i.MX 8 DRAM Introduction and Tools Overview Plus Hardware Design
Search instead for
No ratings
Start your i.MX 8 project off right!  This class will go through what is required for i.MX 8 hardware design and DRAM initialization. We will also discuss methods of achieving first pass success, even with complicated power routing and high-speed signaling.
Comments
Where I can get DDR Stress Test Tool for i.MX8QX ?
MX8 MSCALE SERIES DDR Tool Release (V2.10) supports only i.MX8M and i.MX8M-mini.
Igor
Lydia‌, can you help answer the question above?
Hi Igor,
I will need to contact you offline as it is not posted externally at this time.
Lydia
Version history
Revision #:
1 of 1
Last update:
‎10-22-2018 04:15 PM
Updated by:
