Write Data
Write Data
athul_pm
I am currently working on writing the following URL to an NDEF file after authentication:
https://choose.url.com/ntag424?e=00000000000000000000000000000000&c=0000000000000000
The write file access was set to 0. Here are the details:
  • TI: 9D00C4DF
  • CmdCtr: 0000
  • KSesAuthMAC: 4C6626F5E72EA694202139295C7A7FC7
  • KSesAuthENC: 1309C877509E5A215007FF0ED19CA564
I referred to the AN12196.pdf, specifically section 5.8.2 "Write NDEF File - using Cmd.WriteData, CommMode.FULL".(values above are according to the document) However, I am having difficulty understanding how the commands were calculated to the final form:
908D00009F02000000800000421C73A27D827658AF481 FDFF20A5025B559D0E3AA21E58D347F343CFFC768BFE596 C706BC00F2176781D4B0242642A0FF5A42C461AAF894D9 A1284B8C76BCFA658ACD40555D362E08DB15CF421B51283 F9064BCBE20E96CAE545B407C9D651A3315B27373772E5 DA2367D2064AE054AF996C6F1F669170FA88CE8C4E3A4A7 BBBEF0FD971FF532C3A802AF745660F2B4D1D9A8499661EBF300
KaiLi
Hello @athul_pm
All the steps are described in Table17, so what steps do you not understand?
