long long int , lld in printf /sprintf is not working
1,790 次查看
karthigeyannata
We are using GCC compiler for vybrid processor. Using long long int data type in our code and trying to print value using "lld" in printf/sprintf.
It seems that it is not working....There seems to be endianess problem (32bit words are reversed)
Kindly advise how to overcome this issue
karthi
2 回复数
1,544 次查看
timesyssupport
Senior Contributor II
Hello Karthi,
Can you provide some more details on the toolchain you are using? Who is providing it, or are you generating your own toolchain?
Are you using any build system to provide your rootfs/toolchain, as in Timesys or Yocto?
Timesys Support
1,544 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport are you available to help on this case?
