AN14114: RF Test Mode on Linux OS
1,972件の閲覧回数
sert1m
We are using IW610G with single antenna for our device and preparing commands for FCC test. We have several questions about RF test mode.
FW versions:
Kernel: lf-6.12.3-1.0.0
mwifiex: lf-6.12.20_2.0.0
imx-firmware: lf-6.12.20_2.0.0
1. Can we start TX on one device and receive packets on another device with same settings (band, channel etc)? As described at step 8 of this manual:
https://docs.nxp.com/bundle/AN14114/page/topics/5ghz_rx_command_sequence.html
2. When we are trying to change bandwidth from 40 MHz or 80MHz we receive error in dmesg. It also seems like 80MHz can only be applied to 5GHz band but it is not mention in the manual:
https://docs.nxp.com/bundle/AN14114/page/topics/set_the_channel_bandwidth.html
Here is when we are trying to change bandwidth to 80MHz on 2.4GHz.
echo 'rf_test_mode=1' >> '/proc/mwlan/adapter0/config'
echo 'tx_continuous=0' >> '/proc/mwlan/adapter0/config'
echo 'tx_frame=0' >> '/proc/mwlan/adapter0/config'
echo 'radio_mode=11 0' >> '/proc/mwlan/adapter0/config'
echo 'band=0' >> '/proc/mwlan/adapter0/config'
echo 'bw=4' >> '/proc/mwlan/adapter0/config'
echo 'channel=1' >> '/proc/mwlan/adapter0/config'
kernel: RF test mode cmd error
echo 'tx_antenna=1' >> '/proc/mwlan/adapter0/config'
echo 'rx_antenna=1' >> '/proc/mwlan/adapter0/config'
echo 'tx_power=0 0 0' >> '/proc/mwlan/adapter0/config'
echo 'tx_continuous=1 0 0x00000AAA 0 3 1' >> '/proc/mwlan/adapter0/config'
Here is when we are trying to change bandwidth to 40MHz on 2.4GHz.
echo 'bw=1' >> '/proc/mwlan/adapter0/config'
kernel: 5:185m5:185mRFTM_COMMAND ERROR: 0xffffffff
We still can see that bandwidth parameter was applied in the config. Is this error code critical?
hardware_status=0
netlink_num=31
drv_mode=7
hssetpara=7,0xff,200,400
sdcmd52rw=0 0x0 0x00
rf_test_mode=1
tx_antenna=1
rx_antenna=1
band=0
bw=1
channel=1
radio_mode[0]=11
radio_mode[1]=
total rx pkt count=0
rx multicast/broadcast pkt count=0
rx fcs error pkt count=0
tx_power=
tx_continuous=1 0 0xaaa 0 3 1
tx_frame=0
he_tb_tx=0
trigger_frame=0
otp_mac_add_rd_wr= 00:00:00:00:00:00
antcfg=0x1
3. IW610G supports 802.11n/a/g/b and 802.11ax. For TX  Frame and TX Continuous there is possibility to set data rate. It depends on the standard.
https://docs.nxp.com/bundle/AN14114/page/topics/data_rates.html
But some data rates do not apply and generate error. For example:
echo 'bw=0' >> '/proc/mwlan/adapter0/config'
echo 'tx_continuous=1 0 0x00000AAA 0 3 47' >> '/proc/mwlan/adapter0/config'
kernel: 5:185m5:185mRFTM_COMMAND ERROR: 0x0000001b
Config still looks like settings were applied. Is this error code critical? Is there any description for such error codes?
hardware_status=0
netlink_num=31
drv_mode=7
rf_test_mode=1
tx_antenna=1
rx_antenna=1
band=0
bw=0
channel=1
radio_mode[0]=11
radio_mode[1]=
tx_power=
tx_continuous=1 0 0xaaa 0 3 47
tx_frame=0
he_tb_tx=0
trigger_frame=0
antcfg=0x1
タグ(2)
3 返答(返信)
1,947件の閲覧回数
shaun_wu
Hello @sert1m
--> It is ok, but why you do so? If you are trying to use antenna to test rf signal, please make sure radio environment is good.
--> 2.4GHz not support 80MHz bandwidth.
--> The datarate should match modulation method, you could search internal for the corresponds relationship.
Best Regards
Shaun
1,903件の閲覧回数
sert1m
Hello @shaun_wu !
Thank you for our response!
--> We are trying to test anthena. Unfortynatly, when we start RX on one device and TX on another with the same band, modulation, chanel etc, we cannot see "rx pkt count" etc to be changed.
--> Got it. But what about error "kernel: 5:185m5:185mRFTM_COMMAND ERROR: 0xffffffff " what we set 40 MHz bandwidth? Should it be ignored?
--> Got it, thank you! We will search for it.
タグ(2)
1,888件の閲覧回数
shaun_wu
Hello @sert1m
Your test case is like a signalling test, it is different from non-signalling test. For signalling test, you should make DUT work as STA or AP. So that DUT could receive or transmit to destination correctly. wi-fi communication needs pairing, connection ect..
--> I observe your input already vailed in configure file, so, no problem.
%3CLINGO-SUB%20id%3D%22lingo-sub-2249385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAN14114%3A%20Linux%20OS%20%E4%B8%8A%E3%81%AE%20RF%20%E3%83%86%E3%82%B9%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E5%BC%8A%E7%A4%BE%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%81%AF%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%E3%81%AEIW610G%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81FCC%E3%83%86%E3%82%B9%E3%83%88%E7%94%A8%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82RF%E3%83%86%E3%82%B9%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%3EFW%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3A%20lf-6.12.3-1.0.0%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%3Emwifiex%3A%20lf-6.12.20_2.0.0%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%3Eimx%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3A%20lf-6.12.20_2.0.0%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E1.%20%E3%81%82%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E9%80%81%E4%BF%A1%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%80%81%E5%90%8C%E3%81%98%E8%A8%AD%E5%AE%9A%EF%BC%88%E3%83%90%E3%83%B3%E3%83%89%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AA%E3%81%A9%EF%BC%89%E3%81%A7%E5%88%A5%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%93%E3%81%AE%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E6%89%8B%E9%A0%868%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14114%2Fpage%2Ftopics%2F5ghz_rx_command_sequence.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14114%2Fpage%2Ftopics%2F5ghz_rx_command_sequence.html%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2.%20%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%82%9240MHz%E3%81%BE%E3%81%9F%E3%81%AF80MHz%E3%81%8B%E3%82%89%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81dmesg%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%8180MHz%E3%81%AF5GHz%E5%B8%AF%E3%81%AB%E3%81%AE%E3%81%BF%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14114%2Fpage%2Ftopics%2Fset_the_channel_bandwidth.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14114%2Fpage%2Ftopics%2Fset_the_channel_bandwidth.html%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%812.4GHz%20%E3%81%A7%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%82%92%2080MHz%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eecho%20'rf_test_mode%3D1'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_continuous%3D0'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_frame%3D0'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'radio_mode%3D11%200'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'band%3D0'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'bw%3D4'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'channel%3D1'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Akernel%3A%20RF%20test%20mode%20cmd%20error%20%0Aecho%20'tx_antenna%3D1'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'rx_antenna%3D1'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_power%3D0%200%200'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_continuous%3D1%200%200x00000AAA%200%203%201'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%812.4GHz%20%E3%81%A7%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%82%92%2040MHz%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eecho%20'rf_test_mode%3D1'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_continuous%3D0'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_frame%3D0'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'radio_mode%3D11%200'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'band%3D0'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'bw%3D1'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Akernel%3A%205%3A185m5%3A185mRFTM_COMMAND%20ERROR%3A%200xffffffff%20%0Aecho%20'channel%3D1'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_antenna%3D1'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'rx_antenna%3D1'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_power%3D0%200%200'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_continuous%3D1%200%200x00000AAA%200%203%201'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%E3%81%A7%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%BE%E3%81%A0CAN%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E9%87%8D%E5%A4%A7%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ehardware_status%3D0%20%0Anetlink_num%3D31%20%0Adrv_mode%3D7%20%0Ahssetpara%3D7%2C0xff%2C200%2C400%20%0Asdcmd52rw%3D0%200x0%200x00%20%0Arf_test_mode%3D1%20%0Atx_antenna%3D1%20%0Arx_antenna%3D1%20%0Aband%3D0%20%0Abw%3D1%20%0Achannel%3D1%20%0Aradio_mode%5B0%5D%3D11%20%0Aradio_mode%5B1%5D%3D%20%0Atotal%20rx%20pkt%20count%3D0%20%0Arx%20multicast%2Fbroadcast%20pkt%20count%3D0%20%0Arx%20fcs%20error%20pkt%20count%3D0%20%0Atx_power%3D%20%0Atx_continuous%3D1%200%200xaaa%200%203%201%20%0Atx_frame%3D0%20%0Ahe_tb_tx%3D0%20%0Atrigger_frame%3D0%20%0Aotp_mac_add_rd_wr%3D%2000%3A00%3A00%3A00%3A00%3A00%20%20%0Aantcfg%3D0x1%20%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E3.%3C%2FSPAN%3E%20%3CSPAN%3EIW610G%E3%81%AF802.11n%2Fa%2Fg%2Fb%E3%81%8A%E3%82%88%E3%81%B3802.11ax%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82TX%20Frame%E3%81%A8TX%20Continuous%E3%81%A7%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E8%A8%AD%E5%AE%9A%E3%81%AF%E8%A6%8F%E6%A0%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14114%2Fpage%2Ftopics%2Fdata_rates.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CSPAN%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14114%2Fpage%2Ftopics%2Fdata_rates.html%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%3A%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eecho%20'rf_test_mode%3D1'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_continuous%3D0'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_frame%3D0'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'radio_mode%3D11%200'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'band%3D0'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'bw%3D0'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'channel%3D1'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_antenna%3D1'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'rx_antenna%3D1'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_power%3D0%200%200'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Aecho%20'tx_continuous%3D1%200%200x00000AAA%200%203%2047'%20%26gt%3B%26gt%3B%20'%2Fproc%2Fmwlan%2Fadapter0%2Fconfig'%20%0Akernel%3A%205%3A185m5%3A185mRFTM_COMMAND%20ERROR%3A%200x0000001b%20%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%E3%81%AF%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E9%87%8D%E5%A4%A7%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ehardware_status%3D0%20%0Anetlink_num%3D31%20%0Adrv_mode%3D7%20%0Ahssetpara%3D7%2C0xff%2C200%2C400%20%0Asdcmd52rw%3D0%200x0%200x00%20%0Arf_test_mode%3D1%20%0Atx_antenna%3D1%20%0Arx_antenna%3D1%20%0Aband%3D0%20%0Abw%3D0%20%0Achannel%3D1%20%0Aradio_mode%5B0%5D%3D11%20%0Aradio_mode%5B1%5D%3D%20%0Atotal%20rx%20pkt%20count%3D0%20%0Arx%20multicast%2Fbroadcast%20pkt%20count%3D0%20%0Arx%20fcs%20error%20pkt%20count%3D0%20%0Atx_power%3D%20%0Atx_continuous%3D1%200%200xaaa%200%203%2047%20%0Atx_frame%3D0%20%0Ahe_tb_tx%3D0%20%0Atrigger_frame%3D0%20%0Aotp_mac_add_rd_wr%3D%2000%3A00%3A00%3A00%3A00%3A00%20%20%0Aantcfg%3D0x1%20%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN14114%3A%20RF%20Test%20Mode%20on%20Linux%20OS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245903%22%20target%3D%22_blank%22%3E%40sert1m%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%81%82%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E9%80%81%E4%BF%A1%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%80%81%E5%90%8C%E3%81%98%E8%A8%AD%E5%AE%9A%EF%BC%88%E3%83%90%E3%83%B3%E3%83%89%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AA%E3%81%A9%EF%BC%89%E3%81%A7%E5%88%A5%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%93%E3%81%AE%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%978%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E--%26gt%3B%20%E3%81%9D%E3%82%8C%E3%81%AF%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%AA%E3%81%9CSO%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20RF%20%E4%BF%A1%E5%8F%B7%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E7%84%A1%E7%B7%9A%E7%92%B0%E5%A2%83%E3%81%8C%E8%89%AF%E5%A5%BD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%82%92%2040%20MHz%20%E3%81%BE%E3%81%9F%E3%81%AF%2080%20MHz%20%E3%81%8B%E3%82%89%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81dmesg%20%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%8180MHz%20%E3%81%AF%205GHz%20%E5%B8%AF%E5%9F%9F%E3%81%AB%E3%81%AE%E3%81%BF%20CAN%20%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E--%26gt%3B%202.4GHz%20%E3%81%AF%2080MHz%20%E3%81%AE%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E--%26gt%3B%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF%E5%A4%89%E8%AA%BF%E6%96%B9%E6%B3%95%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E9%96%A2%E4%BF%82%E3%82%92%E5%86%85%E9%83%A8%E3%81%A7%E6%A4%9C%E7%B4%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2251946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN14114%3A%20RF%20Test%20Mode%20on%20Linux%20OS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2251946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186613%22%20target%3D%22_blank%22%3E%40shaun_wu%3C%2FA%3E%20%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%AA%E3%81%9CSO%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6RF%E4%BF%A1%E5%8F%B7%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E7%84%A1%E7%B7%9A%E7%92%B0%E5%A2%83%E3%81%8C%E8%89%AF%E5%A5%BD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E--%26gt%3B%20anthena%20%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E5%90%8C%E3%81%98%E3%83%90%E3%83%B3%E3%83%89%E3%80%81%E5%A4%89%E8%AA%BF%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AA%E3%81%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%811%20%E3%81%A4%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%20RX%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%80%81%E5%88%A5%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%20TX%20%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%80%8Crx%20pkt%20count%E3%80%8D%E3%81%AA%E3%81%A9%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E2.4GHz%E3%81%AF80MHz%E3%81%AE%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3CBR%20%2F%3E--%26gt%3B%20%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%80%8C%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E5%3A185m5%3A185mRFTM_%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E0xffffffff%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%22%2040%20MHz%20%E3%81%AE%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%20%E7%84%A1%E8%A6%96%E3%81%97%E3%81%A6%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF%E5%A4%89%E8%AA%BF%E6%96%B9%E5%BC%8F%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E9%96%A2%E4%BF%82%E3%82%92%E5%86%85%E9%83%A8%E3%81%A7%E6%A4%9C%E7%B4%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E--%26gt%3B%20%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AN14114%3A%20RF%20Test%20Mode%20on%20Linux%20OS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245903%22%20target%3D%22_blank%22%3E%40sert1m%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AECASE%E3%81%AF%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%80%81%E9%9D%9E%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%86%E3%82%B9%E3%83%88%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%B7%E3%82%B0%E3%83%8A%E3%83%AA%E3%83%B3%E3%82%B0%20%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81DUT%20%E3%82%92%20STA%20%E3%81%BE%E3%81%9F%E3%81%AF%20AP%20%E3%81%A8%E3%81%97%E3%81%A6%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82DUT%20%E3%81%8C%E5%AE%9B%E5%85%88%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%8F%E5%8F%97%E4%BF%A1%E3%81%BE%E3%81%9F%E3%81%AF%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%82Wi-Fi%20%E9%80%9A%E4%BF%A1%E3%81%AB%E3%81%AF%E3%83%9A%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%80%81%E6%8E%A5%E7%B6%9A%E3%81%AA%E3%81%A9%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%80%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%EF%BC%9A%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E5%3A185m5%3A185mRFTM_%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E0xffffffff%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%22%2040%20MHz%20%E3%81%AE%E5%B8%AF%E5%9F%9F%E5%B9%85%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%20%E7%84%A1%E8%A6%96%E3%81%97%E3%81%A6%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22%22%3E--%26gt%3B%20%E5%85%A5%E5%8A%9B%E5%86%85%E5%AE%B9%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%20configure%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
