Using Slave Select as an output
3,277件の閲覧回数
jimsmith
I am working on a tight design with a 12G series chip, and using the SPI interface as a slow asynchronous interface, where CLK and SS are not used. Can the not Slave Select line be held low (via programming) for long periods of time and effectively used as a GPIO output?
タグ(1)
0 返答(返信)
