TapLinx iOS SDK, Xcode 16.4
LukaszWojcikIteo
I'm trying to integrate the TapLinxLibrary into my iOS project, but I'm currently facing issues:
  • I followed the instructions in UG10045.
  • Added a missing step: updated Swift Compiler - Search Paths to $(PROJECT_DIR)/TapLinxLibrary.
  • Searched the forum for similar cases but couldn't find a solution.
Depending on the Xcode version, I encounter different incompatibility errors. Currently, on Xcode 16.4, I'm getting the following Swift version error:
Module compiled with Swift 5.8 cannot be imported by Swift 6.1.2.
What confuses me is that in a similar post:
https://community.nxp.com/t5/TapLinx-SDK-TagWriter-and/is-TapLinx-IOS-SDK-incompatible-with-Xcode-16...
the user seems to have encountered an error related to a more recent Xcode version and based on date of the post, he's been using previous TapLinx version.
It seems like current TapLinx has been compiled with less recent Xcode?
In my case, the error references Swift 5.8, which was last used in Xcode 14.3, while the other post mentions iphoneos17.5 SDK, which corresponds to Xcode 15.4.
The option that I'm using outdated library crossed my mind, but is there even possibility to do so? I've started my development with this library not event week ago
I would really appreciate any guidance on resolving this issue or verifying the library's compatibility with Xcode and Swift versions.
Thanks in advance!
