MPC5554 PAD Configuration Register
2,646件の閲覧回数
sureshboddi
Hi, I am using MPC5554 for my project application.
I am an hardware design engineer and I have question regarding usage of GPIOs with pad configuration register (PCR) that corresponds to set of pads (some control 1 and others more than 10).The pad Configuration registers determines the settings of those pads. For example GPIO [147:162] are controlled by same PCR.
Can I use pins from these GPIOs as few inputs and few outputs ??
If yes would like to know how we can configure inputs and outputs using single PCR.
Suresh
0 返答(返信)
