Do not assume that E9171 + AMDGPU on a T1040 platform supports FPGA→GPU PCIe P2P DMA. Based on currently available AMDGPU information, direct FPGA-to-AMDGPU P2P is not generally supported as a standard AMDGPU feature in the same way that NVIDIA GPUDirect RDMA is.
- Does AMDGPU support PCIe Peer-to-Peer (P2P)?
AMDGPU does contain Linux P2P infrastructure support (PCI_P2PDMA) and AMD KFD has an HSA_AMD_P2P option, but this support is primarily documented for:
- AMD GPU ↔ AMD GPU communication
- ROCm/HSA compute environments
- Platforms where the GPU exposes a large BAR and the platform/chipset allows PCIe P2P routing
The Linux Kconfig description explicitly mentions P2P communication between AMD GPUs.
- FPGA → AMD GPU direct DMA?
AMD engineers have publicly stated that:
achieving P2P between Xilinx FPGA and AMD GPU is currently not directly supported
and suggested a host-memory registration workaround instead of true device-to-device PCIe DMA.
Therefore:
Path
Status
AMD GPU ↔ AMD GPU
Supported on specific ROCm platforms
FPGA ↔ AMD GPU direct PCIe DMA
Not generally supported by AMDGPU
FPGA → Host DDR → GPU
Supported
FPGA P2P buffer mapped into host memory and registered with GPU
- Does T1040 support PCIe P2P?
From the T1040 side, PCIe hardware itself can forward Memory Read/Write TLPs between endpoints through a switch if:
- the PCIe switch allows P2P routing,
- ACS redirect is disabled (depends on switch),
- address translation is configured correctly.
PCIe as a protocol does not prevent endpoint-to-endpoint transfers. However, T1040/NXP software does not automatically provide AMDGPU-FPGA P2P support. The critical question is whether:
- AMDGPU exports GPU memory for third-party DMA access.
- FPGA QDMA can obtain GPU BAR/VRAM physical addresses.
- Linux IOMMU/P2PDMA path accepts the transaction.
The AMDGPU limitation is typically the blocking factor rather than the T1040 PCIe controller itself.
- What is likely to work on your system?
Current topology:
PCIe Switch
FPGA(QDMA) E9171 GPU
T1040 RC
Most likely supported flow:
FPGA ---> DDR (T1040 memory)
v
AMDGPU DMA
VRAM
Not guaranteed to work:
FPGA(QDMA) ---> GPU VRAM
because AMDGPU generally does not expose a GPUDirect-RDMA-like interface for arbitrary FPGA devices.
