Unable to enable pass-though mode on Android using TapLinx
1,658 次查看
ashahaf
Hi all,
I'm trying to use fastWrite() on my NTAG I²C Plus 2K tag using TapLinx for Android.
When I use fastWrite(), it fails with passive-mode isn't enabled.
Then I used enablePassMode(true), but got
com.nxp.nfclib.exceptions.NxpNfcLibException: Transceive failed
I'm running a modified version of the sample app, on Pixel 6a.
Any suggestions?
Thanks in advance,
Alon.
标记 (2)
1,500 次查看
ukcas
Dear ashahaf,
Please excuse the delay.
In order to use fastWrite() on NTAG I²C plus:
- NTAG I²C plus needs to be Vcc powered
- It works on SRAM memory only (start block address (F0h), end address (FFh))
UK
