Integrity error while trying to change key settings (PICC) for DESFire EV1 cards
voidazos
When attempting to change PICC key settings on DESFire EV1 cards I get the following error: com.nxp.nfclib.exceptions.PICCException: Integrity Error SW2 = 30
at com.nxp.nfclib.desfire.DESFireUtil.invalidResponse(:229)
at com.nxp.nfclib.desfire.DESFireEV1.changeKeySettings(:879)
Here is a minimal example code causing this:
public void initNewCard(IDESFireEV1 card) {
log("Connecting to card reader");
card.getReader().connect();
log("Starting to init card with id %s, selecting app", Utilities.dumpBytes(card.getUID()));
card.selectApplication(0);
String status = card.getAuthStatus();
log("Current auth status %s", status);
EV1PICCKeySettings keySettings = (EV1PICCKeySettings) card.getKeySettings();
log(
"PICC settings: %s %s",
String.valueOf(keySettings.isPiccKeySettingsChangeable()),
String.valueOf(keySettings.isPiccMasterKeyChangeable())
log("Authenticating");
default2KDESAuthenticate(card);
card.changeKeySettings(makeInUsePICCKeySettings()); // this changeKeySettings() call causes the exception
private EV1PICCKeySettings makeInUsePICCKeySettings() {
EV1PICCKeySettings.Builder builder = new EV1PICCKeySettings.Builder();
builder.setPiccKeySettingsChangeable(true)
.setPiccMasterKeyChangeable(true)
.setAuthenticationRequiredForApplicationManagement(false)
.setAuthenticationRequiredForDirectoryConfigurationData(false);
return builder.build();
I would like to kindly ask for your help with this issue. I have tried formatting the cards and otherwise writing to them seems to work. Am I doing something wrong?
The relevant output is:
Starting to init card with id 0x042A43B2EC6A80, selecting app
Current auth status Not Authenticated
PICC settings: true true
Authenticating
Current auth status Native
Labels (3)
KaiLi
Hello @voidazos
First, you need to select an existing application and file, and successfully authenticate it, and then you can use the command (changeKey) to modify the key, please try again.
vincentthivent
have you received the ats for the desfire card?
Vincent
