[T2080] : Error porting u-boot to Flash
Arathi
Hi NXP Support Team,
I am having a T2080 processor card and trying to boot from eSPI flash.
Configured the board to boot from Hardcoded boot mode and through Code warrior tool target tasks flash programmer window programmed and verified my RCW and u-boot contents into flash successfully.
Next Configured the board to boot from eSPI mode and found uboot to be getting hang. Below are the prints obtained on the serial terminal.
SPI boot...
_fixed_sdram
_fixed_sdram
Configuring DDR for 1599.840 MT/s data rate
calling fsl_ddr_set_memctl_regs
fsl_ddr_set_memctl_regs ddr3
fsl_ddr_set_memctl_regs completed..
set_ddr_laws completed..
ddr_size: 0x40000000
896.5 MiB left unmapped ddrreg
DDR_DDR_SDRAM_CFG: 0xc7200008
Loading second stage boot loader .................................................................................................
Copied
running uboot
Please let us know how we can proceed further.
Thanks and Regards,
Arathi
Priyaa
Hi Arathi,
How did you configure the T2080 custom board to boot from eSPI mode and uart for the u-boot prints??
is there any preferred offset locations to load the RCW and u-boot files in the flash?
And what u-boot file you used to load into the spi flash....can you please tell the procedure you followed..
Thank you
Priya
June_Lu
Please confirm you have done DDR validation with QCVS DDR.
QCVS_DDR_User_Guide
Arathi
Hi @June_Lu ,
We have done DDR validation with QCVS DDR tool by referring to the QCVS_DDR_User_Guide document.
Arathi
%3CLINGO-SUB%20id%3D%22lingo-sub-1752479%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BT2080%5D%20%3A%20Error%20porting%20u-boot%20to%20Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1752479%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3BNXP%20Support%20Team%2C%3C%2FP%3E%3CP%3EI%20am%20having%20a%20T2080%20processor%20card%20and%20trying%20to%20boot%20from%20eSPI%20flash.%3C%2FP%3E%3CP%3EConfigured%20the%20board%20to%20boot%20from%20Hardcoded%20boot%20mode%20and%20through%20Code%20warrior%20tool%20target%20tasks%20flash%20programmer%20window%26nbsp%3Bprogrammed%20and%20verified%20my%20RCW%20and%20u-boot%20contents%20into%20flash%20successfully.%3C%2FP%3E%3CP%3ENext%20Configured%20the%20board%20to%20boot%20from%20eSPI%20mode%20and%20found%20uboot%20to%20be%20getting%20hang.%20Below%20are%20the%20prints%20obtained%20on%20the%20serial%20terminal.%3C%2FP%3E%3CDIV%3E%3CSTRONG%3ESPI%20boot...%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E_fixed_sdram%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E_fixed_sdram%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3EConfiguring%20DDR%20for%201599.840%20MT%2Fs%20data%20rate%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3EConfiguring%20DDR%20for%201599.840%20MT%2Fs%20data%20rate%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3Ecalling%20fsl_ddr_set_memctl_regs%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3Efsl_ddr_set_memctl_regs%20ddr3%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3Efsl_ddr_set_memctl_regs%20completed..%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3Eset_ddr_laws%20completed..%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3Eddr_size%3A%200x40000000%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E896.5%20MiB%20left%20unmapped%20ddrreg%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3EDDR_DDR_SDRAM_CFG%3A%200xc7200008%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3ELoading%20second%20stage%20boot%20loader%20.................................................................................................%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3ECopied%26nbsp%3B%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3Erunning%20uboot%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EPlease%20let%20us%20know%20how%20we%20can%20proceed%20further.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EThanks%20and%20Regards%2C%3CBR%20%2F%3EArathi%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BT2080%5D%20%3A%20Error%20porting%20u-boot%20to%20Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Arathi%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EHow%20did%20you%20configure%20the%20T2080%20custom%20board%20to%20boot%20from%20eSPI%20mode%20and%20uart%20for%20the%20u-boot%20prints%3F%3F%3CBR%20%2F%3E%3CBR%20%2F%3Eis%20there%20any%20preferred%20offset%20locations%20to%20load%20the%20RCW%20and%20u-boot%20files%20in%20the%20flash%3F%3C%2FP%3E%3CP%3EAnd%20what%20u-boot%20file%20you%20used%20to%20load%20into%20the%20spi%20flash....can%20you%20please%20tell%20the%20procedure%20you%20followed..%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EThank%20you%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3ERegards%2C%3CBR%20%2F%3EPriya%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1757310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BT2080%5D%20%3A%20Error%20porting%20u-boot%20to%20Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1757310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F204495%22%20target%3D%22_blank%22%3E%40June_Lu%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EWe%20have%20done%20DDR%20validation%20with%20QCVS%20DDR%20tool%20by%20referring%20to%20the%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fuser-guide%2FQCVS_DDR_User_Guide.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EQCVS_DDR_User_Guide%3C%2FA%3E%26nbsp%3Bdocument.%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%2C%3CBR%20%2F%3EArathi%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1754977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BT2080%5D%20%3A%20Error%20porting%20u-boot%20to%20Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1754977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EPlease%20confirm%20you%20have%20done%20DDR%20validation%20with%20QCVS%20DDR.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fuser-guide%2FQCVS_DDR_User_Guide.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EQCVS_DDR_User_Guide%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
