U4N - How to Set Up an Aion 2 Private Server for Testing
2,302件の閲覧回数
BladePulse9
Why Set Up a Private Server?
Private servers give you full control over the game environment. You can:
  • Test class skills, rotations, and combos without time pressure.
  • Experiment with gear upgrades or enhancements.
  • Run PvP or PvE scenarios repeatedly.
  • Learn the game mechanics faster by observing behaviors in controlled settings.
For many players, this is especially helpful for trying out strategies that would be risky or expensive on the official servers.
What You Need Before Starting
Before setting up a private server, you need to prepare the following:
  1. A Decent Computer
    Private servers can run locally, but performance depends on your CPU and memory. A mid-range machine with at least 8 GB of RAM and a modern CPU is sufficient for small-scale testing.
  2. A Copy of Aion 2 Client
    You will need the game client to connect to your server. Make sure it matches the server version you plan to run.
  3. Server Files
    Private server files for Aion 2 are often shared in community forums. Look for versions explicitly labeled for testing or development. Avoid unknown sources to reduce the risk of malware.
  4. Database Software
    Most private servers use MySQL or MariaDB to store game data. You will need to install and configure one of these databases.
  5. Basic Networking Knowledge
    You don’t need to be a network engineer, but understanding how ports, IP addresses, and firewalls work is important. The server must be reachable from your client.
Step 1: Installing Server Software
Once you have the server files, the first step is to install them:
  1. Extract the Files
    Place them in a dedicated folder on your computer. Avoid system directories to reduce potential conflicts.
  2. Configure Server Settings
    Open the configuration files. The most important settings include:
    • IP Address: Set this to your local machine’s IP or 127.0.0.1 for local-only testing.
    • Port Numbers: Make sure these ports are free. Typical Aion 2 ports are often included in the documentation.
    • Database Connection: Enter your database username, password, and the database name.
  3. Run Setup Scripts
    Many private server packages come with scripts to initialize the database. Run these to create the necessary tables and default data.
  4. Start the Server
    Execute the server program. Monitor the console for any error messages. Common issues include wrong database credentials or ports already in use.
Step 2: Connecting the Client
With the server running, you need to tell your Aion 2 client to connect to it.
  1. Modify the Client Configuration
    Look for a configuration file, often named Aion2.ini or similar. Change the server IP to the one your private server is using.
  2. Test Connection
    Launch the game client and log in. If you encounter connection errors, check firewall settings and make sure the server is running.
  3. Create Test Accounts
    On a private server, you can create unlimited accounts for testing. Use these accounts to experiment with different builds and gear setups.
Step 3: Using the Server for Testing
Once connected, you can begin using the server to test anything without consequence. Some practical approaches include:
  • Skill Rotation Testing: Run dummies or mobs to measure skill timing and damage output.
  • Gear Experiments: Test different gear combinations and upgrades. Many players also simulate the market to see how items affect progression.
  • Economy Simulations: Some players like to simulate trading, crafting, and kinah accumulation. If you want to test kinah acquisition strategies, private servers are perfect because you can simulate large-scale trades, item farming, or even use shortcuts like Aion 2 kinah fast delivery features for controlled experiments.
Step 4: Common Issues and Solutions
Even experienced players run into common problems. Here are a few and how to resolve them:
  • Server Crashes: Often caused by outdated or mismatched server files. Ensure your server files match your client version exactly.
  • Database Errors: Check credentials and database name. Sometimes table structures are missing; re-run the initialization scripts.
  • Lag or Slow Performance: Reduce the number of concurrent players or NPCs, and ensure your computer meets the recommended specifications.
  • Connection Issues: Verify IP addresses, open ports in your firewall, and confirm the client configuration matches the server settings.
Step 5: Maintaining Your Server
Even for testing, it’s useful to maintain the server properly:
  • Backup Frequently: Keep regular backups of your database to avoid losing progress.
  • Update Server Files Carefully: If you download newer versions, test them separately before applying them to your main testing environment.
  • Document Changes: Note any modifications you make to settings, skills, or the database. This helps when troubleshooting unexpected behavior.
Legal and Ethical Considerations
It is important to remember that private servers exist in a gray area. They should only be used for personal testing and learning, not for public distribution or commercial purposes. Avoid connecting private servers to official accounts to protect your data and remain compliant with the game's terms of service.
Setting up a private Aion 2 server is an effective way to learn and test without risking your main account. By following these steps—preparing the right tools, installing server files, configuring the client, and maintaining your server—you can experiment with skills, gear, and in-game strategies safely. For players interested in practical testing, even complex processes like economy simulations can be handled in a controlled environment, including experimenting with concepts like Aion 2 kinah fast delivery for managing in-game currency efficiently.
Private servers are not only useful for testing but also for understanding the game at a deeper level. With patience, careful setup, and attention to detail, you can create a valuable tool for improving your gameplay in Aion 2.
0 返答(返信)
%3CLINGO-SUB%20id%3D%22lingo-sub-2330158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EU4N%20-%20%E3%83%86%E3%82%B9%E3%83%88%E7%94%A8%E3%81%ABAion%202%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2330158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH2%20id%3D%22toc-hId--468932714%22%20id%3D%22toc-hId--468900074%22%3E%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E7%90%86%E7%94%B1%3C%2FH2%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B2%E3%83%BC%E3%83%A0%E7%92%B0%E5%A2%83%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E5%88%B6%E5%BE%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%A7%E3%81%8D%E3%82%8B%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E6%99%82%E9%96%93%E7%9A%84%E3%81%AA%E3%83%97%E3%83%AC%E3%83%83%E3%82%B7%E3%83%A3%E3%83%BC%E3%81%AA%E3%81%97%E3%81%AB%E3%82%AF%E3%83%A9%E3%82%B9%E3%82%B9%E3%82%AD%E3%83%AB%E3%80%81%E3%83%AD%E3%83%BC%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%81%E3%82%B3%E3%83%B3%E3%83%9C%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%82%AE%E3%82%A2%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%82%84%E5%BC%B7%E5%8C%96%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EPvP%20%E3%81%BE%E3%81%9F%E3%81%AF%20PvE%20%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%82%92%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%88%B6%E5%BE%A1%E3%81%95%E3%82%8C%E3%81%9F%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AE%E5%8B%95%E4%BD%9C%E3%82%92%E8%A6%B3%E5%AF%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%82%B2%E3%83%BC%E3%83%A0%E3%81%AE%E4%BB%95%E7%B5%84%E3%81%BF%E3%82%92%E3%82%88%E3%82%8A%E6%97%A9%E3%81%8F%E5%AD%A6%E7%BF%92%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%97%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%85%AC%E5%BC%8F%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A7%E3%81%AF%E3%83%AA%E3%82%B9%E3%82%AF%E3%81%8C%E9%AB%98%E3%81%8B%E3%81%A3%E3%81%9F%E3%82%8A%E8%B2%BB%E7%94%A8%E3%81%8C%E3%81%8B%E3%81%8B%E3%81%A3%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E6%88%A6%E7%95%A5%E3%82%92%E8%A9%A6%E3%81%99%E3%81%AE%E3%81%AB%E7%89%B9%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId-2018580119%22%20id%3D%22toc-hId-2018612759%22%3E%E5%A7%8B%E3%82%81%E3%82%8B%E5%89%8D%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%82%E3%81%AE%3C%2FH2%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E6%BA%96%E5%82%99%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%81%BE%E3%81%A8%E3%82%82%E3%81%AA%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%3C%2FSTRONG%3E%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AF%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AF%20CPU%20%E3%81%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%B0%8F%E8%A6%8F%E6%A8%A1%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%208%20GB%20%E3%81%AE%20RAM%20%E3%81%A8%E6%9C%80%E6%96%B0%E3%81%AE%20CPU%20%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%9F%E3%83%83%E3%83%89%E3%83%AC%E3%83%B3%E3%82%B8%20%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E5%8D%81%E5%88%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EAion%202%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%3C%2FSTRONG%3E%3CBR%20%2F%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%82%B2%E3%83%BC%E3%83%A0%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E5%AE%9F%E8%A1%8C%E4%BA%88%E5%AE%9A%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSTRONG%3E%3CBR%20%2F%3EAion%202%20%E3%81%AE%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%A7%E5%85%B1%E6%9C%89%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%A4%9A%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%83%86%E3%82%B9%E3%83%88%E7%94%A8%E3%81%BE%E3%81%9F%E3%81%AF%E9%96%8B%E7%99%BA%E7%94%A8%E3%81%AB%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E3%83%A9%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E6%8E%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%9E%E3%83%AB%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%AA%E3%82%B9%E3%82%AF%E3%82%92%E8%BB%BD%E6%B8%9B%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E4%B8%8D%E6%98%8E%E3%81%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E9%81%BF%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FSTRONG%3E%3CBR%20%2F%3E%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AF%E3%80%81%E3%82%B2%E3%83%BC%E3%83%A0%20%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E4%BF%9D%E5%AD%98%E3%81%AB%20MySQL%20%E3%81%BE%E3%81%9F%E3%81%AF%20MariaDB%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E7%9F%A5%E8%AD%98%3C%2FSTRONG%3E%3CBR%20%2F%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%20%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%9D%E3%83%BC%E3%83%88%E3%80%81IP%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%AB%E3%81%AE%E4%BB%95%E7%B5%84%E3%81%BF%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8B%E3%82%89%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CH2%20id%3D%22toc-hId-211125656%22%20id%3D%22toc-hId-211158296%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%971%3A%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FH2%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%BE%E3%81%9A%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%8A%BD%E5%87%BA%3C%2FSTRONG%3E%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E5%B0%82%E7%94%A8%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%BD%9C%E5%9C%A8%E7%9A%84%E3%81%AA%E7%AB%B6%E5%90%88%E3%82%92%E6%B8%9B%E3%82%89%E3%81%99%E3%81%9F%E3%82%81%E3%81%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E9%81%BF%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E8%A8%AD%E5%AE%9A%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3CBR%20%2F%3E%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E3%82%82%E9%87%8D%E8%A6%81%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EIP%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSTRONG%3E%3A%20%E3%81%93%E3%82%8C%E3%82%92%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%20%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AE%20IP%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%81%AE%E3%81%BF%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%20127.0.0.1%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%83%9D%E3%83%BC%E3%83%88%E7%95%AA%E5%8F%B7%3C%2FSTRONG%3E%3A%20%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E7%A9%BA%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%85%B8%E5%9E%8B%E7%9A%84%E3%81%AA%20Aion%202%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E3%80%81%E5%A4%9A%E3%81%8F%E3%81%AE%E5%A0%B4%E5%90%88%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E6%8E%A5%E7%B6%9A%3C%2FSTRONG%3E%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%90%8D%E3%80%81%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E5%90%8D%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%AF%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%8C%E4%BB%98%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A8%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3CBR%20%2F%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E7%9B%A3%E8%A6%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E8%B3%87%E6%A0%BC%E6%83%85%E5%A0%B1%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%80%81%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%81%E3%81%AA%E3%81%A9%E3%81%8C%E6%8C%99%E3%81%92%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CH2%20id%3D%22toc-hId--1596328807%22%20id%3D%22toc-hId--1596296167%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%972%3A%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E6%8E%A5%E7%B6%9A%3C%2FH2%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8C%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81Aion%202%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AB%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%8C%87%E7%A4%BA%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E6%A7%8B%E6%88%90%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%A4%9A%E3%81%8F%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81Aion2.ini%20%E3%81%BE%E3%81%9F%E3%81%AF%E9%A1%9E%E4%BC%BC%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%8C%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%9F%E6%A7%8B%E6%88%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%8E%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%20IP%20%E3%82%92%E3%80%81%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20IP%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%83%86%E3%82%B9%E3%83%88%E6%8E%A5%E7%B6%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E3%82%B2%E3%83%BC%E3%83%A0%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%8E%A5%E7%B6%9A%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8C%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%83%86%E3%82%B9%E3%83%88%E3%82%A2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3CBR%20%2F%3E%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A7%E3%81%AF%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E7%94%A8%E3%81%AB%E7%84%A1%E5%88%B6%E9%99%90%E3%81%AE%E3%82%A2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%83%93%E3%83%AB%E3%83%89%E3%81%A8%E3%82%AE%E3%82%A2%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CH2%20id%3D%22toc-hId-891184026%22%20id%3D%22toc-hId-891216666%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%973%3A%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FH2%3E%3CP%3E%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E7%B5%90%E6%9E%9C%E3%82%92%E6%B0%97%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AA%E3%81%8F%E4%BD%95%E3%81%A7%E3%82%82%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%AE%9F%E7%94%A8%E7%9A%84%E3%81%AA%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%82%B9%E3%82%AD%E3%83%AB%E3%83%AD%E3%83%BC%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%86%E3%82%B9%E3%83%88%3C%2FSTRONG%3E%3A%20%E3%83%80%E3%83%9F%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%A2%E3%83%96%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81%E3%82%B9%E3%82%AD%E3%83%AB%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%A8%E3%83%80%E3%83%A1%E3%83%BC%E3%82%B8%E5%87%BA%E5%8A%9B%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%82%AE%E3%82%A2%E5%AE%9F%E9%A8%93%3C%2FSTRONG%3E%3A%20%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%82%AE%E3%82%A2%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A8%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%97%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AF%E3%80%81%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%E3%81%8C%E9%80%B2%E8%A1%8C%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%99%E3%82%8B%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%9E%E3%83%BC%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E7%B5%8C%E6%B8%88%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSTRONG%3E%3A%20%E5%8F%96%E5%BC%95%E3%80%81%E4%BD%9C%E6%88%90%E3%80%81%E3%82%AD%E3%83%8A%E3%81%AE%E8%93%84%E7%A9%8D%E3%82%92%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%A5%BD%E3%82%80%E3%83%97%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%82%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AD%E3%83%8A%E7%8D%B2%E5%BE%97%E6%88%A6%E7%95%A5%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8C%E6%9C%80%E9%81%A9%E3%81%A7%E3%81%99%E3%80%82%E5%A4%A7%E8%A6%8F%E6%A8%A1%E3%81%AA%E5%8F%96%E5%BC%95%E3%82%84%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81Aion%202%20%E3%82%AD%E3%83%8A%E9%AB%98%E9%80%9F%E9%85%8D%E4%BF%A1%E6%A9%9F%E8%83%BD%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%88%E3%82%AB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%88%B6%E5%BE%A1%E3%81%95%E3%82%8C%E3%81%9F%E5%AE%9F%E9%A8%93%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%9F%E3%82%8A%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CH2%20id%3D%22toc-hId--916270437%22%20id%3D%22toc-hId--916237797%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%974%3A%20%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%A8%E8%A7%A3%E6%B1%BA%E7%AD%96%3C%2FH2%3E%3CP%3E%E7%B5%8C%E9%A8%93%E8%B1%8A%E5%AF%8C%E3%81%AA%E3%83%97%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%A7%E3%82%82%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A8%E3%81%9D%E3%81%AE%E8%A7%A3%E6%B1%BA%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%20%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3C%2FSTRONG%3E%3A%20%E5%A4%9A%E3%81%8F%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E5%8F%A4%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%9F%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8%E5%AE%8C%E5%85%A8%E3%81%AB%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSTRONG%3E%3A%20%E8%B3%87%E6%A0%BC%E6%83%85%E5%A0%B1%E3%81%A8%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E5%90%8D%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E6%A7%8B%E9%80%A0%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E9%81%85%E5%BB%B6%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AE%E4%BD%8E%E4%B8%8B%3C%2FSTRONG%3E%3A%20%E5%90%8C%E6%99%82%E3%83%97%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%20NPC%20%E3%81%AE%E6%95%B0%E3%82%92%E6%B8%9B%E3%82%89%E3%81%97%E3%80%81%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E6%8E%A8%E5%A5%A8%E4%BB%95%E6%A7%98%E3%82%92%E6%BA%80%E3%81%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E6%8E%A5%E7%B6%9A%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FSTRONG%3E%3A%20IP%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%AB%E3%81%A7%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E6%A7%8B%E6%88%90%E3%81%8C%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E8%A8%AD%E5%AE%9A%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CH2%20id%3D%22toc-hId-1571242396%22%20id%3D%22toc-hId-1571275036%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%975%3A%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E3%83%A1%E3%83%B3%E3%83%86%E3%83%8A%E3%83%B3%E3%82%B9%3C%2FH2%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%A7%E3%82%82%E3%80%81%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E4%BF%9D%E5%AE%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E6%9C%89%E7%94%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E9%A0%BB%E7%B9%81%E3%81%AB%E3%83%90%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3A%20%E9%80%B2%E8%A1%8C%E7%8A%B6%E6%B3%81%E3%81%8C%E5%A4%B1%E3%82%8F%E3%82%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%90%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%85%8E%E9%87%8D%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%A1%E3%82%A4%E3%83%B3%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E7%92%B0%E5%A2%83%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E5%80%8B%E5%88%A5%E3%81%AB%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FSTRONG%3E%3A%20%E8%A8%AD%E5%AE%9A%E3%80%81%E3%82%B9%E3%82%AD%E3%83%AB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E5%8A%A0%E3%81%88%E3%81%9F%E5%A4%89%E6%9B%B4%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E8%A8%98%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E4%BA%88%E6%9C%9F%E3%81%97%E3%81%AA%E3%81%84%E5%8B%95%E4%BD%9C%E3%81%AE%E3%83%88%E3%83%A9%E3%83%96%E3%83%AB%E3%82%B7%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CH2%20id%3D%22toc-hId--236212067%22%20id%3D%22toc-hId--236179427%22%3E%E6%B3%95%E7%9A%84%E3%81%8A%E3%82%88%E3%81%B3%E5%80%AB%E7%90%86%E7%9A%84%E8%80%83%E6%85%AE%E4%BA%8B%E9%A0%85%3C%2FH2%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AF%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%BE%E3%83%BC%E3%83%B3%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%A6%9A%E3%81%88%E3%81%A6%E3%81%8A%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%3CSTRONG%3E%E5%80%8B%E4%BA%BA%E7%9A%84%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88%E3%81%A8%E5%AD%A6%E7%BF%92%E3%81%AB%E3%81%AE%E3%81%BF%E4%BD%BF%E7%94%A8%E3%81%97%3C%2FSTRONG%3E%E3%80%81%E5%85%AC%E9%96%8B%E9%85%8D%E5%B8%83%E3%82%84%E5%95%86%E6%A5%AD%E7%9B%AE%E7%9A%84%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E4%BF%9D%E8%AD%B7%E3%81%97%E3%80%81%E3%82%B2%E3%83%BC%E3%83%A0%E3%81%AE%E5%88%A9%E7%94%A8%E8%A6%8F%E7%B4%84%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E5%85%AC%E5%BC%8F%E3%82%A2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20Aion%202%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81%E3%83%A1%E3%82%A4%E3%83%B3%20%E3%82%A2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E5%8D%B1%E9%99%BA%E3%81%AB%E3%81%95%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AA%E3%81%8F%E5%AD%A6%E7%BF%92%E3%81%8A%E3%82%88%E3%81%B3%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E8%A1%8C%E3%81%86%E5%8A%B9%E6%9E%9C%E7%9A%84%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%99%E3%80%82%E9%81%A9%E5%88%87%E3%81%AA%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E6%BA%96%E5%82%99%E3%80%81%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%80%81%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E6%A7%8B%E6%88%90%E3%80%81%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E3%83%A1%E3%83%B3%E3%83%86%E3%83%8A%E3%83%B3%E3%82%B9%E3%81%AA%E3%81%A9%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%82%B9%E3%82%AD%E3%83%AB%E3%80%81%E8%A3%85%E5%82%99%E3%80%81%E3%82%B2%E3%83%BC%E3%83%A0%E5%86%85%E6%88%A6%E7%95%A5%E3%82%92%E5%AE%89%E5%85%A8%E3%81%AB%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E5%AE%9F%E8%B7%B5%E7%9A%84%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E8%88%88%E5%91%B3%E3%81%AE%E3%81%82%E3%82%8B%E3%83%97%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%AF%E3%80%81%E3%82%B2%E3%83%BC%E3%83%A0%E5%86%85%E9%80%9A%E8%B2%A8%E3%82%92%E5%8A%B9%E7%8E%87%E7%9A%84%E3%81%AB%E7%AE%A1%E7%90%86%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%20Aion%202%20%E3%82%AD%E3%83%8A%E3%81%AE%E9%AB%98%E9%80%9F%E9%85%8D%E4%BF%A1%E3%81%AA%E3%81%A9%E3%81%AE%E6%A6%82%E5%BF%B5%E3%81%AE%E5%AE%9F%E9%A8%93%E3%82%92%E5%90%AB%E3%82%81%E3%80%81%E7%B5%8C%E6%B8%88%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AA%E3%81%A9%E3%81%AE%E8%A4%87%E9%9B%91%E3%81%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%A7%E3%82%82%E5%88%B6%E5%BE%A1%E3%81%95%E3%82%8C%E3%81%9F%E7%92%B0%E5%A2%83%E3%81%A7%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AF%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AA%E3%81%8F%E3%80%81%E3%82%B2%E3%83%BC%E3%83%A0%E3%82%92%E3%82%88%E3%82%8A%E6%B7%B1%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E3%82%82%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%E5%BF%8D%E8%80%90%E3%80%81%E6%85%8E%E9%87%8D%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%80%81%E7%B4%B0%E9%83%A8%E3%81%B8%E3%81%AE%E9%85%8D%E6%85%AE%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81Aion%202%20%E3%81%A7%E3%81%AE%E3%82%B2%E3%83%BC%E3%83%A0%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E5%90%91%E4%B8%8A%E3%81%95%E3%81%9B%E3%82%8B%E8%B2%B4%E9%87%8D%E3%81%AA%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
