T2081 512MB NOR Flash
arumilli
I am currently working on the T2081 NOR flash configuration with two NOR chips connected on the board:
  • CS0 – 256MB
  • CS1 – 256MB
As of now, the 256MB NOR flash on CS0 is working correctly.
The configured address range is:
  • 0xE0000000 to 0xEFFFFFFF
For booting, we are currently using the 128MB region:
  • 0xE8000000 to 0xEFFFFFFF
Now, I would like to increase the NOR flash size to 512MB. Could you please let me know what changes are required for this update?
Thanks and Regards,
Ravindra Arumilli
arumilli
Thank you for the information.
The proposed CS1 window 0xF0000000–0xFFFFFFFF is already being used by other interfaces in our design. Therefore, we are unable to assign this address range to IFC CS1.
Could you please advise on an alternative address range that can be used for CS1 without overlapping with existing allocations?
arumilli
Thank you for the clarification regarding the IFC NOR mapping for the T2081.
We plan to use CS0 at:
  • CS0 : 0xE0000000 – 0xEFFFFFFF (256 MB)
Could you please confirm what the recommended non-overlapping address range should be for CS1 when using the second 256 MB NOR device?
Since the total NOR size becomes 512 MB, we would like to confirm the correct expanded LAW/IFC address map for CS1 and ensure the combined range is valid for boot and runtime access.
Ravindra Arumilli
Bio_TICFSL
Yes —For T2081, with CS0 at 0xE0000000–0xEFFFFFFF, the correct non-overlapping 256 MB CS1 window is 0xF0000000–0xFFFFFFFF, and the resulting 512 MB is valid as two adjacent IFC banks for runtime access, while boot still uses CS0 only.
Bio_TICFSL
To increase your T2081 IFC NOR space from 256 MB to 512 MB using two 256 MB NOR devices on CS0 and CS1 , the required changes are:
  1. Expand the IFC memory map to cover the full 512 MB window
  2. Program CS0 and CS1 with non-overlapping IFC base/mask settings
  3. Make the LAW window large enough to cover the combined IFC range
  4. Update U-Boot / Linux device tree partitioning to reflect the new map
  5. Keep boot on CS0, because NOR boot uses CS0 as the boot chip-select ,,,,,
The key correction first: for T2081 NOR boot , the available documentation says the valid default NOR map is 0xE8000000 to 0xEFFFFFFF for a 128 MB boot NOR setup, and NXP guidance for 256 MB NOR is to use 0xE0000000 to 0xEFFFFFFF . Since you now want two x 256 MB = 512 MB total , you should not leave the combined map at only 0xE0000000–0xEFFFFFFF, because that range is only 256 MB . The IFC address decode must be expanded so both 256 MB devices fit without overlap
So, To support 512 MB total NOR on T2081 with two 256 MB chips, expand the LAW to 512 MB, keep CS0 and CS1 as separate 256 MB IFC banks with non-overlapping CSPR/AMASK settings, keep boot on CS0, and update U-Boot/TLB/device-tree mappings to the new combined range.
%3CLINGO-SUB%20id%3D%22lingo-sub-2370175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ET2081%20512MB%20NOR%20Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20am%20currently%20working%20on%20the%20T2081%20NOR%20flash%20configuration%20with%20two%20NOR%20chips%20connected%20on%20the%20board%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3ECS0%20%E2%80%93%20256MB%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ECS1%20%E2%80%93%20256MB%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EAs%20of%20now%2C%20the%20256MB%20NOR%20flash%20on%20CS0%20is%20working%20correctly.%3C%2FP%3E%3CP%3EThe%20configured%20address%20range%20is%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E0xE0000000%20to%200xEFFFFFFF%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EFor%20booting%2C%20we%20are%20currently%20using%20the%20128MB%20region%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E0xE8000000%20to%200xEFFFFFFF%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3ENow%2C%20I%20would%20like%20to%20increase%20the%20NOR%20flash%20size%20to%20512MB.%20Could%20you%20please%20let%20me%20know%20what%20changes%20are%20required%20for%20this%20update%3F%3C%2FP%3E%3CP%3EThanks%20and%20Regards%2C%3CBR%20%2F%3ERavindra%20Arumilli%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2370850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20T2081%20512MB%20NOR%20Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EYes%20%E2%80%94For%20T2081%2C%20with%20CS0%20at%200xE0000000%E2%80%930xEFFFFFFF%2C%20the%20correct%20non-overlapping%20256%20MB%20CS1%20window%20is%200xF0000000%E2%80%930xFFFFFFFF%2C%20and%20the%20resulting%20512%20MB%20is%20valid%20as%20two%20adjacent%20IFC%20banks%20for%20runtime%20access%2C%20while%20boot%20still%20uses%20CS0%20only.%3C%2FP%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2370756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20T2081%20512MB%20NOR%20Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EHello%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EThank%20you%20for%20the%20clarification%20regarding%20the%20IFC%20NOR%20mapping%20for%20the%20T2081.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EWe%20plan%20to%20use%20CS0%20at%3A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3ECS0%20%3A%200xE0000000%20%E2%80%93%200xEFFFFFFF%20(256%20MB)%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ECould%20you%20please%20confirm%20what%20the%20recommended%20non-overlapping%20address%20range%20should%20be%20for%20CS1%20when%20using%20the%20second%20256%20MB%20NOR%20device%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ESince%20the%20total%20NOR%20size%20becomes%20512%20MB%2C%20we%20would%20like%20to%20confirm%20the%20correct%20expanded%20LAW%2FIFC%20address%20map%20for%20CS1%20and%20ensure%20the%20combined%20range%20is%20valid%20for%20boot%20and%20runtime%20access.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ERegards%3CBR%20%2F%3E%3C%2FSPAN%3ERavindra%20Arumilli%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2370237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20T2081%20512MB%20NOR%20Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%20class%3D%22animate-fade-in%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ETo%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eincrease%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eyour%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ET2081%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EIFC%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ENOR%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Espace%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Efrom%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E256%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eto%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E512%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eusing%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Etwo%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E256%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ENOR%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Edevices%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eon%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ECS0%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eand%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ECS1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Erequired%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Echanges%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eare%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3COL%20class%3D%22animate-fade-in%22%3E%0A%3CLI%20class%3D%22animate-fade-in%22%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EExpand%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EIFC%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ememory%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Emap%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eto%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ecover%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Efull%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E512%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ewindow%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22animate-fade-in%22%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EProgram%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ECS0%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eand%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ECS1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ewith%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Enon-overlapping%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EIFC%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ebase%2Fmask%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Esettings%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22animate-fade-in%22%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMake%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ELAW%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ewindow%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Elarge%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eenough%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eto%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ecover%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ecombined%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EIFC%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Erange%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22animate-fade-in%22%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EUpdate%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EU-Boot%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%2F%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ELinux%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Edevice%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Etree%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Epartitioning%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eto%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ereflect%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Enew%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Emap%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22animate-fade-in%22%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EKeep%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eboot%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eon%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ECS0%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ebecause%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ENOR%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eboot%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Euses%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ECS0%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eas%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eboot%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Echip-select%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%2C%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%20class%3D%22animate-fade-in%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EThe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ekey%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ecorrection%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Efirst%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Efor%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ET2081%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ENOR%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eboot%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eavailable%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Edocumentation%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Esays%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Evalid%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Edefault%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ENOR%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Emap%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eis%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E0xE8000000%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eto%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E0xEFFFFFFF%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Efor%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ea%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E128%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eboot%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ENOR%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Esetup%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eand%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ENXP%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eguidance%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Efor%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E256%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ENOR%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eis%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eto%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Euse%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E0xE0000000%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eto%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E0xEFFFFFFF%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ESince%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eyou%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Enow%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ewant%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Etwo%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ex%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E256%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E512%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Etotal%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eyou%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eshould%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Enot%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eleave%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ecombined%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Emap%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eat%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eonly%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E0xE0000000%E2%80%930xEFFFFFFF%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ebecause%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ethat%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Erange%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eis%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eonly%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E256%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E.%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EThe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EIFC%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eaddress%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Edecode%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Emust%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ebe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eexpanded%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eso%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eboth%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E256%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Edevices%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Efit%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ewithout%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eoverlap%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20class%3D%22animate-fade-in%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ESo%2C%26nbsp%3BTo%20support%20512%20MB%20total%20NOR%20on%20T2081%20with%20two%20256%20MB%20chips%2C%20expand%20the%20LAW%20to%20512%20MB%2C%20keep%20CS0%20and%20CS1%20as%20separate%20256%20MB%20IFC%20banks%20with%20non-overlapping%20CSPR%2FAMASK%20settings%2C%20keep%20boot%20on%20CS0%2C%20and%20update%20U-Boot%2FTLB%2Fdevice-tree%20mappings%20to%20the%20new%20combined%20range.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20class%3D%22animate-fade-in%22%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2375826%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20T2081%20512MB%20NOR%20Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2375826%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20the%20information.%3C%2FP%3E%3CP%3EThe%20proposed%20CS1%20window%20%3CSTRONG%3E0xF0000000%E2%80%930xFFFFFFFF%3C%2FSTRONG%3E%20is%20already%20being%20used%20by%20other%20interfaces%20in%20our%20design.%20Therefore%2C%20we%20are%20unable%20to%20assign%20this%20address%20range%20to%20IFC%20CS1.%3C%2FP%3E%3CP%3ECould%20you%20please%20advise%20on%20an%20alternative%20address%20range%20that%20can%20be%20used%20for%20CS1%20without%20overlapping%20with%20existing%20allocations%3F%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E
