failed to send message 100 ret is 0 while loading AMDGPU
1,002 次查看
Ganesh3955
While loading AMDGPU driver in T1040 board , i  getting following error, what could be the issue here
root@t1042d4rdb:~# insmod /amdgpu.ko
[drm] amdgpu kernel modesetting enabled.
amdgpu 0001:01:00.0: enabling device (0006 -> 0007)
[drm] initializing kernel modesetting (POLARIS12 0x1002:0x6987 0x1787:0x2389 0x80).
amdgpu 0001:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[drm] register mmio base: 0xA0000000
[drm] register mmio size: 262144
[drm] PCIE atomic ops is not supported
[drm] add ip block number 0 <vi_common>
[drm] add ip block number 1 <gmc_v8_0>
[drm] add ip block number 2 <tonga_ih>
[drm] add ip block number 3 <gfx_v8_0>
[drm] add ip block number 4 <sdma_v3_0>
[drm] add ip block number 5 <powerplay>
[drm] add ip block number 6 <dm>
[drm] add ip block number 7 <uvd_v6_0>
[drm] add ip block number 8 <vce_v3_0>
[drm:.check_atom_bios [amdgpu]] ATOMBIOS detected
amdgpu 0001:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
amdgpu: ATOM BIOS: 113-ER16BFE-001
[drm:.amdgpu_atombios_init [amdgpu]] atom firmware requested 00000000 0kb
[drm] UVD is enabled in VM mode
[drm] UVD ENC is enabled in VM mode
[drm] VCE enabled in VM mode
[drm] GPU posting now...
[drm] vm size is 64 GB, 2 levels, block size is 10-bit, fragment size is 9-bit
[drm:.gmc_v8_0_sw_init [amdgpu]]
amdgpu 0001:01:00.0: BAR 2: releasing [mem 0xd10000000-0xd101fffff 64bit pref]
amdgpu 0001:01:00.0: BAR 0: releasing [mem 0xd00000000-0xd0fffffff 64bit pref]
pcieport 0001:00:00.0: BAR 9: releasing [mem 0xd00000000-0xeffffffff 64bit pref]
pcieport 0001:00:00.0: BAR 9: assigned [mem 0xd00000000-0xe7fffffff 64bit pref]
amdgpu 0001:01:00.0: BAR 0: assigned [mem 0xd00000000-0xdffffffff 64bit pref]
amdgpu 0001:01:00.0: BAR 2: assigned [mem 0xe00000000-0xe001fffff 64bit pref]
pcieport 0001:00:00.0: PCI bridge to [bus 01]
pcieport 0001:00:00.0: bridge window [io 0x8000080000010000-0x800008000001ffff]
pcieport 0001:00:00.0: bridge window [mem 0xa0000000-0xafffffff]
pcieport 0001:00:00.0: bridge window [mem 0xd00000000-0xe7fffffff 64bit pref]
amdgpu 0001:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
amdgpu 0001:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
[drm] Detected VRAM RAM=4096M, BAR=4096M
[drm] RAM width 128bits GDDR5
[drm] amdgpu: 4096M of VRAM memory ready
[drm] amdgpu: 1457M of GTT memory ready.
[drm] GART: num cpu pages 65536, num gpu pages 65536
[drm:.amdgpu_ucode_print_mc_hdr [amdgpu]] MC
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] size_bytes: 32608
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] header_size_bytes: 40
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] header_version_major: 1
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] header_version_minor: 0
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ip_version_major: 8
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ip_version_minor: 1
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ucode_version: 0x00b4dc50
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ucode_size_bytes: 32160
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ucode_array_offset_bytes: 448
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] crc32: 0x9b1e395c
[drm:.amdgpu_ucode_print_mc_hdr [amdgpu]] io_debug_size_bytes: 192
[drm:.amdgpu_ucode_print_mc_hdr [amdgpu]] io_debug_array_offset_bytes: 256
[drm] PCIE GART of 256M enabled (table at 0x000000F400000000).
[drm:.amdgpu_irq_init [amdgpu]] amdgpu: irq initialized.
[drm:.gfx_v8_0_sw_init [amdgpu]]
[drm] Chained IB support enabled!
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring gfx use gpu addr 0x000000ff00400040
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.0.0 use gpu addr 0x000000ff004000e0
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.1.0 use gpu addr 0x000000ff00400180
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.2.0 use gpu addr 0x000000ff00400220
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.3.0 use gpu addr 0x000000ff004002c0
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.0.1 use gpu addr 0x000000ff00400360
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.1.1 use gpu addr 0x000000ff00400400
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.2.1 use gpu addr 0x000000ff004004a0
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.3.1 use gpu addr 0x000000ff00400540
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring kiq_2.1.0 use gpu addr 0x000000ff004005e0
[drm:.sdma_v3_0_sw_init [amdgpu]]
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring sdma0 use gpu addr 0x000000ff00400680
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring sdma1 use gpu addr 0x000000ff00400720
amdgpu: hwmgr_sw_init smu backed is polaris10_smu
[drm] Found UVD firmware Version: 1.130 Family ID: 16
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring uvd use gpu addr 0x000000f4001afa80
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring uvd_enc0 use gpu addr 0x000000ff00400860
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring uvd_enc1 use gpu addr 0x000000ff00400900
[drm] Found VCE firmware Version: 53.26 Binary ID: 3
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring vce0 use gpu addr 0x000000ff004009a0
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring vce1 use gpu addr 0x000000ff00400a40
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring vce2 use gpu addr 0x000000ff00400ae0
[drm:.amdgpu_ucode_print_smc_hdr [amdgpu]] SMC
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] size_bytes: 130388
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] header_size_bytes: 36
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ip_version_major: 7
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ip_version_minor: 2
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ucode_version: 0x00221700
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ucode_size_bytes: 130132
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ucode_array_offset_bytes: 256
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] crc32: 0xae2b3b78
[drm:.amdgpu_ucode_print_smc_hdr [amdgpu]] ucode_start_addr: 131072
amdgpu:
amdgpu: SMU Firmware start failed!
amdgpu: Failed to load SMU ucode.
amdgpu: fw load failed
amdgpu: smu firmware loading failed
amdgpu 0001:01:00.0: amdgpu: amdgpu_device_ip_init failed
amdgpu 0001:01:00.0: amdgpu: Fatal error during GPU init
amdgpu 0001:01:00.0: amdgpu: amdgpu: finishing device.
[drm:.gfx_v8_0_set_eop_interrupt_state [amdgpu]] invalid me 2
amdgpu: probe of 0001:01:00.0 failed with error -22
BUG: Unable to handle kernel data access on read at 0x8000080080954000
Faulting instruction address: 0xc000000000011870
Oops: Kernel access of bad area, sig: 11 [#1]
BE PAGE_SIZE=4K SMP NR_CPUS=24 CoreNet Generic
Modules linked in: amdgpu(+) backlight drm_ttm_helper ttm gpu_sched ucc_uart fsl_jr_uio
CPU: 2 PID: 816 Comm: insmod Not tainted 5.15.71+g95448dd0dc9b #1
**bleep**: c000000000011870 LR: 8000000000e0d120 CTR: 0000000000058400
REGS: c00000000a956d80 TRAP: 0300 Not tainted (5.15.71+g95448dd0dc9b)
MSR: 0000000080029002 <CE,EE,ME> CR: 22002228 XER: 00000000
DEAR: 8000080080954000 ESR: 0000000000000000 IRQMASK: 0
GPR00: 8000000000e0d100 c00000000a957020 c0000000013faa00 c00000000c000000
GPR04: 8000080080954000 00000000002c2000 00000000000b0800 000000007ecc9000
GPR08: 0000000000058400 8000080080954000 c00000000bfffffc 80000000010b76d8
GPR12: c0000000000117f4 c00000003ffff140 000000010b5456f0 000000010b4fa188
GPR16: 0000000000000000 000000010b545810 000000010b5202b0 0000000000000000
GPR20: 0000000000000000 0000000000000000 c00000000ae16a48 8000080080954000
GPR24: 00000000002c2000 0000000000000000 c00000000ae00010 0000000000000001
GPR28: c00000000ae00000 c00000000ae10000 0000000000000000 c00000000ae10000
**bleep** [c000000000011870] ._memcpy_fromio+0x7c/0x100
LR [8000000000e0d120] .amdgpu_uvd_suspend+0x1d4/0x268 [amdgpu]
Call Trace:
[c00000000a957020] [8000000000e0d100] .amdgpu_uvd_suspend+0x1b4/0x268 [amdgpu] (unreliable)
[c00000000a9570f0] [8000000000e1110c] .uvd_v6_0_sw_fini+0x1c/0xcc [amdgpu]
[c00000000a957180] [8000000000cf24b0] .amdgpu_device_fini_sw+0x124/0x378 [amdgpu]
[c00000000a957240] [8000000000cf9e0c] .amdgpu_driver_release_kms+0x1c/0x40 [amdgpu]
[c00000000a9572c0] [c000000000704380] .devm_drm_dev_init_release+0x78/0xcc
[c00000000a957340] [c000000000755248] .devm_action_release+0x28/0x3c
[c00000000a9573b0] [c00000000075576c] .release_nodes+0x78/0x108
[c00000000a957450] [c000000000757174] .devres_release_all+0xa8/0x11c
[c00000000a957510] [c00000000074f788] .really_probe.part.0+0x1b8/0x440
[c00000000a9575b0] [c00000000074fad8] .__driver_probe_device+0xc8/0x198
[c00000000a957640] [c00000000074fbf8] .driver_probe_device+0x50/0x16c
[c00000000a9576e0] [c00000000075055c] .__driver_attach+0xb4/0x200
[c00000000a957770] [c00000000074c518] .bus_for_each_dev+0x9c/0x110
[c00000000a957820] [c00000000074eca4] .driver_attach+0x24/0x38
[c00000000a957890] [c00000000074e4ec] .bus_add_driver+0x1d4/0x2a8
[c00000000a957940] [c00000000075107c] .driver_register+0xa4/0x194
[c00000000a9579c0] [c0000000006217ec] .__pci_register_driver+0x58/0x6c
[c00000000a957a30] [80000000010a9608] .amdgpu_init+0x74/0x94 [amdgpu]
[c00000000a957ab0] [c0000000000021cc] .do_one_initcall+0x6c/0x284
[c00000000a957b90] [c0000000001174a4] .do_init_module+0x5c/0x2bc
[c00000000a957c30] [c00000000011a980] .__do_sys_finit_module+0xc4/0x10c
[c00000000a957d60] [c000000000012454] .system_call_exception+0x11c/0x1c4
[c00000000a957e10] [c0000000000001f8] system_call_common+0xf0/0x210
--- interrupt: c00 at 0x3fffbe532ee4
**bleep**: 00003fffbe532ee4 LR: 00000001366cdbfc CTR: 0000000000000000
REGS: c00000000a957e80 TRAP: 0c00 Not tainted (5.15.71+g95448dd0dc9b)
MSR: 000000008002d002 <CE,EE,PR,ME> CR: 28002882 XER: 00000000
IRQMASK: 0
GPR00: 0000000000000161 00003fffd14f61a0 00003fffbe637200 0000000000000003
GPR04: 00000001366d9148 0000000000000000 0000000000000000 0000000000000000
GPR08: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
GPR12: 0000000000000000 00003fffbe6cf810 000000010b5456f0 000000010b4fa188
GPR20: 0000000000000000 0000000000000000 0000000000000002 00003fffd14f6ee5
GPR24: 00003fffd14f6860 00000001366fd9e8 0000000000000000 00000001366fcbd0
GPR28: 00000001366d9148 0000000000000000 0000000000000000 0000000136701760
**bleep** [00003fffbe532ee4] 0x3fffbe532ee4
LR [00000001366cdbfc] 0x1366cdbfc
--- interrupt: c00
Instruction dump:
4e800020 28250003 40810068 3905fffc 7908f082 38c80001 70c90001 3943fffc
7c892378 40820070 78c8f842 7d0903a6 <80e90000> 390a0004 90ea0004 7c0006ac
---[ end trace e1f14bc598aaf8c6 ]---
Segmentation fault
标记 (1)
3 回复数
994 次查看
Bio_TICFSL
Your log indicates AMDGPU fails during Polaris12 SMU firmware startup, while PCIe appears to enumerate correctly enough to reach late GPU init, so the issue is more likely driver/platform compatibility or probe-cleanup failure than basic T1040 PCIe link training.
943 次查看
Ganesh3955
Hi @Bio_TICFSL
I Bypassed SMU in AMDGPU driver , now i am facing below error(gfx ring test failure)
pcieport 0001:00:00.0: bridge window [io 0x8000080000010000-0x800008000010ffff]
[drm:.amdgpu_ih_process [amdgpu]] amdgpu_ih_process: rptr 0, wptr 16
[drm:.amdgpu_irq_dispatch [amdgpu]] Unhandled interrupt src_id: 141
amdgpu 0001:01:00.0: [drm:.amdgpu_ring_test_helper [amdgpu]] *ERROR* ring gfx test failed (-110)
[drm:.amdgpu_device_init [amdgpu]] *ERROR* hw_init of IP block <gfx_v8_0> failed -110
amdgpu: probe of 0001:01:00.0 failed with error -110
CPU: 2 PID: 819 Comm: insmod Not tainted 5.15.71+g95448dd0dc9b #1
**bleep**: c000000000011870 LR: 8000000000e0efe0 CTR: 0000000000058400
REGS: c00000000a5aad80 TRAP: 0300 Not tainted (5.15.71+g95448dd0dc9b)
GPR00: 8000000000e0efc0 c00000000a5ab020 c0000000013e8c00 c00000000c000000
GPR04: 8000080080954000 00000000002c2000 00000000000b0800 000000007ecd9000
GPR08: 0000000000058400 8000080080954000 c00000000bfffffc 80000000010b8988
GPR12: c0000000000117f4 c00000003ffff140 00000001050e5850 000000010509a188
GPR16: 0000000000000000 00000001050e5990 00000001050bfb80 0000000000000000
GPR20: 0000000000000000 0000000000000000 c00000000a916a48 8000080080954000
GPR24: 00000000002c2000 0000000000000000 c00000000a900010 0000000000000001
GPR28: c00000000a900000 c00000000a910000 0000000000000000 c00000000a910000
LR [8000000000e0efe0] .amdgpu_uvd_suspend+0x1d4/0x268 [amdgpu]
Call Trace:
[c00000000a5ab020] [8000000000e0efc0] .amdgpu_uvd_suspend+0x1b4/0x268 [amdgpu] (unreliable)
[c00000000a5ab0f0] [8000000000e12fcc] .uvd_v6_0_sw_fini+0x1c/0xcc [amdgpu]
[c00000000a5ab180] [8000000000cf44b0] .amdgpu_device_fini_sw+0x124/0x378 [amdgpu]
[c00000000a5ab240] [8000000000cfbe0c] .amdgpu_driver_release_kms+0x1c/0x40 [amdgpu]
[c00000000a5ab2c0] [c0000000006fa1e4] .devm_drm_dev_init_release+0x78/0xcc
[c00000000a5ab340] [c00000000074b0ac] .devm_action_release+0x28/0x3c
[c00000000a5ab3b0] [c00000000074b5d0] .release_nodes+0x78/0x108
[c00000000a5ab450] [c00000000074cfd8] .devres_release_all+0xa8/0x11c
[c00000000a5ab510] [c0000000007455ec] .really_probe.part.0+0x1b8/0x440
[c00000000a5ab5b0] [c00000000074593c] .__driver_probe_device+0xc8/0x198
[c00000000a5ab640] [c000000000745a5c] .driver_probe_device+0x50/0x16c
[c00000000a5ab6e0] [c0000000007463c0] .__driver_attach+0xb4/0x200
[c00000000a5ab770] [c00000000074237c] .bus_for_each_dev+0x9c/0x110
[c00000000a5ab820] [c000000000744b08] .driver_attach+0x24/0x38
[c00000000a5ab890] [c000000000744350] .bus_add_driver+0x1d4/0x2a8
[c00000000a5ab940] [c000000000746ee0] .driver_register+0xa4/0x194
[c00000000a5ab9c0] [c0000000006211dc] .__pci_register_driver+0x58/0x6c
[c00000000a5aba30] [80000000010aa8e8] .amdgpu_init+0x74/0x94 [amdgpu]
[c00000000a5abab0] [c0000000000021cc] .do_one_initcall+0x6c/0x284
[c00000000a5abb90] [c000000000116ea0] .do_init_module+0x5c/0x2bc
[c00000000a5abc30] [c00000000011a37c] .__do_sys_finit_module+0xc4/0x10c
[c00000000a5abd60] [c000000000012454] .system_call_exception+0x11c/0x1c4
[c00000000a5abe10] [c0000000000001f8] system_call_common+0xf0/0x210
--- interrupt: c00 at 0x3fff82934ee4
**bleep**: 00003fff82934ee4 LR: 00000001194adbfc CTR: 0000000000000000
REGS: c00000000a5abe80 TRAP: 0c00 Not tainted (5.15.71+g95448dd0dc9b)
IRQMASK: 0
GPR00: 0000000000000161 00003fffefee52c0 00003fff82a39200 0000000000000003
GPR04: 00000001194b9148 0000000000000000 0000000000000000 0000000000000000
GPR12: 0000000000000000 00003fff82ad1810 00000001050e5850 000000010509a188
GPR20: 0000000000000000 0000000000000000 0000000000000002 00003fffefee5ee5
GPR24: 00003fffefee5980 00000001194dd9e8 0000000000000000 00000001194dcbd0
GPR28: 00000001194b9148 0000000000000000 0000000000000000 00000001194e1760
**bleep** [00003fff82934ee4] 0x3fff82934ee4
LR [00000001194adbfc] 0x1194adbfc
--- interrupt: c00
Instruction dump:
---[ end trace fef1e0dc2e9ff52c ]---
标记 (1)
962 次查看
Ganesh3955
Hi @Bio_TICFSL
Thank you for you reply,
May i know whether the following platforms are compatible with each other:
     - > NXP T1040 with AMD E9171 GPU
     - > NXP T2080 with AMD E9171 GPU
     - > NXP T2080 with AMD E8860 GPU
标记 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-2364970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%8A%A0%E8%BD%BD%20AMDGPU%20%E6%97%B6%E5%8F%91%E9%80%81%E4%BF%A1%E6%81%AF%20100%20%E5%A4%B1%E8%B4%A5%20ret%20%E4%B8%BA%200%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2364970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%9C%A8%20T1040%20%E4%B8%BB%E6%9D%BF%E4%B8%AD%E5%8A%A0%E8%BD%BD%20AMDGPU%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%97%B6%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%8C%E8%BF%99%E9%87%8C%E5%8F%AF%E8%83%BD%E6%9C%89%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Eroot%40t1042d4rdb%3A~%23%20insmod%20%2Famdgpu.ko%3CBR%20%2F%3E%5Bdrm%5D%20amdgpu%20%E5%86%85%E6%A0%B8%E6%A8%A1%E5%BC%8F%E8%AE%BE%E7%BD%AE%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%E5%90%AF%E7%94%A8%E8%AE%BE%E5%A4%87%20(0006-%26gt%3B%200007)%20%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%AD%A3%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E5%86%85%E6%A0%B8%E6%A8%A1%E5%BC%8F%E8%AE%BE%E7%BD%AE%EF%BC%88POLARIS12%200x%201002%3A0%20x6987%200x%201787%3A0%20x2389%200x2389%200x80%EF%BC%89%E3%80%82%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%EF%BC%9A%E4%B8%8D%E6%94%AF%E6%8C%81%E5%8F%AF%E4%BF%A1%E5%86%85%E5%AD%98%E5%8C%BA%EF%BC%88TMZ%EF%BC%89%E5%8A%9F%E8%83%BD%3CBR%20%2F%3E%5Bdrm%5D%20%E5%AF%84%E5%AD%98%E5%99%A8%20mmio%20base%EF%BC%9A0xA0000000%3CBR%20%2F%3E%5Bdrm%5D%20register%20mmio%20size%EF%BC%9A262144%3CBR%20%2F%3E%5Bdrm%5D%20%E4%B8%8D%E6%94%AF%E6%8C%81%20PCIE%20%E5%8E%9F%E5%AD%90%E6%93%8D%E4%BD%9C%3CBR%20%2F%3E%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20%E5%9D%97%E7%BC%96%E5%8F%B7%200%3CVI_COMMON%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20%E5%9D%97%E7%BC%96%E5%8F%B7%201%3CGMC_V8_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20%E5%9D%97%E7%BC%96%E5%8F%B7%202%3CTONGA_IH%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20%E5%9D%97%E7%BC%96%E5%8F%B7%203%3CGFX_V8_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20block%20number%204%3CSDMA_V3_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20block%20number%205%3CPOWERPLAY%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20block%20number%206%3CDM%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20block%20number%207%3CUVD_V6_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20block%20number%208%3CVCE_V3_0%3E%3CBR%20%2F%3E%20%5Bdrm%EF%BC%9A.check_atom_bios%5Bamdgpu%5D%5DATOMBIOS%20%E6%A3%80%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%3A%20Fetched%20VBIOS%20from%20ROM%20BAR%3CBR%20%2F%3Eamdgpu%3A%20ATOM%20BIOS%3A%20113-ER16BFE-001%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_atombios_init%5Bamdgpu%5D%5D%20%E8%AF%B7%E6%B1%82%E5%8E%9F%E5%AD%90%E5%9B%BA%E4%BB%B6%2000000000%200kb%3CBR%20%2F%3E%5Bdrm%5D%20UVD%20%E5%9C%A8%E8%99%9A%E6%8B%9F%E6%9C%BA%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%5Bdrm%5D%20UVD%20ENC%20%E5%9C%A8%E8%99%9A%E6%8B%9F%E6%9C%BA%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%5Bdrm%5D%20VCE%20%E5%9C%A8%E8%99%9A%E6%8B%9F%E6%9C%BA%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%5Bdrm%5D%20GPU%20%E6%AD%A3%E5%9C%A8%E5%8F%91%E5%B8%83...%3CBR%20%2F%3E%5Bdrm%5D%20%E8%99%9A%E6%8B%9F%E6%9C%BA%E5%A4%A7%E5%B0%8F%E4%B8%BA%2064%20GB%EF%BC%8C2%20%E7%BA%A7%EF%BC%8C%E5%9D%97%E5%A4%A7%E5%B0%8F%E4%B8%BA%2010%20%E4%BD%8D%EF%BC%8C%E7%89%87%E6%AE%B5%E5%A4%A7%E5%B0%8F%E4%B8%BA%209%20%E4%BD%8D%3CBR%20%2F%3E%5Bdrm%3A.gmc_v8_0_sw_init%5Bamdgpu%5D%5D%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9ABAR%202%EF%BC%9A%E5%8F%91%E5%B8%83%20%5Bmem%200xd100000000-0xd101ffff%2064%20%E4%BD%8D%E9%A6%96%E9%80%89%E9%A1%B9%5D%20amdgpu%200001%3A01%3A00.0%EF%BC%9A%3CBR%20%2F%3EBAR%200%EF%BC%9A%E5%8F%91%E5%B8%83%20%5Bmem%200xd0000000000-0xd0ffffff%2064%20%E4%BD%8D%E9%A6%96%E9%80%89%E9%A1%B9%5D%20pcieport%200001%3A00%3A00%3A00.0%EF%BC%9A%3CBR%20%2F%3EBAR%209%EF%BC%9A%E5%8F%91%E5%B8%83%20%5Bmem%200xd0000000000-0xefffffff%2064%20%E4%BD%8D%E9%A6%96%E9%80%89%E9%A1%B9%5D%20pcieport%200001%3A00%3A00%3A00.0%EF%BC%9A%3CBR%20%2F%3EBAR%209%3A%20%E5%88%86%E9%85%8D%20%5Bmem%200xd00000000-0xe7fffffff%2064bit%20pref%5D%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%20%5Bmem%200xd00000000-0xdffffffff%2064bit%20pref%5D%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9ABAR%202%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%20%5Bmem%200xe00000000-0xe001fffff%2064bit%20pref%5D%3CBR%20%2F%3Epcieport%200001%3A00%3A00.0%EF%BC%9APCI%20%E6%A1%A5%E6%8E%A5%E5%88%B0%20%5B%E6%80%BB%E7%BA%BF%2001%5D%20%3CBR%20%2F%3E%20pcieport%200001%3A00%3A00.0%EF%BC%9Abridge%20window%20%5Bio%200x8000080000010000-0x800008000001ffff%5D%3CBR%20%2F%3Epcieport%200001%3A00%3A00.0%EF%BC%9Abridge%20window%20%5Bmem%200xa0000000-0xafffffff%5D%3CBR%20%2F%3Epcieport%200001%3A00%3A00.0%EF%BC%9Abridge%20window%20%5Bmem%200xd00000000-0xe7fffffff%2064bit%20pref%5D%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%3A%20VRAM%3A%204096M%200x000000F400000000%20-%200x000000F4FFFFFFFF%20(4096M%20%E5%B7%B2%E7%94%A8)%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%3A%20GART%3A%20256M%200x000000FF00000000%20-%200x000000FF0FFFFFFF%3CBR%20%2F%3E%5Bdrm%5D%20Detected%20VRAM%20RAM%3D4096M%2C%20BAR%3D4096M%3CBR%20%2F%3E%5Bdrm%5D%20RAM%20width%20128bits%20GDDR5%3CBR%20%2F%3E%5Bdrm%5D%20amdgpu%3A%204096M%20of%20VRAM%20memory%20ready%3CBR%20%2F%3E%5Bdrm%5D%20amdgpu%3A%201457M%20of%20GTT%20memory%20ready.%3CBR%20%2F%3E%5Bdrm%5D%20GART%EF%BC%9Acpu%20%E9%A1%B5%E6%95%B0%2065536%EF%BC%8Cgpu%20%E9%A1%B5%E6%95%B0%2065536%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_mc_hdr%5Bamdgpu%5D%5DMC%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20size_bytes%EF%BC%9A32608%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_size_bytes%EF%BC%9A40%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_version_major%3A%201%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_version_minor%3A%200%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ip_version_major%3A%208%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ip_version_minor%3A%201%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_version%3A%200x00b4dc50%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr32160%20%20%5Bdrm%3A.amdgpu_ucode_print_mon_hdrtes%EF%BC%9A32160%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_array_offset_bytes%EF%BC%9A448%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20crc32%3A%200x9b1e395c%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_mc_hdr%5Bamdgpu%5D%5D%20io_debug_size_bytes%3A%20192%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_mc_hdr%5Bamdgpu%5D%5D%20io_debug_array_offset_bytes%3A%20256%3CBR%20%2F%3E%5Bdrm%5D%20%E5%B7%B2%E5%90%AF%E7%94%A8%20256M%20%E7%9A%84%20PCIE%20GART%EF%BC%88%E8%A1%A8%E4%BD%8D%E4%BA%8E%200x000000F400000000%EF%BC%89%E3%80%82%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_irq_init%5Bamdgpu%3A%20irq%20%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_sw_init%5Bamdgpu%5D%5D%3CBR%20%2F%3E%5Bdrm%5D%20%E9%93%BE%E5%BC%8F%20IB%20%E6%94%AF%E6%8C%81%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%81%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20gfx%20use%20gpu%20addr%200x000000ff00400040%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.0.0%20use%20gpu%20addr%200x000000ff004000e0%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5Dcomp_1.1.0%E7%8E%AF%E4%B8%8A%E7%9A%84%E6%A0%85%E6%A0%8F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fuse%20gpu%20addr%200x000000ff00400180%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.2.0%20use%20gpu%20addr%200x000000ff00400220%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.3.0%20use%20gpu%20addr%200x000000ff004002c0%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.0.1%20use%20gpu%20addr%200x000000ff00400360%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.1.1%20use%20gpu%20addr%200x000000ff00400400%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.2.1%20use%20gpu%20addr%200x000000ff004004a0%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.3.1%20use%20gpu%20addr%200x000000ff00400540%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bkiq_2.1.0%20%E7%8E%AF%E4%B8%8A%E7%9A%84%E6%A0%85%E6%A0%8F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fuse%20gpu%20addr%200x000000ff004005e0%3CBR%20%2F%3E%5Bdrm%3A.sdma_v3_0_sw_init%5Bamdgpu%5D%5D%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20sdma0%20use%20gpu%20addr%200x000000ff00400680%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20ring%20sdma1%20%E4%B8%8A%E7%9A%84%E6%A0%85%E6%A0%8F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BD%BF%E7%94%A8%20gpu%20%E5%9C%B0%E5%9D%80%200x000000ff00400720%20amdgpu%EF%BC%9Ahwmgr_sw_init%20smu%20%E6%94%AF%E6%8C%81%E7%9A%84%E6%98%AF%20polaris10_smu%20%5Bdrm%5D%20%E6%89%BE%E5%88%B0%E4%BA%86%20%3CBR%20%2F%3E%20UVD%20%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9A1.130%20%E7%B3%BB%E5%88%97%20ID%EF%BC%9A16%20amdgpu%200001%3A01%3A00.0%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20uvd%20use%20gpu%20addr%200x000000f4001afa80%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20uvd_enc0%20use%20gpu%20addr%200x000000ff00400860%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E6%88%92%E6%8C%87%E4%B8%8A%E7%9A%84%E6%A0%85%E6%A0%8F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20uvd_enc1%20%E4%BD%BF%E7%94%A8%20gpu%20%E5%9C%B0%E5%9D%80%200x000000ff00400900%20%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%89%BE%E5%88%B0%E4%BA%86%20VCE%20%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9A53.26%20%E4%BA%8C%E8%BF%9B%E5%88%B6%20ID%EF%BC%9A3%20amdgpu%200001%3A01%3A00.0%EF%BC%9A%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20vce0%20use%20gpu%20addr%200x000000ff004009a0%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20vce1%20use%20gpu%20addr%200x000000ff00400a40%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E7%8E%AF%20vce2%20%E4%B8%8A%E7%9A%84%E5%9B%B4%E6%A0%8F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BD%BF%E7%94%A8%20gpu%20%E5%9C%B0%E5%9D%80%200x000000ff00400ae0%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_smc_hdr%5Bamdgpu%5D%5D%E3%80%82SMC%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20size_bytes%3A%20130388%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_size_bytes%EF%BC%9A36%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_version_major%3A%201%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_version_minor%3A%200%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ip_version_major%3A%207%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ip_version_minor%3A%202%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_version%3A%200x00221700%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_size_bytes%3A%20130132%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_array_offset_bytes%3A%20256%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20crc32%3A%200xae2b3b78%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_smc_hdr%5Bamdgpu%5D%5D%20ucode_start_addr%3A%20131072%3CBR%20%2F%3Eamdgpu%3A%3CBR%20%2F%3E%E5%8F%91%E9%80%81%E4%BF%A1%E6%81%AF%E5%A4%B1%E8%B4%A5%20100%20ret%20is%200%3CBR%20%2F%3Eamdgpu%3A%20SMU%20%E5%9B%BA%E4%BB%B6%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%EF%BC%81%3CBR%20%2F%3Eamdgpu%3A%20%E5%8A%A0%E8%BD%BD%20SMU%20ucode%20%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3Eamdgpu%3A%20fw%20load%20failed%3CBR%20%2F%3Eamdgpu%3A%20smu%20firmware%20loading%20failed%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%3A%20amdgpu_device_ip_init%20%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%EF%BC%9AGPU%20%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%E5%87%BA%E7%8E%B0%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%EF%BC%9Aamdgpu%EF%BC%9A%E6%95%B4%E7%90%86%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20invalid%20me%202%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20invalid%20me%202%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20invalid%20me%202%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20invalid%20me%202%3CBR%20%2F%3Eamdgpu%3A%20probe%20of%200001%3A01%3A00.0%20failed%20with%20error%20-22%3CBR%20%2F%3EBUG%EF%BC%9A%E6%97%A0%E6%B3%95%E5%A4%84%E7%90%86%E8%AF%BB%E5%8F%96%200x8000080080954000%20%E5%A4%84%E7%9A%84%E5%86%85%E6%A0%B8%E6%95%B0%E6%8D%AE%E8%AE%BF%E9%97%AE%3CBR%20%2F%3E%E6%95%85%E9%9A%9C%E6%8C%87%E4%BB%A4%E5%9C%B0%E5%9D%80%EF%BC%9A0xc000000000011870%3CBR%20%2F%3E%E5%93%8E%E5%91%80%EF%BC%9AOops%3A%20Kernel%20access%20of%20bad%20area%2C%20sig%3A%2011%20%5B%231%5D%3CBR%20%2F%3EBE%20PAGE_SIZE%3D4K%20SMP%20NR_CPUS%3D24%20CoreNet%20Generic%3CBR%20%2F%3EModules%20linked%20in%3A%20amdgpu(%2B)%20backlight%20drm_ttm_helper%20ttm%20gpu_sched%20ucc_uart%20fsl_jr_uio%3CBR%20%2F%3ECPU%3A%202%20PID%3A%20816%20Comm%3A%20insmod%20Not%20tainted%205.15.71%2Bg95448dd0dc9b%20%231%3CBR%20%2F%3E**bleep**%3A%20c0000000011870%20LR%3A%208000000000e0d120%20CTR%3A%200000000000058400%3CBR%20%2F%3EREGS%3A%20c00000000a956d80%20TRAP%3A%200300%20Not%20tainted%20(5.15.71%2Bg95448dd0dc9b)%3CBR%20%2F%3EMSR%3A%200000000080029002%3CCE%3E%20CR%3A%2022002228%20XER%3A%2000000000%3CBR%20%2F%3EDEAR%3A%208000080080954000%20ESR%3A%20000000000000%20IRQMASK%3A%200%3CBR%20%2F%3EGPR00%3A%208000000000e0d100%20c00000000a957020%20c0000000013faa00%20c00000000c000000%3CBR%20%2F%3EGPR04%EF%BC%9A800000080080954000%2000000000002c2000%2000000000000b0800%20000000007ecc9000%3CBR%20%2F%3EGPR08%3A%200000000000058400%208000080080954000%20c00000000bfffffc%2080000000010b76d8%3CBR%20%2F%3EGPR12%EF%BC%9Ac0000000000117f4%20c00000003ffff140%20000000010b5456f0%20000000010b4fa188%3CBR%20%2F%3EGPR16%3A%20000000000000%20000000010b545810%20000000010b5202b0%20000000000000%3CBR%20%2F%3EGPR20%3A%20000000000000%20000000000000%20c00000000ae16a48%208000080080954000%3CBR%20%2F%3EGPR24%EF%BC%9A00000000002c2000%20000000000000%20c00000000ae00010%200000000000000001%3CBR%20%2F%3EGPR28%3A%20c00000000ae00000%20c00000000ae10000%20000000000000%20c00000000ae10000%3CBR%20%2F%3E**bleep**%20%5Bc000000000011870%5D%20._memcpy_fromio%2B0x7c%2F0x100%3CBR%20%2F%3ELR%20%5B8000000000e0d120%5D%20.amdgpu_uvd_suspend%2B0x1d4%2F0x268%5Bamdgpu%5D%3CBR%20%2F%3ECall%20Trace%3A%3CBR%20%2F%3E%5Bc00000000a957020%5D%20%5B8000000000e0d100%5D%20.amdgpu_uvd_suspend%2B0x1b4%2F0x268%5Bamdgpu%5D%20(unreliable)%3CBR%20%2F%3E%5Bc00000000a9570f0%5D%20%5B8000000000e1110c%5D%20.uvd_v6_0_sw_fini%2B0x1c%2F0xcc%5Bamdgpu%5D%3CBR%20%2F%3E%5Bc00000000a957180%5D%20%5B8000000000cf24b0%5D%20.amdgpu_device_fini_sw%2B0x124%2F0x378%5Bamdgpu%5D%3CBR%20%2F%3E%5Bc00000000a957240%5D%20%5B8000000000cf9e0c%5D%20.amdgpu_driver_release_kms%2B0x1c%2F0x40%5Bamdgpu%5D%3CBR%20%2F%3E%5Bc00000000a9572c0%5D%20%5Bc000000000704380%5D%20.devm_drm_dev_init_release%2B0x78%2F0xcc%3CBR%20%2F%3E%5Bc00000000a957340%5D%20%5Bc000000000755248%5D%20.devm_action_release%2B0x28%2F0x3c%3CBR%20%2F%3E%5Bc00000000a9573b0%5D%20%5Bc00000000075576c%5D%20.release_nodes%2B0x78%2F0x108%3CBR%20%2F%3E%5Bc00000000a957450%5D%20%5Bc000000000757174%5D%20.devres_release_all%2B0xa8%2F0x11c%3CBR%20%2F%3E%5Bc00000000a957510%5D%20%5Bc00000000074f788%5D%20.really_probe.part.0%2B0x1b8%2F0x440%3CBR%20%2F%3E%5Bc00000000a9575b0%5D%20%5Bc00000000074fad8%5D%20.__driver_probe_device%2B0xc8%2F0x198%3CBR%20%2F%3E%5Bc00000000a957640%5D%20%5Bc00000000074fbf8%5D%20.driver_probe_device%2B0x50%2F0x16c%3CBR%20%2F%3E%5Bc00000000a9576e0%5D%20%5Bc00000000075055c%5D%20.__driver_attach%2B0xb4%2F0x200%3CBR%20%2F%3E%5Bc00000000a957770%5D%20%5Bc00000000074c518%5D%20.bus_for_each_dev%2B0x9c%2F0x110%3CBR%20%2F%3E%5Bc00000000a957820%5D%20%5Bc00000000074eca4%5D%20.driver_attach%2B0x24%2F0x38%3CBR%20%2F%3E%5Bc00000000a957890%5D%20%5Bc00000000074e4ec%5D%20.bus_add_driver%2B0x1d4%2F0x2a8%3CBR%20%2F%3E%5Bc00000000a957940%5D%20%5Bc00000000075107c%5D%20.driver_register%2B0xa4%2F0x194%3CBR%20%2F%3E%5Bc00000000a9579c0%5D%20%5Bc0000000006217ec%5D%20.__pci_register_driver%2B0x58%2F0x6c%3CBR%20%2F%3E%5Bc00000000a957a30%5D%20%5B80000000010a9608%5D%20.amdgpu_init%2B0x74%2F0x94%5Bamdgpu%5D%3CBR%20%2F%3E%5Bc00000000a957ab0%5D%20%5Bc0000000000021cc%5D%20.do_one_initcall%2B0x6c%2F0x284%3CBR%20%2F%3E%5Bc00000000a957b90%5D%20%5Bc0000000001174a4%5D%20.do_init_module%2B0x5c%2F0x2bc%3CBR%20%2F%3E%5Bc00000000a957c30%5D%20%5Bc00000000011a980%5D%20.__do_sys_finit_module%2B0xc4%2F0x10c%3CBR%20%2F%3E%5Bc00000000a957d60%5D%20%5Bc000000000012454%5D%20.system_call_exception%2B0x11c%2F0x1c4%3CBR%20%2F%3E%5Bc00000000a957e10%5D%20%5Bc0000000000001f8%5D%20system_call_common%2B0xf0%2F0x210%3CBR%20%2F%3E---%20interrupt%3A%20c00%20at%200x3fffbe532ee4%3CBR%20%2F%3E**bleep**%EF%BC%9A00003fffbe532ee4%20LR%3A%2000000001366cdbfc%20CTR%3A%200000000000000000%3CBR%20%2F%3EREGS%3A%20c00000000a957e80%20TRAP%3A%200c00%20Not%20tainted%20(5.15.71%2Bg95448dd0dc9b)%3CBR%20%2F%3EMSR%3A%20000000008002d002%3CCE%3E%20CR%3A%2028002882%20XER%3A%2000000000%3CBR%20%2F%3EIRQMASK%3A%200%3CBR%20%2F%3EGPR00%3A%200000000000000161%2000003fffd14f61a0%2000003fffbe637200%200000000000000003%3CBR%20%2F%3EGPR04%3A%2000000001366d9148%20000000000000%20000000000000%20000000000000%20000000000000%3CBR%20%2F%3EGPR08%EF%BC%9A000000000000%20000000000000%20000000000000%20000000000000%3CBR%20%2F%3EGPR12%3A%20000000000000%2000003fffbe6cf810%20000000010b5456f0%20000000010b4fa188%3CBR%20%2F%3EGPR16%3A%20000000000000%20000000010b545810%20000000010b5202b0%20000000000000%3CBR%20%2F%3EGPR20%EF%BC%9A000000000000%20000000000000%200000000000000002%2000003fffd14f6ee5%3CBR%20%2F%3EGPR24%3A%2000003fffd14f6860%2000000001366fd9e8%20000000000000%2000000001366fcbd0%3CBR%20%2F%3EGPR28%3A%2000000001366d9148%20000000000000%20000000000000%200000000136701760%3CBR%20%2F%3E**bleep**%20%5B00003fffbe532ee4%5D%200x3fffbe532ee4%3CBR%20%2F%3ELR%20%5B00000001366cdbfc%5D%200x1366cdbfc%3CBR%20%2F%3E---%20%E4%B8%AD%E6%96%AD%EF%BC%9Ac00%3CBR%20%2F%3E%E6%8C%87%E4%BB%A4%E8%BD%AC%E5%82%A8%EF%BC%9A%3CBR%20%2F%3E4e800020%2028250003%2040810068%203905fffc%207908f082%2038c80001%2070c90001%203943fffc%3CBR%20%2F%3E7c892378%2040820070%2078c8f842%207d0903a6%26lt%3B80e90000%26gt%3B%20390a0004%2090ea0004%207c0006ac%3CBR%20%2F%3E----%5B%20%E7%BB%93%E6%9D%9F%E8%B7%9F%E8%B8%AA%20e1f14bc598aaf8c6%20%5D----%3C%2FCE%3E%3C%2FCE%3E%3C%2FVCE_V3_0%3E%3C%2FUVD_V6_0%3E%3C%2FDM%3E%3C%2FPOWERPLAY%3E%3C%2FSDMA_V3_0%3E%3C%2FGFX_V8_0%3E%3C%2FTONGA_IH%3E%3C%2FGMC_V8_0%3E%3C%2FVI_COMMON%3E%3C%2FP%3E%3CP%3E%E6%AE%B5%E7%A0%81%E9%94%99%E8%AF%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2365333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20send%20message%20100%20ret%20is%200%20while%20loading%20AMDGPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2365333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E7%BB%95%E8%BF%87%E4%BA%86%20AMDGPU%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E7%9A%84%20SMU%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%88gfx%20ring%20%E6%B5%8B%E8%AF%95%E5%A4%B1%E8%B4%A5%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Eroot%40t1042d4rdb%3A~%23%20insmod%20%2Famdgpu.ko%3CBR%20%2F%3E%5Bdrm%5D%20amdgpu%20%E5%86%85%E6%A0%B8%E6%A8%A1%E5%BC%8F%E8%AE%BE%E7%BD%AE%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%3CBR%20%2F%3E%5Bdrm%5D%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%86%85%E6%A0%B8%E6%A8%A1%E5%BC%8F%E8%AE%BE%E7%BD%AE%EF%BC%88POLARIS12%200x1002%3A0x6987%200x1787%3A0x2389%200x80%EF%BC%89%E3%80%82%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%EF%BC%9A%E4%B8%8D%E6%94%AF%E6%8C%81%E5%8F%AF%E4%BF%A1%E5%86%85%E5%AD%98%E5%8C%BA%EF%BC%88TMZ%EF%BC%89%E5%8A%9F%E8%83%BD%3CBR%20%2F%3E%5Bdrm%5D%20%E5%AF%84%E5%AD%98%E5%99%A8%20mmio%20base%EF%BC%9A0xA0000000%3CBR%20%2F%3E%5Bdrm%5D%20register%20mmio%20size%EF%BC%9A262144%3CBR%20%2F%3E%5Bdrm%5D%20%E4%B8%8D%E6%94%AF%E6%8C%81%20PCIE%20%E5%8E%9F%E5%AD%90%E6%93%8D%E4%BD%9C%3CBR%20%2F%3E%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20%E5%9D%97%E7%BC%96%E5%8F%B7%200%3CVI_COMMON%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20%E5%9D%97%E7%BC%96%E5%8F%B7%201%3CGMC_V8_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20%E5%9D%97%E7%BC%96%E5%8F%B7%202%3CTONGA_IH%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20%E5%9D%97%E7%BC%96%E5%8F%B7%203%3CGFX_V8_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20block%20number%204%3CSDMA_V3_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20block%20number%205%3CPOWERPLAY%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20block%20number%206%3CDM%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20block%20number%207%3CUVD_V6_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%B7%BB%E5%8A%A0%20IP%20block%20number%208%3CVCE_V3_0%3E%3CBR%20%2F%3E%20%5Bdrm%EF%BC%9A.check_atom_bios%5Bamdgpu%5D%5DATOMBIOS%20%E6%A3%80%E6%B5%8B%E5%88%B0%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%3A%20Fetched%20VBIOS%20from%20ROM%20BAR%3CBR%20%2F%3Eamdgpu%3A%20ATOM%20BIOS%3A%20113-ER16BFE-001%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_atombios_init%5Bamdgpu%5D%5D%20%E8%AF%B7%E6%B1%82%E5%8E%9F%E5%AD%90%E5%9B%BA%E4%BB%B6%2000000000%200kb%3CBR%20%2F%3E%5Bdrm%5D%20UVD%20%E5%9C%A8%E8%99%9A%E6%8B%9F%E6%9C%BA%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%5Bdrm%5D%20UVD%20ENC%20%E5%9C%A8%E8%99%9A%E6%8B%9F%E6%9C%BA%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%5Bdrm%5D%20VCE%20%E5%9C%A8%E8%99%9A%E6%8B%9F%E6%9C%BA%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%5Bdrm%5D%20GPU%20%E6%AD%A3%E5%9C%A8%E5%8F%91%E5%B8%83...%3CBR%20%2F%3E%5Bdrm%5D%20%E8%99%9A%E6%8B%9F%E6%9C%BA%E5%A4%A7%E5%B0%8F%E4%B8%BA%2064%20GB%EF%BC%8C2%20%E7%BA%A7%EF%BC%8C%E5%9D%97%E5%A4%A7%E5%B0%8F%E4%B8%BA%2010%20%E4%BD%8D%EF%BC%8C%E7%89%87%E6%AE%B5%E5%A4%A7%E5%B0%8F%E4%B8%BA%209%20%E4%BD%8D%3CBR%20%2F%3E%5Bdrm%3A.gmc_v8_0_sw_init%5Bamdgpu%5D%5D%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9ABAR%202%EF%BC%9A%E5%8F%91%E5%B8%83%20%5Bmem%200xd100000000-0xd101ffff%2064%20%E4%BD%8D%E9%A6%96%E9%80%89%E9%A1%B9%5D%20amdgpu%200001%3A01%3A00.0%EF%BC%9A%3CBR%20%2F%3EBAR%200%EF%BC%9A%E5%8F%91%E5%B8%83%20%5Bmem%200xd0000000000-0xd0ffffff%2064%20%E4%BD%8D%E9%A6%96%E9%80%89%E9%A1%B9%5D%20pcieport%200001%3A00%3A00%3A00.0%EF%BC%9A%3CBR%20%2F%3EBAR%209%EF%BC%9A%E5%8F%91%E5%B8%83%20%5Bmem%200xd0000000000-0xefffffff%2064%20%E4%BD%8D%E9%A6%96%E9%80%89%E9%A1%B9%5D%20pcieport%200001%3A00%3A00%3A00.0%EF%BC%9A%3CBR%20%2F%3EBAR%209%3A%20%E5%88%86%E9%85%8D%20%5Bmem%200xd00000000-0xe7fffffff%2064bit%20pref%5D%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9ABAR%200%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%20%5Bmem%200xd00000000-0xdffffffff%2064bit%20pref%5D%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9ABAR%202%EF%BC%9A%E5%B7%B2%E5%88%86%E9%85%8D%20%5Bmem%200xe00000000-0xe001fffff%2064bit%20pref%5D%3CBR%20%2F%3Epcieport%200001%3A00%3A00.0%EF%BC%9APCI%20%E6%A1%A5%E6%8E%A5%E5%88%B0%20%5B%E6%80%BB%E7%BA%BF%2001%5D%20%3CBR%20%2F%3E%20pcieport%200001%3A00%3A00.0%EF%BC%9Abridge%20window%20%5Bio%200x8000080000010000-0x800008000010ffff%5D%3CBR%20%2F%3Epcieport%200001%3A00%3A00.0%EF%BC%9Abridge%20window%20%5Bmem%200xa0000000-0xafffffff%5D%3CBR%20%2F%3Epcieport%200001%3A00%3A00.0%EF%BC%9Abridge%20window%20%5Bmem%200xd00000000-0xe7fffffff%2064bit%20pref%5D%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%3A%20VRAM%3A%204096M%200x000000F400000000%20-%200x000000F4FFFFFFFF%20(4096M%20%E5%B7%B2%E7%94%A8)%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%3A%20GART%3A%20256M%200x000000FF00000000%20-%200x000000FF0FFFFFFF%3CBR%20%2F%3E%5Bdrm%5D%20Detected%20VRAM%20RAM%3D4096M%2C%20BAR%3D4096M%3CBR%20%2F%3E%5Bdrm%5D%20RAM%20width%20128bits%20GDDR5%3CBR%20%2F%3E%5Bdrm%5D%20amdgpu%3A%204096M%20of%20VRAM%20memory%20ready%3CBR%20%2F%3E%5Bdrm%5D%20amdgpu%3A%201457M%20of%20GTT%20memory%20ready.%3CBR%20%2F%3E%5Bdrm%5D%20GART%EF%BC%9Acpu%20%E9%A1%B5%E6%95%B0%2065536%EF%BC%8Cgpu%20%E9%A1%B5%E6%95%B0%2065536%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_mc_hdr%5Bamdgpu%5D%5DMC%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20size_bytes%EF%BC%9A32608%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_size_bytes%EF%BC%9A40%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_version_major%3A%201%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_version_minor%3A%200%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ip_version_major%3A%208%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ip_version_minor%3A%201%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_version%3A%200x00b4dc50%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr32160%20%20%5Bdrm%3A.amdgpu_ucode_print_mon_hdrtes%EF%BC%9A32160%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_array_offset_bytes%EF%BC%9A448%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20crc32%3A%200x9b1e395c%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_mc_hdr%5Bamdgpu%5D%5D%20io_debug_size_bytes%3A%20192%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_mc_hdr%5Bamdgpu%5D%5D%20io_debug_array_offset_bytes%3A%20256%3CBR%20%2F%3E%5Bdrm%5D%20%E5%B7%B2%E5%90%AF%E7%94%A8%20256M%20%E7%9A%84%20PCIE%20GART%EF%BC%88%E8%A1%A8%E4%BD%8D%E4%BA%8E%200x000000F400000000%EF%BC%89%E3%80%82%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_irq_init%5Bamdgpu%3A%20irq%20%E5%B7%B2%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_sw_init%5Bamdgpu%5D%5D%3CBR%20%2F%3E%5Bdrm%5D%20%E9%93%BE%E5%BC%8F%20IB%20%E6%94%AF%E6%8C%81%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%81%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20gfx%20use%20gpu%20addr%200x000000ff00400040%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.0.0%20use%20gpu%20addr%200x000000ff004000e0%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5Dcomp_1.1.0%E7%8E%AF%E4%B8%8A%E7%9A%84%E6%A0%85%E6%A0%8F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fuse%20gpu%20addr%200x000000ff00400180%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.2.0%20use%20gpu%20addr%200x000000ff00400220%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.3.0%20use%20gpu%20addr%200x000000ff004002c0%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.0.1%20use%20gpu%20addr%200x000000ff00400360%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.1.1%20use%20gpu%20addr%200x000000ff00400400%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.2.1%20use%20gpu%20addr%200x000000ff004004a0%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20comp_1.3.1%20use%20gpu%20addr%200x000000ff00400540%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bkiq_2.1.0%20%E7%8E%AF%E4%B8%8A%E7%9A%84%E6%A0%85%E6%A0%8F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8Fuse%20gpu%20addr%200x000000ff004005e0%3CBR%20%2F%3E%5Bdrm%3A.sdma_v3_0_sw_init%5Bamdgpu%5D%5D%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20sdma0%20use%20gpu%20addr%200x000000ff00400680%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20ring%20sdma1%20%E4%B8%8A%E7%9A%84%E6%A0%85%E6%A0%8F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BD%BF%E7%94%A8%20gpu%20%E5%9C%B0%E5%9D%80%200x000000ff00400720%20amdgpu%EF%BC%9Ahwmgr_sw_init%20smu%20%E6%94%AF%E6%8C%81%E7%9A%84%E6%98%AF%20polaris10_smu%20%5Bdrm%5D%20%E6%89%BE%E5%88%B0%E4%BA%86%20%3CBR%20%2F%3E%20UVD%20%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9A1.130%20%E7%B3%BB%E5%88%97%20ID%EF%BC%9A16%20amdgpu%200001%3A01%3A00.0%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20uvd%20use%20gpu%20addr%200x000000f4001afa80%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20uvd_enc0%20use%20gpu%20addr%200x000000ff00400860%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E6%88%92%E6%8C%87%E4%B8%8A%E7%9A%84%E6%A0%85%E6%A0%8F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20uvd_enc1%20%E4%BD%BF%E7%94%A8%20gpu%20%E5%9C%B0%E5%9D%80%200x000000ff00400900%20%3CBR%20%2F%3E%20%5Bdrm%5D%20%E6%89%BE%E5%88%B0%E4%BA%86%20VCE%20%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9A53.26%20%E4%BA%8C%E8%BF%9B%E5%88%B6%20ID%EF%BC%9A3%20amdgpu%200001%3A01%3A00.0%EF%BC%9A%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20vce0%20use%20gpu%20addr%200x000000ff004009a0%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20f%20fence%20driver%20on%20ring%20vce1%20use%20gpu%20addr%200x000000ff00400a40%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E7%8E%AF%20vce2%20%E4%B8%8A%E7%9A%84%E6%A0%85%E6%A0%8F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BD%BF%E7%94%A8%20gpu%20%E5%9C%B0%E5%9D%80%200x000000ff00400ae0%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ih_process%5Bamdgpu%5D%5D%20amdgpu_ih_process%3A%20rptr%200%2C%20wptr%2016%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_irq_dispatch%5Bamdgpu%5D%5D%E6%9C%AA%E5%A4%84%E7%90%86%E4%B8%AD%E6%96%AD%20src_id%EF%BC%9A141%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9A%5Bdrm%3A.amdgpu_ring_test_helper%5Bamdgpu%5D%5D*ERROR*%20ring%20gfx%20%E6%B5%8B%E8%AF%95%E5%A4%B1%E8%B4%A5%20(-110)%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_device_init%5Bamdgpu%5D%5D*ERROR*%20hw_init%20of%20IP%20block%3CGFX_V8_0%3E%20failed%20-110%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%3A%20amdgpu_device_ip_init%20%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%EF%BC%9AGPU%20%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%E5%87%BA%E7%8E%B0%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%EF%BC%9Aamdgpu%EF%BC%9Aamdgpu%EF%BC%9A%E6%95%B4%E7%90%86%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20invalid%20me%202%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20invalid%20me%202%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20invalid%20me%202%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20invalid%20me%202%3CBR%20%2F%3Eamdgpu%3A%20probe%20of%200001%3A01%3A00.0%20failed%20with%20error%20-110%3CBR%20%2F%3EBUG%EF%BC%9A%E6%97%A0%E6%B3%95%E5%A4%84%E7%90%86%E8%AF%BB%E5%8F%96%200x8000080080954000%20%E5%A4%84%E7%9A%84%E5%86%85%E6%A0%B8%E6%95%B0%E6%8D%AE%E8%AE%BF%E9%97%AE%3CBR%20%2F%3E%E6%95%85%E9%9A%9C%E6%8C%87%E4%BB%A4%E5%9C%B0%E5%9D%80%EF%BC%9A0xc000000000011870%3CBR%20%2F%3E%E5%93%8E%E5%91%80%EF%BC%9AOops%3A%20Kernel%20access%20of%20bad%20area%2C%20sig%3A%2011%20%5B%231%5D%3CBR%20%2F%3EBE%20PAGE_SIZE%3D4K%20SMP%20NR_CPUS%3D24%20CoreNet%20Generic%3CBR%20%2F%3EModules%20linked%20in%3A%20amdgpu(%2B)%20backlight%20drm_ttm_helper%20ttm%20gpu_sched%20ucc_uart%20fsl_jr_uio%3CBR%20%2F%3ECPU%3A%202%20PID%3A%20819%20Comm%3A%20insmod%20Not%20tainted%205.15.71%2Bg95448dd0dc9b%20%231%3CBR%20%2F%3E**bleep**%3A%20c0000000011870%20LR%3A%208000000000e0efe0%20CTR%3A%200000000000058400%3CBR%20%2F%3EREGS%3A%20c00000000a5aad80%20TRAP%3A%200300%20Not%20tainted%20(5.15.71%2Bg95448dd0dc9b)%3CBR%20%2F%3EMSR%3A%200000000080029002%3CCE%3E%20CR%3A%2022002228%20XER%3A%2000000000%3CBR%20%2F%3EDEAR%3A%208000080080954000%20ESR%3A%20000000000000%20IRQMASK%3A%200%3CBR%20%2F%3EGPR00%3A%208000000000e0efc0%20c00000000a5ab020%20c0000000013e8c00%20c00000000c000000%3CBR%20%2F%3EGPR04%EF%BC%9A8000080080954000%2000000000002c2000%2000000000000b0800%20000000007ecd9000%3CBR%20%2F%3EGPR08%3A%200000000000058400%208000080080954000%20c00000000bfffffc%2080000000010b8988%3CBR%20%2F%3EGPR12%EF%BC%9Ac0000000000117f4%20c00000003ffff140%2000000001050e5850%20000000010509a188%3CBR%20%2F%3EGPR16%3A%20000000000000%2000000001050e5990%2000000001050bfb80%20000000000000%3CBR%20%2F%3EGPR20%3A%20000000000000%20000000000000%20c00000000a916a48%208000080080954000%3CBR%20%2F%3EGPR24%EF%BC%9A00000000002c2000%20000000000000%20c00000000a900010%20000000000001%3CBR%20%2F%3EGPR28%3A%20c00000000a900000%20c00000000a910000%20000000000000%20c00000000a910000%3CBR%20%2F%3E**bleep**%20%5Bc000000000011870%5D%20._memcpy_fromio%2B0x7c%2F0x100%3CBR%20%2F%3ELR%20%5B8000000000e0efe0%5D%20.amdgpu_uvd_suspend%2B0x1d4%2F0x268%5Bamdgpu%5D%3CBR%20%2F%3ECall%20Trace%3A%3CBR%20%2F%3E%5Bc00000000a5ab020%5D%20%5B8000000000e0efc0%5D%20.amdgpu_uvd_suspend%2B0x1b4%2F0x268%5Bamdgpu%5D%20(unreliable)%3CBR%20%2F%3E%5Bc00000000a5ab0f0%5D%20%5B8000000000e12fcc%5D%20.uvd_v6_0_sw_fini%2B0x1c%2F0xcc%5Bamdgpu%5D%3CBR%20%2F%3E%5Bc00000000a5ab180%5D%20%5B8000000000cf44b0%5D%20.amdgpu_device_fini_sw%2B0x124%2F0x378%5Bamdgpu%5D%3CBR%20%2F%3E%5Bc00000000a5ab240%5D%20%5B8000000000cfbe0c%5D%20.amdgpu_driver_release_kms%2B0x1c%2F0x40%5Bamdgpu%5D%3CBR%20%2F%3E%5Bc00000000a5ab2c0%5D%20%5Bc0000000006fa1e4%5D%20.devm_drm_dev_init_release%2B0x78%2F0xcc%3CBR%20%2F%3E%5Bc00000000a5ab340%5D%20%5Bc00000000074b0ac%5D%20.devm_action_release%2B0x28%2F0x3c%3CBR%20%2F%3E%5Bc00000000a5ab3b0%5D%20%5Bc00000000074b5d0%5D%20.release_nodes%2B0x78%2F0x108%3CBR%20%2F%3E%5Bc00000000a5ab450%5D%20%5Bc00000000074cfd8%5D%20.devres_release_all%2B0xa8%2F0x11c%3CBR%20%2F%3E%5Bc00000000a5ab510%5D%20%5Bc0000000007455ec%5D%20.really_probe.part.0%2B0x1b8%2F0x440%3CBR%20%2F%3E%5Bc00000000a5ab5b0%5D%20%5Bc00000000074593c%5D%20.__driver_probe_device%2B0xc8%2F0x198%3CBR%20%2F%3E%5Bc00000000a5ab640%5D%20%5Bc000000000745a5c%5D%20.driver_probe_device%2B0x50%2F0x16c%3CBR%20%2F%3E%5Bc00000000a5ab6e0%5D%20%5Bc0000000007463c0%5D%20.__driver_attach%2B0xb4%2F0x200%3CBR%20%2F%3E%5Bc00000000a5ab770%5D%20%5Bc00000000074237c%5D%20.bus_for_each_dev%2B0x9c%2F0x110%3CBR%20%2F%3E%5Bc00000000a5ab820%5D%20%5Bc000000000744b08%5D%20.driver_attach%2B0x24%2F0x38%3CBR%20%2F%3E%5Bc00000000a5ab890%5D%20%5Bc000000000744350%5D%20.bus_add_driver%2B0x1d4%2F0x2a8%3CBR%20%2F%3E%5Bc00000000a5ab940%5D%20%5Bc000000000746ee0%5D%20.driver_register%2B0xa4%2F0x194%3CBR%20%2F%3E%5Bc00000000a5ab9c0%5D%20%5Bc0000000006211dc%5D%20.__pci_register_driver%2B0x58%2F0x6c%3CBR%20%2F%3E%5Bc00000000a5aba30%5D%20%5B80000000010aa8e8%5D%20.amdgpu_init%2B0x74%2F0x94%5Bamdgpu%5D%3CBR%20%2F%3E%5Bc00000000a5abab0%5D%20%5Bc0000000000021cc%5D%20.do_one_initcall%2B0x6c%2F0x284%3CBR%20%2F%3E%5Bc00000000a5abb90%5D%20%5Bc000000000116ea0%5D%20.do_init_module%2B0x5c%2F0x2bc%3CBR%20%2F%3E%5Bc00000000a5abc30%5D%20%5Bc00000000011a37c%5D%20.__do_sys_finit_module%2B0xc4%2F0x10c%3CBR%20%2F%3E%5Bc00000000a5abd60%5D%20%5Bc000000000012454%5D%20.system_call_exception%2B0x11c%2F0x1c4%3CBR%20%2F%3E%5Bc00000000a5abe10%5D%20%5Bc0000000000001f8%5D%20system_call_common%2B0xf0%2F0x210%3CBR%20%2F%3E---%20interrupt%3A%20c00%20at%200x3fff82934ee4%3CBR%20%2F%3E**bleep**%EF%BC%9A00003fff82934ee4%20LR%3A%2000000001194adbfc%20CTR%3A%20000000000000%3CBR%20%2F%3EREGS%3A%20c00000000a5abe80%20TRAP%3A%200c00%20Not%20tainted%20(5.15.71%2Bg95448dd0dc9b)%3CBR%20%2F%3EMSR%3A%20000000008002d002%3CCE%3E%20CR%3A%2028002882%20XER%3A%2000000000%3CBR%20%2F%3EIRQMASK%3A%200%3CBR%20%2F%3EGPR00%3A%200000000000000161%2000003fffefee52c0%2000003fff82a39200%200000000000000003%3CBR%20%2F%3EGPR04%3A%2000000001194b9148%20000000000000%20000000000000%20000000000000%20000000000000%3CBR%20%2F%3EGPR08%EF%BC%9A000000000000%20000000000000%20000000000000%20000000000000%3CBR%20%2F%3EGPR12%3A%20000000000000%2000003fff82ad1810%2000000001050e5850%20000000010509a188%3CBR%20%2F%3EGPR16%3A%20000000000000%2000000001050e5990%2000000001050bfb80%20000000000000%3CBR%20%2F%3EGPR20%EF%BC%9A000000000000%20000000000000%200000000000000002%2000003fffefee5ee5%3CBR%20%2F%3EGPR24%3A%2000003fffefee5980%2000000001194dd9e8%20000000000000%2000000001194dcbd0%3CBR%20%2F%3EGPR28%3A%2000000001194b9148%20000000000000%20000000000000%2000000001194e1760%3CBR%20%2F%3E**bleep**%20%5B00003fff82934ee4%5D%200x3fff82934ee4%3CBR%20%2F%3ELR%20%5B00000001194adbfc%5D%200x1194adbfc%3CBR%20%2F%3E---%20%E4%B8%AD%E6%96%AD%EF%BC%9Ac00%3CBR%20%2F%3E%E6%8C%87%E4%BB%A4%E8%BD%AC%E5%82%A8%EF%BC%9A%3CBR%20%2F%3E4e800020%2028250003%2040810068%203905fffc%207908f082%2038c80001%2070c90001%203943fffc%3CBR%20%2F%3E7c892378%2040820070%2078c8f842%207d0903a6%26lt%3B80e90000%26gt%3B%20390a0004%2090ea0004%207c0006ac%3CBR%20%2F%3E----%5B%20%E7%BB%93%E6%9D%9F%E8%B7%9F%E8%B8%AA%20fef1e0dc2e9ff52c%20%5D----%3C%2FCE%3E%3C%2FCE%3E%3C%2FGFX_V8_0%3E%3C%2FVCE_V3_0%3E%3C%2FUVD_V6_0%3E%3C%2FDM%3E%3C%2FPOWERPLAY%3E%3C%2FSDMA_V3_0%3E%3C%2FGFX_V8_0%3E%3C%2FTONGA_IH%3E%3C%2FGMC_V8_0%3E%3C%2FVI_COMMON%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2365223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20send%20message%20100%20ret%20is%200%20while%20loading%20AMDGPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2365223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E4%BB%A5%E4%B8%8B%E5%B9%B3%E5%8F%B0%E6%98%AF%E5%90%A6%E7%9B%B8%E4%BA%92%E5%85%BC%E5%AE%B9%EF%BC%9A%3CBR%20%2F%3E%20-%26gt%3B%20NXP%20T1040%EF%BC%88%E9%85%8D%E5%A4%87%20AMD%20E9171%20GPU%EF%BC%89%3CBR%20%2F%3E%20-%26gt%3B%20NXP%20T2080%EF%BC%88%E9%85%8D%E5%A4%87%20AMD%20E9171%20GPU%EF%BC%89%3CBR%20%2F%3E%20-%26gt%3B%20NXP%20T2080%EF%BC%88%E9%85%8D%E5%A4%87%20AMD%20E8860%20GPU%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2365014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20send%20message%20100%20ret%20is%200%20while%20loading%20AMDGPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2365014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E7%9A%84%E6%97%A5%E5%BF%97%E6%98%BE%E7%A4%BA%20AMDGPU%20%E5%9C%A8%20Polaris12%20SMU%20%E5%9B%BA%E4%BB%B6%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%E5%A4%B1%E6%95%88%EF%BC%8C%E8%80%8C%20PCIe%20%E4%BC%BC%E4%B9%8E%E8%83%BD%E6%AD%A3%E7%A1%AE%E6%9E%9A%E4%B8%BE%EF%BC%8C%E8%B6%B3%E4%BB%A5%E8%BE%BE%E5%88%B0%20GPU%20%E5%90%AF%E5%8A%A8%E7%9A%84%E5%90%8E%E6%9C%9F%E9%98%B6%E6%AE%B5%EF%BC%8C%E5%9B%A0%E6%AD%A4%E9%97%AE%E9%A2%98%E6%9B%B4%E5%8F%AF%E8%83%BD%E6%98%AF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2F%E5%B9%B3%E5%8F%B0%E5%85%BC%E5%AE%B9%E6%80%A7%E6%88%96%E6%8E%A2%E9%92%88%E6%B8%85%E7%90%86%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%80%8C%E9%9D%9E%E5%9F%BA%E6%9C%AC%E7%9A%84%20T1040%20PCIe%20%E9%93%BE%E6%8E%A5%E8%AE%AD%E7%BB%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E
