I need to compile the macsec userspace application named "hostapd" and "wpa-supplicant" for t2080rdb board.
I tried to use latest yocto version 2.7 (warrior) with the meta-freescale recipes to build this application.
My yocto version is 2.7 and meta-freescale branch is warrior or master.
But during bitbake build I got an nonsense error while compiling glibc,
My first question is does nxp still compatible with latest yocto versions?
If it is not compatible how can I build an specific application with using flex-build?
Any help is appreciated.
已解决! 转到解答。
I have tested using Ubuntu 14-64bit.
The following command sequence was used.
build-essential chrpath socat cpio python python3 python3-pip python3-pexpect \
xz-utils debianutils iputils-ping libsdl1.2-dev xterm
1. Get the Yocto layers from repo manifest: The following is the step of how to use repo utility to download all Yocto layers according to the repo manifest Install the repo utility: $: mkdir ~/bin $: curl https://storage.googleapis.com/git-repo-downloads/repo > ~/bin/repo $: chmod a+x ~/bin/repo Download the Yocto layers: $: export PATH=${PATH}:~/bin $: mkdir yocto-sdk $: cd yocto-sdk $: repo init -u https://source.codeaurora.org/external/qoriq/qoriq-components/yocto-sdk -b thud $: repo sync --no-clone-bundle 2. Get Yocto layers from community repository The following is the step of how to download all Yocto layers through git command: $: mkdir yocto-sdk $: cd yocto-sdk $: mkdir sources $: cd sources $: git clone git://git.yoctoproject.org/poky $: cd poky $: git reset --hard eddff2b361928e88e3628ebc22a1a0ebb119e01b $: cd .. $: git clone git://git.openembedded.org/meta-openembedded $: cd meta-openembedded $: git reset --hard f1511d254632a34c1deb51f4bf8b8c21e7423f51 $: cd .. $: git clone git://git.yoctoproject.org/meta-freescale $: cd meta-freescale $: git reset --hard 9c801795c886578bc4cd72d040143b18532b145d $: cd .. $: git clone git://git.yoctoproject.org/meta-virtualization $: cd meta-virtualization $: git reset --hard f226bea1083b2bf7373ac7e4780459d454830cc4 $: cd .. $: git clone git://git.yoctoproject.org/meta-cloud-services $: cd meta-cloud-services $: git reset --hard 5dec08769e026980e3b5d3217dbbe2ebd87bf33c $: cd .. $: git clone git://git.yoctoproject.org/meta-security $: cd meta-security $: git reset --hard dcb0395033e1b4a5d44d467d041114c5cb5e13eb $: cd .. $: git clone https://github.com/Freescale/meta-freescale-distro $: cd meta-freescale-distro $: git reset --hard 771fb6d4c0c9530083fcc8c5452270bb9b3915ba $: cd .. $: git clone https://source.codeaurora.org/external/qoriq/qoriq-components/meta-qoriq-demos $: cd meta-qoriq-demos $: git reset --hard 62ccd769d5a6a9f7255e1626a4d0ba7229355f18 $: cd .. $: cp sources/meta-qoriq-demos/scripts/setup-env ./ Building images===============Take ls1088ardb as an example:$: . ./setup-env -m ls1088ardb$: bitbake fsl-image-networking
Pavel Chubakov
This thread is continued as a private discussion with the submitter,
NXP support is not following the thread anymore.
Pavel Chubakov
Look at the following page about new Yocto for T2080:
https://source.codeaurora.org/external/qoriq/qoriq-components/yocto-sdk/about/
Pavel Chubakov
