T-series performance benchmark /DMIPS/
milan
As far as I know performance data are not an integral part of T1042/T2080 documentation. I’ve only succeeded in finding
https://www.nxp.com/files-static/training/doc/ftf/2014/FTF-NET-F0140.pdf
and
https://www.nxp.com/files-static/training/doc/ftf/2014/FTF-NET-F0032.pdf
presentations from 2014.
Some designers indicate that the DMIPS/MHz factors of 3 and 6 appear to be overstated based on their experimental measurements in the lab.
Question:
What is the latest and greatest performance benchmark /DMIPS/ for the T1042/T2080 single core in 64-bit mode with and without hyperthreading?
Many thanks,
Milan
Labels (2)
ufedor
There is no document from NXP containing results for excessive Dhrystone benchmarking for the T2080.
The T2080 Fact Sheet also shows 6 DMIPS/MHz per core:
https://www.nxp.com/docs/en/fact-sheet/T2080FS.pdf
