failed to send message 100 ret is 0 while loading AMDGPU
931件の閲覧回数
Ganesh3955
While loading AMDGPU driver in T1040 board , i  getting following error, what could be the issue here
root@t1042d4rdb:~# insmod /amdgpu.ko
[drm] amdgpu kernel modesetting enabled.
amdgpu 0001:01:00.0: enabling device (0006 -> 0007)
[drm] initializing kernel modesetting (POLARIS12 0x1002:0x6987 0x1787:0x2389 0x80).
amdgpu 0001:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[drm] register mmio base: 0xA0000000
[drm] register mmio size: 262144
[drm] PCIE atomic ops is not supported
[drm] add ip block number 0 <vi_common>
[drm] add ip block number 1 <gmc_v8_0>
[drm] add ip block number 2 <tonga_ih>
[drm] add ip block number 3 <gfx_v8_0>
[drm] add ip block number 4 <sdma_v3_0>
[drm] add ip block number 5 <powerplay>
[drm] add ip block number 6 <dm>
[drm] add ip block number 7 <uvd_v6_0>
[drm] add ip block number 8 <vce_v3_0>
[drm:.check_atom_bios [amdgpu]] ATOMBIOS detected
amdgpu 0001:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
amdgpu: ATOM BIOS: 113-ER16BFE-001
[drm:.amdgpu_atombios_init [amdgpu]] atom firmware requested 00000000 0kb
[drm] UVD is enabled in VM mode
[drm] UVD ENC is enabled in VM mode
[drm] VCE enabled in VM mode
[drm] GPU posting now...
[drm] vm size is 64 GB, 2 levels, block size is 10-bit, fragment size is 9-bit
[drm:.gmc_v8_0_sw_init [amdgpu]]
amdgpu 0001:01:00.0: BAR 2: releasing [mem 0xd10000000-0xd101fffff 64bit pref]
amdgpu 0001:01:00.0: BAR 0: releasing [mem 0xd00000000-0xd0fffffff 64bit pref]
pcieport 0001:00:00.0: BAR 9: releasing [mem 0xd00000000-0xeffffffff 64bit pref]
pcieport 0001:00:00.0: BAR 9: assigned [mem 0xd00000000-0xe7fffffff 64bit pref]
amdgpu 0001:01:00.0: BAR 0: assigned [mem 0xd00000000-0xdffffffff 64bit pref]
amdgpu 0001:01:00.0: BAR 2: assigned [mem 0xe00000000-0xe001fffff 64bit pref]
pcieport 0001:00:00.0: PCI bridge to [bus 01]
pcieport 0001:00:00.0: bridge window [io 0x8000080000010000-0x800008000001ffff]
pcieport 0001:00:00.0: bridge window [mem 0xa0000000-0xafffffff]
pcieport 0001:00:00.0: bridge window [mem 0xd00000000-0xe7fffffff 64bit pref]
amdgpu 0001:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
amdgpu 0001:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
[drm] Detected VRAM RAM=4096M, BAR=4096M
[drm] RAM width 128bits GDDR5
[drm] amdgpu: 4096M of VRAM memory ready
[drm] amdgpu: 1457M of GTT memory ready.
[drm] GART: num cpu pages 65536, num gpu pages 65536
[drm:.amdgpu_ucode_print_mc_hdr [amdgpu]] MC
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] size_bytes: 32608
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] header_size_bytes: 40
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] header_version_major: 1
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] header_version_minor: 0
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ip_version_major: 8
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ip_version_minor: 1
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ucode_version: 0x00b4dc50
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ucode_size_bytes: 32160
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ucode_array_offset_bytes: 448
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] crc32: 0x9b1e395c
[drm:.amdgpu_ucode_print_mc_hdr [amdgpu]] io_debug_size_bytes: 192
[drm:.amdgpu_ucode_print_mc_hdr [amdgpu]] io_debug_array_offset_bytes: 256
[drm] PCIE GART of 256M enabled (table at 0x000000F400000000).
[drm:.amdgpu_irq_init [amdgpu]] amdgpu: irq initialized.
[drm:.gfx_v8_0_sw_init [amdgpu]]
[drm] Chained IB support enabled!
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring gfx use gpu addr 0x000000ff00400040
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.0.0 use gpu addr 0x000000ff004000e0
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.1.0 use gpu addr 0x000000ff00400180
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.2.0 use gpu addr 0x000000ff00400220
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.3.0 use gpu addr 0x000000ff004002c0
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.0.1 use gpu addr 0x000000ff00400360
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.1.1 use gpu addr 0x000000ff00400400
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.2.1 use gpu addr 0x000000ff004004a0
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring comp_1.3.1 use gpu addr 0x000000ff00400540
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring kiq_2.1.0 use gpu addr 0x000000ff004005e0
[drm:.sdma_v3_0_sw_init [amdgpu]]
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring sdma0 use gpu addr 0x000000ff00400680
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring sdma1 use gpu addr 0x000000ff00400720
amdgpu: hwmgr_sw_init smu backed is polaris10_smu
[drm] Found UVD firmware Version: 1.130 Family ID: 16
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring uvd use gpu addr 0x000000f4001afa80
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring uvd_enc0 use gpu addr 0x000000ff00400860
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring uvd_enc1 use gpu addr 0x000000ff00400900
[drm] Found VCE firmware Version: 53.26 Binary ID: 3
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring vce0 use gpu addr 0x000000ff004009a0
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring vce1 use gpu addr 0x000000ff00400a40
amdgpu 0001:01:00.0: [drm:.amdgpu_fence_driver_start_ring [amdgpu]] fence driver on ring vce2 use gpu addr 0x000000ff00400ae0
[drm:.amdgpu_ucode_print_smc_hdr [amdgpu]] SMC
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] size_bytes: 130388
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] header_size_bytes: 36
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ip_version_major: 7
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ip_version_minor: 2
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ucode_version: 0x00221700
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ucode_size_bytes: 130132
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] ucode_array_offset_bytes: 256
[drm:.amdgpu_ucode_print_common_hdr [amdgpu]] crc32: 0xae2b3b78
[drm:.amdgpu_ucode_print_smc_hdr [amdgpu]] ucode_start_addr: 131072
amdgpu:
amdgpu: SMU Firmware start failed!
amdgpu: Failed to load SMU ucode.
amdgpu: fw load failed
amdgpu: smu firmware loading failed
amdgpu 0001:01:00.0: amdgpu: amdgpu_device_ip_init failed
amdgpu 0001:01:00.0: amdgpu: Fatal error during GPU init
amdgpu 0001:01:00.0: amdgpu: amdgpu: finishing device.
[drm:.gfx_v8_0_set_eop_interrupt_state [amdgpu]] invalid me 2
amdgpu: probe of 0001:01:00.0 failed with error -22
BUG: Unable to handle kernel data access on read at 0x8000080080954000
Faulting instruction address: 0xc000000000011870
Oops: Kernel access of bad area, sig: 11 [#1]
BE PAGE_SIZE=4K SMP NR_CPUS=24 CoreNet Generic
Modules linked in: amdgpu(+) backlight drm_ttm_helper ttm gpu_sched ucc_uart fsl_jr_uio
CPU: 2 PID: 816 Comm: insmod Not tainted 5.15.71+g95448dd0dc9b #1
**bleep**: c000000000011870 LR: 8000000000e0d120 CTR: 0000000000058400
REGS: c00000000a956d80 TRAP: 0300 Not tainted (5.15.71+g95448dd0dc9b)
MSR: 0000000080029002 <CE,EE,ME> CR: 22002228 XER: 00000000
DEAR: 8000080080954000 ESR: 0000000000000000 IRQMASK: 0
GPR00: 8000000000e0d100 c00000000a957020 c0000000013faa00 c00000000c000000
GPR04: 8000080080954000 00000000002c2000 00000000000b0800 000000007ecc9000
GPR08: 0000000000058400 8000080080954000 c00000000bfffffc 80000000010b76d8
GPR12: c0000000000117f4 c00000003ffff140 000000010b5456f0 000000010b4fa188
GPR16: 0000000000000000 000000010b545810 000000010b5202b0 0000000000000000
GPR20: 0000000000000000 0000000000000000 c00000000ae16a48 8000080080954000
GPR24: 00000000002c2000 0000000000000000 c00000000ae00010 0000000000000001
GPR28: c00000000ae00000 c00000000ae10000 0000000000000000 c00000000ae10000
**bleep** [c000000000011870] ._memcpy_fromio+0x7c/0x100
LR [8000000000e0d120] .amdgpu_uvd_suspend+0x1d4/0x268 [amdgpu]
Call Trace:
[c00000000a957020] [8000000000e0d100] .amdgpu_uvd_suspend+0x1b4/0x268 [amdgpu] (unreliable)
[c00000000a9570f0] [8000000000e1110c] .uvd_v6_0_sw_fini+0x1c/0xcc [amdgpu]
[c00000000a957180] [8000000000cf24b0] .amdgpu_device_fini_sw+0x124/0x378 [amdgpu]
[c00000000a957240] [8000000000cf9e0c] .amdgpu_driver_release_kms+0x1c/0x40 [amdgpu]
[c00000000a9572c0] [c000000000704380] .devm_drm_dev_init_release+0x78/0xcc
[c00000000a957340] [c000000000755248] .devm_action_release+0x28/0x3c
[c00000000a9573b0] [c00000000075576c] .release_nodes+0x78/0x108
[c00000000a957450] [c000000000757174] .devres_release_all+0xa8/0x11c
[c00000000a957510] [c00000000074f788] .really_probe.part.0+0x1b8/0x440
[c00000000a9575b0] [c00000000074fad8] .__driver_probe_device+0xc8/0x198
[c00000000a957640] [c00000000074fbf8] .driver_probe_device+0x50/0x16c
[c00000000a9576e0] [c00000000075055c] .__driver_attach+0xb4/0x200
[c00000000a957770] [c00000000074c518] .bus_for_each_dev+0x9c/0x110
[c00000000a957820] [c00000000074eca4] .driver_attach+0x24/0x38
[c00000000a957890] [c00000000074e4ec] .bus_add_driver+0x1d4/0x2a8
[c00000000a957940] [c00000000075107c] .driver_register+0xa4/0x194
[c00000000a9579c0] [c0000000006217ec] .__pci_register_driver+0x58/0x6c
[c00000000a957a30] [80000000010a9608] .amdgpu_init+0x74/0x94 [amdgpu]
[c00000000a957ab0] [c0000000000021cc] .do_one_initcall+0x6c/0x284
[c00000000a957b90] [c0000000001174a4] .do_init_module+0x5c/0x2bc
[c00000000a957c30] [c00000000011a980] .__do_sys_finit_module+0xc4/0x10c
[c00000000a957d60] [c000000000012454] .system_call_exception+0x11c/0x1c4
[c00000000a957e10] [c0000000000001f8] system_call_common+0xf0/0x210
--- interrupt: c00 at 0x3fffbe532ee4
**bleep**: 00003fffbe532ee4 LR: 00000001366cdbfc CTR: 0000000000000000
REGS: c00000000a957e80 TRAP: 0c00 Not tainted (5.15.71+g95448dd0dc9b)
MSR: 000000008002d002 <CE,EE,PR,ME> CR: 28002882 XER: 00000000
IRQMASK: 0
GPR00: 0000000000000161 00003fffd14f61a0 00003fffbe637200 0000000000000003
GPR04: 00000001366d9148 0000000000000000 0000000000000000 0000000000000000
GPR08: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
GPR12: 0000000000000000 00003fffbe6cf810 000000010b5456f0 000000010b4fa188
GPR20: 0000000000000000 0000000000000000 0000000000000002 00003fffd14f6ee5
GPR24: 00003fffd14f6860 00000001366fd9e8 0000000000000000 00000001366fcbd0
GPR28: 00000001366d9148 0000000000000000 0000000000000000 0000000136701760
**bleep** [00003fffbe532ee4] 0x3fffbe532ee4
LR [00000001366cdbfc] 0x1366cdbfc
--- interrupt: c00
Instruction dump:
4e800020 28250003 40810068 3905fffc 7908f082 38c80001 70c90001 3943fffc
7c892378 40820070 78c8f842 7d0903a6 <80e90000> 390a0004 90ea0004 7c0006ac
---[ end trace e1f14bc598aaf8c6 ]---
Segmentation fault
タグ(1)
3 返答(返信)
923件の閲覧回数
Bio_TICFSL
Your log indicates AMDGPU fails during Polaris12 SMU firmware startup, while PCIe appears to enumerate correctly enough to reach late GPU init, so the issue is more likely driver/platform compatibility or probe-cleanup failure than basic T1040 PCIe link training.
872件の閲覧回数
Ganesh3955
Hi @Bio_TICFSL
I Bypassed SMU in AMDGPU driver , now i am facing below error(gfx ring test failure)
pcieport 0001:00:00.0: bridge window [io 0x8000080000010000-0x800008000010ffff]
[drm:.amdgpu_ih_process [amdgpu]] amdgpu_ih_process: rptr 0, wptr 16
[drm:.amdgpu_irq_dispatch [amdgpu]] Unhandled interrupt src_id: 141
amdgpu 0001:01:00.0: [drm:.amdgpu_ring_test_helper [amdgpu]] *ERROR* ring gfx test failed (-110)
[drm:.amdgpu_device_init [amdgpu]] *ERROR* hw_init of IP block <gfx_v8_0> failed -110
amdgpu: probe of 0001:01:00.0 failed with error -110
CPU: 2 PID: 819 Comm: insmod Not tainted 5.15.71+g95448dd0dc9b #1
**bleep**: c000000000011870 LR: 8000000000e0efe0 CTR: 0000000000058400
REGS: c00000000a5aad80 TRAP: 0300 Not tainted (5.15.71+g95448dd0dc9b)
GPR00: 8000000000e0efc0 c00000000a5ab020 c0000000013e8c00 c00000000c000000
GPR04: 8000080080954000 00000000002c2000 00000000000b0800 000000007ecd9000
GPR08: 0000000000058400 8000080080954000 c00000000bfffffc 80000000010b8988
GPR12: c0000000000117f4 c00000003ffff140 00000001050e5850 000000010509a188
GPR16: 0000000000000000 00000001050e5990 00000001050bfb80 0000000000000000
GPR20: 0000000000000000 0000000000000000 c00000000a916a48 8000080080954000
GPR24: 00000000002c2000 0000000000000000 c00000000a900010 0000000000000001
GPR28: c00000000a900000 c00000000a910000 0000000000000000 c00000000a910000
LR [8000000000e0efe0] .amdgpu_uvd_suspend+0x1d4/0x268 [amdgpu]
Call Trace:
[c00000000a5ab020] [8000000000e0efc0] .amdgpu_uvd_suspend+0x1b4/0x268 [amdgpu] (unreliable)
[c00000000a5ab0f0] [8000000000e12fcc] .uvd_v6_0_sw_fini+0x1c/0xcc [amdgpu]
[c00000000a5ab180] [8000000000cf44b0] .amdgpu_device_fini_sw+0x124/0x378 [amdgpu]
[c00000000a5ab240] [8000000000cfbe0c] .amdgpu_driver_release_kms+0x1c/0x40 [amdgpu]
[c00000000a5ab2c0] [c0000000006fa1e4] .devm_drm_dev_init_release+0x78/0xcc
[c00000000a5ab340] [c00000000074b0ac] .devm_action_release+0x28/0x3c
[c00000000a5ab3b0] [c00000000074b5d0] .release_nodes+0x78/0x108
[c00000000a5ab450] [c00000000074cfd8] .devres_release_all+0xa8/0x11c
[c00000000a5ab510] [c0000000007455ec] .really_probe.part.0+0x1b8/0x440
[c00000000a5ab5b0] [c00000000074593c] .__driver_probe_device+0xc8/0x198
[c00000000a5ab640] [c000000000745a5c] .driver_probe_device+0x50/0x16c
[c00000000a5ab6e0] [c0000000007463c0] .__driver_attach+0xb4/0x200
[c00000000a5ab770] [c00000000074237c] .bus_for_each_dev+0x9c/0x110
[c00000000a5ab820] [c000000000744b08] .driver_attach+0x24/0x38
[c00000000a5ab890] [c000000000744350] .bus_add_driver+0x1d4/0x2a8
[c00000000a5ab940] [c000000000746ee0] .driver_register+0xa4/0x194
[c00000000a5ab9c0] [c0000000006211dc] .__pci_register_driver+0x58/0x6c
[c00000000a5aba30] [80000000010aa8e8] .amdgpu_init+0x74/0x94 [amdgpu]
[c00000000a5abab0] [c0000000000021cc] .do_one_initcall+0x6c/0x284
[c00000000a5abb90] [c000000000116ea0] .do_init_module+0x5c/0x2bc
[c00000000a5abc30] [c00000000011a37c] .__do_sys_finit_module+0xc4/0x10c
[c00000000a5abd60] [c000000000012454] .system_call_exception+0x11c/0x1c4
[c00000000a5abe10] [c0000000000001f8] system_call_common+0xf0/0x210
--- interrupt: c00 at 0x3fff82934ee4
**bleep**: 00003fff82934ee4 LR: 00000001194adbfc CTR: 0000000000000000
REGS: c00000000a5abe80 TRAP: 0c00 Not tainted (5.15.71+g95448dd0dc9b)
IRQMASK: 0
GPR00: 0000000000000161 00003fffefee52c0 00003fff82a39200 0000000000000003
GPR04: 00000001194b9148 0000000000000000 0000000000000000 0000000000000000
GPR12: 0000000000000000 00003fff82ad1810 00000001050e5850 000000010509a188
GPR20: 0000000000000000 0000000000000000 0000000000000002 00003fffefee5ee5
GPR24: 00003fffefee5980 00000001194dd9e8 0000000000000000 00000001194dcbd0
GPR28: 00000001194b9148 0000000000000000 0000000000000000 00000001194e1760
**bleep** [00003fff82934ee4] 0x3fff82934ee4
LR [00000001194adbfc] 0x1194adbfc
--- interrupt: c00
Instruction dump:
---[ end trace fef1e0dc2e9ff52c ]---
タグ(1)
891件の閲覧回数
Ganesh3955
Hi @Bio_TICFSL
Thank you for you reply,
May i know whether the following platforms are compatible with each other:
     - > NXP T1040 with AMD E9171 GPU
     - > NXP T2080 with AMD E9171 GPU
     - > NXP T2080 with AMD E8860 GPU
タグ(1)
%3CLINGO-SUB%20id%3D%22lingo-sub-2364970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAMDGPU%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%E3%81%AB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8100%E3%81%AE%E9%80%81%E4%BF%A1%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82ret%E3%81%AF0%E3%81%A7%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2364970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CBR%20%2F%3E%3CBR%20%2F%3ET1040%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABAMDGPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Eroot%40t1042d4rdb%3A~%23%20insmod%20%2Famdgpu.ko%3CBR%20%2F%3E%5Bdrm%5D%20amdgpu%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%99%E3%82%8B%EF%BC%880006%20%E2%86%92%200007%EF%BC%89%3CBR%20%2F%3E%20%5Bdrm%5D%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(POLARIS12%200x1002%3A0x6987%200x1787%3A0x2389%200x80)%E3%80%82%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20%E3%83%88%E3%83%A9%E3%82%B9%E3%83%86%E3%83%83%E3%83%89%E3%83%BB%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BB%E3%82%BE%E3%83%BC%E3%83%B3%20(TMZ)%20%E6%A9%9F%E8%83%BD%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5Bdrm%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20mmio%20%E3%83%99%E3%83%BC%E3%82%B9%3A%200xA0000000%3CBR%20%2F%3E%20%5Bdrm%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFmmio%E3%82%B5%E3%82%A4%E3%82%BA%3A%20262144%3CBR%20%2F%3E%20%5Bdrm%5D%20PCIE%E3%82%A2%E3%83%88%E3%83%9F%E3%83%83%E3%82%AF%E6%93%8D%E4%BD%9C%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B70%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CVI_COMMON%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B71%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CGMC_V8_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B72%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CTONGA_IH%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B73%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CGFX_V8_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B74%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CSDMA_V3_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B75%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CPOWERPLAY%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B76%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CDM%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B77%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CUVD_V6_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B78%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CVCE_V3_0%3E%3CBR%20%2F%3E%20%5Bdrm%3A.check_atom_bios%5Bamdgpu%5D%5D%20ATOMBIOS%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20ROM%20BAR%E3%81%8B%E3%82%89VBIOS%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%3A%20ATOM%20BIOS%3A%20113-ER16BFE-001%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_atombios_init%5Bamdgpu%5D%5D%20Atom%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C00000000%200KB%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5Bdrm%5D%20VM%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7UVD%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5Bdrm%5D%20VM%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7UVD%20ENC%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5Bdrm%5D%20VM%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7VCE%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5Bdrm%5D%20GPU%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%3CBR%20%2F%3E%20%5Bdrm%5D%20VM%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF64GB%E3%80%812%E3%83%AC%E3%83%99%E3%83%AB%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF10%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E3%83%95%E3%83%A9%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF9%E3%83%93%E3%83%83%E3%83%88%3CBR%20%2F%3E%5Bdrm%3A.gmc_v8_0_sw_init%5Bamdgpu%5D%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3ABAR%202%3A%20%5Bmem%200xd10000000-0xd101fffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%E3%82%92%E8%A7%A3%E6%94%BE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3ABAR%200%3A%20%5Bmem%200xd00000000-0xd0fffffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%E3%82%92%E8%A7%A3%E6%94%BE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Epcieport%200001%3A00%3A00.0%3ABAR%209%3A%20%5Bmem%200xd00000000-0xeffffffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%E3%82%92%E8%A7%A3%E6%94%BE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Epcieport%200001%3A00%3A00.0%3ABAR%209%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200xd00000000-0xe7fffffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3ABAR%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200xd00000000-0xdffffffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3ABAR%202%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200xe00000000-0xe001fffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%3CBR%20%2F%3E%20pcieport%200001%3A00%3A00.0%3APCI%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%8B%E3%82%89%5B%E3%83%90%E3%82%B901%5D%E3%81%B8%3CBR%20%2F%3Epcieport%200001%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5Bio%200x8000080000010000-0x800008000001ffff%5D%3CBR%20%2F%3E%20pcieport%200001%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5Bmem%200xa0000000-0xaffffffff%5D%3CBR%20%2F%3E%20pcieport%200001%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5Bmem%200xd00000000-0xe7fffffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20VRAM%3A%204096M%200x000000F400000000%20-%200x000000F4FFFFFFFF%20(4096M%20%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20GART%3A%20256M%200x000000FF00000000%20-%200x000000FF0FFFFFFF%3CBR%20%2F%3E%20%5Bdrm%5D%20VRAM%20RAM%3D4096M%E3%80%81BAR%3D4096M%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5Bdrm%5D%20RAM%E5%B9%85128%E3%83%93%E3%83%83%E3%83%88GDDR5%3CBR%20%2F%3E%20%5Bdrm%5D%20amdgpu%3A%204096M%E3%81%AEVRAM%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%5Bdrm%5D%20amdgpu%3A%201457M%E3%81%AEGTT%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%E3%80%82%3CBR%20%2F%3E%5Bdrm%5D%20GART%3A%20CPU%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%2065536%E3%80%81GPU%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%2065536%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_mc_hdr%5Bamdgpu%5D%5D%20MC%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%83%90%E3%82%A4%E3%83%88%E6%95%B0%3A%2032608%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%82%B5%E3%82%A4%E3%82%BA%E3%83%90%E3%82%A4%E3%83%88%E6%95%B0%3A%2040%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_version_major%3A%201%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_version_minor%3A%200%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ip_version_major%3A%208%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ip_version_minor%3A%201%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_version%3A%200x00b4dc50%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_size_bytes%3A%2032160%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_array_offset_bytes%3A%20448%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20crc32%3A%200x9b1e395c%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_mc_hdr%5Bamdgpu%5D%5D%20io_debug_size_bytes%3A%20192%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_mc_hdr%5Bamdgpu%5D%5D%20io_debug_array_offset_bytes%3A%20256%3CBR%20%2F%3E%20%5Bdrm%5D%20256M%E3%81%AEPCIE%20GART%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AF0x000000F400000000%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_irq_init%5Bamdgpu%5D%5D%20amdgpu%3A%20irq%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_sw_init%5Bamdgpu%5D%3CBR%20%2F%3E%20%5Bdrm%5D%20%E9%80%A3%E9%8E%96IB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400040%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.0.0%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff004000e0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.1.0%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90GPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400180%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.2.0%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%20GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff00400220%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.3.0%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff004002c0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.0.1%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff00400360%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.1.1%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff00400400%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.2.1%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff004004a0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.3.1%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff00400540%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20kiq_2.1.0%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90GPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff004005e0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5Bdrm%3A.sdma_v3_0_sw_init%5Bamdgpu%5D%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0sdma0%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400680%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0sdma1%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400720%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%3A%20hwmgr_sw_init%20%E3%81%AE%20smu%20%E3%81%AF%20polaris10_smu%20%E3%81%A7%E3%81%99%3CBR%20%2F%3E%5Bdrm%5D%20UVD%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.130%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AAID%3A%2016%20%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0UVD%E4%B8%8A%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000f4001afa80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0uvd_enc0%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400860%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0uvd_enc1%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400900%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5Bdrm%5D%20VCE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%2053.26%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AAID%3A%203%20%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0vce0%E4%B8%8A%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff004009a0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0vce1%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400a40%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0vce2%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400ae0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ucode_print_smc_hdr%5Bamdgpu%5D%5D%20SMC%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%83%90%E3%82%A4%E3%83%88%E6%95%B0%3A%20130388%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%82%B5%E3%82%A4%E3%82%BA%E3%83%90%E3%82%A4%E3%83%88%E6%95%B0%3A%2036%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_version_major%3A%201%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_version_minor%3A%200%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ip_version_major%3A%207%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ip_version_minor%3A%202%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_version%3A%200x00221700%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_size_bytes%3A%20130132%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_array_offset_bytes%3A%20256%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20crc32%3A%200xae2b3b78%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_smc_hdr%5Bamdgpu%5D%5D%20ucode_start_addr%3A%20131072%3CBR%20%2F%3E%20amdgpu%3A%3CBR%20%2F%3E%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8100%E3%81%AE%E9%80%81%E4%BF%A1%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%88%BB%E3%82%8A%E5%80%A4%E3%81%AF0%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20amdgpu%3A%20SMU%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%3CBR%20%2F%3E%20amdgpu%3A%20SMU%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Eamdgpu%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%3A%20smu%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20amdgpu_device_ip_init%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20GPU%E5%88%9D%E6%9C%9F%E5%8C%96%E4%B8%AD%E3%81%AB%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20amdgpu%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%87%A6%E7%90%86%E3%82%92%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20%E7%84%A1%E5%8A%B9%20me%202%3CBR%20%2F%3E%20%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20%E7%84%A1%E5%8A%B9%20me%202%3CBR%20%2F%3E%20%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20%E7%84%A1%E5%8A%B9%20me%202%3CBR%20%2F%3E%20%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20%E7%84%A1%E5%8A%B9%20me%202%3CBR%20%2F%3E%20amdgpu%3A%200001%3A01%3A00.0%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-22%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%90%E3%82%B0%3A%200x8000080080954000%20%E3%81%A7%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%99%82%E3%81%AB%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%E7%99%BA%E7%94%9F%E5%91%BD%E4%BB%A4%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%200xc000000000011870%3CBR%20%2F%3E%E3%81%8A%E3%81%A3%E3%81%A8%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8C%E4%B8%8D%E6%AD%A3%E3%81%AA%E9%A0%98%E5%9F%9F%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E7%BD%B2%E5%90%8D%3A%2011%20%5B%231%5D%3CBR%20%2F%3E%20BE%20PAGE_SIZE%3D4K%20SMP%20NR_CPUS%3D24%20CoreNet%20%E6%B1%8E%E7%94%A8%3CBR%20%2F%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3A%20amdgpu(%2B)%20backlight%20drm_ttm_helper%20ttm%20gpu_sched%20ucc_uart%20fsl_jr_uio%3CBR%20%2F%3E%20CPU%3A%202%20PID%3A%20816%20Comm%3A%20insmod%20%E6%B1%9A%E6%9F%93%E3%81%AA%E3%81%97%205.15.71%2Bg95448dd0dc9b%20%231%3CBR%20%2F%3E%20**%E3%83%94%E3%83%BC%E9%9F%B3**%3A%20c000000000011870%20LR%3A%208000000000e0d120%20CTR%3A%200000000000058400%3CBR%20%2F%3E%E8%A6%8F%E5%88%B6%3A%20c00000000a956d80%20%E3%83%88%E3%83%A9%E3%83%83%E3%83%97%3A%200300%20%E6%B1%9A%E6%9F%93%E3%81%AA%E3%81%97%20(5.15.71%2Bg95448dd0dc9b)%3CBR%20%2F%3EMSR%3A%200000000080029002%20%3CCE%3E%20CR%3A%2022002228%20XER%3A%2000000000%3CBR%20%2F%3E%20DEAR%3A%208000080080954000%20ESR%3A%200000000000000000%20IRQMASK%3A%200%3CBR%20%2F%3E%20GPR00%3A%208000000000e0d100%20c00000000a957020%20c0000000013faa00%20c00000000c000000%3CBR%20%2F%3E%20GPR04%3A%208000080080954000%2000000000002c2000%2000000000000b0800%20000000007ecc9000%3CBR%20%2F%3E%20GPR08%3A%200000000000058400%208000080080954000%20c00000000bfffffc%2080000000010b76d8%3CBR%20%2F%3E%20GPR12%3A%20c0000000000117f4%20c00000003ffff140%20000000010b5456f0%20000000010b4fa188%3CBR%20%2F%3E%20GPR16%3A%200000000000000000%20000000010b545810%20000000010b5202b0%200000000000000000%3CBR%20%2F%3E%20GPR20%3A%200000000000000000%200000000000000000%20c00000000ae16a48%208000080080954000%3CBR%20%2F%3E%20GPR24%3A%2000000000002c2000%200000000000000000%20c00000000ae00010%200000000000000001%3CBR%20%2F%3E%20GPR28%3A%20c00000000ae00000%20c00000000ae10000%200000000000000000%20c00000000ae10000%3CBR%20%2F%3E%20**%E3%83%94%E3%83%BC**%20%5Bc000000000011870%5D%20._memcpy_fromio%2B0x7c%2F0x100%3CBR%20%2F%3ELR%20%5B8000000000e0d120%5D%20.amdgpu_uvd_suspend%2B0x1d4%2F0x268%5Bamdgpu%5D%3CBR%20%2F%3E%E9%80%9A%E8%A9%B1%E8%BF%BD%E8%B7%A1%EF%BC%9A%3CBR%20%2F%3E%20%5Bc00000000a957020%5D%20%5B8000000000e0d100%5D%20.amdgpu_uvd_suspend%2B0x1b4%2F0x268%5Bamdgpu%5D%20(%E4%BF%A1%E9%A0%BC%E6%80%A7%E3%81%8C%E4%BD%8E%E3%81%84)%3CBR%20%2F%3E%20%5Bc00000000a9570f0%5D%20%5B8000000000e1110c%5D%20.uvd_v6_0_sw_fini%2B0x1c%2F0xcc%5Bamdgpu%5D%3CBR%20%2F%3E%20%5Bc00000000a957180%5D%20%5B8000000000cf24b0%5D%20.amdgpu_device_fini_sw%2B0x124%2F0x378%5Bamdgpu%5D%3CBR%20%2F%3E%20%5Bc00000000a957240%5D%20%5B8000000000cf9e0c%5D%20.amdgpu_driver_release_kms%2B0x1c%2F0x40%5Bamdgpu%5D%3CBR%20%2F%3E%20%5Bc00000000a9572c0%5D%20%5Bc000000000704380%5D%20.devm_drm_dev_init_release%2B0x78%2F0xcc%3CBR%20%2F%3E%5Bc00000000a957340%5D%20%5Bc000000000755248%5D%20.devm_action_release%2B0x28%2F0x3c%3CBR%20%2F%3E%5Bc00000000a9573b0%5D%20%5Bc00000000075576c%5D%20.release_nodes%2B0x78%2F0x108%3CBR%20%2F%3E%5Bc00000000a957450%5D%20%5Bc000000000757174%5D%20.devres_release_all%2B0xa8%2F0x11c%3CBR%20%2F%3E%5Bc00000000a957510%5D%20%5Bc00000000074f788%5D%20.really_probe.part.0%2B0x1b8%2F0x440%3CBR%20%2F%3E%5Bc00000000a9575b0%5D%20%5Bc00000000074fad8%5D%20.__driver_probe_device%2B0xc8%2F0x198%3CBR%20%2F%3E%5Bc00000000a957640%5D%20%5Bc00000000074fbf8%5D%20.driver_probe_device%2B0x50%2F0x16c%3CBR%20%2F%3E%5Bc00000000a9576e0%5D%20%5Bc00000000075055c%5D%20.__driver_attach%2B0xb4%2F0x200%3CBR%20%2F%3E%5Bc00000000a957770%5D%20%5Bc00000000074c518%5D%20.bus_for_each_dev%2B0x9c%2F0x110%3CBR%20%2F%3E%5Bc00000000a957820%5D%20%5Bc00000000074eca4%5D%20.driver_attach%2B0x24%2F0x38%3CBR%20%2F%3E%5Bc00000000a957890%5D%20%5Bc00000000074e4ec%5D%20.bus_add_driver%2B0x1d4%2F0x2a8%3CBR%20%2F%3E%5Bc00000000a957940%5D%20%5Bc00000000075107c%5D%20.driver_register%2B0xa4%2F0x194%3CBR%20%2F%3E%5Bc00000000a9579c0%5D%20%5Bc0000000006217ec%5D%20.__pci_register_driver%2B0x58%2F0x6c%3CBR%20%2F%3E%5Bc00000000a957a30%5D%20%5B80000000010a9608%5D%20.amdgpu_init%2B0x74%2F0x94%5Bamdgpu%5D%3CBR%20%2F%3E%20%5Bc00000000a957ab0%5D%20%5Bc0000000000021cc%5D%20.do_one_initcall%2B0x6c%2F0x284%3CBR%20%2F%3E%5Bc00000000a957b90%5D%20%5Bc0000000001174a4%5D%20.do_init_module%2B0x5c%2F0x2bc%3CBR%20%2F%3E%5Bc00000000a957c30%5D%20%5Bc00000000011a980%5D%20.__do_sys_finit_module%2B0xc4%2F0x10c%3CBR%20%2F%3E%5Bc00000000a957d60%5D%20%5Bc000000000012454%5D%20.system_call_exception%2B0x11c%2F0x1c4%3CBR%20%2F%3E%5Bc00000000a957e10%5D%20%5Bc0000000000001f8%5D%20system_call_common%2B0xf0%2F0x210%3CBR%20%2F%3E%20---%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3A%20c00%20(0x3fffbe532ee4)%3CBR%20%2F%3E%20**%E3%83%94%E3%83%BC%E9%9F%B3**%3A%2000003fffbe532ee4%20LR%3A%2000000001366cdbfc%20CTR%3A%200000000000000000%3CBR%20%2F%3E%20REGS%3A%20c00000000a957e80%20TRAP%3A%200c00%20%E6%B1%9A%E6%9F%93%E3%81%AA%E3%81%97%20(5.15.71%2Bg95448dd0dc9b)%3CBR%20%2F%3EMSR%3A%20000000008002d002%20%3CCE%3E%20CR%3A%2028002882%20XER%3A%2000000000%3CBR%20%2F%3E%20IRQMASK%3A%200%3CBR%20%2F%3E%20GPR00%3A%200000000000000161%2000003fffd14f61a0%2000003fffbe637200%200000000000000003%3CBR%20%2F%3E%20GPR04%3A%2000000001366d9148%200000000000000000%200000000000000000%200000000000000000%3CBR%20%2F%3E%20GPR08%3A%200000000000000000%200000000000000000%2000000000000000000%200000000000000000%3CBR%20%2F%3E%20GPR12%3A%200000000000000000%2000003fffbe6cf810%20000000010b5456f0%20000000010b4fa188%3CBR%20%2F%3E%20GPR16%3A%200000000000000000%20000000010b545810%20000000010b5202b0%200000000000000000%3CBR%20%2F%3E%20GPR20%3A%200000000000000000%200000000000000000%200000000000000002%2000003fffd14f6ee5%3CBR%20%2F%3E%20GPR24%3A%2000003fffd14f6860%2000000001366fd9e8%200000000000000000%2000000001366fcbd0%3CBR%20%2F%3E%20GPR28%3A%2000000001366d9148%200000000000000000%200000000000000000%200000000136701760%3CBR%20%2F%3E%20**%E3%83%94%E3%83%BC**%20%5B00003fffbe532ee4%5D%200x3fffbe532ee4%3CBR%20%2F%3E%20LR%20%5B00000001366cdbfc%5D%200x1366cdbfc%3CBR%20%2F%3E%20---%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3A%20c00%3CBR%20%2F%3E%E5%91%BD%E4%BB%A4%E3%83%80%E3%83%B3%E3%83%97%3A%3CBR%20%2F%3E%204e800020%2028250003%2040810068%203905fffc%207908f082%2038c80001%2070c90001%203943fffc%3CBR%20%2F%3E%207c892378%2040820070%2078c8f842%207d0903a6%20%26lt%3B80e90000%26gt%3B%20390a0004%2090ea0004%207c0006ac%3CBR%20%2F%3E%20---%5B%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E7%B5%82%E4%BA%86%20e1f14bc598aaf8c6%20%5D---%3C%2FCE%3E%3C%2FCE%3E%3C%2FVCE_V3_0%3E%3C%2FUVD_V6_0%3E%3C%2FDM%3E%3C%2FPOWERPLAY%3E%3C%2FSDMA_V3_0%3E%3C%2FGFX_V8_0%3E%3C%2FTONGA_IH%3E%3C%2FGMC_V8_0%3E%3C%2FVI_COMMON%3E%3C%2FP%3E%3CP%3E%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2365333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20send%20message%20100%20ret%20is%200%20while%20loading%20AMDGPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2365333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20AMDGPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7SMU%E3%82%92%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%EF%BC%88gfx%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%86%E3%82%B9%E3%83%88%E5%A4%B1%E6%95%97%EF%BC%89%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3Eroot%40t1042d4rdb%3A~%23%20insmod%20%2Famdgpu.ko%3CBR%20%2F%3E%5Bdrm%5D%20amdgpu%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5Bdrm%5D%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(POLARIS12%200x1002%3A0x6987%200x1787%3A0x2389%200x80)%E3%80%82%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20%E3%83%88%E3%83%A9%E3%82%B9%E3%83%86%E3%83%83%E3%83%89%E3%83%BB%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BB%E3%82%BE%E3%83%BC%E3%83%B3%20(TMZ)%20%E6%A9%9F%E8%83%BD%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5Bdrm%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20mmio%20%E3%83%99%E3%83%BC%E3%82%B9%3A%200xA0000000%3CBR%20%2F%3E%20%5Bdrm%5D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFmmio%E3%82%B5%E3%82%A4%E3%82%BA%3A%20262144%3CBR%20%2F%3E%20%5Bdrm%5D%20PCIE%E3%82%A2%E3%83%88%E3%83%9F%E3%83%83%E3%82%AF%E6%93%8D%E4%BD%9C%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B70%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CVI_COMMON%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B71%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CGMC_V8_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B72%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CTONGA_IH%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B73%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CGFX_V8_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B74%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CSDMA_V3_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B75%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CPOWERPLAY%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B76%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CDM%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B77%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CUVD_V6_0%3E%3CBR%20%2F%3E%20%5Bdrm%5D%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B78%E3%82%92%E8%BF%BD%E5%8A%A0%20%3CVCE_V3_0%3E%3CBR%20%2F%3E%20%5Bdrm%3A.check_atom_bios%5Bamdgpu%5D%5D%20ATOMBIOS%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20ROM%20BAR%E3%81%8B%E3%82%89VBIOS%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%3A%20ATOM%20BIOS%3A%20113-ER16BFE-001%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_atombios_init%5Bamdgpu%5D%5D%20Atom%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C00000000%200KB%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5Bdrm%5D%20VM%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7UVD%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5Bdrm%5D%20VM%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7UVD%20ENC%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5Bdrm%5D%20VM%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7VCE%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5Bdrm%5D%20GPU%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F...%3CBR%20%2F%3E%20%5Bdrm%5D%20VM%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF64GB%E3%80%812%E3%83%AC%E3%83%99%E3%83%AB%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF10%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E3%83%95%E3%83%A9%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF9%E3%83%93%E3%83%83%E3%83%88%3CBR%20%2F%3E%5Bdrm%3A.gmc_v8_0_sw_init%5Bamdgpu%5D%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3ABAR%202%3A%20%5Bmem%200xd10000000-0xd101fffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%E3%82%92%E8%A7%A3%E6%94%BE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3ABAR%200%3A%20%5Bmem%200xd00000000-0xd0fffffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%E3%82%92%E8%A7%A3%E6%94%BE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Epcieport%200001%3A00%3A00.0%3ABAR%209%3A%20%5Bmem%200xd00000000-0xeffffffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%E3%82%92%E8%A7%A3%E6%94%BE%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Epcieport%200001%3A00%3A00.0%3ABAR%209%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200xd00000000-0xe7fffffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3ABAR%200%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200xd00000000-0xdffffffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3ABAR%202%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%B8%88%E3%81%BF%20%5Bmem%200xe00000000-0xe001fffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%3CBR%20%2F%3E%20pcieport%200001%3A00%3A00.0%3APCI%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%8B%E3%82%89%5B%E3%83%90%E3%82%B901%5D%E3%81%B8%3CBR%20%2F%3Epcieport%200001%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5Bio%200x8000080000010000-0x800008000010ffff%5D%3CBR%20%2F%3E%20pcieport%200001%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5Bmem%200xa0000000-0xaffffffff%5D%3CBR%20%2F%3E%20pcieport%200001%3A00%3A00.0%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%5Bmem%200xd00000000-0xe7fffffff%2064%E3%83%93%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%5D%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20VRAM%3A%204096M%200x000000F400000000%20-%200x000000F4FFFFFFFF%20(4096M%20%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20GART%3A%20256M%200x000000FF00000000%20-%200x000000FF0FFFFFFF%3CBR%20%2F%3E%20%5Bdrm%5D%20VRAM%20RAM%3D4096M%E3%80%81BAR%3D4096M%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5Bdrm%5D%20RAM%E5%B9%85128%E3%83%93%E3%83%83%E3%83%88GDDR5%3CBR%20%2F%3E%20%5Bdrm%5D%20amdgpu%3A%204096M%E3%81%AEVRAM%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%5Bdrm%5D%20amdgpu%3A%201457M%E3%81%AEGTT%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%E3%80%82%3CBR%20%2F%3E%5Bdrm%5D%20GART%3A%20CPU%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%2065536%E3%80%81GPU%E3%83%9A%E3%83%BC%E3%82%B8%E6%95%B0%2065536%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_mc_hdr%5Bamdgpu%5D%5D%20MC%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%83%90%E3%82%A4%E3%83%88%E6%95%B0%3A%2032608%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%82%B5%E3%82%A4%E3%82%BA%E3%83%90%E3%82%A4%E3%83%88%E6%95%B0%3A%2040%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_version_major%3A%201%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20header_version_minor%3A%200%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ip_version_major%3A%208%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ip_version_minor%3A%201%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_version%3A%200x00b4dc50%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_size_bytes%3A%2032160%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20ucode_array_offset_bytes%3A%20448%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_common_hdr%5Bamdgpu%5D%5D%20crc32%3A%200x9b1e395c%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_mc_hdr%5Bamdgpu%5D%5D%20io_debug_size_bytes%3A%20192%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_ucode_print_mc_hdr%5Bamdgpu%5D%5D%20io_debug_array_offset_bytes%3A%20256%3CBR%20%2F%3E%20%5Bdrm%5D%20256M%E3%81%AEPCIE%20GART%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AF0x000000F400000000%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_irq_init%5Bamdgpu%5D%5D%20amdgpu%3A%20irq%20%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_sw_init%5Bamdgpu%5D%3CBR%20%2F%3E%20%5Bdrm%5D%20%E9%80%A3%E9%8E%96IB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400040%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.0.0%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff004000e0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.1.0%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90GPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400180%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.2.0%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%20GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff00400220%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.3.0%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff004002c0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.0.1%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff00400360%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.1.1%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff00400400%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.2.1%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff004004a0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20comp_1.3.1%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GPU%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x000000ff00400540%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0%20kiq_2.1.0%20%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90GPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff004005e0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5Bdrm%3A.sdma_v3_0_sw_init%5Bamdgpu%5D%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0sdma0%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400680%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0sdma1%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400720%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%3A%20hwmgr_sw_init%20%E3%81%AE%20smu%20%E3%81%AF%20polaris10_smu%20%E3%81%A7%E3%81%99%3CBR%20%2F%3E%5Bdrm%5D%20UVD%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.130%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AAID%3A%2016%20%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0UVD%E4%B8%8A%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000f4001afa80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0uvd_enc0%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400860%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0uvd_enc1%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400900%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5Bdrm%5D%20VCE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%2053.26%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AAID%3A%203%20%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0vce0%E4%B8%8A%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff004009a0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0vce1%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400a40%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_fence_driver_start_ring%5Bamdgpu%5D%5D%20%E3%83%AA%E3%83%B3%E3%82%B0vce2%E3%81%AE%E3%83%95%E3%82%A7%E3%83%B3%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AFGPU%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x000000ff00400ae0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5Bdrm%3A.amdgpu_ih_process%5Bamdgpu%5D%5D%20amdgpu_ih_process%3A%20rptr%200%E3%80%81wptr%2016%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_irq_dispatch%5Bamdgpu%5D%5D%20%E6%9C%AA%E5%87%A6%E7%90%86%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20src_id%3A%20141%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3A%5Bdrm%3A.amdgpu_ring_test_helper%5Bamdgpu%5D%20*%E3%82%A8%E3%83%A9%E3%83%BC*%20%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(-110)%3CBR%20%2F%3E%20%5Bdrm%3A.amdgpu_device_init%5Bamdgpu%5D%5D%20*%E3%82%A8%E3%83%A9%E3%83%BC*%20IP%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%3CGFX_V8_0%3E%E3%81%AEhw_init%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-110%3CBR%20%2F%3E%20amdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20amdgpu_device_ip_init%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20GPU%E5%88%9D%E6%9C%9F%E5%8C%96%E4%B8%AD%E3%81%AB%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eamdgpu%200001%3A01%3A00.0%3Aamdgpu%3A%20amdgpu%3A%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%87%A6%E7%90%86%E3%82%92%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20%E7%84%A1%E5%8A%B9%20me%202%3CBR%20%2F%3E%20%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20%E7%84%A1%E5%8A%B9%20me%202%3CBR%20%2F%3E%20%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20%E7%84%A1%E5%8A%B9%20me%202%3CBR%20%2F%3E%20%5Bdrm%3A.gfx_v8_0_set_eop_interrupt_state%5Bamdgpu%5D%5D%20%E7%84%A1%E5%8A%B9%20me%202%3CBR%20%2F%3E%20amdgpu%3A%200001%3A01%3A00.0%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-110%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%90%E3%82%B0%3A%200x8000080080954000%20%E3%81%A7%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E6%99%82%E3%81%AB%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%E7%99%BA%E7%94%9F%E5%91%BD%E4%BB%A4%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%200xc000000000011870%3CBR%20%2F%3E%E3%81%8A%E3%81%A3%E3%81%A8%3A%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8C%E4%B8%8D%E6%AD%A3%E3%81%AA%E9%A0%98%E5%9F%9F%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E7%BD%B2%E5%90%8D%3A%2011%20%5B%231%5D%3CBR%20%2F%3E%20BE%20PAGE_SIZE%3D4K%20SMP%20NR_CPUS%3D24%20CoreNet%20%E6%B1%8E%E7%94%A8%3CBR%20%2F%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3A%20amdgpu(%2B)%20backlight%20drm_ttm_helper%20ttm%20gpu_sched%20ucc_uart%20fsl_jr_uio%3CBR%20%2F%3E%20CPU%3A%202%20PID%3A%20819%20Comm%3A%20insmod%20%E6%B1%9A%E6%9F%93%E3%81%AA%E3%81%97%205.15.71%2Bg95448dd0dc9b%20%231%3CBR%20%2F%3E%20**%E3%83%94%E3%83%BC%E9%9F%B3**%3A%20c000000000011870%20LR%3A%208000000000e0efe0%20CTR%3A%200000000000058400%3CBR%20%2F%3E%E8%A6%8F%E5%88%B6%3A%20c00000000a5aad80%20%E3%83%88%E3%83%A9%E3%83%83%E3%83%97%3A%200300%20%E6%B1%9A%E6%9F%93%E3%81%AA%E3%81%97%20(5.15.71%2Bg95448dd0dc9b)%3CBR%20%2F%3EMSR%3A%200000000080029002%20%3CCE%3E%20CR%3A%2022002228%20XER%3A%2000000000%3CBR%20%2F%3E%20DEAR%3A%208000080080954000%20ESR%3A%200000000000000000%20IRQMASK%3A%200%3CBR%20%2F%3E%20GPR00%3A%208000000000e0efc0%20c00000000a5ab020%20c0000000013e8c00%20c00000000c000000%3CBR%20%2F%3E%20GPR04%3A%208000080080954000%2000000000002c2000%2000000000000b0800%20000000007ecd9000%3CBR%20%2F%3E%20GPR08%3A%200000000000058400%208000080080954000%20c00000000bfffffc%2080000000010b8988%3CBR%20%2F%3E%20GPR12%3A%20c0000000000117f4%20c00000003ffff140%2000000001050e5850%20000000010509a188%3CBR%20%2F%3E%20GPR16%3A%200000000000000000%2000000001050e5990%2000000001050bfb80%200000000000000000%3CBR%20%2F%3E%20GPR20%3A%200000000000000000%200000000000000000%20c00000000a916a48%208000080080954000%3CBR%20%2F%3E%20GPR24%3A%2000000000002c2000%200000000000000000%20c00000000a900010%200000000000000001%3CBR%20%2F%3E%20GPR28%3A%20c00000000a900000%20c00000000a910000%200000000000000000%20c00000000a910000%3CBR%20%2F%3E%20**%E3%83%94%E3%83%BC**%20%5Bc000000000011870%5D%20._memcpy_fromio%2B0x7c%2F0x100%3CBR%20%2F%3ELR%20%5B8000000000e0efe0%5D%20.amdgpu_uvd_suspend%2B0x1d4%2F0x268%5Bamdgpu%5D%3CBR%20%2F%3E%E9%80%9A%E8%A9%B1%E8%BF%BD%E8%B7%A1%EF%BC%9A%3CBR%20%2F%3E%20%5Bc00000000a5ab020%5D%20%5B8000000000e0efc0%5D%20.amdgpu_uvd_suspend%2B0x1b4%2F0x268%5Bamdgpu%5D%20(%E4%BF%A1%E9%A0%BC%E6%80%A7%E3%81%8C%E4%BD%8E%E3%81%84)%3CBR%20%2F%3E%20%5Bc00000000a5ab0f0%5D%20%5B8000000000e12fcc%5D%20.uvd_v6_0_sw_fini%2B0x1c%2F0xcc%5Bamdgpu%5D%3CBR%20%2F%3E%20%5Bc00000000a5ab180%5D%20%5B8000000000cf44b0%5D%20.amdgpu_device_fini_sw%2B0x124%2F0x378%5Bamdgpu%5D%3CBR%20%2F%3E%20%5Bc00000000a5ab240%5D%20%5B8000000000cfbe0c%5D%20.amdgpu_driver_release_kms%2B0x1c%2F0x40%5Bamdgpu%5D%3CBR%20%2F%3E%20%5Bc00000000a5ab2c0%5D%20%5Bc0000000006fa1e4%5D%20.devm_drm_dev_init_release%2B0x78%2F0xcc%3CBR%20%2F%3E%5Bc00000000a5ab340%5D%20%5Bc00000000074b0ac%5D%20.devm_action_release%2B0x28%2F0x3c%3CBR%20%2F%3E%5Bc00000000a5ab3b0%5D%20%5Bc00000000074b5d0%5D%20.release_nodes%2B0x78%2F0x108%3CBR%20%2F%3E%5Bc00000000a5ab450%5D%20%5Bc00000000074cfd8%5D%20.devres_release_all%2B0xa8%2F0x11c%3CBR%20%2F%3E%5Bc00000000a5ab510%5D%20%5Bc0000000007455ec%5D%20.really_probe.part.0%2B0x1b8%2F0x440%3CBR%20%2F%3E%5Bc00000000a5ab5b0%5D%20%5Bc00000000074593c%5D%20.__driver_probe_device%2B0xc8%2F0x198%3CBR%20%2F%3E%5Bc00000000a5ab640%5D%20%5Bc000000000745a5c%5D%20.driver_probe_device%2B0x50%2F0x16c%3CBR%20%2F%3E%5Bc00000000a5ab6e0%5D%20%5Bc0000000007463c0%5D%20.__driver_attach%2B0xb4%2F0x200%3CBR%20%2F%3E%5Bc00000000a5ab770%5D%20%5Bc00000000074237c%5D%20.bus_for_each_dev%2B0x9c%2F0x110%3CBR%20%2F%3E%5Bc00000000a5ab820%5D%20%5Bc000000000744b08%5D%20.driver_attach%2B0x24%2F0x38%3CBR%20%2F%3E%5Bc00000000a5ab890%5D%20%5Bc000000000744350%5D%20.bus_add_driver%2B0x1d4%2F0x2a8%3CBR%20%2F%3E%5Bc00000000a5ab940%5D%20%5Bc000000000746ee0%5D%20.driver_register%2B0xa4%2F0x194%3CBR%20%2F%3E%5Bc00000000a5ab9c0%5D%20%5Bc0000000006211dc%5D%20.__pci_register_driver%2B0x58%2F0x6c%3CBR%20%2F%3E%5Bc00000000a5aba30%5D%20%5B80000000010aa8e8%5D%20.amdgpu_init%2B0x74%2F0x94%5Bamdgpu%5D%3CBR%20%2F%3E%20%5Bc00000000a5abab0%5D%20%5Bc0000000000021cc%5D%20.do_one_initcall%2B0x6c%2F0x284%3CBR%20%2F%3E%5Bc00000000a5abb90%5D%20%5Bc000000000116ea0%5D%20.do_init_module%2B0x5c%2F0x2bc%3CBR%20%2F%3E%5Bc00000000a5abc30%5D%20%5Bc00000000011a37c%5D%20.__do_sys_finit_module%2B0xc4%2F0x10c%3CBR%20%2F%3E%5Bc00000000a5abd60%5D%20%5Bc000000000012454%5D%20.system_call_exception%2B0x11c%2F0x1c4%3CBR%20%2F%3E%5Bc00000000a5abe10%5D%20%5Bc0000000000001f8%5D%20system_call_common%2B0xf0%2F0x210%3CBR%20%2F%3E%20---%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3A%20c00%20(0x3fff82934ee4)%3CBR%20%2F%3E%20**%E3%83%94%E3%83%BC%E9%9F%B3**%3A%2000003fff82934ee4%20LR%3A%2000000001194adbfc%20CTR%3A%200000000000000000%3CBR%20%2F%3E%20REGS%3A%20c00000000a5abe80%20TRAP%3A%200c00%20%E6%B1%9A%E6%9F%93%E3%81%AA%E3%81%97%20(5.15.71%2Bg95448dd0dc9b)%3CBR%20%2F%3EMSR%3A%20000000008002d002%20%3CCE%3E%20CR%3A%2028002882%20XER%3A%2000000000%3CBR%20%2F%3E%20IRQMASK%3A%200%3CBR%20%2F%3E%20GPR00%3A%200000000000000161%2000003fffefee52c0%2000003fff82a39200%200000000000000003%3CBR%20%2F%3E%20GPR04%3A%2000000001194b9148%200000000000000000%200000000000000000%200000000000000000%3CBR%20%2F%3E%20GPR08%3A%200000000000000000%200000000000000000%2000000000000000000%200000000000000000%3CBR%20%2F%3E%20GPR12%3A%200000000000000000%2000003fff82ad1810%2000000001050e5850%20000000010509a188%3CBR%20%2F%3E%20GPR16%3A%200000000000000000%2000000001050e5990%2000000001050bfb80%200000000000000000%3CBR%20%2F%3E%20GPR20%3A%200000000000000000%200000000000000000%200000000000000002%2000003fffefee5ee5%3CBR%20%2F%3E%20GPR24%3A%2000003fffefee5980%2000000001194dd9e8%200000000000000000%2000000001194dcbd0%3CBR%20%2F%3E%20GPR28%3A%2000000001194b9148%200000000000000000%200000000000000000%2000000001194e1760%3CBR%20%2F%3E%20**%E3%83%94%E3%83%BC**%20%5B00003fff82934ee4%5D%200x3fff82934ee4%3CBR%20%2F%3E%20LR%20%5B00000001194adbfc%5D%200x1194adbfc%3CBR%20%2F%3E%20---%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3A%20c00%3CBR%20%2F%3E%E5%91%BD%E4%BB%A4%E3%83%80%E3%83%B3%E3%83%97%3A%3CBR%20%2F%3E%204e800020%2028250003%2040810068%203905fffc%207908f082%2038c80001%2070c90001%203943fffc%3CBR%20%2F%3E%207c892378%2040820070%2078c8f842%207d0903a6%20%26lt%3B80e90000%26gt%3B%20390a0004%2090ea0004%207c0006ac%3CBR%20%2F%3E%20---%5B%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E7%B5%82%E4%BA%86%20fef1e0dc2e9ff52c%20%5D---%3C%2FCE%3E%3C%2FCE%3E%3C%2FGFX_V8_0%3E%3C%2FVCE_V3_0%3E%3C%2FUVD_V6_0%3E%3C%2FDM%3E%3C%2FPOWERPLAY%3E%3C%2FSDMA_V3_0%3E%3C%2FGFX_V8_0%3E%3C%2FTONGA_IH%3E%3C%2FGMC_V8_0%3E%3C%2FVI_COMMON%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2365223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20send%20message%20100%20ret%20is%200%20while%20loading%20AMDGPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2365223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F34846%22%20target%3D%22_blank%22%3E%40Bio_TICFSL%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AF%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%20-%26gt%3B%20NXP%20T1040%EF%BC%88AMD%20E9171%20GPU%E6%90%AD%E8%BC%89%EF%BC%89%3CBR%20%2F%3E%20-%26gt%3B%20NXP%20T2080%EF%BC%88AMD%20E9171%20GPU%E6%90%AD%E8%BC%89%EF%BC%89%3CBR%20%2F%3E%20-%26gt%3B%20NXP%20T2080%EF%BC%88AMD%20E8860%20GPU%E6%90%AD%E8%BC%89%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2365014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20failed%20to%20send%20message%20100%20ret%20is%200%20while%20loading%20AMDGPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2365014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%AD%E3%82%B0%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81AMDGPU%E3%81%AFPolaris12%20SMU%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%B5%B7%E5%8B%95%E4%B8%AD%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E4%B8%80%E6%96%B9%E3%80%81PCIe%E3%81%AFGPU%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E5%BE%8C%E6%9C%9F%E3%81%BE%E3%81%A7%E6%AD%A3%E3%81%97%E3%81%8F%E5%88%97%E6%8C%99%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AAT1040%20PCIe%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%A8%E3%81%84%E3%81%86%E3%82%88%E3%82%8A%E3%82%82%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E5%A4%B1%E6%95%97%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E9%AB%98%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
