license authorizaton
1,471 次查看
assangeye
when i install the software completely ,finding license authorizaton ,it tells me there is a err.Now my code is over 32K and  i have a license,but i can't use it .how can  do it?
1,242 次查看
TomasPaez
License file needs to be placed in the following directory,
You can discard the help menu option for license authorization.
Just locate a valid license file in the following directory C:\Program Files (x86)\Freescale\CWS12v5.1
Make sure you have admin access so you can write in program files directory, if not check with the local admin to get this.
hope this helps
