Vybrid Tower PCB Stackup ?
ChrisNielsen
I can see the layer usage and ordering in the Gerbers but it doesn't show the actual layer spacings.  Would it be possible to post the stackup?  Thanks, Chris
Labels (5)
naoumgitnik
Senior Contributor V
Hello Chris,
Attached is the stack-up and dielectric types.
I'd like to warn you, though - important here is impedance of the impedance-controlled traces; quite likely the customer would use different material and these data might be used for reference only.
Regards, Naoum Gitnik.
naoumgitnik
Hello Chris,
ChrisNielsen
Perfect.  Thanks and I appreciate the warning on dielectric constants.  I will be careful.
To help the next person, I put all the data in Excel and had it add up to ~62 mils to confirm that I understand the individual pieces properly (attached), Chris
