Where to Find Advanced Mechanical Components in Arc Raiders
BladePulse9
In Arc Raiders, Advanced Mechanical Components are essential for crafting and upgrading various tools, equipment, and other crucial items within the game. As an experienced player, you'll want to know exactly where to find these rare materials and how to make the most out of them. This guide will help you identify the key locations where Advanced Mechanical Components can be sourced, along with additional tips to make your resource farming more efficient.
What Are Advanced Mechanical Components?
Before diving into the locations, let's briefly define Advanced Mechanical Components. These are refined materials used primarily for crafting and upgrading high-level items such as weapons, armor, and utility tools. They are classified as "rare" items in the game and have a variety of uses, including recycling into crafting materials and upgrading stations.
Advanced Mechanical Components are particularly useful when crafting items like the Combat Mk. 3 (Aggressive) or the Looting Mk. 3 (Cautious), which require them for advanced crafting recipes.
How to Find Advanced Mechanical Components
1. Scavenging Locations
The most straightforward way to find Advanced Mechanical Components is through scavenging. These can be found in various locations across the map, especially when you’re exploring industrial or high-tech zones. Some of the common places to scavenge for these components include:
  • Electrical Zones: These areas, marked by their heavy use of electronics and machinery, are rich in Advanced Mechanical Components. Make sure to check around power stations and repair stations, as these often have a higher chance of yielding the materials you need.
  • The Queen's Domain: A specific high-tier area known for its tougher enemies and resource-rich environment. If you're skilled enough to handle the Queen's domain, you can farm Advanced Mechanical Components more effectively, as these locations tend to have the rarest components.
2. Crafting Advanced Mechanical Components
If you prefer a more controlled method, crafting is another option. You'll need a Refiner 2 or a Refiner 3 station to craft Advanced Mechanical Components. The basic crafting recipe requires:
  • 3 Wires
  • 2 Electrical Components
This recipe is simple to obtain early in the game and gives you an efficient way to create these components without depending on scavenging.
3. Recycling for Components
If you have excess lower-tier components or other materials you no longer need, recycling is another great method to obtain Advanced Mechanical Components. This process is especially useful when you've gathered materials from various other sources and want to convert them into more useful resources.
4. Buy Advanced Mechanical Components
If you are in a rush or don’t have the time to farm or craft the components yourself, you can also buy arc raiders items directly from the in-game store or other players through the marketplace. This is a convenient way to get your hands on these materials if you're short on time.
Tips for Efficient Farming
While knowing the locations of Advanced Mechanical Components is essential, there are a few strategies you can use to maximize your farming efficiency:
  • Target High-Density Areas: Focus on locations known to have high drop rates for rare materials. If you are scavenging, don't waste time in low-yield areas.
  • Upgrade Your Tools: Use higher-tier scavenging tools or equipment to increase the likelihood of finding rare components. Tools that boost your resource-gathering efficiency will save you time and effort.
  • Join Multiplayer Sessions: If you’re playing in multiplayer mode, coordinate with teammates to farm different areas simultaneously. This not only speeds up the process but also reduces the danger of running into enemies that could slow you down.
  • Use Your Utility Stations Effectively: Don’t forget that your Utility Station can be upgraded using Advanced Mechanical Components. If you’ve got a lot of components, consider using some of them for station upgrades to open up more crafting options and improve your overall resource management.
Advanced Mechanical Components are crucial for crafting and upgrading in Arc Raiders, and knowing where to find them is key to progressing efficiently in the game. Whether you’re scavenging in high-tech zones, crafting them yourself, or recycling other items, there are various ways to obtain these rare materials. For those looking for a quicker solution, consider choosing to buy arc raiders items to save time.
By following the tips in this guide, you’ll be well-equipped to find and use Advanced Mechanical Components to their full potential. Happy scavenging, crafting, and upgrading!
Go Further: Arc Raiders Best Hand Cannons Strengths & Weaknesses 2026
%3CLINGO-SUB%20id%3D%22lingo-sub-2295283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EWhere%20to%20Find%20Advanced%20Mechanical%20Components%20in%20Arc%20Raiders%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIn%20Arc%20Raiders%2C%20Advanced%20Mechanical%20Components%20are%20essential%20for%20crafting%20and%20upgrading%20various%20tools%2C%20equipment%2C%20and%20other%20crucial%20items%20within%20the%20game.%20As%20an%20experienced%20player%2C%20you'll%20want%20to%20know%20exactly%20where%20to%20find%20these%20rare%20materials%20and%20how%20to%20make%20the%20most%20out%20of%20them.%20This%20guide%20will%20help%20you%20identify%20the%20key%20locations%20where%20Advanced%20Mechanical%20Components%20can%20be%20sourced%2C%20along%20with%20additional%20tips%20to%20make%20your%20resource%20farming%20more%20efficient.%3C%2FP%3E%3CH3%20id%3D%22toc-hId-2006145202%22%20id%3D%22toc-hId-2006147066%22%3EWhat%20Are%20Advanced%20Mechanical%20Components%3F%3C%2FH3%3E%3CP%3EBefore%20diving%20into%20the%20locations%2C%20let's%20briefly%20define%20Advanced%20Mechanical%20Components.%20These%20are%20refined%20materials%20used%20primarily%20for%20crafting%20and%20upgrading%20high-level%20items%20such%20as%20weapons%2C%20armor%2C%20and%20utility%20tools.%20They%20are%20classified%20as%20%22rare%22%20items%20in%20the%20game%20and%20have%20a%20variety%20of%20uses%2C%20including%20recycling%20into%20crafting%20materials%20and%20upgrading%20stations.%3C%2FP%3E%3CP%3EAdvanced%20Mechanical%20Components%20are%20particularly%20useful%20when%20crafting%20items%20like%20the%20Combat%20Mk.%203%20(Aggressive)%20or%20the%20Looting%20Mk.%203%20(Cautious)%2C%20which%20require%20them%20for%20advanced%20crafting%20recipes.%3C%2FP%3E%3CH3%20id%3D%22toc-hId-198690739%22%20id%3D%22toc-hId-198692603%22%3EHow%20to%20Find%20Advanced%20Mechanical%20Components%3C%2FH3%3E%3CH4%20id%3D%22toc-hId-889252213%22%20id%3D%22toc-hId-889254077%22%3E1.%20Scavenging%20Locations%3C%2FH4%3E%3CP%3EThe%20most%20straightforward%20way%20to%20find%20Advanced%20Mechanical%20Components%20is%20through%20scavenging.%20These%20can%20be%20found%20in%20various%20locations%20across%20the%20map%2C%20especially%20when%20you%E2%80%99re%20exploring%20industrial%20or%20high-tech%20zones.%20Some%20of%20the%20common%20places%20to%20scavenge%20for%20these%20components%20include%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EElectrical%20Zones%3A%20These%20areas%2C%20marked%20by%20their%20heavy%20use%20of%20electronics%20and%20machinery%2C%20are%20rich%20in%20Advanced%20Mechanical%20Components.%20Make%20sure%20to%20check%20around%20power%20stations%20and%20repair%20stations%2C%20as%20these%20often%20have%20a%20higher%20chance%20of%20yielding%20the%20materials%20you%20need.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EThe%20Queen's%20Domain%3A%20A%20specific%20high-tier%20area%20known%20for%20its%20tougher%20enemies%20and%20resource-rich%20environment.%20If%20you're%20skilled%20enough%20to%20handle%20the%20Queen's%20domain%2C%20you%20can%20farm%20Advanced%20Mechanical%20Components%20more%20effectively%2C%20as%20these%20locations%20tend%20to%20have%20the%20rarest%20components.%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CH4%20id%3D%22toc-hId--918202250%22%20id%3D%22toc-hId--918200386%22%3E2.%20Crafting%20Advanced%20Mechanical%20Components%3C%2FH4%3E%3CP%3EIf%20you%20prefer%20a%20more%20controlled%20method%2C%20crafting%20is%20another%20option.%20You'll%20need%20a%20Refiner%202%20or%20a%20Refiner%203%20station%20to%20craft%20Advanced%20Mechanical%20Components.%20The%20basic%20crafting%20recipe%20requires%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E3%20Wires%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E2%20Electrical%20Components%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EThis%20recipe%20is%20simple%20to%20obtain%20early%20in%20the%20game%20and%20gives%20you%20an%20efficient%20way%20to%20create%20these%20components%20without%20depending%20on%20scavenging.%3C%2FP%3E%3CH4%20id%3D%22toc-hId-1569310583%22%20id%3D%22toc-hId-1569312447%22%3E3.%20Recycling%20for%20Components%3C%2FH4%3E%3CP%3EIf%20you%20have%20excess%20lower-tier%20components%20or%20other%20materials%20you%20no%20longer%20need%2C%20recycling%20is%20another%20great%20method%20to%20obtain%20Advanced%20Mechanical%20Components.%20This%20process%20is%20especially%20useful%20when%20you've%20gathered%20materials%20from%20various%20other%20sources%20and%20want%20to%20convert%20them%20into%20more%20useful%20resources.%3C%2FP%3E%3CH4%20id%3D%22toc-hId--238143880%22%20id%3D%22toc-hId--238142016%22%3E4.%20Buy%20Advanced%20Mechanical%20Components%3C%2FH4%3E%3CP%3EIf%20you%20are%20in%20a%20rush%20or%20don%E2%80%99t%20have%20the%20time%20to%20farm%20or%20craft%20the%20components%20yourself%2C%20you%20can%20also%20%3CA%20href%3D%22https%3A%2F%2Fwww.u4n.com%2Farc-raiders%2Fitems%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ebuy%20arc%20raiders%20items%3C%2FA%3E%20directly%20from%20the%20in-game%20store%20or%20other%20players%20through%20the%20marketplace.%20This%20is%20a%20convenient%20way%20to%20get%20your%20hands%20on%20these%20materials%20if%20you're%20short%20on%20time.%3C%2FP%3E%3CH3%20id%3D%22toc-hId--248646984%22%20id%3D%22toc-hId--248645120%22%3ETips%20for%20Efficient%20Farming%3C%2FH3%3E%3CP%3EWhile%20knowing%20the%20locations%20of%20Advanced%20Mechanical%20Components%20is%20essential%2C%20there%20are%20a%20few%20strategies%20you%20can%20use%20to%20maximize%20your%20farming%20efficiency%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3ETarget%20High-Density%20Areas%3A%20Focus%20on%20locations%20known%20to%20have%20high%20drop%20rates%20for%20rare%20materials.%20If%20you%20are%20scavenging%2C%20don't%20waste%20time%20in%20low-yield%20areas.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EUpgrade%20Your%20Tools%3A%20Use%20higher-tier%20scavenging%20tools%20or%20equipment%20to%20increase%20the%20likelihood%20of%20finding%20rare%20components.%20Tools%20that%20boost%20your%20resource-gathering%20efficiency%20will%20save%20you%20time%20and%20effort.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EJoin%20Multiplayer%20Sessions%3A%20If%20you%E2%80%99re%20playing%20in%20multiplayer%20mode%2C%20coordinate%20with%20teammates%20to%20farm%20different%20areas%20simultaneously.%20This%20not%20only%20speeds%20up%20the%20process%20but%20also%20reduces%20the%20danger%20of%20running%20into%20enemies%20that%20could%20slow%20you%20down.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EUse%20Your%20Utility%20Stations%20Effectively%3A%20Don%E2%80%99t%20forget%20that%20your%20Utility%20Station%20can%20be%20upgraded%20using%20Advanced%20Mechanical%20Components.%20If%20you%E2%80%99ve%20got%20a%20lot%20of%20components%2C%20consider%20using%20some%20of%20them%20for%20station%20upgrades%20to%20open%20up%20more%20crafting%20options%20and%20improve%20your%20overall%20resource%20management.%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EAdvanced%20Mechanical%20Components%20are%20crucial%20for%20crafting%20and%20upgrading%20in%20Arc%20Raiders%2C%20and%20knowing%20where%20to%20find%20them%20is%20key%20to%20progressing%20efficiently%20in%20the%20game.%20Whether%20you%E2%80%99re%20scavenging%20in%20high-tech%20zones%2C%20crafting%20them%20yourself%2C%20or%20recycling%20other%20items%2C%20there%20are%20various%20ways%20to%20obtain%20these%20rare%20materials.%20For%20those%20looking%20for%20a%20quicker%20solution%2C%20consider%20choosing%20to%20buy%20arc%20raiders%20items%20to%20save%20time.%3C%2FP%3E%3CP%3EBy%20following%20the%20tips%20in%20this%20guide%2C%20you%E2%80%99ll%20be%20well-equipped%20to%20find%20and%20use%20Advanced%20Mechanical%20Components%20to%20their%20full%20potential.%20Happy%20scavenging%2C%20crafting%2C%20and%20upgrading!%3C%2FP%3E%3CP%3EGo%20Further%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.u4n.com%2Fnews%2Farc-raiders-best-hand-cannons-strengths-weaknesses-2026.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EArc%20Raiders%20Best%20Hand%20Cannons%20Strengths%20%26amp%3B%20Weaknesses%202026%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
