silly question
2,906件の閲覧回数
Nouchi
Senior Contributor II
How to convert axf file to plain binnary from DS-5. I tried "fromelf" command, but it complain about DS license.
Emmanuel
Edit:
Found :
In project properties->C/C++ Build->Settings->Build Steps tab->Post-build steps : fromelf --bin --output=outfile infile
ラベル(6)
2,534件の閲覧回数
timesyssupport
Hi Emmanuel,
You are correct, you can use the 'fromelf' utility to convert from an .axf to a .bin.
If you have a Vybrid Tower kit, this comes with a one year license for DS-5. Please check your TWR-VF65GS10 box for the pamphlet with the DS-5 link.
Timesys Support
3 返答(返信)
2,535件の閲覧回数
timesyssupport
Hi Emmanuel,
Timesys Support
2,534件の閲覧回数
Nouchi
It wasn't a real license problem, I just used fromelf outside eclipse, it wasn't a good idea. Using it in eclipse with the Post-build steps option works fine.
Emmanuel
2,534件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport can you attend this case?
