Taplinx iOS - apduExchange(withByteArray apduData: Data) -> TL_TagAPDUResponse?
635件の閲覧回数
sh4
according to UG10045 I setup the project, but apduExchange method not calling. Can you provide the sample project or detail about how to initialise TLLibraryManager and create instance.
7 返答(返信)
563件の閲覧回数
DamianD
there is no sample app that i know of, i also asked here about it and got no helpful answer. On what line exactly does you app crashes? show some code
556件の閲覧回数
sh4
  func beginSession() {
    guard NFCTagReaderSession.readingAvailable else {
      onError?("NFC not supported on this device.")
      return
    session = NFCTagReaderSession(pollingOption: [.iso14443], delegate: self, queue: queue)
    session?.alertMessage = "Hold your iPhone near the NFC tag."
    session?.begin()
    self.handler = TapLinxApduHandler()
    self.handler?.delegate = self
    TLLibraryManager.shared().setApduHandlerWithApduHandler(handler)
when I define TLLibraryManager.shared() then it getting crash with error
error: memory read failed for 0x10.
552件の閲覧回数
DamianD
call first TapLinxLibrary.SharedLibrary.VerifyLicense - does it also crash on call to verifyLicense?
549件の閲覧回数
sh4
No, not crash on that.
and I got it.
"Online license verified successfully, time to explore Taplinx Library"
546件の閲覧回数
DamianD
ok, please take a look at https://community.nxp.com/t5/TapLinx-SDK-TagWriter-and/Taplinx-iOS-appcrash-on-tag-response/m-p/1991... and see if sample code in swift posted there by nxp employee helps you. You will have to move setting apduHandler into tag detected event because reader needs access to that tag.
581件の閲覧回数
DamianD
1. header files are lying - you have to return IOSByteArray from apduExchange method, not TL_TagAPDUResponse. As for calling your apduExchange method, do something like this:
Taplinx.iOS.TapLinxLibrary.SharedLibrary.VerifyLicense(licenseKey, (success, errMsg) =>
    if (success == true)
        NFCTagReaderSession = new NFCTagReaderSession(NFCPollingOption.Iso14443
            , this, DispatchQueue.DefaultGlobalQueue);
        NFCTagReaderSession.BeginSession();
        TLLibraryManager.Shared.SetApduHandlerWithApduHandler(apduHandler);
and in tag detection event, just connect tag to session and call appropriate methods, example:
 TLLibraryManager.Shared.GetTagDetailsOnCompletion
565件の閲覧回数
sh4
I have a Mifare Desfire EV2 tag and when I am creating an instance like that TLLibraryManager.shared() and the application getting crashes and return an error
error: memory read failed for 0x24.
I detected a tag in this method
func tagReaderSession(_ session: NFCTagReaderSession, didDetect tags: [NFCTag]).
can you please share more details or the sample app for
reference?
