I assume that you have CodeWarrior and CodeWarrior TAP.
Please create a bareboard project, in the Processing Model configuration panel , please select Core index as you required.
Please open CodeWarrior launch configuration from Run->Debug Configurations-><project>_RAM_<processor>_Download, please select multicores at Target Settings, then connect to the target board, the CodeWarrior demo program will be executed on each core.
TIC
