T2081 512MB NOR Flash
1,022 次查看
arumilli
I am currently working on the T2081 NOR flash configuration with two NOR chips connected on the board:
  • CS0 – 256MB
  • CS1 – 256MB
As of now, the 256MB NOR flash on CS0 is working correctly.
The configured address range is:
  • 0xE0000000 to 0xEFFFFFFF
For booting, we are currently using the 128MB region:
  • 0xE8000000 to 0xEFFFFFFF
Now, I would like to increase the NOR flash size to 512MB. Could you please let me know what changes are required for this update?
Thanks and Regards,
Ravindra Arumilli
4 回复数
788 次查看
arumilli
Thank you for the information.
The proposed CS1 window 0xF0000000–0xFFFFFFFF is already being used by other interfaces in our design. Therefore, we are unable to assign this address range to IFC CS1.
Could you please advise on an alternative address range that can be used for CS1 without overlapping with existing allocations?
928 次查看
arumilli
Thank you for the clarification regarding the IFC NOR mapping for the T2081.
We plan to use CS0 at:
  • CS0 : 0xE0000000 – 0xEFFFFFFF (256 MB)
Could you please confirm what the recommended non-overlapping address range should be for CS1 when using the second 256 MB NOR device?
Since the total NOR size becomes 512 MB, we would like to confirm the correct expanded LAW/IFC address map for CS1 and ensure the combined range is valid for boot and runtime access.
Ravindra Arumilli
925 次查看
Bio_TICFSL
Yes —For T2081, with CS0 at 0xE0000000–0xEFFFFFFF, the correct non-overlapping 256 MB CS1 window is 0xF0000000–0xFFFFFFFF, and the resulting 512 MB is valid as two adjacent IFC banks for runtime access, while boot still uses CS0 only.
1,010 次查看
Bio_TICFSL
To increase your T2081 IFC NOR space from 256 MB to 512 MB using two 256 MB NOR devices on CS0 and CS1 , the required changes are:
  1. Expand the IFC memory map to cover the full 512 MB window
  2. Program CS0 and CS1 with non-overlapping IFC base/mask settings
  3. Make the LAW window large enough to cover the combined IFC range
  4. Update U-Boot / Linux device tree partitioning to reflect the new map
  5. Keep boot on CS0, because NOR boot uses CS0 as the boot chip-select ,,,,,
The key correction first: for T2081 NOR boot , the available documentation says the valid default NOR map is 0xE8000000 to 0xEFFFFFFF for a 128 MB boot NOR setup, and NXP guidance for 256 MB NOR is to use 0xE0000000 to 0xEFFFFFFF . Since you now want two x 256 MB = 512 MB total , you should not leave the combined map at only 0xE0000000–0xEFFFFFFF, because that range is only 256 MB . The IFC address decode must be expanded so both 256 MB devices fit without overlap
So, To support 512 MB total NOR on T2081 with two 256 MB chips, expand the LAW to 512 MB, keep CS0 and CS1 as separate 256 MB IFC banks with non-overlapping CSPR/AMASK settings, keep boot on CS0, and update U-Boot/TLB/device-tree mappings to the new combined range.
%3CLINGO-SUB%20id%3D%22lingo-sub-2370175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ET2081%20512MB%20%E6%88%96%E9%9D%9E%20%E9%97%AA%E5%AD%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6%20T2081%20NOR%20%E9%97%AA%E5%AD%98%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%B8%BB%E6%9D%BF%E4%B8%8A%E8%BF%9E%E6%8E%A5%E4%BA%86%E4%B8%A4%E4%B8%AA%20NOR%20%E8%8A%AF%E7%89%87%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3ECS0%20-%20256MB%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ECS1%20-%20256MB%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%EF%BC%8CCS0%20%E4%B8%8A%E7%9A%84%20256MB%20%E6%88%96%E9%9D%9E%20%E9%97%AA%E5%AD%98%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E9%85%8D%E7%BD%AE%E7%9A%84%E5%9C%B0%E5%9D%80%E8%8C%83%E5%9B%B4%E6%98%AF%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E0xE0000000%20%E8%87%B3%200xEFFFFFFF%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E4%B8%BA%E4%BA%86%E5%90%AF%E5%8A%A8%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9B%AE%E5%89%8D%E4%BD%BF%E7%94%A8%20128MB%20%E7%9A%84%E5%8C%BA%E5%9F%9F%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E0xE8000000%20%E8%87%B3%200xEFFFFFFF%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E6%83%B3%E5%B0%86%20NOR%20%E9%97%AA%E5%AD%98%E5%A4%A7%E5%B0%8F%E5%A2%9E%E5%8A%A0%E5%88%B0%20512MB%E3%80%82%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E8%BF%99%E6%AC%A1%E6%9B%B4%E6%96%B0%E9%9C%80%E8%A6%81%E5%81%9A%E5%93%AA%E4%BA%9B%E6%9B%B4%E6%94%B9%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E5%92%8C%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3ERavindra%20Arumilli%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2370850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20T2081%20512MB%20NOR%20Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%98%AF%20%E2%80%94%20%E5%AF%B9%E4%BA%8E%20T2081%EF%BC%8C%E5%BD%93%20CS0%20%E4%B8%BA%200xe0000000%E2%80%940xefffffff%20%E6%97%B6%EF%BC%8C%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%9D%9E%E9%87%8D%E5%8F%A0%20256%20MB%20CS1%20%E7%AA%97%E5%8F%A3%E6%98%AF%200xf0000000%E2%80%940xffffff%EF%BC%8C%E7%94%9F%E6%88%90%E7%9A%84%20512%20MB%20%E5%8F%AF%E7%94%A8%E4%BD%9C%E4%B8%A4%E4%B8%AA%E7%9B%B8%E9%82%BB%E7%9A%84%20IFC%20%E5%AD%98%E5%82%A8%E5%BA%93%E8%BF%9B%E8%A1%8C%E8%BF%90%E8%A1%8C%E6%97%B6%E8%AE%BF%E9%97%AE%EF%BC%8C%E8%80%8C%E5%90%AF%E5%8A%A8%E4%BB%8D%E4%BB%85%E4%BD%BF%E7%94%A8%20CS0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2370756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20T2081%20512MB%20NOR%20Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E4%BD%A0%E5%A5%BD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%AF%B9%20T2081%20%E7%9A%84%20IFC%20%E6%88%96%E9%9D%9E%20%E6%98%A0%E5%B0%84%E7%9A%84%E6%BE%84%E6%B8%85%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E4%BB%AC%E8%AE%A1%E5%88%92%E5%9C%A8%E4%BB%A5%E4%B8%8B%E5%9C%B0%E7%82%B9%E4%BD%BF%E7%94%A8%20CS0%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3ECS0%20%3A%200xE0000000%20-%200xEFFFFFFF%20(256%20MB)%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E7%A1%AE%E8%AE%A4%E4%BD%BF%E7%94%A8%E7%AC%AC%E4%BA%8C%E5%8F%B0%20256%20MB%20%E6%88%96%E9%9D%9E%20%E8%AE%BE%E5%A4%87%E6%97%B6%20CS1%20%E7%9A%84%E6%8E%A8%E8%8D%90%E9%9D%9E%E9%87%8D%E5%8F%A0%E5%9C%B0%E5%9D%80%E8%8C%83%E5%9B%B4%E5%BA%94%E8%AF%A5%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E7%94%B1%E4%BA%8E%20NOR%20%E6%80%BB%E5%A4%A7%E5%B0%8F%E5%8F%98%E4%B8%BA%20512%20MB%EF%BC%8C%E6%88%91%E4%BB%AC%E6%83%B3%E7%A1%AE%E8%AE%A4%20CS1%20%E7%9A%84%E6%AD%A3%E7%A1%AE%E6%89%A9%E5%B1%95%20LAW%2FIFC%20%E5%9C%B0%E5%9D%80%E6%98%A0%E5%B0%84%EF%BC%8C%E5%B9%B6%E7%A1%AE%E4%BF%9D%E7%BB%84%E5%90%88%E8%8C%83%E5%9B%B4%E5%AF%B9%E5%90%AF%E5%8A%A8%E5%92%8C%E8%BF%90%E8%A1%8C%E6%97%B6%E8%AE%BF%E9%97%AE%E6%9C%89%E6%95%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ERegards%3CBR%20%2F%3E%3C%2FSPAN%3ERavindra%20Arumilli%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2370237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20T2081%20512MB%20NOR%20Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%20class%3D%22animate-fade-in%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ETo%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eincrease%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eyour%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ET2081%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EIFC%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%88%96%E9%9D%9E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Espace%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Efrom%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E256%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eto%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E512%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eusing%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Etwo%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E256%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%88%96%E9%9D%9E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eon%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ECS0%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eand%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ECS1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ethe%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Erequired%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Echanges%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Eare%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3COL%20class%3D%22animate-fade-in%22%3E%0A%3CLI%20class%3D%22animate-fade-in%22%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%89%A9%E5%B1%95%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%9B%BD%E9%99%85%E9%87%91%E8%9E%8D%E4%B8%AD%E5%BF%83%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EIFC%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%86%85%E5%AD%98%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%9C%B0%E5%9B%BE%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E4%BB%A5%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E8%A6%86%E7%9B%96%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%95%B4%E4%B8%AA%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%85%A8%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E512%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E7%AA%97%E5%8F%A3%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22animate-fade-in%22%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ECS0%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%92%8C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ECS1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E4%B8%8E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E4%B8%8D%E9%87%8D%E5%8F%A0%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EIFC%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%9F%BA%E7%A1%80%2F%E6%8E%A9%E7%A0%81%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22animate-fade-in%22%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%88%B6%E4%BD%9C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E4%BD%BF%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3ELAW%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E7%AA%97%E5%8F%A3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E8%B6%B3%E5%A4%9F%E5%A4%A7%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E8%B6%B3%E5%A4%9F%E5%A4%A7%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E4%BB%A5%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E8%A6%86%E7%9B%96%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E7%9A%84%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E7%9A%84%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EIFC%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E8%8C%83%E5%9B%B4%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22animate-fade-in%22%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20U-Boot%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%2F%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20Linux%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E6%A0%91%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E5%88%86%E5%8C%BA%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E4%BB%A5%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E5%8F%8D%E6%98%A0%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%96%B0%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E5%9C%B0%E5%9B%BE%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22animate-fade-in%22%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%9C%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20CS0%20%E4%B8%8A%20%E7%BB%A7%E7%BB%AD%20%E5%90%AF%E5%8A%A8%20%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E5%9B%A0%E4%B8%BA%20%E6%88%96%E9%9D%9E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20CS0%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E4%BD%9C%E4%B8%BA%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E8%8A%AF%E7%89%87%E9%80%89%E6%8B%A9%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%EF%BC%8C%EF%BC%8C%EF%BC%8C%EF%BC%8C%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%20class%3D%22animate-fade-in%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E9%A6%96%E5%85%88%40%40%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E6%98%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E5%AF%86%E9%92%A5%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E6%9B%B4%E6%AD%A3%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%EF%BC%9A%20%E5%AF%B9%E4%BA%8E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20T2081%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E6%88%96%E9%9D%9E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E5%8F%AF%E7%94%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%96%87%E6%A1%A3%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%98%BE%E7%A4%BA%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E6%9C%89%E6%95%88%E7%9A%84%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E9%BB%98%E8%AE%A4%20%E6%88%96%E9%9D%9E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E6%98%A0%E5%B0%84%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E5%AF%B9%E4%BA%8E%20128%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E7%9A%84%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E6%88%96%E9%9D%9E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E8%AE%BE%E7%BD%AE%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E6%98%AF%200xE8000000%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E5%88%B0%200xEFFFFF%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%EF%BC%8C%2025%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%206%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20MB%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E6%88%96%E9%9D%9E%20%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E4%B8%BA%20%E6%88%96%E9%9D%9E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20R%20%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%E6%8C%87%E5%8D%97%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E6%98%AF%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%200xE0000000%20%E5%88%B0%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%200xE%20FFFFFF%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%9B%A0%E4%B8%BA%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E4%BD%A0%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E7%8E%B0%E5%9C%A8%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%83%B3%E8%A6%81%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E4%B8%A4%E4%B8%AA%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3Ex%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E256%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E512%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%80%BB%E8%AE%A1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E4%BD%A0%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E4%B8%8D%E5%BA%94%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E4%B8%8D%E8%A6%81%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E7%A6%BB%E5%BC%80%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%90%88%E5%B9%B6%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E7%BB%84%E5%90%88%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%9C%B0%E5%9B%BE%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%9C%A8%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E4%BB%85%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E0xE0000000%E2%80%930xEFFFFFFF%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%9B%A0%E4%B8%BA%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%9B%A0%E4%B8%BA%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E8%8C%83%E5%9B%B4%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E6%98%AF%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%8F%AA%E6%9C%89%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E256%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3EMB%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%BF%85%E9%A1%BB%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E6%89%A9%E5%B1%95%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20IFC%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E8%A7%A3%E7%A0%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%EF%BC%8C%20%E4%BB%A5%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E4%BD%BF%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E4%B8%A4%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E4%B8%AA%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20256%20MB%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E7%9A%84%20%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E9%83%BD%E8%83%BD%3C%2FSPAN%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%20%E5%AE%B9%E7%BA%B3%20%E4%B8%94%E4%B8%8D%E4%BC%9A%E9%87%8D%E5%8F%A0%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20class%3D%22animate-fade-in%22%3E%3CSPAN%20class%3D%22inline-block%20whitespace-pre-wrap%20animate-fade-in%22%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%A6%81%E5%9C%A8%E5%B8%A6%E6%9C%89%E4%B8%A4%E4%B8%AA%20256%20MB%20%E8%8A%AF%E7%89%87%E7%9A%84%20T2081%20%E4%B8%8A%E6%94%AF%E6%8C%81%E6%80%BB%E8%AE%A1%20512%20MB%20%E7%9A%84%20NOR%EF%BC%8C%E8%AF%B7%E5%B0%86%20LAW%20%E6%89%A9%E5%B1%95%E5%88%B0%20512%20MB%EF%BC%8C%E4%BF%9D%E7%95%99%20CS0%20%E5%92%8C%20CS1%20%E4%BD%9C%E4%B8%BA%E5%8D%95%E7%8B%AC%E7%9A%84%20256%20MB%20IFC%20Bank%EF%BC%8C%E4%BD%BF%E7%94%A8%20CSPR%2FAMASK%20%E8%AE%BE%E7%BD%AE%E4%B8%8D%E9%87%8D%E5%8F%A0%EF%BC%8C%E5%9C%A8%20CS0%20%E4%B8%8A%E7%BB%A7%E7%BB%AD%E5%90%AF%E5%8A%A8%EF%BC%8C%E5%B9%B6%E5%B0%86%20u-boot%2FTLB%2F%E8%AE%BE%E5%A4%87%E6%A0%91%E6%98%A0%E5%B0%84%E6%9B%B4%E6%96%B0%E5%88%B0%E6%96%B0%E7%9A%84%E7%BB%84%E5%90%88%E8%8C%83%E5%9B%B4%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20class%3D%22animate-fade-in%22%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2375826%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20T2081%20512MB%20NOR%20Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2375826%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E8%AE%BE%E8%AE%A1%E4%B8%AD%EF%BC%8C%E5%85%B6%E4%BB%96%E6%8E%A5%E5%8F%A3%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%E4%BA%86%E5%BB%BA%E8%AE%AE%E7%9A%84%20CS1%20%E7%AA%97%E5%8F%A3%3CSTRONG%3E0xF0000000-0xFFFFFFFF%3C%2FSTRONG%3E%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BB%AC%E6%97%A0%E6%B3%95%E5%B0%86%E6%AD%A4%E5%9C%B0%E5%9D%80%E8%8C%83%E5%9B%B4%E5%88%86%E9%85%8D%E7%BB%99%20IFC%20CS1%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%91%8A%E7%9F%A5%20CS1%20%E5%8F%AF%E4%BD%BF%E7%94%A8%E7%9A%84%E5%85%B6%E4%BB%96%E5%9C%B0%E5%9D%80%E8%8C%83%E5%9B%B4%EF%BC%8C%E4%B8%94%E4%B8%8D%E4%B8%8E%E7%8E%B0%E6%9C%89%E5%88%86%E9%85%8D%E9%87%8D%E5%8F%A0%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E
