iOS TagInfo scaremonger
917件の閲覧回数
gentilkiwi
When using iOS TagInfo with a Random UID enabled card (a Desfire by eg.), the application show 'Non-genuine, most probably counterfeit product' in the 'IC Manufacturer' field.
A little bit alarmist, as to not be able to check is an expected behavior because of the Random UID.
> Android version does not show this message
(btw, it does not make difference between a Desfire EV2 and a Desfire EV2 XL, Android version does - iOS version has the same information from GetVersion though)
0 返答(返信)
