DIP breakout board for KL25Z
DIP breakout board for the Kinetis Microcontrollers
2 layer board of 0.65x1.35 inches (16.54x34.29 mm).  Minimal component requirements. You can buy the board from Osh Park ($4.95) or download the design files here!
Thanks dgd for sharing the link!
Tags (2)
Comments
It'll be better if it comes in completely soldered unit, on-board programming interface and pin compatibility with Arduino Nano. It can be named "Nano Freedom Board" :smileylaugh:
In order to put the on-board programming on, the K20 needs to be put somewhere. The McHck from http://mchck.org can be used as a small external programmer; that board can be ordered from OSHPark, too. Here is the schematic:
I still need to formally test this board; I am awaiting them to arrive.  I expect that it will work without incident like the 64QFP one I built.  The QFP is much easier to solder... [More info on the QFP board here.]
My intent with this board as well as the QFP one was to make KL25Z boards that I could employ for various functions. I am in need of more than a handful of boards and the FRDM-KL25Z, while very attractive, becomes cost prohibitive in the quantities I need. Once the software for each function is mature enough for service, the programmer is no longer necessary.  That'd be why there's no programmer on the board itself - I'm using the FRDM board.
The board has been tested and it works.  It's important to note that the code loaded needs to use the internal oscillator.
Order here: OSH Park ~ microKL25Z-v1
If using mbed, then here's a modified mbed library that uses the internal oscillator by default and which also operates it at 48MHz instead of the original FLL setting of 41MHz:
mbed-src-FLL48 - a mercurial repository | mbed
A larger version with a little prototype area can also be ordered from: OSH Park ~ miniKL25Z
More info on that version can be seen here:
http://blog.sundayschildsnapshots.com/wp/2013/09/more-printed-circuit-boards/
%3CLINGO-SUB%20id%3D%22lingo-sub-1128585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDIP%20breakout%20board%20for%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDIP%20breakout%20board%20for%20the%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fspace%2F2019%22%20target%3D%22_blank%22%3E%20Kinetis%20Microcontrollers%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CIMG%20alt%3D%22thumb_i.png%22%20class%3D%22jive-image%22%20src%3D%22http%3A%2F%2Fuploads.oshpark.com%2Fuploads%2Fproject%2Ftop_image%2FMsCRJIem%2Fthumb_i.png%22%20%2F%3E%26nbsp%3B%20%3CIMG%20alt%3D%22thumb_i.png%22%20class%3D%22jive-image%22%20src%3D%22http%3A%2F%2Fuploads.oshpark.com%2Fuploads%2Fproject%2Fbottom_image%2FMsCRJIem%2Fthumb_i.png%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2%20layer%20board%20of%200.65x1.35%20inches%20(16.54x34.29%20mm).%26nbsp%3B%20Minimal%20component%20requirements.%20You%20can%20buy%20the%20board%20from%20Osh%20Park%20(%244.95)%20or%20download%20the%20design%20files%20%3CA%20href%3D%22http%3A%2F%2Foshpark.com%2Fshared_projects%2FMsCRJIem%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehere%3C%2FA%3E!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fdgd%22%20target%3D%22_blank%22%3Edgd%3C%2FA%3E%20for%20sharing%20the%20link!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20DIP%20breakout%20board%20for%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20board%20has%20been%20tested%20and%20it%20works.%26nbsp%3B%20It's%20important%20to%20note%20that%20the%20code%20loaded%20needs%20to%20use%20the%20internal%20oscillator.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOrder%20here%3A%20%3CA%20href%3D%22http%3A%2F%2Foshpark.com%2Fshared_projects%2FMsCRJIem%22%20title%3D%22http%3A%2F%2Foshpark.com%2Fshared_projects%2FMsCRJIem%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EOSH%20Park%20~%20microKL25Z-v1%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIf%20using%20mbed%2C%20then%20here's%20a%20modified%20mbed%20library%20that%20uses%20the%20internal%20oscillator%20by%20default%20and%20which%20also%20operates%20it%20at%2048MHz%20instead%20of%20the%20original%20FLL%20setting%20of%2041MHz%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fmbed.org%2Fusers%2Ficenyne%2Fcode%2Fmbed-src-FLL48%2F%22%20title%3D%22http%3A%2F%2Fmbed.org%2Fusers%2Ficenyne%2Fcode%2Fmbed-src-FLL48%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Embed-src-FLL48%20-%20a%20mercurial%20repository%20%7C%20mbed%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EA%20larger%20version%20with%20a%20little%20prototype%20area%20can%20also%20be%20ordered%20from%3A%20%3CA%20href%3D%22http%3A%2F%2Foshpark.com%2Fshared_projects%2F90oLkyZS%22%20title%3D%22http%3A%2F%2Foshpark.com%2Fshared_projects%2F90oLkyZS%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EOSH%20Park%20~%20miniKL25Z%3C%2FA%3E%3C%2FP%3E%3CP%3EMore%20info%20on%20that%20version%20can%20be%20seen%20here%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fblog.sundayschildsnapshots.com%2Fwp%2F2013%2F09%2Fmore-printed-circuit-boards%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fblog.sundayschildsnapshots.com%2Fwp%2F2013%2F09%2Fmore-printed-circuit-boards%2F%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20DIP%20breakout%20board%20for%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EIn%20order%20to%20put%20the%20on-board%20programming%20on%2C%20the%20K20%20needs%20to%20be%20put%20somewhere.%20The%20McHck%20from%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fmchck.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fmchck.org%3C%2FA%3E%3CSPAN%3E%20can%20be%20used%20as%20a%20small%20external%20programmer%3B%20that%20board%20can%20be%20ordered%20from%20OSHPark%2C%20too.%20Here%20is%20the%20schematic%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MicroKL25Z-DIP-v1-board.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MicroKL25Z-DIP-v1-board.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F41044i6E5515D34C31C6DA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MicroKL25Z-DIP-v1-board.png%22%20alt%3D%22MicroKL25Z-DIP-v1-board.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20still%20need%20to%20formally%20test%20this%20board%3B%20I%20am%20awaiting%20them%20to%20arrive.%26nbsp%3B%20I%20expect%20that%20it%20will%20work%20without%20incident%20like%20the%20%3CA%20href%3D%22http%3A%2F%2Foshpark.com%2Fshared_projects%2F90oLkyZS%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E64QFP%20one%20I%20built%3C%2FA%3E.%26nbsp%3B%20The%20QFP%20is%20much%20easier%20to%20solder...%20%5BMore%20info%20on%20the%20%3CA%20href%3D%22http%3A%2F%2Fblog.sundayschildsnapshots.com%2Fwp%2F2013%2F10%2Fnew-board-for-prototyping-the-functions-of-the-swiss-photoknife%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EQFP%20board%20here%3C%2FA%3E.%5D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMy%20intent%20with%20this%20board%20as%20well%20as%20the%20QFP%20one%20was%20to%20make%20KL25Z%20boards%20that%20I%20could%20employ%20for%20various%20functions.%20I%20am%20in%20need%20of%20more%20than%20a%20handful%20of%20boards%20and%20the%20FRDM-KL25Z%2C%20while%20very%20attractive%2C%20becomes%20cost%20prohibitive%20in%20the%20quantities%20I%20need.%20Once%20the%20software%20for%20each%20function%20is%20mature%20enough%20for%20service%2C%20the%20programmer%20is%20no%20longer%20necessary.%26nbsp%3B%20That'd%20be%20why%20there's%20no%20programmer%20on%20the%20board%20itself%20-%20I'm%20using%20the%20FRDM%20board.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20DIP%20breakout%20board%20for%20KL25Z%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128586%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt'll%20be%20better%20if%20it%20comes%20in%20completely%20soldered%20unit%2C%20on-board%20programming%20interface%20and%20pin%20compatibility%20with%20Arduino%20Nano.%20It%20can%20be%20named%20%22Nano%20Freedom%20Board%22%20%3Asmileylaugh%3A%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎10-18-2013 01:12 PM
Updated by:
