How do I add a TOC to my content?
2,923件の閲覧回数
-nilda
Place your pointer where you would like to add the TOC (usually at the top of the page).  In the Edit screen GUI toolbar, select the macros button [>>].  From the pulldown list, select Table of Contents.  A TOC icon will appear in the document or discussion.  The TOC will dynamically update based on header entries placed in the content.
If you are entering reply in a discussion, you will need to first select the "Use advanced editor" link in the top right corner in order for the GUI toolbar to appear:
The TOC will appear as a bulleted list in your content.  Based on the selection of the headers used (select "Style" in the toolbar).  For example, Header 1 will place one bullet and the entry text that was made for the header.  If you select Header 2 and there are no Header 1 content available, it will appear with 2 bullets.  But if there is Header 1 and Header 2 content, then the Header 2 content will display as an indented bulleted item beneath Header 1.
0 返答(返信)
