I'm trying to understand how bypass initialization works. But, There is not enough information in T1042 reference manual. I need to bypass the initialization process for SDRAM after re-initialize the system. When I reset the board, CPLD resets the whole board component, including SDRAM. I want to do not reset the SDRAM for hot start according to my design. Is this possible with reference design board ?
I must use the data that is written before system reset. Therefore, Is it enough to sets BI bit and re-sets all configuration register after the reset ? If it's enough, What is the meaning of the following sentence ?
"Initialization routine will be bypassed, software is responsible for initializing memory through DDR_SDRAM_MD_CTRL register."
Should I sets DDR_SDRAM_MD_CTRL for this issue?
Thanks.
解決済! 解決策の投稿を見る。
Not possible.
Firmware does not distinguish power-on reset and CPLD reset because the same PORESET_B is asserted.
If DDR SDRAM devices are already initialized - no.
Not possible.
