T1042 Device RGMII
T1042 Device RGMII
3,524 次查看
vishwadeep_ns
Dear Concern,
We are working on  NXP T1042 PowerPC Module located on a custom baseboard.
Both module and baseboard are new designs. Here we are facing an issue with RGMII ports issue. (EC1: fm1-mac3 & EC2:fm1-mac4).
We are using DP83867 PHY.
Attached log file.
Need support ASAP.
Thank you
8 回复数
3,302 次查看
vishwadeep_ns
Hi ufedor,
PFA for DTS file.
EC1 PHY address : 00001110b (0e)
EC2 PHY address : 00000101b (05)
PHY : DP83867
Thank you
3,302 次查看
ufedor
Please check that you are able to access the RGMII PHY's registers in U-Boot.
In the described case it is convenient to create a Technical Case:
1)    open www.nxp.com
2)    Select "Support" -> "All Support Options"
3)    Click "Go to Tickets"
4)    Log in with your NXP login and password
5)    On the "Group, Create and View your support cases" page press "+ Add a new case" to start the process.
3,302 次查看
ufedor
Please provide the DTS being used for inspection.
3,302 次查看
vishwadeep_ns
Hi ufedor,
PFA for your information.
Let me know your suggestions.
Thanks for your support.
3,302 次查看
ufedor
The request was to provide Device Tree Source (DTS) file.
Please also provide the processor's connection schematics for inspection as searchable PDF and explain which addresses were projected for each PHY.
3,302 次查看
vishwadeep_ns
Hi ufedor,
Could you please provide your mail id.
We will share it to your mail.
Thank you.
3,302 次查看
vinothkumars
Senior Contributor IV
Hi  [email protected]‌,
Please check the phy address of your dts file. First you will debug with u-boot itself (check u-boot configuration file for phy address provided right or wrong?)
Thanks & Regards,
VinothS.
Vinothkumar Sekar
3,302 次查看
vishwadeep_ns
Hi Vinoth S,
I am new to this T1042.
How can i see the dts file.
How to check the phy address in dts file
Could you please let me know the some more information how to check in
dts file.
Thanks for your help.
