I am trying to determine if there is hardware support on the T4240 for PTP packets over Ethernet, i.e., IEEE 1588 Annex F. In chapter 7 in the DPAA ref manual, there is an example with PTP over UDP, i.e., IEEE 1588 Annex E.
Cheers,
Solved! Go to Solution.
Timestamping and Fman frame parser work independently and at different levels. A timestamp can by created for any packet
regardless of it's format and FMAN can be configured to recognize any packet including PTP over Ethernet.
Platon
Platon
