MPC5604B RAM
MPC5604B RAM
cedricdestin
Hey, I am having some trouble, since yesterday, I have been unable to run any new code from the RAM memory, as soon as I remove it from my PC, some old code written two weeks ago starts running. I am not certain of the problem, but I though of a solution... But do you guys have any ideas what may have cause the problem or has that problem ever happened to a micro controller.
admin
Specialist II
There is a drop down menu that allows you to select between RAM and FLASH programming.  Are you doing that?
cedricdestin
Yeah, I figured it out the same day... Thanks
