OpenVG MQX Vybrid - buffer-handling / behaviour of eglMakeCurrent
1,461 次查看
slw
My system includes the following components:
- Freescale MQX4.1
- Freescale Vybrid VF522
- OpenVG 0.7.0
I want to use OpenVG to render into 2 different layers. At the moment my solution is something like that (using layer 0 and layer 3):
fbdisp0 = fbws_open_display(0, &buf_info0);
fbdisp3 = fbws_open_display(3, &buf_info0);
fbws_create_window(fbdisp0, 0, 0, info.width, info.height);
fbws_create_window(fbdisp3, 0, 0, info.width, info.height);
eglBindAPI(EGL_OPENVG_API);
eglCreateContext(disp0, cfg[i], ...);
eglCreateContext(disp3, cfg[i], ...);
eglCreateWindowSurface(disp0, ....);
eglCreateWindowSurface(disp3, ....);
while(1)
     eglMakeCurrent(disp0, surf0, surf0, ctx0);
     .... calling vg-functions to render to layer 0.....
     eglSwapbuffers(disp0, surf0);
     eglMakeCurrent(disp3, surf3, surf3, ctx3);
     .... calling vg-functions to render to layer .....
     eglSwapbuffers(disp3, surf3);
The framebuffer-pointer from the single DCU-layer is switched correctly : buffer[0] > buffer[1] > buffer[2] > buffer[0] > buffer[1] .....
But the OpenVG-Library always renders his data to buffer[0].
The problem is still there when I only use 1 context, 1 layer, ... but using eglMakeCurrent.
Any hints ?
Sebastian
标签 (2)
977 次查看
andre_silva
I contacted the Vybrid team and as you said, it is not supported. The solution can be provided, but in this case, customer needs to sign up for a special service.
regards,
Andre
4 回复数
977 次查看
slw
Update:
When I change my code in the main-loop to that:
while(1)
     .... calling vg-functions to render to layer 3.....
then the 2 layers are shown correctly. It seems that eglMakeCurrent always resets the internal draw-buffer-index to 0.
Is this an error inside eglMakeCurrent-function or is it possible to set the internal draw-buffer-index ?
Sebastian
977 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupport can you attend this case?
977 次查看
timesyssupport
Senior Contributor II
Unfortunately, we are not supporting OpenVG on this Vybrid part. Does the Freescale Vybrid team have any comment?
Timesys Support
978 次查看
andre_silva
regards,
Andre
