2C%20and%20div%20to%3CBR%20%2F%3E%23%20speed%20up%20DH%20and%20RSA%20calculation%20considerably%3CBR%20%2F%3E%23CONFIG_INTERNAL_LIBTOMMATH_FAST%3Dy%3C%2FP%3E%3CP%3E%23%20%E9%80%9A%E8%BF%87%20WMI%20%E5%B0%86%20NDIS%20%E4%BA%8B%E4%BB%B6%E5%A4%84%E7%90%86%E7%BA%B3%E5%85%A5%20wpa_supplicant%2Fwpasvc%E3%80%82%3CBR%20%2F%3E%23%20%E8%BF%99%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%20Windows%20%E7%89%88%E6%9C%AC%EF%BC%8C%E9%9C%80%E8%A6%81%E4%B8%8E%20WMI%20%E7%9B%B8%E5%85%B3%E7%9A%84%E5%A4%B4%E6%96%87%E4%BB%B6%E5%92%8C%20%3CBR%20%2F%3E%20%23%20%E5%B9%B3%E5%8F%B0%E8%BD%AF%E4%BB%B6%E5%BC%80%E5%8F%91%E5%B7%A5%E5%85%B7%E5%8C%85%E4%B8%AD%E7%9A%84%20Wbemuuid.lib%20%E5%8D%B3%E4%BD%BF%E4%BD%BF%E7%94%A8%20MinGW%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E8%AF%91%E3%80%82%3CBR%20%2F%3E%23CONFIG_NDIS_EVENTS_INTEGRATED%3Dy%3CBR%20%2F%3E%23PLATFORMSDKLIB%3D%22%2Fopt%2FProgram%20Files%2FMicrosoft%20Platform%20SDK%2FLib%22%3C%2FP%3E%3CP%3E%23%20%E6%B7%BB%E5%8A%A0%E5%AF%B9%E6%96%B0%20DBus%20%E6%8E%A7%E5%88%B6%E6%8E%A5%E5%8F%A3%E7%9A%84%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%23%20(fi.w1.wpa_supplicant1)%3CBR%20%2F%3E%23CONFIG_CTRL_IFACE_DBUS_NEW%3Dy%3C%2FP%3E%3CP%3E%23%20%E4%B8%BA%E6%96%B0%E7%9A%84%20DBus%20%E6%8E%A7%E5%88%B6%E6%8E%A5%E5%8F%A3%E6%B7%BB%E5%8A%A0%E8%87%AA%E7%9C%81%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%23CONFIG_CTRL_IFACE_DBUS_INTRO%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%B7%BB%E5%8A%A0%E5%8A%A8%E6%80%81%E5%8A%A0%E8%BD%BD%20EAP%20%E6%96%B9%E6%B3%95%E7%9A%84%E5%85%B1%E4%BA%AB%E5%BA%93%E6%94%AF%E6%8C%81%E3%80%82%3CBR%20%2F%3E%23%20%E5%90%AF%E7%94%A8%E8%AF%A5%E9%80%89%E9%A1%B9%E5%90%8E%EF%BC%8C%E6%AF%8F%E4%B8%AA%20EAP%3CBR%20%2F%3E%20%E6%96%B9%E6%B3%95%E9%83%BD%E5%8F%AF%E4%BB%A5%E9%9D%99%E6%80%81%EF%BC%88CONFIG_EAP_%3CMETHOD%3E%20%3Dy%EF%BC%89%E6%88%96%E5%8A%A8%E6%80%81%EF%BC%88CONFIG_EAP_%3CMETHOD%3E%20%3Ddyn%EF%BC%89%E5%9C%B0%E5%8C%85%E5%90%AB%20%23%20%E3%80%82%3CBR%20%2F%3E%23%20%E5%8A%A8%E6%80%81%20EAP%20%E6%96%B9%E6%B3%95%E4%BD%9C%E4%B8%BA%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%E6%9E%84%E5%BB%BA%20(eap_*.so)%E5%9C%A8%3CBR%20%2F%3E%23%20%E7%BD%91%E7%BB%9C%E5%9D%97%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%B9%8B%E5%89%8D%EF%BC%8C%E9%9C%80%E8%A6%81%E5%9C%A8%20wpa_supplicant%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%3CBR%20%2F%3E%23%20%E7%9A%84%E5%BC%80%E5%A4%B4%E5%8A%A0%E8%BD%BD%E5%AE%83%E4%BB%AC%3CBR%20%2F%3E%23%EF%BC%88%E8%AF%B7%E5%8F%82%E9%98%85%E7%A4%BA%E4%BE%8B%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%20load_dynamic_eap%20%E5%8F%82%E6%95%B0%EF%BC%89%E3%80%82%3CBR%20%2F%3E%23%20%3CBR%20%2F%3E%20%23%20%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E4%B8%BB%E7%A8%8B%E5%BA%8F%20%3CBR%20%2F%3E%20%23%20%E4%B8%AD%E5%8C%85%E5%90%AB%20EAP%20%E6%96%B9%E6%B3%95%E7%9A%84%E6%9F%90%E4%BA%9B%E5%85%B1%E4%BA%AB%E9%83%A8%E5%88%86%EF%BC%8C%E4%B8%BA%E4%BA%86%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%E8%BF%99%E4%BA%9B%E9%83%A8%E5%88%86%E4%BD%BF%E7%94%A8%E5%8A%A8%E6%80%81%20EAP%20%E6%96%B9%E6%B3%95%EF%BC%8C%3CBR%20%2F%3E%23%20%E4%B8%BB%E7%A8%8B%E5%BA%8F%E5%BF%85%E9%A1%BB%E6%98%AF%E5%9C%A8%E5%90%AF%E7%94%A8%20EAP%20%E6%96%B9%E6%B3%95%EF%BC%88%3Dy%20%E6%88%96%20%3Ddyn%EF%BC%89%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E7%89%88%E6%9C%AC%E6%9E%84%E5%BB%BA%E7%9A%84%E3%80%82%3CBR%20%2F%3E%23%20%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E4%B8%8D%E8%83%BD%E5%B0%86%20EAP-TLS%2FPEAP%2FTTLS%2FFAST%20%E6%B7%BB%E5%8A%A0%E4%B8%BA%E5%8A%A8%E6%80%81%E5%BA%93%20%3CBR%20%2F%3E%20%23%20%E9%99%A4%E9%9D%9E%E5%9C%A8%E4%B8%BB%E7%89%88%E6%9C%AC%E4%B8%AD%E5%8C%85%E5%90%AB%E8%87%B3%E5%B0%91%E4%B8%80%E4%B8%AA%E4%BB%A5%E5%BC%BA%E5%88%B6%E5%8C%85%E5%90%AB%20%23%20%E5%85%B1%E4%BA%AB%E4%BB%A3%E7%A0%81%E3%80%82%3CBR%20%2F%3E%E5%90%8C%E6%A0%B7%EF%BC%8C%E4%B8%BB%E7%89%88%E6%9C%AC%E4%B8%AD%E5%BF%85%E9%A1%BB%E8%87%B3%E5%B0%91%E5%8C%85%E5%90%AB%E4%B8%80%E4%B8%AA%20EAP-SIM%2FAKA%20%3CBR%20%2F%3E%20%23%20%E6%89%8D%E8%83%BD%E5%8A%A8%E6%80%81%E5%8A%A0%E8%BD%BD%E8%BF%99%E4%BA%9B%E6%96%B9%E6%B3%95%E3%80%82%3CBR%20%2F%3E%23%20%3CBR%20%2F%3E%20%23%20%E5%8F%A6%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%8A%A8%E6%80%81%E5%BA%93%E4%BC%9A%E5%A2%9E%E5%8A%A0%E4%BA%8C%E8%BF%9B%E5%88%B6%20%3CBR%20%2F%3E%20%23%20%E7%9A%84%E6%80%BB%E5%A4%A7%E5%B0%8F%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%AF%B9%E4%BA%8E%3CBR%20%2F%3E%23%20%E5%86%85%E5%AD%98%2F%E9%97%AA%E5%AD%98%E6%95%B0%E9%87%8F%E6%9C%89%E9%99%90%E7%9A%84%E7%9B%AE%E6%A0%87%E6%9D%A5%E8%AF%B4%EF%BC%8C%E5%AE%83%E5%8F%AF%E8%83%BD%E4%B8%8D%E6%98%AF%E6%9C%80%E4%BD%B3%E9%80%89%E6%8B%A9%E3%80%82%3CBR%20%2F%3E%23CONFIG_DYNAMIC_EAP_METHODS%3Dy%3C%2FMETHOD%3E%3C%2FMETHOD%3E%3C%2FP%3E%3CP%3E%23%20%E5%8A%A8%E6%80%81%E5%8A%A0%E8%BD%BD%E5%9B%BE%E4%B9%A6%E9%A6%86%3C%2FP%3E%3CP%3E%23%20%E6%B7%BB%E5%8A%A0%E9%85%8D%E7%BD%AE%E5%BA%93%E7%9A%84%E5%8A%9F%E8%83%BD%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%9C%A8%E7%BC%96%E8%AF%91%E6%97%B6%E5%8A%A0%E8%BD%BD%E3%80%82%3CBR%20%2F%3E%23%20%E5%A6%82%E6%9E%9C%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%88%99%E7%A6%81%E7%94%A8%E5%8A%A8%E6%80%81%E9%85%8D%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%23CONFIG_PKCS11_ENGINE_PATH%20-%20pkcs11_engine%20%E5%BA%93%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%23CONFIG_PKCS11_MODULE_PATH%20-%20pkcs11_module%20%E5%BA%93%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%23CONFIG_OPENSC_ENGINE_PATH%20-%20opensc_engine%20%E5%BA%93%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%23%3CBR%20%2F%3E%23%20%E9%98%BB%E6%AD%A2%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%97%B6%E5%8A%A0%E8%BD%BD%E5%BA%93%3CBR%20%2F%3E%23CONFIG_NO_PKCS11_ENGINE_PATH%3Dy%20%23%20%E9%98%BB%E6%AD%A2%E5%8A%A0%E8%BD%BD%20pkcs11_engine%20%E5%BA%93%E3%80%82%3CBR%20%2F%3E%23CONFIG_NO_PKCS11_MODULE_PATH%3Dy%20%23%20%E9%98%BB%E6%AD%A2%E5%8A%A0%E8%BD%BD%20pkcs11_module%20%E5%BA%93%E3%80%82%3CBR%20%2F%3E%23%20CONFIG_NO_OPENSC_ENGINE_PATH%3Dy%20%23%20%E9%98%BB%E6%AD%A2%E5%8A%A0%E8%BD%BD%20opensc_engine%20%E5%BA%93%E3%80%82%3C%2FP%3E%3CP%3E%23%20%E9%98%BB%E6%AD%A2%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%97%B6%E5%8A%A0%E8%BD%BD%20EAP%20%E5%BA%93%3CBR%20%2F%3E%23CONFIG_NO_LOAD_DYNAMIC_EAP%3Dy%3C%2FP%3E%3CP%3E%23%20%E9%80%82%E7%94%A8%E4%BA%8E%E5%B7%A5%E4%BD%9C%E7%AB%99%E6%A8%A1%E5%BC%8F%E7%9A%84%20IEEE%20%E6%A0%87%E5%87%86%20802.11r-2008%EF%BC%88%E5%BF%AB%E9%80%9F%20BSS%20%E8%BF%87%E6%B8%A1%EF%BC%89config_IEE80211r%3DY%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%23%20%E6%B7%BB%E5%8A%A0%E5%B0%86%E8%B0%83%E8%AF%95%E6%97%A5%E5%BF%97%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%20(%2Ftmp%2Fwpa_supplicant-log-%23.txt)%20%E7%9A%84%E6%94%AF%E6%8C%81%3CBR%20%2F%3ECONFIG_DEBUG_FILE%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%B0%86%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%E5%8F%91%E9%80%81%E5%88%B0%20syslog%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20stdout%3CBR%20%2F%3ECONFIG_DEBUG_SYSLOG%3Dy%3CBR%20%2F%3E%23%20%E4%B8%BA%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%E8%AE%BE%E7%BD%AE%20syslog%20%E8%AE%BE%E6%96%BD%3CBR%20%2F%3E%23CONFIG_DEBUG_SYSLOG_FACILITY%3DLOG_DAEMON%3C%2FP%3E%3CP%3E%23%20%E6%B7%BB%E5%8A%A0%E5%90%91%20Linux%20%E5%86%85%E6%A0%B8%E8%B7%9F%E8%B8%AA%E5%B7%A5%E5%85%B7%E5%8F%91%E9%80%81%E6%89%80%E6%9C%89%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%EF%BC%88%E6%97%A0%E8%AE%BA%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%E7%9A%84%E5%86%97%E4%BD%99%E7%A8%8B%E5%BA%A6%E5%A6%82%E4%BD%95%EF%BC%89%E7%9A%84%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%23%E3%80%82%E8%BF%99%E6%9C%89%E5%8A%A9%E4%BA%8E%E9%80%9A%E8%BF%87%3CBR%20%2F%3E%23%20%E8%B0%83%E8%AF%95%E6%95%B4%E4%B8%AA%E5%A0%86%E6%A0%88%EF%BC%8C%E4%BE%8B%E5%A6%82%E4%BD%BF%E7%94%A8%20trace-cmd%20%E5%B0%86%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%8F%91%E7%94%9F%E7%9A%84%E4%B8%80%E5%88%87%E8%AE%B0%E5%BD%95%E5%88%B0%3CBR%20%2F%3E%23%20%E5%90%8C%E4%B8%80%E6%96%87%E4%BB%B6%E4%B8%AD%E3%80%82%3CBR%20%2F%3E%23CONFIG_DEBUG_LINUX_TRACING%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%B7%BB%E5%8A%A0%E6%94%AF%E6%8C%81%E5%B0%86%E8%B0%83%E8%AF%95%E6%97%A5%E5%BF%97%E5%86%99%E5%85%A5%20Android%20logcat%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E6%A0%87%E5%87%86%3CBR%20%2F%3E%23%20%E8%BE%93%E5%87%BA%3CBR%20%2F%3E%23CONFIG_ANDROID_LOG%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%90%AF%E7%94%A8%E6%9D%83%E9%99%90%E5%88%86%E7%A6%BB%EF%BC%88%E8%AF%A6%E8%A7%81%20README%20%22%E6%9D%83%E9%99%90%E5%88%86%E7%A6%BB%22%EF%BC%89%3CBR%20%2F%3E%23CONFIG_PRIVSEP%3Dy%3C%2FP%3E%3CP%3E%23%20%E9%80%9A%E8%BF%87%E5%B0%86%20Michael%3CBR%20%2F%3E%23%20MIC%20%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%E5%BB%B6%E8%BF%9F%200%20%E5%88%B0%2060%20%E7%A7%92%E4%B9%8B%E9%97%B4%E7%9A%84%E9%9A%8F%E6%9C%BA%E6%97%B6%E9%97%B4%EF%BC%8C%E6%9D%A5%E5%87%8F%E8%BD%BB%E9%92%88%E5%AF%B9%20TKIP%20%E7%9A%84%E6%9F%90%E4%BA%9B%E6%94%BB%E5%87%BB%3CBR%20%2F%3E%23CONFIG_DELAYED_MIC_ERROR_REPORT%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%90%AF%E7%94%A8%E7%94%A8%E4%BA%8E%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E8%B0%83%E8%AF%95%E7%9A%84%E8%B7%9F%E8%B8%AA%E4%BB%A3%E7%A0%81%3CBR%20%2F%3E%23%20%E8%BF%99%E5%B0%86%E8%B7%9F%E8%B8%AA%E5%86%85%E5%AD%98%E5%88%86%E9%85%8D%E5%92%8C%E5%85%B6%E4%BB%96%E6%B3%A8%E5%86%8C%E7%9A%84%E4%BD%BF%E7%94%A8%E6%83%85%E5%86%B5%EF%BC%8C%E5%B9%B6%E9%80%9A%E8%BF%87%E8%B0%83%E7%94%A8%EF%BC%88%E6%88%96%E5%88%86%E9%85%8D%EF%BC%89%E4%BD%8D%E7%BD%AE%E7%9A%84%E5%9B%9E%E6%BA%AF%E6%8A%A5%E5%91%8A%3CBR%20%2F%3E%23%20%E4%B8%8D%E6%AD%A3%E7%A1%AE%E7%9A%84%E4%BD%BF%E7%94%A8%E6%83%85%E5%86%B5%E3%80%82%3CBR%20%2F%3E%23CONFIG_WPA_TRACE%3Dy%3CBR%20%2F%3E%23%20%E5%AF%B9%E4%BA%8E%20BSD%EF%BC%8C%E8%AF%B7%E5%8F%96%E6%B6%88%E8%BF%99%E4%BA%9B%E6%B3%A8%E9%87%8A%E3%80%82%3CBR%20%2F%3E%23LIBS%20%2B%3D%20-lexecinfo%3CBR%20%2F%3E%23LIBS_p%20%2B%3D%20-lexecinfo%3CBR%20%2F%3E%23LIBS_c%20%2B%3D%20-lexecinfo%3C%2FP%3E%3CP%3E%23%20%E4%BD%BF%E7%94%A8%20libbfd%20%E8%8E%B7%E5%8F%96%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E8%B0%83%E8%AF%95%E6%89%80%E9%9C%80%E7%9A%84%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%3CBR%20%2F%3E%23%20%E8%BF%99%E5%B0%86%E5%90%AF%E7%94%A8%20libbfd%EF%BC%8C%E4%BB%A5%E4%BE%BF%E4%B8%BA%20CONFIG_WPA_TRACE%3Dy%20%E7%94%9F%E6%88%90%E7%9A%84%E5%9B%9E%E6%BA%AF%E8%8E%B7%E5%8F%96%E6%9B%B4%E8%AF%A6%E7%BB%86%E7%9A%84%E7%AC%A6%E5%8F%B7%3CBR%20%2F%3E%23%E3%80%82%3CBR%20%2F%3E%23CONFIG_WPA_TRACE_BFD%3Dy%3CBR%20%2F%3E%23%20%E5%AF%B9%E4%BA%8E%20BSD%EF%BC%8C%E8%AF%B7%E5%8F%96%E6%B6%88%E8%BF%99%E4%BA%9B%E6%B3%A8%E9%87%8A%E3%80%82%3CBR%20%2F%3E%23LIBS%20%2B%3D%20-lbfd%20-liberty%20-lz%3CBR%20%2F%3E%23LIBS_p%20%2B%3D%20-lbfd%20-liberty%20-lz%3CBR%20%2F%3E%23LIBS_c%20%2B%3D%20-lbfd%20-liberty%20-lz%3C%2FP%3E%3CP%3E%23%20wpa_supplicant%20%E4%BE%9D%E8%B5%96%E4%BA%8E%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E6%8F%90%E4%BE%9B%E7%9A%84%E5%BC%BA%E9%9A%8F%E6%9C%BA%E6%95%B0%E7%94%9F%E6%88%90%3CBR%20%2F%3E%23%E3%80%82os_get_random()%20%E5%87%BD%E6%95%B0%E7%94%A8%E4%BA%8E%E5%9C%A8%E9%9C%80%E8%A6%81%E6%97%B6%E8%8E%B7%E5%8F%96%E9%9A%8F%E6%9C%BA%3CBR%20%2F%3E%23%20%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%BE%8B%E5%A6%82%E7%94%A8%E4%BA%8E%E7%94%9F%E6%88%90%E5%AF%86%E9%92%A5%E3%80%82%E5%9C%A8%20Linux%20%E5%92%8C%20BSD%20%E7%B3%BB%E7%BB%9F%E4%B8%8A%EF%BC%8C%E8%AF%A5%3CBR%20%2F%3E%23%20%E9%80%9A%E8%BF%87%E8%AF%BB%E5%8F%96%20%2Fdev%2Furandom%20%E8%BF%90%E8%A1%8C%E3%80%82%E9%9C%80%E8%A6%81%E6%B3%A8%E6%84%8F%E7%9A%84%E6%98%AF%EF%BC%8C%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E7%86%B5%E6%B1%A0%3CBR%20%2F%3E%23%20%E9%9C%80%E8%A6%81%E5%9C%A8%20wpa_supplicant%20%E5%90%AF%E5%8A%A8%E5%89%8D%E6%AD%A3%E7%A1%AE%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%E8%BF%99%E5%BE%88%3CBR%20%2F%3E%E9%87%8D%E8%A6%81%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%E5%9C%A8%E6%B2%A1%E6%9C%89%E7%A1%AC%E4%BB%B6%E9%9A%8F%E6%9C%BA%3CBR%20%2F%3E%E6%95%B0%E7%94%9F%E6%88%90%E5%99%A8%E7%9A%84%E5%B5%8C%E5%85%A5%E5%BC%8F%E8%AE%BE%E5%A4%87%E4%B8%8A%EF%BC%8C%E5%B9%B6%E4%B8%94%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E5%90%AF%E5%8A%A8%E6%97%B6%E5%8F%AF%E8%83%BD%E4%BD%BF%E7%94%A8%E6%9C%80%E5%B0%8F%E7%9A%84%E7%86%B5%E6%9D%A5%E7%94%9F%E6%88%90%E9%9A%8F%E6%9C%BA%E6%95%B0%20%3CBR%20%2F%3E%20%23%E3%80%82%3CBR%20%2F%3E%23%20%3CBR%20%2F%3E%20%23%20%E4%BD%9C%E4%B8%BA%E5%AE%89%E5%85%A8%E7%BD%91%EF%BC%8Cwpa_supplicant%20%E9%BB%98%E8%AE%A4%E5%B0%9D%E8%AF%95%E5%9C%A8%E5%86%85%E9%83%A8%E6%94%B6%E9%9B%86%20%3CBR%20%2F%3E%20%23%20%E4%B8%AA%E9%A2%9D%E5%A4%96%E7%86%B5%EF%BC%8C%E7%94%A8%E4%BA%8E%E7%94%9F%E6%88%90%E9%9A%8F%E6%9C%BA%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%B8%8E%E4%BB%8E%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E8%8E%B7%E5%8F%96%E7%9A%84%E6%95%B0%E6%8D%AE%20%23%20%E6%B7%B7%E5%90%88%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E6%9C%AC%E8%BA%AB%E5%B9%B6%E4%B8%8D%E6%98%AF%E5%BE%88%E5%BC%BA%EF%BC%8C%E4%BD%86%E5%9C%A8%E7%B3%BB%E7%BB%9F%E6%B1%A0%E6%9C%AA%E6%AD%A3%E7%A1%AE%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%AE%83%E5%8F%AF%E8%83%BD%3CBR%20%2F%3E%23%20%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BC%BA%E7%83%88%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%E7%A1%AC%E4%BB%B6%E8%BE%85%E5%8A%A9%E9%9A%8F%E6%9C%BA%E6%95%B0%E7%94%9F%E6%88%90%E5%99%A8%E6%88%96%20%3CBR%20%2F%3E%20%23%20%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E9%87%8D%E5%90%AF%E6%97%B6%E7%9A%84%E7%8A%B6%E6%80%81%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%B6%B3%E5%A4%9F%E7%9A%84%20%3CBR%20%2F%3E%20%23%20%E7%86%B5%E5%AF%B9%E7%B3%BB%E7%BB%9F%E6%B1%A0%E8%BF%9B%E8%A1%8C%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%23%3CBR%20%2F%3E%23%20%E5%8F%AF%E5%AF%B9%20wpa_supplicant%20%E8%BF%9B%E8%A1%8C%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%BD%BF%E5%85%B6%E5%9C%A8%3CBR%20%2F%3E%23%20%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E6%97%B6%E4%BF%9D%E6%8C%81%E8%87%AA%E5%B7%B1%E7%9A%84%E7%86%B5%E5%AD%98%E5%82%A8%EF%BC%8C%E4%BB%A5%E5%A2%9E%E5%BC%BA%E9%9A%8F%E6%9C%BA%E6%95%B0%E7%94%9F%E6%88%90%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E6%A0%B7%E5%81%9A%E5%B9%B6%E4%B8%8D%E5%AE%8C%E7%BE%8E%EF%BC%8C%E4%BD%86%E6%AF%94%E6%AF%8F%E6%AC%A1%3CBR%20%2F%3E%23%20%E9%87%8D%E5%90%AF%E5%90%8E%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E9%9A%8F%E6%9C%BA%E6%95%B0%E5%BA%8F%E5%88%97%E8%A6%81%E5%AE%89%E5%85%A8%E5%BE%97%E5%A4%9A%E3%80%82%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20-e%3CENTROPY%20file%3D%22%22%3E%20%E5%91%BD%E4%BB%A4%E8%A1%8C%E9%80%89%E9%A1%B9%E5%90%AF%E7%94%A8%E8%AF%A5%E5%8A%9F%E8%83%BD%E3%80%82%3CBR%20%2F%3E%23%20%E6%8C%87%E5%AE%9A%E7%9A%84%E6%96%87%E4%BB%B6%E9%9C%80%E8%A6%81%E8%83%BD%E8%A2%AB%20wpa_supplicant%20%E8%AF%BB%E5%8F%96%E5%92%8C%E5%86%99%E5%85%A5%E3%80%82%3CBR%20%2F%3E%23%20%3CBR%20%2F%3E%20%23%20%E5%A6%82%E6%9E%9C%E5%B7%B2%E7%9F%A5%20os_get_random%20()%20%E5%8F%AF%E4%BB%A5%E6%8F%90%E4%BE%9B%E5%BC%BA%E5%A4%A7%E7%9A%84%E9%9A%8F%E6%9C%BA%E6%95%B0%E6%8D%AE%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%9C%A8%20%3CBR%20%2F%3E%20%23%20Linux%2FBSD%20%E4%B8%8A%EF%BC%8C%E5%B7%B2%E7%9F%A5%E7%9B%B8%E5%85%B3%E6%9D%BF%E6%8B%A5%E6%9C%89%E6%9D%A5%E8%87%AA%20%2Fdev%2Furandom%20%E7%9A%84%E9%9A%8F%E6%9C%BA%20%3CBR%20%2F%3E%20%23%20%E6%95%B0%E6%8D%AE%E7%9A%84%E5%8F%AF%E9%9D%A0%E6%9D%A5%E6%BA%90%EF%BC%89%EF%BC%8C%E5%88%99%E5%86%85%E9%83%A8%20wpa_supplicant%20%E9%9A%8F%E6%9C%BA%E6%B1%A0%E5%8F%AF%E4%BB%A5%20%23%20%E7%A6%81%E7%94%A8%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E5%B0%86%E8%8A%82%E7%9C%81%E4%B8%80%E4%BA%9B%E4%BA%8C%E8%BF%9B%E5%88%B6%E5%A4%A7%E5%B0%8F%E5%92%8C%20CPU%20%E4%BD%BF%E7%94%A8%E9%87%8F%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%B7%B2%E7%9F%A5%E5%8F%AF%E5%9C%A8%E6%BB%A1%E8%B6%B3%E4%B8%8A%E8%BF%B0%E8%A6%81%E6%B1%82%E7%9A%84%E8%AE%BE%E5%A4%87%20%3CBR%20%2F%3E%20%23%20%E4%B8%8A%E4%BD%BF%E7%94%A8%E7%9A%84%E7%89%88%E6%9C%AC%E6%89%8D%E5%BA%94%E8%80%83%E8%99%91%E6%AD%A4%20%23%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%23CONFIG_NO_RANDOM_POOL%3Dy%3C%2FENTROPY%3E%3C%2FP%3E%3CP%3E%23%20%E5%9C%A8%20Linux%203.17%20%E5%8F%8A%E6%9B%B4%E6%96%B0%E7%89%88%E6%9C%AC%E4%B8%AD%EF%BC%8Cgetrandom(2)%20%E8%B0%83%E7%94%A8%E6%8F%90%E4%BE%9B%E4%BA%86%E6%AF%94%20%2Fdev%2Frandom%20%E6%9B%B4%E5%8F%AF%E9%9D%A0%3CBR%20%2F%3E%23%20%E4%BD%86%E6%9B%B4%E5%AE%89%E5%85%A8%E7%9A%84%E9%9A%8F%E6%9C%BA%E6%80%A7%E6%9D%A5%E6%BA%90%E3%80%82%3CBR%20%2F%3E%23%20%E9%9C%80%E8%A6%81%20glibc%202.25%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%8D%E5%8F%AF%E7%94%A8%EF%BC%8C%E5%88%99%E5%9B%9E%E9%80%80%E5%88%B0%20%2Fdev%2Frandom%E3%80%82%3CBR%20%2F%3E%23CONFIG_GETRANDOM%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%94%AF%E6%8C%81%20IEEE%20802.11ac%EF%BC%88%E8%B6%85%E9%AB%98%E5%90%9E%E5%90%90%E9%87%8F%EF%BC%89%EF%BC%88%E4%B8%BB%E8%A6%81%E7%94%A8%E4%BA%8E%20AP%20%E6%A8%A1%E5%BC%8F%EF%BC%89%3CBR%20%2F%3ECONFIG_IEEE80211AC%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%94%AF%E6%8C%81%20IEEE%20802.11ax%20HE%EF%BC%88%E4%B8%BB%E8%A6%81%E7%94%A8%E4%BA%8E%20AP%20%E6%A8%A1%E5%BC%8F%EF%BC%89%3CBR%20%2F%3ECONFIG_IEEE80211AX%3Dy%3C%2FP%3E%3CP%3E%23%20IEEE%20802.11be%20EHT%20%E6%94%AF%E6%8C%81%EF%BC%88%E4%B8%BB%E8%A6%81%E7%94%A8%E4%BA%8E%20AP%20%E6%A8%A1%E5%BC%8F%EF%BC%89%3CBR%20%2F%3E%23%20CONFIG_IEEE80211AX%20%E6%98%AF%E8%AE%BE%E7%BD%AE%20CONFIG_IEEE80211BE%20%E7%9A%84%E5%BF%85%E9%80%89%E9%A1%B9%E3%80%82%3CBR%20%2F%3E%23%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%BF%99%E6%98%AF%E4%B8%80%E9%A1%B9%E8%AF%95%E9%AA%8C%E6%80%A7%E5%B7%A5%E4%BD%9C%EF%BC%8C%E6%AD%A3%E5%9C%A8%E8%BF%9B%E8%A1%8C%E4%B8%AD%E3%80%82%3CBR%20%2F%3E%23%20%E5%AE%9A%E4%B9%89%E4%BB%8D%E6%9C%89%E5%8F%AF%E8%83%BD%E6%9B%B4%E6%94%B9%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%B8%8D%E5%BA%94%E6%8C%87%E6%9C%9B%E5%AE%83%E8%83%BD%E4%B8%8E%3CBR%20%2F%3E%23%20%E6%9C%80%E7%BB%88%E7%9A%84%20IEEE%20802.11be%20%E7%89%88%E6%9C%AC%E4%BA%92%E6%93%8D%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%23CONFIG_IEEE80211BE%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%97%A0%E7%BA%BF%E7%BD%91%E7%BB%9C%E7%AE%A1%E7%90%86%20(IEEE%20STD%20802.11v-2011)%20%3CBR%20%2F%3E%20%23%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%BF%99%E6%98%AF%E5%AE%9E%E9%AA%8C%E6%80%A7%E7%9A%84%EF%BC%8C%E5%B0%9A%E6%9C%AA%E5%AE%8C%E5%85%A8%E5%AE%9E%E7%8E%B0%E3%80%82%3CBR%20%2F%3E%23CONFIG_WNM%3Dy%3C%2FP%3E%3CP%3E%23%20Interworking%20(IEEE%20802.11u)%3CBR%20%2F%3E%23%20%E6%AD%A4%E9%A1%B9%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%90%AF%E7%94%A8%E6%94%B9%E8%BF%9B%E4%B8%8E%3CBR%20%2F%3E%23%20%E5%A4%96%E9%83%A8%E7%BD%91%E7%BB%9C%E4%BA%92%E9%80%9A%E7%9A%84%E5%8A%9F%E8%83%BD%EF%BC%88GAS%2FANQP%20%E5%8F%AF%E4%BA%86%E8%A7%A3%E6%9B%B4%E5%A4%9A%E6%9C%89%E5%85%B3%E7%BD%91%E7%BB%9C%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%B9%B6%E6%A0%B9%E6%8D%AE%E5%8F%AF%E7%94%A8%E5%87%AD%E8%AF%81%E9%80%89%E6%8B%A9%E7%BD%91%E7%BB%9C%3CBR%20%2F%3E%23%EF%BC%89%E3%80%82%3CBR%20%2F%3ECONFIG_INTERWORKING%3Dy%3C%2FP%3E%3CP%3E%23%20Hotspot%202.0%3CBR%20%2F%3ECONFIG_HS20%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%9C%A8%20wpa_supplicant%3CBR%20%2F%3E%20%E4%B8%AD%E5%90%AF%E7%94%A8%E6%8E%A5%E5%8F%A3%E5%8C%B9%E9%85%8D%20%23CONFIG_MATCH_IFACE%3Dy%3C%2FP%3E%3CP%3E%23%20Disable%20roaming%20in%20wpa_supplicant%3CBR%20%2F%3E%23CONFIG_NO_ROAMING%3Dy%3C%2FP%3E%3CP%3E%23%20%E4%BD%BF%E7%94%A8%20wpa_supplicant%20%E8%BF%9B%E8%A1%8C%20AP%20%E6%A8%A1%E5%BC%8F%E5%B7%A5%E4%BD%9C%20%3CBR%20%2F%3E%20%23%20%E8%BF%99%E5%8F%AF%E7%94%A8%E4%BA%8E%E4%BD%BF%E7%94%A8%20wpa_supplicant%20%E6%8E%A7%E5%88%B6%20AP%20%E6%A8%A1%E5%BC%8F%E5%B7%A5%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%23%20%E9%9C%80%E8%A6%81%E6%B3%A8%E6%84%8F%E7%9A%84%E6%98%AF%EF%BC%8C%E8%BF%99%E4%B8%BB%E8%A6%81%E6%98%AF%E9%92%88%E5%AF%B9%E7%AE%80%E5%8D%95%E7%9A%84%E6%83%85%E5%86%B5%EF%BC%8C%E5%A6%82%3CBR%20%2F%3E%23%20WPA2-%E4%B8%AA%E4%BA%BA%EF%BC%8C%E8%80%8C%E6%9B%B4%E5%A4%8D%E6%9D%82%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%8C%E5%A6%82%E5%B8%A6%E6%9C%89%3CBR%20%2F%3E%23%20%E5%A4%96%E9%83%A8%20RADIUS%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%20WPA2-%E4%BC%81%E4%B8%9A%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20hostapd%20%E6%94%AF%E6%8C%81%E3%80%82%3CBR%20%2F%3ECONFIG_AP%3Dy%3C%2FP%3E%3CP%3E%23%20P2P%20(Wi-Fi%20Direct)%3CBR%20%2F%3E%23%20%E6%AD%A4%E9%A1%B9%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%9C%A8%20wpa_supplicant%20%E4%B8%AD%E5%90%AF%E7%94%A8%20P2P%20%E6%94%AF%E6%8C%81%E3%80%82%E6%9C%89%E5%85%B3%20P2P%20%E6%93%8D%E4%BD%9C%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20README-P2P%3CBR%20%2F%3E%23%E3%80%82%3CBR%20%2F%3ECONFIG_P2P%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%90%AF%E7%94%A8%20TDLS%20%E6%94%AF%E6%8C%81%3CBR%20%2F%3ECONFIG_TDLS%3Dy%3C%2FP%3E%3CP%3E%23%20Wi-Fi%20Display%3CBR%20%2F%3E%23%20%E6%AD%A4%E9%A1%B9%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%90%AF%E7%94%A8%20P2P%20%E7%9A%84%20Wi-Fi%20Display%20%E6%89%A9%E5%B1%95%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%3CBR%20%2F%3E%23%20%E7%A8%8B%E5%BA%8F%E6%9D%A5%E6%8E%A7%E5%88%B6%E4%BF%A1%E6%81%AF%E4%B8%AD%E7%9A%84%E9%99%84%E5%8A%A0%E4%BF%A1%E6%81%AF%E4%BA%A4%E6%8D%A2%E3%80%82%3CBR%20%2F%3ECONFIG_WIFI_DISPLAY%3Dy%3C%2FP%3E%3CP%3E%23%20Autoscan%3CBR%20%2F%3E%23%20%E6%AD%A4%E9%A1%B9%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%9C%A8%20wpa_supplicant%20%E4%B8%AD%E5%90%AF%E7%94%A8%E8%87%AA%E5%8A%A8%E6%89%AB%E6%8F%8F%E6%94%AF%E6%8C%81%E3%80%82%3CBR%20%2F%3E%23%20%E6%9C%89%E5%85%B3%E8%87%AA%E5%8A%A8%E6%89%AB%E6%8F%8F%E7%94%A8%E6%B3%95%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20wpa_supplicant.conf%E3%80%82%3CBR%20%2F%3E%23%3CBR%20%2F%3E%23%20%E7%9B%B4%E6%8E%A5%E5%90%AF%E7%94%A8%E6%A8%A1%E5%9D%97%E5%B0%86%E5%90%AF%E7%94%A8%E8%87%AA%E5%8A%A8%E6%89%AB%E6%8F%8F%E6%94%AF%E6%8C%81%E3%80%82%3CBR%20%2F%3E%23%20%E5%AF%B9%E4%BA%8E%E6%8C%87%E6%95%B0%E6%A8%A1%E5%9D%97%EF%BC%9A%3CBR%20%2F%3E%23CONFIG_AUTOSCAN_EXPONENTIAL%3Dy%3CBR%20%2F%3E%23%20%E5%AF%B9%E4%BA%8E%E5%91%A8%E6%9C%9F%E6%A8%A1%E5%9D%97%EF%BC%9A%3CBR%20%2F%3E%23CONFIG_AUTOSCAN_PERIODIC%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%A4%96%E9%83%A8%E5%AD%98%E5%82%A8%E7%9A%84%E5%AF%86%E7%A0%81%EF%BC%88%E5%92%8C%E5%AF%86%E7%A0%81%E7%AD%89%EF%BC%89%E5%90%8E%E7%AB%AF%20%3CBR%20%2F%3E%20%23%20%E8%BF%99%E4%BA%9B%E5%8F%AF%E9%80%89%E7%9A%84%E6%9C%BA%E5%88%B6%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%A2%9E%E5%8A%A0%E5%AF%B9%E5%9C%A8%E5%A4%96%E9%83%A8%EF%BC%88%E5%88%B0%20wpa_supplicant%EF%BC%89%E4%BD%8D%E7%BD%AE%E5%AD%98%E5%82%A8%E5%AF%86%E7%A0%81%20%3CBR%20%2F%3E%20%23%20%E5%92%8C%E5%85%B6%E4%BB%96%E6%9C%BA%E5%AF%86%E4%BF%A1%E6%81%AF%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%E4%BE%8B%E5%A6%82%3CBR%20%2F%3E%EF%BC%8C%E8%BF%99%E5%85%81%E8%AE%B8%E4%BD%BF%E7%94%A8%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E7%89%B9%E5%AE%9A%E7%9A%84%E5%AF%86%E9%92%A5%E5%AD%98%E5%82%A8%20%3CBR%20%2F%3E%20%23%20%3CBR%20%2F%3E%20%23%20%E5%A4%96%E9%83%A8%E5%AF%86%E7%A0%81%E5%90%8E%E7%AB%AF%E7%94%A8%E4%BA%8E%E6%B5%8B%E8%AF%95%E7%9B%AE%E7%9A%84%EF%BC%88%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%23CONFIG_EXT_PASSWORD_TEST%20%3Dy%20%3CBR%20%2F%3E%20%23%20%E5%9F%BA%E4%BA%8E%E6%96%87%E4%BB%B6%E7%9A%84%E5%90%8E%E7%AB%AF%E4%BB%8E%E5%A4%96%E9%83%A8%E6%96%87%E4%BB%B6%E8%AF%BB%E5%8F%96%E5%AF%86%E7%A0%81%E3%80%82%3CBR%20%2F%3E%23CONFIG_EXT_PASSWORD_FILE%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%90%AF%E7%94%A8%E5%BF%AB%E9%80%9F%E4%BC%9A%E8%AF%9D%E4%BC%A0%E8%BE%93%20(FST)%3CBR%20%2F%3E%23CONFIG_FST%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%90%AF%E7%94%A8%E7%94%A8%E4%BA%8E%20FST%20%E6%B5%8B%E8%AF%95%E7%9A%84%20CLI%20%E5%91%BD%E4%BB%A4%3CBR%20%2F%3E%23CONFIG_FST_TEST%3Dy%3C%2FP%3E%3CP%3E%23%20OS%20X%20%E7%89%88%E6%9C%AC%E3%80%82%E8%BF%99%E4%BB%85%E7%94%A8%E4%BA%8E%E6%9E%84%E5%BB%BA%20eapol_test%E3%80%82%3CBR%20%2F%3E%23CONFIG_OSX%3Dy%3C%2FP%3E%3CP%3E%23%20%E8%87%AA%E5%8A%A8%E4%BF%A1%E9%81%93%E9%80%89%E6%8B%A9%3CBR%20%2F%3E%23%20%E5%BD%93%E4%BF%A1%E9%81%93%3CBR%20%2F%3E%23%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%220%20%E6%97%B6%EF%BC%8C%E8%BF%99%E5%B0%86%E5%85%81%E8%AE%B8%20wpa_supplicant%20%E8%87%AA%E5%8A%A8%E9%80%89%E6%8B%A9%E4%BF%A1%E9%81%93%22.%3CBR%20%2F%3E%23%3CBR%20%2F%3E%23%20TODO%EF%BC%9A%E6%89%A9%E5%B1%95%E8%A7%A3%E6%9E%90%E5%99%A8%EF%BC%8C%E4%BD%BF%E5%85%B6%E8%83%BD%E5%A4%9F%E8%A7%A3%E6%9E%90%22channel%3Dacs_survey%22%20%EF%BC%8C%E4%BB%A5%E6%9B%BF%E4%BB%A3%3CBR%20%2F%3E%23%22channel%3D0%22%20%E3%80%82%E8%BF%99%E5%B0%86%E4%BD%BF%E6%88%91%E4%BB%AC%E6%9C%80%E7%BB%88%E8%83%BD%E4%BB%A5%3CBR%20%2F%3E%23%20%E7%B1%BB%E4%BC%BC%E7%9A%84%E6%96%B9%E5%BC%8F%E6%B7%BB%E5%8A%A0%E5%85%B6%E4%BB%96%20ACS%20%E7%AE%97%E6%B3%95%E3%80%82%3CBR%20%2F%3E%23%3CBR%20%2F%3E%23%20%E8%87%AA%E5%8A%A8%E9%80%89%E6%8B%A9%E7%9B%AE%E5%89%8D%E5%8F%AA%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E6%97%B6%E8%BF%9B%E8%A1%8C%EF%BC%8C%E4%BB%A5%E5%90%8E%3CBR%20%2F%3E%23%20%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E8%BF%9B%E8%A1%8C%E8%83%8C%E6%99%AF%E6%A3%80%E6%9F%A5%EF%BC%8C%E4%BB%A5%E4%BE%BF%E9%9A%8F%E7%9D%80%3CBR%20%2F%3E%23%20%E6%97%B6%E9%97%B4%E7%9A%84%E6%8E%A8%E7%A7%BB%EF%BC%8C%E4%B8%8D%E6%96%AD%E5%90%91%E6%9B%B4%E7%90%86%E6%83%B3%E7%9A%84%E9%80%9A%E9%81%93%E5%8F%91%E5%B1%95%E3%80%82ACS%20%E7%9B%AE%E5%89%8D%E4%BB%85%E9%80%9A%E8%BF%87%20nl80211%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%94%AF%E6%8C%81%EF%BC%8C%3CBR%20%2F%3E%23%20%E6%82%A8%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%BF%85%E9%A1%BB%E5%85%B7%E5%A4%87%E8%B0%83%E6%9F%A5%E8%BD%AC%E5%82%A8%E5%8A%9F%E8%83%BD%EF%BC%8C%E8%AF%A5%E5%8A%9F%E8%83%BD%E5%9C%A8%E6%89%AB%E6%8F%8F%E8%BF%87%E7%A8%8B%E4%B8%AD%E7%94%B1%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%23%20%E5%A1%AB%E5%85%A5%E3%80%82%3CBR%20%2F%3E%23%3CBR%20%2F%3E%23%20TODO%EF%BC%9A%E4%B8%8E%20hostapd%20%E7%B1%BB%E4%BC%BC%EF%BC%8C%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%3CBR%20%2F%3E%23%20%E6%96%B0%E5%88%9B%E5%BB%BA%E7%9A%84%20wpa_supplicant.conf%20%E5%8F%98%E9%87%8F%20acs_num_scans%20%E8%87%AA%E5%AE%9A%E4%B9%89%20ACS%20%E5%8B%98%E6%B5%8B%E7%AE%97%E6%B3%95%E3%80%82%3CBR%20%2F%3E%23%3CBR%20%2F%3E%23%20%E6%94%AF%E6%8C%81%E7%9A%84%20ACS%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%3CBR%20%2F%3E%23%20*%20ath9k%3CBR%20%2F%3E%23%20*%20ath5k%3CBR%20%2F%3E%23%20*%20ath10k%3CBR%20%2F%3E%23%3CBR%20%2F%3E%23%20%E6%9B%B4%E5%A4%9A%E8%AF%A6%E6%83%85%E8%AF%B7%E5%8F%82%E8%80%83%EF%BC%9A%3CBR%20%2F%3E%23%3CA%20href%3D%22http%3A%2F%2Fwireless.kernel.org%2Fen%2Fusers%2FDocumentation%2Facs%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwireless.kernel.org%2Fen%2Fusers%2FDocumentation%2Facs%3C%2FA%3E%3CBR%20%2F%3E%23CONFIG_ACS%3Dy%3C%2FP%3E%3CP%3E%23%20%E6%94%AF%E6%8C%81%E5%A4%9A%E9%A2%91%E6%AE%B5%E8%BF%90%E8%A1%8C%3CBR%20%2F%3E%23CONFIG_MBO%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%BF%AB%E9%80%9F%E5%88%9D%E5%A7%8B%E9%93%BE%E8%B7%AF%E8%AE%BE%E7%BD%AE%20(FILS)%20(IEEE%20802.11ai)%3CBR%20%2F%3ECONFIG_FILS%3Dy%3CBR%20%2F%3E%23%20%E4%BD%BF%E7%94%A8%20PFS%20%E8%BF%9B%E8%A1%8C%20FILS%20%E5%85%B1%E4%BA%AB%E5%AF%86%E9%92%A5%E9%AA%8C%E8%AF%81%3CBR%20%2F%3E%23CONFIG_FILS_SK_PFS%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%9C%A8%20IBSS%20%E7%BD%91%E7%BB%9C%E4%B8%8A%E6%94%AF%E6%8C%81%20RSN%20%3CBR%20%2F%3E%20%23%20%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20proto%3DRSN%20%E5%92%8C%20%3CBR%20%2F%3E%20%23%20key_mgmt%3DWPA-PSK%20%E7%9A%84%20mode%3D1%20%E7%BD%91%E7%BB%9C%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%EF%BC%88%E5%8D%B3%E5%85%A8%E5%AF%86%E9%92%A5%E7%AE%A1%E7%90%86%E8%80%8C%E4%B8%8D%E6%98%AF%20WPA-None%EF%BC%89%E3%80%82%3CBR%20%2F%3ECONFIG_IBSS_RSN%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%A4%96%E9%83%A8%20PMKSA%20%E7%BC%93%E5%AD%98%E6%8E%A7%E5%88%B6%3CBR%20%2F%3E%23%20%E6%AD%A4%E9%A1%B9%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%90%AF%E7%94%A8%E6%8E%A7%E5%88%B6%E6%8E%A5%E5%8F%A3%E5%91%BD%E4%BB%A4%EF%BC%8C%E5%85%81%E8%AE%B8%E8%8E%B7%E5%8F%96%E5%BD%93%E5%89%8D%3CBR%20%2F%3E%23%20PMKSA%20%E7%BC%93%E5%AD%98%E6%9D%A1%E7%9B%AE%E5%B9%B6%E6%B7%BB%E5%8A%A0%E6%96%B0%E6%9D%A1%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%23CONFIG_PMKSA_CACHE_EXTERNAL%3Dy%3C%2FP%3E%3CP%3E%23%20%E7%BD%91%E7%8A%B6%E7%BD%91%E7%BB%9C%EF%BC%88IEEE%20802.11s%EF%BC%89%3CBR%20%2F%3E%23CONFIG_MESH%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%90%8E%E5%8F%B0%E6%89%AB%E6%8F%8F%E6%A8%A1%E5%9D%97%3CBR%20%2F%3E%23%20%E8%BF%99%E4%BA%9B%E6%A8%A1%E5%9D%97%E5%8F%AF%E7%94%A8%E4%BA%8E%E8%AF%B7%E6%B1%82%20wpa_supplicant%20%E6%89%A7%E8%A1%8C%E5%90%8E%E5%8F%B0%E6%89%AB%E6%8F%8F%3CBR%20%2F%3E%23%20%E6%93%8D%E4%BD%9C%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%9C%A8%20ESS%EF%BC%88%E5%90%8C%E4%B8%80%20SSID%EF%BC%89%E5%86%85%E8%BF%9B%E8%A1%8C%E6%BC%AB%E6%B8%B8%E3%80%82%E6%9C%89%E5%85%B3%E8%AF%A6%E6%83%85%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CBR%20%2F%3E%23%20wpa_supplicant.conf%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%20bgscan%20%E5%8F%82%E6%95%B0%E3%80%82%3CBR%20%2F%3E%23%20%E6%A0%B9%E6%8D%AE%E4%BF%A1%E5%8F%B7%E5%BC%BA%E5%BA%A6%E5%AE%9A%E6%9C%9F%E8%BF%9B%E8%A1%8C%E8%83%8C%E6%99%AF%E6%89%AB%E6%8F%8F%3CBR%20%2F%3ECONFIG_BGSCAN_SIMPLE%3Dy%3CBR%20%2F%3E%23%20%E5%AD%A6%E4%B9%A0%E7%BD%91%E7%BB%9C%E4%BD%BF%E7%94%A8%E7%9A%84%E4%BF%A1%E9%81%93%EF%BC%8C%E5%B9%B6%E5%B0%BD%E9%87%8F%E9%81%BF%E5%85%8D%E5%9C%A8%E5%85%B6%E4%BB%96%3CBR%20%2F%3E%23%20%E4%BF%A1%E9%81%93%E4%B8%8A%E8%BF%9B%E8%A1%8C%20bgscans%20%E6%89%AB%E6%8F%8F%EF%BC%88%E5%AE%9E%E9%AA%8C%E6%80%A7%EF%BC%89%3CBR%20%2F%3E%23CONFIG_BGSCAN_LEARN%3Dy%3C%2FP%3E%3CP%3E%23%20Opportunistic%20Wireless%20Encryption%20(OWE)%3CBR%20%2F%3E%23%20Experimental%20implementation%20of%20draft-harkins-owe-07.txt%3CBR%20%2F%3E%23CONFIG_OWE%3Dy%3C%2FP%3E%3CP%3E%23%20%E8%AE%BE%E5%A4%87%E9%85%8D%E7%BD%AE%E5%8D%8F%E8%AE%AE%20(DPP)%EF%BC%88%E4%B9%9F%E7%A7%B0%E4%B8%BA%20Wi-Fi%20Easy%20Connect%EF%BC%89%3CBR%20%2F%3Econfig_dpp%3DY%20%3CBR%20%2F%3E%20%23%20DPP%20%E7%89%88%E6%9C%AC%202%20%E6%94%AF%E6%8C%81%20c%20%3CBR%20%2F%3E%20onfig_dpp2%3DY%20%23%20DPP%20%E7%89%88%E6%9C%AC%203%20%E6%94%AF%E6%8C%81%EF%BC%88%E5%AE%9E%E9%AA%8C%E6%80%A7%E4%B8%94%E4%BB%8D%E5%9C%A8%E5%8F%98%E5%8C%96%EF%BC%9B%E4%B8%8D%E5%90%AF%E7%94%A8%20%3CBR%20%2F%3E%20%23%20%E7%94%9F%E4%BA%A7%E7%94%A8%E9%80%94%EF%BC%89%23CONFIG_DPP3%20%3Dy%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%23%20%E6%9C%89%E7%BA%BF%E7%AD%89%E6%95%88%E9%9A%90%E7%A7%81%20(WEP)%20%3CBR%20%2F%3E%20%23%20WEP%20%E6%98%AF%E4%B8%80%E7%A7%8D%E8%BF%87%E6%97%B6%E7%9A%84%E5%8A%A0%E5%AF%86%E6%95%B0%E6%8D%AE%E4%BF%9D%E5%AF%86%E7%AE%97%E6%B3%95%EF%BC%8C%E4%B8%8D%E6%98%AF%20%3CBR%20%2F%3E%20%23%20%E5%AE%89%E5%85%A8%E7%9A%84%E3%80%82%E5%AE%83%E4%B8%8D%E5%BA%94%E8%AF%A5%E5%86%8D%E8%A2%AB%E7%94%A8%E6%9D%A5%E5%81%9A%E4%BB%BB%E4%BD%95%E4%BA%8B%E6%83%85%E3%80%82%E4%BD%BF%E7%94%A8%20WEP%20%E6%89%80%E9%9C%80%E7%9A%84%20%3CBR%20%2F%3E%20%23%20%E5%8A%9F%E8%83%BD%E5%8F%AF%E5%9C%A8%E5%BD%93%E5%89%8D%20wpa_supplicant%20%3CBR%20%2F%3E%20%23%20%E7%89%88%E6%9C%AC%E7%9A%84%E8%BF%99%E4%B8%AA%E5%8F%AF%E9%80%89%E7%BC%96%E8%AF%91%E5%8F%82%E6%95%B0%E4%B8%8B%E6%89%BE%E5%88%B0%E3%80%82%E6%AD%A4%E5%8A%9F%E8%83%BD%E5%B0%86%E5%9C%A8%E6%9C%AA%E6%9D%A5%E7%9A%84%E7%89%88%E6%9C%AC%E4%B8%AD%E5%AE%8C%E5%85%A8%E5%88%A0%E9%99%A4%20%3CBR%20%2F%3E%20%23%E3%80%82%3CBR%20%2F%3E%23CONFIG_WEP%3Dy%3C%2FP%3E%3CP%3E%23%20%E7%A7%BB%E9%99%A4%E6%89%80%E6%9C%89%20TKIP%20%E5%8A%9F%E8%83%BD%20%3CBR%20%2F%3E%20%23%20TKIP%20%E6%98%AF%E4%B8%80%E7%A7%8D%E6%97%A7%E7%9A%84%E5%8A%A0%E5%AF%86%E6%95%B0%E6%8D%AE%E4%BF%9D%E5%AF%86%E7%AE%97%E6%B3%95%EF%BC%8C%E4%B8%8D%E6%98%AF%20%23%20%E5%AE%89%E5%85%A8%E7%9A%84%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%3CBR%20%2F%3E%23%20%E4%BD%BF%E7%94%A8%20WPA%2BWPA2%20%E6%B7%B7%E5%90%88%E6%A8%A1%E5%BC%8F%E7%9A%84%E6%8E%A5%E5%85%A5%E7%82%B9%E6%97%B6%EF%BC%8C%E9%99%A4%E4%BA%86%E4%BD%9C%E4%B8%BA%E7%BB%84%E5%AF%86%E7%A0%81%E7%9A%84%3CBR%20%2F%3E%23%20%E5%90%91%E5%90%8E%E5%85%BC%E5%AE%B9%E6%80%A7%E9%80%89%E9%A1%B9%E5%A4%96%EF%BC%8C%E4%B8%8D%E5%BA%94%E5%86%8D%E4%BD%BF%E7%94%A8%E5%AE%83%E3%80%82%E7%9B%AE%E5%89%8D%EF%BC%8C%E9%BB%98%E8%AE%A4%E7%9A%84%20wpa_supplicant%20%E7%89%88%E6%9C%AC%E9%BB%98%E8%AE%A4%E5%8C%85%E5%90%AB%E5%AF%B9%E6%AD%A4%E7%9A%84%20%3CBR%20%2F%3E%20%23%20%E6%94%AF%E6%8C%81%EF%BC%8C%E4%BD%86%E8%AF%A5%E5%8A%9F%E8%83%BD%E5%B0%86%E6%9D%A5%E5%8F%AF%E8%83%BD%E4%BC%9A%E8%A2%AB%E5%88%A0%E9%99%A4%20%3CBR%20%2F%3E%20%23%E3%80%82%3CBR%20%2F%3E%23CONFIG_NO_TKIP%3Dy%3C%2FP%3E%3CP%3E%23%20%E5%85%B3%E8%81%94%E5%89%8D%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E5%8D%8F%E5%95%86%20(PASN)%20%3CBR%20%2F%3E%20%23%20%E5%9F%BA%E4%BA%8E%20IEEE%20p802.11z%2FD2.6%20%E7%9A%84%E5%AE%9E%E9%AA%8C%E5%AE%9E%E7%8E%B0%E5%92%8C%E5%8D%8F%E8%AE%AE%20%23%20%E8%AE%BE%E8%AE%A1%E4%BB%8D%E5%8F%AF%E8%83%BD%E5%8F%91%E7%94%9F%E5%8F%98%E5%8C%96%E3%80%82%3CBR%20%2F%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%3CBR%20%2F%3E%23%20%E7%94%9F%E4%BA%A7%E4%BD%BF%E7%94%A8%E4%B8%AD%E8%BF%98%E4%B8%8D%E5%BA%94%E5%90%AF%E7%94%A8%E6%AD%A4%E5%8A%9F%E8%83%BD%E3%80%82%3CBR%20%2F%3E%23CONFIG_PASN%3Dy%3C%2FP%3E%3CP%3E%23%20%E7%A6%81%E7%94%A8%E5%AF%B9%E6%97%A0%E7%BA%BF%E7%94%B5%E6%B5%8B%E9%87%8F%EF%BC%88IEEE%20802.11k%EF%BC%89%E5%92%8C%E6%94%AF%E6%8C%81%E7%9A%84%E8%BF%90%E8%A1%8C%3CBR%20%2F%3E%23%20%E7%B1%BB%E6%8C%87%E7%A4%BA%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%E4%B8%8D%E5%BB%BA%E8%AE%AE%E7%A7%BB%E9%99%A4%E8%BF%99%E4%BA%9B%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%8A%A9%3CBR%20%2F%3E%23%20AP%20%E7%AE%A1%E7%90%86%E7%BD%91%E7%BB%9C%E5%92%8C%20STA%20%E8%BD%AC%E5%90%91%E3%80%82%3CBR%20%2F%3E%23CONFIG_NO_RRM%3Dy%3C%2FP%3E%3CP%3E%23%20%E7%A6%81%E7%94%A8%E5%AF%B9%E6%B6%88%E8%B4%B9%E8%80%85%E5%92%8C%E4%BC%81%E4%B8%9A%20Wi-Fi%20%3CBR%20%2F%3E%20%23%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%BC%BA%E5%A4%A7%20AV%20%E6%B5%81%E5%AA%92%E4%BD%93%E6%94%AF%E6%8C%81%EF%BC%9BIEEE%20Std%20802.11-2020%EF%BC%8C4.3.24%EF%BC%9BSCS%E3%80%81MSCS%E3%80%81QoS%20%E7%AE%A1%E7%90%86%3CBR%20%2F%3E%23CONFIG_NO_ROBUST_AV%3Dy%3C%2FP%3E%3CP%3E%23%20%E7%A6%81%E7%94%A8%E5%AF%B9%20WMM%20%E5%87%86%E5%85%A5%E6%8E%A7%E5%88%B6%E7%9A%84%E6%94%AF%E6%8C%81%3CBR%20%2F%3E%23CONFIG_NO_WMM_AC%3Dy%3C%2FP%3E%3CP%3E%23%20Wi-Fi%20%E6%84%9F%E7%9F%A5%E9%9D%9E%E5%90%8C%E6%AD%A5%E6%9C%8D%E5%8A%A1%E5%8F%91%E7%8E%B0%EF%BC%88NAN%20USD%EF%BC%89%3CBR%20%2F%3E%23CONFIG_NAN_USD%3Dy%3C%2FP%3E%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%23%20%E7%A4%BA%E4%BE%8B%20wpa_supplicant%20%E7%BC%96%E8%AF%91%E6%97%B6%E9%85%8D%E7%BD%AE%20%23%23%20%E6%AD%A4%E6%96%87%E4%BB%B6%E5%88%97%E5%87%BA%E4%BA%86%E6%9E%84%E5%BB%BA%20%23%20wpa_supplicant%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E6%97%B6%E4%BD%BF%E7%94%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E9%80%89%E9%A1%B9%E3%80%82%E6%89%80%E6%9C%89%E4%BB%A5%20%23%20%E5%BC%80%E5%A4%B4%E7%9A%84%E8%A1%8C%E9%83%BD%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%E3%80%82%E9%85%8D%E7%BD%AE%23%20%E9%80%89%E9%A1%B9%E8%A1%8C%E5%A6%82%E6%9E%9C%E4%B8%8D%E5%8C%85%E6%8B%AC%E5%9C%A8%E5%86%85%EF%BC%8C%E5%B0%B1%E5%BF%85%E9%A1%BB%E5%85%A8%E9%83%A8%E6%B3%A8%E9%87%8A%E6%8E%89%EF%BC%8C%23%E4%B9%9F%E5%B0%B1%E6%98%AF%E8%AF%B4%EF%BC%8C%E4%BB%85%E4%BB%85%E8%AE%BE%E7%BD%AE%20VARIABLE%3Dn%20%E5%B9%B6%E4%B8%8D%E8%83%BD%E7%A6%81%E7%94%A8%E8%AF%A5%E5%8F%98%E9%87%8F%E3%80%82%E8%AF%A5%E6%96%87%E4%BB%B6%E5%8C%85%E5%90%AB%E5%9C%A8%20Makefile%20%E4%B8%AD%EF%BC%8C%E5%9B%A0%E6%AD%A4%20CFLAGS%20%E5%92%8C%20LIBS%20%E7%AD%89%E5%8F%98%E9%87%8F%E4%B9%9F%E5%8F%AF%E4%BB%A5%23%20%E4%BB%8E%E8%BF%99%E9%87%8C%E4%BF%AE%E6%94%B9%E3%80%82%E5%9C%A8%E5%A4%A7%E5%A4%9A%E6%95%B0%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E8%BF%99%E4%BA%9B%E8%A1%8C%E5%BA%94%E4%BD%BF%E7%94%A8%20%2B%3D%20%E4%BB%A5%E9%81%BF%E5%85%8D%23%E8%A6%86%E7%9B%96%E5%8F%98%E9%87%8F%E4%BB%A5%E5%89%8D%E7%9A%84%E5%80%BC%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E9%9D%9E%E9%BB%98%E8%AE%A4%E4%BD%8D%E7%BD%AE%E5%AE%89%E8%A3%85%E4%BA%86%20OpenSSL%23%20%E6%88%96%20GnuTLS%EF%BC%8C%E8%AF%B7%E5%8F%96%E6%B6%88%E6%B3%A8%E9%87%8A%E4%BB%A5%E4%B8%8B%E4%B8%A4%E8%A1%8C%E5%B9%B6%E4%BF%AE%E6%AD%A3%E8%B7%AF%E5%BE%84%23CFLAGS%20%2B%3D%20-I%2Fusr%2Flocal%2Fopenssl%2Finclude%23LIBS%20%2B%3D%20-L%2Fusr%2Flocal%2Fopenssl%2Flib%23%20%E6%9F%90%E4%BA%9B%20Red%20Hat%20%E7%89%88%E6%9C%AC%E4%BC%BC%E4%B9%8E%E5%8C%85%E5%90%AB%E4%BA%86%20OpenSSL%20%E7%9A%84%20kerberos%20%E5%A4%B4%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E6%98%AF%23%20kerberos%20%E6%96%87%E4%BB%B6%E4%B8%8D%E5%9C%A8%E9%BB%98%E8%AE%A4%E5%8C%85%E5%90%AB%E8%B7%AF%E5%BE%84%E4%B8%AD%E3%80%82%E4%BB%A5%E4%B8%8B%E8%A1%8C%E5%8F%AF%E4%BB%A5%E7%94%A8%E4%BA%8E%20%23%20%E4%BF%AE%E5%A4%8D%E6%AD%A4%E7%B1%BB%E7%B3%BB%E7%BB%9F%E4%B8%8A%E7%9A%84%E7%89%88%E6%9C%AC%E9%97%AE%E9%A2%98%20(krb5.h)%E6%9C%AA%E6%89%BE%E5%88%B0%EF%BC%89.%23CFLAGS%2B%3D%20-I%2Fusr%2Finclude%2Fkerberos%23%20%E9%80%9A%E7%94%A8%20Linux%20%E6%97%A0%E7%BA%BF%E6%89%A9%E5%B1%95%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%23%20%E6%B3%A8%E6%84%8F%EF%BC%9AWEXT%20%E5%9C%A8%E5%BD%93%E5%89%8D%E7%9A%84%20Linux%20%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E4%B8%AD%E5%B7%B2%E8%A2%AB%E5%BC%83%E7%94%A8%EF%BC%8C%E6%B2%A1%E6%9C%89%E6%B7%BB%E5%8A%A0%E6%96%B0%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82CONFIG_DRIVER_WEXT%3Dy%23%20%E4%BD%BF%E7%94%A8%20nl80211%20%E5%86%85%E6%A0%B8%E6%8E%A5%E5%8F%A3%E7%9A%84%20Linux%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3CONFIG_DRIVER_NL80211%3Dy%23%20QCA%20%E4%BE%9B%E5%BA%94%E5%95%86%E5%AF%B9%20nl80211%20%E7%9A%84%E6%89%A9%E5%B1%95CONFIG_DRIVER_NL80211_QCA%3Dy%23%20driver_nl80211.c%E9%9C%80%E8%A6%81%20libnl.%E5%A6%82%E6%9E%9C%E6%98%AF%E8%87%AA%E8%A1%8C%E7%BC%96%E8%AF%91%EF%BC%8C%23%20%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E5%B0%86%20hostapd%20%E6%8C%87%E5%90%91%E6%82%A8%E7%9A%84%20libnl%20%E7%89%88%E6%9C%AC%E3%80%82%2B%3D%20-I%24%3CPATH%20to%3D%22%22%20libnl%3D%22%22%20include%3D%22%22%20files%3D%22%22%3E%20%23LIBS%20%2B%3D%20-L%24%3CPATH%20to%3D%22%22%20libnl%3D%22%22%20library%3D%22%22%20files%3D%22%22%3E%20%23%20%E4%BD%BF%E7%94%A8%20libnl%20v2.0%EF%BC%88%E6%88%96%203.0%EF%BC%89%E5%BA%93%E3%80%82%23CONFIG_LIBNL20%3Dy%23%E4%BD%BF%E7%94%A8%20libnl%203.2%20%E5%BA%93%EF%BC%88%E5%A6%82%E6%9E%9C%E9%80%89%E6%8B%A9%E6%AD%A4%E9%80%89%E9%A1%B9%EF%BC%8C%E5%88%99%E5%BF%BD%E7%95%A5%20CONFIG_LIBNL20%EF%BC%89config_libnl32%3DY%23%20FreeBSD%20net80211%20%E5%B1%82%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%EF%BC%88%E4%BE%8B%E5%A6%82%20Atheros%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%89%23CONFIG_DRIVER_BSD%20%3Dy%20%23CFLAGS%20%2B%3D-i%2Fusr%2FLocal%2Finclude%20%23LIBS%20%2B%3D-L%2FUSR%2FLocal%2Flib%20%23LIBS_p%20%2B%3D-L%2FUSR%2FLocal%2Flib%20%2B%3D-L%2FUSR%2FLocal%2Flib%20%23LIBS_c%20%2B%3D-L%2FUSR%2FLocal%2Flib%20%23Windows%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%20NDIS%20%23CONFIG_DRIVER_NDIS%20%3Dy%20%23CFLAGS%20%2B%3D-i%2Fusr%2Finclude%2Fw32api%2FDDK%20%23LIBS%20%2B%3D-L%2FUSR%2FLocal%2Flib%23%20%E4%BD%BF%E7%94%A8%20mingw%20%E8%BF%9B%E8%A1%8C%E5%8E%9F%E7%94%9F%E6%9E%84%E5%BB%BA%20%23CONFIG_NATIVE_WINDOWS%20%3Dy%23%20%E5%9C%A8%20Linux%20%E4%B8%BB%E6%9C%BA%E4%B8%8A%E7%94%A8%E4%BA%8E%20mingw%20%E7%9B%AE%E6%A0%87%E7%9A%84%E5%85%B6%E4%BB%96%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%E7%9B%AE%E5%BD%95%20%23CFLAGS%20%2B%3D-i%2Fopt%2Fmingw%2Fmingw32%2Finclude%2Fddk%20%23LIBS%20%2B%3D-L%2Fopt%2Fmingw32%2Flib%20%23CC%20%3Dmingw32-gcc%23%20%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8Cdriver_ndis%20%E4%BD%BF%E7%94%A8%20WinpCap%20%E8%BF%9B%E8%A1%8C%E4%BD%8E%E7%BA%A7%E6%93%8D%E4%BD%9C%E3%80%82%E5%8F%AF%E4%BB%A5%23%20%E7%94%A8%E4%BB%A5%E4%B8%8B%E9%80%89%E9%A1%B9%E4%BB%A3%E6%9B%BF%EF%BC%8C%E5%8D%B3%E7%94%A8%20NDISUIO%20%E4%BB%A3%E6%9B%BF%20WinPcap%20%E8%B0%83%E7%94%A8%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E8%BF%99%E9%9C%80%E8%A6%81%E5%9C%A8%E5%90%AF%E5%8A%A8%20%23%20wpa_supplicant.%23%20%E4%B9%8B%E5%89%8D%E7%A6%81%E7%94%A8%20WZC%EF%BC%88net%20stop%20wzcsvc%EF%BC%89%E3%80%82config_use_ndisuio%3DY%23%20%E6%9C%89%E7%BA%BF%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%20Config_driver_Wired%3DY%23%20%E6%94%AF%E6%8C%81%20MacSec%20%E7%9A%84%E9%AB%98%E9%80%9A%20Atheros%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%20%23CONFIG_DRIVER_MACSEC_QCA%20%3Dy%23%20%E9%80%82%E7%94%A8%E4%BA%8E%20Linux%20MacSec%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%20%23CONFIG_DRIVER_MACSEC_LINUX%20%3Dy%23%20%E5%8D%9A%E9%80%9A%20RoboSwitch%20%E7%B3%BB%E5%88%97%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%20%23CONFIG_DRIVER_ROBOSWITCH%20%3Dy%23%20%E4%B8%8D%E6%94%AF%E6%8C%81%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E4%BB%85%E9%99%90%20WPS%20ER%EF%BC%89%23CONFIG_DRIVER_NONE%20%3Dy%23%20Solaris%20%E5%BA%93%20%23LIBS%20%2B%3D-lsocket-ldpi-lnsl%20%23LIBS_c%20%2B%3D-lsocket%23%20%E5%90%AF%E7%94%A8%20IEEE%20802.1X%20%E8%AF%B7%E6%B1%82%E6%96%B9%EF%BC%88%E5%A6%82%E6%9E%9C%E5%8C%85%E5%90%AB%E4%BB%BB%E4%BD%95%20EAP%20%E6%96%B9%E6%B3%95%E6%88%96%20%23%20MACsec%EF%BC%8C%E5%88%99%E8%87%AA%E5%8A%A8%E5%8C%85%E6%8B%AC%E5%9C%A8%E5%86%85%EF%BC%89config_ieee8021x_eapol%3DY%23%20eap-md5config_eap_md5%3Dy%23%20eap-mdv2config_eap_mschapv2config_eap_mschapv2%3DY%23%20eap-tlsconfig_eap_tls%3Dy%23%20%E5%90%AF%E7%94%A8%20EAP-TLSv1.3%E9%BB%98%E8%AE%A4%E6%94%AF%E6%8C%81%EF%BC%88%E5%BD%93%E5%89%8D%E5%B7%B2%E7%A6%81%E7%94%A8%EF%BC%8C%E9%99%A4%E9%9D%9E%E5%9C%A8%E7%BD%91%E7%BB%9C%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%98%8E%E7%A1%AE%23%20%E5%90%AF%E7%94%A8%EF%BC%89%23CONFIG_EAP_TLSV1_3%3Dy%23%20EAL-PEAPCONFIG_EAP_PEAP%3Dy%23%20EAP-TTLSCONFIG_EAP_TTLS%3Dy%23%20EAP-FASTCONFIG_EAP_FAST%3Dy%23%20EAP-TEAP%23%20%E6%B3%A8%E6%84%8F%EF%BC%9A%E5%BD%93%E5%89%8D%E7%9A%84%20EAP-TEAP%20%E5%AE%9E%E7%8E%B0%E6%98%AF%E8%AF%95%E9%AA%8C%E6%80%A7%E7%9A%84%EF%BC%8C%E4%B8%8D%E5%BA%94%23%20%E5%9C%A8%E7%94%9F%E4%BA%A7%E4%BD%BF%E7%94%A8%E4%B8%AD%E5%90%AF%E7%94%A8%E3%80%82%E5%AE%9A%E4%B9%89%20EAP-TEAP%20%E7%9A%84%20IETF%20RFC%207170%20%E6%9C%89%E8%AE%B8%E5%A4%9A%E7%9B%B8%E4%BA%92%E5%86%B2%E7%AA%81%E7%9A%84%E5%A3%B0%E6%98%8E%E5%92%8C%E7%BC%BA%E5%A4%B1%E7%9A%84%E7%BB%86%E8%8A%82%EF%BC%8C%E8%80%8C%E4%B8%94%E5%AE%9E%E6%96%BD%E8%BF%87%E7%A8%8B%E4%B8%AD%E4%B9%9F%E6%9C%89%20%23%20%E4%BE%9B%E5%BA%94%E5%95%86%E7%89%B9%E5%AE%9A%E7%9A%84%E5%8F%98%E9%80%9A%E6%96%B9%E6%B3%95%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%8F%AF%E8%83%BD%E6%97%A0%E6%B3%95%E4%B8%8E%20%23%20%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E5%AE%9E%E6%96%BD%E8%BF%87%E7%A8%8B%E4%BA%92%E6%93%8D%E4%BD%9C%E3%80%82%E5%9C%A8%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%E5%BE%97%E5%88%B0%E8%A7%A3%E5%86%B3%E4%B9%8B%E5%89%8D%EF%BC%8C%E4%B8%8D%E5%BA%94%E5%B0%86%E5%85%B6%E7%94%A8%E4%BA%8E%20%23%20%E5%AE%9E%E9%AA%8C%E5%92%8C%E4%BA%92%E6%93%8D%E4%BD%9C%E6%80%A7%E6%B5%8B%E8%AF%95%E4%BB%A5%E5%A4%96%E7%9A%84%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E7%94%A8%E9%80%94%E3%80%82%23CONFIG_EAP_TEAP%20%3Dy%23EAP-GTCCONFIG_EAP_GTC%3Dy%23%20EAP-OTPCONFIG_EAP_OTP%3Dy%23%20EAP-SIM%EF%BC%88%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20EAP-SIM%EF%BC%8C%E5%88%99%E5%90%AF%E7%94%A8%20CONFIG_PCSC%EF%BC%89%23CONFIG_EAP_SIM%3Dy%23%20%E4%B8%BA%20EAP-SIM%20%E5%90%AF%E7%94%A8%20SIM%20%E6%A8%A1%E6%8B%9F%E5%99%A8%20(Milenage)%23CONFIG_SIM_SIMULATOR%3Dy%23%20EAP-PSK%EF%BC%88%E8%AF%95%E9%AA%8C%E6%80%A7%EF%BC%9BEAP-PAXCONFIG_EAP_PAX%3Dy%23LEAPCONFIG_EAP_LEAP%3Dy%23EAP-AKA%EF%BC%88%E5%90%AF%E7%94%A8%20CONFIG_PCSC%E3%80%81%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20EAP-AKA%EF%BC%8C%E5%88%99%E5%90%AF%E7%94%A8%20CONFIG_PCSC%EF%BC%89%23CONFIG_EAP_AKA%3Dy%23%20EAP-AKA'%EF%BC%88%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20EAP-AKA%EF%BC%8C%E5%88%99%E5%90%AF%E7%94%A8%20CONFIG_PCSC%EF%BC%89%E3%80%82%23%E8%BF%99%E4%B9%9F%E9%9C%80%E8%A6%81%E5%90%AF%E7%94%A8%20CONFIG_EAP_AKA%E3%80%82%E4%B8%BA%20EAP-AKA%20%E5%90%AF%E7%94%A8%20USIM%20%E6%A8%A1%E6%8B%9F%E5%99%A8%EF%BC%88Milenage%EF%BC%89%23CONFIG_USIM_SIMULATOR%20%3Dy%23%20eap-sakeconfig_eap_sake%3Dy%23%20eap-gpskconfig_eap_gpsk%3DY%23%20%E5%9C%A8%20EAP-gpskconfig_eap_EAP_SA256%3DY%23%20EAP-TNC%20%E5%92%8C%E7%9B%B8%E5%85%B3%E7%9A%84%E5%8F%AF%E4%BF%A1%E7%BD%91%E7%BB%9C%E8%BF%9E%E6%8E%A5%E6%94%AF%E6%8C%81%EF%BC%88%E5%AE%9E%E9%AA%8C%E6%80%A7%EF%BC%89config_EAPCONFIG_EAP_SA256%3DY%23%20EAP-TNC%20%E5%92%8C%E7%9B%B8%E5%85%B3%E7%9A%84%E5%8F%AF%E4%BF%A1%E7%BD%91%E7%BB%9C%E8%BF%9E%E6%8E%A5%E6%94%AF%E6%8C%81%EF%BC%88%E5%AE%9E%E9%AA%8C%E6%80%A7%EF%BC%89config_EAP_EAPCONFIG_SA256%3DY%23%20_tnc%3DY%23%20Wi-Fi%20%E4%BF%9D%E6%8A%A4%E8%AE%BE%E7%BD%AE%20(WPS)%20config_wps%3DY%23%20%E5%90%AF%E7%94%A8%20WPS%20%E5%A4%96%E9%83%A8%E6%B3%A8%E5%86%8C%E5%99%A8%E5%8A%9F%E8%83%BD%20%23CONFIG_WPS_ER%20%3Dy%23%20%E5%9C%A8%E5%85%85%E5%BD%93%20WPS%23%20%E6%B3%A8%E5%86%8C%E5%95%86%E6%97%B6%E9%BB%98%E8%AE%A4%E7%A6%81%E7%94%A8%E5%BC%80%E6%94%BE%E7%BD%91%E7%BB%9C%E7%9A%84%E5%87%AD%E6%8D%AE%E3%80%82SHA256%23CONFIG_WPS_REG_DISABLE_OPEN%20%3Dy%23%E4%BD%BF%E7%94%A8%20NFC%20%E9%85%8D%E7%BD%AE%E6%96%B9%E6%B3%95%E5%90%AF%E7%94%A8%20WPS%20%E6%94%AF%E6%8C%81%23CONFIG_WPS_NFC%3Dy%23%20EAP-IKEv2CONFIG_EAP_IKEV2%3Dy%23%20EAP-EKE%23CONFIG_EAP_EKE%3Dy%23%20MACsecCONFIG_MACSEC%3Dy%23%20PKCS%2312%20(PFX)%20%E6%94%AF%E6%8C%81%EF%BC%88%E7%94%A8%E4%BA%8E%E4%BB%8E%23%20%E8%AF%BB%E5%8F%96%E7%A7%81%E9%92%A5%E5%92%8C%E8%AF%81%E4%B9%A6%E6%96%87%E4%BB%B6%EF%BC%8C%E8%AF%A5%E6%96%87%E4%BB%B6%E7%9A%84%E6%89%A9%E5%B1%95%E5%90%8D%E9%80%9A%E5%B8%B8%E4%B8%BA%20.p12%E6%88%96%20.pfx)CONFIG_PKCS12%3Dy%23%E6%94%AF%E6%8C%81%E6%99%BA%E8%83%BD%E5%8D%A1%EF%BC%88%E5%8D%B3%E6%99%BA%E8%83%BD%E5%8D%A1%E4%B8%8A%E7%9A%84%E7%A7%81%E9%92%A5%EF%BC%89%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%8C%E4%BD%BF%E7%94%A8%20openssl%23%20engine.config_smartcard%3DY%23%20%E6%99%BA%E8%83%BD%E5%8D%A1%EF%BC%88USIM%E3%80%81GSM%20SIM%EF%BC%89%E7%9A%84%20PC%2FSC%20%E6%8E%A5%E5%8F%A3%20%23%20%E5%A6%82%E6%9E%9C%E5%8C%85%E5%90%AB%20EAP-SIM%20%E6%88%96%20EAP-AKA%20%E5%88%99%E5%90%AF%E7%94%A8%E6%AD%A4%E5%8A%9F%E8%83%BD%20%23CONFIG_PCSC%20%3Dy%23%20%E6%94%AF%E6%8C%81%20HT%20%E8%A6%86%E7%9B%96%EF%BC%88%E7%A6%81%E7%94%A8%20HT%2FHT40%E3%80%81%E5%B1%8F%E8%94%BD%20MCS%20%E9%80%9F%E7%8E%87%E7%AD%89%EF%BC%89%23CONFIG_HT_OVERRIDES%20%3Dy%23%20%E6%94%AF%E6%8C%81%20VHT%20%E8%A6%86%E7%9B%96%EF%BC%88%E7%A6%81%E7%94%A8%20VHT%E3%80%81%E5%B1%8F%E8%94%BD%20MCS%20%E9%80%9F%E7%8E%87%E7%AD%89%EF%BC%89%23CONFIG_VHT_OVERRIDES%20%3Dy%23%20%E6%94%AF%E6%8C%81%20HE%20%E8%A6%86%E7%9B%96%20%23CONFIG_HE_OVERRIDES%20%3Dy%23%20%E5%BC%80%E5%8F%91%E6%B5%8B%E8%AF%95%20%23CONFIG_EAPOL_TEST%20%3Dy%23%20%E6%94%AF%E6%8C%81%20IPv6config_IPv6%3DY%23%20%E4%B8%BA%E5%A4%96%E9%83%A8%E7%A8%8B%E5%BA%8F%E9%80%89%E6%8B%A9%E6%8E%A7%E5%88%B6%E6%8E%A5%E5%8F%A3%E5%90%8E%E7%AB%AF%EF%BC%8C%E4%BE%8B%E5%A6%82%20wpa_cli%3A%20%23%20unix%20%3D%20UNIX%20%E5%9F%9F%E5%A5%97%E6%8E%A5%E5%AD%97%EF%BC%88Linux%2F*BSD%20%E7%9A%84%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%89%23%20udp%20%3D%20%E4%BD%BF%E7%94%A8%E6%9C%AC%E5%9C%B0%E4%B8%BB%E6%9C%BA%20(127.0.0.1)%20%E7%9A%84%20UDP%20IPv6%20%E5%A5%97%E6%8E%A5%E5%AD%97%20(%3A%3A%201)%20%23%20named_bsd%20pipe%20%3D%20Windows%20%E5%91%BD%E5%90%8D%E7%AE%A1%E9%81%93%EF%BC%88Windows%20%E9%BB%98%E8%AE%A4%EF%BC%89%23%20udp-remote%20%3D%20%E5%85%B7%E6%9C%89%E8%BF%9C%E7%A8%8B%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%E7%9A%84%20UDP%20%E5%A5%97%E6%8E%A5%E5%AD%97%EF%BC%88%E4%BB%85%E7%94%A8%E4%BA%8E%E6%B5%8B%E8%AF%95%E7%B3%BB%E7%BB%9F%2F%E7%9B%AE%E7%9A%84%EF%BC%89%23%20udp6-remote%20%3D%20%E5%85%B7%E6%9C%89%E8%BF%9C%E7%A8%8B%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%E7%9A%84%20UDP%20IPv6%20%E5%A5%97%E6%8E%A5%E5%AD%97%EF%BC%88%E4%BB%85%E7%94%A8%E4%BA%8E%E6%B5%8B%E8%AF%95%E7%9B%AE%E7%9A%84%EF%BC%89%23%20y%20%3D%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%88%E5%90%91%E5%90%8E%E5%85%BC%E5%AE%B9%EF%BC%89%23%20%E5%A6%82%E6%9E%9C%E6%B3%A8%E9%87%8A%E6%8E%89%E6%AD%A4%E9%80%89%E9%A1%B9%EF%BC%8C%E5%88%99%E6%8E%A7%E5%88%B6%E6%8E%A5%E5%8F%A3%E4%B8%8D%E5%8C%85%E5%90%AB%E5%9C%A8%20%23%20%E7%89%88%E6%9C%AC.config_ctrl_iface%3DY%23%20%E5%9C%A8%20wpa_cli%20%E4%B8%AD%E5%8C%85%E5%90%AB%E5%AF%B9%20GNU%20Readline%20%E5%92%8C%E5%8E%86%E5%8F%B2%E5%BA%93%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%23%E5%9C%A8%E6%9E%84%E5%BB%BA%20wpa_cli%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E4%BB%A5%E4%BE%9B%E5%88%86%E5%8F%91%E6%97%B6%EF%BC%8C%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E8%BF%99%E4%BA%9B%20%23%20%E5%BA%93%E6%98%AF%E6%A0%B9%E6%8D%AE%20GPL%20%E8%AE%B8%E5%8F%AF%E7%9A%84%EF%BC%8C%E5%9B%A0%E6%AD%A4%EF%BC%8CBSD%20%E8%AE%B8%E5%8F%AF%E8%AF%81%E5%8F%AF%E8%83%BD%E4%B8%8D%E9%80%82%E7%94%A8%E4%BA%8E%20%23%20%E7%94%9F%E6%88%90%E7%9A%84%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%23CONFIG_READLINE%20%3Dy%23%E5%9C%A8%20wpa_cli%20%E4%B8%AD%E5%8A%A0%E5%85%A5%E5%86%85%E9%83%A8%E8%A1%8C%E7%BC%96%E8%BE%91%E6%A8%A1%E5%BC%8F%E3%80%82%E5%AE%83%E5%8F%AF%E6%9B%BF%E4%BB%A3%20GNU%20Readline%23%EF%BC%8C%E6%8F%90%E4%BE%9B%E6%9C%89%E9%99%90%E7%9A%84%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%BC%96%E8%BE%91%E5%92%8C%E5%8E%86%E5%8F%B2%E8%AE%B0%E5%BD%95%E6%94%AF%E6%8C%81%E3%80%82%E5%88%A0%E9%99%A4%E5%90%91%20stdout%20%E8%BE%93%E5%87%BA%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%E7%9A%84%E8%B0%83%E8%AF%95%E4%BB%A3%E7%A0%81%E3%80%82%E5%A6%82%E6%9E%9C%E4%B8%8D%E9%9C%80%E8%A6%81%E8%B0%83%E8%AF%95%E4%BB%A3%E7%A0%81%EF%BC%8C%E8%BF%99%E5%8F%AF%E4%BB%A5%E7%94%A8%E6%9D%A5%E5%A4%A7%E5%A4%A7%E7%BC%A9%E5%B0%8F%20wpa_supplicant%20%E7%9A%84%E5%A4%A7%E5%B0%8F%23%E3%80%82%E5%A4%A7%E5%B0%8F%E5%8F%AF%E5%87%8F%E5%B0%91%E7%BA%A6%2035%25%23%EF%BC%88%E4%BE%8B%E5%A6%82%2090%20kB%EF%BC%89%E3%80%82%23CONFIG_NO_STDOUT_DEBUG%3Dy%23%E5%8F%96%E6%B6%88%E5%AF%B9%20WPA%20%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%8C%E4%BE%8B%E5%A6%82%E5%8F%AA%E6%94%AF%E6%8C%81%E6%9C%89%E7%BA%BF%20IEEE%20802.1X%20supplicant%EF%BC%8C%E4%BB%A5%E8%8A%82%E7%9C%81%20%23%2035-50%20kB%20%E7%9A%84%E4%BB%A3%E7%A0%81%E5%A4%A7%E5%B0%8F%E3%80%82%E7%A7%BB%E9%99%A4%20IEEE%20802.11i%2FWPA%20%E4%B8%AA%E4%BA%BA%E7%89%88ASCII%20%E5%8F%A3%E4%BB%A4%E6%94%AF%E6%8C%81%23%20%E8%AF%A5%E9%80%89%E9%A1%B9%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%8F%96%E6%B6%88%E5%B0%86%20ASCII%20%E5%8F%A3%E4%BB%A4%E8%BD%AC%E6%8D%A2%E4%B8%BA%20PSK%20%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%8C%E4%BB%8E%E8%80%8C%E5%87%8F%E5%B0%91%E4%BB%A3%E7%A0%81%E9%87%8F%E3%80%82%E5%A6%82%E6%9E%9C%E5%88%A0%E9%99%A4%E4%BA%86%E8%BF%99%E4%B8%80%E5%8A%9F%E8%83%BD%EF%BC%8C%23%20PSK%20%E5%8F%AA%E8%83%BD%E9%85%8D%E7%BD%AE%E4%B8%BA%2064%20%E5%85%AB%E4%BD%8D%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E5%AD%97%E7%AC%A6%E4%B8%B2%EF%BC%88%E4%BE%8B%E5%A6%82%E6%9D%A5%E8%87%AA%23%20wpa_passphrase%EF%BC%89%E3%80%82%E8%BF%99%E6%A0%B7%E5%8F%AF%E8%8A%82%E7%9C%81%E7%BA%A6%200.5%20kB%20%E7%9A%84%E4%BB%A3%E7%A0%81%E5%A4%A7%E5%B0%8F%E3%80%82%23CONFIG_NO_WPA_PASSPHRASE%3Dy%23%E7%AD%89%E6%95%88%E5%90%8C%E6%AD%A5%E9%AA%8C%E8%AF%81%20(SAE)%EF%BC%8CWPA3-PersonalCONFIG_SAE%3DyCONFIG_IEEE80211W%3DyCONFIG_IEEE80211N%3DyCONFIG_WPA3%3Dy%23%20SAE%20%E5%85%AC%E9%92%A5%EF%BC%8CWPA3-Personal%23CONFIG_SAE_PK%3Dy%23%20%E7%A6%81%E7%94%A8%E6%89%AB%E6%8F%8F%E7%BB%93%E6%9E%9C%E5%A4%84%E7%90%86%20(ap_scan%3D1)%EF%BC%8C%E4%BB%A5%E8%8A%82%E7%9C%81%E7%BA%A6%201%20kB%20%E7%9A%84%E4%BB%A3%E7%A0%81%E5%A4%A7%E5%B0%8F%E3%80%82%E5%A6%82%E6%9E%9C%E4%BB%8E%E6%9C%AA%E5%90%AF%E7%94%A8%20ap_scan%3D1%20%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%AD%A4%E5%8A%9F%E8%83%BD%E3%80%82%20%23CONFIG_NO_SCAN_PROCESSING%3Dy%23%E9%80%89%E6%8B%A9%E9%85%8D%E7%BD%AE%E5%90%8E%E7%AB%AF%EF%BC%9A%23%20%E6%96%87%E4%BB%B6%20%3D%20%E6%96%87%E6%9C%AC%E6%96%87%E4%BB%B6%EF%BC%88%E5%A6%82%20wpa_supplicant.conf%EF%BC%9B%E6%B3%A8%E6%84%8F%EF%BC%9A%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%23%20%E8%B7%AF%E5%BE%84%E6%98%AF%E5%9C%A8%E5%91%BD%E4%BB%A4%E8%A1%8C%E4%B8%AD%E7%BB%99%E5%87%BA%E7%9A%84%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E5%9C%A8%E8%BF%99%E9%87%8C%EF%BC%9B%E8%AF%A5%E9%80%89%E9%A1%B9%E5%8F%AA%E6%98%AF%E7%94%A8%E6%9D%A5%23%20%E9%80%89%E6%8B%A9%E5%85%81%E8%AE%B8%E4%BD%BF%E7%94%A8%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E7%9A%84%E5%90%8E%E7%AB%AF%EF%BC%89%23%20winreg%20%3D%20Windows%20%E6%B3%A8%E5%86%8C%E8%A1%A8%EF%BC%88%E7%A4%BA%E4%BE%8B%E5%8F%82%E8%A7%81%20win_example.reg%EF%BC%89CONFIG_BACKEND%3Dfile%23%20%E7%A7%BB%E9%99%A4%E9%85%8D%E7%BD%AE%E5%86%99%E5%85%A5%E5%8A%9F%E8%83%BD%EF%BC%88%E5%8D%B3%E5%85%81%E8%AE%B8%E6%A0%B9%E6%8D%AE%E8%BF%90%E8%A1%8C%E6%97%B6%E7%9A%84%E9%85%8D%E7%BD%AE%E6%9B%B4%E6%94%B9%E6%9B%B4%E6%96%B0%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%EF%BC%89%E3%80%82%E8%BF%90%E8%A1%8C%E6%97%B6%23%E9%85%8D%E7%BD%AE%E4%BB%8D%E5%8F%AF%E6%9B%B4%E6%94%B9%EF%BC%8C%E5%8F%AA%E6%98%AF%E6%9B%B4%E6%94%B9%E4%B8%8D%E4%BC%9A%23%E6%8C%81%E7%BB%AD%E9%87%8D%E5%90%AF%E3%80%82%23CONFIG_NO_CONFIG_WRITE%3Dy%23%20%E7%A7%BB%E9%99%A4%E5%AF%B9%E9%85%8D%E7%BD%AE%20blobs%20%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%8C%E5%8F%AF%E5%B0%86%E4%BB%A3%E7%A0%81%E5%A4%A7%E5%B0%8F%E5%87%8F%E5%B0%91%E7%BA%A6%203.5%20kB%E3%80%82%23CONFIG_NO_CONFIG_BLOBS%3Dy%23%20%E9%80%89%E6%8B%A9%E7%A8%8B%E5%BA%8F%E5%85%A5%E5%8F%A3%E7%82%B9%E5%AE%9E%E7%8E%B0%EF%BC%9Amain%20%3D%20%E7%B1%BB%E4%BC%BC%20UNIX%2FPOSIX%20%E7%9A%84%20main()%20%E5%87%BD%E6%95%B0%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%23%20main_winsvc%20%3D%20Windows%20%E6%9C%8D%E5%8A%A1%EF%BC%88%E4%BB%8E%E6%B3%A8%E5%86%8C%E8%A1%A8%E8%AF%BB%E5%8F%96%E5%8F%82%E6%95%B0%EF%BC%89%23%20main_none%20%3D%20%E9%9D%9E%E5%B8%B8%E5%9F%BA%E6%9C%AC%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%88%E4%BB%85%E4%BE%9B%E5%BC%80%E5%8F%91%E4%BD%BF%E7%94%A8%EF%BC%89%23CONFIG_MAIN%3Dmain%23%E9%80%89%E6%8B%A9%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E5%92%8C%20C%20%E5%BA%93%E7%89%B9%E5%AE%9A%E5%87%BD%E6%95%B0%E7%9A%84%E5%B0%81%E8%A3%85%E5%99%A8%23%20unix%20%3D%20%E7%B1%BB%E4%BC%BC%20UNIX%2FPOSIX%20%E7%9A%84%E7%B3%BB%E7%BB%9F%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%23%20win32%E9%80%89%E6%8B%A9%E4%BA%8B%E4%BB%B6%E5%BE%AA%E7%8E%AF%E5%AE%9E%E7%8E%B0%23%20eloop%20%3D%20select()%20%E5%BE%AA%E7%8E%AF%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%23%20eloop_win%20%3D%20Windows%20%E4%BA%8B%E4%BB%B6%E5%92%8C%20WaitForMultipleObject()%20%E5%BE%AA%E7%8E%AF%23CONFIG_ELOOP%3Deloop%23%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20poll%20%E4%BB%A3%E6%9B%BF%20select%EF%BC%9F%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E4%BD%BF%E7%94%A8%20%22%E9%80%89%E6%8B%A9%22%E3%80%82%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20epoll%20%E8%80%8C%E4%B8%8D%E6%98%AF%20select%20%E5%90%97%EF%BC%9F%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E4%BD%BF%E7%94%A8%20%22%E9%80%89%E6%8B%A9%22%E3%80%82%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20kqueue%20%E8%80%8C%E4%B8%8D%E6%98%AF%20select%20%E5%90%97%EF%BC%9F%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E4%BD%BF%E7%94%A8%20%22%E9%80%89%E6%8B%A9%22%E3%80%82%E9%80%89%E6%8B%A9%E7%AC%AC%202%20%E5%B1%82%E6%95%B0%E6%8D%AE%E5%8C%85%E5%AE%9E%E7%8E%B0%23%20linux%20%3D%20Linux%20%E6%95%B0%E6%8D%AE%E5%8C%85%E5%A5%97%E6%8E%A5%E5%AD%97%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%23%20pcap%20%3D%20libpcap%2Flibdnet%2Fwinpcap%23%20freebsd%20%3D%20FreeBSD%20libpcap%23%20winpcap%20%3D%20%E5%B8%A6%E6%8E%A5%E6%94%B6%E7%BA%BF%E7%A8%8B%E7%9A%84%20Winpcap%20%23%20nedis%20%3D%20Windows%20NDISUIO%EF%BC%88%E6%B3%A8%E6%84%8F%EF%BC%9A%E9%9C%80%E8%A6%81%20config_use_ndisuio%3DY%EF%BC%89%23%20%E6%97%A0%20%3D%20%E7%A9%BA%E6%A8%A1%E6%9D%BF%20%23CONFIG_L2_PACKET%20%3Dlinux%23%20%E7%A6%81%E7%94%A8%E9%80%82%E7%94%A8%E4%BA%8E%E7%AB%99%E9%97%B4%E7%9A%84%20Linux%20%E6%95%B0%E6%8D%AE%E5%8C%85%E5%A5%97%E6%8E%A5%E5%AD%97%E5%8F%98%E9%80%9A%E6%96%B9%E6%B3%95%E5%9C%A8%20EAPOL%20%E5%B8%A7%E7%9A%84%E6%A1%A5%E6%8E%A5%E4%B8%AD%20face%23%E3%80%82%E5%8F%AA%E6%9C%89%E5%BD%93%E5%86%85%E6%A0%B8%23%20%E5%B7%B2%E7%9F%A5%E5%9C%A8%E4%BD%BF%E7%94%A8%23%20%E7%BD%91%E6%A1%A5%E6%8E%A5%E5%8F%A3%EF%BC%88%E6%8F%90%E4%BA%A4%20%22bridge%3A%20respect%20RFC2863%20operational%20state%22%EF%BC%89%E6%97%B6%E4%B8%8D%E5%AD%98%E5%9C%A8%E6%95%B0%E6%8D%AE%E5%8C%85%E5%A5%97%E6%8E%A5%E5%AD%97%E8%A1%8C%E4%B8%BA%E7%9A%84%E5%9B%9E%E5%BD%92%E9%97%AE%E9%A2%98%E6%97%B6%EF%BC%8C%E6%89%8D%E5%BA%94%E5%8F%96%E6%B6%88%E6%B3%A8%E9%87%8A').%23CONFIG_NO_LINUX_PACKET_SOCKET_WAR%3Dy%23%E3%80%82%E6%94%AF%E6%8C%81%E6%93%8D%E4%BD%9C%E9%80%9A%E9%81%93%E9%AA%8C%E8%AF%81%23CONFIG_OCV%3Dy%23%20%E9%80%89%E6%8B%A9%20TLS%20%E5%AE%9E%E7%8E%B0%23%20openssl%20%3D%20OpenSSL%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%23%20gnutls%20%3D%20GnuTLS%23%20internal%20%3D%20%E5%86%85%E9%83%A8%20TLSv1%20%E5%AE%9E%E7%8E%B0%EF%BC%88%E5%AE%9E%E9%AA%8C%EF%BC%89%23%20linux%20%3D%20Linux%20%E5%86%85%E6%A0%B8%20AF_ALG%20%E5%92%8C%E5%86%85%E9%83%A8%20TLSv1%20%E5%AE%9E%E7%8E%B0%EF%BC%88%E5%AE%9E%E9%AA%8C%EF%BC%89%23%20none%20%3D%20%E7%A9%BA%E6%A8%A1%E6%9D%BFCONFIG_TLS%3Dopenssl%23%20%E5%9F%BA%E4%BA%8E%20TLS%20%E7%9A%84%20EAP%20%E6%96%B9%E6%B3%95%E8%87%B3%E5%B0%91%E9%9C%80%E8%A6%81%20TLS%20v1.0%E3%80%82%E5%90%AF%E7%94%A8%E8%BE%83%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20TLS%20(v1.1)%23%EF%BC%8C%E5%8F%AF%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%9D%97%E5%AF%86%E7%A0%81%23%20%E6%97%B6%E8%8E%B7%E5%BE%97%E6%9B%B4%E5%BC%BA%E7%9A%84%E4%BF%A1%E6%81%AF%E7%BB%93%E6%9E%84%E3%80%82%E9%9C%80%E8%A6%81%E6%B3%A8%E6%84%8F%E7%9A%84%E6%98%AF%EF%BC%8C%E6%9F%90%E4%BA%9B%E7%8E%B0%E6%9C%89%E7%9A%84%E5%9F%BA%E4%BA%8E%20TLS%20v1.0%20%E7%9A%84%E5%AE%9E%E7%8E%B0%E5%8F%AF%E8%83%BD%E4%B8%8E%20TLS%20v1.1%20%E6%B6%88%E6%81%AF%E4%B8%8D%E5%85%BC%E5%AE%B9%EF%BC%88ClientHello%20%E4%BC%9A%E5%9C%A8%E5%8D%8F%E5%95%86%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E4%B9%8B%E5%89%8D%E5%8F%91%E9%80%81%EF%BC%89%23CONFIG_TLSV11%3Dy%23%20%E5%9F%BA%E4%BA%8E%20TLS%20%E7%9A%84%20EAP%20%E6%96%B9%E6%B3%95%E8%87%B3%E5%B0%91%E9%9C%80%E8%A6%81%20TLS%20v1.0%E3%80%82%E5%8F%AF%E4%BB%A5%E5%90%AF%E7%94%A8%E8%BE%83%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20TLS%20(v1.2)%23%EF%BC%8C%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%9B%B4%E5%BC%BA%E7%9A%84%E5%8A%A0%E5%AF%86%E7%AE%97%E6%B3%95%E3%80%82%E5%BA%94%E5%BD%93%E6%B3%A8%E6%84%8F%E7%9A%84%E6%98%AF%EF%BC%8C%E6%9F%90%E4%BA%9B%E5%9F%BA%E4%BA%8E%20TLS%20v1.0%20%E7%9A%84%E7%8E%B0%E6%9C%89%E5%AE%9E%E7%8E%B0%E5%8F%AF%E8%83%BD%E4%B8%8E%20TLS%20v1.2%20%E6%B6%88%E6%81%AF%E4%B8%8D%E5%85%BC%E5%AE%B9%EF%BC%88%E5%9C%A8%E5%8D%8F%E5%95%86%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E4%B9%8B%E5%89%8D%E4%BC%9A%E5%8F%91%E9%80%81%20ClientHello%EF%BC%89%23CONFIG_TLSV12%3Dy%23%20%E5%A6%82%E6%9E%9C%E7%94%A8%E6%88%B7%E6%9C%AA%E6%8C%87%E5%AE%9A%E5%AF%86%E7%A0%81%EF%BC%8C%E8%AF%B7%E9%80%89%E6%8B%A9%20OpenSSL%20%E9%BB%98%E8%AE%A4%E4%BD%BF%E7%94%A8%E7%9A%84%E5%AF%86%E7%A0%81%E3%80%82%23CONFIG_TLS_DEFAULT_CIPHERS%3D%22DEFAULT%3A!EXP%3A!LOW%22%23%20%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20CONFIG_TLS%3Dinternal%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E4%B8%BA%20LibTomMath%23%E6%B7%BB%E5%8A%A0%E9%A2%9D%E5%A4%96%E7%9A%84%E5%BA%93%E5%92%8C%E5%8C%85%E5%90%AB%E8%B7%AF%E5%BE%84%E3%80%82%E6%88%96%E8%80%85%EF%BC%8C%E4%B9%9F%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E9%9B%86%E6%88%90%E7%9A%84%E6%9C%80%E5%B0%8F%E7%89%88%E6%9C%AC%23%20LibTomMath%E3%80%82%E6%9C%89%E5%85%B3%E6%AD%A4%E9%80%89%E9%A1%B9%E7%9A%84%E4%BC%98%E7%BC%BA%E7%82%B9%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20libtommath.c%20%E7%9A%84%E5%BC%80%E5%A4%B4%E9%83%A8%E5%88%86%E3%80%82%23CONFIG_INTERNAL_LIBTOMMATH%3Dy%23ifndefCONFIG_INTERNAL_LIBTOMMATH%20%23LTM_PATH%20%3D%2Fusr%2Fsrc%2Flibtommath-0.39%20%23CFLAGS%20%2B%3D-I%24%20(LTM_PATH)%20%23LIBS%20%2B%3D-L%24%20(LTM_PATH)%20%23LIBS_p%20%2B%3D-L%24%20(LTM_PATH)%20%23endif%20%23%20%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%86%85%E9%83%A8%20libtommath%20%23%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E5%8C%85%E5%90%AB%20exptmod%20%E7%9A%84%E6%9B%B4%E5%BF%AB%E4%BE%8B%E7%A8%8B%EF%BC%8Csq%20r%20%E5%92%8C%20div%20to%20%23%20%E5%8F%AF%E5%A4%A7%E5%A4%A7%E5%8A%A0%E5%BF%AB%20DH%20%E5%92%8C%20RSA%20%E7%9A%84%E8%AE%A1%E7%AE%97%E9%80%9F%E5%BA%A6%20%23CONFIG_INTERNAL_LIBTOMMATH_FAST%20%3Dy%23%20%E5%B0%86%E9%80%9A%E8%BF%87%20WMI%20%E8%BF%9B%E8%A1%8C%E7%9A%84%20NDIS%20%E4%BA%8B%E4%BB%B6%E5%A4%84%E7%90%86%E5%8C%85%E5%90%AB%E5%88%B0%20wpa_supplicant%2Fwpasvc%20%E4%B8%AD%E3%80%82%23%E8%BF%99%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%20Windows%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%8D%B3%E4%BD%BF%E4%BD%BF%E7%94%A8%20MinGW%20%E8%BF%9B%E8%A1%8C%E6%9E%84%E5%BB%BA%EF%BC%8C%E4%B9%9F%E9%9C%80%E8%A6%81%E5%B9%B3%E5%8F%B0%E8%BD%AF%E4%BB%B6%E5%BC%80%E5%8F%91%E5%B7%A5%E5%85%B7%E5%8C%85%E4%B8%AD%E7%9A%84%20WMI%20%E7%9B%B8%E5%85%B3%E5%A4%B4%E6%96%87%E4%BB%B6%E5%92%8C%20%23%20Wbemuuid.lib%E3%80%82%23CONFIG_NDIS_EVENTS_INTEGRATED%20%3Dy%20%23PLATFORMSDKLIB%20%3D%20%22%20%2Fopt%2FprogramFiles%2FMicrosoft%20Platform%20SDK%2FLib%22%23%20%E6%B7%BB%E5%8A%A0%E5%AF%B9%E6%96%B0%20DBus%20%E6%8E%A7%E5%88%B6%E6%8E%A5%E5%8F%A3%E7%9A%84%E6%94%AF%E6%8C%81%23%20(fi.w1.wpa_supplicant1)%23CONFIG_CTRL_IFACE_DBUS_NEW%3Dy%23%E4%B8%BA%E6%96%B0%E7%9A%84%20DBus%20%E6%8E%A7%E5%88%B6%E6%8E%A5%E5%8F%A3%E6%B7%BB%E5%8A%A0%E5%86%85%E7%9C%81%E6%94%AF%E6%8C%81%23CONFIG_CTRL_IFACE_DBUS_INTRO%3Dy%23%20%E6%B7%BB%E5%8A%A0%E4%BB%A5%E5%85%B1%E4%BA%AB%E5%BA%93%E5%BD%A2%E5%BC%8F%E5%8A%A8%E6%80%81%E5%8A%A0%E8%BD%BD%20EAP%20%E6%96%B9%E6%B3%95%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%E5%90%AF%E7%94%A8%E8%AF%A5%E9%80%89%E9%A1%B9%E5%90%8E%EF%BC%8C%E6%AF%8F%E4%B8%AA%20EAP%20%E6%96%B9%E6%B3%95%E9%83%BD%E5%8F%AF%E4%BB%A5%E9%9D%99%E6%80%81%EF%BC%88CONFIG_EAP_%3CMETHOD%3E%3Dy%EF%BC%89%E6%88%96%E5%8A%A8%E6%80%81%EF%BC%88CONFIG_EAP_%3CMETHOD%3E%3Ddyn%EF%BC%89%E6%96%B9%E5%BC%8F%23%E5%8C%85%E5%90%AB%E3%80%82%20%23%E5%8A%A8%E6%80%81%20EAP%20%E6%96%B9%E6%B3%95%E4%BD%9C%E4%B8%BA%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%20(eap_*.so)%20%E6%9E%84%E5%BB%BA%E5%9C%A8%E7%BD%91%E7%BB%9C%E5%8C%BA%E5%9D%97%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%B9%8B%E5%89%8D%EF%BC%8C%E9%9C%80%E8%A6%81%E5%9C%A8%20wpa_supplicant%20%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E7%9A%84%E5%BC%80%E5%A4%B4%E5%8A%A0%E8%BD%BD%E5%AE%83%E4%BB%AC%EF%BC%88%E5%8F%82%E8%A7%81%E7%A4%BA%E4%BE%8B%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%20load_dynamic_eap%20%E5%8F%82%E6%95%B0%EF%BC%89%E3%80%82%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E4%B8%BB%E7%A8%8B%E5%BA%8F%20%23%20%E4%B8%AD%E5%8C%85%E5%90%AB%20EAP%20%E6%96%B9%E6%B3%95%E7%9A%84%E6%9F%90%E4%BA%9B%E5%85%B1%E4%BA%AB%E9%83%A8%E5%88%86%EF%BC%8C%E4%B8%BA%E4%BA%86%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%E8%BF%99%E4%BA%9B%E9%83%A8%E5%88%86%E4%BD%BF%E7%94%A8%E5%8A%A8%E6%80%81%20EAP%20%E6%96%B9%E6%B3%95%EF%BC%8C%23%20%E4%B8%BB%E7%A8%8B%E5%BA%8F%E5%BF%85%E9%A1%BB%E6%98%AF%E5%9C%A8%E5%90%AF%E7%94%A8%20EAP%20%E6%96%B9%E6%B3%95%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E6%9E%84%E5%BB%BA%E7%9A%84%EF%BC%88%3Dy%20%E6%88%96%20%3Ddyn%EF%BC%89%E3%80%82%23%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E4%B8%8D%E8%83%BD%E5%B0%86%20EAP-TLS%2FPEAP%2FTTLS%2FFAST%20%E6%B7%BB%E5%8A%A0%E4%B8%BA%E5%8A%A8%E6%80%81%E5%BA%93%23%EF%BC%8C%E9%99%A4%E9%9D%9E%E4%B8%BB%E7%89%88%E6%9C%AC%E4%B8%AD%E5%8C%85%E5%90%AB%E8%87%B3%E5%B0%91%E4%B8%80%E4%B8%AA%E4%BB%A5%E5%BC%BA%E5%88%B6%E5%8C%85%E5%90%AB%E5%85%B1%E4%BA%AB%E4%BB%A3%E7%A0%81%20%23%E3%80%82%E5%90%8C%E6%A0%B7%EF%BC%8C%E4%B8%BB%E7%89%88%E6%9C%AC%E4%B8%AD%E5%BF%85%E9%A1%BB%E8%87%B3%E5%B0%91%E5%8C%85%E5%90%AB%E4%B8%80%E4%B8%AA%20EAP-SIM%2FAKA%20%23%EF%BC%8C%E6%89%8D%E8%83%BD%E5%8A%A8%E6%80%81%E5%8A%A0%E8%BD%BD%E8%BF%99%E4%BA%9B%E6%96%B9%E6%B3%95%E3%80%82%23%23%E5%8F%A6%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%8A%A8%E6%80%81%E5%BA%93%E5%B0%86%E5%A2%9E%E5%8A%A0%E4%BA%8C%E8%BF%9B%E5%88%B6%20%23%20%E7%9A%84%E6%80%BB%E5%A4%A7%E5%B0%8F%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%AF%B9%E4%BA%8E%E5%86%85%E5%AD%98%2F%E9%97%AA%E5%AD%98%E5%AE%B9%E9%87%8F%E6%9C%89%E9%99%90%E7%9A%84%E7%9B%AE%E6%A0%87%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E4%B8%8D%E6%98%AF%E6%9C%80%E4%BD%B3%E9%80%89%E6%8B%A9%E3%80%82%E5%8A%A8%E6%80%81%E5%8A%A0%E8%BD%BD%E5%BA%93%23%20%E6%B7%BB%E5%8A%A0%E9%85%8D%E7%BD%AE%E5%9C%A8%E7%BC%96%E8%AF%91%E6%97%B6%E5%8A%A0%E8%BD%BD%E5%BA%93%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%23CONFIG_PKCS11_ENGINE_PATH%20-%20pkcs11_engine%20%E5%BA%93%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%23CONFIG_PKCS11_MODULE_PATH%20-%20pkcs11_engine%20%E5%BA%93%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82-%20pkcs11_module%20library%20location.%23CONFIG_OPENSC_ENGINE_PATH-%20opensc_engine%20%E5%BA%93%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%E9%98%B2%E6%AD%A2%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%97%B6%E5%8A%A0%E8%BD%BD%E5%BA%93%23CONFIG_NO_PKCS11_ENGINE_PATH%3Dy%20%23%20%E9%98%B2%E6%AD%A2%E5%8A%A0%E8%BD%BD%20pkcs11_engine%20%E5%BA%93%E3%80%82%23%20%E9%98%BB%E6%AD%A2%E5%8A%A0%E8%BD%BD%20pkcs11_module%20library.%23CONFIG_NO_OPENSC_ENGINE_PATH%3Dy%20%23%20%E9%98%BB%E6%AD%A2%E5%8A%A0%E8%BD%BD%20opensc_engine%20%E5%BA%93%E3%80%82%E9%98%B2%E6%AD%A2%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%97%B6%E5%8A%A0%E8%BD%BD%20EAP%20%E5%BA%93%20%23CONFIG_NO_LOAD_DYNAMIC_EAP%20%3Dy%23%20IEEE%20Std%20802.11r-2008%EF%BC%88%E5%BF%AB%E9%80%9F%20BSS%20%E8%BF%87%E6%B8%A1%EF%BC%89%E9%80%82%E7%94%A8%E4%BA%8E%E5%B7%A5%E4%BD%9C%E7%AB%99%E6%A8%A1%E5%BC%8F%20Config_IEEE80211r%3DY%23%20%E6%B7%BB%E5%8A%A0%E5%AF%B9%E5%B0%86%E8%B0%83%E8%AF%95%E6%97%A5%E5%BF%97%E5%86%99%E5%85%A5%E6%96%87%E4%BB%B6%20(%2Ftmp%2Fwpa_supplicant-log-%23.txt)%20config_DEBUG_File%3DY%23%20%E7%9A%84%E6%94%AF%E6%8C%81%E5%B0%86%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%E5%8F%91%E9%80%81%E5%88%B0%20syslog%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20stdoutCONFIG_DEBUG_SYSLOG%3Dy%23%E4%B8%BA%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%E8%AE%BE%E7%BD%AE%20syslog%20%E8%AE%BE%E6%96%BD%23CONFIG_DEBUG_SYSLOG_FACILITY%3DLOG_DAEMON%23%E6%B7%BB%E5%8A%A0%E5%B0%86%E6%89%80%E6%9C%89%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%EF%BC%88%E6%97%A0%E8%AE%BA%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%E7%9A%84%E5%86%97%E9%95%BF%E7%A8%8B%E5%BA%A6%E5%A6%82%E4%BD%95%EF%BC%89%23%20%E5%8F%91%E9%80%81%E5%88%B0%20Linux%20%E5%86%85%E6%A0%B8%E8%B7%9F%E8%B8%AA%E8%AE%BE%E6%96%BD%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%E8%BF%99%E6%9C%89%E5%8A%A9%E4%BA%8E%E8%B0%83%E8%AF%95%E6%95%B4%E4%B8%AA%E5%A0%86%E6%A0%88%EF%BC%8C%E5%9B%A0%E4%B8%BA%20%23%20%E5%8F%AF%E4%BB%A5%E8%BD%BB%E6%9D%BE%E5%9C%B0%E5%B0%86%E4%BB%8E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%90%91%E4%B8%8A%E5%8F%91%E7%94%9F%E7%9A%84%E4%B8%80%E5%88%87%E8%AE%B0%E5%BD%95%E5%88%B0%20%23%20%E5%90%8C%E4%B8%80%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%E4%BE%8B%E5%A6%82%E4%BD%BF%E7%94%A8%E8%B7%9F%E8%B8%AA%E5%91%BD%E4%BB%A4%E3%80%82%E6%B7%BB%E5%8A%A0%E5%B0%86%E8%B0%83%E8%AF%95%E6%97%A5%E5%BF%97%E5%86%99%E5%85%A5%20Android%20logcat%20%E8%80%8C%E9%9D%9E%E6%A0%87%E5%87%86%E8%BE%93%E5%87%BA%E7%9A%84%E6%94%AF%E6%8C%81%23CONFIG_ANDROID_LOG%3Dy%23%23%20%E5%90%AF%E7%94%A8%E6%9D%83%E9%99%90%E5%88%86%E7%A6%BB%EF%BC%88%E8%AF%A6%E6%83%85%E8%AF%B7%E5%8F%82%E8%A7%81%20README%20'%E6%9D%83%E9%99%90%E5%88%86%E7%A6%BB'%EF%BC%89%23CONFIG_PRIVSEP%3Dy%23%20%E9%80%9A%E8%BF%87%E5%BB%B6%E8%BF%9F%20Michael%23%20MIC%20%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%200%20%E5%88%B0%2060%20%E7%A7%92%E4%B9%8B%E9%97%B4%E7%9A%84%E9%9A%8F%E6%9C%BA%E6%97%B6%E9%97%B4%EF%BC%8C%E7%BC%93%E8%A7%A3%E9%92%88%E5%AF%B9%20TKIP%20%E7%9A%84%E6%9F%90%E4%BA%9B%E6%94%BB%E5%87%BB%23CONFIG_DELAYED_MIC_ERROR_REPORT%3Dy%23%20%E5%90%AF%E7%94%A8%E7%94%A8%E4%BA%8E%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E8%B0%83%E8%AF%95%E7%9A%84%E8%B7%9F%E8%B8%AA%E4%BB%A3%E7%A0%81%23%20%E8%BF%99%E5%B0%86%E8%B7%9F%E8%B8%AA%E8%B0%83%E8%AF%95%E6%97%A5%E5%BF%97%E7%9A%84%E4%BD%BF%E7%94%A8%E6%83%85%E5%86%B5%E3%80%82MIC%20%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%E7%9A%84%E6%97%B6%E9%97%B4%E5%9C%A8%200%20%E8%87%B3%2060%20%E7%A7%92%E4%B9%8B%E9%97%B4%23CONFIG_DELAYED_MIC_ERROR_REPORT%3Dy%23%23%E5%90%AF%E7%94%A8%E8%B7%9F%E8%B8%AA%E4%BB%A3%E7%A0%81%EF%BC%8C%E7%94%A8%E4%BA%8E%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E8%B0%83%E8%AF%95%23%20%E8%BF%99%E5%B0%86%E8%B7%9F%E8%B8%AA%E5%86%85%E5%AD%98%E5%88%86%E9%85%8D%E5%92%8C%E5%85%B6%E4%BB%96%E6%B3%A8%E5%86%8C%E7%9A%84%E4%BD%BF%E7%94%A8%E6%83%85%E5%86%B5%EF%BC%8C%E5%B9%B6%E9%80%9A%E8%BF%87%E8%B0%83%E7%94%A8%EF%BC%88%E6%88%96%E5%88%86%E9%85%8D%EF%BC%89%E4%BD%8D%E7%BD%AE%E7%9A%84%E5%9B%9E%E6%BA%AF%E6%8A%A5%E5%91%8A%23%20%E4%B8%8D%E6%AD%A3%E7%A1%AE%E7%9A%84%E4%BD%BF%E7%94%A8%E6%83%85%E5%86%B5%E3%80%82%23CONFIG_WPA_TRACE%3Dy%23%E5%AF%B9%E4%BA%8E%20BSD%EF%BC%8C%E5%8F%96%E6%B6%88%E8%BF%99%E4%BA%9B%20%23LIBS%2B%3D%20-lexecinfo%23LIBS_p%20%2B%3D%20-lexecinfo%23LIBS_c%20%2B%3D%20-lexecinfo%23%20Use%20libbfd%20to%20get%20more%20details%20for%20developer%20debugging%23%20This%20enables%20use%20of%20libbfd%20to%20get%20more%20detailed%20symbols%20for%20the%20backtraces%23%20generated%20by%20CONFIG_WPA_TRACE%3Dy.%23CONFIG_WPA_TRACE_BFD%3Dy%23.%E5%AF%B9%E4%BA%8E%20BSD%EF%BC%8C%E5%8F%96%E6%B6%88%E8%BF%99%E4%BA%9B%20%23LIBS%2B%3D%20-lbfd%20-liberty%20-lz%23LIBS_p%20%2B%3D%20-lbfd%20-liberty%20-lz%23LIBS_c%20%2B%3D%20-lbfd%20-liberty%20-lz%23%20wpa_supplicant%20%E4%BE%9D%E8%B5%96%E4%BA%8E%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E6%8F%90%E4%BE%9B%E7%9A%84%E5%BC%BA%E9%9A%8F%E6%9C%BA%E6%95%B0%E7%94%9F%E6%88%90%E5%8A%9F%E8%83%BD%E3%80%82os_get_random()%20%E5%87%BD%E6%95%B0%E7%94%A8%E4%BA%8E%E5%9C%A8%E9%9C%80%E8%A6%81%E6%97%B6%E8%8E%B7%E5%8F%96%E9%9A%8F%E6%9C%BA%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%BE%8B%E5%A6%82%E7%94%9F%E6%88%90%E5%AF%86%E9%92%A5%E3%80%82%E5%9C%A8%20Linux%20%E5%92%8C%20BSD%20%E7%B3%BB%E7%BB%9F%E4%B8%8A%EF%BC%8C%E8%AF%A5%23%20%E9%80%9A%E8%BF%87%E8%AF%BB%E5%8F%96%20%2Fdev%2Furandom%20%E8%BF%90%E8%A1%8C%E3%80%82%E9%9C%80%E8%A6%81%E6%B3%A8%E6%84%8F%E7%9A%84%E6%98%AF%EF%BC%8C%E5%9C%A8%E5%90%AF%E5%8A%A8%20wpa_supplicant%20%E4%B9%8B%E5%89%8D%EF%BC%8C%E9%9C%80%E8%A6%81%E6%AD%A3%E7%A1%AE%E5%88%9D%E5%A7%8B%E5%8C%96%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E7%86%B5%E6%B1%A0%23%E3%80%82%E8%BF%99%E6%98%AF%20%23%20%E9%87%8D%E8%A6%81%E7%9A%84%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%E5%9C%A8%E6%B2%A1%E6%9C%89%E7%A1%AC%E4%BB%B6%E9%9A%8F%E6%9C%BA%E6%95%B0%E7%94%9F%E6%88%90%E5%99%A8%E4%B8%94%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E5%90%AF%E5%8A%A8%E6%97%B6%E5%8F%AF%E8%83%BD%E4%BD%BF%E7%94%A8%E6%9C%80%E5%B0%8F%E7%9A%84%E7%86%B5%E6%9D%A5%E7%94%9F%E6%88%90%E9%9A%8F%E6%9C%BA%E6%95%B0%E7%9A%84%E5%B5%8C%E5%85%A5%E5%BC%8F%E8%AE%BE%E5%A4%87%E4%B8%8A%E3%80%82%23%23%E4%BD%9C%E4%B8%BA%E5%AE%89%E5%85%A8%E7%BD%91%EF%BC%8C%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8Cwpa_supplicant%20%E4%BC%9A%E5%B0%9D%E8%AF%95%E5%9C%A8%E5%86%85%E9%83%A8%E6%94%B6%E9%9B%86%20%23%20%E9%A2%9D%E5%A4%96%E7%86%B5%EF%BC%8C%E4%BB%A5%E7%94%9F%E6%88%90%E9%9A%8F%E6%9C%BA%E6%95%B0%E6%8D%AE%EF%BC%8C%E4%B8%8E%E4%BB%8E%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E8%8E%B7%E5%8F%96%E7%9A%84%E6%95%B0%E6%8D%AE%20%23%20%E6%B7%B7%E5%90%88%E3%80%82%E8%BF%99%E6%9C%AC%E8%BA%AB%E5%B9%B6%E4%B8%8D%E7%AE%97%E5%BE%88%E5%BC%BA%EF%BC%8C%E4%BD%86%E5%9C%A8%E7%B3%BB%E7%BB%9F%E6%B1%A0%E6%9C%AA%E6%AD%A3%E7%A1%AE%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%8F%AF%E8%83%BD%23%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BC%BA%E7%83%88%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%E7%A1%AC%E4%BB%B6%E8%BE%85%E5%8A%A9%E9%9A%8F%E6%9C%BA%E6%95%B0%E7%94%9F%E6%88%90%E5%99%A8%E6%88%96%20%23%20%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E9%87%8D%E5%90%AF%E6%97%B6%E7%9A%84%E7%8A%B6%E6%80%81%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%B6%B3%E5%A4%9F%E7%9A%84%20%23%20%E7%86%B5%E5%AF%B9%E7%B3%BB%E7%BB%9F%E6%B1%A0%E8%BF%9B%E8%A1%8C%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%23%23%E5%8F%AF%E5%AF%B9%20wpa_supplicant%20%E8%BF%9B%E8%A1%8C%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%BD%BF%E5%85%B6%E5%9C%A8%23%E6%AC%A1%E9%87%8D%E5%90%AF%E6%97%B6%E4%BF%9D%E6%8C%81%E8%87%AA%E5%B7%B1%E7%9A%84%E7%86%B5%E5%AD%98%E5%82%A8%EF%BC%8C%E4%BB%A5%E5%A2%9E%E5%BC%BA%E9%9A%8F%E6%9C%BA%E6%95%B0%E7%94%9F%E6%88%90%E8%83%BD%E5%8A%9B%E3%80%82%E8%BF%99%E6%A0%B7%E5%81%9A%E5%B9%B6%E4%B8%8D%E5%AE%8C%E7%BE%8E%EF%BC%8C%E4%BD%86%E6%AF%94%E6%AF%8F%E6%AC%A1%20%23%20%E9%87%8D%E5%90%AF%E5%90%8E%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E9%9A%8F%E6%9C%BA%E6%95%B0%E5%BA%8F%E5%88%97%E8%A6%81%20%23%20%E5%AE%89%E5%85%A8%E5%BE%97%E5%A4%9A%E3%80%82%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20-e%3CENTROPY%20file%3D%22%22%3E%20%E5%91%BD%E4%BB%A4%E8%A1%8C%E9%80%89%E9%A1%B9%E5%90%AF%E7%94%A8%E8%AF%A5%E5%8A%9F%E8%83%BD%E3%80%82%E6%8C%87%E5%AE%9A%E6%96%87%E4%BB%B6%E5%BF%85%E9%A1%BB%E5%8F%AF%E7%94%B1%20wpa_supplicant%20%E8%AF%BB%E5%86%99%E3%80%82%E5%A6%82%E6%9E%9C%E5%B7%B2%E7%9F%A5%20os_get_random%20()%20%E5%8F%AF%E4%BB%A5%E6%8F%90%E4%BE%9B%E5%BC%BA%E5%A4%A7%E7%9A%84%E9%9A%8F%E6%9C%BA%E6%95%B0%E6%8D%AE%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%9C%A8%20%23%20Linux%2FBSD%20%E4%B8%8A%EF%BC%8C%E5%B7%B2%E7%9F%A5%E8%AF%A5%E6%9D%BF%E6%8B%A5%E6%9C%89%E6%9D%A5%E8%87%AA%20%2Fdev%2Furandom%20%E7%9A%84%E5%8F%AF%E9%9D%A0%E9%9A%8F%E6%9C%BA%E6%95%B0%E6%8D%AE%E6%9D%A5%E6%BA%90%EF%BC%89%EF%BC%8C%E5%88%99%E5%86%85%E9%83%A8%20wpa_supplicant%20%E9%9A%8F%E6%9C%BA%E6%B1%A0%E5%8F%AF%E4%BB%A5%20%23%20%E7%A6%81%E7%94%A8%E3%80%82%E8%BF%99%E5%B0%86%E8%8A%82%E7%9C%81%E4%B8%80%E4%BA%9B%E4%BA%8C%E8%BF%9B%E5%88%B6%E5%A4%A7%E5%B0%8F%E5%92%8C%20CPU%20%E4%BD%BF%E7%94%A8%E9%87%8F%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%B7%B2%E7%9F%A5%E5%8F%AF%E5%9C%A8%E6%BB%A1%E8%B6%B3%E4%B8%8A%E8%BF%B0%E8%A6%81%E6%B1%82%E7%9A%84%E8%AE%BE%E5%A4%87%20%23%E4%B8%8A%E4%BD%BF%E7%94%A8%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%8C%E6%89%8D%E5%BA%94%E8%80%83%E8%99%91%E4%BD%BF%E7%94%A8%E6%AD%A4%23%E3%80%82%23CONFIG_NO_RANDOM_POOL%20%3Dy%23%E5%9C%A8%20Linux%203.17%20%E5%8F%8A%E6%9B%B4%E6%96%B0%E7%89%88%E6%9C%AC%E4%B8%AD%EF%BC%8Cgetrandom(2)%20%E8%B0%83%E7%94%A8%E6%8F%90%E4%BE%9B%E4%BA%86%E6%AF%94%20%2Fdev%2Frandom%20%E6%9B%B4%E5%8F%AF%E9%9D%A0%23%E3%80%81%E6%9B%B4%E5%AE%89%E5%85%A8%E7%9A%84%E9%9A%8F%E6%9C%BA%E6%80%A7%E6%BA%90%EF%BC%8C%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E5%BA%94%E8%AF%A5%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E5%AE%83%E5%91%A2%EF%BC%9F%E9%9C%80%E8%A6%81%E6%9E%84%E5%BB%BA%20glibc%202.25%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%B8%8D%E5%8F%AF%E7%94%A8%EF%BC%8C%E5%88%99%E5%9B%9E%E9%80%80%E5%88%B0%20%2Fdev%2Frandom%E3%80%82%23CONFIG_GETRANDOM%20%3Dy%23%E6%94%AF%E6%8C%81%20IEEE%20802.11ac%EF%BC%88%E8%B6%85%E9%AB%98%E5%90%9E%E5%90%90%E9%87%8F%EF%BC%89%EF%BC%88%E4%B8%BB%E8%A6%81%E7%94%A8%E4%BA%8E%20AP%20%E6%A8%A1%E5%BC%8F%EF%BC%89CONFIG_IEEE80211AC%3Dy%23%20%E6%94%AF%E6%8C%81%20IEEE%20802.11ax%20HE%EF%BC%88%E4%B8%BB%E8%A6%81%E7%94%A8%E4%BA%8E%20AP%20%E6%A8%A1%E5%BC%8F%EF%BC%89CONFIG_IEEE80211AX%3Dy%23%20%E6%94%AF%E6%8C%81%20IEEE%20802.11be%20EHT%EF%BC%88%E4%B8%BB%E8%A6%81%E7%94%A8%E4%BA%8E%20AP%20%E6%A8%A1%E5%BC%8F%EF%BC%89%23%20CONFIG_IEEE80211AX%20%E6%98%AF%E8%AE%BE%E7%BD%AE%20CONFIG_IEEE80211BE.%23%20%E7%9A%84%E5%BF%85%E9%80%89%E9%A1%B9%E3%80%82%E6%B3%A8%EF%BC%9A%E8%BF%99%E6%98%AF%E4%B8%80%E9%A1%B9%E8%AF%95%E9%AA%8C%E6%80%A7%E5%B7%A5%E4%BD%9C%EF%BC%8C%E6%AD%A3%E5%9C%A8%E8%BF%9B%E8%A1%8C%E4%B8%AD%E3%80%82%E8%BF%99%E4%BA%9B%E5%AE%9A%E4%B9%89%E4%BB%8D%23%20%E6%9C%89%E5%8F%AF%E8%83%BD%E6%9B%B4%E6%94%B9%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%B8%8D%E5%BA%94%E6%8C%87%E6%9C%9B%E5%AE%83%E4%B8%8E%23%20%E6%9C%80%E7%BB%88%E7%9A%84%20IEEE%20802.11be%20%E7%89%88%E6%9C%AC%E4%BA%92%E6%93%8D%E4%BD%9C%E3%80%82%E6%97%A0%E7%BA%BF%E7%BD%91%E7%BB%9C%E7%AE%A1%E7%90%86%20(IEEE%20%E6%A0%87%E5%87%86%20802.11v-2011)%20%23%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%BF%99%E5%8F%AA%E6%98%AF%E8%AF%95%E9%AA%8C%E6%80%A7%E7%9A%84%EF%BC%8C%E5%B9%B6%E9%9D%9E%E5%AE%8C%E5%85%A8%E5%AE%9E%E7%8E%B0%E3%80%82%E4%BA%92%E9%80%9A%EF%BC%88IEEE%20802.11u%EF%BC%89%23%E8%BF%99%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%90%AF%E7%94%A8%E6%94%B9%E5%96%84%E4%B8%8E%20%23%20%E5%A4%96%E9%83%A8%E7%BD%91%E7%BB%9C%E4%BA%92%E9%80%9A%E7%9A%84%E5%8A%9F%E8%83%BD%EF%BC%88GAS%2FANQP%20%E7%94%A8%E4%BA%8E%E8%AF%A6%E7%BB%86%E4%BA%86%E8%A7%A3%E7%BD%91%E7%BB%9C%E5%92%8C%E5%9F%BA%E4%BA%8E%E5%8F%AF%E7%94%A8%E5%87%AD%E6%8D%AE%E9%80%89%E6%8B%A9%E7%9A%84%E7%BD%91%E7%BB%9C%EF%BC%89%E3%80%82config_interworking%3Dy%23%20Hotspot%202.0config_HS20%3DY%23%20%E5%9C%A8%20wpa_supplicant%20%E4%B8%AD%E5%90%AF%E7%94%A8%E6%8E%A5%E5%8F%A3%E5%8C%B9%E9%85%8D%20%23CONFIG_MATCH_IFACE%20%3Dy%23%20%E4%BD%BF%E7%94%A8%20wpa_supplicant%20%E5%9C%A8%20wpa_supplicant%20%E4%B8%AD%E7%A6%81%E7%94%A8%E6%BC%AB%E6%B8%B8%20%23CONFIG_NO_ROAMING%20%3Dy%23%20AP%20%E6%A8%A1%E5%BC%8F%E4%BD%BF%E7%94%A8%20wpa_supplicant%23%20%E8%BF%99%E4%B8%AA%E5%8F%AF%E4%BB%A5%E7%94%A8%E4%BA%8E%E4%BD%BF%E7%94%A8%20wpa_supplicant%20%E6%8E%A7%E5%88%B6%20AP%20%E6%A8%A1%E5%BC%8F%E5%B7%A5%E4%BD%9C%E3%80%82%E5%BA%94%E8%AF%A5%E6%B3%A8%E6%84%8F%E7%9A%84%E6%98%AF%EF%BC%8C%E8%BF%99%E4%B8%BB%E8%A6%81%E9%92%88%E5%AF%B9%20WPA2-Personal%20%E7%AD%89%E7%AE%80%E5%8D%95%E6%83%85%E5%86%B5%EF%BC%8C%E8%80%8C%E6%9B%B4%E5%A4%8D%E6%9D%82%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%88%E5%A6%82%E5%B8%A6%E6%9C%89%E5%A4%96%E9%83%A8%20RADIUS%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%20WPA2-Enterprise%EF%BC%89%E5%88%99%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20hostapd.CONFIG_AP%3Dy%23%20P2P%20(Wi-Fi%20Direct)%23%20%E5%9C%A8%20wpa_supplicant%20%E4%B8%AD%E5%90%AF%E7%94%A8%20P2P%20%E6%94%AF%E6%8C%81%E3%80%82%E6%9C%89%E5%85%B3%20P2P%20%E6%93%8D%E4%BD%9C%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20README-P2P%E3%80%82CONFIG_P2P%3Dy%23%20%E5%90%AF%E7%94%A8%20TDLS%20%E6%94%AF%E6%8C%81CONFIG_TDLS%3Dy%23%20Wi-Fi%20%E6%98%BE%E7%A4%BA%23%20%E7%94%A8%E4%BA%8E%E5%90%AF%E7%94%A8%20P2P%20%E7%9A%84%20Wi-Fi%20%E6%98%BE%E7%A4%BA%E6%89%A9%E5%B1%95%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%23%20%E7%A8%8B%E5%BA%8F%E6%8E%A7%E5%88%B6%E4%BF%A1%E6%81%AF%E4%B8%AD%E7%9A%84%E9%99%84%E5%8A%A0%E4%BF%A1%E6%81%AF%E4%BA%A4%E6%8D%A2%E3%80%82%E6%9C%89%E5%85%B3%E8%87%AA%E5%8A%A8%E6%89%AB%E6%8F%8F%E7%94%A8%E6%B3%95%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20wpa_supplicant.conf%E3%80%82%E7%9B%B4%E6%8E%A5%E5%90%AF%E7%94%A8%E6%A8%A1%E5%9D%97%E5%B0%86%E5%90%AF%E7%94%A8%E8%87%AA%E5%8A%A8%E6%89%AB%E6%8F%8F%E6%94%AF%E6%8C%81%E3%80%82%E5%AF%B9%E4%BA%8E%E6%8C%87%E6%95%B0%E6%A8%A1%E5%9D%97%EF%BC%9A%23CONFIG_AUTOSCAN_EXPONENTIAL%20%3Dy%23%20%E5%AF%B9%E4%BA%8E%E5%91%A8%E6%9C%9F%E6%80%A7%E6%A8%A1%E5%9D%97%EF%BC%9A%23CONFIG_AUTOSCAN_PERIODIC%20%3Dy%23%20%E5%A4%96%E9%83%A8%E5%AD%98%E5%82%A8%E7%9A%84%E5%AF%86%E7%A0%81%EF%BC%88%E5%92%8C%E5%AF%86%E7%A0%81%E7%AD%89%EF%BC%89%E5%90%8E%E7%AB%AF%23%20%E8%BF%99%E4%BA%9B%E5%8F%AF%E9%80%89%E6%9C%BA%E5%88%B6%E5%8F%AF%E7%94%A8%E4%BA%8E%E6%B7%BB%E5%8A%A0%E5%AF%B9%E5%9C%A8%E5%A4%96%E9%83%A8%EF%BC%88%E8%87%B3%20wpa_supplicant%EF%BC%89%E4%BD%8D%E7%BD%AE%E5%AD%98%E5%82%A8%E5%AF%86%E7%A0%81%20%23%20%E5%92%8C%E5%85%B6%E4%BB%96%E6%9C%BA%E5%AF%86%E4%BF%A1%E6%81%AF%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E8%BF%99%E5%85%81%E8%AE%B8%E4%BD%BF%E7%94%A8%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E7%89%B9%E5%AE%9A%E7%9A%84%E5%AF%86%E9%92%A5%E5%AD%98%E5%82%A8%E7%A9%BA%E9%97%B4%23%23%20%E5%A4%96%E9%83%A8%E5%AF%86%E7%A0%81%E5%90%8E%E7%AB%AF%E7%94%A8%E4%BA%8E%E6%B5%8B%E8%AF%95%E7%9B%AE%E7%9A%84%EF%BC%88%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E4%BD%BF%E7%94%A8%EF%BC%89%23CONFIG_EXT_PASSWORD_TEST%20%3Dy%23%20%E5%9F%BA%E4%BA%8E%E6%96%87%E4%BB%B6%E7%9A%84%E5%90%8E%E7%AB%AF%E4%BB%8E%E5%A4%96%E9%83%A8%E6%96%87%E4%BB%B6%E8%AF%BB%E5%8F%96%E5%AF%86%E7%A0%81%E3%80%82%23CONFIG_EXT_PASSWORD_FILE%20%3Dy%23%E5%90%AF%E7%94%A8%E5%BF%AB%E9%80%9F%E4%BC%9A%E8%AF%9D%E4%BC%A0%E8%BE%93%20(FST)%20%23CONFIG_FST%20%3Dy%23%20%E5%90%AF%E7%94%A8%20CLI%20%E5%91%BD%E4%BB%A4%E8%BF%9B%E8%A1%8C%20FST%20%E6%B5%8B%E8%AF%95%20%23CONFIG_FST_TEST%20%3Dy%23%20OS%20X%20%E7%89%88%E6%9C%AC%E3%80%82%E8%BF%99%E4%BB%85%E7%94%A8%E4%BA%8E%E6%9E%84%E5%BB%BA%20eapol_test.%23CONFIG_OSX%3Dy%23%E3%80%82%E8%87%AA%E5%8A%A8%E4%BF%A1%E9%81%93%E9%80%89%E6%8B%A9%23%20%E5%BD%93%E4%BF%A1%E9%81%93%23%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%220%22.%23%23%20%E6%97%B6%EF%BC%8C%E6%AD%A4%E5%8A%9F%E8%83%BD%E5%B0%86%E5%85%81%E8%AE%B8%20wpa_supplicant%20%E8%87%AA%E5%8A%A8%E9%80%89%E6%8B%A9%E4%BF%A1%E9%81%93%E3%80%82TODO%3A%20%E6%89%A9%E5%B1%95%E8%A7%A3%E6%9E%90%E5%99%A8%EF%BC%8C%E4%BD%BF%E5%85%B6%E8%83%BD%E5%A4%9F%E8%A7%A3%E6%9E%90%22channel%3Dacs_survey%22%20%E4%BD%9C%E4%B8%BA%22channel%3D0%22%20%E7%9A%84%E6%9B%BF%E4%BB%A3%23%20%E3%80%82%E8%BF%99%E5%B0%86%E4%BD%BF%E6%88%91%E4%BB%AC%E6%9C%80%E7%BB%88%E8%83%BD%E5%A4%9F%E4%BB%A5%E7%B1%BB%E4%BC%BC%E7%9A%84%E6%96%B9%E5%BC%8F%E6%B7%BB%E5%8A%A0%E5%85%B6%E4%BB%96%20ACS%20%E7%AE%97%E6%B3%95%E3%80%82%E8%87%AA%E5%8A%A8%E9%80%89%E6%8B%A9%E7%9B%AE%E5%89%8D%E5%8F%AA%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E6%97%B6%E8%BF%9B%E8%A1%8C%EF%BC%8C%E4%BB%A5%E5%90%8E%23%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E8%83%BD%E8%BF%9B%E8%A1%8C%E8%83%8C%E6%99%AF%E6%A3%80%E6%9F%A5%EF%BC%8C%E4%BB%A5%E4%BE%BF%E9%9A%8F%E7%9D%80%23%E6%97%B6%E9%97%B4%E7%9A%84%E6%8E%A8%E7%A7%BB%EF%BC%8C%E8%AE%A9%E6%88%91%E4%BB%AC%E5%90%91%E6%9B%B4%E7%90%86%E6%83%B3%E7%9A%84%E6%B8%A0%E9%81%93%E5%8F%91%E5%B1%95%E3%80%82%E7%9B%AE%E5%89%8D%EF%BC%8C%E5%8F%AA%E6%9C%89%20nl80211%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%94%AF%E6%8C%81%20ACS%EF%BC%8C%E5%B9%B6%E4%B8%94%23%E6%82%A8%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%BF%85%E9%A1%BB%E5%85%B7%E5%A4%87%E8%B0%83%E6%9F%A5%E8%BD%AC%E5%82%A8%E5%8A%9F%E8%83%BD%EF%BC%8C%E8%AF%A5%E5%8A%9F%E8%83%BD%E7%94%B1%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%23%E5%9C%A8%E6%89%AB%E6%8F%8F%E8%BF%87%E7%A8%8B%E4%B8%AD%E5%A1%AB%E5%85%85%E3%80%82TODO%3A%20%E4%B8%8E%20hostapd%20%E7%B1%BB%E4%BC%BC%EF%BC%8C%E6%96%B0%E5%88%9B%E5%BB%BA%E7%9A%84%20wpa_supplicant.conf%20%E5%8F%98%E9%87%8F%20acs_num_scans.%23%23%20%E5%8F%AF%E4%BB%A5%E8%87%AA%E5%AE%9A%E4%B9%89%20ACS%20%E5%8B%98%E6%B5%8B%E7%AE%97%E6%B3%95%E3%80%82%E6%94%AF%E6%8C%81%E7%9A%84%20ACS%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%23%20*%20ath9k%23%20*%20ath5k%23%20*%20ath10k%23%23%20%E6%9B%B4%E5%A4%9A%E8%AF%A6%E6%83%85%E8%AF%B7%E5%8F%82%E8%80%83%EF%BC%9A%23%20%3CA%20href%3D%22http%3A%2F%2Fwireless.kernel.org%2Fen%2Fusers%2FDocumentation%2Facs%23CONFIG_ACS%3Dy%23%E6%94%AF%E6%8C%81%E5%A4%9A%E9%A2%91%E6%AE%B5%E6%93%8D%E4%BD%9C%23CONFIG_MBO%3Dy%23%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwireless.kernel.org%2Fen%2Fusers%2FDocumentation%2Facs%23CONFIG_ACS%3Dy%23%E6%94%AF%E6%8C%81%E5%A4%9A%E9%A2%91%E6%AE%B5%E6%93%8D%E4%BD%9C%23CONFIG_MBO%3Dy%23%3C%2FA%3E%20%E5%BF%AB%E9%80%9F%E5%88%9D%E5%A7%8B%E9%93%BE%E8%B7%AF%E8%AE%BE%E7%BD%AE%20(FILS)%20(IEEE%20802.11ai)CONFIG_FILS%3Dy%23%E4%BD%BF%E7%94%A8%20PFS%20%E8%BF%9B%E8%A1%8C%20FILS%20%E5%85%B1%E4%BA%AB%E5%AF%86%E9%92%A5%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%20%23CONFIG_FILS_SK_PFS%20%3Dy%23%20%E6%94%AF%E6%8C%81%20IBSS%20%E7%BD%91%E7%BB%9C%E4%B8%8A%E7%9A%84%20RSN%20%23%20%E8%BF%99%E6%98%AF%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20proto%3DRSN%20%E5%92%8C%20%23%20key_mgmt%3DWPA-PSK%EF%BC%88%E5%8D%B3%E5%85%A8%E5%AF%86%E9%92%A5%E7%AE%A1%E7%90%86%E8%80%8C%E4%B8%8D%E6%98%AF%20WPA-None%EF%BC%89%E7%9A%84%20mode%3D1%20%E7%BD%91%E7%BB%9C%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E6%89%80%E5%BF%85%E9%9C%80%E7%9A%84%E3%80%82config_ibss_rsn%3DY%23%20%E5%A4%96%E9%83%A8%20PMKSA%20%E7%BC%93%E5%AD%98%E6%8E%A7%E5%88%B6%23%20%E8%BF%99%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%90%AF%E7%94%A8%E5%85%81%E8%AE%B8%E5%BD%93%E5%89%8D%20PMKSA%20%E7%BC%93%E5%AD%98%E7%9A%84%E6%8E%A7%E5%88%B6%E6%8E%A5%E5%8F%A3%E5%91%BD%E4%BB%A4%20%23%20%E8%A6%81%E6%8F%90%E5%8F%96%E7%9A%84%20PMKSA%20%E7%BC%93%E5%AD%98%E6%9D%A1%E7%9B%AE%E5%92%8C%E8%A6%81%E6%B7%BB%E5%8A%A0%E7%9A%84%E6%96%B0%E6%9D%A1%E7%9B%AE%E3%80%82%23CONFIG_PMKSA_CACHE_EXTERNAL%20%3Dy%23%E7%BD%91%E7%8A%B6%E7%BD%91%E7%BB%9C%20(IEEE%20802.11s)%23CONFIG_MESH%3Dy%23%E5%90%8E%E5%8F%B0%E6%89%AB%E6%8F%8F%E6%A8%A1%E5%9D%97%23%20%E8%BF%99%E4%BA%9B%E6%A8%A1%E5%9D%97%E5%8F%AF%E7%94%A8%E4%BA%8E%E8%AF%B7%E6%B1%82%20wpa_supplicant%20%E6%89%A7%E8%A1%8C%E5%90%8E%E5%8F%B0%E6%89%AB%E6%8F%8F%E6%93%8D%E4%BD%9C%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%9C%A8%20ESS%EF%BC%88%E5%90%8C%E4%B8%80%20SSID%EF%BC%89%E5%86%85%E8%BF%9B%E8%A1%8C%E6%BC%AB%E6%B8%B8%E3%80%82%E6%9C%89%E5%85%B3%E8%AF%A6%E6%83%85%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20wpa_supplicant.conf%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%20bgscan%20%E5%8F%82%E6%95%B0%E3%80%82%E6%A0%B9%E6%8D%AE%E4%BF%A1%E5%8F%B7%E5%BC%BA%E5%BA%A6%E8%BF%9B%E8%A1%8C%E5%AE%9A%E6%9C%9F%E5%90%8E%E5%8F%B0%E6%89%AB%E6%8F%8F%20Config_bgscan_simple%3DY%23%20%E5%AD%A6%E4%B9%A0%E7%BD%91%E7%BB%9C%E4%BD%BF%E7%94%A8%E7%9A%84%E9%A2%91%E9%81%93%E5%B9%B6%E5%B0%BD%E9%87%8F%E9%81%BF%E5%85%8D%E5%9C%A8%E5%85%B6%E4%BB%96%20%23%20%E9%A2%91%E9%81%93%E4%B8%8A%E8%BF%9B%E8%A1%8C%20bgscan%EF%BC%88%E5%AE%9E%E9%AA%8C%E6%80%A7%EF%BC%89%23CONFIG_BGSCAN_LEARN%20%3Dy%23%20%E6%9C%BA%E4%BC%9A%E6%80%A7%E6%97%A0%E7%BA%BF%E5%8A%A0%E5%AF%86%20(OWE)%20%23%20draft-harkins-owe-07.txt%20%E7%9A%84%E5%AE%9E%E9%AA%8C%E5%AE%9E%E7%8E%B0%20%23CONFIG_OWE%20%3Dy%23%20%E8%AE%BE%E5%A4%87%E9%85%8D%E7%BD%AE%E5%8D%8F%E8%AE%AE%20(DPP)%EF%BC%88%E4%B9%9F%E7%A7%B0%E4%B8%BA%20Wi-Fi%20Easy%20Connect%EF%BC%89config_dpp%3DY%23%20DPP%20%E7%89%88%E6%9C%AC%202%20supportconfig_dpp2%3DY%23%20PP%20%E7%89%88%E6%9C%AC%203%20%E6%94%AF%E6%8C%81%EF%BC%88%E5%AE%9E%E9%AA%8C%E4%B8%AD%E4%B8%94%E4%BB%8D%E5%9C%A8%E5%8F%98%E5%8C%96%EF%BC%9B%E4%B8%8D%E5%90%AF%E7%94%A8%20%23%20%E7%94%9F%E4%BA%A7%E7%94%A8%E9%80%94%EF%BC%89%23CONFIG_DPP3%20%3Dy%23%20%E6%9C%89%E7%BA%BF%E7%AD%89%E6%95%88%E9%9A%90%E7%A7%81%20(WEP)%20%23%20WEP%20%E6%98%AF%E4%B8%80%E4%B8%AA%E8%BF%87%E6%97%B6%E7%9A%84%E5%8A%A0%E5%AF%86%E6%95%B0%E6%8D%AE%E4%BF%9D%E5%AF%86%E7%AE%97%E6%B3%95%EF%BC%8C%E4%B8%8D%E6%98%AF%20%23%20%E5%AE%89%E5%85%A8%E7%9A%84%E3%80%82%E5%AE%83%E4%B8%8D%E5%BA%94%E8%AF%A5%E5%86%8D%E8%A2%AB%E7%94%A8%E6%9D%A5%E5%81%9A%E4%BB%BB%E4%BD%95%E4%BA%8B%E6%83%85%E3%80%82%E4%BD%BF%E7%94%A8%20WEP%20%E6%89%80%E9%9C%80%E7%9A%84%20%23%20%E5%8A%9F%E8%83%BD%E5%8F%AF%E5%9C%A8%E5%BD%93%E5%89%8D%20wpa_supplicant%23%20%E7%89%88%E6%9C%AC%E4%B8%AD%E4%BD%BF%E7%94%A8%E6%AD%A4%E5%8F%AF%E9%80%89%E7%9A%84%E7%BC%96%E8%AF%91%E5%8F%82%E6%95%B0%E6%8F%90%E4%BE%9B%E3%80%82%E6%AD%A4%E5%8A%9F%E8%83%BD%E5%B0%86%E5%9C%A8%E6%9C%AA%E6%9D%A5%E7%9A%84%E7%89%88%E6%9C%AC%E4%B8%AD%E5%AE%8C%E5%85%A8%E5%88%A0%E9%99%A4%20%23%E3%80%82%23CONFIG_WEP%20%3Dy%23%E7%A7%BB%E9%99%A4%E6%89%80%E6%9C%89%20TKIP%20%E5%8A%9F%E8%83%BD%23%20TKIP%20%E6%98%AF%E4%B8%80%E7%A7%8D%E6%97%A7%E7%9A%84%E5%8A%A0%E5%AF%86%E6%95%B0%E6%8D%AE%E4%BF%9D%E5%AF%86%E7%AE%97%E6%B3%95%EF%BC%8C%E4%B8%8D%E6%98%AF%20%23%20%E5%AE%89%E5%85%A8%E7%9A%84%E3%80%82%E5%9C%A8%E8%BF%9E%E6%8E%A5%E4%BD%BF%E7%94%A8%20WPA%2BWPA2%20%E6%B7%B7%E5%90%88%E6%A8%A1%E5%BC%8F%E7%9A%84%E6%97%A0%E7%BA%BF%E6%8E%A5%E5%85%A5%E7%82%B9%E6%97%B6%EF%BC%8C%E9%99%A4%E4%BA%86%E4%BD%9C%E4%B8%BA%E7%BB%84%E5%AF%86%E7%A0%81%E7%9A%84%E5%90%91%E5%90%8E%E5%85%BC%E5%AE%B9%E6%80%A7%E9%80%89%E9%A1%B9%E5%A4%96%EF%BC%8C%E4%B8%8D%E5%BA%94%E5%86%8D%E4%BD%BF%E7%94%A8%E5%AE%83%E3%80%82%E7%9B%AE%E5%89%8D%EF%BC%8C%E9%BB%98%E8%AE%A4%E7%9A%84%20wpa_supplicant%20%E7%89%88%E6%9C%AC%E9%BB%98%E8%AE%A4%E5%8C%85%E5%90%AB%E5%AF%B9%E6%AD%A4%E7%9A%84%20%23%20%E6%94%AF%E6%8C%81%EF%BC%8C%E4%BD%86%E8%AF%A5%E5%8A%9F%E8%83%BD%E5%B0%86%E6%9D%A5%E5%8F%AF%E8%83%BD%E4%BC%9A%E8%A2%AB%E5%88%A0%E9%99%A4%20%23%E3%80%82%23CONFIG_NO_TKIP%20%3Dy%23%E5%85%B3%E8%81%94%E5%89%8D%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E5%8D%8F%E5%95%86%20(PASN)%20%23%20%E5%9F%BA%E4%BA%8E%20IEEE%20p802.11z%2FD2.6%20%E7%9A%84%E5%AE%9E%E9%AA%8C%E5%AE%9E%E7%8E%B0%E5%92%8C%E5%8D%8F%E8%AE%AE%20%23%20%E7%9A%84%E8%AE%BE%E8%AE%A1%E4%BB%8D%E5%8F%AF%E8%83%BD%E5%8F%91%E7%94%9F%E5%8F%98%E5%8C%96%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%20%23%20%E7%94%9F%E4%BA%A7%E4%BD%BF%E7%94%A8%E4%B8%AD%E8%BF%98%E4%B8%8D%E5%BA%94%E5%90%AF%E7%94%A8%E6%AD%A4%E5%8A%9F%E8%83%BD%E3%80%82%E7%A6%81%E7%94%A8%E5%AF%B9%E6%97%A0%E7%BA%BF%E7%94%B5%E6%B5%8B%E9%87%8F%EF%BC%88IEEE%20802.11k%EF%BC%89%E5%92%8C%E6%94%AF%E6%8C%81%E7%9A%84%E6%93%8D%E4%BD%9C%20%23%20%E7%B1%BB%E5%88%AB%E6%8C%87%E7%A4%BA%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%E4%B8%8D%E5%BB%BA%E8%AE%AE%E5%88%A0%E9%99%A4%E8%BF%99%E4%BA%9B%E9%80%89%E9%A1%B9%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%8A%A9%23%20%E6%8E%A5%E5%85%A5%E7%82%B9%E7%AE%A1%E7%90%86%E7%BD%91%E7%BB%9C%E5%92%8C%20STA%20%E8%BD%AC%E5%90%91%E3%80%82%E7%A6%81%E7%94%A8%E6%B6%88%E8%B4%B9%E8%80%85%E5%92%8C%E4%BC%81%E4%B8%9A%20Wi-Fi%23%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%AF%B9%E5%BC%BA%E5%A4%A7%E9%9F%B3%E8%A7%86%E9%A2%91%E6%B5%81%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%9BIEEE%20Std%20802.11-2020%EF%BC%8C4.3.24%EF%BC%9BSCS%E3%80%81MSCS%E3%80%81QoS%20%E7%AE%A1%E7%90%86%23CONFIG_NO_ROBUST_AV%3Dy%23%20%E7%A6%81%E7%94%A8%E5%AF%B9%20WMM%20%E5%87%86%E5%85%A5%E6%8E%A7%E5%88%B6%E7%9A%84%E6%94%AF%E6%8C%81%23CONFIG_NO_WMM_AC%3Dy%23%20Wi-Fi%20%E6%84%9F%E7%9F%A5%E9%9D%9E%E5%90%8C%E6%AD%A5%E6%9C%8D%E5%8A%A1%E5%8F%91%E7%8E%B0%20(NAN%20USD)%23CONFIG_NAN_USD%3Dy%3C%2FENTROPY%3E%3C%2FMETHOD%3E%3C%2FMETHOD%3E%3C%2FPATH%3E%3C%2FPATH%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3EMakefile%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%89%A7%E9%80%8F%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E9%AB%98%E4%BA%AE%E9%83%A8%E5%88%86%E5%8F%AF%E4%BE%9B%E9%98%85%E8%AF%BB%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AW611%20WiFi%20chip%20Wi-Fi%20scan%20timeout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F250148%22%20target%3D%22_blank%22%3E%40eric25%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E9%9D%99%E6%80%81%E6%9E%84%E5%BB%BA%E6%A8%A1%E5%BC%8F%E7%BC%96%E8%AF%91%E4%BA%86%20wpa_supplicant-2.11%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%89%80%E6%9C%89%E6%AD%A5%E9%AA%A4%E9%83%BD%E8%AE%B0%E5%BD%95%E5%9C%A8%E9%99%84%E4%BB%B6%E4%B8%AD%EF%BC%8C%E4%BE%9B%E6%82%A8%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%8D%AB%E4%B8%9C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AW611%20WiFi%20chip%20Wi-Fi%20scan%20timeout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ewpa_supplicant%20%E6%98%AF%E6%88%91%E6%A0%B9%E6%8D%AE%E6%BA%90%E4%BB%A3%E7%A0%81%E7%BC%96%E8%AF%91%E7%9A%84%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E7%B3%BB%E7%BB%9F%E6%8F%90%E4%BE%9B%E7%9A%84%E3%80%82%E7%BC%96%E8%AF%91%E6%97%B6%E4%BD%BF%E7%94%A8%E7%9A%84%20Makefile%20%E9%80%89%E9%A1%B9%E6%98%AF%E5%90%A6%E6%9C%89%E8%AF%AF%EF%BC%9F%E6%82%A8%E5%AF%B9%E5%A6%82%E4%BD%95%E7%BC%96%E8%AF%91%E6%9C%89%E4%BB%80%E4%B9%88%E6%8C%87%E5%AF%BC%E6%84%8F%E8%A7%81%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339161%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AW611%20WiFi%20chip%20Wi-Fi%20scan%20timeout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339161%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%20vervion%EF%BC%8C%E5%AE%83%E6%98%AF%20wpa_supplicant%20v2.11%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5Broot%40br03%20~%5D%23%20wpa_supplicant%20-v%3CBR%20%2F%3Ewpa_supplicant%20v2.11-devel-hostap_2_10-386-gb859b9bce%3CBR%20%2F%3ECopyright%20(c)%202003-2022%2C%20Jouni%20Malinen%3CJ%3E%E5%92%8C%E8%B4%A1%E7%8C%AE%E8%80%85%3CBR%20%2F%3E%5Broot%40br03%20~%5D%23%3CBR%20%2F%3E%5Broot%40br03%20~%5D%23%20wpa%3CBR%20%2F%3Ewpa.conf%20wpa_cli%20wpa_supplicant%3CBR%20%2F%3E%5Broot%40br03%20~%5D%23%20wpa%3CBR%20%2F%3Ewpa.conf%20wpa_cli%20wpa_supplicant%3CBR%20%2F%3E%5Broot%40br03%20~%5D%23%20wpa_cli%3CBR%20%2F%3Ewpa_cli%20v2.11-devel-hostap_2_10-386-gb859b9bce%3CBR%20%2F%3ECopyright%20(c)%202004-2022%2C%20Jouni%20Malinen%3CJ%3E%E5%92%8C%E8%B4%A1%E7%8C%AE%E8%80%85%3C%2FJ%3E%3C%2FJ%3E%3C%2FP%3E%3CP%3E%E6%9C%AC%E8%BD%AF%E4%BB%B6%E5%8F%AF%E6%A0%B9%E6%8D%AE%20BSD%20%E8%AE%B8%E5%8F%AF%E8%AF%81%E6%9D%A1%E6%AC%BE%E8%BF%9B%E8%A1%8C%E5%8F%91%E5%B8%83%E3%80%82%3CBR%20%2F%3E%E8%AF%A6%E6%83%85%E8%AF%B7%E5%8F%82%E8%A7%81%20README%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BA%92%E5%8A%A8%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%20wpa_supplicant%EF%BC%9A%EF%BC%88%E6%97%A0%EF%BC%89%20-%20%E9%87%8D%E8%AF%95%3C%2FP%3E%3CP%3E%5Broot%40br03%20~%5D%23%20wpa_cli%20-v%3CBR%20%2F%3Ewpa_cli%20v2.11-devel-hostap_2_10-386-gb859b9bce%3CBR%20%2F%3ECopyright%20(c)%202004-2022%2C%20Jouni%20Malinen%3CJ%3E%E5%92%8C%E8%B4%A1%E7%8C%AE%E8%80%85%3CBR%20%2F%3E%5Broot%40br03%20~%5D%23%3C%2FJ%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AW611%20WiFi%20chip%20Wi-Fi%20scan%20timeout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F250148%22%20target%3D%22_blank%22%3E%40eric25%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E5%88%9D%E6%AD%A5%E5%88%A4%E6%96%AD%3CSTRONG%3E%E6%82%A8%E7%B3%BB%E7%BB%9F%E4%B8%AD%E7%9A%84%20wpa_supplicant%20%E7%89%88%E6%9C%AC%E8%BF%87%E6%97%A7%3C%2FSTRONG%3E%E3%80%82%E7%94%B1%E4%BA%8E%E6%82%A8%E7%9A%84%E5%B9%B3%E5%8F%B0%E8%BF%90%E8%A1%8C%E7%9A%84%E6%98%AF%3CSTRONG%3ELinux%204.4.19%20%E5%86%85%E6%A0%B8%3C%2FSTRONG%3E%EF%BC%8C%E6%AD%A4%E7%B1%BB%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%8C%85%E5%90%AB%E7%9A%84%20wpa_supplicant%20%E9%80%9A%E5%B8%B8%3CSTRONG%3E%E4%B8%8D%E4%BC%9A%E6%AF%94%202.5%20%E7%89%88%E6%9C%AC%E6%9B%B4%E6%96%B0%3C%2FSTRONG%3E%E3%80%82%E6%97%A7%E7%89%88%E6%9C%AC%E4%B8%8D%E5%AE%8C%E5%85%A8%E6%94%AF%E6%8C%81%E6%89%80%E9%9C%80%E7%9A%84%20nl80211%20%E6%89%AB%E6%8F%8F%E6%9C%BA%E5%88%B6%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E5%AF%BC%E8%87%B4%3CSTRONG%3E%E6%89%AB%E6%8F%8F%E8%B6%85%E6%97%B6%E5%92%8C%E6%97%A0%E6%B3%95%E6%A3%80%E6%B5%8B%E5%88%B0%3C%2FSTRONG%3E%E6%82%A8%E6%AD%A3%E5%9C%A8%E8%A7%82%E5%AF%9F%E7%9A%84Wi-Fi%20%E7%83%AD%E7%82%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E5%BB%BA%E8%AE%AE%E4%BD%A0%3CSTRONG%3E%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%20wpa_supplicant%20%E7%89%88%E6%9C%AC%202.10%EF%BC%8C%E6%88%96%E8%80%85%E4%BA%A4%E5%8F%89%E7%BC%96%E8%AF%91%202.11%20%E6%88%96%202.12%EF%BC%8C%E7%84%B6%E5%90%8E%E6%9B%BF%E6%8D%A2%3C%2FSTRONG%3E%E6%9D%BF%E4%B8%8A%E7%9A%84%E6%97%A7%E7%89%88%E6%9C%AC%E3%80%82%E6%9B%B4%E6%96%B0%20wpa_supplicant%20%E5%90%8E%EF%BC%8C%E8%AF%B7%E9%87%8D%E5%A4%8D%E5%8E%9F%E6%9D%A5%E7%9A%84%E6%B5%8B%E8%AF%95%E6%AD%A5%E9%AA%A4%EF%BC%8C%E6%A3%80%E6%9F%A5%20Wi-Fi%20%E6%89%AB%E6%8F%8F%E6%98%AF%E5%90%A6%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E8%AF%95%E8%AF%95%E7%9C%8B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%8D%AB%E4%B8%9C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2340126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AW611%20WiFi%20chip%20Wi-Fi%20scan%20timeout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2340126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%E3%80%81%20%3C%2FP%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E4%B8%8A%E4%BC%A0%E9%99%84%E4%BB%B6%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2340048%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AW611%20WiFi%20chip%20Wi-Fi%20scan%20timeout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2340048%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8C%B9%E9%85%8D%EF%BC%8C%3C%2FP%3E%3CP%3Ewifi%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%E6%98%AF%20aw611_driver%5Cp26.11%5CWIFI-BT-AAU_6_1_55-IMX8--MM6X18540.p17_V3-GPL%5Cwlan_src%5C%E3%80%81%E7%94%B1UTA%20%E6%8F%90%E4%BE%9B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%97%A5%E5%BF%97%E5%92%8C%20dmesg%20%E5%9C%A8%E8%BF%99%E9%87%8C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fpan.quark.cn%2Fs%2F5e926a94d760%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fpan.quark.cn%2Fs%2F5e926a94d760%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20615px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20615px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20615px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20615px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpg%22%20style%3D%22width%3A%20615px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380473i4C6585F31CE20E57%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.jpg%22%20alt%3D%222.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ewpa_supplicant.conf%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%89%A7%E9%80%8F%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E9%AB%98%E4%BA%AE%E9%83%A8%E5%88%86%E5%8F%AF%E4%BE%9B%E9%98%85%E8%AF%BB%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3Eupdate_config%3D1%3CBR%20%2F%3Ectrl_interface%3D%2Fvar%2Frun%2Fwpa_supplicant%3CBR%20%2F%3Eeapol_version%3D1%3CBR%20%2F%3Eap_scan%3D1%3CBR%20%2F%3Efast_reauth%3D1%3CBR%20%2F%3Edriver_param%3Duse_p2p_group_interface%3D1p2p_device%3D1%3CBR%20%2F%3E%23device_name%3DI1587-s_wifi%3CBR%20%2F%3Edevice_type%3D10-0050F204-5%3CBR%20%2F%3Econfig_methods%3Dvirtual_push_button%20physical_display%20keyboard%3CBR%20%2F%3Ehs20%3D1%3CBR%20%2F%3Einterworking%3D1%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3Eupdate_config%3D1ctrl_interface%3D%2Fvar%2Frun%2Fwpa_supplicanteapol_version%3D1ap_scan%3D1fast_reauth%3D1driver_param%3Duse_p2p_group_interface%3D1p2p_device%3D1%23device_name%3DI1587-s_wifidevice_type%3D10-0050F204-5config_methods%3Dvirtual_push_button%20physical_display%20keyboardhs20%3D1interworking%3D1%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3Edmesg0326-2.txt%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%89%A7%E9%80%8F%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E9%AB%98%E4%BA%AE%E9%83%A8%E5%88%86%E5%8F%AF%E4%BE%9B%E9%98%85%E8%AF%BB%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%5B0.000000%5D%20%E5%9C%A8%E7%89%A9%E7%90%86%20CPU%20%E4%B8%8A%E5%90%AF%E5%8A%A8%20Linux%200x0%20%3CBR%20%2F%3E%20%5B0.000000%5D%20Linux%20%E7%89%88%E6%9C%AC%204.4.19(root%40AndroidSev)%20(gcc%20version%204.9.3%2020141031%20(prerelease)%20(Linaro%20GCC%202014.11)%20)%23226%20Thu%20Mar%2026%2011%3A48%3A39%20CST%202026%3CBR%20%2F%3E%5B%200.000000%5D%20CPU%EF%BC%9AARMv7%20%E5%A4%84%E7%90%86%E5%99%A8%20%5B410fc051%5D%20%E4%BF%AE%E8%AE%A2%E7%89%88%201%20(ARMv7)%2C%20cr%3D10c53c7d%3CBR%20%2F%3E%5B%200.000000%5D%20CPU%EF%BC%9APIPT%20%2F%20VIPT%20%E9%9D%9E%E6%B7%B7%E5%8F%A0%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%EF%BC%8CVIPT%20%E6%B7%B7%E5%8F%A0%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%3CBR%20%2F%3E%5B%200.000000%5D%20%E6%9C%BA%E5%99%A8%E5%9E%8B%E5%8F%B7%EF%BC%9ASAMA5D3%20Xplained%3CBR%20%2F%3E%5B%200.000000%5D%20Reserved%20memory%3A%20created%20CMA%20memory%20pool%20at%200x26c00000%2C%20size%2016%20MiB%3CBR%20%2F%3E%5B%200.000000%5D%20Reserved%20memory%3A%20initialized%20node%20linux%2Ccma%2C%20compatible%20id%20shared-dma-pool%3CBR%20%2F%3E%5B%200.000000%5D%20Memory%20policy%EF%BC%9AData%20cache%20writeback%3CBR%20%2F%3E%5B%200.000000%5D%20On%20node%200%20totalpages%EF%BC%9A32512%3CBR%20%2F%3E%5B%200.000000%5D%20free_area_init_node%3A%20node%200%2C%20pgdat%20c0643dd0%2C%20node_mem_map%20c7df2000%3CBR%20%2F%3E%5B%200.000000%5D%20Normal%20zone%3A%20254%20pages%20used%20for%20memmap%3CBR%20%2F%3E%5B%200.000000%5D%20Normal%20zone%3A%200%20pages%20reserved%3CBR%20%2F%3E%5B%200.000000%5D%20Normal%20zone%3A%2032512%20pages%2C%20LIFO%20batch%3A7%3CBR%20%2F%3E%5B%200.000000%5D%20CPU%EF%BC%9A%E6%89%80%E6%9C%89%20CPU%20%E5%9D%87%E4%BB%A5%20SVC%20%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%E3%80%82%3CBR%20%2F%3E%5B0.000000%5D%20pcpu-alloc%EF%BC%9As0%20r0%20d32768%20u32768%20alloc%3D1*32768%20%5B0.000000%5D%20pcpu-alloc%EF%BC%9A%5B0%5D%200%20%3CBR%20%2F%3E%20%5B0.000000%5D%20%E6%8C%89%E5%8C%BA%E5%9F%9F%E9%A1%BA%E5%BA%8F%E6%9E%84%E5%BB%BA%201%20%E4%B8%AA%E5%8C%BA%E5%9F%9F%E5%88%97%E8%A1%A8%EF%BC%8C%E7%A7%BB%E5%8A%A8%E5%88%86%E7%BB%84%E5%BC%80%E5%90%AF%E3%80%82%3CBR%20%2F%3E%E6%80%BB%E9%A1%B5%E6%95%B0%EF%BC%9A32258%20%3CBR%20%2F%3E%20%5B0.000000%5D%20%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Anoinitrd%20console%3Dttys0%2C115200%20clk_ignore_unused%20rootfstype%3Dubifs%20ubi.mtd%3D3%20root%3Dubi0%3A%20rootfs%20ro%20rootwait%20init%3D%2Fsinit%20%5B0.000000%5D%20PID%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A-1%EF%BC%8C2048%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.00000%5D%5D%20%E5%85%A5%E5%8F%A3%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A16384%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A4%EF%BC%8C65536%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.000000%5D%20%E7%B4%A2%E5%BC%95%E8%8A%82%E7%82%B9%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A8192%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A3%EF%BC%8C32768%20%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%5B0.000000%5D%20%E5%86%85%E5%AD%98%EF%BC%9A105740K%2F130048K%20%E5%8F%AF%E7%94%A8%EF%BC%884696K%20%E5%86%85%E6%A0%B8%E4%BB%A3%E7%A0%81%E3%80%81145K%20rwdata%E3%80%811360K%20rodata%E3%80%81180K%20%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%81159K%20bss%E3%80%817924S%20%E5%B7%B2%E4%BF%9D%E7%95%99%EF%BC%8C16384K%20cma-reserved%EF%BC%89%3CBR%20%2F%3E%5B0.%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E000000%5D%20%E8%99%9A%E6%8B%9F%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%EF%BC%9A%3CBR%20%2F%3E%5B0.000000%5D%20%E5%90%91%E9%87%8F%EF%BC%9A0xffff0000-0xffff1000%20(4%20kB)%20%5B0.000000%5D%20%E4%BF%AE%E5%A4%8D%E5%9C%B0%E5%9B%BE%EF%BC%9A0xffc00000-0xfff00000%20(3072%20kB)%20%3CBR%20%2F%3E%20%5B0.000000%5D%20vmalloc%EF%BC%9A0xc8000000-0xff800000%20(888%20MB)%20%5B0.000000%5D%20lowmem%EF%BC%9A0xc00000000-0xc7f00000%20(127%20MB)%20%3CBR%20%2F%3E%20%5B0.000000%5D%20%E6%A8%A1%E5%9D%97%EF%BC%9A0xbf000000-0xc0000000%20(16%20MB)%20%5B0.000000%5D%20.text%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3A0xc0008000%20-%200xc05f22d4%20(6057%20kB)%3CBR%20%2F%3E%5B%200.000000%5D%20.init%3A0xc05f3000%20-%200xc0620000%20(%20180%20kB)%3CBR%20%2F%3E%5B%200.000000%5D%20.data%3A0xc0620000%20-%200xc06447a0%20(%20146%20kB)%3CBR%20%2F%3E%5B%200.000000%5D%20.bss%3A%200xc06447a0-0xc066c72c%20(160%20kB)%20%3CBR%20%2F%3E%20%5B0.000000%5D%20SLUB%EF%BC%9AHWAlign%3D64%EF%BC%8COrder%3D0-3%EF%BC%8CminObjects%3D0%EF%BC%8CCPUS%3D1%EF%BC%8C%E8%8A%82%E7%82%B9%3D1%20%5B0.000000%5D%20NR_IRQS%3A%2016%2016%20%5B0.000000%5D%20%E6%97%B6%E9%92%9F%E6%9D%A5%E6%BA%90%EF%BC%9A%E8%AE%A1%E6%97%B6%E5%99%A8%20%40f0010000%EF%BC%9A%E6%8E%A9%E7%A0%81%EF%BC%9A0xfffffff%20max_cycles%3A%200xfffffff%EF%BC%8Cmax_idle_ns%EF%BC%9A115833966437%20ns%20%5B0.000022%5D%20sched_clock%EF%BC%9A16%20MHz%20%E6%97%B6%E4%B8%BA%2032%20%E4%BD%8D%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87%2060ns%EF%BC%8C%E6%AF%8F%20130150523873ns%20%E5%8C%85%E8%A3%B9%E4%B8%80%E6%AC%A1%20%3CBR%20%2F%3E%20%5B0.000048%5D%20%E5%88%87%E6%8D%A2%E5%88%B0%E5%9F%BA%E4%BA%8E%E8%AE%A1%E6%97%B6%E5%99%A8%E7%9A%84%E5%BB%B6%E8%BF%9F%E5%9B%9E%E8%B7%AF%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87%2060ns%20%3CBR%20%2F%3E%20%5B0.027983%5D%20%E6%97%B6%E9%92%9F%E6%9D%A5%E6%BA%90%EF%BC%9Apit%EF%BC%9A%E6%8E%A9%E7%A0%81%EF%BC%9A0xfffff%20max_cycles%EF%BC%9A0xfffff%20max_cycles%EF%BC%9A0xfffff%20max_cycles%EF%BC%9A0xfffff%EF%BC%8Cmax_idle_ns%EF%BC%9A14479245754%20ns%20%5B0.028414%5D%20%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%BD%A9%E8%89%B2%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E8%99%9A%E6%8B%9F%E8%AE%BE%E5%A4%87%2080x30%20%3CBR%20%2F%3E%20%5B0.028472%5D%20%E6%A0%A1%E5%87%86%E5%BB%B6%E8%BF%9F%E5%9B%9E%E8%B7%AF%EF%BC%88%E5%B7%B2%E8%B7%B3%E8%BF%87%EF%BC%89%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%AE%A1%E6%97%B6%E5%99%A8%E9%A2%91%E7%8E%87%E8%AE%A1%E7%AE%97%E5%BE%97%E5%87%BA%E7%9A%84%E5%80%BC...%2033.00%20bogoMips%20(lpj%3D165000)%20%3CBR%20%2F%3E%20%5B0.028501%5D%20pid_max%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%9A32768%20%E6%9C%80%E5%B0%8F%E5%80%BC%EF%BC%9A301%20%5B0.028689%5D%20%E6%8C%82%E8%BD%BD%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3E%5B0.028718%5D%20Mountpoint-Cache%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.029699%5D%20CPU%EF%BC%9A%E6%B5%8B%E8%AF%95%E5%86%99%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%80%E8%87%B4%E6%80%A7%EF%BC%9Aok%20%3CBR%20%2F%3E%20%5B0.028718%5D%20Mountpoint-Cache%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.029699%5D%20CPU%EF%BC%9A%E6%AD%A3%E5%9C%A8%E6%B5%8B%E8%AF%95%E5%86%99%E5%85%A5%5B%2030370%5D%20%E4%B8%BA%200x20008200-0x20008258%20%3CBR%20%2F%3E%20%5B0.051134%5D%20VFP%20%E6%94%AF%E6%8C%81%20v0.3%20%E8%AE%BE%E7%BD%AE%E9%9D%99%E6%80%81%E8%BA%AB%E4%BB%BD%E6%98%A0%E5%B0%84%EF%BC%9A%E5%AE%9E%E7%8E%B0%E8%80%85%2041%20%E6%9E%B6%E6%9E%84%202%20%E7%AC%AC%2030%20%E9%83%A8%E5%88%86%E5%8F%98%E4%BD%93%205%20%E4%BF%AE%E8%AE%A2%E7%89%88%201%20%3CBR%20%2F%3E%20%5B0.051225%5D%20%5Bdri_chk_init%20(241)%5D%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%E7%A1%AE%E5%AE%9A%20%5B0.051855%5D%20%E6%97%B6%E9%92%9F%E6%9D%A5%E6%BA%90%EF%BC%9Ajiffies%EF%BC%9A%E6%8E%A9%E7%A0%81%EF%BC%9A0xfffffff%20max%20%3CBR%20%2F%3E%20_%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E5%91%A8%E6%9C%9F%EF%BC%9A0xfffffff%EF%BC%8Cmax_idle_ns%EF%BC%9A19112604462750000%20ns%20%5B0.053706%5D%20pinctrl%20%E6%A0%B8%E5%BF%83%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%20pinctrl%20%E5%AD%90%E7%B3%BB%E7%BB%9F%20%3CBR%20%2F%3E%20%5B0.055024%5D%20unidebug_init%EF%BC%9Aabort_log_paddr%EF%BC%9A0xc07bf0-%26gt%3B%200xc8020000%EF%BC%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A0x10000%20%3CBR%20%2F%3E%20%5B0.055056%5D%20%E4%B8%AD%E6%AD%A2%E6%97%A5%E5%BF%97%E7%BC%93%E5%86%B2%E5%8C%BA%E5%9C%B0%E5%9D%80%EF%BC%9A0xc8020000%EF%BC%8C%E5%A4%B4%EF%BC%9A0%EF%BC%8C%E5%B0%BE%E9%83%A8%EF%BC%9A0%20%5B0.055102%5D%20unidebug_init%EF%BC%9Arealtime_log_paddr%EF%BC%9A0xc0c07bf8-%26gt%3B%200xc8040000%EF%BC%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A0x30000%20%5B0.055125%5D%20%E5%AE%9E%E6%97%B6%E6%97%A5%E5%BF%97%E7%BC%93%E5%86%B2%E5%8C%BA%E5%9C%B0%E5%9D%80%EF%BC%9A0xc8040000%EF%BC%8C%E5%A4%B4%EF%BC%9A0%EF%BC%8C%E5%B0%BE%E9%83%A8%EF%BC%9A751%EF%BC%8C%E5%BD%93%E5%89%8D%E6%B6%88%E6%81%AF%E5%A4%A7%E5%B0%8F%EF%BC%9A751%20%3CBR%20%2F%3E%20%5B0.055448%5D%20dt_uni_dbg_%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E6%A0%87%E5%BF%97%EF%BC%9Auni_dbg_flag%20addr%3A%20value-%26gt%3B%200xc8010f00%EF%BC%9A0x55d454d4%20%5B0.056903%5D%20NET%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%97%2016%20%5B0.061074%5D%20DMA%EF%BC%9A%E4%B8%BA%E5%8E%9F%E5%AD%90%E7%9B%B8%E5%B9%B2%E5%88%86%E9%85%8D%E9%A2%84%E5%88%86%E9%85%8D%E7%9A%84%20256%20KiB%20%E6%B1%A0%20%3CBR%20%2F%3E%20%5B0.061161%5D%20%5Buni_register_pm_check_unit%20(119)%5D%EF%BC%9A%E6%B3%A8%E5%86%8C%E4%B8%BB%E5%87%BD%E6%95%B0%EF%BC%9A%3CBR%20%2F%3E%5Bpm-driver-self-check-check_unit%20(119)%5D%5D%EF%BC%8Cfun%20%3D%200xc0043044%20%5B0.063487%5D%20AT91%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%E7%9A%84%20SoC%20%E7%B3%BB%E5%88%97%EF%BC%9Asama5d3%20%3CBR%20%2F%3E%20%5B0.063517%5D%20AT91%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%E7%9A%84%20SoC%EF%BC%9Asama5d31%EF%BC%8C%E4%BF%AE%E8%AE%A2%E7%89%88%203%20%5B0.078086%5D%20irq%EF%BC%9A%E6%89%BE%E4%B8%8D%E5%88%B0%20%2Fahb%2Fapb%2Fpinctrl%20%40fffff200%20%2Fgpio%20%40fffffa00%20%E7%9A%84%20irq%20%E5%8A%9F%E8%83%BD%E5%9F%9F%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%5B0.089307%5D%20gpio-at91%20fffff200.gpio%EF%BC%9A%E5%9C%B0%E5%9D%80%E4%B8%BA%20c8018200%3CBR%20%2F%3E%5B%200.090542%5D%20gpio-at91%20fffff400.gpio%EF%BC%9A%E5%9C%B0%E5%9D%80%E4%B8%BA%20c801a400%3CBR%20%2F%3E%5B%200.091861%5D%20gpio-at91%20fffff600.gpio%EF%BC%9A%E5%9C%B0%E5%9D%80%E4%B8%BA%20c801c600%3CBR%20%2F%3E%5B%200.093208%5D%20gpio-at91%20fffff800.gpio%EF%BC%9A%E5%9C%B0%E5%9D%80%E4%B8%BA%20c801e800%3CBR%20%2F%3E%5B%200.094664%5D%20gpio-at91%20fffffa00.gpio%EF%BC%9A%E5%9C%B0%E5%9D%80%E4%B8%BA%20c8032a00%3CBR%20%2F%3E%5B%200.096164%5D%20pinctrl-at91%20ahb%3Aapb%3Apinctrl%40fffff200%3A%20%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20AT91%20pinctrl%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%200.097460%5D%20%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%EF%BC%9Abr03_v01p01d_wifi_bt_UTA2_0326%3CBR%20%2F%3E%5B%200.097489%5D%20%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9Abr03%3CBR%20%2F%3E%5B%200.097504%5D%20%E8%8A%82%E7%82%B9%E5%90%8D%E7%A7%B0%EF%BC%9A%E5%90%AF%E5%8A%A8paras%3CBR%20%2F%3E%5B%200.097544%5D%20%E5%90%AF%E5%8A%A8_mode%200x27ffff80%20%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%A0%E5%B0%84%E5%88%B0%20c8034f80%3CBR%20%2F%3E%5B%200.097567%5D%20RESET_reason%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%A0%E5%B0%84%E5%88%B0%20c8036fc0%3CBR%20%2F%3E%5B%200.098054%5D%20%E6%9D%A5%E8%87%AA%20%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%20%E7%9A%84%20RESET%20%E5%8E%9F%E5%9B%A0%EF%BC%9A0x17554444%3CBR%20%2F%3E%5B%200.098074%5D%20%E8%AE%BE%E5%A4%87%E5%BC%80%E5%A7%8B%E5%8A%A0%E7%94%B5%EF%BC%81%3CBR%20%2F%3E%5B%200.098087%5D%20RESET%20%E5%8E%9F%E5%9B%A0%EF%BC%9APOWR%3CBR%20%2F%3E%5B%200.098099%5D%20%E5%86%99%E5%85%A5%20RESET%20%E5%8E%9F%E5%9B%A0%EF%BC%9A0x53525748%3CBR%20%2F%3E%5B%200.098110%5D%20%E8%AF%BB%E5%8F%96%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%EF%BC%9A0x55554451%3CBR%20%2F%3E%5B%200.098126%5D%20%E8%AF%BB%E5%8F%96%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%EF%BC%9A0xffffffff%20--%26gt%3B%20%E5%9C%A8%20%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%20%E4%B8%AD%E9%9A%8F%E6%9C%BA%3CBR%20%2F%3E%5B%200.098464%5D%20sysclk%20ctrl%20io%3A%2021%3CBR%20%2F%3E%5B%200.098556%5D%20%E7%B4%A2%E5%BC%95%EF%BC%9A0%3CBR%20%2F%3E%5B%200.098606%5D%20cnt%3A%200%3CBR%20%2F%3E%5B%200.098910%5D%20%E5%90%AF%E5%8A%A8paras%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A2%E6%B5%8B%E5%99%A8%20%5B%E7%A1%AE%E5%AE%9A%5D%3CBR%20%2F%3E%5B%200.159347%5D%20at_hdmac%20ffffe600.dma-controller%3A%20Atmel%20AHB%20DMA%20%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%88cpy%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%BB%8E%20sg-cpy%EF%BC%89%EF%BC%8C8%20%E4%B8%AA%E9%80%9A%E9%81%93%3CBR%20%2F%3E%5B%200.161569%5D%20at_hdmac%20ffffe800.dma-controller%EF%BC%9AAtmel%20AHB%20DMA%20%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%88cpy%20%E8%AE%BE%E7%BD%AE%E4%BB%8E%E6%9C%BA%20sg-cpy%EF%BC%89%EF%BC%8C8%20%E4%B8%AA%E9%80%9A%E9%81%93%20%3CBR%20%2F%3E%20%5B0.165426%5D%20usbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E4%BA%86%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usbfs%20%5B0.165610%5D%20usbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E4%BA%86%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9B%86%E7%BA%BF%E5%99%A8%20%3CBR%20%2F%3E%20%5B0.165780%5D%20usbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E4%BA%86%E6%96%B0%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb%20%5B0.166087%5D%20I2C%20FPGA%20KEYPAD%20INIT%20%5B0%3B%2040%3B%2032m%20%3CBR%20%2F%3E%20%5BOK%5D%20%5B0m%5D%200.166215%5D%20I2C%20FPGA%20GPI%20%E5%88%9D%E5%A7%8B%E5%8C%96%20%5B%E7%A1%AE%E5%AE%9A%5D%20%3CBR%20%2F%3E%20%5B0.167819%5D%20at91_i2c%20f0014000.i2c%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3EAT91%20i2c%20%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9A0x402%EF%BC%89%E3%80%82%3CBR%20%2F%3E%5B%200.169063%5D%20I2C%20FPGA%20GPI%20Probe%2Caddr%3A0x70%20%5BOK%5D%3CBR%20%2F%3E%5B%200.169439%5D%20%26lt%3B5%26gt%3Bfpga_keypad_probe(168)%3A%20I2C%20FPGA%20KEYPAD%20i2c%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E5%9C%B0%E5%9D%80%EF%BC%9A0x72%3CBR%20%2F%3E%5B%200.169477%5D%20I2C%20FPGA%20KEYPAD%20Probe%20%26%2327%3B%5B0%3B40%3B32m%5B%20OK%20%5D%26%2327%3B%5B0m%3CBR%20%2F%3E%5B%200.183675%5D%20gpio-ice40lp1k%20probe%20%5BOK%5D%3CBR%20%2F%3E%5B%200.184153%5D%20mcu-%E5%90%AF%E5%8A%A8-ctrl-pin%20196%20init%201%20ok%3CBR%20%2F%3E%5B%200.184285%5D%20at91_i2c%20f0018000.i2c%3AAT91%20i2c%20%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9A0x402%EF%BC%89%E3%80%82%3CBR%20%2F%3E%5B%200.185739%5D%20%E9%AB%98%E7%BA%A7%20Linux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net%2Fwireless%2Freg.c%3A%20523%20regulatory_init%2B0x84%2F0x128%20()%20%3CBR%20%2F%3E%20%5B0.187916%5D%20db.txt%20%E6%98%AF%E7%A9%BA%E7%9A%84%EF%BC%8C%E4%BD%A0%E5%BA%94%E8%AF%A5%E6%9B%B4%E6%96%B0%E5%AE%83...%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%5B0.187928%5D%20%E9%93%BE%E6%8E%A5%E7%9A%84%E6%A8%A1%E5%9D%97%EF%BC%9A%3CBR%20%2F%3E%5B0.187958%5D%20CPU%EF%BC%9A0%20PID%EF%BC%9A1%20Comm%EF%BC%9Aswapper%20%E6%9C%AA%E5%8F%97%E6%B1%A1%E6%9F%93%204.4.19%23226%3CBR%20%2F%3E%20%5B0.187973%5D%20%E7%A1%AC%E4%BB%B6%E5%90%8D%E7%A7%B0%EF%BC%9AAtmel%20SAMA5%3CBR%20%2F%3E%20%5B0.188039%5D%20%5B%5D%3CC001499C%3E%20(unwind_backtrace)%20%E6%9D%A5%E8%87%AA%3CC00125DC%3E%20%5B%5D%20(show_stack%2B0x10%2F0x14)%3CBR%20%2F%3E%20%5B0.188084%5D%20%5B%5D%3CC00125DC%3E%20(show_stack)%20%E6%9D%A5%E8%87%AA%3CC001FBD0%3E%20%5B%5D%20(warn_slowpath_commonn)%20%2B0x80%2F0xac)%3CBR%20%2F%3E%20%5B0.188120%5D%3CC001FBD0%3E%20%5B%5D%20(warn_slowpath_common)%20%E6%9D%A5%E8%87%AA%3CC001FC2C%3E%20%5B%5D%20(warn_slowpath_fmt%2B0x30%2F0x40)%3CBR%20%2F%3E%20%5B0.188153%5D%20%5B%5D%3CC001FC2C%3E%20(warn_slowpath_fmt)%20%E6%9D%A5%E8%87%AA%3CC06133C0%3E%20%5B%5D%20(regulatory_init%2B0x84%2F0xx%2B)%3CBR%20%2F%3E%20%5Bc001fc2c%5D%3CC06133C0%3E%20(warn_slowpath_fmt)%20(warn_slowpath_fmt)%3CC06132C4%3E%20128)%3CBR%20%2F%3E%20%5B0.188185%5D%20%5B%26lt%3B%3CC06132C4%3E%3CC000961C%3E%3CC000961C%3E%20%3CC05F3D80%3Ec06133c0%3CBR%20%2F%3E%20%3CC05F3D80%3E%3CC0479308%3E%3CBR%20%2F%3E%3CC0479308%3E%3CC000F3F8%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%26lt%3B5%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%26lt%3B5%26gt%3B%3CBR%20%2F%3E%26lt%3B5%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%26gt%3B%5D%3CBR%20%2F%3E%20(regulatory_init)%20%E6%9D%A5%E8%87%AA%20%5B%5D%20(cfg80211_init%2B0x54%2F0xcc)%20%5B0.188216%5D%20%5B%5D%20(cfg80211_init)%20%E6%9D%A5%E8%87%AA%20%5B%5D%20(do_one_initcall%2B0x90%2F0x1d8)%20%5B188260%5D%20%5B%5D%20(do_one_initcall)%20%E6%9D%A5%E8%87%AA%20%5B%5D%20(kernel_init_freeable%2B0x130%2F0x1d0)%20%5B0.188305%5D%20%5B%5D%20(kernel_init_freeable)%20%E6%9D%A5%E8%87%AA%20%5B%5D%20(kernel_init%2B0xe8)%20%5B0.188341%5D%20%5B%26lt%3B%20c0479308%5D%20(kernel_init%2B0xe8)%20%5B0.188341%5D%20%5Bc0479308%20%26gt%3B%5D%20(kernel_init)%20%E6%9D%A5%E8%87%AA%20%5B%5D%20(ret_from_fork%2B0x14%2F0x3c)%20%5B0.188400%5D---%5B%E7%BB%93%E6%9D%9F%E8%B7%9F%E8%B8%AA%20db6e7ed398e5acc9%5D---%5B%200.192800%5D%20%E6%97%B6%E9%92%9F%E6%BA%90%EF%BC%9A%E5%88%87%E6%8D%A2%E5%88%B0%E6%97%B6%E9%92%9F%E6%BA%90%E8%AE%A1%E6%97%B6%E5%99%A8%20%40f0010000%20%5B0.208795%5D%20NET%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%97%202%20%5B0.209929%5D%20TCP%20%E5%B7%B2%E5%BB%BA%E7%AB%8B%E7%9A%84%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.209988%5D%20TCP%20%E7%BB%91%E5%AE%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.210031%5D%20TCP%EF%BC%9A%E5%B7%B2%E9%85%8D%E7%BD%AE%E5%93%88%E5%B8%8C%E8%A1%A8%EF%BC%88%E5%B7%B2%E5%BB%BA%E7%AB%8B%201024%20%E7%BB%91%E5%AE%9A%201024%EF%BC%89%5B0.210207%5D%20UDP%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A256%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.210254%5D%20UDP-Lite%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A256%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.210579%5D%20NET%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%97%201%20%5B0.211421%5D%20%E8%BE%93%E5%85%A5%EF%BC%9A%E6%9C%AA%E6%8C%87%E5%AE%9A%20%E8%AE%BE%E5%A4%87%E4%BD%9C%E4%B8%BA%20%2Fdevices%2Fvirtual%2Finput%2Finput0%20%5B0.211463%5D%20si_key_probe%20(171)%EF%BC%9A%E5%AF%86%E9%92%A5%EF%BC%9A%E6%B3%A8%E5%86%8C%20sama5d3%20%E9%94%AE%E8%BE%93%E5%85%A5%E8%AE%BE%E5%A4%87%20%5B0.229580%5D%20SI%20%E6%A0%B8%E5%BF%83%E6%8E%A2%E6%B5%8B%E5%99%A8%20%5B0%3B%2040%3B%2032m%20%5B%E7%A1%AE%E5%AE%9A%5D%20%5B0%3B%2040%3B%2032m%20%5B%E7%A1%AE%E5%AE%9A%5D%20%5B0m%20%5B0.232200%5D%20parse_dt%20(569)%EF%BC%9Abt%20ref%20clk%20%E4%B8%8D%E6%98%AF%E6%9D%A5%E8%87%AA%20ref%20clk%20%E8%8A%82%E7%82%B9%20%5B0.232249%5D%20parse_dt%20(578)%EF%BC%9Abt%20clk%20%E4%B8%8D%E6%98%AF%E6%9D%A5%E8%87%AA%20bt%20clk%20%E8%8A%82%E7%82%B9%20%5B0.232400%5D%20bt%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A2%E6%B5%8B%E5%99%A8%20%5B0%3B%2040%3B%2032m%20%5B%E7%A1%AE%E5%AE%9A%5D%20%5B0m%20%5B0.234678%5D%20futex%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A256%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A-1%EF%BC%8C3072%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.261119%5D%20ntfs%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%202.1.32%5BFlags%3A%20R%2FW%5D.%3CBR%20%2F%3E%5B%200.271996%5D%20%E6%B3%A8%E5%86%8C%E4%BA%86%E9%9D%9E%E5%AF%B9%E7%A7%B0%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8B%3CBR%20%2F%3E%5B%200.272046%5D%20%E6%B3%A8%E5%86%8C%E4%BA%86%E9%9D%9E%E5%AF%B9%E7%A7%B0%E5%AF%86%E9%92%A5%E8%A7%A3%E6%9E%90%E5%99%A8%20%22x509%22%3CBR%20%2F%3E%5B%200.272142%5D%20%E6%B3%A8%E5%86%8C%E4%BA%86%20io%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20noop%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3CBR%20%2F%3E%5B%200.275288%5D%20f001c000.serial%EF%BC%9AttyS1%20%E5%9C%A8%20MMIO%200xf001c000%EF%BC%88irq%20%3D%2032%EF%BC%8Cbase_baud%20%3D%204125000%EF%BC%89%E6%98%AF%E4%B8%80%E4%B8%AA%20ATMEL_SERIAL%3CBR%20%2F%3E%5B%200.276372%5D%20f8024000.serial%EF%BC%9A%E5%9C%A8%20MMIO%200xf8024000%EF%BC%88irq%20%3D%2034%EF%BC%8Cbase_baud%20%3D%204125000%EF%BC%89%E5%A4%84%E7%9A%84%20ttys4%20%E6%98%AF%20ATMEL_SERIAL%20%5B0.278040%5D%20aquire%20gpis%20%E5%90%AF%E5%8A%A8%20gpio%20%E5%AF%86%E7%A0%81%E9%94%99%E8%AF%AF%EF%BC%8C%E4%B8%8D%E8%A6%81%E7%94%A8%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%5B%200.278239%5D%20kfifo%3A%20size%20%3D1024%2C%20recsize%3D0%2C%20esize%3D1%2C%20inited%3D1023%3CBR%20%2F%3E%5B%200.278268%5D%20sama5d3-gps%20gps%3A%20gps%20init%20ok%3CBR%20%2F%3E%5B%200.279091%5D%26lt%3B3%26gt%3Bacc_init_ctl_io(987)%EF%BC%9A%E8%8E%B7%E5%8F%96%20io0_sel%20gpio%20%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%5B%200.279141%5D%26lt%3B3%26gt%3Bacc_init_ctl_io(994)%EF%BC%9AFailed%20to%20get%20io1_sel%20gpio%3CBR%20%2F%3E%5B%200.279497%5D%20uni-acc%20uni_acc0%3A%20acc0%20init%20ok%3CBR%20%2F%3E%5B%200.289728%5D%20brd%3A%20module%20loaded%3CBR%20%2F%3E%5B%200.300025%5D%20loop%3A%20module%20loaded%3CBR%20%2F%3E%5B%200.300727%5D%20ssc%20f0008000.ssc.0%EF%BC%9A%E4%BD%8D%E4%BA%8E%200xc80d8000%20(irq%2029)%20%5B0.301156%5D%20%E7%9A%84%20Atmel%20SSC%20%E8%AE%BE%E5%A4%87%20ssc%20f800c000.ssc.1%EF%BC%9A%3CBR%20%2F%3E%E4%BD%8D%E4%BA%8E%200xc80e0000%20(irq%2033)%20%3CBR%20%2F%3E%20%5B0.302061%5D%20%E7%9A%84%20Atmel%20SSC%20%E8%AE%BE%E5%A4%87%E4%BD%8D%E4%BA%8E%2024%200-0050%EF%BC%9A512%20%E5%AD%97%E8%8A%82%2024c04%20EEPROM%EF%BC%8C%E5%8F%AF%E5%86%99%EF%BC%8C16%20%E5%AD%97%E8%8A%82%2F%E5%86%99%E5%85%A5%20%5B0.306971%5D%20atmel_nand_nfc%2070000000.nfc%EF%BC%9A%3CBR%20%2F%3E%E5%AF%B9%20NFC%20%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%8E%A2%E6%B5%8B%E3%80%82%3CBR%20%2F%3E%5B0.307215%5D%20atmel_%E4%B8%8E%E9%9D%9E%2060000000.%E4%B8%8E%E9%9D%9E%EF%BC%9A%E5%9C%A8%20Flash%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20BBT%20%3CBR%20%2F%3E%20%5B0.308380%5D%20atmel_%E4%B8%8E%E9%9D%9E%2060000000.%E4%B8%8E%E9%9D%9E%EF%BC%9A%E4%BD%BF%E7%94%A8%20dma0chan0%20%E8%BF%9B%E8%A1%8C%20DMA%20%E4%BC%A0%E8%BE%93%E3%80%82%3CBR%20%2F%3E%5B%200.309744%5D%20%E4%B8%8E%E9%9D%9E%3A%20%E5%B7%B2%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%88%B6%E9%80%A0%E5%95%86%20ID%EF%BC%9A0x2c%EF%BC%8C%E8%8A%AF%E7%89%87%20ID%EF%BC%9A0xa3%3CBR%20%2F%3E%5B%200.309772%5D%20%E4%B8%8E%E9%9D%9E%3A%20%E7%BE%8E%E5%85%89%20MT29F8G08ABBCAH4%3CBR%20%2F%3E%5B%200.309794%5D%20%E4%B8%8E%E9%9D%9E%3A%201024%20MiB%EF%BC%8CSLC%EF%BC%8C%E6%93%A6%E9%99%A4%E5%A4%A7%E5%B0%8F%EF%BC%9A256%20KiB%EF%BC%8C%E9%A1%B5%E9%9D%A2%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%EF%BC%8COOB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A224%3CBR%20%2F%3E%5B%200.309826%5D%20atmel_%E4%B8%8E%E9%9D%9E%2060000000.%E4%B8%8E%E9%9D%9E%EF%BC%9A%E6%9C%80%E4%BD%8E%20ECC%EF%BC%9A512%20%E5%AD%97%E8%8A%82%E5%86%85%E6%9C%89%208%20%E4%BD%8D%20%3CBR%20%2F%3E%20%5B0.309850%5D%20atmel_%E4%B8%8E%E9%9D%9E%2060000000.%E4%B8%8E%E9%9D%9E%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%20PMECC%20%E5%8F%82%E6%95%B0%EF%BC%8C%E4%B8%8A%E9%99%90%EF%BC%9A12%EF%BC%8C%E6%89%87%E5%8C%BA%EF%BC%9A512%20%3CBR%20%2F%3E%20%5B0.309956%5D%20atmel_%E4%B8%8E%E9%9D%9E%2060000000.%E4%B8%8E%E9%9D%9E%EF%BC%9A%E4%BD%BF%E7%94%A8%20NFC%20Sram%20%E8%AF%BB%E5%8F%96%3CBR%20%2F%3E%20%5B0.311307%5D%20%E5%9C%A8%20262080%3CBR%20%2F%3E%20%E9%A1%B5%E6%89%BE%E5%88%B0%E7%9A%84%E9%94%99%E8%AF%AF%E5%8C%BA%E5%9D%97%E8%A1%A8%EF%BC%8C%E7%89%88%E6%9C%AC%200x01%20%5B0.312151%5D%20%E5%9C%A8%20262016%3CBR%20%2F%3E%20%E9%A1%B5%E6%89%BE%E5%88%B0%E7%9A%84%E9%94%99%E8%AF%AF%E5%8C%BA%E5%9D%97%E8%A1%A8%EF%BC%8C%E7%89%88%E6%9C%AC%200x01%20%5B0.312999%5D%20%E5%9C%A8%20MTD%3CBR%20%2F%3E%20%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%89%BE%E5%88%B0%204%20%E4%B8%AA%E5%88%86%E5%8C%BA%20atmel_nand%20%5B0.313028%5D%20%E5%9C%A8%20%22%20atmel_nand%20%22%3A%20%5B0.313059%5D%200x000000000000-0x0000000%E4%B8%8A%E5%88%9B%E5%BB%BA%204%20%E4%B8%AA%20MTD%20%E5%88%86%E5%8C%BA%3CBR%20%2F%3E%2040000%EF%BC%9A%22%20iplp1%20%22%3CBR%20%2F%3E%20%5B0.313770%5D%200x000000040000-0x000001080000%EF%BC%9A%20%22%20minisys%20%22%3CBR%20%2F%3E%20%5B0.314417%5D%200x000001080000-0x000002480000%EF%BC%9A%22%20workbin%20%22%3CBR%20%2F%3E%20%5B0.315035%5D%200x000002480000-0x0000000000-0x00000000000%EF%BC%9A%22%20user-fs%20%22%3CBR%20%2F%3E%20%5B0.317794%5D%26lt%3B3%26gt%3B%20dsp_output_probe%20(348)%EF%BC%9A%E5%AF%84%E5%AD%98%E5%99%A8%20dsp%20%E8%BE%93%E5%87%BA0%3CBR%20%2F%3E%20%5B0.317885%5D%20dsp%20%E8%BE%93%E5%87%BA%20dsp-output0%3A%20dsp_output%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A2%E6%B5%8B%E5%99%A8%3CBR%20%2F%3E%20%5B0.318003%5D%26lt%3B3%26gt%3B%20dsp_output_probe%20(354)%EF%BC%9A%E5%AF%84%E5%AD%98%E5%99%A8%20dsp%20%E8%BE%93%E5%87%BA%201%3CBR%20%2F%3E%20%5B0.318070%5D%20dsp%20%E8%BE%93%E5%87%BA%20dsp%20%E8%BE%93%E5%87%BA%201%EF%BC%9Adsp_output%20%E9%A9%B1%E5%8A%A8%E5%99%A8%E6%8E%A2%E5%A4%B4%3CBR%20%2F%3E%20%5B0.318552%5D%26lt%3B3%26gt%3B%20dsp_input_probe%20(334)%EF%BC%9A%E5%AF%84%E5%AD%98%E5%99%A8%20dsp%20%E8%BE%93%E5%85%A5%200%EF%BC%8Cret%3D0%3CBR%20%2F%3E%20%5B0.318652%5D%20dsp-input%20dsp-input0%EF%BC%9Adsp_input%20%E9%A9%B1%E5%8A%A8%E5%99%A8%E6%8E%A2%E5%A4%B4%3CBR%20%2F%3E%20%5B0.318772%5D%26lt%3B3%26gt%3B%20dsp_input_probe%20(340)%EF%BC%9A%E5%AF%84%E5%AD%98%E5%99%A8%20dsp%20%E8%BE%93%E5%85%A5%201%EF%BC%8Cret%3D0%3CBR%20%2F%3E%20%5B0.318839%5D%20dsp-input%20dsp-input%20dsp-input1%EF%BC%9A%20dsp_input%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A2%E6%B5%8B%E5%99%A8%3CBR%20%2F%3E%20%5B0.320816%5D%20atmel_spi%20f8008000.spi%EF%BC%9A%E7%89%88%E6%9C%AC%EF%BC%9A0x213%3CBR%20%2F%3E%5B%200.321306%5D%20atmel_spi%20f8008000.spi%EF%BC%9A%E4%BD%BF%E7%94%A8%20dma1chan0%EF%BC%88tx%EF%BC%89%E5%92%8C%20dma1chan1%EF%BC%88rx%EF%BC%89%E8%BF%9B%E8%A1%8C%20DMA%20%E4%BC%A0%E8%BE%93%3CBR%20%2F%3E%5B%200.321433%5D%20atmel-spi%20%E5%AF%84%E5%AD%98%E5%99%A8%20pio-irq%EF%BC%8Cret%20%3D%200%3CBR%20%2F%3E%5B%200.321481%5D%20atmel_spi%20f8008000.spi%EF%BC%9AAtmel%20SPI%20%E6%8E%A7%E5%88%B6%E5%99%A8%E5%9C%A8%200xf8008000%20(irq%2027)%3CBR%20%2F%3E%5B%200.324620%5D%20spi_master%20spi32766%EF%BC%9A%E5%B0%86%E4%BB%A5%E5%AE%9E%E6%97%B6%E4%BC%98%E5%85%88%E7%BA%A7%E8%BF%90%E8%A1%8C%E6%B6%88%E6%81%AF%E6%B3%B5%3CBR%20%2F%3E%5B%200.325692%5D%26lt%3B3%26gt%3Bdsp_spi_probe(2295)%3A%20spi%20%E5%90%8D%E4%B8%BA%20br03-dsp-spi1%20%E6%AD%A3%E5%9C%A8%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3E%5B%200.325746%5D%26lt%3B3%26gt%3Bdsp_spi_probe(2304)%3A%20malloc%20607%20size%20of%20dsp%20driver%2C%20spidev%20%3D%200xc6969c00%2C%20spi%20%3D%200xc6969800%2C%20maste%26lt%3B3%26gt%3Bdsp_spi_probe(2334)%3A%20register%20dsp%20master1%3CBR%20%2F%3E%5B%200.325823%5D%20dspmaster%20spi32766.0%EF%BC%9Adsp%20spi%20probe%20speed(3000000)%20dev%200x0f800001%3CBR%20%2F%3E%5B%201.127630%5D%20%5Buni_register_pm_check_unit(153)%5D%3A%20%E5%AF%84%E5%AD%98%E5%99%A8%20DSP1-INT%2C%20func%20%3D%200xc0254700%3CBR%20%2F%3E%5B%201.128522%5D%20m25p80%20spi32766.1%EF%BC%9Am25p10-nonjedec%20(128%20Kbytes)%3CBR%20%2F%3E%5B%201.130820%5D%20atmel_spi%20f0004000.spi%EF%BC%9A%E7%89%88%E6%9C%AC%EF%BC%9A0x213%3CBR%20%2F%3E%5B%201.131300%5D%20atmel_spi%20f0004000.spi%EF%BC%9A%E4%BD%BF%E7%94%A8%20dma0chan1%EF%BC%88tx%EF%BC%89%E5%92%8C%20dma0chan2%EF%BC%88rx%EF%BC%89%E8%BF%9B%E8%A1%8C%20DMA%20%E4%BC%A0%E8%BE%93%3CBR%20%2F%3E%5B%201.131396%5D%20atmel-spi%20%E5%AF%84%E5%AD%98%E5%99%A8%20pio-irq%EF%BC%8Cret%20%3D%200%3CBR%20%2F%3E%5B%201.131441%5D%20atmel_spi%20f0004000.spi%EF%BC%9AAtmel%20SPI%20Controller%20at%200xf0004000%20(irq%2028)%3CBR%20%2F%3E%5B%201.132565%5D%20spi_master%20spi32765%3A%20%E5%B0%86%E4%BB%A5%E5%AE%9E%E6%97%B6%E4%BC%98%E5%85%88%E7%BA%A7%E8%BF%90%E8%A1%8C%E6%B6%88%E6%81%AF%E6%B3%B5%3CBR%20%2F%3E%5B%201.133707%5D%26lt%3B3%26gt%3Bdsp_spi_probe(2295)%3A%20spi%20named%20br03-dsp-spi0%20probing%3CBR%20%2F%3E%5B%201.133760%5D%26lt%3B3%26gt%3Bdsp_spi_probe(2304)%3A%20malloc%20607%20size%20of%20dsp%20driver%2C%20spidev%20%3D%200xc6a05000%2C%20spi%20%3D%200xc6a04c00%2C%20maste%26lt%3B3%26gt%3Bdsp_spi_probe(2326)%3A%20register%20dsp%20master0%3CBR%20%2F%3E%5B%201.133836%5D%20dspmaster%20spi32765.0%EF%BC%9Adsp%20spi%20probe%20speed(3000000)%20dev%200x0f800000%3CBR%20%2F%3E%5B%201.134065%5D%26lt%3B5%26gt%3Bdsp_hw_init(1705)%3A%20can't%20find%20pwr-gpio%20in%20dts%3CBR%20%2F%3E%5B%201.134099%5D%26lt%3B5%26gt%3Bdsp_hw_init(1705)%3A%20can't%20find%20rf_6V_pwr_en-gpio%20in%20dts%3CBR%20%2F%3E%5B%201.134130%5D%26lt%3B5%26gt%3Bdsp_hw_init(1705)%3A%20can't%20find%20fpga_reset-gpio%20in%20dts%3CBR%20%2F%3E%5B%201.134157%5D%26lt%3B5%26gt%3Bdsp_hw_init(1705)%3A%20can%20not%20find%20dsp_switch_ctl_A%20in%20dts%3CBR%20%2F%3E%5B%201.134184%5D%26lt%3B5%26gt%3Bdsp_hw_init(1705)%3A%20can%20not%20find%20dsp_switch_ctl_B%20in%20dts%3CBR%20%2F%3E%5B%201.134211%5D%26lt%3B5%26gt%3Bdsp_hw_init(1705)%3A%20can%20not%20find%20dsp_fpga_done%20in%20dts%3CBR%20%2F%3E%5B%201.135118%5D%26lt%3B5%26gt%3Bdsp_fault_save_timestamp(1541)%3A%20dspmaster%5B0%5D%20dsp_fault_save_timestamp%3CBR%20%2F%3E%5B%201.135390%5D%26lt%3B3%26gt%3Bhost_ctl_rf_power(350)%3A%20dspmaster%5B0%5D%20cannot%20ctl%20pwr%20io%3CBR%20%2F%3E%5B%201.935625%5D%26lt%3B3%26gt%3Bhost_ctl_rf_power(350)%3A%20dspmaster%5B0%5D%20cannot%20ctl%20pwr%20io%3CBR%20%2F%3E%5B%201.935669%5D%20%5Buni_register_pm_check_unit(153)%5D%3A%20register%20DSP0-INT%2C%20func%20%3D%200xc0254700%3CBR%20%2F%3E%5B%201.936358%5D%20usbcore%3A%20registered%20new%20interface%20driver%20asix%3CBR%20%2F%3E%5B%201.936535%5D%20usbcore%3A%20registered%20new%20interface%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20ax88179_178a%3CBR%20%2F%3E%5B%201.936693%5D%20usbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20cdc_ether%3CBR%20%2F%3E%5B%201.936844%5D%20usbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20net1080%3CBR%20%2F%3E%5B%201.936996%5D%20usbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E6%96%B0%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20rndis_host%3CBR%20%2F%3E%5B%201.937143%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_subset%3CBR%20%2F%3E%5B%201.937291%5D%20usbcore%3A%20registered%20new%20interface%20driver%20zaurus%3CBR%20%2F%3E%5B%201.937549%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_ncm%3CBR%20%2F%3E%5B%201.937585%5D%20ehci_hcd%EF%BC%9AUSB%202.0%20'Enhanced'%20Host%20Controller%20(EHCI)%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%201.937614%5D%20ehci-atmel%EF%BC%9AEHCI%20Atmel%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%201.938029%5D%20ohci_hcd%EF%BC%9AUSB%201.1%20'Open'%20Host%20Controller%20(OHCI)%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%201.938067%5D%20ohci-atmel%EF%BC%9AOHCI%20Atmel%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%201.938829%5D%20at91_ohci%20600000.ohci%EF%BC%9AUSB%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%3CBR%20%2F%3E%5B%201.938918%5D%20at91_ohci%20600000.ohci%EF%BC%9A%E6%96%B0%20USB%20%E6%80%BB%E7%BA%BF%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%8C%E5%88%86%E9%85%8D%E7%9A%84%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%E4%B8%BA%201%20%3CBR%20%2F%3E%20%5B1.939060%5D%20%26lt%3B3%26gt%3B%20host_timer_enable%20(1109)%EF%BC%9Adspmaster%20%5B0%5D%20%E7%A6%81%E7%94%A8%E4%B8%BB%E6%9C%BA%E8%AE%A1%E6%97%B6%E5%99%A8%20%5B1.940111%5D%20at91_ohci%20600000.ohci%EF%BC%9A%3CBR%20%2F%3Eirq%2047%2C%20io%20mem%200x00600000%3CBR%20%2F%3E%5B%201.998637%5D%20hub%201-0%3A1.0%EF%BC%9A%E5%8F%91%E7%8E%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%3CBR%20%2F%3E%5B%201.998899%5D%20%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%3A%20%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3E%5B%202.001020%5D%20atmel_usba_udc%20500000.gadget%EF%BC%9A%E4%BD%8D%E4%BA%8E%200xf8030000%20%E7%9A%84%20MMIO%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%A0%E5%B0%84%E5%88%B0%20c80e8000%3CBR%20%2F%3E%5B%202.001125%5D%20atmel_usba_udc%20500000.gadget%EF%BC%9AFIFO%20%E5%9C%A8%200x00500000%20%E6%98%A0%E5%B0%84%E5%88%B0%20c8600000%3CBR%20%2F%3E%5B%202.003751%5D%20%E4%BD%BF%E7%94%A8%E9%9A%8F%E6%9C%BA%E8%87%AA%E8%BA%AB%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%9C%B0%E5%9D%80%3CBR%20%2F%3E%5B%202.003796%5D%20%E4%BD%BF%E7%94%A8%E9%9A%8F%E6%9C%BA%E4%B8%BB%E6%9C%BA%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%9C%B0%E5%9D%80%3CBR%20%2F%3E%5B%202.003829%5D%20%E4%BD%BF%E7%94%A8%E4%B8%BB%E6%9C%BA%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%9C%B0%E5%9D%80%EF%BC%9Abe%3A6e%3A3b%3A3e%3A6f%3A6b%3CBR%20%2F%3E%5B%202.003847%5D%20%E4%BD%BF%E7%94%A8%E8%87%AA%E8%BA%AB%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%9C%B0%E5%9D%80%EF%BC%9A12%3A56%3A59%3A21%3A22%3A05%26lt%3B6%26gt%3B%5B%202.005248%5D%20usb0%3A%20HOST%20MAC%20be%3A6e%3A3b%3A3e%3A6f%3A6b%3CBR%20%2F%3E%5B%202.005345%5D%20usb0%3A%20MAC%2012%3A56%3A59%3A21%3A22%3A05%3CBR%20%2F%3E%5B%202.005441%5D%20g_multi%20gadget%EF%BC%9A%E5%A4%9A%E5%8A%9F%E8%83%BD%E5%A4%8D%E5%90%88%E5%B0%8F%E5%B7%A5%E5%85%B7%3CBR%20%2F%3E%5B%202.005464%5D%20g_multi%20gadget%3A%20userpace%20failed%20to%20provide%20iSerialNumber%3CBR%20%2F%3E%5B%202.005480%5D%20g_multi%20gadget%3A%20g_multi%20ready%3CBR%20%2F%3E%5B%202.010574%5D%26lt%3B5%26gt%3Bfpga_keypad_probe(529)%3A%20fpga%20keypad%20gpio%20(status)%EF%BC%9A158%20(1)%2C%20virq%3A%20207%3CBR%20%2F%3E%5B%202.010697%5D%20%5Buni_register_pm_check_unit(153)%5D%3A%20register%20keypad%2C%20func%20%3D%200xc02b8794%3CBR%20%2F%3E%5B%202.011893%5D%26lt%3B5%26gt%3Bfpga_keypad_probe(568)%3A%20pck1%20rate%20%3D%2024000000%2C%20is_enable%20%3D%200%3CBR%20%2F%3E%5B%202.011978%5D%20fpga%20keypad%20driver%20probe%20%5B0%3B40%3B32m%5B%20OK%20%5D%5B0m%3CBR%20%2F%3E%5B%202.022710%5D%26lt%3B5%26gt%3Bfpga_channel_knob_probe(353)%EF%BC%9A%E9%80%9A%E9%81%93%EF%BC%9A%20ch_num(16)%20%EF%BC%81%3D%20evnet_code_end(16)%3CBR%20%2F%3E%5B%202.022954%5D%20%5Buni_register_pm_check_unit(153)%5D%3A%20register%20channel_knob%2C%20func%20%3D%200xc02b8d98%3CBR%20%2F%3E%5B%202.024185%5D%20fpga%20channel%20knob%20driver%20probe%20%5B0%3B40%3B32m%5B%20OK%20%5D%5B0m%3CBR%20%2F%3E%5B%202.025204%5D%26lt%3B5%26gt%3Bkeypad_backlight_probe(161)%3A%20keypad_backlight%20gpio%5B0%2F1%5D%EF%BC%9A181%3CBR%20%2F%3E%5B%202.025256%5D%20%E9%94%AE%E7%9B%98%E8%83%8C%E5%85%89%E9%A9%B1%E5%8A%A8%E6%8E%A2%E9%92%88%20%5B0%3B40%3B32m%5B%20OK%20%5D%5B0m%3CBR%20%2F%3E%5B%202.025803%5D%20vox%20fpga%20init%20ok%20%5B0%3B40%3B32m%5B%20OK%20%5D%5B0m%3CBR%20%2F%3E%5B%202.026681%5D%20rtc%20rtc0%3A%20alarm%20rollover%20not%20handled%3CBR%20%2F%3E%5B%202.026720%5D%20rtc%20rtc0%3A%20invalid%20alarm%20value%3A%201900-1-1%200%3A0%3A0%3CBR%20%2F%3E%5B%202.027090%5D%20rtc%20rtc0%3A%20fffffeb0.rtc%EF%BC%9Adev%20(254%3A0)%3CBR%20%2F%3E%5B%202.027149%5D%20at91_rtc%20fffffeb0.rtc%EF%BC%9Artc%20core%3A%20registered%20fffffeb0.rtc%20as%20rtc0%3CBR%20%2F%3E%5B%202.027245%5D%20at91_rtc%20fffffeb0.rtc%EF%BC%9AAT91%20%E5%AE%9E%E6%97%B6%E6%97%B6%E9%92%9F%E9%A9%B1%E5%8A%A8%E5%99%A8%3CBR%20%2F%3E%5B%202.027521%5D%20i2c%20%2Fdev%20entries%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%202.029303%5D%20AT91%EF%BC%9A%E5%94%A4%E9%86%92%E5%90%8E%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%5B%202.029773%5D%26lt%3B5%26gt%3Bbq40z80_i2c_probe(69)%3A%20bq40z80%20i2c%20%E6%8E%A2%E6%B5%8B%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%5B%202.030367%5D%20at91_wdt%20fffffe40.%E7%9C%8B%E9%97%A8%E7%8B%97%EF%BC%9Adisable%3CBR%20%2F%3E%5B%202.030404%5D%26lt%3B5%26gt%3Bof_at91wdt_init(519)%3A%20sama5d3%20watchdog%20%3A%20sama5d3%20watchdog%20status%20default%20disabled%20in%20the%20dts.%3CBR%20%2F%3E%5B%202.030457%5D%26lt%3B5%26gt%3Bat91wdt_check_mask(571)%3A%20sama5d3%20watchdog%20%3A%200x57155155%3CBR%20%2F%3E%5B%202.030496%5D%26lt%3B5%26gt%3Bat91wdt_probe(647)%3A%20sama5d3%20watchdog%20%3A%20sama5d3%20watchdog%20status%20set%20enable%20by%20sysfs.%3CBR%20%2F%3E%5B2.031079%5D%20%26lt%3B5%26gt%3B%20at91wdt_probe%20(670)%EF%BC%9Asama5d3%20%E7%9C%8B%E9%97%A8%E7%8B%97%EF%BC%9Asama5d3%20%E7%9C%8B%E9%97%A8%E7%8B%97%E6%88%90%E5%8A%9F%E6%B3%A8%E5%86%8C%E4%BA%86%E7%9C%8B%E9%97%A8%E7%8B%97%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3E%5B%202.031163%5D%26lt%3B5%26gt%3Bat91wdt_probe(679)%3A%20sama5d3%20watchdog%20%3A%20AT91%20WDT%20init%20ok%3CBR%20%2F%3E%5B%202.031624%5D%26lt%3B5%26gt%3Bfpga_wdt_get_dts(677)%3A%20fpga%20watchdog%20%3A%20fpga%20watchdog%20default%20enable%20in%20the%20dts%E3%80%82%3CBR%20%2F%3E%5B%202.032776%5D%26lt%3B3%26gt%3Bfpga_wdt_reg_status_read(157)%3A%20fpga%20watchdog%20%3A%20fpga%20wdt%20%E4%BB%8E%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%E8%AF%BB%E5%8F%96%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%5B%202.032938%5D%26lt%3B3%26gt%3Bfpga_wdt_config(693)%3A%20fpga%20watchdog%20%3A%20fpga%20watchdog%20%E8%AF%BB%E5%8F%96%E8%AE%BE%E7%BD%AE%E7%8A%B6%E6%80%81%E6%B3%A8%E5%86%8C%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%5B%202.032981%5D%26lt%3B3%26gt%3Bfpga_wdt_probe(764)%3A%20fpga%20watchdog%20%3A%20failed%20to%20config%20fpga%20wdt.%3CBR%20%2F%3E%5B%202.033018%5D%26lt%3B5%26gt%3Bfpga_wdt_probe(770)%3A%20fpga%20watchdog%20%3A%20fpga%20watchdog%20probe%20ok.%3CBR%20%2F%3E%5B%202.033272%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC%202.3%3CBR%20%2F%3E%5B%202.033305%5D%20Bluetooth%EF%BC%9AHCI%20UART%20%E5%8D%8F%E8%AE%AE%20BCSP%20%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B%202.034207%5D%20atmel_mci%20f0000000.mmc%EF%BC%9A%E7%89%88%E6%9C%AC%EF%BC%9A0x505%3CBR%20%2F%3E%5B%202.034841%5D%20atmel_mci%20f0000000.mmc%EF%BC%9A%E4%BD%BF%E7%94%A8%20dma0chan3%20%E8%BF%9B%E8%A1%8C%20DMA%20%E4%BC%A0%E8%BE%93%3CBR%20%2F%3E%5B%202.072889%5D%20atmel_mci%20f0000000.mmc%EF%BC%9AAtmel%20MCI%20%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%8C0xf0000000%20irq%2026%EF%BC%8C1%20%E4%B8%AA%E6%8F%92%E6%A7%BD%3CBR%20%2F%3E%5B%202.074162%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(499)%3A%20led0_gpio0%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.074606%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(526)%3A%20led0_gpio1%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.075024%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led0%20OK%3CBR%20%2F%3E%5B%202.076547%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(499)%3A%20led1_gpio0%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.078705%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(526)%3A%20led1_gpio1%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.079168%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led1%20OK%3CBR%20%2F%3E%5B%202.079734%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(499)%3A%20led2_gpio0%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.080221%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(526)%3A%20led2_gpio1%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.080603%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led2%20OK%3CBR%20%2F%3E%5B%202.081202%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(499)%3A%20led3_gpio0%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.081727%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(526)%3A%20led3_gpio1%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.082124%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led3%20OK%3CBR%20%2F%3E%5B%202.082759%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(499)%3A%20led4_gpio0%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.083352%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(526)%3A%20led4_gpio1%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.083817%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led4%20OK%3CBR%20%2F%3E%5B%202.085076%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(499)%3A%20led5_gpio0%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.085465%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led5%20OK%3CBR%20%2F%3E%5B%202.086755%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(499)%3A%20led6_gpio0%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.087271%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(526)%3A%20led6_gpio1%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.087737%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led6%20OK%3CBR%20%2F%3E%5B%202.088347%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(499)%3A%20led7_gpio0%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.088871%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(526)%3A%20led7_gpio1%20ctrl%20signal%20init%20success%3CBR%20%2F%3E%5B%202.089315%5D%26lt%3B5%26gt%3Bsama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led7%20OK%3CBR%20%2F%3E%5B%202.089890%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usbhid%3CBR%20%2F%3E%5B%202.089912%5D%20usbhid%EF%BC%9AUSB%20HID%20%E6%A0%B8%E5%BF%83%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%202.092923%5D%26lt%3B5%26gt%3Bmcp47feb01_probe(218)%EF%BC%9AMCP47FEB01C%20DAC%20%E8%8A%AF%E7%89%87%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%5B2.095692%5D%20bt-sco%20bt-sco%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3E%20%5B2.096381%5D%20tlv320aic32x4%201-0018%EF%BC%9Aaic32x4_i2c_probe%20(27)%EF%BC%9A%E6%8E%A2%E6%B5%8B%3CBR%20%2F%3E%20%5B2.096583%5D%26lt%3B5%26gt%3B%20tlvaic32x4_probe%20(1325)%EF%BC%9Atlvaic32x4%20%E6%8E%A2%E6%B5%8B%E5%99%A8%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3E%20%5B2.120032%5D%20mmc0%EF%BC%9A%E5%85%A8%E6%96%B0%E9%AB%98%E9%80%9F%20SMC0%20%E5%9C%B0%E5%9D%80%E4%B8%BA%200001%3CBR%20%2F%3E%20%5B2.135421%5D%26lt%3B5%26gt%3B%20aic32x4_probe%20(1154)%EF%BC%9A%E6%8E%A2%E6%B5%8B%E6%AD%A3%E5%B8%B8%3CBR%20%2F%3E%20%5B2.135537%5D%20tlv320aic32x4%201-0018%EF%BC%9AasoC%EF%BC%9A%E6%89%BE%E4%B8%8D%E5%88%B0%20HPR%20Power%3CBR%20%2F%3E%20%5B2.135569%5D%20%E7%9A%84%E6%8E%A5%E6%94%B6%E5%99%A8%E5%B0%8F%E9%83%A8%E4%BB%B6%20tlv320aic32x4%201-0018%EF%BC%9AASoC%EF%BC%9A%E5%A4%B1%E8%B4%A5%20%E6%B7%BB%E5%8A%A0%E8%B7%AF%E7%94%B1%20Left%20DAC%20%E8%B7%AF%E7%94%B1%E5%88%B0%20HPR-%26gt%3B%20direct-%26gt%3B%20HPR%20Power%3CBR%20%2F%3E%20%5B2.135593%5D%20tlv320aic32x4%201-0018%EF%BC%9AasoC%EF%BC%9A%E6%89%BE%E4%B8%8D%E5%88%B0%20HPR%20Power%3CBR%20%2F%3E%20%5B2.135616%5D%20tlv320aic32x4%201-0018%EF%BC%9AasoC%EF%BC%9A%E6%97%A0%E6%B3%95%E6%B7%BB%E5%8A%A0%E8%B7%AF%E7%94%B1%20HPR%20Power-%26gt%3B%20%E7%9B%B4%E6%8E%A5-%26gt%3B%20HPR%3CBR%20%2F%3E%20%5B2.135638%5D%20tlv320aic32x4%201-0018%3A%20asoC%EF%BC%9A%E6%89%BE%E4%B8%8D%E5%88%B0%20Mic%3CBR%20%2F%3E%20%5B2.135660%5D%20%E7%9A%84%E6%BA%90%E6%8E%A7%E4%BB%B6%20tlv320aic32x4%201-0018%EF%BC%9AasoC%EF%BC%9A%E6%97%A0%E6%B3%95%E6%B7%BB%E5%8A%A0%E8%B7%AF%E7%94%B1%20Mic-%26gt%3B%20direct-direct-%20%26gt%3B%3CBR%20%2F%3E%20%E9%BA%A6%E5%85%8B%E9%A3%8E%E5%81%8F%E5%B7%AE%20%5B2.137683%5D%20atmel-tlv320aic32x4-%E9%9F%B3%E9%A2%91%E5%A3%B0%E9%9F%B3%EF%BC%9Atlv320aic32x4-i2s%26lt%3B-%26gt%3B%20f800c000.ssc.1%3CBR%20%2F%3E%26lt%3B5%26gt%3B%20%3CBR%20%2F%3E%26lt%3B-%26gt%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%98%A0%E5%B0%84%E8%BF%98%E8%A1%8C%20%5B2.139543%5D%20atmel_asoc_tlv320aic4_probe%20(570)%EF%BC%9Aatmel%20asco%20tlv320aic32x4%20%E6%8E%A2%E6%B5%8B%E5%99%A8%E5%A5%BD%E7%9A%84%20%5B2.1423x4%20%E6%8E%A2%E6%B5%8B%E5%99%A8%E5%A5%BD%E7%9A%84%20%5B2.1423x4%5D%2014%5D%20atmel-bluetooth-audio%20bluetooth_sound%EF%BC%9Abt-sco-pcm%20f0008000.ssc.0%20%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%20%5B2.144936%5D%20atmel-bluetooth-audio%20bluetooth_sound%EF%BC%9AALSA%20resigster%20%E8%99%9A%E6%8B%9F%E8%93%9D%E7%89%99%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%20OK%20%5B2.145674%5D%20NET%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%97%2017%20%5B2.145846%5D%20bridge%EF%BC%9A%E9%80%9A%E8%BF%87%20arp%2Fip%2Fip6tables%20%E8%BF%9B%E8%A1%8C%E8%87%AA%E5%8A%A8%E8%BF%87%E6%BB%A4%E5%B7%B2%E8%A2%AB%E5%BC%83%E7%94%A8%E3%80%82%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%EF%BC%8C%E8%AF%B7%E6%9B%B4%E6%96%B0%E6%82%A8%E7%9A%84%E8%84%9A%E6%9C%AC%E4%BB%A5%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%20br_netfilter%E3%80%82%5B2.146597%5D%20%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20TTY%20%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%20%5B2.146657%5D%20%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%20%5B2.146676%5D%3CBR%20%2F%3E%20%E8%93%9D%E7%89%99%EF%BC%9ABNEP%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BB%BF%E7%9C%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.3%3CBR%20%2F%3E%20%5B2.146737%5D%20%E8%93%9D%E7%89%99%EF%BC%9ABNEP%20%E8%BF%87%E6%BB%A4%E5%99%A8%EF%BC%9A%E5%8D%8F%E8%AE%AE%E5%A4%9A%E6%92%AD%20%5B2.146766%5D%20%E8%93%9D%E7%89%99%EF%BC%9ABNEP%3CBR%20%2F%3E%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%5B2.146766%5D%20%E8%93%9D%E7%89%99%EF%BC%9ABNEP%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%20%5B2.146766%5D%2097%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHIDP%EF%BC%88%E4%BA%BA%E6%9C%BA%E6%8E%A5%E5%8F%A3%E4%BB%BF%E7%9C%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.2%3CBR%20%2F%3E%20%5B2.146825%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHIDP%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%3CBR%20%2F%3E%20%5B2.146854%5D%20lib80211%EF%BC%9AIEE802.11%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%B8%B8%E8%A7%81%E4%BE%8B%E7%A8%8B%3CBR%20%2F%3E%20%5B2.146871%5D%20lib80211_crypt%EF%BC%9A%20%E6%B3%A8%E5%86%8C%E7%AE%97%E6%B3%95%20%E2%80%9CNULL%E2%80%9D%3CBR%20%2F%3E%20%5B2.146900%5D%20lib80211_crypt%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%AE%97%E6%B3%95%20%E2%80%9CWEP%E2%80%9D%3CBR%20%2F%3E%20%5B2.146928%5D%20lib80211_crypt%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%AE%97%E6%B3%95%20%E2%80%9CCCMP%E2%80%9D%3CBR%20%2F%3E%20%5B2.146955%5D%20lib80211_crypt%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%AE%97%E6%B3%95%20%E2%80%9CTKIP%E2%80%9D%3CBR%20%2F%3E%20%26lt%3B5%26gt%3B%5B2.154283%5D%20sama5d3_oledfb_of_init%20(2150)%3A%20of_init%EF%BC%9Aoled_cs%20%3D%201%EF%BC%8COLED_CS_BASE%20%E5%BE%97%E5%88%B0%200x40000000%3CBR%20%2F%3E%20%5B2.154410%5D%26lt%3B5%26gt%3B%20sama5d3_oledfb_of_init%20(2164)%EF%BC%9Aof_init%EF%BC%9Aoled_data_phy_addr%20%3D%200x40004000%3CBR%20%2F%3E%20%5B2.154458%5D%26lt%3B5%26gt%3B%20sama5d3_oledfb_of_init%20(2176)%EF%BC%9Aof_init%EF%BC%9ASMC_BASE_ADDR%20%E5%BE%97%E5%88%B0%200xFFFC614%3CBR%20%2F%3E%20%5B2.154635%5D%26lt%3B5%26gt%3B%20sama5d3_oledfb_of_init%20(2206)%EF%BC%9Aof_init%EF%BC%9A%E9%80%89%E6%8B%A9%E5%B8%A6%E5%AE%BD%EF%BC%888%3CBR%20%2F%3E%20%E4%BD%8D%EF%BC%89%5B2.154678%5D%26lt%3B5%26gt%3B%20a5d3_oledfb_of_init%20(2212)%EF%BC%9Aof_init%EF%BC%9A%E6%9C%89%20dma%3CBR%20%2F%3E%20%5B2.154716%5D%20%5Buni_register_pm_check_unit%20(153)%5D%EF%BC%9A%E6%B3%A8%E5%86%8C%20oled_not_in_sleep%EF%BC%8Cfunc%20%3D%200xc01d0774%3CBR%20%2F%3E%20%5B2.156126%5D%26lt%3B5%26gt%3B%20set_dma_config%20(953)%EF%BC%9Aoled%20%E4%BD%BF%E7%94%A8%20dma0chan6%20%E8%BF%9B%E8%A1%8C%20DMA%20%E4%BC%A0%E8%BE%93%3CBR%20%2F%3E%20%5B2.156517%5D%26lt%3B5%26gt%3B%20get_ft2308_id%20(294)%EF%BC%9A%E9%A2%84%E6%9C%9F%20OLED%20ID%20%E4%B8%BA%200x01%2C0x02%2C0x00%3CBR%20%2F%3E%26lt%3B5%26gt%3B%20%5B2.156565%5D%20get_ft2308_id%20(295)%EF%BC%9A%E8%8E%B7%E5%8F%96%20OLED%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EID1~DI3%EF%BC%9A0xda%2C0x0x00%3CBR%20%2F%3E%20%5B2.156565%5D%205%20get_ft2308_id%20(295)%EF%BC%9A%E8%8E%B7%E5%8F%96%20OLED%20ID1~DI3%EF%BC%9A0xda%2C0xx00%20%5B2.156565%5D%205%20get_ft2308_id%20(295)%20db%2C0xdc%20%5B%202.189820%5D%20ubi0%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%BF%AB%E9%80%9F%E5%9C%B0%E5%9B%BE%E6%B1%A0%E5%A4%A7%E5%B0%8F%EF%BC%9A195%20%5B2.189849%5D%20ubi0%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%BF%AB%E9%80%9F%E5%9C%B0%E5%9B%BE%20WL%20%E6%B1%A0%E5%A4%A7%E5%B0%8F%EF%BC%9A97%20%5B2.189865%5D%20ubi0%EF%BC%9A%E9%99%84%E5%8A%A0%20mtd3%20%5B2.312533%5D%20g_multi%20%E5%B0%8F%E5%B7%A5%E5%85%B7%EF%BC%9A%E5%85%A8%E9%80%9F%E9%85%8D%E7%BD%AE%20%231%EF%BC%9A%E4%BD%BF%E7%94%A8%20RNDIS%20%E5%AE%9E%E7%8E%B0%E5%A4%9A%E5%8A%9F%E8%83%BD%20%5B2.734519%5D%20ubi0%EF%BC%9A%E7%94%B1%20fastmap%20%E8%BF%9E%E6%8E%A5%20%5B2.734549%5D%20ubi0%EF%BC%9A%E5%BF%AB%E9%80%9F%E5%9C%B0%E5%9B%BE%E6%B1%A0%E5%A4%A7%E5%B0%8F%EF%BC%9A195%20%5B2.734562%5D%20ubi0%EF%BC%9Afastmap%20WL%20%E6%B1%A0%E5%A4%A7%E5%B0%8F%EF%BC%9A97%20%5B2.753987%5D%20ubi0%EF%BC%9A%E9%99%84%E5%8A%A0%20mtd3%EF%BC%88%E5%90%8D%E7%A7%B0%20%22%20user-fs%20%22%EF%BC%8C%E5%A4%A7%E5%B0%8F%20987%20MiB%EF%BC%89%5B2.754018%5D%20ubi0%EF%BC%9APEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A262144%20%E5%AD%97%E8%8A%82%20(256%20KiB)%EF%BC%8CLEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A%20253952%20%E5%AD%97%E8%8A%82%20%5B2.754035%5D%20ubi0%EF%BC%9A%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%2F4096%2C%20%E5%AD%90%E9%A1%B5%E9%9D%A2%E5%A4%A7%E5%B0%8F%204096%3CBR%20%2F%3E%5B%202.754050%5D%20ubi0%3A%20VID%20%E5%A4%B4%E5%81%8F%E7%A7%BB%EF%BC%9A4096%EF%BC%88%E5%AF%B9%E9%BD%90%204096%EF%BC%89%EF%BC%8C%E6%95%B0%E6%8D%AE%E5%81%8F%E7%A7%BB%EF%BC%9A8192%3CBR%20%2F%3E%5B%202.754064%5D%20ubi0%EF%BC%9A%E5%A5%BD%20PEB%EF%BC%9A3946%EF%BC%8C%E5%9D%8F%20PEB%EF%BC%9A4%EF%BC%8C%E6%8D%9F%E5%9D%8F%E7%9A%84%20PEB%EF%BC%9A0%3CBR%20%2F%3E%5B%202.754078%5D%20ubi0%EF%BC%9A%E7%94%A8%E6%88%B7%E5%8D%B7%EF%BC%9A9%EF%BC%8C%E5%86%85%E9%83%A8%E5%8D%B7%EF%BC%9A1%2C%20max.%E5%8D%B7%E6%95%B0%EF%BC%9A128%3CBR%20%2F%3E%5B%202.754096%5D%20ubi0%EF%BC%9A%E6%9C%80%E5%A4%A7%2F%E5%B9%B3%E5%9D%87%E6%93%A6%E9%99%A4%E8%AE%A1%E6%95%B0%E5%99%A8%EF%BC%9A214%2F116%EF%BC%8CWL%E9%98%88%E5%80%BC%EF%BC%9A4096%EF%BC%8C%E5%9B%BE%E5%83%8F%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9A1635931764%3CBR%20%2F%3E%5B%202.754110%5D%20ubi0%EF%BC%9A%E5%8F%AF%E7%94%A8%20PEB%EF%BC%9A0%EF%BC%8C%E6%80%BB%E9%A2%84%E7%95%99%20PEB%EF%BC%9A3946%2C%20PEBs%20reserved%20for%20bad%20PEB%20handling%EF%BC%9A76%3CBR%20%2F%3E%5B%202.754858%5D%20%5Buni_register_pm_check_unit(153)%5D%3A%20register%20power_knob%2C%20func%20%3D%200xc02b73d4%3CBR%20%2F%3E%5B%202.754896%5D%26lt%3B5%26gt%3Baux_register_key(94)%3A%20not%20AUX%20key%2C%20PASS%3CBR%20%2F%3E%5B%202.755003%5D%26lt%3B5%26gt%3Baux_register_key(94)%3A%20not%20AUX%20key%2C%20PASS%3CBR%20%2F%3E%5B%202.755105%5D%26lt%3B5%26gt%3Baux_register_key(100)%3A%20get%20key%3A%20aux_eptt_key%E3%80%82%3CBR%20%2F%3E%5B%202.755203%5D%26lt%3B5%26gt%3Baux_register_key(100)%EF%BC%9A%E8%8E%B7%E5%8F%96%E5%AF%86%E9%92%A5%EF%BC%9A%20aux_ignition_key%E3%80%82%3CBR%20%2F%3E%5B%202.755297%5D%20gpio%20key%20driver%20probe%20%5B0%3B40%3B32m%5B%20OK%20%5D%5B0m%3CBR%20%2F%3E%5B%202.755725%5D%20at91_rtc%20fffffeb0.rtc%EF%BC%9A%E5%B0%86%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%E4%B8%BA%202007-01-01%2000%3A00%3A06%20UTC%20(1167609606)%3CBR%20%2F%3E%20%5B2.757268%5D%20%2Fltc4020%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%BE%97%20%2Fahb%2Fapb%2Fadc%20%E7%9A%84%20%23io-channel-cells%20%40f8018000%3CBR%20%2F%3E%20%5B2.757303%5D%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20IIO%20%E9%A2%91%E9%81%93%20%2Fltc4020%3A%20vbat-%E6%84%9F%E7%9F%A5%20(0)%3CBR%20%2F%3E%20%5B2.757331%5D%26lt%3B3%26gt%3B%20ltc4020_iios%20_chn_init%20(343)%EF%BC%9A%E5%9C%A8%20dts%20%E4%B8%AD%E6%9F%A5%E6%89%BE%20vbat-%E6%84%9F%E7%9F%A5%20%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%5B%202.757366%5D%26lt%3B3%26gt%3Bltc4020_probe(1255)%3A%20ltc4020%20iio%20chn%20init%20%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%5B%202.757778%5D%20ubi0%EF%BC%9A%E5%90%8E%E5%8F%B0%E7%BA%BF%E7%A8%8B%22ubi_bgt0d%22%20%E5%90%AF%E5%8A%A8%EF%BC%8CPID%20658%3CBR%20%2F%3E%5B%202.763788%5D%20ltc4020%EF%BC%9Altc4020%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%20-1%3CBR%20%2F%3E%5B%202.764889%5D%26lt%3B5%26gt%3Bfan_probe(403)%3A%20fan%20level%20table%20%3A%3CBR%20%2F%3E%5B%202.764936%5D%26lt%3B5%26gt%3Bfan_probe(408)%3A%20fan%20rotate%20level%20%3A%200%2C%20fan%20pwr%20en%20state%20%3A%200%2C%20dac0%20reg%20val%20%3A%200x64.%3CBR%20%2F%3E%5B%202.764980%5D%26lt%3B5%26gt%3Bfan_probe(408)%3A%20fan%20rotate%20level%20%3A%201%2C%20fan%20pwr%20en%20state%20%3A%201%2C%20dac0%20reg%20val%20%3A%200x64.%3CBR%20%2F%3E%5B%202.765022%5D%26lt%3B5%26gt%3Bfan_probe(408)%3A%20fan%20rotate%20level%20%3A%202%2C%20fan%20pwr%20en%20state%20%3A%201%2C%20dac0%20reg%20val%20%3A%200x55.%3CBR%20%2F%3E%5B%202.765063%5D%26lt%3B5%26gt%3Bfan_probe(408)%3A%20fan%20rotate%20level%20%3A%203%2C%20fan%20pwr%20en%20state%20%3A%201%2C%20dac0%20reg%20val%20%3A%200x46.%3CBR%20%2F%3E%5B%202.765103%5D%26lt%3B5%26gt%3Bfan_probe(408)%3A%20fan%20rotate%20level%20%3A%204%2C%20fan%20pwr%20en%20state%20%3A%201%2C%20dac0%20reg%20val%20%3A%200x3d.%3CBR%20%2F%3E%5B%202.765289%5D%26lt%3B5%26gt%3Bfan_probe%EF%BC%88436%EF%BC%89%EF%BC%9A%E9%A3%8E%E6%89%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%5B2.765542%5D%20clk%EF%BC%9A%E6%9C%AA%E7%A6%81%E7%94%A8%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E6%97%B6%E9%92%9F%20%3CBR%20%2F%3E%20%5B2.765581%5D%20ALSA%20%E8%AE%BE%E5%A4%87%E5%88%97%E8%A1%A8%EF%BC%9A%5B2.765598%5D%20%230%3A%20tlv320aic3204%20%40%20SAMA5D3%20%3CBR%20%2F%3E%20%5B2.765611%5D%20%231%EF%BC%9A%E8%93%9D%E7%89%99%E9%9F%B3%E9%A2%91%20%40%20SAMA5D3%20%3CBR%20%2F%3E%20%5B2.765808%5D%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%88%9D%E5%A7%8B%E4%B8%BB%E6%9C%BA%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%5B2.832155%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9A%E9%9C%80%E8%A6%81%E6%81%A2%E5%A4%8D%20%3CBR%20%2F%3E%20%5B3.154783%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9A%E6%81%A2%E5%A4%8D%E5%BB%B6%E8%BF%9F%20%3CBR%20%2F%3E%20%5B3.154823%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E5%8D%B7%201%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20rootfs%20%22%EF%BC%8CR%2FO%20%E6%A8%A1%E5%BC%8F%20%5B3.154846%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%EF%BC%88248%20KiB)%EF%BC%8C%E6%9C%80%E5%B0%8F%20%3CBR%20%2F%3E%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%3CBR%20%2F%3E%20%5B3.154868%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A64757760%20%E5%AD%97%E8%8A%82%EF%BC%8861%20MiB%EF%BC%8C255%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%209142272%20%E5%AD%97%E8%8A%82%EF%BC%888%20MiB%EF%BC%8C36%20LEB%EF%BC%89%5B3.154883%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%3CBR%20%2F%3E%20%5B3.154911%5D%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E4%B8%BA%20w4%2Fr0%EF%BC%89%E3%80%81UUID%201BACF5C4-B91E-47B4-ACA8-82F0D21AEE55%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%3CBR%20%2F%3E%20%5B3.157150%5D%20VFS%EF%BC%9A%E5%9C%A8%E8%AE%BE%E5%A4%87%200%3A12%20%E4%B8%8A%E6%8C%82%E8%BD%BD%E7%9A%84%E6%A0%B9%E7%9B%AE%E5%BD%95%EF%BC%88ubifs%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%89%E5%8F%AA%E8%AF%BB%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%5B3.157697%5D%20%E9%87%8A%E6%94%BE%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%EF%BC%9A180K%20(c05f3000-c0620000)%20%3CBR%20%2F%3E%20%5B3.471780%5D%20UBIFS%20(ubi%200%3A0)%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E5%8D%B7%200%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20%E6%A0%A1%E5%87%86%20%22%EF%BC%8CR%2FO%20%E6%A8%A1%E5%BC%8F%20%5B3.471821%5D%20UBIFS%20(ubi%200%3A0)%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%20(248%20KiB)%EF%BC%8C%E6%9C%80%E5%B0%8F%20%3CBR%20%2F%3E%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%3CBR%20%2F%3E%20%5B3.471847%5D%20UBIFS%EF%BC%88ubi%200%3A0%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A22855680%20%E5%AD%97%E8%8A%82%EF%BC%8821%20MiB%EF%BC%8C90%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%203809280%20%E5%AD%97%E8%8A%82%EF%BC%883%20MiB%EF%BC%8C15%20LEB%EF%BC%89%5B3.471864%5D%20UBIFS%20(ubi%200%3A0)%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%3CBR%20%2F%3E%20%5B3.471890%5D%5D%20UBIFS%EF%BC%88ubi%200%3A0%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E4%B8%BA%20w4%2Fr0%EF%BC%89%E3%80%81UUID%208C0A841D-9F6D-4F4B-A47B-242F17AF30D2%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E6%A8%A1%E5%9E%8B%20%5B3.514476%5D%20%E9%9A%8F%E6%9C%BA%EF%BC%9A%E9%9D%9E%E9%98%BB%E5%A1%9E%E6%B1%A0%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%3CBR%20%2F%3E%20%5B3.634316%5D%20UBIFS%EF%BC%88ubi%200%3A2%EF%BC%89%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E7%AC%AC%202%20%E5%8D%B7%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20qpe%20%22%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%EF%BC%8CR%2FO%20%E6%A8%A1%E5%BC%8F%20%3CBR%20%2F%3E%20%5B3.634356%5D%20UBIFS%EF%BC%88ubi%200%3A2%EF%BC%89%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%EF%BC%88248%20KiB%EF%BC%89%EF%BC%8C%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%3CBR%20%2F%3E%20%5B3.634381%5D%20UBIFS%EF%BC%88ubi%200%3A2%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A131801088%20%E5%AD%97%E8%8A%82%EF%BC%88125%20MiB%EF%BC%8C519%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%209404416%20%E5%AD%97%E8%8A%82%EF%BC%888%20MiB%EF%BC%8C38%20LEB%EF%BC%89%5B3.634397%5D%20UBIFS%EF%BC%88ubi%200%3A2%EF%BC%89%EF%BC%9A%E7%95%99%E7%BB%99%20root%EF%BC%9A0%20%E5%AD%97%E8%8A%82%EF%BC%880%20KiB%EF%BC%89%3CBR%20%2F%3E%5B3.634397%5D%20UBIFS%20(ubi%200%3A2)%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%5B3.63397%5D%20UBIFS%EF%BC%88ubi%200%3A2%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E6%98%AF%20w4%2Fr0%EF%BC%89%E3%80%81UUID%20E83FECA1-27DE-4703-B7D8-CB5079BD58DE%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%3CBR%20%2F%3E%20%5B3.761127%5D%20UBIFS%EF%BC%88ubi%200%3A3%EF%BC%89%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E7%AC%AC%203%20%E5%8D%B7%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20defpara%20%22%EF%BC%8CR%2FO%20%E6%A8%A1%E5%BC%8F%20%5B3.761166%5D%20UBIFS%EF%BC%88ubi%200%3A3%EF%BC%89%EF%BC%9ALEB%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%20(248%20KiB)%EF%BC%8C%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%3CBR%20%2F%3E%20%5B3.761190%5D%20UBIFS%EF%BC%88ubi%200%3A3%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A18538496%20%E5%AD%97%E8%8A%82%EF%BC%8817%20MiB%EF%BC%8C73%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%203301376%20%E5%AD%97%E8%8A%82%EF%BC%883%20MiB%EF%BC%8C13%20LEB%EF%BC%89%5B3.761206%5D%20UBIFS%20(ubi%200%3A3)%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%3CBR%20%2F%3E%20%5B3.761232%5D%5D%20UBIFS%EF%BC%88ubi%200%3A3%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E6%98%AF%20w4%2Fr0%EF%BC%89%E3%80%81UUID%20A7AE1FB4-18F3-456E-B406-88BF6D1EB1A0%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%3CBR%20%2F%3E%20%5B3.870579%5D%20UBIFS%EF%BC%88ubi%200%3A4%EF%BC%89%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E7%AC%AC%204%20%E5%8D%B7%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20otapara%20%22%EF%BC%8CR%2FO%20%E6%A8%A1%E5%BC%8F%20%5B3.870616%5D%20UBIFS%EF%BC%88ubi%200%3A4%EF%BC%89%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E253952%20%E5%AD%97%E8%8A%82%20(248%20KiB)%EF%BC%8C%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%3CBR%20%2F%3E%20%5B3.870639%5D%20UBIFS%EF%BC%88ubi%200%3A4%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A18538496%20%E5%AD%97%E8%8A%82%EF%BC%8817%20MiB%EF%BC%8C73%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%203301376%20%E5%AD%97%E8%8A%82%EF%BC%883%20MiB%EF%BC%8C13%20LEB%EF%BC%89%5B3.870654%5D%20UBIFS%EF%BC%88ubi%200%3A4%EF%BC%89%EF%BC%9A%E7%95%99%E7%BB%99%20root%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%5B3.870654%5D%20UBIFS%20(ubi%200%3A4)%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%3CBR%20%2F%3E%20%5B3.870654%5D%2070680%5D%20UBIFS%EF%BC%88ubi%200%3A4%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E6%98%AF%20w4%2Fr0%EF%BC%89%E3%80%81UUID%202BAEEFB9-96BE-4423-B712-4BB6807A7EBE%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%3CBR%20%2F%3E%20%5B3.892982%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9A%E5%90%8E%E5%8F%B0%E8%AF%9D%E9%A2%98%20%22%20ubifs_bgt0_7%20%22%20%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CPID%20677%20%5B3.950282%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9A%E9%9C%80%E8%A6%81%E6%81%A2%E5%A4%8D%20%5B4%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E.132101%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9A%E6%81%A2%E5%A4%8D%E5%B7%B2%E5%AE%8C%E6%88%90%20%3CBR%20%2F%3E%20%5B4.132143%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E7%AC%AC%207%20%E5%8D%B7%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20%E7%94%A8%E6%88%B7%E6%95%B0%E6%8D%AE%20%22%20%3CBR%20%2F%3E%20%5B4.132166%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%20(248%20KiB)%EF%BC%8C%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%3CBR%20%2F%3E%20%5B4.132191%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A520855552%20%E5%AD%97%E8%8A%82%EF%BC%88496%20MiB%EF%BC%8C2051%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%209404416%20%E5%AD%97%E8%8A%82%EF%BC%888%20MiB%EF%BC%8C38%20LEB%EF%BC%89%5B4.132207%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%EF%BC%880%20KiB%EF%BC%89%5B4.132207%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%EF%BC%880%20KiB%EF%BC%89%3CBR%20%2F%3E%5B4.132207%5D%20132235%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E6%98%AF%20w4%2Fr0%EF%BC%89%E3%80%81UUID%20E88A1FD7-4C14-4993-BB64-B06940D639FD%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%3CBR%20%2F%3E%20%5B4.138639%5D%20UBIFS%EF%BC%88ubi%200%3A5%EF%BC%89%EF%BC%9A%E5%90%8E%E5%8F%B0%E8%AF%9D%E9%A2%98%20%22%20ubifs_bgt0_5%20%22%20%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CPID%20686%20%5B4.205510%5D%20UBIFS%EF%BC%88ubi%200%3A5%EF%BC%89%EF%BC%9A%E9%9C%80%E8%A6%81%E6%81%A2%E5%A4%8D%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%5B4.272093%5D%20UBIFS%EF%BC%88ubi%200%3A5%EF%BC%89%EF%BC%9A%E6%81%A2%E5%A4%8D%E5%B7%B2%E5%AE%8C%E6%88%90%20%3CBR%20%2F%3E%20%5B4.272135%5D%20UBIFS%EF%BC%88ubi%200%3A5%EF%BC%89%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E5%8D%B7%205%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20runpara%20%22%20%3CBR%20%2F%3E%20%5B4.272158%5D%20UBIFS%EF%BC%88ubi%200%3A5%EF%BC%89%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%20(248%20KiB)%EF%BC%8C%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%3CBR%20%2F%3E%20%5B4.272180%5D%20UBIFS%EF%BC%88ubi%200%3A5%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A18538496%20%E5%AD%97%E8%8A%82%EF%BC%8817%20MiB%EF%BC%8C73%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%203301376%20%E5%AD%97%E8%8A%82%EF%BC%883%20MiB%EF%BC%8C13%20LEB%EF%BC%89%5B4.272195%5D%20UBIFS%20(ubi%200%3A5)%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%3CBR%20%2F%3E%20%5B4.272223%5D%5D%20UBIFS%EF%BC%88ubi%200%3A5%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E6%98%AF%20w4%2Fr0%EF%BC%89%E3%80%81UUID%2020E891E0-AAB5-43B6-9068-CAEE4CCFA6B4%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E6%A8%A1%E5%9E%8B%20%3CBR%20%2F%3E%20%5B4.283106%5D%20UBIFS%EF%BC%88ubi%200%3A6%EF%BC%89%EF%BC%9A%E8%83%8C%E6%99%AF%E8%AF%9D%E9%A2%98%20%22%20ubifs_bgt0_6%20%22%20%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CPID%20689%20%5B4.333357%5D%20UBIFS%EF%BC%88ubi%200%3A6%EF%BC%89%EF%BC%9A%E9%9C%80%E8%A6%81%E6%81%A2%E5%A4%8D%20%5B4%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E.498782%5D%20UBIFS%EF%BC%88ubi%200%3A6%EF%BC%89%EF%BC%9A%E6%81%A2%E5%A4%8D%E5%B7%B2%E5%AE%8C%E6%88%90%20%3CBR%20%2F%3E%20%5B4.498825%5D%20UBIFS%EF%BC%88ubi%200%3A6%EF%BC%89%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E5%8D%B7%206%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20%E6%97%A5%E5%BF%97%20%22%20%3CBR%20%2F%3E%20%5B4.498848%5D%20UBIFS%EF%BC%88ubi%200%3A6%EF%BC%89%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%20(248%20KiB)%EF%BC%8C%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%3CBR%20%2F%3E%20%5B4.498870%5D%20UBIFS%EF%BC%88ubi%200%3A6%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A31236096%20%E5%AD%97%E8%8A%82%EF%BC%8829%20MiB%EF%BC%8C123%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%204825088%20%E5%AD%97%E8%8A%82%EF%BC%884%20MiB%EF%BC%8C19%3CBR%20%2F%3E%20LEB%EF%BC%89%5B4.498885%5D%20UBIFS%20(ubi%200%3A6)%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%5B4.498912%5D%20UBIFS%20(ubi%200%3A6)%3CBR%20%2F%3E%20%5B4.498912%5D%20UBIFS%20(ubi%200%3A6)%20FS%EF%BC%88ubi%200%3A6%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E6%98%AF%20w4%2Fr0%EF%BC%89%E3%80%81UUID%20B53E2A40-EB64-4248-9C15-A08B82484E92%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%3CBR%20%2F%3E%20%5B4.683284%5D%26lt%3B5%26gt%3B%20at91_wdt_start%20(313)%EF%BC%9Asama5d3%20%E7%9C%8B%E9%97%A8%E7%8B%97%EF%BC%9Amcu%20%E7%9C%8B%E9%97%A8%E7%8B%97%E5%B7%B2%E7%A6%81%E7%94%A8%EF%BC%8C%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E3%80%82%3CBR%20%2F%3E%5B5.620927%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E5%90%8E%E5%8F%B0%E8%AF%9D%E9%A2%98%20%22%20ubifs_bgt0_8%20%22%20%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CPID%20732%20%3CBR%20%2F%3E%20%5B5.816472%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E5%8D%B7%208%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20%E6%9B%B4%E6%96%B0%20%22%20%5B5.816514%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%EF%BC%88248%20KiB%EF%BC%89b)%EF%BC%8C%E5%88%86%E9%92%9F%20%3CBR%20%2F%3E%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%3CBR%20%2F%3E%20%5B5.816541%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A130785280%20%E5%AD%97%E8%8A%82%EF%BC%88124%20MiB%EF%BC%8C515%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%206602752%20%E5%AD%97%E8%8A%82%EF%BC%886%20MiB%EF%BC%8C26%20LEB%EF%BC%89%5B5.816557%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E7%95%99%E7%BB%99%20root%EF%BC%9A4952683%20%E5%AD%97%E8%8A%82%EF%BC%884836%20KiB%EF%BC%89)%20%3CBR%20%2F%3E%20%5B5.816584%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E6%98%AF%20w4%2Fr0%EF%BC%89%E3%80%81UUID%209C8DF7E6-05DA-4D41-A3C5-0029C4D16B41%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%5B5.954423%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E5%8D%B8%E8%BD%BD%20UBI%20%E8%AE%BE%E5%A4%87%200%20%3CBR%20%2F%3E%20%5B5.954498%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E5%90%8E%E5%8F%B0%E8%AF%9D%E9%A2%98%20%22%20ubifs_bgt0_8%20%22%20%E5%81%9C%E6%AD%A2%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%5B106.889343%5D%20wlan%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%20MWLAN%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%3CBR%20%2F%3E%20%5B106.893826%5D%20wlan%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%88%B0%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3CBR%20%2F%3E%5B106.957922%5D%20vendor%3D0x0471%20device%3D0x0205%20class%3D0%20function%3D1%20%5B106.958180%5D%20Attach%20moal%20handle%20ops%EF%BC%8C%E5%8D%A1%E7%89%87%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%EF%BC%9A0x109%20%5B106.958223%5D%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E6%9C%AA%E6%8C%87%E5%AE%9A%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%20cfg%20%E6%96%87%E4%BB%B6%3CBR%20%2F%3E%5B%20106.958246%5D%20combo%20fw%3Anxp%2Fsduart_nw61x.bin.se%20wlan%20fw%3Anxp%2Fsd_w61x.bin.se%3CBR%20%2F%3E%5B%20106.958290%5D%20SDIO%3A%20sdio_blk_size%3D256%20max_blk_count%3D512%20max_segs%3D64%20max_seg_size%3D4096%3CBR%20%2F%3E%5B%20106.958304%5D%20rx_work%3D0%20cpu_num%3D1%3CBR%20%2F%3E%5B%20106.958324%5D%20Enable%20moal_recv_amsdu_packet%3CBR%20%2F%3E%5B%20106.958422%5D%20Attach%20mlan%20adapter%20operations.card_type%20is%200x109.%3CBR%20%2F%3E%5B%20106.959647%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20TX%20SG%20%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%20106.959677%5D%20wlan%3A%20mpa_tx.buf_size%3D4096%3CBR%20%2F%3E%5B%20106.959689%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20RX%20SG%20%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B%20106.959700%5D%20wlan%EF%BC%9A%20mpa_rx.buf_size%3D4096%3CBR%20%2F%3E%5B%20106.965857%5D%20%E8%AF%B7%E6%B1%82%E5%9B%BA%E4%BB%B6%EF%BC%9Anxp%2Fsd_w61x_v1.bin.se%3CBR%20%2F%3E%5B107.096406%5D%20%E5%94%A4%E9%86%92%E8%AE%BE%E5%A4%87...%3CBR%20%2F%3E%5B107.344529%5D%20Wlan%EF%BC%9A%E5%9B%BA%E4%BB%B6%E4%B8%8B%E8%BD%BD%E7%BB%93%E6%9D%9F%EF%BC%8Cfirmwarelen%3D681308%20%E5%B7%B2%E4%B8%8B%E8%BD%BD%20565508%20%5B107.742950%5D%20WLAN%20%E5%9B%BA%E4%BB%B6%E5%A4%84%E4%BA%8E%E6%B4%BB%E5%8A%A8%E7%8A%B6%E6%80%81%20%3CBR%20%2F%3E%20%5B107.742992%5D%20on_time%20%E6%98%AF%20107730209917%20%5B107.743440%5D%20QUEUE_CMD%EF%BC%9AFUNC_INIT%20%5B0xa9%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B107.743473%5D%20QUEUE_CMD%EF%BC%9A_HW_SPEC%20%3CBR%20%2F%3E%20%5B0x3%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B107.743517%5D%20DNLD_CMD%20(107.730%20%3CBR%20%2F%3E%20716)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3EFUNC_INIT%20%5B0xa9%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x263%E3%80%81len%2016%E3%80%81seqno%200x1%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20107.766158%5D%20CMD_RESP%20(107.753332)%EF%BC%9AFUNC_INIT%20%5B0x80a9%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1%3CBR%20%2F%3E%5B%20107.766220%5D%20DNLD_CMD%20(107.753417)%EF%BC%9AGET_HW_SPEC%20%5B0x3%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x0%E3%80%81len%2071%E3%80%81seqno%200x2%20%E8%B6%85%E6%97%B6%205000%20%5B107.766565%5D%20107.753753%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%3CBR%20%2F%3E%20%5B107.766612%5D%20VDLL_IND%EF%BC%88%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%89%EF%BC%9Aoffset%3D0x1c458%20%5B107.767544%5D%20VDLL%20%E5%9B%BE%E7%89%87%EF%BC%9Alen%3D115800%20%5B107.767544%5D%20VDLL%207.767850%5D%20CMD_RESP%20(107.755035)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EGET_HW_SPEC%20%5B0x8003%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20205%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2%3CBR%20%2F%3E%5B%20107.767880%5D%20fw_cap_info%3D0x487cff03%EF%BC%8Cdev_cap_mask%3D0xffffffff%3CBR%20%2F%3E%5B%20107.767897%5D%20GET_HW_SPEC%EF%BC%9Acountry_code%3D0x0%3CBR%20%2F%3E%5B%20107.767909%5D%20num_ant%3D1%EF%BC%8Cantinfo%3D0x0%3CBR%20%2F%3E%5B%20107.767923%5D%20GET_HW_SPEC%EF%BC%9Ahw_mpdu_density%3D4%20dev_mcs_support%3D0x11%3CBR%20%2F%3E%5B%20107.767934%5D%20%E5%90%AF%E7%94%A8%E6%B3%A2%E6%9D%9F%E8%B5%8B%E5%BD%A2%3CBR%20%2F%3E%5B%20107.767950%5D%20GET_HW_SPEC%EF%BC%9A%E7%AE%A1%E7%90%86%20IE%20count%3D13%3CBR%20%2F%3E%5B%20107.767965%5D%20%E5%9B%BA%E4%BB%B6%EF%BC%9ASDIO%20rx%20aggr%20%E5%B7%B2%E7%A6%81%E7%94%A8%200x487cff03%3CBR%20%2F%3E%5B%20107.767981%5D%20pmadapter-%26gt%3Becsa_enable%3D1%3CBR%20%2F%3E%5B%20107.768016%5D%20QUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20107.768030%5D%20pmadapter-%26gt%3Bgetlog_enable%3D1%3CBR%20%2F%3E%5B%20107.768052%5D%20chanrpt%20api%20ver%3D14.1%3CBR%20%2F%3E%5B%20107.768067%5D%20fw_cap_info%3D0x487cff03%20fw_cap_ext%3D0x2182b5%3CBR%20%2F%3E%5B%20107.768082%5D%20uuid%3A%20c10d697cf87d596cab35c831392df315%3CBR%20%2F%3E%5B%20107.768093%5D%20fw%20hotfix%20ver%3D11%3CBR%20%2F%3E%5B%20107.768105%5D%20fw%20ver%3D15.1%3CBR%20%2F%3E%5B%20107.768116%5D%20uap%20fw%20ver%3D2.0%3CBR%20%2F%3E%5B%20107.768127%5D%20max_p2p_conn%20%3D%208%2C%20max_sta_conn%20%3D%2016%3CBR%20%2F%3E%5B%20107.768145%5D%20wlan_set_regiontable%3A%202.4G%200x10%3CBR%20%2F%3E%5B%20107.768166%5D%20wlan_set_regiontable%3A%205G%200x10%3CBR%20%2F%3E%5B%20107.768202%5D%20Get%20Hw%20Spec%20done%2C%20fw_cap%3D0x487cff03%3CBR%20%2F%3E%5B%20107.768231%5D%20org_drv_mode%3D0x7%20drv_mode%3D0x7%3CBR%20%2F%3E%5B%20107.768815%5D%20Enable%20%E6%B3%A2%E6%9D%9F%E8%B5%8B%E5%BD%A2%3CBR%20%2F%3E%5B%20107.768873%5D%20QUEUE_CMD%3A%20802_11_FW_WAKE_METHOD%20%5B0x74%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.768901%5D%20set%20tx_buf%20%3D%204096%3CBR%20%2F%3E%5B%20107.768922%5D%20QUEUE_CMD%3A%20RECONFIGURE_TX_BUFF%20%5B0xd9%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.768949%5D%20PS%20Command%3A%20action%20%3D%200x6%2C%20bitmap%20%3D%200x1%3CBR%20%2F%3E%5B%20107.768969%5D%20QUEUE_CMD%3A%20802_11_PS_MODE_ENH%20%5B0xe4%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.768999%5D%20QUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.769028%5D%20QUEUE_CMD%3A%20802_11_RF_ANTENNA%20%5B0x20%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.769060%5D%20QUEUE_CMD%3A%20CHAN_REGION_CFG%20%5B0x242%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.769091%5D%20QUEUE_CMD%3A%20TX_RATE_CFG%20%5B0xd6%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.769118%5D%20QUEUE_CMD%3A%20802_11_RF_TX_POWER%20%5B0x1e%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.769146%5D%20QUEUE_CMD%3A%20AMSDU_AGGR_CTRL%20%5B0xdf%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.769174%5D%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.769216%5D%20DNLD_CMD%20(107.756415)%3A%20802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2015%E3%80%81seqno%200x3%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20107.769607%5D%20CMD_RESP%20(107.756793)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2015%EF%BC%8Cseqno%200x3%3CBR%20%2F%3E%5B%20107.769662%5D%20DNLD_CMD%20(107.756860)%EF%BC%9A802_11_FW_WAKE_METHOD%20%5B0x74%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x4%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20107.769996%5D%20CMD_RESP%20(107.757182)%EF%BC%9A802_11_FW_WAKE_METHOD%20%5B0x8074%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2018%EF%BC%8Cseqno%200x4%3CBR%20%2F%3E%5B%20107.770023%5D%20FW%20%E5%94%A4%E9%86%92%E6%96%B9%E6%B3%95%3D1%EF%BC%8Cgpio%3D0%3CBR%20%2F%3E%5B%20107.770063%5D%20DNLD_CMD%20(107.757261)%EF%BC%9ARECONFIGURE_TX_BUFF%20%5B0xd9%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2016%E3%80%81seqno%200x5%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20107.771157%5D%20CMD_RESP%20(107.758341)%EF%BC%9ARECONFIGURE_TX_BUFF%20%5B0x80d9%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x5%3CBR%20%2F%3E%5B%20107.771188%5D%20end%20port%2032%EF%BC%8Cdata%20port%20mask%20ffffffff%3CBR%20%2F%3E%5B%20107.771204%5D%20max_tx_buf_size%3D4096%EF%BC%8Ctx_buf_size%3D3328%3CBR%20%2F%3E%5B%20107.771246%5D%20DNLD_CMD%20(107.758444)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x6%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x6%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20107.771595%5D%20CMD_RESP%20(107.758781)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x6%3CBR%20%2F%3E%5B%20107.771644%5D%20DNLD_CMD%20(107.758844)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2018%EF%BC%8Cseqno%200x7%20%E8%B6%85%E6%97%B6%205000%20%5B107.771973%5D%20CMD_RESP%20(107.759162)%EF%BC%9A%3CBR%20%2F%3E802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2018%EF%BC%8Cseqno%200x7%3CBR%20%2F%3E%5B%20107.772022%5D%20DNLD_CMD%20(107.759222)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8Cact%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x8%20%E8%B6%85%E6%97%B6%205000%20%5B107.772352%5D%20CMD_RESP%20(107.759539)%EF%BC%9A%3CBR%20%2F%3E802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x8%3CBR%20%2F%3E%5B%20107.772407%5D%20DNLD_CMD%20(107.759602)%EF%BC%9ACHAN_REGION_CFG%20%5B0x242%5D%E3%80%81act%200x0%E3%80%81len%2011%E3%80%81seqno%200x9%20%E8%B6%85%E6%97%B6%205000%20%5B107.773717%5D%20CMD_RESP%20(107.760894)%EF%BC%9A%3CBR%20%2F%3ECHAN_REGION_CFG%20%5B0x8242%5D%EF%BC%8Cresult%200%EF%BC%8Clen%201297%EF%BC%8Cseqno%200x9%3CBR%20%2F%3E%5B%20107.773819%5D%20DNLD_CMD%20(107.761014)%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2076%EF%BC%8Cseqno%200xa%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20107.774478%5D%20CMD_RESP%20(107.761658)%EF%BC%9ATX_RATE_CFG%20%5B0x80d6%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20832%EF%BC%8Cseqno%200xa%3CBR%20%2F%3E%5B%20107.774538%5D%20DNLD_CMD%20(107.761736)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2014%EF%BC%8Cseqno%200xb%20%E8%B6%85%E6%97%B6%205000%20%5B107.774893%5D%20CMD_RESP%20(107.762080)%EF%BC%9A%3CBR%20%2F%3E802_11_RF_TX_POWER%20%5B0x801e%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200xb%3CBR%20%2F%3E%5B%20107.774946%5D%20DNLD_CMD%20(107.762143)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0xdf%5D%E3%80%81act%200x1%E3%80%81len%2014%E3%80%81seqno%200xc%20%E8%B6%85%E6%97%B6%205000%20%5B107.775283%5D%20CMD_RESP%20(107.762469)%EF%BC%9A%3CBR%20%2F%3EAMSDU_AGGR_CTRL%20%5B0x80df%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200xc%3CBR%20%2F%3E%5B%20107.775329%5D%20DNLD_CMD%20(107.762529)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200xd%20%E8%B6%85%E6%97%B6%205000%20%5B107.775658%5D%20CMD_RESP%20(107.762846)%EF%BC%9A%3CBR%20%2F%3EMAC_CONTROL%20%5B0x8028%5D%2C%20result%200%2C%20len%2012%2C%20seqno%200xd%3CBR%20%2F%3E%5B%20107.775711%5D%20QUEUE_CMD%3A%20APCMD_SYS_CONFIGURE%20%5B0xb0%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.775749%5D%20DNLD_CMD%20(107.762949)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x100e%20%E8%B6%85%E6%97%B6%205000%20%5B107.776811%5D%20CMD_RESP%20(107.763986)%EF%BC%9A%3CBR%20%2F%3EAPCMD_SYS_CONFIGURE%20%5B0x80b0%5D%2C%20result%200%2C%20len%2020%2C%20seqno%200x100e%3CBR%20%2F%3E%5B%20107.776874%5D%20QUEUE_CMD%3A%20TX_RATE_CFG%20%5B0xd6%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20107.776907%5D%20QUEUE_CMD%3A%20802_11_RF_TX_POWER%20%5B0x1e%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20107.776937%5D%20QUEUE_CMD%3A%20AMSDU_AGGR_CTRL%20%5B0xdf%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20107.776966%5D%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20107.776994%5D%20QUEUE_CMD%3A%20802_11_MAC_ADDRESS%20%5B0x4d%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20107.777031%5D%20DNLD_CMD%20(107.764231)%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2076%EF%BC%8Cseqno%200x200f%20%E8%B6%85%E6%97%B6%205000%20%5B107.781332%5D%20CMD_RESP%20(107.768504)%EF%BC%9A%3CBR%20%2F%3ETX_RATE_CFG%20%5B0x80d6%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20832%EF%BC%8Cseqno%200x200f%3CBR%20%2F%3E%5B%20107.781397%5D%20DNLD_CMD%20(107.768592)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2010%20%E8%B6%85%E6%97%B6%205000%20%5B107.781772%5D%20CMD_RESP%20(107.768958)%EF%BC%9A%3CBR%20%2F%3E802_11_RF_TX_POWER%20%5B0x801e%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2010%3CBR%20%2F%3E%5B%20107.781826%5D%20DNLD_CMD%20(107.769023)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0xdf%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2011%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B107.782166%5D%20CMD_RESP%20(107.769351)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0x80df%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2011%3CBR%20%2F%3E%5B%20107.782215%5D%20DNLD_CMD%20(107.769414)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200x2012%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20107.782555%5D%20CMD_RESP%20(107.769741)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2012%3CBR%20%2F%3E%5B%20107.782608%5D%20DNLD_CMD%20(107.769805)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4D%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2013%20%E8%B6%85%E6%97%B6%205000%20%5B107.783021%5D%20CMD_RESP%20(107.770204)%EF%BC%9A%3CBR%20%2F%3E802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2013%3CBR%20%2F%3E%5B%20107.783082%5D%20QUEUE_CMD%3A%20WMM_PARAM_CONFIG%20%5B0x23a%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20107.783132%5D%20DNLD_CMD%EF%BC%88107.770330%EF%BC%89%EF%BC%9AWMM_PARAM_CONFIG%20%5B0x23a%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x2%E3%80%81len%2026%E3%80%81seqno%200x14%20%E8%B6%85%E6%97%B6%205000%20%5B107.783476%5D%20CMD_RESP%20(107.770660)%EF%BC%9A%3CBR%20%2F%3EWMM_PARAM_CONFIG%20%5B0x823a%5D%EF%BC%8C%20result%200%EF%BC%8C%20len%2026%EF%BC%8C%20seqno%200x14%3CBR%20%2F%3E%5B%20107.784828%5D%20Set%20wiphy%20max_ap_assoc_sta%3D8%3CBR%20%2F%3E%5B%20107.784919%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%20107.784934%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%20107.784952%5D%20vht_cap%3D0x33d07030%20rx_mcs_map%3D0xfffe%20rx_max%3D0x186%20tx_mcs_map%3D0xfffe%20tx_max%3D0x186%3CBR%20%2F%3E%5B%20107.784970%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%20107.784980%5D%20max_rate%3D390M%3CBR%20%2F%3E%5B%20107.784996%5D%20vht_cap%3D0x33d07030%20rx_mcs_map%3D0xfffe%20rx_max%3D0x186%20tx_mcs_map%3D0xfffe%20tx_max%3D0x186%3CBR%20%2F%3E%5B%20107.785031%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_RF_ANTENNA%20%5B0x20%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.789721%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.776929)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x15%20%E8%B6%85%E6%97%B6%205000%20%5B107.790230%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.777434)%EF%BC%9A%3CBR%20%2F%3E802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x15%3CBR%20%2F%3E%5B%20107.790404%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.790479%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.777692)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x16%20%E8%B6%85%E6%97%B6%205000%20%5B107.790921%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.778126)%EF%BC%9A%3CBR%20%2F%3E802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x16%3CBR%20%2F%3E%5B%20107.791073%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.791142%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.778356)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x17%20%E8%B6%85%E6%97%B6%205000%20%5B107.791587%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.778791)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x1700%20%5B%20107.791740%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.791812%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.779024)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x18%20%E8%B6%85%E6%97%B6%205000%20%5B107.792245%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.779451)%EF%BC%9A%3CBR%20%2F%3E802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20142%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x18%20%5B107.792781%5D%20cfg80211%20%E7%9B%91%E7%AE%A1%E5%9F%9F%E5%9B%9E%E8%B0%83%2000%20%E5%90%AF%E5%8A%A8%E5%99%A8%3D0%20dfs_region%3D0%20%5B107.792933%5D%20%E7%9B%91%E7%AE%A1%E5%9F%9F%20by_CORE%20%3CBR%20%2F%3E%20%5B107.793004%5D%20wlan%25d%EF%BC%9AQUEE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%20%5B107.793250%5D%20wlan%25d%EF%BC%9ADNLD_%20%3CBR%20%2F%3E%20CMD%20(107.780459)%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x19%20%E8%B6%85%E6%97%B6%205000%20%5B107.793746%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.780950)%EF%BC%9A%3CBR%20%2F%3E802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x19%3CBR%20%2F%3E%5B%20107.794103%5D%20PS%20%E5%91%BD%E4%BB%A4%EF%BC%9Aaction%20%3D%200x0%EF%BC%8Cbitmap%20%3D%200x0%3CBR%20%2F%3E%5B%20107.794134%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_PS_MODE_ENH%20%5B0xe4%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.794212%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.781424)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x1a%20%E8%B6%85%E6%97%B6%205000%20%5B107.794667%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.781872)%EF%BC%9A%3CBR%20%2F%3E802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2068%EF%BC%8Cseqno%200x1a%3CBR%20%2F%3E%5B%20107.794721%5D%20ps_bitmap%3D0x0%3CBR%20%2F%3E%5B%20107.794847%5D%20CFG80211%3A%20Country%3D00%2C%20band%3D0%2C%20no_of_sub_band%3D1%3CBR%20%2F%3E%5B%20107.794888%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.794943%5D%2011D%3ACountry%3DWW%20band%3D0%20sub-band%3D1%20dfs_region%3D0%3CBR%20%2F%3E%5B%20107.794960%5D%2011D%3A%20first%20chan%3D1%20no_of_chan%3D14%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.794976%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.795005%5D%20wlan_set_regiontable%3A%202.4G%200x0%3CBR%20%2F%3E%5B%20107.795030%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%3CBR%20%2F%3E%5B%20107.795106%5D%20wlan%25d%EF%BC%9Adnld_cmd%20(107.782316)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81act%200x1%E3%80%81len%2016%E3%80%81seqno%200x1b%20%E8%B6%85%E6%97%B6%205000%20%5B107.795546%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.782751)%EF%BC%9A%3CBR%20%2F%3E802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1b%3CBR%20%2F%3E%5B%20107.795609%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.782821)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2032%E3%80%81seqno%200x1c%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B%20107.796041%5D%20wlan%25d%EF%BC%9A107.783248%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.796108%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xe808%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.796136%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.814067%5D%20wlan%25d%EF%BC%9A107.801266%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.814148%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xea60%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.814175%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.814855%5D%20wlan%25d%EF%BC%9A107.802058%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.814929%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xecb8%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.814956%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.815552%5D%20wlan%25d%EF%BC%9A107.802757%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.815622%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xef10%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.815648%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.816282%5D%20wlan%25d%EF%BC%9A107.803486%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.816354%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf168%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.816381%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.817006%5D%20wlan%25d%EF%BC%9A107.804210%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.817078%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf3c0%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.817104%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.817661%5D%20wlan%25d%EF%BC%9A107.804863%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.817734%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf618%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.817764%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.818332%5D%20wlan%25d%EF%BC%9A107.805535%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.818407%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xf870%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.818434%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.818999%5D%20wlan%25d%EF%BC%9A107.806202%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.819071%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D23%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xfac8%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.819097%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.833214%5D%20wlan%25d%EF%BC%9A107.820414%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.833298%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xc4e0%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.833326%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.851074%5D%20wlan%25d%EF%BC%9A107.838275%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.851152%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xc738%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.851180%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.851793%5D%20wlan%25d%EF%BC%9A107.838999%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.851865%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xc990%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.851892%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.852417%5D%20wlan%25d%EF%BC%9A107.839623%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.852488%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xcbe8%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.852514%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.853067%5D%20wlan%25d%EF%BC%9A107.840270%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%3CBR%20%2F%3E%5B%20107.853139%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D18%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xce40%20len%20%3D%20600%3CBR%20%2F%3E%5B%20107.853165%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%3CBR%20%2F%3E%5B%20107.853917%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.841120)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%20result%200%EF%BC%8C%20len%2032%EF%BC%8C%20seqno%200x1c%3CBR%20%2F%3E%5B%20107.854070%5D%20CFG80211%3A%20Country%3D00%2C%20band%3D1%2C%20no_of_sub_band%3D25%3CBR%20%2F%3E%5B%20107.854131%5D%2011D%3ACountry%3DWW%20band%3D1%20sub-band%3D25%20dfs_region%3D0%3CBR%20%2F%3E%5B%20107.854147%5D%2011D%3A%20first%20chan%3D36%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854160%5D%2011D%3A%20first%20chan%3D40%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854171%5D%2011D%3A%20first%20chan%3D44%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854182%5D%2011D%3A%20first%20chan%3D48%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854193%5D%2011D%3A%20first%20chan%3D52%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854205%5D%2011D%3A%20first%20chan%3D56%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854216%5D%2011D%3A%20first%20chan%3D60%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854228%5D%2011D%3A%20first%20chan%3D64%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854239%5D%2011D%3A%20first%20chan%3D100%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854251%5D%2011D%3A%20first%20chan%3D104%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854263%5D%2011D%3A%20first%20chan%3D108%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854275%5D%2011D%3A%20first%20chan%3D112%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854286%5D%2011D%3A%20first%20chan%3D116%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854298%5D%2011D%3A%20first%20chan%3D120%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854310%5D%2011D%3A%20first%20chan%3D124%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854322%5D%2011D%3A%20first%20chan%3D128%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854333%5D%2011D%3A%20first%20chan%3D132%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854345%5D%2011D%3A%20first%20chan%3D136%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854357%5D%2011D%3A%20first%20chan%3D140%20no_of_chan%3D1%E3%80%81%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854368%5D%2011D%3A%20first%20chan%3D144%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854380%5D%2011D%3A%20first%20chan%3D149%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854392%5D%2011D%3A%20first%20chan%3D153%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854404%5D%2011D%3A%20first%20chan%3D157%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854416%5D%2011D%3A%20first%20chan%3D161%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854428%5D%2011D%3A%20first%20chan%3D165%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.854445%5D%20wlan%25D%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.854475%5D%20wlan_set_regiontable%3A%202.4G%200x0%3CBR%20%2F%3E%5B%20107.854495%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%3CBR%20%2F%3E%5B%20107.854574%5D%20wlan%25d%EF%BC%9Adnld_cmd%20(107.841784)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81act%200x1%E3%80%81len%20104%E3%80%81seqno%200x1d%20%E8%B6%85%E6%97%B6%205000%20%5B107.876156%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.863356)%EF%BC%9A%3CBR%20%2F%3E802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20104%EF%BC%8Cseqno%200x1d%3CBR%20%2F%3E%5B%20107.876808%5D%20%E8%AE%BE%E7%BD%AE%20wlan%25d%20%E6%8E%A5%E5%8F%A3%E5%9C%B0%E5%9D%80%EF%BC%9A30%3AXX%3AXX%3AXX%3A8c%3A11%3CBR%20%2F%3E%5B%20107.876870%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_MAC_ADDRESS%20%5B0x4d%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.876956%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.864168)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%E3%80%81act%200x1%E3%80%81len%2016%E3%80%81seqno%200x1e%20%E8%B6%85%E6%97%B6%205000%20%5B107.877442%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.864647)%EF%BC%9A%3CBR%20%2F%3E802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1e%3CBR%20%2F%3E%5B%20107.879187%5D%20Register%20NXP%20802.11%20Adapter%20wlan0%3CBR%20%2F%3E%5B%20107.879583%5D%20uap%25d%EF%BC%9AQUEUE_CMD%3A%2011AX_CFG%20%5B0x266%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.879698%5D%20wlan0%20set%20multicast_list%3CBR%20%2F%3E%5B%20107.879738%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.879772%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.892976%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(107.880175)%EF%BC%9A11AX_CFG%20%5B0x266%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2039%E3%80%81seqno%200x101f%20%E8%B6%85%E6%97%B6%205000%20%5B107.893507%5D%20wlan0%EF%BC%9A107.880712%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%3CBR%20%2F%3E%20%5B107.893585%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xfd20%20len%20%3D%20600%20%5B107.893614%5D%20wlan14%200%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B107.911756%5D%20wlan0%EF%BC%9A107.898955%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%3CBR%20%2F%3E%20%5B0x81%5D%20%5B107.911843%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200xff78%20len%20%3D%20600%20%5B107.911872%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%3CBR%20%2F%3E%20%5B107.912558%5D%20wlan0%EF%BC%9A107.899762%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B107.912635%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x101d0%20len%20%3D%20600%20%3CBR%20%2F%3E%20%5B107.%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E912662%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%5B107.913268%5D%20wlan0%EF%BC%9A107.900472%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%3CBR%20%2F%3E%20%5B107.913341%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x10428%20len%20%3D%20600%20%5B107.913367%5D%20wlan0%EF%BC%9ADNLD_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x10428%20len%20%3D%20600%20%5B107.913367%5D%20wlan0%EF%BC%9ADNLD_IND%20VDLL%EF%BC%9Ablock_len%3D600%20%3CBR%20%2F%3E%20%5B107.913915%5D%20wlan0%EF%BC%9A107.901118%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B107.913988%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x10680%20len%20%3D%20600%20%5B107.914012%5D%20wlan0%EF%BC%9ADNLD_VDLL%EF%BC%9Ablock_len%3D600%20%3CBR%20%2F%3E%20%5B107.914012%5D%5D%20wlan0%EF%BC%9A107.901770%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B107.914645%5D%20VDLL_IND%EF%BC%9Atype%3D0%20ID%3D24%20%E5%81%8F%E7%A7%BB%E9%87%8F%20%3D%200x108d8%20len%20%3D%20600%20%3CBR%20%2F%3E%20%5B107.914672%5D%20wlan0%EF%BC%9ADNLD_%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3EVDLL%EF%BC%9Ablock_len%3D600%20%3CBR%20%2F%3E%20%5B107.915343%5D%20uap%25d%EF%BC%9ACMD_RESP%20(107.902546)%EF%BC%9A11AX_CFG%20%5B0x8266%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2039%EF%BC%8Cseqno%200x101f%3CBR%20%2F%3E%5B%20107.915409%5D%20user_2g_hecap_len%3D28%3CBR%20%2F%3E%5B%20107.915456%5D%20wlan0%3A%20DNLD_CMD%20(107.902667)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%20204%E3%80%81seqno%200x20%20%E8%B6%85%E6%97%B6%205000%3CBR%20%2F%3E%5B107.915901%5D%20wlan0%EF%BC%9ACMD_RESP%20(107.903108)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8C%20result%200%EF%BC%8C%20len%20204%EF%BC%8C%20seqno%200x20%3CBR%20%2F%3E%5B%20107.915958%5D%20wlan0%3A%20DNLD_CMD%20(107.903171)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200x21%20%E8%B6%85%E6%97%B6%205000%20%3CBR%20%2F%3E%20%5B107.916292%5D%20wlan0%EF%BC%9ACMD_RESP%20(107.903500)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x21%3CBR%20%2F%3E%5B%20107.916457%5D%20uap%25d%EF%BC%9AQUEUE_CMD%3A%2011AX_CFG%20%5B0x266%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.916542%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(107.903755)%EF%BC%9A11AX_CFG%20%5B0x266%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2039%E3%80%81seqno%200x1022%20%E8%B6%85%E6%97%B6%205000%20%5B107.917004%5D%20uap%25d%EF%BC%9ACMD_RESP%20(107.904210)%EF%BC%9A%3CBR%20%2F%3E11AX_CFG%20%5B0x8266%5D%2C%20result%200%2C%20len%2039%2C%20seqno%200x1022%3CBR%20%2F%3E%5B%20107.917062%5D%20user_hecap_len%3D28%3CBR%20%2F%3E%5B%20107.925724%5D%20Set%20uap%25d%20interface%20addr%3A%2032%3AXX%3AXX%3AXX%3A8d%3A11%3CBR%20%2F%3E%5B%20107.925790%5D%20uap%25d%EF%BC%9AQUEUE_CMD%3A%20APCMD_SYS_CONFIGURE%20%5B0xb0%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.925886%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(107.913098)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%E3%80%81act%200x1%E3%80%81len%2020%E3%80%81seqno%200x1023%20%E8%B6%85%E6%97%B6%205000%20%5B107.926382%5D%20uap%25d%EF%BC%9ACMD_RESP%20(107.913587)%EF%BC%9A%3CBR%20%2F%3EAPCMD_SYS_CONFIGURE%20%5B0x80b0%5D%EF%BC%8C%20result%200%EF%BC%8C%20len%2020%EF%BC%8C%20seqno%200x1023%3CBR%20%2F%3E%5B%20107.928101%5D%20Register%20NXP%20802.11%20Adapter%20uap0%3CBR%20%2F%3E%5B%20107.928429%5D%20PS%20Command%3A%20action%20%3D%200x0%EF%BC%8C%20bitmap%20%3D%200x0%3CBR%20%2F%3E%5B%20107.928457%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_PS_MODE_ENH%20%5B0xe4%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.928543%5D%20uap0%20set%20multicast_list%3CBR%20%2F%3E%5B%20107.929049%5D%20p2p%25d%EF%BC%9Adnld_cmd%20(107.916254)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2024%20%E8%B6%85%E6%97%B6%205000%20%5B107.929566%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(107.916771)%EF%BC%9A%3CBR%20%2F%3E802_11_PS_MODE_ENH%20%5B0x80e4%5D%2C%20result%200%2C%20len%2068%2C%20seqno%200x2024%3CBR%20%2F%3E%5B%20107.929623%5D%20ps_bitmap%3D0x0%3CBR%20%2F%3E%5B%20107.929729%5D%20CFG80211%3A%20Country%3D00%2C%20band%3D0%2C%20no_of_sub_band%3D1%3CBR%20%2F%3E%5B%20107.929770%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.929823%5D%2011D%3ACountry%3DWW%20band%3D0%20sub-band%3D1%20dfs_region%3D0%3CBR%20%2F%3E%5B%20107.929840%5D%2011D%3A%20first%20chan%3D1%20no_of_chan%3D14%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.929856%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.929885%5D%20wlan_set_regiontable%3A%202.4G%200x0%3CBR%20%2F%3E%5B%20107.929906%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%3CBR%20%2F%3E%5B%20107.929995%5D%20p2p%25d%EF%BC%9Adnld_cmd%20(107.917205)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8Cact%200x1%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2025%20%E8%B6%85%E6%97%B6%205000%20%5B107.930461%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(107.917665)%EF%BC%9A%3CBR%20%2F%3E802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2025%3CBR%20%2F%3E%5B%20107.930524%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(107.917737)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2032%E3%80%81seqno%200x2026%20%E8%B6%85%E6%97%B6%205000%20%5B107.952050%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(107.939248)%EF%BC%9A%3CBR%20%2F%3E802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%20result%200%EF%BC%8C%20len%2032%EF%BC%8C%20seqno%200x2026%3CBR%20%2F%3E%5B%20107.952237%5D%20CFG80211%3A%20Country%3D00%2C%20band%3D1%2C%20no_of_sub_band%3D25%3CBR%20%2F%3E%5B%20107.952300%5D%2011D%3ACountry%3DWW%20band%3D1%20sub-band%3D25%20dfs_region%3D0%3CBR%20%2F%3E%5B%20107.952316%5D%2011D%3A%20first%20chan%3D36%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952329%5D%2011D%3A%20first%20chan%3D40%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952341%5D%2011D%3A%20first%20chan%3D44%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952353%5D%2011D%3A%20first%20chan%3D48%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952364%5D%2011D%3A%20first%20chan%3D52%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952376%5D%2011D%3A%20first%20chan%3D56%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952388%5D%2011D%3A%20first%20chan%3D60%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952399%5D%2011D%3A%20first%20chan%3D64%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952411%5D%2011D%3A%20first%20chan%3D100%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952423%5D%2011D%3A%20first%20chan%3D104%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952435%5D%2011D%3A%20first%20chan%3D108%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952447%5D%2011D%3A%20first%20chan%3D112%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952458%5D%2011D%3A%20first%20chan%3D116%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952470%5D%2011D%3A%20first%20chan%3D120%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952482%5D%2011D%3A%20first%20chan%3D124%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952494%5D%2011D%3A%20first%20chan%3D128%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952505%5D%2011D%3A%20first%20chan%3D132%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952517%5D%2011D%3A%20first%20chan%3D136%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952529%5D%2011D%3A%20first%20chan%3D140%20no_of_chan%3D1%E3%80%81%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952541%5D%2011D%3A%20first%20chan%3D144%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952553%5D%2011D%3A%20first%20chan%3D149%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952565%5D%2011D%3A%20first%20chan%3D153%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952576%5D%2011D%3A%20first%20chan%3D157%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952588%5D%2011D%3A%20first%20chan%3D161%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952600%5D%2011D%3A%20first%20chan%3D165%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%3CBR%20%2F%3E%5B%20107.952618%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.952652%5D%20wlan_set_regiontable%3A%202.4G%200x0%3CBR%20%2F%3E%5B%20107.952673%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%3CBR%20%2F%3E%5B%20107.952749%5D%20p2p%25d%EF%BC%9Adnld_cmd%20(107.939958)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81act%200x1%E3%80%81len%20104%E3%80%81seqno%200x2027%20%E8%B6%85%E6%97%B6%205000%20%5B107.974398%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(107.961599)%EF%BC%9A%3CBR%20%2F%3E802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20104%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2027%20%5B107.975810%5D%20%E8%AE%BE%E7%BD%AE%20WFD%20%E8%AE%BE%E5%A4%87%E5%9C%B0%E5%9D%80%EF%BC%9A32%20%3CBR%20%2F%3E%20%3Axx%3Axx%3Axx%3A8c%3A11%20%5B107.975874%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B107.9774%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_MAC_ADDRESS%20%3CBR%20%2F%3E%20%5B0x4d%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B107.9774%5D%205962%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(107.963174)%EF%BC%9A%3CBR%20%2F%3E802_11_MAC_ADDRESS%20%5B0x4d%5D%E3%80%81act%200x1%E3%80%81len%2016%E3%80%81seqno%200x2028%20%E8%B6%85%E6%97%B6%205000%20%5B107.976455%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(107.963659)%EF%BC%9A%3CBR%20%2F%3E802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2028%3CBR%20%2F%3E%5B%20107.978205%5D%20Register%20NXP%20802.11%20Adapter%20p2p0%3CBR%20%2F%3E%5B%20107.978352%5D%20wlan%3A%20version%20%3D%20SDIW612---18.99.3.p26.11-MM6X18540.p17-(FP92)%3CBR%20%2F%3E%5B%20107.978415%5D%20wlan0%3A%20QUEUE_CMD%3A%20REG_ACCESS%20%5B0x27c%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.979033%5D%20p2p0%20set%20multicast_list%3CBR%20%2F%3E%5B%20107.979084%5D%20p2p0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.979124%5D%20p2p0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20is%20queued%3CBR%20%2F%3E%5B%20107.979189%5D%20wlan0%3A%20DNLD_CMD%20(107.966402)%EF%BC%9AREG_ACCESS%20%5B0x27c%5D%E3%80%81act%200x0%E3%80%81len%2020%E3%80%81seqno%200x29%20%E8%B6%85%E6%97%B6%205000%20%5B107.979694%5D%20wlan0%EF%BC%9ACMD_RESP%20(107.966899)%EF%BC%9ACMD_RESP%20(107.966899)%EF%BC%9A%3CBR%20%2F%3EREG_ACCESS%20%5B0x827c%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x29%3CBR%20%2F%3E%5B%20107.979776%5D%20p2p0%3A%20DNLD_CMD%20(107.966989)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81act%200x1%E3%80%81len%20204%E3%80%81seqno%200x202a%20%E8%B6%85%E6%97%B6%205000%20%5B107.980228%5D%20p2p0%EF%BC%9ACMD_RESP%20(107.967434)%EF%BC%9A%3CBR%20%2F%3EMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x202a%3CBR%20%2F%3E%5B%20107.980285%5D%20p2p0%3A%20DNLD_CMD%20(107.967498)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81act%200x213%E3%80%81len%2012%E3%80%81seqno%200x202b%20%E8%B6%85%E6%97%B6%205000%20%5B107.980607%5D%20p2p0%EF%BC%9ACMD_RESP%20(107.967814)%EF%BC%9A%3CBR%20%2F%3EMAC_CONTROL%20%5B0x8028%5D%2C%20result%200%2C%20len%2012%2C%20seqno%200x202b%3CBR%20%2F%3E%5B%20108.023067%5D%20%E8%AE%BE%E7%BD%AE%20REG%200x90002328%3A%200x13d57%20slew_rate%3D3%3CBR%20%2F%3E%5B%20108.023135%5D%20wlan0%3A%20QUEUE_CMD%3A%20REG_ACCESS%20%5B0x27c%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%3CBR%20%2F%3E%5B%20108.023231%5D%20wlan0%3A%20DNLD_CMD%20(108.010442)%EF%BC%9AREG_ACCESS%20%5B0x27c%5D%E3%80%81act%200x1%E3%80%81len%2020%E3%80%81seqno%200x2c%20%E8%B6%85%E6%97%B6%205000%20%3CBR%20%2F%3E%20%5B108.023738%5D%20wlan0%EF%BC%9ACMD_RESP%20(108.010941)%EF%BC%9AREG_ACCESS%20%5B0x827c%5D%2C%20result%200%2C%20len%2020%2C%20seqno%200x2c%3CBR%20%2F%3E%5B%20108.023925%5D%20wlan0%3A%20QUEUE_CMD%3A%20INDEPENDENT_RESET_CFG%20%5B0x243%5D%20is%20queued%3CBR%20%2F%3E%5B%20108.024006%5D%20wlan0%3A%20DNLD_CMD%20(108.011218)%EF%BC%9AINDEPENDENT_RESET_CFG%20%5B0x243%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2d%20%E8%B6%85%E6%97%B6%205000%20%5B108.024460%5D%20wlan0%EF%BC%9ACMD_RESP%20(108.011666)%EF%BC%9A%3CBR%20%2F%3EINDEPENDENT_RESET_CFG%20%5B0x8243%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2d%20%5B108.025121%5D%20wlan%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%88%B0%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%AE%8C%E6%88%90%20%3CBR%20%2F%3E%20%5B108.025146%5D%20wlan%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%88%90%E5%8A%9F%E5%8A%A0%E8%BD%BD%20%3CBR%20%2F%3E%3C%2FC000F3F8%3E%3C%2FC0479308%3E%3C%2FC0479308%3E%3C%2FC05F3D80%3E%3C%2FC05F3D80%3E%3C%2FC000961C%3E%3C%2FC000961C%3E%3C%2FC06132C4%3E%3C%2FC06132C4%3E%3C%2FC06133C0%3E%3C%2FC06133C0%3E%3C%2FC001FC2C%3E%3C%2FC001FC2C%3E%3C%2FC001FBD0%3E%3C%2FC001FBD0%3E%3C%2FC00125DC%3E%3C%2FC00125DC%3E%3C%2FC001499C%3E%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%5B0.000000%5D%20%E5%9C%A8%E7%89%A9%E7%90%86%20CPU%20%E4%B8%8A%E5%90%AF%E5%8A%A8%20Linux%200x0%20%5B0.000000%5D%20Linux%20%E7%89%88%E6%9C%AC%204.4.19(root%40AndroidSev)%20(gcc%20version%204.9.3%2020141031%20(prerelease)%20(Linaro%20GCC%202014.11)%20)%23226%20Thu%20Mar%2026%2011%3A48%3A39%20CST%202026%5B%200.000000%5D%20CPU%EF%BC%9AARMv7%20Processor%20%5B410fc051%5D%20revision%201%20(ARMv7)%2C%20cr%3D10c53c7d%5B%200.000000%5D%20CPU%EF%BC%9APIPT%20%2F%20VIPT%20%E9%9D%9E%E6%B7%B7%E5%8F%A0%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%EF%BC%8CVIPT%20%E6%B7%B7%E5%8F%A0%E6%8C%87%E4%BB%A4%E7%BC%93%E5%AD%98%5B%200.000000%5D%20%E6%9C%BA%E5%99%A8%E5%9E%8B%E5%8F%B7%EF%BC%9ASAMA5D3%20Xplained%5B%200.000000%5D%20Reserved%20memory%3A%20created%20CMA%20memory%20pool%20at%200x26c00000%2C%20size%2016%20MiB%5B%200.000000%5D%20Reserved%20memory%3A%20initialized%20node%20linux%2Ccma%2C%20compatible%20id%20shared-dma-pool%5B%200.000000%5D%20Memory%20policy%EF%BC%9AData%20cache%20writeback%5B%200.000000%5D%20On%20node%200%20totalpages%EF%BC%9A32512%5B%200.000000%5D%20free_area_init_node%3A%20node%200%2C%20pgdat%20c0643dd0%2C%20node_mem_map%20c7df2000%5B%200.000000%5D%20Normal%20zone%3A%20254%20pages%20used%20for%20memmap%5B%200.000000%5D%20Normal%20zone%3A%200%20pages%20reserved%5B%200.000000%5D%20Normal%20zone%3A%2032512%20pages%2C%20LIFO%20batch%3A7%5B%200.000000%5D%20CPU%EF%BC%9A%E6%89%80%E6%9C%89%20CPU%20%E5%9D%87%E4%BB%A5%20SVC%20%E6%A8%A1%E5%BC%8F%E5%90%AF%E5%8A%A8%E3%80%820.000000%5D%20pcpu-alloc%EF%BC%9As0%20r0%20d32768%20u32768%20alloc%3D1*32768%20%5B0.000000%5D%20pcpu-alloc%EF%BC%9A%5B0%5D%200%20%5B0.000000%5D%20%E6%8C%89%E5%8C%BA%E5%9F%9F%E9%A1%BA%E5%BA%8F%E6%9E%84%E5%BB%BA%201%20%E4%B8%AA%E5%8C%BA%E5%9F%9F%E5%88%97%E8%A1%A8%EF%BC%8C%E7%A7%BB%E5%8A%A8%E5%88%86%E7%BB%84%E5%BC%80%E5%90%AF%E3%80%82%E6%80%BB%E9%A1%B5%E6%95%B0%EF%BC%9A32258%20%5B0.000000%5D%20%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Anoinitrd%20console%3Dttys0%2C115200%20clk_ignore_unused%20rootfstype%3Dubifs%20ubi.mtd%3D3%20root%3Dubi0%3A%20rootfs%20ro%20rootwait%20init%3D%2Fsinit%20%5B0.000000%5D%20PID%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A512%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A-1%EF%BC%8C2048%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.00000%5D%5D%20%E5%85%A5%E5%8F%A3%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A16384%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A4%EF%BC%8C65536%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.000000%5D%20%E7%B4%A2%E5%BC%95%E8%8A%82%E7%82%B9%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A8192%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A3%EF%BC%8C32768%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.000000%5D%20%E5%86%85%E5%AD%98%EF%BC%9A105740K%2F130048K%20%E5%8F%AF%E7%94%A8%EF%BC%884696K%20%E5%86%85%E6%A0%B8%E4%BB%A3%E7%A0%81%E3%80%81145K%20rwdata%E3%80%811360K%20rodata%E3%80%81180K%20%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%81159K%20bss%E3%80%817924S%20%E5%B7%B2%E4%BF%9D%E7%95%99%EF%BC%8C16384K%20cma-reserved)%20%5B0.000000%5D%20%E8%99%9A%E6%8B%9F%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%3A%20%5B0.000000%5D%20%E5%90%91%E9%87%8F%EF%BC%9A0xffff0000-0xfff1000%20(4%20kB)%20%5B0.000000%5D%20%E4%BF%AE%E5%A4%8D%E5%9C%B0%E5%9B%BE%EF%BC%9A0xffc00000-0xfff00000%20(3072%20kB)%20%5B0.000000%5D%20vmalloc%EF%BC%9A0xc8000000-0xff800000%20(888%20MB)%20%5B0.000000%5D%20lowmem%EF%BC%9A0xc0000000-0xc7f0000000-0xc7f0000000%20000%20(127%20MB)%20%5B0.000000%5D%20%E6%A8%A1%E5%9D%97%EF%BC%9A0xbf000000-0xc0000000%20(16%20MB)%20%5B0.000000%5D%20.text%3A0xc0008000%20-%200xc05f22d4%20(6057%20kB)%5B%200.000000%5D%20.init%3A0xc05f3000%20-%200xc0620000%20(%20180%20kB)%5B%200.000000%5D%20.data%3A0xc0620000%20-%200xc06447a0%20(%20146%20kB)%5B%200.000000%5D%20.bss%3A%200xc06447a0-0xc066c72c%20(160%20kB)%20%5B0.000000%5D%20SLUB%EF%BC%9AHWAlign%3D64%EF%BC%8COrder%3D0-3%EF%BC%8CminObjects%3D0%EF%BC%8CCPUS%3D1%EF%BC%8C%E8%8A%82%E7%82%B9%3D1%20%5B0.000000%5D%20NR_IRQS%3A%2016%2016%20%5B0.000000%5D%20%E6%97%B6%E9%92%9F%E6%9D%A5%E6%BA%90%EF%BC%9A%E8%AE%A1%E6%97%B6%E5%99%A8%20%40f0010000%EF%BC%9A%E6%8E%A9%E7%A0%81%EF%BC%9A0xffffffff%20max_cycles%3A%200xffffffff%EF%BC%8Cmax_idle_ns%EF%BC%9A115833966437%20ns%20%5B0.000022%5D%20sched_clock%EF%BC%9A16%20MHz%20%E6%97%B6%E4%B8%BA%2032%20%E4%BD%8D%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87%2060ns%EF%BC%8C%E6%AF%8F%20130150523873ns%20%E5%8C%85%E8%A3%B9%E4%B8%80%E6%AC%A1%20%5B0.000048%5D%20%E5%88%87%E6%8D%A2%E5%88%B0%E5%9F%BA%E4%BA%8E%E8%AE%A1%E6%97%B6%E5%99%A8%E7%9A%84%E5%BB%B6%E8%BF%9F%E5%9B%9E%E8%B7%AF%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87%2060ns%20%5B0.027983%5D%20%E6%97%B6%E9%92%9F%E6%9D%A5%E6%BA%90%EF%BC%9Apit%EF%BC%9A%E6%8E%A9%E7%A0%81%EF%BC%9A0xfffffff%20max_cycles%EF%BC%9A0xfffffff%EF%BC%8Cmax_idle_ns%EF%BC%9A14479245754%20ns%20%5B0.028414%5D%20%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%9A%E5%BD%A9%E8%89%B2%E8%99%9A%E6%8B%9F%E8%AE%BE%E5%A4%87%2080x30%20%5B0.028472%5D%20%E6%A0%A1%E5%87%86%E5%BB%B6%E8%BF%9F%E5%BE%AA%E7%8E%AF%EF%BC%88%E8%B7%B3%E8%BF%87%EF%BC%89%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%AE%A1%E6%97%B6%E5%99%A8%E9%A2%91%E7%8E%87%E8%AE%A1%E7%AE%97%E7%9A%84%E5%80%BC%E3%80%82%2033.00%20bogoMips%20(lpj%3D165000)%20%5B0.028501%5D%20pid_max%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%9A32768%20%E6%9C%80%E5%B0%8F%E5%80%BC%EF%BC%9A301%20%5B0.028689%5D%20%E6%8C%82%E8%BD%BD%E7%BC%93%E5%AD%98%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.028718%5D%20Mountpoint-Cache%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.029699%5D%20CPU%EF%BC%9A%E6%B5%8B%E8%AF%95%E5%86%99%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%80%E8%87%B4%E6%80%A7%EF%BC%9Aok%20%5B0.030370%5D%20%E4%B8%BA%200x20008200-0x20008258%20%5B0.051134%5D%20VFP%20%E6%94%AF%E6%8C%81%20v0.3%20%E8%AE%BE%E7%BD%AE%E9%9D%99%E6%80%81%E8%BA%AB%E4%BB%BD%E6%98%A0%E5%B0%84%EF%BC%9A%E5%AE%9E%E7%8E%B0%E8%80%85%2041%20%E6%9E%B6%E6%9E%84%202%20%E7%AC%AC%2030%20%E9%83%A8%E5%88%86%E5%8F%98%E4%BD%93%205%20%E4%BF%AE%E8%AE%A2%E7%89%88%201%20%5B0.051225%5D%20%5Bdri_chk_init%20(241)%5D%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%E6%AD%A3%E5%B8%B8%20%5B0.051855%5D%20%E6%97%B6%E9%92%9F%E6%9D%A5%E6%BA%90%EF%BC%9Ajiffies%EF%BC%9A%E6%8E%A9%E7%A0%81%EF%BC%9A0xffffffff%20max_cycles%EF%BC%9A0xffffffff%EF%BC%8Cmax_idle_ns%3A19112604462750000%20ns%20%5B0.053706%5D%20pinctrl%20%E5%86%85%E6%A0%B8%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9A%84%20pinctrl%20%E5%AD%90%E7%B3%BB%E7%BB%9F%20%5B0.055024%5D%20unidebug_init%EF%BC%9Aabort_log_paddr%EF%BC%9A0xc0c07bf0-%26gt%3B%200xc8020000%EF%BC%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A0x10000%20%5B0.055056%5D%20%E4%B8%AD%E6%AD%A2%E6%97%A5%E5%BF%97%E7%BC%93%E5%86%B2%E5%8C%BA%E5%9C%B0%E5%9D%80%EF%BC%9A0xc8020000%EF%BC%8C%E5%A4%B4%EF%BC%9A0%EF%BC%8Ctail%EF%BC%9A0%20%5B0.055102%5D%20unidebug_init%EF%BC%9Arealtime_log_paddr%EF%BC%9A0xc0c07bf8-%26gt%3B%200xc8040000%EF%BC%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A0x30000%20%5B0.055125%5D%20%E5%AE%9E%E6%97%B6%E6%97%A5%E5%BF%97%E7%BC%93%E5%86%B2%E5%8C%BA%E5%9C%B0%E5%9D%80%EF%BC%9A0xc8040000%EF%BC%8C%E5%A4%B4%EF%BC%9A0%EF%BC%8C%E5%B0%BE%E9%83%A8%EF%BC%9A751%EF%BC%8C%E5%BD%93%E5%89%8D%E6%B6%88%E6%81%AF%E5%A4%A7%E5%B0%8F%EF%BC%9A751%20%5B0.055448%5D%20dt_uni_dbg_flag%EF%BC%9Auni_dbg_flag%20%E5%9C%B0%E5%9D%80%EF%BC%9A%E5%80%BC-%26gt%3B%200xc8010f00%EF%BC%9A0x55d454d4%20%5B0.056903%5D%20NET%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%97%2016%20%5B0.061074%5D%20DMA%EF%BC%9A%E4%B8%BA%E5%8E%9F%E5%AD%90%E7%9B%B8%E5%B9%B2%E5%88%86%E9%85%8D%E9%A2%84%E5%88%86%E9%85%8D%E7%9A%84%20256%20KiB%20%E6%B1%A0%20%5B0.061161%5D%20%5Buni_register_pm_check_unit%20(119)%5D%EF%BC%9A%E6%B3%A8%E5%86%8C%E4%B8%BB%E5%87%BD%E6%95%B0%EF%BC%9A%5Bpm-driver-selfcheck%5D%EF%BC%8Cfun%20%3D%200xc0043044%20%5B0.063487%5D%20AT91%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%E7%9A%84%20SoC%20%E7%B3%BB%E5%88%97%EF%BC%9Asama5d3%20%5B0.063517%5D%20AT91%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%E7%9A%84%20SoC%EF%BC%9Asama5d31%EF%BC%8C%E4%BF%AE%E8%AE%A2%E7%89%88%203%20%5B0.078086%5D%20irq%EF%BC%9A%E6%89%BE%E4%B8%8D%E5%88%B0%20%2Fahb%2Fapb%2Fpinctrl%20%40fffff200%20%2Fgpio%20%40fffffa00%20%E7%9A%84%20irq%20%E5%8A%9F%E8%83%BD%E5%9F%9F%EF%BC%81%5B0.089307%5D%20gpio-at91%20fffff200.gpio%EF%BC%9A%E5%9C%A8%E5%9C%B0%E5%9D%80%20c8018200%5B%200.090542%5D%20gpio-at91%20fffff400.gpio%20%E4%B8%8A%EF%BC%9A%E5%9C%A8%E5%9C%B0%E5%9D%80%20c801a400%5B%200.091861%5D%20gpio-at91%20fffff600.gpio%20%E4%B8%8A%EF%BC%9A%E5%9C%A8%E5%9C%B0%E5%9D%80%20c801c600%5B%200.093208%5D%20gpio-at91%20fffff800.gpio%20%E4%B8%8A%EF%BC%9A%E5%9C%A8%E5%9C%B0%E5%9D%80%20c801e800%5B%200.094664%5D%20gpio-at91%20fffffa00.gpio%20%E4%B8%8A%EF%BC%9A%E5%9C%B0%E5%9D%80%E4%B8%BA%20c8032a00%20%5B0.096164%5D%20pinctrl-at91%20ahb%3A%20apb%3A%20pinctrl%20%40fffff200%3A%20%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20AT91%20pinctrl%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5B0.097460%5D%20%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%3A%20br03_v01p01d_wifi_bt_UTA2_0326%20%5B0.097489%5D%20%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%3A%20br03%20%5B0.097504%5D%20%E8%8A%82%E7%82%B9%E5%90%8D%E7%A7%B0%3A%E5%90%AF%E5%8A%A8%E5%8F%82%E6%95%B0%20%5B0.097544%5D%20%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%200x27ffff80%20%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%A0%E5%B0%84%E5%88%B0%20c8034f80%20%5B0.097567%5D%20reset_reason%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%A0%E5%B0%84%E5%88%B0%20c8036fc0%20%5B0.098054%5D%20%E6%9D%A5%E8%87%AA%20%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%20%E7%9A%84%20RESET%20%E5%8E%9F%E5%9B%A0%3A%200x17554444%20%5B0.098074%5D%20%E8%AE%BE%E5%A4%87%E5%BC%80%E5%A7%8B%E5%8A%A0%E7%94%B5%EF%BC%81%5B0.098087%5D%20RESET%20%E5%8E%9F%E5%9B%A0%3APOWR%20%5B0.098099%5D%20%E5%86%99%E5%85%A5%20RESET%20%E5%8E%9F%E5%9B%A0%3A%200x53525748%20%5B0.098110%5D%20%E8%AF%BB%E5%8F%96%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%3A%200x55554451%20%5B0.098126%5D%20%E8%AF%BB%E5%8F%96%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%3A0xffffffff%20--%26gt%3B%20%E5%9C%A8%20%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%20%E4%B8%AD%E9%9A%8F%E6%9C%BA%20%5B0.098464%5D%20sysclk%20ctrl%20io%3A%2021%20%5B0.098556%5D%20%E7%B4%A2%E5%BC%95%3A%200%20%5B0.098606%5D%20cnt%3A%200%20%5B0.098910%5D%20%E5%90%AF%E5%8A%A8%E5%8F%82%E6%95%B0%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A2%E6%B5%8B%E5%99%A8%20%5B%E7%A1%AE%E5%AE%9A%5D%20%5B0.159347%5D%20at_hdmac%20ffffe600.dma-controller%3AAtmel%20AHB%20DMA%20Controller%20(%20cpy%20set%20slave%20sg-cpy%20)%2C%208%20channels%5B%200.161569%5D%20at_hdmac%20ffffe800.dma-controller%EF%BC%9AAtmel%20AHB%20DMA%20%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%88cpy%20%E8%AE%BE%E7%BD%AE%E4%BB%8E%E6%9C%BA%20sg-cpy%EF%BC%89%EF%BC%8C8%20%E4%B8%AA%E9%80%9A%E9%81%93%20%5B0.165426%5D%20usbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E4%BA%86%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usbfs%20%5B0.165610%5D%20usbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E4%BA%86%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9B%86%E7%BA%BF%E5%99%A8%20%5B0.165780%5D%20usbcore%EF%BC%9A%E6%B3%A8%E5%86%8C%E4%BA%86%E6%96%B0%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20usb%20%5B0.166087%5D%20I2C%20FPGA%20KEYPAD%20INIT%20%5B0%3B%2040%3B%2032m%20%5BOK%5D%20%5B0m%5D%200.166215%5D%20I2C%20FPGA%20GPI%20%E5%88%9D%E5%A7%8B%E5%8C%96%20%5B%E7%A1%AE%E5%AE%9A%5D%20%5B0.167819%5D%20at91_i2c%20f0014000.i2c%EF%BC%9AAT91%20i2c%20%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9A0x402%EF%BC%89%E3%80%82%5B0.169063%5D%20I2C%20FPGA%20GPI%20%E6%8E%A2%E6%B5%8B%E5%99%A8%EF%BC%8C%E5%9C%B0%E5%9D%80%EF%BC%9A0x70%20%5B%E7%A1%AE%E5%AE%9A%5D%5B%200.169439%5D%20%26lt%3B5%26gt%3Bfpga_keypad_probe(168)%3A%20I2C%20FPGA%20KEYPAD%20i2c%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E5%9C%B0%E5%9D%80%EF%BC%9A0x72%5B%200.169477%5D%20I2C%20FPGA%20%E9%94%AE%E7%9B%98%E6%8E%A2%E6%B5%8B%E5%99%A8%20%26%2327%3B%5B0%3B40%3B32m%5B%20OK%20%5D%26%2327%3B%5B0m%5B%200.183675%5D%20gpio-ice40lp1k%20probe%20%5BOK%5D%5B%200.184153%5D%20mcu-%E5%90%AF%E5%8A%A8-ctrl-pin%20196%20init%201%20ok%5B%200.184285%5D%20at91_i2c%20f0018000.i2c%3AAT91%20i2c%20%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9A0x402%EF%BC%89%E3%80%82%5B0.185739%5D%E9%AB%98%E7%BA%A7%20Linux%20%E5%A3%B0%E9%9F%B3%E6%9E%B6%E6%9E%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%820.186998%5D%20%E8%93%9D%E7%89%99%EF%BC%9A%E6%A0%B8%E5%BF%83%E7%89%88%E6%9C%AC%202.21%20%5B0.187115%5D%20NET%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%97%2031%20%5B0.187136%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHCI%20%E8%AE%BE%E5%A4%87%E5%92%8C%E8%BF%9E%E6%8E%A5%E7%AE%A1%E7%90%86%E5%99%A8%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%5B0.187173%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHCI%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%5B0.187199%5D%20%E8%93%9D%E7%89%99%EF%BC%9AL2CAP%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%5B0.187226%5D%20%E8%93%9D%E7%89%99%EF%BC%9ASCO%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%5B0.187851%5D------------%5B%E5%88%87%E5%85%A5%E6%AD%A4%E5%A4%84%5D-----------------------%5B0.187902%5D%20%E8%AD%A6%E5%91%8A%EF%BC%9ACPU%EF%BC%9A0%20PID%EF%BC%9A1%20%E5%9C%A8%20net%2Fwireless%2Freg.c%3A%20523%20regulatory_init%2B0x84%2F0x128%20()%20%5B0.187916%5D%20db.txt%20%E6%98%AF%E7%A9%BA%E7%9A%84%EF%BC%8C%E4%BD%A0%E5%BA%94%E8%AF%A5%E6%9B%B4%E6%96%B0%E5%AE%83...%20%5B0.187928%5D%20%E9%93%BE%E6%8E%A5%E7%9A%84%E6%A8%A1%E5%9D%97%EF%BC%9A%5B0.187958%5D%20CPU%EF%BC%9A0%20PID%EF%BC%9A1%20%E9%80%9A%E4%BF%A1%EF%BC%9A%E4%BA%A4%E6%8D%A2%E6%9C%BA%E4%B8%8D%E6%98%AF%E5%8F%97%E6%B1%A1%E6%9F%93%204.4.19%23226%20%5B0.187973%5D%20%E7%A1%AC%E4%BB%B6%E5%90%8D%E7%A7%B0%EF%BC%9AAtmel%20SAMA5%20%5B0.188039%5D%20%5B%3CC001499C%3E%5D%20(unwind_backtrace)%20%E6%9D%A5%E8%87%AA%20%5B%3CC00125DC%3E%5D%20(show_stack%2B0x10%2F0x14)%20%5B0.188084%5D%20%5B%3CC00125DC%3E%5D%20(show_stack)%20%E6%9D%A5%E8%87%AA%20%5B%3CC001FBD0%3E%5D%20(warn_slowpath_commonn)%20%2B0x80%2F0xac)%20%5B0.188120%5D%20%5B%3CC001FBD0%3E%5D%20(warn_slowpath_common)%20%E6%9D%A5%E8%87%AA%20%5B%3CC001FC2C%3E%5D%20(warn_slowpath_fmt%2B0x30%2F0x40)%20%5B0.188153%5D%20%5B%3CC001FC2C%3E%5D%20(warn_slowpath_fmt)%20%E6%9D%A5%E8%87%AA%20%5B%3CC06133C0%3E%5D%20(regulatory_init%2B0x84%2F0x128)%20%5B0.188185)%5D%20%5B%3CC06133C0%3E%5D%20(regulatory_init)%20%E6%9D%A5%E8%87%AA%20%5B%3CC06132C4%3E%5D%20(cfg80211_init%2B0x54%2F0xcc)%20%5B0.188216%5D%20%5B%3CC06132C4%3E%5D%20(cfg80211_init)%20%E6%9D%A5%E8%87%AA%20%5B%3CC000961C%3E%5D%20(do_one_initcall%2B0x90%2F0x1d8)%20%5B0.188260%5D%20%5B%3CC000961C%3E%5D%20(do_one_initcall)%20%E6%9D%A5%E8%87%AA%20%5B%3CC05F3D80%3E%5D%20(kernel_init_)freeable%2B0x130%2F0x1d0)%20%5B0.188305%5D%20%5B%3CC05F3D80%3E%5D%20(kernel_init_freeable)%20%E6%9D%A5%E8%87%AA%20%5B%3CC0479308%3E%5D%20(kernel_init%2B0xc%2F0xe8)%20%5B0.188341%5D%20%5B%3CC0479308%3E%5D%20(kernel_init)%20%E6%9D%A5%E8%87%AA%20%5B%3CC000F3F8%3E%5D%20(ret_from_fork%2B0x14%2F0x3c)%20%5B0.188400%5D---%5B%E7%BB%93%E6%9D%9F%E8%B7%9F%E8%B8%AA%20db6e7ed398e5acc9%5D---%5B0.192800%5D%20%E6%97%B6%E9%92%9F%E6%BA%90%EF%BC%9A%E5%B7%B2%E5%88%87%E6%8D%A2%E5%88%B0%E6%97%B6%E9%92%9F%E6%BA%90%E8%AE%A1%E6%97%B6%E5%99%A8%20%40f0010000%20%5B0.208795%5D%20NET%EF%BC%9A%20%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%97%202%20%5B0.209929%5D%20TCP%20%E5%B7%B2%E5%BB%BA%E7%AB%8B%E7%9A%84%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.209988%5D%20TCP%20%E7%BB%91%E5%AE%9A%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A1024%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.210031%5D%20TCP%EF%BC%9A%E5%B7%B2%E9%85%8D%E7%BD%AE%E5%93%88%E5%B8%8C%E8%A1%A8%EF%BC%88%E5%B7%B2%E5%BB%BA%E7%AB%8B%201024%20%E7%BB%91%E5%AE%9A%201024%EF%BC%89%5B0.210207%5D%20UDP%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A256%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.210254%5D%20uDP%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A256%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.210254%5D%20uDP%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A256%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.210254%5D%20P-Lite%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A256%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A0%EF%BC%8C4096%20%E5%AD%97%E8%8A%82%EF%BC%89%5B0.210579%5D%20NET%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%97%201%20%5B0.211421%5D%20%E8%BE%93%E5%85%A5%EF%BC%9A%E6%9C%AA%E6%8C%87%E5%AE%9A%E8%AE%BE%E5%A4%87%E4%B8%BA%20%2Fdevices%2Fvirtual%2Finput%2Finput0%20%5B0.211463%5D%20%26lt%3B5%26gt%3B%20si_key_probe%20(171)%EF%BC%9A%E5%AF%86%E9%92%A5%EF%BC%9A%E6%B3%A8%E5%86%8C%20sama5d3%20%E9%94%AE%E8%BE%93%E5%85%A5%E8%AE%BE%E5%A4%87%20%5B0.229580%5D%20SI%20%E6%A0%B8%E5%BF%83%E6%8E%A2%E6%B5%8B%E5%99%A8%20%5B0%3B%2040%3B%2032m%20%5BOK%5D%20%5B0m%20%5B0.229863%5D%20SI%20%E6%A0%B8%E5%BF%83%E5%88%9D%E5%A7%8B%E5%8C%96%20%5B0%3B%2040%3B%2032m%20%5B%E7%A1%AE%E5%AE%9A%5D%20%5B0m%20%5B0.232200%5D%20%26lt%3B5%26gt%3B%20parse_dt%20(569)%EF%BC%9Abt%20ref%20clk%20%E4%B8%8D%E6%98%AF%E6%9D%A5%E8%87%AA%20ref%20clk%20k%20%E8%8A%82%E7%82%B9%20%5B0.232249%5D%20%26lt%3B5%26gt%3B%20parse_dt%20(578)%EF%BC%9Abt%20clk%20%E4%B8%8D%E6%98%AF%E6%9D%A5%E8%87%AA%20bt%20clk%20%E8%8A%82%E7%82%B9%20%5B0.232400%5D%20bt%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A2%E6%B5%8B%E5%99%A8%20%5B0%3B%2040%3B%2032m%20%5BOK%5D%20%5B0m%20%5B0.234678%5D%20futex%20%E5%93%88%E5%B8%8C%E8%A1%A8%E6%9D%A1%E7%9B%AE%EF%BC%9A256%EF%BC%88%E9%A1%BA%E5%BA%8F%EF%BC%9A-1%E3%80%813072%EF%BC%89%E5%AD%97%E8%8A%82)%20%5B0.261119%5D%20ntfs%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%202.1.32%5BFlags%3A%20R%2FW%5D.%5B%200.271996%5D%20%E6%B3%A8%E5%86%8C%E4%BA%86%E9%9D%9E%E5%AF%B9%E7%A7%B0%E5%AF%86%E9%92%A5%E7%B1%BB%E5%9E%8B%5B%200.272046%5D%20%E6%B3%A8%E5%86%8C%E4%BA%86%E9%9D%9E%E5%AF%B9%E7%A7%B0%E5%AF%86%E9%92%A5%E8%A7%A3%E6%9E%90%E5%99%A8%20%22x509%22%5B%200.272142%5D%20%E6%B3%A8%E5%86%8C%E4%BA%86%20io%20%E8%B0%83%E5%BA%A6%E7%A8%8B%E5%BA%8F%20noop%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%5B%200.275288%5D%20f001c000.serial%EF%BC%9AMMIO%200xf001c000%20%E4%B8%8A%E7%9A%84%20ttyS1%EF%BC%88irq%20%3D%2032%EF%BC%8Cbase_baud%20%3D%204125000%EF%BC%89%E6%98%AF%20ATMEL_SERIAL%5B0.276372%5Df8024000.serial%EF%BC%9A%E5%9C%A8%20MMIO%200xf8024000%EF%BC%88irq%20%3D%2034%EF%BC%8Cbase_baud%20%3D%204125000%EF%BC%89%E5%A4%84%E7%9A%84%20ttys4%20%E6%98%AF%20ATMEL_SERIAL%20%5B0.278040%5D%20aquire%20gpis%20%E5%90%AF%E5%8A%A8%20gpio%20%E5%AF%86%E7%A0%81%E9%94%99%E8%AF%AF%EF%BC%8C%E4%B8%8D%E8%A6%81%E7%94%A8%EF%BC%81%5B0.278239%5D%20kfifo%3A%20size%20%3D1024%2C%20recsize%3D0%2C%20esize%3D1%2C%20inited%3D1023%5B%200.278268%5D%20sama5d3-gps%20gps%3A%20gps%20init%20ok%5B%200.279091%5D%26lt%3B3%26gt%3Bacc_init_ctl_io(987)%EF%BC%9AFailed%20to%20get%20io0_sel%20gpio%5B%200.279141%5D%26lt%3B3%26gt%3Bacc_init_ctl_io(994)%EF%BC%9AFailed%20to%20get%20io1_sel%20gpio%5B%200.279497%5D%20uni-acc%20uni_acc0%3A%20acc0%20init%20ok%5B%200.289728%5D%20brd%3A%20module%20loaded%5B%200.300025%5D%20loop%3A%20module%20loaded%5B%200.300727%5D%20ssc%20f0008000.ssc.0%EF%BC%9A%E4%BD%8D%E4%BA%8E%200xc80d8000%20(irq%2029)%20%5B0.301156%5D%20%E7%9A%84%20Atmel%20SSC%20%E8%AE%BE%E5%A4%87%20ssc%20f800c000.ssc.1%EF%BC%9A%E4%BD%8D%E4%BA%8E%200xc80e0000%20(irq%2033)%20%5B0.302061%5D%20%E7%9A%84%20Atmel%20SSC%20%E8%AE%BE%E5%A4%87%E4%BD%8D%E4%BA%8E%2024%200-0050%EF%BC%9A512%20%E5%AD%97%E8%8A%82%2024c04%20EEPROM%EF%BC%8C%E5%8F%AF%E5%86%99%EF%BC%8C16%20%E5%AD%97%E8%8A%82%2F%E5%86%99%E5%85%A5%20%5B0.306971%5D%20atmel_nand_nfc%2070000000.nfc%EF%BC%9A%E5%AF%B9%20NFC%20%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%8E%A2%E6%B5%8B%E3%80%820.307215%5D%20atmel_%E4%B8%8E%E9%9D%9E%2060000000.%E4%B8%8E%E9%9D%9E%EF%BC%9A%E5%9C%A8%20Flash%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20BBT%20%5B0.308380%5D%20atmel_%E4%B8%8E%E9%9D%9E%2060000000.%E4%B8%8E%E9%9D%9E%EF%BC%9A%E4%BD%BF%E7%94%A8%20dma0chan0%20%E8%BF%9B%E8%A1%8C%20DMA%20%E4%BC%A0%E8%BE%93%E3%80%820.309744%5D%20%E4%B8%8E%E9%9D%9E%3A%20%E5%B7%B2%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%88%B6%E9%80%A0%E5%95%86%20ID%EF%BC%9A0x2c%EF%BC%8C%E8%8A%AF%E7%89%87%E7%BC%96%E5%8F%B7%EF%BC%9A0xa3%20%5B0.309772%5D%20%E4%B8%8E%E9%9D%9E%3A%20%E7%BE%8E%E5%85%89%20MT29F8G08ABBCAH4%20%5B0.309794%5D%20%E4%B8%8E%E9%9D%9E%3A%201024%20MiB%EF%BC%8CSLC%EF%BC%8C%E6%93%A6%E9%99%A4%E5%A4%A7%E5%B0%8F%EF%BC%9A256%20KiB%EF%BC%8C%E9%A1%B5%E9%9D%A2%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%EF%BC%8COOB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A224%20%5B0.309826%5D%20atmel_%E4%B8%8E%E9%9D%9E%2060000000.%E4%B8%8E%E9%9D%9E%3A%E6%9C%80%E4%BD%8E%20ECC%EF%BC%9A512%20%E5%AD%97%E8%8A%82%E5%86%85%E6%9C%89%208%20%E4%BD%8D%20%5B0.309850%5D%20atmel_nand%2060000000.nand%EF%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%20PMECC%20%E5%8F%82%E6%95%B0%EF%BC%8C%E4%B8%8A%E9%99%90%EF%BC%9A12%EF%BC%8C%E6%89%87%E5%8C%BA%EF%BC%9A512%20%5B0.309956%5D%20atmel_%E4%B8%8E%E9%9D%9E%2060000000.%E4%B8%8E%E9%9D%9E%EF%BC%9A%E4%BD%BF%E7%94%A8%20NFC%20Sram%20%E8%AF%BB%E5%8F%96%20%5B0.311307%5D%20%E5%9C%A8%20262080%20%E9%A1%B5%E6%89%BE%E5%88%B0%E7%9A%84%E9%94%99%E8%AF%AF%E5%8C%BA%E5%9D%97%E8%A1%A8%EF%BC%8C%E7%89%88%E6%9C%AC%200x01%20%5B0.312151%5D%20%E5%9C%A8%20262016%20%E9%A1%B5%E6%89%BE%E5%88%B0%E7%9A%84%E9%94%99%E8%AF%AF%E5%8C%BA%E5%9D%97%E8%A1%A8%EF%BC%8C%E7%89%88%E6%9C%AC%200x01%20%5B0.312999%5D%20%E5%9C%A8%20MTD%20%E8%AE%BE%E5%A4%87%E4%B8%8A%E6%89%BE%E5%88%B0%204%20%E4%B8%AA%E5%88%86%E5%8C%BA%20atmel_nand%20%5B0.313028%5D%20%E5%9C%A8%20%22%20atmel_nand%20%22%3A%20%5B0.313059%5D%200x000000000000-0x0000000%E4%B8%8A%E5%88%9B%E5%BB%BA%204%20%E4%B8%AA%20MTD%20%E5%88%86%E5%8C%BA%2040000%EF%BC%9A%22%20iplp1%20%22%20%5B0.313770%5D%200x000000040000-0x000001080000%EF%BC%9A%22%20minisys%22%20%5B0.314417%5D%200x000001080000-0x000002480000%EF%BC%9A%22%20workbin%20%22%20%5B0.315035%5D%200x000002480000-0x0000000000-0x00000000000%EF%BC%9A%22%20user-fs%20%22%20%5B0.317794%5D%20%26lt%3B3%26gt%3B%20dsp_output_probe%20(348)%EF%BC%9A%E5%AF%84%E5%AD%98%E5%99%A8%20dsp%20%E8%BE%93%E5%87%BA0%20%5B0.317885%5D%20dsp%20%E8%BE%93%E5%87%BA%20dsp-output0%EF%BC%9Adsp-output0%20_output%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A2%E6%B5%8B%E5%99%A8%20%5B0.318003%5D%20%26lt%3B3%26gt%3B%20dsp_output_probe%20(354)%EF%BC%9A%E5%AF%84%E5%AD%98%E5%99%A8%20dsp%20%E8%BE%93%E5%87%BA%201%20%5B0.318070%5D%20dsp%20%E8%BE%93%E5%87%BA%20dsp%20%E8%BE%93%E5%87%BA%201%EF%BC%9Adsp_output%20%E9%A9%B1%E5%8A%A8%E5%99%A8%E6%8E%A2%E5%A4%B4%20%5B0.318552%5D%20%26lt%3B3%26gt%3B%20dsp_input_probe%20(334)%EF%BC%9A%E5%AF%84%E5%AD%98%E5%99%A8%20dsp%20%E8%BE%93%E5%85%A5%200%EF%BC%8Cret%3D0%20%5B0.318652%5D%20dsp%20%E8%BE%93%E5%85%A5%20dsp%20%E8%BE%93%E5%85%A50%EF%BC%9Adsp_input%20%E9%A9%B1%E5%8A%A8%E5%99%A8%E6%8E%A2%E6%B5%8B%E5%99%A8%20%5B0.318772%5D%20%26lt%3B3%26gt%3B%20dsp_input_probe%20(340)%EF%BC%9A%E5%AF%84%E5%AD%98%E5%99%A8%20dsp%20%E8%BE%93%E5%85%A5%201%EF%BC%8Cret%3D0%20%5B0.318839%5D%20dsp-input%20dsp-input%20dsp-input1%EF%BC%9Adsp_input%20%E9%A9%B1%E5%8A%A8%E5%99%A8%E6%8E%A2%E6%B5%8B%E5%99%A8%20%5B0.320816%5D%20atmel_spi%20f8000.spi%EF%BC%9Aversion%3A%200x213%5B%200.321306%5D%20atmel_spi%20f8008000.spi%EF%BC%9A%E4%BD%BF%E7%94%A8%20dma1chan0%EF%BC%88tx%EF%BC%89%E5%92%8C%20dma1chan1%EF%BC%88rx%EF%BC%89%E8%BF%9B%E8%A1%8C%20DMA%20%E4%BC%A0%E8%BE%93%5B%200.321433%5D%20atmel-spi%20%E5%AF%84%E5%AD%98%E5%99%A8%20pio-irq%EF%BC%8Cret%20%3D%200%5B%200.321481%5D%20atmel_spi%20f8008000.spi%EF%BC%9AAtmel%20SPI%20%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%8C0xf8008000%20(irq%2027)%5B%200.324620%5D%20spi_master%20spi32766%3A%20%E5%B0%86%E4%BB%A5%E5%AE%9E%E6%97%B6%E4%BC%98%E5%85%88%E7%BA%A7%E8%BF%90%E8%A1%8C%E6%B6%88%E6%81%AF%E6%B3%B5%5B%200.325692%5D%26lt%3B3%26gt%3Bdsp_spi_probe(2295)%3A%20%E5%90%8D%E4%B8%BA%20br03-dsp-spi1%20%E7%9A%84%20spi%20%E6%AD%A3%E5%9C%A8%E6%8E%A2%E6%B5%8B%5B%200.325746%5D%26lt%3B3%26gt%3Bdsp_spi_probe(2304)%3A%20malloc%20607%20size%20of%20dsp%20driver%2C%20spidev%20%3D%200xc6969c00%2C%20spi%20%3D%200xc6969800%2C%20maste%26lt%3B3%26gt%3Bdsp_spi_probe(2334)%3A%20register%20dsp%20master1%5B%200.325823%5D%20dspmaster%20spi32766.0%EF%BC%9Adsp%20spi%20probe%20speed(3000000)%20dev%200x0f800001%5B%201.127630%5D%20%5Buni_register_pm_check_unit(153)%5D%3A%20%E5%AF%84%E5%AD%98%E5%99%A8%20DSP1-INT%2C%20func%20%3D%200xc0254700%5B%201.128522%5D%20m25p80%20spi32766.1%EF%BC%9Am25p10-nonjedec%20(128%20Kbytes)%5B%201.130820%5D%20atmel_spi%20f0004000.spi%EF%BC%9A%E7%89%88%E6%9C%AC%EF%BC%9A%200x213%5B%201.131300%5D%20atmel_spi%20f0004000.spi%EF%BC%9A%E4%BD%BF%E7%94%A8%20dma0chan1%EF%BC%88tx%EF%BC%89%E5%92%8C%20dma0chan2%EF%BC%88rx%EF%BC%89%E8%BF%9B%E8%A1%8C%20DMA%20%E4%BC%A0%E8%BE%93%5B%201.131396%5D%20atmel-spi%20%E5%AF%84%E5%AD%98%E5%99%A8%20pio-irq%EF%BC%8Cret%20%3D%200%5B%201.131441%5D%20atmel_spi%20f0004000.spi%EF%BC%9AAtmel%20SPI%20%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%8C0xf0004000%20(irq%2028)%5B%201.132565%5D%20spi_master%20spi32765%EF%BC%9A%E5%B0%86%E4%BB%A5%E5%AE%9E%E6%97%B6%E4%BC%98%E5%85%88%E7%BA%A7%E8%BF%90%E8%A1%8C%E6%B6%88%E6%81%AF%E6%B3%B5%5B%201.133707%5D%26lt%3B3%26gt%3Bdsp_spi_probe(2295)%3A%20spi%20%E5%90%8D%E4%B8%BA%20br03-dsp-spi0%20probing%5B%201.133760%5D%26lt%3B3%26gt%3Bdsp_spi_probe(2304)%3A%20malloc%20607%20size%20of%20dsp%20driver%2C%20spidev%20%3D%200xc6a05000%2C%20spi%20%3D%200xc6a04c00%2C%20maste%26lt%3B3%26gt%3Bdsp_spi_probe(2326)%3A%20register%20dsp%20master0%5B%201.133836%5D%20dspmaster%20spi32765.0%EF%BC%9Adsp%20spi%20probe%20speed(3000000)%20dev%200x0f800000%5B%201.134065%5D%26lt%3B5%26gt%3Bdsp_hw_init(1705)%3A%20can't%20find%20pwr-gpio%20in%20dts%5B%201.134099%5D%26lt%3B5%26gt%3Bdsp_hw_init(1705)%3A%20can't%20find%20rf_6V_pwr_en-gpio%20in%20dts%5B%201.134130%5D%26lt%3B5%26gt%3Bdsp_hw_init(1705)%3A%20can't%20find%20fpga_reset-gpio%20in%20dts%5B%201.134157%5D%26lt%3B5%26gt%3Bdsp_hw_init(1705)%3A%20can't%20find%20dsp_switch_ctl_A%20in%20dts%5B%201.134184%5D%26lt%3B5%26gt%3Bdsp_hw_init(1705)%3A%20can't%20find%20dsp_switch_ctl_B%20in%20dts%5B%201.134211%5D%26lt%3B5%26gt%3Bdsp_hw_init(1705)%3A%20can't%20find%20dsp_fpga_done%20in%20dts%5B%201.135118%5D%26lt%3B5%26gt%3Bdsp_fault_save_timestamp(1541)%3A%20dspmaster%5B0%5D%20dsp_fault_save_timestamp%5B%201.135390%5D%26lt%3B3%26gt%3Bhost_ctl_rf_power(350)%3A%20dspmaster%5B0%5D%20cannot%20ctl%20pwr%20io%5B%201.935625%5D%26lt%3B3%26gt%3Bhost_ctl_rf_power(350)%3A%20dspmaster%5B0%5D%20cannot%20ctl%20pwr%20io%5B%201.935669%5D%20%5Buni_register_pm_check_unit(153)%5D%3A%20register%20DSP0-INT%2C%20func%20%3D%200xc0254700%5B%201.936358%5D%20usbcore%3A%20registered%20new%20interface%20driver%20asix%5B%201.936535%5D%20usbcore%3A%20registered%20new%20interface%20driver%20ax88179_178a%5B%201.936693%5D%20usbcore%3A%20registered%20new%20interface%20driver%20cdc_ether%5B%201.936844%5D%20usbcore%3A%20%E6%B3%A8%E5%86%8C%E4%BA%86%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20net1080%5B%201.936996%5D%20usbcore%3A%20%E6%B3%A8%E5%86%8C%E4%BA%86%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20rndis_host%5B%201.937143%5D%20usbcore%3A%20%E6%B3%A8%E5%86%8C%E4%BA%86%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20cdc_subset%5B%201.937291%5D%20usbcore%3A%20%E6%B3%A8%E5%86%8C%E4%BA%86%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20zaurus%5B%201.937549%5D%20usbcore%3A%20%E6%B3%A8%E5%86%8C%E4%BA%86%E6%96%B0%E7%9A%84%E6%8E%A5%E5%8F%A3%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20cdc_ncm%5B%201.937585%5D%20ehci_hcd%EF%BC%9AUSB%202.0%20%22%E5%A2%9E%E5%BC%BA%E5%9E%8B%20%22%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%88EHCI%EF%BC%89%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5B%201.937614%5D%20ehci-atmel%EF%BC%9AEHCI%20Atmel%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5B%201.938029%5D%20ohci_hcd%EF%BC%9AUSB%201.1%20'Open'%20Host%20Controller%20(OHCI)%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5B%201.938067%5D%20ohci-atmel%EF%BC%9AOHCI%20Atmel%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5B%201.938829%5D%20at91_ohci%20600000.ohci%EF%BC%9AUSB%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%5B%201.938918%5D%20at91_ohci%20600000.ohci%EF%BC%9A%E6%96%B0%20USB%20%E6%80%BB%E7%BA%BF%E5%B7%B2%E6%B3%A8%E5%86%8C%EF%BC%8C%E5%88%86%E9%85%8D%E7%9A%84%E6%80%BB%E7%BA%BF%E7%BC%96%E5%8F%B7%E4%B8%BA%201%20%5B1.939060%5D%20%26lt%3B3%26gt%3B%20host_timer_enable%20(1109)%EF%BC%9Adspmaster%20%5B0%5D%20%E7%A6%81%E7%94%A8%E4%B8%BB%E6%9C%BA%E8%AE%A1%E6%97%B6%E5%99%A8%20%5B1.940111%5D%20at91_ohci%20600000.ohci%EF%BC%9Airq%2047%2C%20io%20mem%200x00600000%5B%201.998637%5D%20hub%201-0%3A1.0%EF%BC%9A%E5%8F%91%E7%8E%B0%20USB%20%E9%9B%86%E7%BA%BF%E5%99%A8%5B%201.998899%5D%20%E9%9B%86%E7%BA%BF%E5%99%A8%201-0%3A1.0%3A%20%E6%A3%80%E6%B5%8B%E5%88%B0%201%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%5B%202.001020%5D%20atmel_usba_udc%20500000.gadget%EF%BC%9A%E4%BD%8D%E4%BA%8E%200xf8030000%20%E7%9A%84%20MMIO%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%A0%E5%B0%84%E5%88%B0%20c80e8000%5B%202.001125%5D%20atmel_usba_udc%20500000.gadget%EF%BC%9AFIFO%20at%200x00500000%20mapped%20at%20c8600000%5B%202.003751%5D%20using%20random%20self%20ethernet%20address%5B%202.003796%5D%20using%20random%20host%20ethernet%20address%5B%202.003829%5D%20using%20host%20ethernet%20address%3A%20be%3A6e%3A3b%3A3e%3A6f%3A6b%5B%202.003847%5D%20using%20self%20ethernet%20address%EF%BC%9A12%3A56%3A59%3A21%3A22%3A05%26lt%3B6%26gt%3B%5B%202.005248%5D%20usb0%3A%20HOST%20MAC%20be%3A6e%3A3b%3A3e%3A6f%3A6b%5B%202.005345%5D%20usb0%3A%20MAC%2012%3A56%3A59%3A21%3A22%3A05%5B%202.005441%5D%20g_multi%20%E5%B0%8F%E5%B7%A5%E5%85%B7%EF%BC%9A%E5%A4%9A%E5%8A%9F%E8%83%BD%E5%A4%8D%E5%90%88%E5%B0%8F%E5%B7%A5%E5%85%B7%5B%202.005464%5D%20g_multi%20%E5%B0%8F%E5%B7%A5%E5%85%B7%EF%BC%9A%E7%94%A8%E6%88%B7%E7%A9%BA%E9%97%B4%E6%9C%AA%E8%83%BD%E6%8F%90%E4%BE%9B%20iSerialNumber%5B%202.005480%5D%20g_multi%20%E5%B0%8F%E5%B7%A5%E5%85%B7%EF%BC%9Ag_multi%20%E5%87%86%E5%A4%87%E5%B0%B1%E7%BB%AA%5B%202.010574%5D%26lt%3B5%26gt%3Bfpga_keypad_probe(529)%3A%20fpga%20keypad%20gpio%20(status)%EF%BC%9A158%20(1)%2C%20virq%3A%20207%5B%202.010697%5D%20%5Buni_register_pm_check_unit(153)%5D%3A%20register%20keypad%2C%20func%20%3D%200xc02b8794%5B%202.011893%5D%26lt%3B5%26gt%3Bfpga_keypad_probe(568)%3A%20pck1%20rate%20%3D%2024000000%2C%20is_enable%20%3D%200%5B%202.011978%5D%20fpga%20keypad%20driver%20probe%20%5B0%3B40%3B32m%5B%20OK%20%5D%5B0m%5B%202.022710%5D%26lt%3B5%26gt%3Bfpga_channel_knob_probe(353)%EF%BC%9A%E9%80%9A%E9%81%93%EF%BC%9A%20ch_num(16)%20%EF%BC%81%3D%20evnet_code_end(16)%5B%202.022954%5D%20%5Buni_register_pm_check_unit(153)%5D%3A%20register%20channel_knob%2C%20func%20%3D%200xc02b8d98%5B%202.024185%5D%20fpga%20channel%20knob%20driver%20probe%20%5B0%3B40%3B32m%5B%20OK%20%5D%5B0m%5B%202.025204%5D%26lt%3B5%26gt%3Bkeypad_backlight_probe(161)%3A%20keypad_backlight%20gpio%5B0%2F1%5D%EF%BC%9A181%5B%202.025256%5D%20%E9%94%AE%E7%9B%98%E8%83%8C%E5%85%89%E9%A9%B1%E5%8A%A8%E6%8E%A2%E9%92%88%20%5B0%3B40%3B32m%5B%20OK%20%5D%5B0m%5B%202.025803%5D%20vox%20fpga%20init%20ok%20%5B0%3B40%3B32m%5B%20OK%20%5D%5B0m%5B%202.0m%5B%202.026681%5D%20RTC%20RTC0%3A%20%E6%8A%A5%E8%AD%A6%E7%BF%BB%E8%BD%AC%E6%9C%AA%E5%A4%84%E7%90%86%5B%202.026720%5D%20RTC%20RTC0%3A%20%E6%97%A0%E6%95%88%E6%8A%A5%E8%AD%A6%E5%80%BC%3A%201900-1-1%200%3A0%3A0%5B%202.027090%5D%20RTC%20RTC0%3A%20fffffeb0.rtc%EF%BC%9Adev%20(254%3A0)%5B%202.027149%5D%20at91_rtc%20fffffeb0.rtc%EF%BC%9Artc%20core%3A%20registered%20fffffeb0.rtc%20as%20rtc0%5B%202.027245%5D%20at91_rtc%20fffffeb0.rtc%EF%BC%9AAT91%20%E5%AE%9E%E6%97%B6%E6%97%B6%E9%92%9F%E9%A9%B1%E5%8A%A8%E5%99%A8%E3%80%822.027521%5D%20i2c%20%2Fdev%20entries%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5B%202.029303%5D%20AT91%EF%BC%9A%E5%94%A4%E9%86%92%E5%90%8E%E5%90%AF%E5%8A%A8%5B%202.029773%5D%26lt%3B5%26gt%3Bbq40z80_i2c_probe(69)%3A%20bq40z80%20i2c%20%E6%8E%A2%E6%B5%8B%E6%88%90%E5%8A%9F%5B%20%E3%80%822.030367%5D%20at91_wdt%20fffffe40.watchdog%EF%BC%9Adisable%5B%202.030404%5D%26lt%3B5%26gt%3Bof_at91wdt_init(519)%3A%20sama5d3%20watchdog%20%3A%20sama5d3%20watchdog%20status%20default%20disabled%20in%20the%20dts.%5B%202.030457%5D%26lt%3B5%26gt%3Bat91wdt_check_mask(571)%3A%20sama5d3%20watchdog%20%3A%200x57155155%5B%202.030496%5D%26lt%3B5%26gt%3Bat91wdt_probe(647)%3A%20sama5d3%20watchdog%20%3A%20sama5d3%20watchdog%20status%20set%20enable%20by%20sysfs.%5B%202.2.031079%5D%20%26lt%3B5%26gt%3B%20at91wdt_probe%20(670)%EF%BC%9Asama5d3%20%E7%9C%8B%E9%97%A8%E7%8B%97%EF%BC%9Asama5d3%20%E7%9C%8B%E9%97%A8%E7%8B%97%E6%88%90%E5%8A%9F%E6%B3%A8%E5%86%8C%E4%BA%86%E7%9C%8B%E9%97%A8%E7%8B%97%E8%AE%BE%E5%A4%87%E3%80%82%5B2.031163%5D%26lt%3B5%26gt%3Bat91wdt_probe(679)%3A%20sama5d3%20watchdog%20%3A%20AT91%20WDT%20init%20ok%5B%202.031624%5D%26lt%3B5%26gt%3Bfpga_wdt_get_dts(677)%3A%20fpga%20watchdog%20%3A%20fpga%20watchdog%20default%20enable%20in%20the%20dts.%5B%202.032776%5D%26lt%3B3%26gt%3Bfpga_wdt_reg_status_read(157)%3A%20fpga%20watchdog%20%3A%20fpga%20wdt%20%E4%BB%8E%20status%20reg%20%E8%AF%BB%E5%8F%96%E5%A4%B1%E8%B4%A5%E3%80%822.032938%5D%26lt%3B3%26gt%3Bfpga_wdt_config(693)%3A%20fpga%20watchdog%20%3A%20fpga%20watchdog%20read%20status%20reg%20on%20setup%20failed.%5B..2.032981%5D%26lt%3B3%26gt%3Bfpga_wdt_probe(764)%3A%20fpga%20watchdog%20%3A%20failed%20to%20config%20fpga%20wdt.%5B%202.033018%5D%26lt%3B5%26gt%3Bfpga_wdt_probe(770)%3A%20fpga%20watchdog%20%3A%20fpga%20watchdog%20probe%20ok.%5B%202.033018%5D%202.033272%5D%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%20driver%20ver%202.3%5B%202.033305%5D%20Bluetooth%EF%BC%9AHCI%20UART%20%E5%8D%8F%E8%AE%AE%20BCSP%20%E5%B7%B2%E6%B3%A8%E5%86%8C%5B%202.034207%5D%20atmel_mci%20f0000000.mmc%EF%BC%9A%E7%89%88%E6%9C%AC%EF%BC%9A%200x505%5B%202.034841%5D%20atmel_mci%20f0000000.mmc%EF%BC%9A%E4%BD%BF%E7%94%A8%20dma0chan3%20%E8%BF%9B%E8%A1%8C%20DMA%20%E4%BC%A0%E8%BE%93%5B%202.072889%5D%20atmel_mci%20f0000000.mmc%EF%BC%9AAtmel%20MCI%20%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%8C0xf0000000%20irq%2026%EF%BC%8C1%20%E4%B8%AA%E6%8F%92%E6%A7%BD%5B%202.074162%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(499)%3A%20led0_gpio0%20ctrl%20%E4%BF%A1%E5%8F%B7%E5%88%9D%E5%A7%8B%E5%8C%96%E6%88%90%E5%8A%9F%5B%202.074606%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(526)%3A%20led0_gpio1%20ctrl%20%E4%BF%A1%E5%8F%B7%E5%88%9D%E5%A7%8B%E5%8C%96%E6%88%90%E5%8A%9F%5B%202.075024%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led0%20OK%5B%202.076547%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(499)%3A%20led1_gpio0%20ctrl%20signal%20init%20success%5B%202.078705%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(526)%3A%20led1_gpio1%20ctrl%20signal%20init%20success%5B%202.079168%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led1%20OK%5B%202.079734%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(499)%3A%20led2_gpio0%20ctrl%20signal%20init%20success%5B%202.080221%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(526)%3A%20led2_gpio1%20ctrl%20signal%20init%20success%5B%202.080603%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led2%20OK%5B%202.081202%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(499)%3A%20led3_gpio0%20ctrl%20signal%20init%20success%5B%202.081727%5D%26lt%3B5%26gt%3B%205%26gt%3Bsama5d3_gpio_leds_probe(526)%3A%20led3_gpio1%20ctrl%20signal%20init%20success%5B%202.082124%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led3%20OK%5B%202.082759%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(499)%3A%20led4_gpio0%20ctrl%20signal%20init%20success%5B%202.083352%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(526)%3A%20led4_gpio1%20ctrl%20signal%20init%20success%5B%202.083817%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led4%20OK%5B%202.085076%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(499)%3A%20led5_gpio0%20ctrl%20signal%20init%20success%5B%202.085465%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led5%20OK%5B%202.086755%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(499)%3A%20led6_gpio0%20ctrl%20signal%20init%20success%5B%202.087271%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(526)%3A%20led6_gpio1%20ctrl%20signal%20init%20success%5B%202.087737%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led6%20OK%5B%202.088347%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(499)%3A%20led7_gpio0%20ctrl%20signal%20init%20success%5B%202.088871%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(526)%3A%20led7_gpio1%20ctrl%20signal%20init%20success%5B%202.089315%5D%26lt%3B5%26gt%3B%20sama5d3_gpio_leds_probe(577)%3A%20sama5d3%20led%20driver%20probe%20led7%20OK%5B%202.089890%5D%20usbcore%3A%20registered%20new%20interface%20driver%20usbhid%5B%202.089912%5D%20usbhid%EF%BC%9AUSB%20HID%20%E6%A0%B8%E5%BF%83%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%5B%202.092923%5D%26lt%3B5%26gt%3B%20mcp47feb01_probe(218)%EF%BC%9AMCP47FEB01C%20DAC%20%E8%8A%AF%E7%89%87%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E3%80%822.095692%5D%20bt-sco%20bt-sco%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E6%AD%A3%E5%B8%B8%20%5B2.096381%5D%20tlv320aic32x4%201-0018%EF%BC%9Aaic32x4_i2c_probe%20(27)%EF%BC%9A%E6%8E%A2%E6%B5%8B%20%5B2.096583%5D%20%26lt%3B5%26gt%3B%20tlvaic32x4_probe%20(1325)%EF%BC%9Atlvaic32x4%20%E6%8E%A2%E6%B5%8B%E5%99%A8%E6%AD%A3%E5%B8%B8%20%5B2.120032%5D%20mmc0%EF%BC%9A%E5%85%A8%E6%96%B0%E9%AB%98%E9%80%9F%20SDIO%20%E5%9C%B0%E5%9D%80%E4%B8%BA%200001%20%5B2.135421%5D%20%26lt%3B5%26gt%3B%20aic32x4_probe%20(1154)%EF%BC%9A%E6%8E%A2%E6%B5%8B%E6%AD%A3%E5%B8%B8%20%5B2.135537%5D%20tlv320aic32x4%201-0018%EF%BC%9AasoC%EF%BC%9A%E6%89%BE%E4%B8%8D%E5%88%B0%20HPR%20Power%20%5B2.135569%5D%20tlv320aic32x4%201-0018%20%E7%9A%84%E6%8E%A5%E6%94%B6%E5%99%A8%E5%B0%8F%E9%83%A8%E4%BB%B6%EF%BC%9AASoC%EF%BC%9A%E6%97%A0%E6%B3%95%E5%90%91%20HPR%20%E6%B7%BB%E5%8A%A0%E8%B7%AF%E7%94%B1%20Left%20DAC%20%E8%B7%AF%E7%94%B1-%26gt%3B%20direct-%26gt%3B%20HPR%20Power%20%5B2.135593%5D%20tlv320aic32x4%201-0018%EF%BC%9AasoC%EF%BC%9A%E6%89%BE%E4%B8%8D%E5%88%B0%20HPR%20Power%20%E7%9A%84%E6%BA%90%E6%8E%A7%E4%BB%B6%20%5B2.135616%5D%20tlv320aic32x4%201-0018%EF%BC%9AasoC%EF%BC%9A%E6%97%A0%E6%B3%95%E6%B7%BB%E5%8A%A0%E8%B7%AF%E7%94%B1%20HPR%20Power-%26gt%3B%20direct-%26gt%3B%20HPR%20%5B2.135638%5D%20tlv320aic32x4%201-0018%EF%BC%9AasoC%EF%BC%9A%E6%89%BE%E4%B8%8D%E5%88%B0%E9%BA%A6%E5%85%8B%E9%A3%8E%E7%9A%84%E6%BA%90%E6%8E%A7%E4%BB%B6%20%5B2.135660%5D%20tlv320aic32x4%201-0018%EF%BC%9AASoC%EF%BC%9A%E6%97%A0%E6%B3%95%E6%B7%BB%E5%8A%A0%E8%B7%AF%E7%BA%BF%20Mic-%26gt%3B%20direct-%26gt%3B%20Mic%20Bias%20%5B2.137683%5Datmel-tlv320aic32x4-audio%20%E5%A3%B0%E9%9F%B3%EF%BC%9Atlv320aic32x4-i2s%20%26lt%3B-%26gt%3B%20f800c000.ssc.1%20%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%20%5B2.139543%5D%20%26lt%3B5%26gt%3B%20atmel_asoc_tlv320aic32x4%20%E6%8E%A2%E6%B5%8B%E5%99%A8%E5%A5%BD%20%5B2.142314%5D%20atmel-bluetooth-audio%20%E8%93%9D%E7%89%99%E9%9F%B3%E9%A2%91%20(570)%EF%BC%9Aatmel%20asco%20tlv320aic4x4%20%E6%8E%A2%E6%B5%8B%E5%99%A8%E5%A5%BD%E7%9A%84%20%5B2.142314%5D%20atmel-bluetooth-audio%20%E8%93%9D%E7%89%99%E9%9F%B3%E9%A2%91%20tooth_sound%EF%BC%9Abt-sco-pcm%20%26lt%3B-%26gt%3B%20f0008000.ssc.0%20%E6%98%A0%E5%B0%84%E6%AD%A3%E5%B8%B8%20%5B2.144936%5D%20atmel-bluetooth-audio%20bluetooth_sound%EF%BC%9AALSA%20resigster%20%E8%99%9A%E6%8B%9F%E8%93%9D%E7%89%99%E7%BC%96%E8%A7%A3%E7%A0%81%E5%99%A8%E6%B2%A1%E9%97%AE%E9%A2%98%20%5B2.145674%5D%20NET%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%8D%8F%E8%AE%AE%E7%B3%BB%E5%88%97%2017%20%5B2.145846%5D%20%E6%A1%A5%E6%8E%A5%EF%BC%9A%E9%80%9A%E8%BF%87%20arp%2Fip%2Fip6tables%20%E8%BF%9B%E8%A1%8C%E8%87%AA%E5%8A%A8%E8%BF%87%E6%BB%A4%E5%B7%B2%E8%A2%AB%E5%BC%83%E7%94%A8%E3%80%82%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%EF%BC%8C%E8%AF%B7%E6%9B%B4%E6%96%B0%E6%82%A8%E7%9A%84%E8%84%9A%E6%9C%AC%E4%BB%A5%E5%8A%A0%E8%BD%BD%20br_netfilter%E3%80%82%5B%202.146597%5D%20%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20TTY%20%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%5B2.146657%5D%20%E8%93%9D%E7%89%99%EF%BC%9ARFCOMM%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%5B2.146676%5D%20%E8%93%9D%E7%89%99%EF%BC%9ABNEP%EF%BC%88%E4%BB%A5%E5%A4%AA%E7%BD%91%E4%BB%BF%E7%9C%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.3%20%5B2.146737%5D%20%E8%93%9D%E7%89%99%EF%BC%9ABNEP%20%E8%BF%87%E6%BB%A4%E5%99%A8%EF%BC%9A%E5%8D%8F%E8%AE%AE%E5%A4%9A%E6%92%AD%20%5B2.146766%5D%20%E8%93%9D%E7%89%99%EF%BC%9ABNEP%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%5B2.146797%5D%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHIDP%EF%BC%88%E4%BA%BA%E6%9C%BA%E6%8E%A5%E5%8F%A3%E4%BB%BF%E7%9C%9F%EF%BC%89%E7%89%88%E6%9C%AC%201.2%20%5B2.146825%5D%20%E8%93%9D%E7%89%99%EF%BC%9AHIDP%20%E5%A5%97%E6%8E%A5%E5%AD%97%E5%B1%82%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%5B2.146854%5D%20lib80211%EF%BC%9AIEE802.11%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%B8%B8%E7%94%A8%E4%BE%8B%E7%A8%8B%20%5B2.146871%5D%20lib80211_crypt%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%AE%97%E6%B3%95%20%E2%80%9CNULL%E2%80%9D%20%5B2.146900%5D%20lib80211_crypt%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%AE%97%E6%B3%95%20%E2%80%9CNULL%E2%80%9D%20%5B2.146900%5D%20lib80211_crypt%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%AE%97%E6%B3%95%20'WEP'%20%5B2.146928%5D%20lib80211_crypt%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%AE%97%E6%B3%95%20'CCMP'%20%5B2.146955%5D%20lib80211_crypt%EF%BC%9A%E6%B3%A8%E5%86%8C%E7%AE%97%E6%B3%95%20'TKIP'%20%5B2.154283%5D%20%26lt%3B5%26gt%3B%20sama5d3_oledfb_of_init%20(2150)%EF%BC%9Aof_init%EF%BC%9Aoled_cs%20%3D%201%EF%BC%8COLED_CS_BASE%20%E6%94%B6%E5%88%B0%E4%BA%86%200x40000000%20%5B2.154410%5D%20%26lt%3B5%26gt%3B%20sama5d3_oledfb_of_init%20(2164)%EF%BC%9Aof_init%EF%BC%9Aoled_data_phy_addr%20%3D%200x40004000%20%5B2.154458%5D%20%26lt%3B5%26gt%3B%20sama5d3_oledfb_of_init%20(2176)%EF%BC%9Aof_init%EF%BC%9ASMC_BASE_ADDR%20%E5%BE%97%E5%88%B0%200xFFFC614%20%5B2.154635%5D%20%26lt%3B5%26gt%3B%20sama5d3_oledfb_of_init%20(2206)%EF%BC%9Aof_ini%EF%BC%9A%E9%80%89%E6%8B%A9%E5%B8%A6%E5%AE%BD%EF%BC%888%20%E4%BD%8D%EF%BC%89%5B2.154678%5D%20%26lt%3B5%26gt%3B%20sama5d3_oledfb_of_init%20(22bit)%2012)%3A%20of_init%3A%20%E6%9C%89%20dma%20%5B2.154716%5D%20%5Buni_register_pm_check_unit%20(153)%5D%EF%BC%9A%E6%B3%A8%E5%86%8C%20oled_not_in_sleep%EF%BC%8Cfunc%20%3D%200xc01d0774%20%5B2.156126%5D%20%26lt%3B5%26gt%3B%20set_dma_config%20(953)%EF%BC%9Aoled%20%E4%BD%BF%E7%94%A8%20dma0chan6%20%E8%BF%9B%E8%A1%8C%20DMA%E4%BC%A0%E8%BE%93%20%5B2.156517%5D%20%26lt%3B5%26gt%3B%20get_ft2308_id%20(294)%EF%BC%9A%E9%A2%84%E6%9C%9F%20OLED%20ID%20%E4%B8%BA%200x01%2C0x02%2C0x00%20%5B2.156565%5D%20%26lt%3B5%26gt%3B%20get_ft2308_id%20(295)%EF%BC%9A%E8%8E%B7%E5%8F%96%20OLED%20ID1~DI3%EF%BC%9A0xda%2C0xdb%2C0xdc%20%5B2.189820%5D%20ubi0%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%BF%AB%E9%80%9F%E6%98%A0%E5%B0%84%E6%B1%A0%E5%A4%A7%E5%B0%8F%EF%BC%9A195%20%5B2.181820%5D%20ubi0%EF%BC%9A%E9%BB%98%E8%AE%A4%E5%BF%AB%E9%80%9F%E6%98%A0%E5%B0%84%E6%B1%A0%E5%A4%A7%E5%B0%8F%EF%BC%9A195%20%5B2.181820%5D%209849%5D%20ubi0%EF%BC%9A%E9%BB%98%E8%AE%A4%20fastmap%20WL%20%E6%B1%A0%E5%A4%A7%E5%B0%8F%EF%BC%9A97%20%5B2.189865%5D%20ubi0%EF%BC%9A%E9%99%84%E5%8A%A0%20mtd3%20%5B2.312533%5D%20g_multi%20%E5%B0%8F%E5%B7%A5%E5%85%B7%EF%BC%9A%E5%85%A8%E9%80%9F%E9%85%8D%E7%BD%AE%20%231%EF%BC%9A%E5%B8%A6%E6%9C%89%20RNDIS%20%E7%9A%84%E5%A4%9A%E5%8A%9F%E8%83%BD%20%5B2.734519%5D%20ubi0%EF%BC%9A%E7%94%B1%20fastmap%20%E9%99%84%E5%8A%A0%20%5B2.734549%5D%20ubi0%EF%BC%9Afastmap%20%E6%B1%A0%E5%A4%A7%E5%B0%8F%EF%BC%9A195%20%5B2.734562%5D%20ubi0%EF%BC%9A%E9%99%84%E5%8A%A0%20mtd3%EF%BC%88%E5%90%8D%E7%A7%B0%20%22%20user-fs%20%22%EF%BC%8C%E5%A4%A7%E5%B0%8F%20987%20MiB%EF%BC%89%5B2.754018%5D%20ubi0%EF%BC%9APE0%20B%20%E5%A4%A7%E5%B0%8F%EF%BC%9A262144%20%E5%AD%97%E8%8A%82%20(256%20KiB)%EF%BC%8CLEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%20%5B2.754035%5D%20ubi0%EF%BC%9A%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%2F4096%2C%20sub-page%20size%204096%5B%202.754050%5D%20ubi0%3A%20VID%20header%20offset%EF%BC%9A4096%EF%BC%88%E5%AF%B9%E9%BD%90%204096%EF%BC%89%EF%BC%8C%E6%95%B0%E6%8D%AE%E5%81%8F%E7%A7%BB%EF%BC%9A8192%5B%202.754064%5D%20ubi0%EF%BC%9A%E5%A5%BD%20PEB%EF%BC%9A3946%EF%BC%8C%E5%9D%8F%20PEB%EF%BC%9A4%EF%BC%8C%E6%8D%9F%E5%9D%8F%E7%9A%84%20PEB%EF%BC%9A0%5B%202.754078%5D%20ubi0%EF%BC%9A%E7%94%A8%E6%88%B7%E5%8D%B7%EF%BC%9A9%EF%BC%8C%E5%86%85%E9%83%A8%E5%8D%B7%EF%BC%9A1%2C%20max.volumes%20count%EF%BC%9A128%5B%202.754096%5D%20UBI0%EF%BC%9A%E6%9C%80%E5%A4%A7%2F%E5%B9%B3%E5%9D%87%E6%93%A6%E9%99%A4%E8%AE%A1%E6%95%B0%E5%99%A8%EF%BC%9A214%2F116%EF%BC%8CWL%E9%98%88%E5%80%BC%EF%BC%9A4096%EF%BC%8C%E5%9B%BE%E5%83%8F%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9A1635931764%5B%202.754110%5D%20ubi0%EF%BC%9A%E5%8F%AF%E7%94%A8%20PEB%EF%BC%9A0%EF%BC%8C%E6%80%BB%E9%A2%84%E7%95%99%20PEB%EF%BC%9A3946%EF%BC%8C%E4%B8%BA%E4%B8%8D%E8%89%AF%20PEB%20%E5%A4%84%E7%90%86%E9%A2%84%E7%95%99%E7%9A%84%20PEB%EF%BC%9A76%5B%202.754858%5D%20%5Buni_register_pm_check_unit(153)%5D%3A%20register%20power_knob%2C%20func%20%3D%200xc02b73d4%5B%202.754896%5D%26lt%3B5%26gt%3Baux_register_key(94)%3A%20not%20AUX%20key%2C%20PASS%5B%202.755003%5D%26lt%3B5%26gt%3Baux_register_key(94)%EF%BC%9A%E4%B8%8D%E6%98%AF%20AUX%20%E9%94%AE%EF%BC%8CPASS%5B%202.755105%5D%26lt%3B5%26gt%3Baux_register_key(100)%EF%BC%9A%E8%8E%B7%E5%8F%96%E9%94%AE%EF%BC%9Aaux_eptt_key.2.755203%5D%26lt%3B5%26gt%3Baux_register_key(100)%EF%BC%9A%E8%8E%B7%E5%8F%96%E5%AF%86%E9%92%A5%EF%BC%9A%20aux_ignition_key%E3%80%822.755297%5D%20gpio%20%E5%AF%86%E9%92%A5%E9%A9%B1%E5%8A%A8%E6%8E%A2%E9%92%88%20%5B0%3B40%3B32m%5B%20OK%20%5D%5B0m%5B%202.755725%5D%20at91_rtc%20fffffeb0.rtc%EF%BC%9A%E5%B0%86%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%E4%B8%BA%202007-01-01%2000%3A00%3A06%20UTC%20(1167609606)%20%5B2.757268%5D%20%2Fltc4020%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%BE%97%20%2Fahb%2Fapb%2Fadc%20%E7%9A%84%20%23io-channel-cells%20%40f8018000%20%5B2.757303%5D%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E8%8E%B7%E5%8F%96%20IIO%20%E9%A2%91%E9%81%93%20%2Fltc4020%3A%20vbat-%E6%84%9F%E7%9F%A5%20(0)%20%5B2.757331%5D%20%26lt%3B3%26gt%3B%20ltc4020_iios%20_chn_init%20(343)%EF%BC%9A%E5%9C%A8%20dts%20%E4%B8%AD%E6%9F%A5%E6%89%BE%20vbat-%E6%84%9F%E7%9F%A5%20%E5%A4%B1%E8%B4%A5%E3%80%82%5B2.757366%5D%26lt%3B3%26gt%3Bltc4020_probe(1255)%3A%20ltc4020%20iio%20chn%20init%20failed.%5B2.757778%5D%20ubi0%EF%BC%9A%E5%90%8E%E5%8F%B0%E7%BA%BF%E7%A8%8B%22ubi_bgt0d%22%20%E5%90%AF%E5%8A%A8%EF%BC%8CPID%20658%5B%202.763788%5D%20ltc4020%EF%BC%9Altc4020%20%E6%8E%A2%E6%B5%8B%E5%A4%B1%E8%B4%A5%EF%BC%8C%E9%94%99%E8%AF%AF%20-1%5B%202.764889%5D%26lt%3B5%26gt%3Bfan_probe(403)%3A%20fan%20level%20table%20%3A%5B%202.764936%5D%26lt%3B5%26gt%3Bfan_probe(408)%3A%20fan%20rotate%20level%20%3A%200%2C%20fan%20pwr%20en%20state%20%3A%200%2C%20dac0%20reg%20val%20%3A%200x64.%5B%202.2.764980%5D%26lt%3B5%26gt%3Bfan_probe(408)%3A%20fan%20rotate%20level%20%3A%201%2C%20fan%20pwr%20en%20state%20%3A%201%2C%20dac0%20reg%20val%20%3A%200x64.%5B..2.765022%5D%26lt%3B5%26gt%3Bfan_probe(408)%3A%20fan%20rotate%20level%20%3A%202%2C%20fan%20pwr%20en%20state%20%3A%201%2C%20dac0%20reg%20val%20%3A%200x55.%5B2.765063%5D%26lt%3B5%26gt%3Bfan_probe(408)%3A%20fan%20rotate%20level%20%3A%203%2C%20fan%20pwr%20en%20state%20%3A%201%2C%20dac0%20reg%20val%20%3A%200x46.%5B2.765103%5D%26lt%3B5%26gt%3Bfan_probe(408)%3A%20fan%20rotate%20level%20%3A%204%2C%20fan%20pwr%20en%20state%20%3A%201%2C%20dac0%20reg%20val%20%3A%200x3d.%5B..2.765289%5D%26lt%3B5%26gt%3Bfan_probe(436)%3A%20%E9%A3%8E%E6%89%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E3%80%82%5B2.765542%5D%20clk%EF%BC%9A%E6%9C%AA%E7%A6%81%E7%94%A8%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E6%97%B6%E9%92%9F%20%5B2.765581%5D%20ALSA%20%E8%AE%BE%E5%A4%87%E5%88%97%E8%A1%A8%EF%BC%9A%5B2.765598%5D%20%230%3A%20tlv320aic3204%20%40%20SAMA5D3%20%5B2.765611%5D%20%231%EF%BC%9A%E8%93%9D%E7%89%99%E9%9F%B3%E9%A2%91%20%40%20SAMA5D3%20%5B2.765808%5D%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E5%88%9D%E5%A7%8B%E4%B8%BB%E6%9C%BA%E3%80%82%5B2.832155%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9A%E9%9C%80%E8%A6%81%E6%81%A2%E5%A4%8D%20%5B3.154783%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9A%E6%81%A2%E5%A4%8D%E5%BB%B6%E8%BF%9F%20%5B3.154823%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9AUBI%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E5%8D%B7%201%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20rootfs%20%22%EF%BC%8CR%2FO%20%E6%A8%A1%E5%BC%8F%20%5B3.154846%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%EF%BC%88248%EF%BC%89KiB)%EF%BC%8C%E5%88%86%E9%92%9F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%5B3.154868%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A64757760%20%E5%AD%97%E8%8A%82%EF%BC%8861%20MiB%EF%BC%8C255%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%209142272%20%E5%AD%97%E8%8A%82%EF%BC%888%20MiB%EF%BC%8C36%20LEB%EF%BC%89%5B3.154883%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%5B3.154911%5D%5D%20UBIFS%EF%BC%88ubi%200%3A1%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E4%B8%BA%20w4%2Fr0%EF%BC%89%E3%80%81UUID%201BACF5C4-B91E-47B4-ACA8-82F0D21AEE55%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%5B3.157150%5D%20VFS%EF%BC%9A%E5%9C%A8%E8%AE%BE%E5%A4%87%200%3A12%20%E4%B8%8A%E6%8C%82%E8%BD%BD%E7%9A%84%E6%A0%B9%E7%9B%AE%E5%BD%95%EF%BC%88ubifs%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%89%E5%8F%AA%E8%AF%BB%E3%80%82%5B3.157697%5D%20%E9%87%8A%E6%94%BE%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E5%86%85%E6%A0%B8%E5%86%85%E5%AD%98%EF%BC%9A180K%20(c05f3000-c0620000)%20%5B3.471780%5D%20UBIFS%20(ubi%200%3A0)%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E5%8D%B7%200%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20%E6%A0%A1%E5%87%86%20%22%EF%BC%8CR%2FO%20%E6%A8%A1%E5%BC%8F%20%5B3.471821%5D%20UBIFS%20(ubi%200%3A0)%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%20(248%20KiB)%EF%BC%8C%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%5B3.471847%5D%20UBIFS%EF%BC%88ubi%200%3A0%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A22855680%20%E5%AD%97%E8%8A%82%EF%BC%8821%20MiB%EF%BC%8C90%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%203809280%20%E5%AD%97%E8%8A%82%EF%BC%883%20MiB%EF%BC%8C15%20LEB%EF%BC%89%5B3.471864%5D%20UBIFS%20(ubi%200%3A0)%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%5B3.471890%5D%5D%20UBIFS%EF%BC%88ubi%200%3A0%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E4%B8%BA%20w4%2Fr0%EF%BC%89%E3%80%81UUID%208C0A841D-9F6D-4F4B-A47B-242F17AF30D2%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E6%A8%A1%E5%9E%8B%20%5B3.514476%5D%20%E9%9A%8F%E6%9C%BA%EF%BC%9A%E9%9D%9E%E9%98%BB%E5%A1%9E%E6%B1%A0%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%20%5B3.634316%5D%20UBIFS%EF%BC%88ubi%200%3A2%EF%BC%89%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E7%AC%AC%202%20%E5%8D%B7%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20qpe%20%22%EF%BC%8CR%2FO%20%E6%A8%A1%E5%BC%8F%20%5B3.634356%5D%20UBI%20FS%20(ubi%200%3A2)%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%20(248%20KiB)%EF%BC%8C%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%5B3.634381%5D%20UBIFS%EF%BC%88ubi%200%3A2%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A131801088%20%E5%AD%97%E8%8A%82%EF%BC%88125%20MiB%EF%BC%8C519%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%209404416%20%E5%AD%97%E8%8A%82%EF%BC%888%20MiB%EF%BC%8C38%20LEB%EF%BC%89%5B3.634397%5D%20UBIFS%EF%BC%88ubi%200%3A2%EF%BC%89%EF%BC%9A%E7%95%99%E7%BB%99%20root%EF%BC%9A0%20%E5%AD%97%E8%8A%82%EF%BC%880%20KiB%EF%BC%89%5B3.634397%5D%20UBIFS%20(ubi%200%3A2)%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%5B3.63397%5D%20UBIFS%EF%BC%88ubi%200%3A2%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E4%B8%BA%20w4%2Fr0%EF%BC%89%E3%80%81UUID%20E83FECA1-27DE-4703-B7D8-CB5079BD58DE%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%5B3.761127%5D%20UBIFS%EF%BC%88ubi%200%3A3%EF%BC%89%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E7%AC%AC%203%20%E5%8D%B7%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20defpara%20%22%EF%BC%8CR%2FO%20%E6%A8%A1%E5%BC%8F%20%5B3.761166%5D%20UBIFS%EF%BC%88ubi%200%3A3%EF%BC%89%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A25%25%203952%20%E5%AD%97%E8%8A%82%EF%BC%88248%20KiB%EF%BC%89%EF%BC%8C%E5%88%86%E9%92%9F%E3%80%82%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%5B3.761190%5D%20UBIFS%EF%BC%88ubi%200%3A3%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A18538496%20%E5%AD%97%E8%8A%82%EF%BC%8817%20MiB%EF%BC%8C73%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%203301376%20%E5%AD%97%E8%8A%82%EF%BC%883%20MiB%EF%BC%8C13%20LEB%EF%BC%89%5B3.761206%5D%20UBIFS%20(ubi%200%3A3)%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%5B3.761232%5D%5D%20UBIFS%EF%BC%88ubi%200%3A3%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E6%98%AF%20w4%2Fr0%EF%BC%89%E3%80%81UUID%20A7AE1FB4-18F3-456E-B406-88BF6D1EB1A0%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%5B3.870579%5D%20UBIFS%EF%BC%88ubi%200%3A4%EF%BC%89%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E7%AC%AC%204%20%E5%8D%B7%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20otapara%20%22%EF%BC%8CR%2FO%20%E6%A8%A1%E5%BC%8F%20%5B3.870616%5D%20UBIFS%EF%BC%88ubi%200%3A4%EF%BC%89%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%20(248%20KiB)%EF%BC%8C%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%5B3.870639%5D%20UBIFS%EF%BC%88ubi%200%3A4%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A18538496%20%E5%AD%97%E8%8A%82%EF%BC%8817%20MiB%EF%BC%8C73%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%203301376%20%E5%AD%97%E8%8A%82%EF%BC%883%20MiB%EF%BC%8C13%20LEB%EF%BC%89%5B3.870654%5D%20UBIFS%EF%BC%88ubi%200%3A4%EF%BC%89%EF%BC%9A%E7%95%99%E7%BB%99%20root%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%5B3.870654%5D%20UBIFS%20(ubi%200%3A4)%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%5B3.870654%5D%2070680%5D%20UBIFS%EF%BC%88ubi%200%3A4%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E6%98%AF%20w4%2Fr0%EF%BC%89%E3%80%81UUID%202BAEEFB9-96BE-4423-B712-4BB6807A7EBE%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%5B3.892982%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9A%E5%90%8E%E5%8F%B0%E8%AF%9D%E9%A2%98%20%22%20ubifs_bgt0_7%20%22%20%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CPID%20677%20%5B3.950282%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9A%E9%9C%80%E8%A6%81%E6%81%A2%E5%A4%8D%20%5B4.132101%5D%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9A%E6%81%A2%E5%A4%8D%E5%B7%B2%E5%AE%8C%E6%88%90%20%5B4.132143%5D%20UBIFS%20(ubi%200%3A7)%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E7%AC%AC%207%20%E5%8D%B7%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20%E7%94%A8%E6%88%B7%E6%95%B0%E6%8D%AE%20%22%20%5B4.132166%5D%20UBIFS%20(ubi%200%3A7)%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%20(248%20KiB)%EF%BC%8C%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%5B4.132191%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A520855552%20%E5%AD%97%E8%8A%82%EF%BC%88496%20MiB%EF%BC%8C2051%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%209404416%20%E5%AD%97%E8%8A%82%EF%BC%888%20MiB%EF%BC%8C38%20LEB%EF%BC%89%5B4.132207%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%EF%BC%880%20KiB%EF%BC%89%5B4.132207%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%EF%BC%880%20KiB%EF%BC%89%5B4.132207%5D%20132235%5D%20UBIFS%EF%BC%88ubi%200%3A7%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E6%98%AF%20w4%2Fr0%EF%BC%89%E3%80%81UUID%20E88A1FD7-4C14-4993-BB64-B06940D639FD%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%5B4.138639%5D%20UBIFS%EF%BC%88ubi%200%3A5%EF%BC%89%EF%BC%9A%E5%90%8E%E5%8F%B0%E8%AF%9D%E9%A2%98%20%22%20ubifs_bgt0_5%20%22%20%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CPID%20686%20%5B4.205510%5D%20UBIFS%EF%BC%88ubi%200%3A5%EF%BC%89%EF%BC%9A%E9%9C%80%E8%A6%81%E6%81%A2%E5%A4%8D%20%5B4.272093%5D%20UBIFS%EF%BC%88ubi%200%3A5%EF%BC%89%EF%BC%9A%E6%81%A2%E5%A4%8D%E5%B7%B2%E5%AE%8C%E6%88%90%20%5B4.272135%5D%20UBIFS%20(ubi%200%3A5)%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E7%AC%AC%205%20%E5%8D%B7%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20runpara%20%22%20%5B4.272158%5D%20UBIFS%20(ubi%200%3A5)%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%20(248%20KiB)%EF%BC%8C%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%5B4.272180%5D%20UBIFS%EF%BC%88ubi%200%3A5%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A18538496%20%E5%AD%97%E8%8A%82%EF%BC%8817%20MiB%EF%BC%8C73%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%203301376%20%E5%AD%97%E8%8A%82%EF%BC%883%20MiB%EF%BC%8C13%20LEB%EF%BC%89%5B4.272195%5D%20UBIFS%20(ubi%200%3A5)%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%5B4.272223%5D%5D%20UBIFS%EF%BC%88ubi%200%3A5%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E6%98%AF%20w4%2Fr0%EF%BC%89%E3%80%81UUID%2020E891E0-AAB5-43B6-9068-CAEE4CCFA6B4%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E6%A8%A1%E5%9E%8B%20%5B4.283106%5D%20UBIFS%EF%BC%88ubi%200%3A6%EF%BC%89%EF%BC%9A%E8%83%8C%E6%99%AF%E8%AF%9D%E9%A2%98%20%22%20ubifs_bgt0_6%20%22%20%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CPID%20689%20%5B4.333357%5D%20UBIFS%EF%BC%88ubi%200%3A6%EF%BC%89%EF%BC%9A%E9%9C%80%E8%A6%81%E6%81%A2%E5%A4%8D%20%5B4.498782%5D%20UBIFS%20FS%EF%BC%88ubi%200%3A6%EF%BC%89%EF%BC%9A%E6%81%A2%E5%A4%8D%E5%B7%B2%E5%AE%8C%E6%88%90%20%5B4.498825%5D%20UBIFS%20(ubi%200%3A6)%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E7%AC%AC%206%20%E5%8D%B7%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20%E6%97%A5%E5%BF%97%20%22%20%5B4.498848%5D%20UBIFS%20(ubi%200%3A6)%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%20(248%20KiB)%EF%BC%8C%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%5B4.498870%5D%20UBIFS%EF%BC%88ubi%200%3A6%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A31236096%20%E5%AD%97%E8%8A%82%EF%BC%8829%20MiB%EF%BC%8C123%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%204825088%20%E5%AD%97%E8%8A%82%EF%BC%884%20MiB%EF%BC%8C19%20LEB%EF%BC%89%5B4.498885%5D%20UBIFS%20(ubi%200%3A6)%EF%BC%9A%E7%95%99%E7%BB%99%E6%A0%B9%E7%94%A8%E6%88%B7%EF%BC%9A0%20%E5%AD%97%E8%8A%82%20(0%20KiB)%20%5B4.498912%5D%20UBIFS%20(ubi%200%3A6)%20%5B4.498912%5D%20UBIFS%20(ubi%200%3A6)%20FS%EF%BC%88ubi%200%3A6%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E6%98%AF%20w4%2Fr0%EF%BC%89%E3%80%81UUID%20B53E2A40-EB64-4248-9C15-A08B82484E92%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%5B4.683284%5D%20%26lt%3B5%26gt%3B%20at91_wdt_start%20(313)%EF%BC%9Asama5d3%20%E7%9C%8B%E9%97%A8%E7%8B%97%EF%BC%9Amcu%20%E7%9C%8B%E9%97%A8%E7%8B%97%E5%B7%B2%E7%A6%81%E7%94%A8%EF%BC%8C%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E3%80%82%5B5.620927%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E5%90%8E%E5%8F%B0%E8%AF%9D%E9%A2%98%20%22%20ubifs_bgt0_8%20%22%20%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8CPID%20732%20%5B5.816472%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9AUBIFS%EF%BC%9A%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20UBI%20%E8%AE%BE%E5%A4%87%200%EF%BC%8C%E5%8D%B7%208%EF%BC%8C%E5%90%8D%E7%A7%B0%20%22%20%E6%9B%B4%E6%96%B0%20%22%20%5B5.816514%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9ALEB%20%E5%A4%A7%E5%B0%8F%EF%BC%9A253952%20%E5%AD%97%E8%8A%82%EF%BC%88248%20KiB%EF%BC%89)%EF%BC%8C%E5%88%86%E9%92%9F%2F%E6%9C%80%E5%A4%A7%E3%80%82I%2FO%20%E5%8D%95%E5%85%83%E5%A4%A7%E5%B0%8F%EF%BC%9A4096%20%E5%AD%97%E8%8A%82%2F4096%20%E5%AD%97%E8%8A%82%20%5B5.816541%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9AFS%20%E5%A4%A7%E5%B0%8F%EF%BC%9A130785280%20%E5%AD%97%E8%8A%82%EF%BC%88124%20MiB%EF%BC%8C515%20LEB%EF%BC%89%EF%BC%8C%E6%97%A5%E5%BF%97%E5%A4%A7%E5%B0%8F%206602752%20%E5%AD%97%E8%8A%82%EF%BC%886%20MiB%EF%BC%8C26%20LEB%EF%BC%89%5B5.816557%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E7%95%99%E7%BB%99%20root%EF%BC%9A4952683%20%E5%AD%97%E8%8A%82%EF%BC%884836%20KiB%EF%BC%89)%20%5B5.816584%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E5%AA%92%E4%BD%93%E6%A0%BC%E5%BC%8F%EF%BC%9Aw4%2Fr0%EF%BC%88%E6%9C%80%E6%96%B0%E6%98%AF%20w4%2Fr0%EF%BC%89%E3%80%81UUID%209C8DF7E6-05DA-4D41-A3C5-0029C4D16B41%E3%80%81%E5%B0%8F%E5%9E%8B%20LPT%20%E5%9E%8B%E5%8F%B7%20%5B5.954423%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E5%8D%B8%E8%BD%BD%20UBI%20%E8%AE%BE%E5%A4%87%200%20%5B5.954498%5D%20UBIFS%EF%BC%88ubi%200%3A8%EF%BC%89%EF%BC%9A%E5%90%8E%E5%8F%B0%E8%AF%9D%E9%A2%98%20%22%20ubifs_bgt0_8%20%22%20%E5%81%9C%E6%AD%A2%20%5B106.889343%5D%20%E6%97%A0%E7%BA%BF%E5%B1%80%E5%9F%9F%E7%BD%91%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BDMWLAN%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20%5B106.893826%5D%20wlan%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%88%B0%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%20%5B106.957922%5D%20vendor%3D0x0471%20device%3D0x0205%20class%3D0%20function%3D1%20%5B106.958180%5D%E9%99%84%E5%8A%A0%E6%A8%A1%E6%8B%9F%E5%8F%A5%E6%9F%84%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%8D%A1%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%EF%BC%9A0x109%5B%20106.958223%5D%E6%9C%AA%E6%8C%87%E5%AE%9A%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%20cfg%20%E6%96%87%E4%BB%B6%5B%20106.958246%5D%20combo%20fw%3Anxp%2Fsduart_nw61x.bin.se%20wlan%20fw%3Anxp%2Fsd_w61x.bin.se%5B106.958290%5DSDIO%3A%20sdio_blk_size%3D256%20max_blk_count%3D512%20max_segs%3D64%20max_seg_size%3D4096%5B%20106.958304%5D%20rx_work%3D0%20cpu_num%3D1%5B%20106.958324%EF%BC%BD%E5%90%AF%E7%94%A8%20moal_recv_amsdu_packet%5B%20106.958422%5D%E9%99%84%E5%8A%A0%20mlan%20%E9%80%82%E9%85%8D%E5%99%A8%E6%93%8D%E4%BD%9C%E3%80%82card_type%20%E4%B8%BA%200x109%E3%80%82106.959647%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20TX%20SG%20%E6%A8%A1%E5%BC%8F%5B%20106.959677%5D%20wlan%3A%20mpa_tx.buf_size%3D4096%5B106.959689%5D%20wlan%EF%BC%9A%E5%90%AF%E7%94%A8%20RX%20SG%20%E6%A8%A1%E5%BC%8F%5B%20106.959700%5D%20wlan%3A%20mpa_rx.buf_size%3D4096%5B106.965857%5D%E8%AF%B7%E6%B1%82%E5%9B%BA%E4%BB%B6%EF%BC%9A%20nxp%2Fsd_w61x_v1.bin.se%5B107.096406%5D%E5%94%A4%E9%86%92%E8%AE%BE%E5%A4%87...%20%5B107.344529%5DWlan%EF%BC%9AFW%20%E4%B8%8B%E8%BD%BD%E7%BB%93%E6%9D%9F%EF%BC%8Cfirmwarelen%3D681308%20%E5%B7%B2%E4%B8%8B%E8%BD%BD%20565508%5B%20107.742950%5DWLAN%20FW%20%E5%A4%84%E4%BA%8E%E6%B4%BB%E5%8A%A8%E7%8A%B6%E6%80%81%5B%20107.742992%5D%20on_time%20is%20107730209917%5B%20107.743440%5DQUEUE_CMD%3A%20FUNC_INIT%20%5B0xa9%5D%E5%B7%B2%E6%8E%92%E5%85%A5%E9%98%9F%E5%88%97%5B%20107.743473%EF%BC%BDQUEUE_CMD%3A%20GET_HW_SPEC%20%5B0x3%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.743517%5Ddnld_cmd%20(107.730716)%EF%BC%9AFUNC_INIT%20%5B0xa9%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x263%E3%80%81len%2016%E3%80%81seqno%200x1%20%E8%B6%85%E6%97%B6%205000%20%5B107.766158%5Dcmd_resp%20(107.753332)%EF%BC%9AFUNC_INIT%20%5B0x80a9%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1%5B%20107.766220%5Ddnld_cmd%20(107.753417)%EF%BC%9AGET_HW_SPEC%20%5B0x3%5D%E3%80%81act%200x0%E3%80%81len%2071%E3%80%81seqno%200x2%20%E8%B6%85%E6%97%B6%205000%20%5B107.766565%5D%20107.753753%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B107.766612%5DVDLL_IND%20(OFFSET)%3A%20offset%3D0x1c458%5B%20107.767544%5DVDLL%20%E6%98%A0%E5%83%8F%3A%20len%3D115800%5B%20107.767850%5Dcmd_resp%20(107.755035)%EF%BC%9AGET_HW_SPEC%20%5B0x8003%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20205%EF%BC%8Cseqno%200x2%5B%20107.767880%5D%20fw_cap_info%3D0x487cff03%2C%20dev_cap_mask%3D0xffffffff%5B%20107.767897%5DGET_HW_SPEC%3A%20country_code%3D0x0%5B%20107.767909%5D%20num_ant%3D1%2C%20antinfo%3D0x0%5B%20107.767923%5DGET_HW_SPEC%3A%20hw_mpdu_density%3D4%20dev_mcs_support%3D0x11%5B%20107.767934%5D%E5%90%AF%E7%94%A8%E6%B3%A2%E6%9D%9F%E8%B5%8B%E5%BD%A2%20%5B107.767950%5DGET_HW_SPEC%3A%20mgmt%20IE%20count%3D13%5B%20107.767965%5DFW%3A%20SDIO%20rx%20aggr%20disabled%200x487cff03%5B%20107.767981%5D%20pmadapter-%26gt%3Becsa_enable%3D1%5B%20107.768016%5DQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%5B%20107.768030%5D%20pmadapter-%26gt%3Bgetlog_enable%3D1%5B%20107.768052%5D%20chanrpt%20api%20ver%3D14.1%5B107.768067%5D%20fw_cap_info%3D0x487cff03%20fw_cap_ext%3D0x2182b5%5B%20107.768082%5D%20uuid%3A%20c10d697cf87d596cab35c831392df315%5B%20107.768093%5D%20fw%20hotfix%20ver%3D11%5B%20107.768105%5D%20fw%20ver%3D15.1%5B107.768116%5D%20uap%20fw%20ver%3D2.0%5B107.768127%5D%20max_p2p_conn%20%3D%208%2C%20max_sta_conn%20%3D%2016%5B%20107.768145%5D%20wlan_set_regiontable%3A%202.4G%200x10%5B%20107.768166%5D%20wlan_set_regiontable%EF%BC%9A5G%200x10%5B%20107.768202%5D%E8%8E%B7%E5%8F%96%20Hw%20Spec%20%E5%B7%B2%E5%AE%8C%E6%88%90%EF%BC%8Cfw_cap%3D0x487cff03%5B%20107.768231%5D%20org_drv_mode%3D0x7%20drv_mode%3D0x7%5B%20107.768815%5D%E5%90%AF%E7%94%A8%E6%B3%A2%E6%9D%9F%E8%B5%8B%E5%BD%A2%20%5B107.768873%5DQUEUE_CMD%3A%20802_11_FW_WAKE_METHOD%20%5B0x74%5D%20is%20queued%5B%20107.768901%5D%20set%20tx_buf%20%3D%204096%5B%20107.768922%5DQUEUE_CMD%3A%20RECONFIGURE_TX_BUFF%20%5B0xd9%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.768949%5DPS%20%E5%91%BD%E4%BB%A4%EF%BC%9A%E6%93%8D%E4%BD%9C%20%3D%200x6%EF%BC%8C%E4%BD%8D%E5%9B%BE%20%3D%200x1%5B%20107.768969%5DQUEUE_CMD%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.768999%5DQUEUE_CMD%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.769028%5DQUEUE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.769060%5DQUEUE_CMD%EF%BC%9ACHAN_REGION_CFG%20%5B0x242%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.769091%5DQUEUE_CMD%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%20107.769118%5DQUEUE_CMD%3A%20802_11_RF_TX_POWER%20%5B0x1e%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.769146%5DQUEUE_CMD%EF%BC%9AAMSDU_AGR_CTRL%20%5B0xdf%5D%20%E5%B7%B2%E6%8E%92%E5%85%A5%E9%98%9F%E5%88%97%5B%20107.769174%5DQUEUE_CMD%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.769216%5Ddnld_cmd%20(107.756415)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81act%200x1%E3%80%81len%2015%E3%80%81seqno%200x3%20%E8%B6%85%E6%97%B6%205000%20%5B107.769607%5Dcmd_resp%20(107.756793)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2015%EF%BC%8Cseqno%200x3%5B%20107.769662%5Ddnld_cmd%20(107.756860)%EF%BC%9A802_11_FW_WAKE_METHOD%20%5B0x74%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x0%E3%80%81len%2012%E3%80%81seqno%200x4%20%E8%B6%85%E6%97%B6%205000%20%5B107.769996%5Dcmd_resp%20(107.757182)%EF%BC%9A802_11_FW_WAKE_METHOD%20%5B0x8074%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2018%EF%BC%8Cseqno%200x4%5B%20107.770023%5DFW%20%E5%94%A4%E9%86%92%E6%96%B9%E6%B3%95%3D1%EF%BC%8Cgpio%3D0%5B%20107.770063%EF%BC%BDdnld_cmd%20(107.757261)%EF%BC%9ARECONFIGURE_TX_BUFF%20%5B0xd9%5D%E3%80%81act%200x1%E3%80%81len%2016%E3%80%81seqno%200x5%20%E8%B6%85%E6%97%B6%205000%20%5B107.771157%5Dcmd_resp%20(107.758341)%EF%BC%9ARECONFIGURE_TX_BUFF%20%5B0x80d9%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x5%5B%20107.771188%5D%20%E7%AB%AF%E5%8F%A3%2032%EF%BC%8C%E6%95%B0%E6%8D%AE%E7%AB%AF%E5%8F%A3%E5%B1%8F%E8%94%BD%20ffffffff%5B%20107.771204%5D%20max_tx_buf_size%3D4096%EF%BC%8Ctx_buf_size%3D3328%5B%20107.771246%EF%BC%BDdnld_cmd%20(107.758444)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8Cact%200x6%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x6%20%E8%B6%85%E6%97%B6%205000%20%5B107.771595%5Dcmd_resp%20(107.758781)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x6%5B%20107.771644%5Ddnld_cmd%20(107.758844)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81act%200x1%E3%80%81len%2018%E3%80%81seqno%200x7%20%E8%B6%85%E6%97%B6%205000%20%5B107.771973%5Dcmd_resp%20(107.759162)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2018%EF%BC%8Cseqno%200x7%5B%20107.772022%5Ddnld_cmd%20(107.759222)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8Cact%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x8%20%E8%B6%85%E6%97%B6%205000%20%5B107.772352%5Dcmd_resp%20(107.759539)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x8%5B%20107.772407%5Ddnld_cmd%20(107.759602)%EF%BC%9ACHAN_REGION_CFG%20%5B0x242%5D%E3%80%81act%200x0%E3%80%81len%2011%E3%80%81seqno%200x9%20%E8%B6%85%E6%97%B6%205000%20%5B107.773717%5Dcmd_resp%20(107.760894)%EF%BC%9ACHAN_REGION_CFG%20%5B0x8242%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%201297%EF%BC%8Cseqno%200x9%5B%20107.773819%5Ddnld_cmd%20(107.761014)%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2076%EF%BC%8Cseqno%200xa%20%E8%B6%85%E6%97%B6%205000%20%5B107.774478%5Dcmd_resp%20(107.761658)%EF%BC%9ATX_RATE_CFG%20%5B0x80d6%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20832%EF%BC%8Cseqno%200xa%5B%20107.774538%5Ddnld_cmd%20(107.761736)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%E3%80%81act%200x0%E3%80%81len%2014%E3%80%81seqno%200xb%20%E8%B6%85%E6%97%B6%205000%20%5B107.774893%5Dcmd_resp%20(107.762080)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x801e%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200xb%5B%20107.774946%5Ddnld_cmd%20(107.762143)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0xdf%5D%E3%80%81act%200x1%E3%80%81len%2014%E3%80%81seqno%200xc%20%E8%B6%85%E6%97%B6%205000%20%5B107.775283%5Dcmd_resp%20(107.762469)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0x80df%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200xc%5B107.775329%5D%E3%80%82dnld_cmd%20(107.762529)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200xd%20%E8%B6%85%E6%97%B6%205000%20%5B107.775658%5Dcmd_resp%20(107.762846)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200xd%5B%20107.775711%5DQUEUE_CMD%3A%20APCMD_SYS_CONFIGURE%20%5B0xb0%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.775749%5Ddnld_cmd%20(107.762949)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%E3%80%81act%200x0%E3%80%81len%2020%E3%80%81seqno%200x100e%20%E8%B6%85%E6%97%B6%205000%20%5B107.776811%5Dcmd_resp%20(107.763986)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0x80b0%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x100e%5B%20107.776874%5DQUEUE_CMD%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%5B%20107.776907%5DQUEUE_CMD%3A%20802_11_RF_TX_POWER%20%5B0x1e%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.776937%5DQUEUE_CMD%EF%BC%9AAMSDU_AGR_CTRL%20%5B0xdf%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.776966%5DQUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.776994%5DQUEUE_CMD%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.777031%5Ddnld_cmd%20(107.764231)%EF%BC%9ATX_RATE_CFG%20%5B0xd6%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2076%EF%BC%8Cseqno%200x200f%20%E8%B6%85%E6%97%B6%205000%20%5B107.781332%5Dcmd_resp%20(107.768504)%EF%BC%9ATX_RATE_CFG%20%5B0x80d6%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20832%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x200f%5B107.781397%5D%E3%80%82dnld_cmd%20(107.768592)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x1e%5D%E3%80%81act%200x0%E3%80%81len%2014%E3%80%81seqno%200x2010%20%E8%B6%85%E6%97%B6%205000%20%5B107.781772%5Dcmd_resp%20(107.768958)%EF%BC%9A802_11_RF_TX_POWER%20%5B0x801e%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2010%5B%20107.781826%5Ddnld_cmd%20(107.769023)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0xdf%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x1%EF%BC%8Clen%2014%EF%BC%8Cseqno%200x2011%20%E8%B6%85%E6%97%B6%205000%20%5B107.782166%5Dcmd_resp%20(107.769351)%EF%BC%9AAMSDU_AGGR_CTRL%20%5B0x80df%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2014%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x2011%5B%20107.782215%5Ddnld_cmd%20(107.769414)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200x2012%20%E8%B6%85%E6%97%B6%205000%20%5B107.782555%5Dcmd_resp%20(107.769741)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2012%5B%20107.782608%5Ddnld_cmd%20(107.769805)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2013%20%E8%B6%85%E6%97%B6%205000%20%5B107.783021%5Dcmd_resp%20(107.770204)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2013%5B%20107.783082%5DQUEUE_CMD%3A%20WMM_PARAM_CONFIG%20%5B0x23a%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.783132%5Ddnld_cmd%20(107.770330)%EF%BC%9AWMM_PARAM_CONFIG%20%5B0x23a%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x2%E3%80%81len%2026%E3%80%81seqno%200x14%20%E8%B6%85%E6%97%B6%205000%20%5B107.783476%5Dcmd_resp%20(107.770660)%EF%BC%9AWMM_PARAM_CONFIG%20%5B0x823a%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2026%EF%BC%8Cseqno%200x14%5B%20107.784828%5D%E8%AE%BE%E7%BD%AE%20wiphy%20max_ap_assoc_sta%3D8%5B%20107.784919%5D%20max_rate%3D390M%5B%20107.784934%5D%20max_rate%3D390M%5B%20107.784952%5D%20vht_cap%3D0x33d07030%20rx_mcs_map%3D0xfffe%20rx_max%3D0x186%20tx_mcs_map%3D0xfffe%20tx_max%3D0x186%5B%20107.784970%5D%20max_rate%3D390M%5B%20107.784980%5D%20max_rate%3D390M%5B%20107.784996%5D%20vht_cap%3D0x33d07030%20rx_mcs_map%3D0xfffe%20rx_max%3D0x186%20tx_mcs_map%3D0xfffe%20tx_max%3D0x186%5B%20107.785031%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_RF_ANTENNA%20%5B0x20%5D%20is%20queued%5B%20107.789721%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.776929)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8Cact%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x15%20%E8%B6%85%E6%97%B6%205000%20%5B107.790230%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.777434)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x15%5B%20107.790404%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%5B%20107.790479%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.777692)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x16%20%E8%B6%85%E6%97%B6%205000%20%5B107.790921%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.778126)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x16%5B%20107.791073%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%5B%20107.791142%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.778356)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x17%20%E8%B6%85%E6%97%B6%205000%20%5B107.791587%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.778791)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x17%5B%20107.791740%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%5B%20107.791812%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.779024)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%20142%EF%BC%8Cseqno%200x18%20%E8%B6%85%E6%97%B6%205000%20%5B107.792245%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.779451)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20142%EF%BC%8C%E5%BA%8F%E5%88%97%E5%8F%B7%200x18%20%5B107.792781%5D%20cfg80211%20%E7%9B%91%E7%AE%A1%E5%9F%9F%E5%9B%9E%E8%B0%83%2000%20%E5%90%AF%E5%8A%A8%E5%99%A8%20%3D%200%20dfs_region%3D0%20%5B107.792933%5D%E7%9B%91%E7%AE%A1%E5%8A%9F%E8%83%BD%E5%9F%9F%20BY_CORE%20%5B107.793004%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B107.793250%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.780459)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x20%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200xc%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x19%20%E8%B6%85%E6%97%B6%205000%20%5B107.793746%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.780950)%EF%BC%9A802_11_RF_ANTENNA%20%5B0x8020%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x19%5B%20107.794103%5DPS%20%E5%91%BD%E4%BB%A4%EF%BC%9A%E6%93%8D%E4%BD%9C%20%3D%200x0%EF%BC%8C%E4%BD%8D%E5%9B%BE%20%3D%200x0%5B%20107.794134%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_PS_MODE_ENH%20%5B0xe4%5D%20is%20queued%5B%20107.794212%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.781424)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8Cact%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x1a%20%E8%B6%85%E6%97%B6%205000%20%5B107.794667%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.781872)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2068%EF%BC%8Cseqno%200x1a%5B%20107.794721%5D%20ps_bitmap%3D0x0%5B%20107.794847%5DCFG80211%3A%20Country%3D00%2C%20band%3D0%2C%20no_of_sub_band%3D1%5B%20107.794888%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%5B%20107.794943%5D%2011D%3ACountry%3DWW%20band%3D0%20sub-band%3D1%20dfs_region%3D0%5B%20107.794960%5D%2011D%3A%20first%20chan%3D1%20no_of_chan%3D14%2C%20max_tx_pwr%3D20%5B%20107.794976%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%5B%20107.795005%5D%20wlan_set_regiontable%3A%202.4G%200x0%5B%20107.795030%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%5B%20107.795106%5D%20wlan%25d%EF%BC%9Adnld_cmd%20(107.782316)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2016%E3%80%81seqno%200x1b%20%E8%B6%85%E6%97%B6%205000%20%5B107.795546%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.782751)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1b%5B%20107.795609%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.782821)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81act%200x1%E3%80%81len%2032%E3%80%81seqno%200x1c%20%E8%B6%85%E6%97%B6%205000%20%5B107.796041%5D%20wlan%25d%EF%BC%9A107.783248%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B107.796108%5DVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xe808%20len%20%3D%20600%5B%20107.796136%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.814067%5D%20wlan%25d%3A%20107.801266%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.814148%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xea60%20len%20%3D%20600%5B%20107.814175%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.814855%5D%20wlan%25d%3A%20107.802058%20%EF%BC%9AEvent%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.814929%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xecb8%20len%20%3D%20600%5B%20107.814956%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.815552%5D%20wlan%25d%3A%20107.802757%20%EF%BC%9AEvent%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.815622%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xef10%20len%20%3D%20600%5B%20107.815648%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.816282%5D%20wlan%25d%3A%20107.803486%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.816354%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xf168%20len%20%3D%20600%5B%20107.816381%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.817006%5D%20wlan%25d%3A%20107.804210%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.817078%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xf3c0%20len%20%3D%20600%5B%20107.817104%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.817661%5D%20wlan%25d%3A%20107.804863%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.817734%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xf618%20len%20%3D%20600%5B%20107.817764%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.818332%5D%20wlan%25d%3A%20107.805535%20%EF%BC%9AEvent%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.818407%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xf870%20len%20%3D%20600%5B%20107.818434%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.818999%5D%20wlan%25d%3A%20107.806202%20%EF%BC%9AEvent%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.819071%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D23%20offset%20%3D%200xfac8%20len%20%3D%20600%5B%20107.819097%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.833214%5D%20wlan%25d%3A%20107.820414%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.833298%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D18%20offset%20%3D%200xc4e0%20len%20%3D%20600%5B%20107.833326%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.851074%5D%20wlan%25d%3A%20107.838275%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.851152%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D18%20offset%20%3D%200xc738%20len%20%3D%20600%5B%20107.851180%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.851793%5D%20wlan%25d%3A%20107.838999%20%EF%BC%9AEvent%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.851865%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D18%20offset%20%3D%200xc990%20len%20%3D%20600%5B%20107.851892%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.852417%5D%20wlan%25d%3A%20107.839623%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.852488%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D18%20offset%20%3D%200xcbe8%20len%20%3D%20600%5B%20107.852514%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.853067%5D%20wlan%25d%3A%20107.840270%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.853139%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D18%20offset%20%3D%200xce40%20len%20%3D%20600%5B%20107.853165%5D%20wlan%25d%EF%BC%9ADNLD_VDLL%20%3A%20block_len%3D600%5B%20107.853917%5D%20wlan%25d%EF%BC%9Acmd_resp%20(107.841120)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2032%EF%BC%8Cseqno%200x1c%5B%20107.854070%5DCFG80211%3A%20Country%3D00%2C%20band%3D1%2C%20no_of_sub_band%3D25%5B%20107.854131%5D%2011D%3ACountry%3DWW%20band%3D1%20sub-band%3D25%20dfs_region%3D0%5B%20107.854147%5D%2011D%3A%20first%20chan%3D36%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854160%5D%2011D%3A%20first%20chan%3D40%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854171%5D%2011D%3A%20first%20chan%3D44%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854182%5D%2011D%3A%20first%20chan%3D48%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854193%5D%2011D%3A%20first%20chan%3D52%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854205%5D%2011D%3A%20first%20chan%3D56%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854216%5D%2011D%3A%20first%20chan%3D60%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854228%5D%2011D%3A%20first%20chan%3D64%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854239%5D%2011D%3A%20first%20chan%3D100%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854251%5D%2011D%3A%20first%20chan%3D104%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854263%5D%2011D%3A%20first%20chan%3D108%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854275%5D%2011D%3A%20first%20chan%3D112%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854286%5D%2011D%3A%20first%20chan%3D116%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854298%5D%2011D%3A%20first%20chan%3D120%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854310%5D%2011D%3A%20first%20chan%3D124%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854322%5D%2011D%3A%20first%20chan%3D128%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854333%5D%2011D%3A%20first%20chan%3D132%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854345%5D%2011D%3A%20first%20chan%3D136%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854357%5D%2011D%3A%20first%20chan%3D140%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854368%5D%2011D%3A%20first%20chan%3D144%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854380%5D%2011D%3A%20first%20chan%3D149%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854392%5D%2011D%3A%20first%20chan%3D153%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.%20107.854404%5D11D%3A%20first%20chan%3D157%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854416%5D%2011D%3A%20first%20chan%3D161%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854428%5D%2011D%3A%20first%20chan%3D165%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.854445%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%5B%20107.854475%5D%20wlan_set_regiontable%3A%202.4G%200x0%5B%20107.854495%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%5B%20107.854574%5D%20wlan%25d%EF%BC%9Adnld_cmd%20(107.841784)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81act%200x1%E3%80%81len%20104%E3%80%81seqno%200x1d%20%E8%B6%85%E6%97%B6%205000%20%5B107.876156%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.863356)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20104%EF%BC%8Cseqno%200x1d%5B%20107.876808%5D%E8%AE%BE%E7%BD%AE%20wlan%25d%20%E6%8E%A5%E5%8F%A3%E5%9C%B0%E5%9D%80%EF%BC%9A30%3AXX%3AXX%3AXX%3A8c%3A11%5B%20107.876870%5D%20wlan%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_MAC_ADDRESS%20%5B0x4d%5D%20is%20queued%5B%20107.876956%5D%20wlan%25d%EF%BC%9ADNLD_CMD%20(107.864168)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%E3%80%81act%200x1%E3%80%81len%2016%E3%80%81seqno%200x1e%20%E8%B6%85%E6%97%B6%205000%20%5B107.877442%5D%20wlan%25d%EF%BC%9ACMD_RESP%20(107.864647)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x1e%5B%20107.879187%5D%E6%B3%A8%E5%86%8C%E6%81%A9%E6%99%BA%E6%B5%A6%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20wlan0%5B%20107.879583%5D%20uap%25d%EF%BC%9AQUEUE_CMD%3A%2011AX_CFG%20%5B0x266%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.879698%5D%20wlan0%20set%20multicast_list%5B%20107.879738%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.879772%5D%20wlan0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.892976%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(107.880175)%EF%BC%9A11AX_CFG%20%5B0x266%5D%E3%80%81act%200x1%E3%80%81len%2039%E3%80%81seqno%200x101f%20%E8%B6%85%E6%97%B6%205000%20%5B107.893507%5D%20wlan0%EF%BC%9A107.880712%EF%BC%9A%E4%BA%8B%E4%BB%B6%EF%BC%9AVDLL_IND%20%5B0x81%5D%20%5B107.893585%5DVDLL_IND%3A%20type%3D0%20ID%3D24%20offset%20%3D%200xfd20%20len%20%3D%20600%5B%20107.893614%5D%20wlan0%3A%20DNLD_VDLL%20%3A%20block_len%3D600%5B%20107.911756%5D%20wlan0%3A%20107.898955%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.911843%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D24%20offset%20%3D%200xff78%20len%20%3D%20600%5B%20107.911872%5D%20wlan0%3A%20DNLD_VDLL%20%3A%20block_len%3D600%5B%20107.912558%5D%20wlan0%3A%20107.899762%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.912635%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D24%20offset%20%3D%200x101d0%20len%20%3D%20600%5B%20107.912662%5D%20wlan0%3A%20DNLD_VDLL%20%3A%20block_len%3D600%5B%20107.913268%5D%20wlan0%3A%20107.900472%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.913341%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D24%20offset%20%3D%200x10428%20len%20%3D%20600%5B%20107.913367%5D%20wlan0%3A%20DNLD_VDLL%20%3A%20block_len%3D600%5B%20107.913915%5D%20wlan0%3A%20107.901118%20%EF%BC%9AEvent%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.913988%5DVDLL_IND%3A%20type%3D0%20ID%3D24%20offset%20%3D%200x10680%20len%20%3D%20600%5B%20107.914012%5D%20wlan0%3A%20DNLD_VDLL%20%3A%20block_len%3D600%5B%20107.914567%5D%20wlan0%3A%20107.901770%20%3A%20Event%EF%BC%9AVDLL_IND%20%5B0x81%5D%5B%20107.914645%EF%BC%BDVDLL_IND%3A%20type%3D0%20ID%3D24%20offset%20%3D%200x108d8%20len%20%3D%20600%5B%20107.914672%5D%20wlan0%3A%20DNLD_VDLL%20%3A%20block_len%3D600%5B%20107.915343%5D%20uap%25d%EF%BC%9Acmd_resp%20(107.902546)%EF%BC%9A11AX_CFG%20%5B0x8266%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2039%EF%BC%8Cseqno%200x101f%5B%20107.915409%5D%20user_2g_hecap_len%3D28%5B%20107.915456%5D%20wlan0%3A%20DNLD_CMD%20(107.902667)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81act%200x1%E3%80%81len%20204%E3%80%81seqno%200x20%20%E8%B6%85%E6%97%B6%205000%20%5B107.915901%5D%20wlan0%EF%BC%9ACMD_RESP%20(107.903108)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8C%20result%200%EF%BC%8C%20len%20204%EF%BC%8C%20seqno%200x20%5B%20107.915958%5D%20wlan0%3A%20DNLD_CMD%20(107.903171)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x213%E3%80%81len%2012%E3%80%81seqno%200x21%20%E8%B6%85%E6%97%B6%205000%20%5B107.916292%5D%20wlan0%EF%BC%9ACMD_RESP%20(107.903500)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x21%5B%20107.916457%5D%20uap%25d%EF%BC%9AQUEUE_CMD%3A%2011AX_CFG%20%5B0x266%5D%20is%20queued%5B%20107.916542%5D%20uap%25d%EF%BC%9Adnld_cmd%20(107.903755)%EF%BC%9A11AX_CFG%20%5B0x266%5D%E3%80%81act%200x1%E3%80%81len%2039%E3%80%81seqno%200x1022%20%E8%B6%85%E6%97%B6%205000%20%5B107.917004%5D%20uap%25d%EF%BC%9ACMD_RESP%20(107.904210)%EF%BC%9A11AX_CFG%20%5B0x8266%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2039%EF%BC%8Cseqno%200x1022%5B%20107.917062%5D%20user_hecap_len%3D28%5B%20107.925724%5DSet%20uap%25d%20interface%20addr%3A%2032%3AXX%3AXX%3AXX%3A8d%3A11%5B%20107.925790%5D%20uap%25d%EF%BC%9AQUEUE_CMD%3A%20APCMD_SYS_CONFIGURE%20%5B0xb0%5D%20is%20queued%5B%20107.925886%5D%20uap%25d%EF%BC%9ADNLD_CMD%20(107.913098)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0xb0%5D%E3%80%81act%200x1%E3%80%81len%2020%E3%80%81seqno%200x1023%20%E8%B6%85%E6%97%B6%205000%20%5B107.926382%5D%20uap%25d%EF%BC%9ACMD_RESP%20(107.913587)%EF%BC%9AAPCMD_SYS_CONFIGURE%20%5B0x80b0%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x1023%5B%20107.928101%5D%E6%B3%A8%E5%86%8C%E6%81%A9%E6%99%BA%E6%B5%A6%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20uap0%5B%20107.928429%EF%BC%BDPS%20%E5%91%BD%E4%BB%A4%EF%BC%9A%E6%93%8D%E4%BD%9C%20%3D%200x0%EF%BC%8C%E4%BD%8D%E5%9B%BE%20%3D%200x0%5B%20107.928457%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_PS_MODE_ENH%20%5B0xe4%5D%20is%20queued%5B%20107.928543%5D%20uap0%20set%20multicast_list%5B%20107.929049%5D%20p2p%25d%EF%BC%9Adnld_cmd%20(107.916254)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0xe4%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2024%20%E8%B6%85%E6%97%B6%205000%20%5B107.929566%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(107.916771)%EF%BC%9A802_11_PS_MODE_ENH%20%5B0x80e4%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2068%EF%BC%8Cseqno%200x2024%5B%20107.929623%5D%20ps_bitmap%3D0x0%5B%20107.929729%5DCFG80211%3A%20Country%3D00%2C%20band%3D0%2C%20no_of_sub_band%3D1%5B%20107.929770%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11_SNMP_MIB%20%5B0x16%5D%20is%20queued%5B%20107.929823%5D%2011D%3ACountry%3DWW%20band%3D0%20sub-band%3D1%20dfs_region%3D0%5B%20107.929840%5D%2011D%3A%20first%20chan%3D1%20no_of_chan%3D14%2C%20max_tx_pwr%3D20%5B%20107.929856%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%5B%20107.929885%5D%20wlan_set_regiontable%3A%202.4G%200x0%5B%20107.929906%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%5B%20107.929995%5D%20p2p%25d%EF%BC%9Adnld_cmd%20(107.917205)%EF%BC%9A802_11_SNMP_MIB%20%5B0x16%5D%EF%BC%8Cact%200x1%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2025%20%E8%B6%85%E6%97%B6%205000%20%5B107.930461%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(107.917665)%EF%BC%9A802_11_SNMP_MIB%20%5B0x8016%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2025%5B%20107.930524%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(107.917737)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%2032%E3%80%81seqno%200x2026%20%E8%B6%85%E6%97%B6%205000%20%5B107.952050%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(107.939248)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2032%EF%BC%8Cseqno%200x2026%5B%20107.952237%5DCFG80211%3A%20Country%3D00%2C%20band%3D1%2C%20no_of_sub_band%3D25%5B%20107.952300%5D%2011D%3ACountry%3DWW%20band%3D1%20sub-band%3D25%20dfs_region%3D0%5B%20107.952316%5D%2011D%3A%20first%20chan%3D36%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952329%5D%2011D%3A%20first%20chan%3D40%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952341%5D%2011D%3A%20first%20chan%3D44%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952353%5D%2011D%3A%20first%20chan%3D48%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952364%5D%2011D%3A%20first%20chan%3D52%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952376%5D%2011D%3A%20first%20chan%3D56%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952388%5D%2011D%3A%20first%20chan%3D60%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952399%5D%2011D%3A%20first%20chan%3D64%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952411%5D%2011D%3A%20first%20chan%3D100%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952423%5D%2011D%3A%20first%20chan%3D104%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952435%5D%2011D%3A%20first%20chan%3D108%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952447%5D%2011D%3A%20first%20chan%3D112%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952458%5D%2011D%3A%20first%20chan%3D116%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952470%5D%2011D%3A%20first%20chan%3D120%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952482%5D%2011D%3A%20first%20chan%3D124%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952494%5D%2011D%3A%20first%20chan%3D128%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952505%5D%2011D%3A%20first%20chan%3D132%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952517%5D%2011D%3A%20first%20chan%3D136%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952529%5D%2011D%3A%20first%20chan%3D140%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952541%5D%2011D%3A%20%E7%AC%AC%E4%B8%80%20Chan%3D144%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952553%5D%2011D%3A%20%E7%AC%AC%E4%B8%80%20Chan%3D149%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952565%5D%2011D%3A%20%E7%AC%AC%E4%B8%80%20Chan%3D153%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952576%5D11D%3A%20first%20chan%3D157%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952588%5D%2011D%3A%20first%20chan%3D161%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952600%5D%2011D%3A%20first%20chan%3D165%20no_of_chan%3D1%2C%20max_tx_pwr%3D20%5B%20107.952618%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%3A%20802_11D_DOMAIN_INFO%20%5B0x5b%5D%20is%20queued%5B%20107.952652%5D%20wlan_set_regiontable%3A%202.4G%200x0%5B%20107.952673%5D%20wlan_set_regiontable%EF%BC%9A5G%200x0%5B%20107.952749%5D%20p2p%25d%EF%BC%9Adnld_cmd%20(107.939958)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x5b%5D%E3%80%81%E8%A1%8C%E5%8A%A8%200x1%E3%80%81len%20104%E3%80%81seqno%200x2027%20%E8%B6%85%E6%97%B6%205000%20%5B107.974398%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(107.961599)%EF%BC%9A802_11D_DOMAIN_INFO%20%5B0x805b%5D%EF%BC%8Cresult%200%EF%BC%8Clen%20104%EF%BC%8Cseqno%200x2027%5B%20107.975810%5D%E8%AE%BE%E7%BD%AE%20WFD%20%E8%AE%BE%E5%A4%87%E5%9C%B0%E5%9D%80%EF%BC%9A32%3Axx%3Axx%3Axx%3A8c%3A11%20%5B107.975874%5D%20p2p%25d%EF%BC%9AQUEUE_CMD%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%20%E5%B7%B2%E6%8E%92%E9%98%9F%20%5B107.975962%5D%20p2p%25d%EF%BC%9ADNLD_CMD%20(107.963174)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x4d%5D%E3%80%81act%200x1%E3%80%81len%2016%E3%80%81seqno%200x2028%20%E8%B6%85%E6%97%B6%205000%20%5B107.976455%5D%20p2p%25d%EF%BC%9ACMD_RESP%20(107.963659)%EF%BC%9A802_11_MAC_ADDRESS%20%5B0x804d%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2016%EF%BC%8Cseqno%200x2028%5B%20107.978205%5D%E6%B3%A8%E5%86%8C%E6%81%A9%E6%99%BA%E6%B5%A6%20802.11%20%E9%80%82%E9%85%8D%E5%99%A8%20p2p0%5B%20107.978352%5D%20wlan%3A%20version%20%3D%20SDIW612---18.99.3.p26.11-MM6X18540.p17-(FP92)%5B107.978415%5D%20wlan0%3A%20QUEUE_CMD%3A%20REG_ACCESS%20%5B0x27c%5D%20is%20queued%5B%20107.979033%5D%20p2p0%20set%20multicast_list%5B%20107.979084%5D%20p2p0%3A%20QUEUE_CMD%3A%20MAC_MULTICAST_ADR%20%5B0x10%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.979124%5D%20p2p0%3A%20QUEUE_CMD%3A%20MAC_CONTROL%20%5B0x28%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20107.979189%5D%20wlan0%3A%20DNLD_CMD%20(107.966402)%EF%BC%9AREG_ACCESS%20%5B0x27c%5D%E3%80%81act%200x0%E3%80%81len%2020%E3%80%81seqno%200x29%20%E8%B6%85%E6%97%B6%205000%20%5B107.979694%5D%20wlan0%EF%BC%9ACMD_RESP%20(107.966899)%EF%BC%9ACMD_RESP%20(107.966899)%EF%BC%9AREG_ACCESS%20%5B0x827c%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x29%5B%20107.979776%5D%20p2p0%3A%20DNLD_CMD%20(107.966989)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x10%5D%E3%80%81act%200x1%E3%80%81len%20204%E3%80%81seqno%200x202a%20%E8%B6%85%E6%97%B6%205000%20%5B107.980228%5D%20p2p0%EF%BC%9ACMD_RESP%20(107.967434)%EF%BC%9AMAC_MULTICAST_ADR%20%5B0x8010%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%20204%EF%BC%8Cseqno%200x202a%5B%20107.980285%5D%20p2p0%3A%20DNLD_CMD%20(107.967498)%EF%BC%9AMAC_CONTROL%20%5B0x28%5D%E3%80%81act%200x213%E3%80%81len%2012%E3%80%81seqno%200x202b%20%E8%B6%85%E6%97%B6%205000%20%5B107.980607%5D%20p2p0%EF%BC%9ACMD_RESP%20(107.967814)%EF%BC%9AMAC_CONTROL%20%5B0x8028%5D%EF%BC%8Cresult%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x202b%5B%20108.023067%5D%E8%AE%BE%E7%BD%AE%20REG%200x90002328%3A%200x13d57%20slew_rate%3D3%5B%20108.023135%5D%20wlan0%3A%20QUEUE_CMD%3A%20REG_ACCESS%20%5B0x27c%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20108.023231%5D%20wlan0%3A%20DNLD_CMD%20(108.010442)%EF%BC%9AREG_ACCESS%20%5B0x27c%5D%E3%80%81act%200x1%E3%80%81len%2020%E3%80%81seqno%200x2c%20%E8%B6%85%E6%97%B6%205000%20%5B108.023738%5D%20wlan0%EF%BC%9ACMD_RESP%20(108.010941)%EF%BC%9AREG_ACCESS%20%5B0x827c%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2020%EF%BC%8Cseqno%200x2c%5B%20108.023925%5D%20wlan0%3A%20QUEUE_CMD%3A%20INDEPENDENT_RESET_CFG%20%5B0x243%5D%20%E6%AD%A3%E5%9C%A8%E6%8E%92%E9%98%9F%5B%20108.024006%5D%20wlan0%3A%20DNLD_CMD%20(108.011218)%EF%BC%9AINDEPENDENT_RESET_CFG%20%5B0x243%5D%EF%BC%8C%E8%A1%8C%E5%8A%A8%200x0%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2d%20%E8%B6%85%E6%97%B6%205000%20%5B108.024460%5D%20wlan0%EF%BC%9ACMD_RESP%20(108.011666)%EF%BC%9AINDEPENDENT_RESET_CFG%20%5B0x8243%5D%EF%BC%8C%E7%BB%93%E6%9E%9C%200%EF%BC%8Clen%2012%EF%BC%8Cseqno%200x2d%20%5B108.025121%5D%20wlan%EF%BC%9A%E6%B3%A8%E5%86%8C%E5%88%B0%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%AE%8C%E6%88%90%20%5B108.025146%5D%20wlan%EF%BC%9A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E6%88%90%E5%8A%9F%E5%8A%A0%E8%BD%BD%3C%2FC000F3F8%3E%3C%2FC0479308%3E%3C%2FC0479308%3E%3C%2FC05F3D80%3E%3C%2FC05F3D80%3E%3C%2FC000961C%3E%3C%2FC000961C%3E%3C%2FC06132C4%3E%3C%2FC06132C4%3E%3C%2FC06133C0%3E%3C%2FC06133C0%3E%3C%2FC001FC2C%3E%3C%2FC001FC2C%3E%3C%2FC001FBD0%3E%3C%2FC001FBD0%3E%3C%2FC00125DC%3E%3C%2FC00125DC%3E%3C%2FC001499C%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3Elog0326.txt%3C%2FP%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%89%A7%E9%80%8F%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E9%AB%98%E4%BA%AE%E9%83%A8%E5%88%86%E5%8F%AF%E4%BE%9B%E9%98%85%E8%AF%BB%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%3CP%3E%3CBR%20%2F%3E(%E6%97%A0)%20%E7%99%BB%E5%BD%95%EF%BC%9A%3CBR%20%2F%3E(%E6%97%A0)%20%E7%99%BB%E5%BD%95%EF%BC%9Aroot%3CBR%20%2F%3E%E5%AF%86%E7%A0%81%EF%BC%9A%3CBR%20%2F%3E%5Broot%40br03%20~%5D%23%20cd%20%2Fuserdata%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20rm%20dmesg0325%3CBR%20%2F%3Edmesg0325-1.txt%20dmesg0325-2.txt%20dmesg0325.txt%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20rm%20dmesg0325%3CBR%20%2F%3Edmesg0325-1.txt%20dmesg0325-2.txt%20dmesg0325.txt%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20rm%20dmesg0325*%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20dmesg%26gt%3Bdmesg0326-1.txt%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20insmod%20mlan.ko%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20insmod%20moal.ko%20drv_mode%3D7%20ps_mode%3D2%20auto_ds%3D2%20host_mlme%3D1%20cal_data_cfg%3Dn%3CBR%20%2F%3Eone%20fw_name%3Dnxp%2Fsd_w61x_v1.bin.se%20sta_name%3Dwlan%20wfd_name%3Dp2p%20cfg80211_wext%3D0xf%20drvdbg%3D0x80037%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20dmesg%26gt%3Bdmesg0326-2.txt%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fw%3CBR%20%2F%3Ewifi_mod_para.conf%20wpa_cli%20wpa_supplicant%20wpa_supplicant.conf%3CBR%20%2F%3Ewlan.ko%20wpa_cli-old%20wpa_supplicant-old%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fwpa_supplicant%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20ls%20-lh%20wpa_*%3CBR%20%2F%3E-rwxr-xr-x%201%20root%200%20313.8K%20Jan%201%2000%3A03%20wpa_cli%3CBR%20%2F%3E-rwxr-xr-x%201%20root%200%2083.6K%20Jan%201%2000%3A14%20wpa_cli-old%3CBR%20%2F%3E-rwxr-xr-x%201%20root%200%2014.7M%20Jan%201%2000%3A02%20wpa_supplicant%3CBR%20%2F%3E-rwxr-xr-x%201%20root%200%201.8M%20Jan%201%2000%3A13%20wpa_supplicant-old%3CBR%20%2F%3E-rw-r--r--%201%20root%200%20281%20Jan%201%202007%20wpa_supplicant.conf%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fwpa_supplicant-B-Dnl80211-iwlan0-c%20%2Fetc%2Fwpa_supplicant.conf%20%3CBR%20%2F%3E%20%E6%88%90%E5%8A%9F%E5%88%9D%E5%A7%8B%E5%8C%96%20wpa_supplicant%20rfkill%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%20RFKILL%20%E6%8E%A7%E5%88%B6%E8%AE%BE%E5%A4%87%20%5Broot%20%40br03%20%2Fuserdata%5D%20%23%20ps%7Cgrep%20wpa%201358%20root%200%3A00%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%2Fwpa_supplicant-B%20-Dnl80211%20-iwlan0%20-c%20%2Fetc%2Fwpa_supplicant.conf%3CBR%20%2F%3E1372%20root%200%3A00%20grep%20wpa%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20ifconfig%20-a%3CBR%20%2F%3Elo%20Link%20encap%3ALocal%20Loopback%3CBR%20%2F%3Einet%20addr%3A127.0.0.1%20Mask%3A255.0.0.0%3CBR%20%2F%3EUP%20LOOPBACK%20%E8%BF%90%E8%A1%8C%20MTU%3A%2065536%20%E6%8C%87%E6%A0%87%3A1%20%3CBR%20%2F%3E%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%3A0%20%E9%94%99%E8%AF%AF%3A0%20%E4%B8%A2%E5%BC%83%3A0%20%E6%BA%A2%E5%87%BA%3A0%20%E5%B8%A7%3A0%20TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%3A0%20%E9%94%99%E8%AF%AF%3A0%20%E4%B8%A2%E5%BC%83%3A0%20%E8%B6%85%E9%99%90%3A0%20%E8%BD%BD%E6%B3%A2%3A0%20%E7%A2%B0%E6%92%9E%3A0%20txqueuelen%3A%201%20RX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Ep2p0%20Link%20encap%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWaddr%2032%3A4%20A%3A%20C%204%3A9%20E%3A%208%20C%3A%2011%20%3CBR%20%2F%3E%20%E5%B9%BF%E6%92%AD%E5%A4%9A%E6%92%AD%20MTU%3A%201500%20%E6%8C%87%E6%A0%87%EF%BC%9A1%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%20T%20%3CBR%20%2F%3E%20X%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%20%E7%A2%B0%E6%92%9E%EF%BC%9A0%20txqueuelen%EF%BC%9A1000%20RX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0)%20B)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Euap0%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWaddr%2032%3A4%20A%3A%20C%204%3A9%20E%3A%208D%3A%2011%20%3CBR%20%2F%3E%20%E5%B9%BF%E6%92%AD%E5%A4%9A%E6%92%AD%20MTU%3A%201500%20%E6%8C%87%E6%A0%87%EF%BC%9A1%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%20T%20%3CBR%20%2F%3E%20X%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%20%E7%A2%B0%E6%92%9E%EF%BC%9A0%20txqueuelen%EF%BC%9A1000%20RX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B))%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Eusb0%20Link%20encap%3AEthernet%20HWaddr%2012%3A56%3A59%3A21%3A22%3A05%3CBR%20%2F%3Einet%20addr%3A10.10.0.12Bcast%3A0.0.0.0%20Mask%3A255.255.0.0%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E5%A4%9A%E6%92%AD%E5%B9%BF%E6%92%AD%E7%9A%84%20MTU%3A%201500%20%E6%8C%87%E6%A0%87%3A1%20%E4%B8%AA%20%3CBR%20%2F%3E%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%3A740%20%E9%94%99%E8%AF%AF%3A0%20%E4%B8%A2%E5%BC%83%3A124%20%E8%B6%85%E8%BD%BD%3A0%20%E5%B8%A7%3A0%20TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%3A360%20%E9%94%99%E8%AF%AF%3A0%20%E4%B8%A2%E5%BC%83%3A0%20%E8%B6%85%E8%BD%BD%3A0%20%E8%BD%BD%E6%B3%A2%3A0%20%E7%A2%B0%E6%92%9E%3A0%20txqueuelen%3A%201000%20RX%20%E5%AD%97%E8%8A%82%3A38831%20(37.9%20KiB)%20TX%20%E5%AD%97%E8%8A%82%3A106517%20(104.0)%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3EKiB)%3C%2FP%3E%3CP%3Ewlan0%20Link%20encap%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWaddr%2030%3A4%20A%3A%20C%204%3A9%20E%3A%208%20C%3A%2011%20U%20%3CBR%20%2F%3E%20P%20%E5%B9%BF%E6%92%AD%E5%A4%9A%E6%92%AD%20MTU%3A%201500%20%E6%8C%87%E6%A0%87%EF%BC%9A1%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E8%BD%BD%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%20T%20%3CBR%20%2F%3E%20X%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E9%99%90%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%20txqueuelen%EF%BC%9A1000%20RX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0)%20B)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%5Broot%40br03%20%2Fuserdata%5D%23%20ifconfig%3CBR%20%2F%3Elo%20Link%20encap%3ALocal%20Loopback%3CBR%20%2F%3Einet%20addr%3A127.0.0.1%20Mask%3A255.0.0.0%3CBR%20%2F%3EUP%20LOOPBACK%20%E8%BF%90%E8%A1%8C%20MTU%3A%2065536%20%E6%8C%87%E6%A0%87%3A1%20%3CBR%20%2F%3E%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%3A0%20%E9%94%99%E8%AF%AF%3A0%20%E4%B8%A2%E5%BC%83%3A0%20%E6%BA%A2%E5%87%BA%3A0%20%E5%B8%A7%3A0%20TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%3A0%20%E9%94%99%E8%AF%AF%3A0%20%E4%B8%A2%E5%BC%83%3A0%20%E8%B6%85%E9%99%90%3A0%20%E8%BD%BD%E6%B3%A2%3A0%20%E7%A2%B0%E6%92%9E%3A0%20txqueuelen%3A%201%20RX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Eusb0%20Link%20encap%3AEthernet%20HWaddr%2012%3A56%3A59%3A21%3A22%3A05%3CBR%20%2F%3Einet%20addr%3A10.10.0.12Bcast%3A0.0.0.0%20Mask%3A255.255.0.0%3CBR%20%2F%3E%E5%90%AF%E5%8A%A8%E5%B9%BF%E6%92%AD%E8%BF%90%E8%A1%8C%E5%A4%9A%E6%92%AD%20MTU%EF%BC%9A1500%20%E6%8C%87%E6%A0%87%EF%BC%9A1%20%E4%B8%AA%20%3CBR%20%2F%3E%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A750%20%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A124%20%E4%B8%AA%E8%B6%85%E8%BD%BD%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%20TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A367%20%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E8%BD%BD%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%20%E7%A2%B0%E6%92%9E%EF%BC%9A0%20txqueuelen%EF%BC%9A1000%20RX%20%E5%AD%97%E8%8A%82%EF%BC%9A39238%20(38.3%20KiB)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A109073%20(106.5%20KiB%3CBR%20%2F%3E)%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Ewlan0%20Link%20encap%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWaddr%2030%3A4%20A%3A%20C%204%3A9%20E%3A%208%20C%3A%2011%20U%20%3CBR%20%2F%3E%20P%20%E5%B9%BF%E6%92%AD%E5%A4%9A%E6%92%AD%20MTU%3A%201500%20%E6%8C%87%E6%A0%87%EF%BC%9A1%20RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E8%BD%BD%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%20T%20%3CBR%20%2F%3E%20X%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E9%99%90%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%20txqueuelen%EF%BC%9A1000%20RX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0)%20B)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fwpa_cli-i%20wlan0%20-g%2Fvar%2Frun%2Fwpa_supplicant%2Fwlan0%20ap_scan%201%3CBR%20%2F%3EOK%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fwpa_cli-i%20wlan0%20-g%2Fvar%2Frun%2Fwpa_supplicant%2Fwlan0%20scan%3CBR%20%2F%3EOK%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20wpa_cli%20-i%20wlan0%20-g%2Fvar%2Frun%2Fwpa_supplicant%2Fwlan0%20scan_result%3CBR%20%2F%3Ebssid%20%2F%20frequency%20%2F%20signal%20level%20%2F%20flags%20%2F%20ssid%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20dmesg%26gt%3B%20dmesg0326-3.txt%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20rm%20file_%3CBR%20%2F%3Efile_drv_info%20file_fwdump%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20rm%20file_*%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20cp%20%2Fvar%2F%3CBR%20%2F%3Edump_332%2Flib%2F%20run%2F%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20cp%20%2Fvar%2Fdump_332%2Ffile_%3CBR%20%2F%3Efile_drv_info%20file_fwdump%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20cp%20%2Fvar%2Fdump_332%2Ffile_*%20.%2F%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fdownload.sh%20dmesg0326-1.txt%3CBR%20%2F%3Edmesg0326-1.txt%20100%25%20%7C************************************************************%7C%2032427%200%3A00%3A00%20ETA%3CBR%20%2F%3E-rw-r--r--%201%20root%200%2031.7K%20Jan%201%2000%3A01%20dmesg0326-1.txt%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fdownload.sh%20dmesg0326-2.txt%3CBR%20%2F%3Edmesg0326-2.txt%20100%25%20%7C************************************************************%7C%2055782%200%3A00%3A00%20ETA%3CBR%20%2F%3E-rw-r--r--%201%20root%200%2054.5K%20Jan%201%2000%3A03%20dmesg0326-2.txt%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fdownload.sh%20dmesg0326-3.txt%3CBR%20%2F%3Edmesg0326-3.txt%20100%25%20%7C************************************************************%7C%2062694%200%3A00%3A00%20ETA%3CBR%20%2F%3E-rw-r--r--%201%20root%200%2061.2K%20Jan%201%2000%3A06%20dmesg0326-3.txt%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fdownload.sh%20file_fwdump%3CBR%20%2F%3Efile_fwdump%20100%25%20%7C************************************************************%7C%201375k%200%3A00%3A00%20ETA%3CBR%20%2F%3E-rw-r--r--%201%20root%200%201.3M%20Jan%201%2000%3A06%20file_fwdump%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fdownload.sh%20file_%3CBR%20%2F%3Efile_drv_info%20file_fwdump%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fdownload.sh%20file_drv_info%3CBR%20%2F%3Efile_drv_info%20100%25%20%7C************************************************************%7C%20411k%200%3A00%3A00%20ETA%3CBR%20%2F%3E-rw-r--r--%201%20root%200%20411.3K%20Jan%201%2000%3A06%20file_drv_info%3CBR%20%2F%3E%5Broot%40br03%20%2Fuserdata%5D%23%20%3C%2FP%3E%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E(%E6%97%A0)%20%E7%99%BB%E5%BD%95%EF%BC%9A(%E6%97%A0)%20%E7%99%BB%E5%BD%95%EF%BC%9Aroot%20%E5%AF%86%E7%A0%81%EF%BC%9A%5Broot%40br03%20~%5D%23%20cd%20%2Fuserdata%5Broot%40br03%20%2Fuserdata%5D%23%20rm%20dmesg0325dmesg0325-1.txt%20dmesg0325-2.txt%20dmesg0325.txt%5Broot%40br03%2Fuserdata%5D%23%20rm%20dmesg0325dmesg0325-1.txt%20dmesg0325-2.txt%20dmesg0325.txt%5Broot%40br03%2Fuserdata%5D%23%20rm%20dmesg0325*%5Broot%40br03%20%2Fuserdata%5D%23%20dmesg%26gt%3Bdmesg0326-1.txt%5Broot%40br03%2Fuserdata%5D%23%20insmod%20mlan.ko%5Broot%40br03%2Fuserdata%5D%23%20insmod%20moal.ko%20drv_mode%3D7%20ps_mode%3D2%20auto_ds%3D2%20host_mlme%3D1%20cal_data_cfg%3Dnone%20fw_name%3Dnxp%2Fsd_w61x_v1.bin.se%20sta_name%3Dwlan%20wfd_name%3Dp2p%20cfg80211_wext%3D0xf%20drvdbg%3D0x80037%5Broot%40br03%20%2Fuserdata%5D%23%20dmesg%26gt%3Bdmesg0326-2.txt%5Broot%40br03%2Fuserdata%5D%23%20.%2Fwwifi_mod_para.conf%20wpa_cli%20wpa_supplicant%20wpa_supplicant.confwlan.ko%20wpa_cli-old%20wpa_supplicant-old%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fwpa_supplicant%5Broot%40br03%2Fuserdata%5D%23%20ls%20-lh%20wpa_*-rwxr-xr-x%201%20root%200%20313.8K%20Jan%201%2000%3A03%20wpa_cli-rwxr-xr-x%201%20root%200%2083.6K%20Jan%201%2000%3A14%20wpa_cli-old-rwxr-xr-x%201%20root%200%2014.7M%20Jan%201%2000%3A02%20wpa_supplicant-rwxr-xr-x%201%20root%200%201.8M%20Jan%201%2000%3A13%20wpa_supplicant-old-rw-r--r--%201%20root%200%20281%20Jan%201%202007%20wpa_supplicant.conf%5Broot%40br03%2Fuserdata%5D%23%20.%2Fwpa_supplicant-B-Dnl80211-iwlan0-c%20%2Fetc%2Fwpa_supplicant.conf%20%E6%88%90%E5%8A%9F%E5%88%9D%E5%A7%8B%E5%8C%96%20wpa_supplicantrfkill%EF%BC%9A%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%20RFKILL%20%E6%8E%A7%E5%88%B6%E8%AE%BE%E5%A4%87%20%5Broot%20%40br03%20%2Fuserdata%5D%20%23%20ps%7Cgrep%20wpa1358%20root%200%3A00%E3%80%82%2Fwpa_supplicant-B%20-Dnl80211%20-iwlan0%20-c%20%2Fetc%2Fwpa_supplicant.conf1372%20root%200%3A00%20grep%20wpa%5Broot%40br03%20%2Fuserdata%5D%23%20ifconfig%20-alo%20Link%20encap%3ALocal%20Loopbackinet%20addr%3A127.0.0.1%20Mask%3A255.0.0.0UP%E7%8E%AF%E5%9B%9E%E8%BF%90%E8%A1%8C%20MTU%3A%2065536%20%E6%8C%87%E6%A0%87%3A1RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%3A0%20%E9%94%99%E8%AF%AF%3A0%20%E4%B8%A2%E5%BC%83%3A0%20%E8%B6%85%E9%99%90%3A0%20%E5%B8%A7%3A0TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%3A0%20%E9%94%99%E8%AF%AF%3A0%20%E4%B8%A2%E5%BC%83%3A0%20%E6%BA%A2%E5%87%BA%3A0%20%E8%B6%85%E8%BD%BD%3A0%20%E8%BD%BD%E4%BD%93%3A0%20%E7%A2%B0%E6%92%9E%3A0%20txQueuelen%3A%201RX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20p2p0%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%3A%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%A1%AC%E4%BB%B6%20addr%2032%3A4%20A%3A%20C%204%3A9%20E%3A%208C%3A%2011%20%E5%B9%BF%E6%92%AD%E5%A4%9A%E6%92%AD%20MTU%3A%201500%20%E6%8C%87%E6%A0%87%3A1RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%3A0%20%E9%94%99%E8%AF%AF%3A0%20%E4%B8%A2%E5%BC%83%3A0%20%E8%B6%85%E8%BD%BD%3A0%20%E5%B8%A7%3A0TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%3A0%20%E9%94%99%E8%AF%AF%3A0%20%E4%B8%A2%E5%BC%83%3A0%20%E8%B6%85%E8%BD%BD%3A0%20%E8%BD%BD%E6%B3%A2%3A0%20%E8%BD%BD%E4%BD%93%3A0%20%E7%A2%B0%E6%92%9E%3A0%20TxQueuelen%3A%201000RX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20TX%20B)%20uap0%20Link%20encap%3A%20Ethernet%20HWaddr%2032%3A4%20A%3A%20C%204%3A9%20E%3A%208D%3A%2011BROADCAST%20%E5%A4%9A%E6%92%AD%20MTU%3A%201500%20%E6%8C%87%E6%A0%87%3A1RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%3A0%20%E9%94%99%E8%AF%AF%3A0%20%E4%B8%A2%E5%BC%83%3A0%E8%B6%85%E9%99%90%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E8%BD%BD%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%20%E7%A2%B0%E6%92%9E%EF%BC%9A0%20TxQueuelen%EF%BC%9A1000RX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20usb0%20%E9%93%BE%E6%8E%A5%E5%B0%81%E8%A3%85%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWADDR%2012%3A56%3A59%3A21%3A22%3A05%20inet%20%E5%9C%B0%E5%9D%80%EF%BC%9A10.10.0.12Bcast%3A0.0.0.0%20Mask%3A255.255.0.0UP%E5%B9%BF%E6%92%AD%E8%BF%90%E8%A1%8C%E5%A4%9A%E6%92%AD%20MTU%3A%201500%20%E6%8C%87%E6%A0%87%3A1RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%3A740%20%E9%94%99%E8%AF%AF%3A0%20%E4%B8%A2%E5%BC%83%3A124%20%E8%B6%85%E8%BD%BD%3A0%20%E5%B8%A7%3A0TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%3A360%20%E9%94%99%E8%AF%AF%3A0%20%E4%B8%A2%E5%BC%83%3A0%20%E8%B6%85%E8%BD%BD%3A0%20%E8%BD%BD%E6%B3%A2%3A0%20%E7%A2%B0%E6%92%9E%3A0%20txQueuelen%3A%201000RX%20%E5%AD%97%E8%8A%82%3A38831%20(37.9%20KiB)%20TX%20%E5%AD%97%E8%8A%82%3A106517%20(104.0)KiB)%20wlan0%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWaddr%2030%3A4%20A%3A%20C%204%3A9%20E%3A%208C%3A%2011UP%20%E5%B9%BF%E6%92%AD%E5%A4%9A%E6%92%AD%20MTU%3A%201500%20%E6%8C%87%E6%A0%87%EF%BC%9A1RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E8%BD%BD%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E8%BD%BD%EF%BC%9A0%20%E8%BF%90%E8%90%A5%E5%95%86%EF%BC%9A0%20%E7%A2%B0%E6%92%9E%EF%BC%9A0%20TxQueuelen%3A%201000RX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%3A0%20(0.0%20B)%20%5Broot%20%40br03%20%2Fuserdata%5D%20%23%20ifconfiglo%20Link%20encap%3A%20Local%20Loopbackinet%20%E5%9C%B0%E5%9D%80%3A127.0.0.1%20%E6%8E%A9%E7%A0%81%3A255.0.0.0UP%E7%8E%AF%E5%9B%9E%E8%BF%90%E8%A1%8C%20MTU%EF%BC%9A65536%20%E6%8C%87%E6%A0%87%EF%BC%9A1RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E9%99%90%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E8%B6%85%E8%BD%BD%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%20%E7%A2%B0%E6%92%9E%EF%BC%9A0%20txQueuelen%EF%BC%9A1RX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20usb0%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWADDD%2012%3A56%3A59%3A21%3A22%3A05%20inet%20%E5%9C%B0%E5%9D%80%3A10.10.0.12Bcast%3A0.0.0.0%20Mask%3A255.255.0.0UP%E5%B9%BF%E6%92%AD%E8%BF%90%E8%A1%8C%E5%A4%9A%E6%92%AD%20MTU%EF%BC%9A1500%20%E6%8C%87%E6%A0%87%EF%BC%9A1RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A750%20%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A124%20%E4%B8%AA%E8%B6%85%E8%BD%BD%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A367%20%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E8%BD%BD%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%20%E7%A2%B0%E6%92%9E%EF%BC%9A0%20txQueuelen%EF%BC%9A1000RX%20%E5%AD%97%E8%8A%82%EF%BC%9A39238%20(38.3%20KiB)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A109073%20(106.5%20KiB)%20wlan0%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWADDR%2030%3A4%20A%3A%20C%204%3A9%20E%3A%208C%3A%2011UP%20%E5%B9%BF%E6%92%AD%E5%A4%9A%E6%92%AD%20MTU%3A%201500%20%E6%8C%87%E6%A0%87%EF%BC%9A1RX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E5%B7%B2%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0TX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E8%BD%BD%E4%BD%93%EF%BC%9A0%20%E7%A2%B0%E6%92%9E%EF%BC%9A0%20TxQueuelen%3A%201000RX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20%5Broot%20%40br03%20%2Fuserdata%5D%20%23%E3%80%82%2Fwpa_cli-i%20wlan0%20-g%2Fvar%2Frun%2Fwpa_supplicant%2Fwlan0%20ap_scan%201OK%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fwpa_cli-i%20wlan0%20-g%2Fvar%2Frun%2Fwpa_supplicant%2Fwlan0%20scanOK%5Broot%40br03%20%2Fuserdata%5D%23%20wpa_cli%20-i%20wlan0%20-g%2Fvar%2Frun%2Fwpa_supplicant%2Fwlan0%20scan_resultbssid%20%2F%20frequency%20%2F%20signal%20level%20%2F%20flags%20%2F%20ssid%5Broot%40br03%20%2Fuserdata%5D%23%20dmesg%26gt%3B%20dmesg0326-3.txt%5Broot%40br03%2Fuserdata%5D%23%20rm%20file_file_drv_info%20file_fwdump%5Broot%40br03%20%2Fuserdata%5D%23%20rm%20file_*%5Broot%40br03%20%2Fuserdata%5D%23%20cp%20%2Fvar%2Fdump_332%2F%20lib%2F%20run%2F%5Broot%40br03%20%2Fuserdata%5D%23%20cp%20%2Fvar%2Fdump_332%2Ffile_file_drv_info%20file_fwdump%5Broot%40br03%20%2Fuserdata%5D%23%20cp%20%2Fvar%2Fdump_332%2Ffile_*%20.%2F%5Broot%40br03%2Fuserdata%5D%23%20.%2Fdownload.sh%20dmesg0326-1.txtdmesg0326-1.txt%20100%25%20%7C************************************************************%7C%2032427%200%3A00%3A00%20ETA-rw-r--r--%201%20root%200%2031.7K%20Jan%201%2000%3A01%20dmesg0326-1.txt%5Broot%40br03%2Fuserdata%5D%23%20.%2Fdownload.sh%20dmesg0326-2.txtdmesg0326-2.txt%20100%25%20%7C************************************************************%7C%2055782%200%3A00%3A00%20ETA-rw-r--r--%201%20root%200%2054.5K%20Jan%201%2000%3A03%20dmesg0326-2.txt%5Broot%40br03%2Fuserdata%5D%23%20.%2Fdownload.sh%20dmesg0326-3.txtdmesg0326-3.txt%20100%25%20%7C************************************************************%7C%2062694%200%3A00%3A00%20ETA-rw-r--r--%201%20root%200%2061.2K%20Jan%201%2000%3A06%20dmesg0326-3.txt%5Broot%40br03%2Fuserdata%5D%23%20.%2Fdownload.sh%20file_fwdumpfile_fwdump%20100%25%20%7C************************************************************%7C%201375k%200%3A00%3A00%20ETA-rw-r--r--%201%20root%200%201.3M%20Jan%201%2000%3A06%20file_fwdump%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fdownload.sh%20file_file_drv_info%20file_fwdump%5Broot%40br03%20%2Fuserdata%5D%23%20.%2Fdownload.sh%20file_drv_info%20file_drv_info%20100%25%20%7C************************************************************%7C%20411k%200%3A00%3A00%20ETA-rw-r--r--%201%20root%200%20411.3K%20Jan%201%2000%3A06%20file_drv_info%5Broot%40br03%20%2Fuserdata%5D%23%20%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2340700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AW611%20WiFi%20chip%20Wi-Fi%20scan%20timeout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2340700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F250148%22%20target%3D%22_blank%22%3E%40eric25%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AE%A9%E6%88%91%E4%B8%8E%E5%A4%A7%E5%AE%B6%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E6%88%91%E7%9A%84%20wpa_supplicant.conf%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%20AP%20%E7%AB%AF%EF%BC%8C%E5%BA%94%E8%AE%BE%E7%BD%AE%20wpa2%EF%BC%8C%E8%AF%B7%E6%B3%A8%E6%84%8F%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3Ectrl_interface%3D%2Fvar%2Frun%2Fwpa_supplicant%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3Eupdate_config%3D1%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3Ep2p_noo_group_iface%3D1%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3E%E7%BD%91%E7%BB%9C%3D%7B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3E%20%20%20%20ssid%3D%22%E6%82%A8%E7%9A%84%20SSID%22%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3E%20%20%20%20psk%3D%22%E6%82%A8%E7%9A%84%E9%80%9A%E8%A1%8C%E8%AF%81%22%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3E%20%20%20%20proto%3DRSN%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3E%20%20%20%20key_mgmt%3DWPA-PSK%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3E%20%20%20%20%E6%88%90%E5%AF%B9%3DCCMP%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3E%20%20%20%20group%3DCCMP%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CEM%3E%3CSTRONG%3E%E8%AF%B7%E5%A1%AB%E5%86%99%E6%82%A8%E7%9A%84%20AP%20SSID%20%E5%92%8C%E5%AF%86%E7%A0%81%EF%BC%8C%E4%BB%A5%E5%8F%96%E4%BB%A3%22YOUR%20SSID%22%2C%22YOUR%20PASSWORD%22%20%E3%80%82%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3E%E5%8D%AB%E4%B8%9C%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2344509%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AW611%20WiFi%20chip%20Wi-Fi%20scan%20timeout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2344509%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F250148%22%20target%3D%22_blank%22%3E%40eric25%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%9C%8B%E5%88%B0%E4%BD%A0%E7%9A%84log%E6%96%87%E4%BB%B6%E6%98%AF%E4%B8%AD%E6%96%87%EF%BC%8C%E9%82%A3%E4%B9%88%E6%88%91%E8%BF%99%E9%87%8C%E7%94%A8%E4%B8%AD%E6%96%87%E5%92%8C%E4%BD%A0%E8%AE%A8%E8%AE%BA%EF%BC%8C%E8%AF%B7%E7%94%A8%E4%B8%8B%E9%9D%A2%E5%91%BD%E4%BB%A4%E7%A1%AE%E8%AE%A4%E6%98%AF%E5%90%A6%E4%BD%A0%E7%9A%84%E7%B3%BB%E7%BB%9F%E6%9C%89rfkill%EF%BC%8C%E9%98%BB%E6%AD%A2%E4%BA%86WIFI%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BB%8E%E6%89%AB%E6%8F%8F%E7%BB%93%E6%9E%9C%E7%9C%8B%EF%BC%9A%E4%BD%A0%E7%9A%84WIFI%20wlan0%EF%BC%8C%E6%B2%A1%E6%9C%89%E6%89%AB%E6%8F%8F%E5%88%B0AP%E3%80%82%E6%89%AB%E6%8F%8F%E7%BB%93%E6%9E%9C%E6%98%AF%E7%A9%BA%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E8%BF%98%E4%B8%8D%E8%A1%8C%EF%BC%8C%E8%AF%B7%E6%8A%8A%E4%BD%A0WIFI%E9%83%A8%E5%88%86%E7%9A%84%E5%8E%9F%E7%90%86%E5%9B%BE%E7%BB%99%E6%88%91%E7%9C%8B%E4%B8%80%E4%B8%8B%EF%BC%8C%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E9%82%AE%E4%BB%B6%EF%BC%9Aweidong.sun%40nxp.com%E3%80%82%3C%2FP%3E%0A%3CDIV%3Erfkill%20unblock%20all%3C%2FDIV%3E%0A%3CDIV%3Eifconfig%20wlan0%20down%3C%2FDIV%3E%0A%3CDIV%3Eifconfig%20wlan0%20up%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E5%9C%A8%E5%90%AF%E5%8A%A8wpa%20supplicant%2C%20%E6%B5%8B%E8%AF%95%E4%B8%80%E4%B8%8B%EF%BC%8C%E4%B8%BB%E8%A6%81%E7%9C%8B%E6%9C%89%E6%B2%A1%E6%9C%89%E6%89%AB%E6%8F%8F%E7%9A%84AP%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FDIV%3E%0A%3CDIV%3E%E4%BC%9F%E4%B8%9C%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2344396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AW611%20WiFi%20chip%20Wi-Fi%20scan%20timeout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2344396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E8%AF%A6%E5%B0%BD%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%88%91%E5%90%AC%E4%BB%8E%E4%BA%86%E4%BD%A0%E7%9A%84%E5%BB%BA%E8%AE%AE%E3%80%82%E9%97%AE%E9%A2%98%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%20-%20%E5%AE%83%E7%BB%A7%E7%BB%AD%E6%98%BE%E7%A4%BA%E6%89%AB%E6%8F%8F%E8%B6%85%E6%97%B6%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%BB%BB%E4%BD%95%20Wi-Fi%20%E7%83%AD%E7%82%B9%E3%80%82%E6%A0%B9%E6%8D%AE%E6%97%A5%E5%BF%97%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E5%B8%AE%E5%8A%A9%E5%88%86%E6%9E%90%E5%8F%AF%E8%83%BD%E7%9A%84%E5%8E%9F%E5%9B%A0%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
